  4. nach dem Update, geht nichts mehr.....
44 Beiträge 7 Kommentatoren 5.4k Aufrufe 5 Beobachtet
  • Z Zimbl
    ah ok...vielen Dank...
    So hier das Ergebnis :
                            v.2024-12-09 Raspbian+zigbee diag+masking
       Static hostname: raspberrypi
             Icon name: computer
      Operating System: Raspbian GNU/Linux 11 (bullseye)
                Kernel: Linux 6.1.21-v7+
          Architecture: arm
    Kernel:                 armv7l
    Userland:               32 bit
    Timezone:               Europe/Berlin (CET, +0100)
    User-ID:                1000
    Display-Server:         false
    Boot Target:            multi-user.target
    Pending OS-Updates:     0
    internal/modules/cjs/loader.js:781
          throw new ERR_UNKNOWN_BUILTIN_MODULE(filename);
    Error [ERR_UNKNOWN_BUILTIN_MODULE]: No such built-in module: node:timers/promises
        at new NodeError (internal/errors.js:322:7)
        at Function.Module._load (internal/modules/cjs/loader.js:781:13)
        at Module.require (internal/modules/cjs/loader.js:1003:19)
        at require (internal/modules/cjs/helpers.js:107:18)
        at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker/js-controller-cli/build/lib/setup/dbConnection.js:34:20)
        at Module._compile (internal/modules/cjs/loader.js:1114:14)
        at Object.Module._extensions..js (internal/modules/cjs/loader.js:1143:10)
        at Module.load (internal/modules/cjs/loader.js:979:32)
        at Function.Module._load (internal/modules/cjs/loader.js:819:12)
        at Module.require (internal/modules/cjs/loader.js:1003:19) {
      code: 'ERR_UNKNOWN_BUILTIN_MODULE'
    Pending iob updates:    0
    Nodejs-Installation:
    /usr/bin/nodejs         v14.21.3
    /usr/bin/node           v14.21.3
    /usr/bin/npm            6.14.18
    /usr/bin/npx            6.14.18
    /usr/bin/corepack       0.15.1
    Recommended versions are nodejs  and npm
    nodeJS installation is correct
    MEMORY:
    Mem:            921M         57M        248M        0.0K        615M        799M
    Swap:            99M        2.0M         97M
    Total:          1.0G         59M        346M
    Active iob-Instances:   0
    ioBroker Core:          js-controller
                            admin
    ioBroker Status:
    Objects:                0
    States:                 0
    Size of iob-Database:
    9.9M    /opt/iobroker/iobroker-data/objects.jsonl
    200K    /opt/iobroker/iobroker-data/states.jsonl
    1 CRITICAL ERRORS DETECTED!
    Check 'sudo dmesg --level=emerg,alert,crit -T' for details
    Debian 'bullseye' is the current oldstable version. Please upgrade to the latest stable release 'bookworm' in due time!
    @zimbl sagte in nach dem Update, geht nichts mehr.....:
    Die Langfassung.
    Nachdem du
    iob nodejs-update 20
    ausgeführt hast.
    Z 1 Antwort Letzte Antwort
      Die Langfassung.
      Nachdem du
      ausgeführt hast.
      Z Offline
      Z Offline
      Zimbl
      ok ich führe aus.
      Vielleicht bekomme ich es ja noch hin, das es ein gutes System wird :-)
      • Z Zimbl
        ok ich führe aus.
        Das ist durch die abgehangene Hardware schon ausgeschlossen.
          Z Offline
          Z Offline
          Zimbl
          ok, wenn wir die mal ausklammern. Sagen wir es mal so, das es das beste wird, was man rausholen kann.
          Wenn ich z.b. eine neue Hardware kaufe, kann man dann eigentlich das Backup auch auf diese dann aufspielen ?
          • Z Zimbl
            Ein Backup nur des ioBrokers: Ja
            Ein 'Backup' (Klon) des gesamten Systems: Nein
              Z Offline
              Z Offline
              Zimbl
              also ich würde dann die Normale Installation inkl. IOBroker durchführen und dann die Backups ausführen..
              das würde aber dann funktionieren...
              Aber ein Pi5 mit 4 GB sollten dann aber auch erstmal dem Stand der Technik reichen,
              oder?
              • Z Zimbl
                oder?
                @zimbl
                Ja, dürfte mehr als ausreichend sein für deinen Anwendungsfall.
                Der Raspberry4 dürfte auch ausreichen.
                Unter 4GB würde ich allerdings nicht gehen.
                • Z Offline
                  Z Offline
                  Zimbl
                  ja man weiß ja nie, was da alles noch so kommt...
                  Bin dann eher jemand der nicht irgendwann wieder aufrüsten will...
                  IOB Diag läuft noch..
                  aber muss auch wieder über das Skript laufen, da der normale immer noch nicht läuft...
                  steht dann dort wieder, das ich den Fix durchführen muss, aber auch , nachdem ich
                  den Fix durchgeführt habe..
                  ```bash
                  Script v.2024-12-09 Raspbian+zigbee diag+masking
                  *** BASE SYSTEM ***
                           Icon name: computer
                        Architecture: arm
                  OS is similar to: debian
                  Model           : Raspberry Pi 2 Model B Rev 1.1
                  Docker          : false
                  Virtualization  : none
                  Kernel          : armv7l
                  Userland        : 32 bit
                  Systemuptime and Load:
                   18:14:20 up 12 min,  1 user,  load average: 0.37, 0.31, 0.28
                  CPU threads: 4
                  *** LIFE CYCLE STATUS ***
                  *** RASPBERRY THROTTLING ***
                  Current issues:
                  Previously detected issues:
                  ~ Under-voltage has occurred
                  ~ Arm frequency capping has occurred
                  *** TIME AND TIMEZONES ***
                                 Local time: Tue 2024-12-10 18:14:21 CET
                             Universal time: Tue 2024-12-10 17:14:21 UTC
                                   RTC time: n/a
                                NTP service: active
                            RTC in local TZ: no
                  *** Users and Groups ***
                  User that called 'iob diag':
                  pi
                  HOME=/home/pi
                  GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                  js-controller is not running
                  *** DISPLAY-SERVER SETUP ***
                  Desktop:
                  Terminal:       tty
                  *** MEMORY ***
                  Mem:            921M         59M        435M        0.0K        426M        797M
                  Swap:            99M          0B         99M
                  Total:          1.0G         59M        535M
                  Active iob-Instances:   1
                            921 M total memory
                             60 M used memory
                            241 M active memory
                            150 M inactive memory
                            435 M free memory
                             68 M buffer memory
                            358 M swap cache
                             99 M total swap
                              0 M used swap
                             99 M free swap
                  top - 18:14:21 up 12 min,  1 user,  load average: 0.37, 0.31, 0.28
                  Tasks: 120 total,   1 running, 119 sleeping,   0 stopped,   0 zombie
                  %Cpu(s):  2.5 us,  3.8 sy,  0.0 ni, 93.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                  MiB Mem :    922.0 total,    435.7 free,     60.0 used,    426.4 buff/cache
                  MiB Swap:    100.0 total,    100.0 free,      0.0 used.    797.1 avail Mem
                  *** FAILED SERVICES ***
                    UNIT             LOAD   ACTIVE SUB    DESCRIPTION
                  * iobroker.service loaded failed failed ioBroker Server
                  * rc-local.service loaded failed failed /etc/rc.local Compatibility
                  2 loaded units listed.
                  *** DMESG CRITICAL ERRORS ***
                  *** FILESYSTEM ***
                  /dev/root      ext4       59G  6.8G   50G  13% /
                  devtmpfs       devtmpfs  333M     0  333M   0% /dev
                  tmpfs          tmpfs     461M     0  461M   0% /dev/shm
                  tmpfs          tmpfs     185M  940K  184M   1% /run
                  /dev/mmcblk0p1 vfat      255M   51M  205M  20% /boot
                  tmpfs          tmpfs      93M     0   93M   0% /run/user/1000
                  [Tue Dec 10 18:02:05 2024] Kernel command line: coherent_pool=1M snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=Composite-1:720x480@60i vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyAMA0,115200 console=tty1 root=PARTUUID=a13bd72e-02 rootfstype=ext4 fsck.repair=yes rootwait
                  [Tue Dec 10 18:02:09 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                  [Tue Dec 10 18:02:09 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                  [Tue Dec 10 18:02:14 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                  Show mounted filesystems:
                  TARGET  SOURCE         FSTYPE OPTIONS
                  /       /dev/mmcblk0p2 ext4   rw,noatime
                  `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,ioc
                  /var:
                  2.2G    /var/
                  1.9G    /var/log/journal/b4db8c2bf1074a1ba2ba6c07d9465d9d
                  1.9G    /var/log
                  123M    /var/cache
                  Archived and active journals take up 1.8G in the file system.
                  /opt/iobroker/backups:
                  94M     /opt/iobroker/backups/
                  /opt/iobroker/iobroker-data:
                  804M    /opt/iobroker/iobroker-data/
                  720M    /opt/iobroker/iobroker-data/files
                  617M    /opt/iobroker/iobroker-data/files/javascript.admin
                  560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
                  558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                  22M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.578d79d9.js.map
                  12M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.bd24114f.js
                  8.8M    /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.578d79d9.js
                  8.7M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/838.0aa41cb0.chunk.js.map
                  USB-Devices by-id:
                  /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_ceccc8e6cbc9eb119edf8b4f1d69213e-if00-port0
                  *** ZigBee Settings ***
                  Your zigbee.0 COM-Port is matching 'by-id'. Very good!
                  zigbee.X
                  Extended Pan ID:
                  *** MASKED ***
                  Pan ID:
                  *** MASKED ***
                  Channel:
                  *** MASKED ***
                  Network Key:
                  *** MASKED ***
                  *** NodeJS-Installation ***
                  /usr/bin/nodejs         v20.18.1
                  /usr/bin/node           v20.18.1
                  /usr/bin/npm            10.8.2
                  /usr/bin/npx            10.8.2
                  /usr/bin/corepack       0.29.4
                  nodejs:
                    Installed: 20.18.1-1nodesource1
                    Candidate: 20.18.1-1nodesource1
                    Version table:
                   *** 20.18.1-1nodesource1 600
                          500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages
                       20.18.0-1nodesource1 600
                       20.17.0-1nodesource1 600
                       20.16.0-1nodesource1 600
                       20.15.1-1nodesource1 600
                       20.15.0-1nodesource1 600
                       20.14.0-1nodesource1 600
                       20.13.1-1nodesource1 600
                       20.13.0-1nodesource1 600
                       20.12.2-1nodesource1 600
                       20.12.1-1nodesource1 600
                       20.12.0-1nodesource1 600
                       20.11.1-1nodesource1 600
                       20.11.0-1nodesource1 600
                       20.10.0-1nodesource1 600
                       20.9.0-1nodesource1 600
                       20.8.1-1nodesource1 600
                       20.8.0-1nodesource1 600
                       20.7.0-1nodesource1 600
                       20.6.1-1nodesource1 600
                       20.6.0-1nodesource1 600
                       20.5.1-1nodesource1 600
                       20.5.0-1nodesource1 600
                       20.4.0-1nodesource1 600
                       20.3.1-1nodesource1 600
                       20.3.0-1nodesource1 600
                       20.2.0-1nodesource1 600
                       20.1.0-1nodesource1 600
                       20.0.0-1nodesource1 600
                       12.22.12~dfsg-1~deb11u5 500
                  No problems detected
                  Errors in npm tree: 0
                  *** ioBroker-Installation ***
                  ioBroker Status
                  iobroker is not running on this host.
                  Objects type: jsonl
                  States  type: jsonl
                  Hosts:
                  raspberrypi         raspberrypi (version: 5.0.19, hostname: raspberrypi   , alive, uptime: 45)
                  Core adapters versions
                  js-controller:  5.0.19
                  admin:          7.1.5
                  javascript:     8.8.3
                  nodejs modules from github:     0
                  Adapter State
                    system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                    system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
                    system.adapter.discovery.0              : discovery             : raspberrypi                              - disabled
                    system.adapter.gruenbeck.0              : gruenbeck             : raspberrypi                              - disabled
                    system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
                    system.adapter.modbus.0                 : modbus                : raspberrypi                              -  enabled
                    system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
                    system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
                    system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
                    system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
                    system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_ceccc8e6cbc9eb119edf8b4f1d69213e-if00-port0
                  + instance is alive
                  ioBroker-Repositories
                  Active repo(s): stable
                  Installed ioBroker-Instances
                  Used repository: stable
                  Adapter    "admin"        : 7.1.5    , installed 7.1.5
                  Adapter    "backitup"     : 3.0.25   , installed 3.0.25
                  Adapter    "deconz"       : 1.4.1    , installed 1.4.0  [Updatable]
                  Adapter    "discovery"    : 5.0.0    , installed 4.4.0  [Updatable]
                  Adapter    "gruenbeck"    : 0.0.43   , installed 0.0.42 [Updatable]
                  Adapter    "javascript"   : 8.8.3    , installed 8.8.3
                  Controller "js-controller": 7.0.3    , installed 5.0.19 [Updatable]
                  Adapter    "modbus"       : 6.3.2    , installed 6.1.0  [Updatable]
                  Adapter    "rpi2"         : 2.2.1    , installed 1.3.2  [Updatable]
                  Adapter    "shelly"       : 8.2.1    , installed 8.2.1
                  Adapter    "sonoff"       : 3.1.2    , installed 3.0.3  [Updatable]
                  Adapter    "tuya"         : 3.16.0   , installed 3.15.0 [Updatable]
                  Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
                  Objects and States
                  Objects:        957
                  States:         570
                  Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
                  Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                  Hit:3 https://deb.nodesource.com/node_20.x nodistro InRelease
                  Reading package lists... Done
                  Pending Updates: 0
                  *** Listening Ports ***
                  tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          11824      446/sshd: /usr/sbin
                  tcp6       0      0 :::22                   :::*                    LISTEN      0          11826      446/sshd: /usr/sbin
                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12579      344/avahi-daemon: r
                  udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          448        571/dhcpcd
                  udp        0      0 0.0.0.0:46688           0.0.0.0:*                           108        12581      344/avahi-daemon: r
                  udp6       0      0 :::5353                 :::*                                108        12580      344/avahi-daemon: r
                  udp6       0      0 :::58708                :::*                                108        12582      344/avahi-daemon: r
                  udp6       0      0 :::546                  :::*                                0          13728      571/dhcpcd
                  2024-12-10 18:03:09.660  - info: admin.0 (684) terminating
                  2024-12-10 18:03:09.737  - warn: host.raspberrypi instance system.adapter.rpi2.0 terminated due to SIGTERM
                  2024-12-10 18:03:09.739  - info: host.raspberrypi instance system.adapter.rpi2.0 terminated with code null ()
                  2024-12-10 18:03:09.741  - warn: host.raspberrypi instance system.adapter.tuya.0 terminated due to SIGTERM
                  2024-12-10 18:03:09.743  - info: host.raspberrypi instance system.adapter.tuya.0 terminated with code null ()
                  2024-12-10 18:03:09.746  - warn: host.raspberrypi instance system.adapter.zigbee.0 terminated due to SIGTERM
                  2024-12-10 18:03:09.747  - info: host.raspberrypi instance system.adapter.zigbee.0 terminated with code null ()
                  2024-12-10 18:03:09.827  - warn: admin.0 (684) get state error: Connection is closed.
                  2024-12-10 18:03:09.887  - warn: admin.0 (684) Could not perform strict object check of state admin.0.info.updatesJson: DB closed
                  2024-12-10 18:03:09.890  - warn: admin.0 (684) get state error: Connection is closed.
                  2024-12-10 18:03:09.895  - warn: admin.0 (684) Cannot check common objects: DB closed
                  2024-12-10 18:03:10.266  - info: host.raspberrypi instance system.adapter.javascript.0 terminated with code 0 (NO_ERROR)
                  2024-12-10 18:03:10.270  - info: host.raspberrypi instance system.adapter.backitup.0 terminated with code 0 (NO_ERROR)
                  2024-12-10 18:03:10.273  - info: host.raspberrypi instance system.adapter.modbus.0 terminated with code 0 (NO_ERROR)
                  2024-12-10 18:03:10.376  - info: host.raspberrypi instance system.adapter.ping.0 started with pid 817
                  2024-12-10 18:03:10.408  - info: host.raspberrypi instance system.adapter.admin.0 terminated with code 0 (NO_ERROR)
                  2024-12-10 18:03:17.864  - info: ping.0 (817) starting. Version 1.6.2 in /opt/iobroker/node_modules/iobroker.ping, node: v20.18.1, js-controller: 5.0.19
                  2024-12-10 18:03:17.941  - warn: ping.0 (817) Poll interval is too short. Reset to 5000 ms.
                  2024-12-10 18:03:21.717  - info: host.raspberrypi force terminating
                  2024-12-10 18:03:21.721  - info: host.raspberrypi Adapter ping still running
                  2024-12-10 18:03:24.399  - info: ping.0 (817) terminating with timeout
                  2024-12-10 18:03:24.407  - info: ping.0 (817) Terminated (NO_ERROR): Without reason
                  2024-12-10 18:03:26.556  - error: ping.0 (817) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                  2024-12-10 18:03:26.832  - warn: ping.0 (817) get state error: Connection is closed.
                  2024-12-10 18:03:26.840  - info: ping.0 (817) terminating
                  iob diag has finished.
                  Press any key for a summary
                  so was sollte ich nun noch durchführen ?
                  • Z Zimbl
                    ```bash
                    *** BASE SYSTEM ***
                             Icon name: computer
                          Architecture: arm
                    Docker          : false
                    Kernel          : armv7l
                    Userland        : 32 bit
                    CPU threads: 4
                    Current issues:
                                     RTC time: n/a
                                  NTP service: active
                              RTC in local TZ: no
                    pi
                    HOME=/home/pi
                    Desktop:
                    Terminal:       tty
                    *** MEMORY ***
                    Swap:            99M          0B         99M
                              921 M total memory
                               60 M used memory
                              241 M active memory
                              435 M free memory
                               68 M buffer memory
                              358 M swap cache
                               99 M total swap
                                0 M used swap
                               99 M free swap
                    *** FILESYSTEM ***
                    /var:
                    2.2G    /var/
                    1.9G    /var/log
                    123M    /var/cache
                    USB-Devices by-id:
                    zigbee.X
                    Extended Pan ID:
                    *** MASKED ***
                    Pan ID:
                    *** MASKED ***
                    Channel:
                    *** MASKED ***
                    Network Key:
                    *** MASKED ***
                    /usr/bin/npm            10.8.2
                    /usr/bin/npx            10.8.2
                    nodejs:
                      Version table:
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    Hosts:
                    admin:          7.1.5
                    javascript:     8.8.3
                    Adapter State
                    + instance is alive
                    Objects and States
                    Objects:        957
                    States:         570
                    Pending Updates: 0
                    @zimbl
                    iob update
                    iob upgrade all -y
                    iob stop
                    iob upgrade self
                    iob start
                    • Z Zimbl
                      ```bash
                      *** BASE SYSTEM ***
                               Icon name: computer
                            Architecture: arm
                      Docker          : false
                      Kernel          : armv7l
                      Userland        : 32 bit
                      CPU threads: 4
                      Current issues:
                                       RTC time: n/a
                                    NTP service: active
                                RTC in local TZ: no
                      pi
                      HOME=/home/pi
                      Desktop:
                      Terminal:       tty
                      *** MEMORY ***
                      Swap:            99M          0B         99M
                                921 M total memory
                                 60 M used memory
                                241 M active memory
                                435 M free memory
                                 68 M buffer memory
                                358 M swap cache
                                 99 M total swap
                                  0 M used swap
                                 99 M free swap
                      *** FILESYSTEM ***
                      /var:
                      2.2G    /var/
                      1.9G    /var/log
                      123M    /var/cache
                      USB-Devices by-id:
                      zigbee.X
                      Extended Pan ID:
                      *** MASKED ***
                      Pan ID:
                      *** MASKED ***
                      Channel:
                      *** MASKED ***
                      Network Key:
                      *** MASKED ***
                      /usr/bin/npm            10.8.2
                      /usr/bin/npx            10.8.2
                      nodejs:
                        Version table:
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      Hosts:
                      admin:          7.1.5
                      javascript:     8.8.3
                      Adapter State
                      + instance is alive
                      Objects and States
                      Objects:        957
                      States:         570
                      Pending Updates: 0
                      Ja, da ist ein 'Bug' drin. Deswegen ja die Testversion, da ist es behoben.
                        Z Offline
                        Z Offline
                        Zimbl
                        ah ok, danke für die Info Thomas...
                        die Updates laufen derzeit, danach führe ich wieder den DIAG aus...
                        • Z Zimbl
                          Z Offline
                          Z Offline
                          Zimbl
                          So ich habe wieder mal ein aktuelles Ergebnis :
                          ```bash
                          *** BASE SYSTEM ***
                                   Icon name: computer
                                Architecture: arm
                          Docker          : false
                          Kernel          : armv7l
                          Userland        : 32 bit
                           18:52:41 up 50 min,  1 user,  load average: 1.45, 1.87, 1.47
                          CPU threads: 4
                          Current issues:
                                         Local time: Tue 2024-12-10 18:52:41 CET
                                     Universal time: Tue 2024-12-10 17:52:41 UTC
                                           RTC time: n/a
                                        NTP service: active
                                    RTC in local TZ: no
                          pi
                          HOME=/home/pi
                          iobroker
                          HOME=/home/iobroker
                          Desktop:
                          Terminal:       tty
                          *** MEMORY ***
                          Mem:            921M        517M         75M        0.0K        328M        344M
                          Swap:            99M         92M        7.0M
                          Total:          1.0G        610M         82M
                          Active iob-Instances:   10
                                    921 M total memory
                                    517 M used memory
                                    300 M active memory
                                    466 M inactive memory
                                     74 M free memory
                                     22 M buffer memory
                                    307 M swap cache
                                     99 M total swap
                                     92 M used swap
                                      7 M free swap
                          top - 18:52:43 up 50 min,  1 user,  load average: 1.41, 1.86, 1.47
                          Tasks: 133 total,   1 running, 132 sleeping,   0 stopped,   0 zombie
                          %Cpu(s):  2.6 us,  3.9 sy,  0.0 ni, 93.4 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                          MiB Mem :    922.0 total,     74.4 free,    518.1 used,    329.4 buff/cache
                          MiB Swap:    100.0 total,      7.3 free,     92.7 used.    343.8 avail Mem
                          1 loaded units listed.
                          *** FILESYSTEM ***
                          /dev/root      ext4       59G  7.0G   49G  13% /
                          tmpfs          tmpfs     185M  944K  184M   1% /run
                          /var:
                          2.2G    /var/
                          1.9G    /var/log
                          123M    /var/cache
                          97M     /opt/iobroker/backups/
                          818M    /opt/iobroker/iobroker-data/
                          722M    /opt/iobroker/iobroker-data/files
                          24M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js.map
                          21M     /opt/iobroker/iobroker-data/objects.jsonl
                          9.3M    /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js
                          USB-Devices by-id:
                          zigbee.X
                          Extended Pan ID:
                          *** MASKED ***
                          Pan ID:
                          *** MASKED ***
                          Channel:
                          *** MASKED ***
                          Network Key:
                          *** MASKED ***
                          /usr/bin/npm            10.8.2
                          /usr/bin/npx            10.8.2
                          nodejs:
                            Version table:
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          Hosts:
                          raspberrypi         raspberrypi (version: 7.0.3, hostname: raspberrypi   , alive, uptime: 495)
                          js-controller:  7.0.3
                          admin:          7.1.5
                          javascript:     8.8.3
                          Adapter State
                          + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                          + system.adapter.modbus.0                 : modbus                : raspberrypi                              -  enabled
                          + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
                          + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
                          + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
                          + system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
                          + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_ceccc8e6cbc9eb119edf8b4f1d69213e-if00-port0
                          + instance is alive
                          Upgrade policy: none
                          Adapter    "deconz"       : 1.4.1    , installed 1.4.1
                          Adapter    "gruenbeck"    : 0.0.43   , installed 0.0.43
                          Controller "js-controller": 7.0.3    , installed 7.0.3
                          Adapter    "modbus"       : 6.3.2    , installed 6.3.2
                          Adapter    "rpi2"         : 2.2.1    , installed 2.2.1
                          Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
                          Adapter    "tuya"         : 3.16.0   , installed 3.16.0
                          Objects and States
                          Objects:        974
                          States:         665
                          Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                          Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
                          Pending Updates: 0
                          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       33968      3854/iobroker.js-co
                          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       33963      3854/iobroker.js-co
                          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       34103      3872/io.admin.0
                          udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       34921      3919/io.tuya.0
                          udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       34922      3919/io.tuya.0
                          udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       33344      3950/io.shelly.0
                          2024-12-10 18:51:53.743  - info: host.raspberrypi stopInstance system.adapter.rpi2.0 (force=false, process=true)
                          2024-12-10 18:51:53.811  - info: rpi2.0 (5014) Got terminate signal TERMINATE_YOURSELF
                          2024-12-10 18:51:53.828  - info: host.raspberrypi stopInstance system.adapter.rpi2.0 send kill signal
                          2024-12-10 18:51:53.823  - info: rpi2.0 (5014) terminating
                          2024-12-10 18:51:53.830  - info: rpi2.0 (5014) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                          2024-12-10 18:51:54.454  - info: rpi2.0 (5014) terminating
                          2024-12-10 18:51:54.529  - error: rpi2.0 (5014) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                          2024-12-10 18:51:54.531  - error: rpi2.0 (5014) unhandled promise rejection: DB closed
                          2024-12-10 18:51:54.540  - error: rpi2.0 (5014) Error: DB closed
                              at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:636:24)
                              at Redis.get (/opt/iobroker/node_modules/ioredis/built/commander.js:122:25)
                              at ObjectsInRedisClient._getObject (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/build/esm/lib/objects/objectsInRedisClient.js:2333:37)
                              at Immediate.<anonymous> (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/build/esm/lib/objects/objectsInRedisClient.js:2374:29)
                              at process.processImmediate (node:internal/timers:485:21)
                          2024-12-10 18:51:54.543  - error: rpi2.0 (5014) DB closed
                          2024-12-10 18:51:54.668  - info: host.raspberrypi instance system.adapter.rpi2.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                          2024-12-10 18:51:59.938  - info: host.raspberrypi instance system.adapter.rpi2.0 in version "2.2.1" started with pid 5085
                          2024-12-10 18:52:07.710  - info: rpi2.0 (5085) starting. Version 2.2.1 in /opt/iobroker/node_modules/iobroker.rpi2, node: v20.18.1, js-controller: 7.0.3
                          2024-12-10 18:53:10.144  - info: admin.0 (3872) ==> Connected system.user.admin from ::ffff:192.168.178.82
                          2024-12-10 18:53:11.238  - info: zigbee.0 (3932) List of port: [{"path":"/dev/ttyAMA0"},{"path":"/dev/ttyUSB0","manufacturer":"ITead","serialNumber":"ceccc8e6cbc9eb119edf8b4f1d69213e","pnpId":"usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_ceccc8e6cbc9eb119edf8b4f1d69213e-if00-port0","vendorId":"10c4","productId":"ea60"}]
                          2024-12-10 18:53:16.482  - info: admin.0 (3872) <== Disconnect system.user.admin from ::ffff:192.168.178.82
                          2024-12-10 18:53:24.487  - info: admin.0 (3872) ==> Connected system.user.admin from ::ffff:192.168.178.82
                          2024-12-10 18:53:46.635  - info: admin.0 (3872) <== Disconnect system.user.admin from ::ffff:192.168.178.82 javascript
                          2024-12-10 18:53:57.051  - info: admin.0 (3872) ==> Connected system.user.admin from ::ffff:192.168.178.82
                          2024-12-10 18:54:58.672  - warn: backitup.0 (3886) [iobroker/clean] No older backup files are deleted, because this backup was started manually
                          • Z Zimbl
                            ```bash
                            *** BASE SYSTEM ***
                                     Icon name: computer
                                  Architecture: arm
                            Docker          : false
                            Kernel          : armv7l
                            Userland        : 32 bit
                            CPU threads: 4
                            Current issues:
                                             RTC time: n/a
                                          NTP service: active
                                      RTC in local TZ: no
                            pi
                            HOME=/home/pi
                            iobroker
                            HOME=/home/iobroker
                            Desktop:
                            Terminal:       tty
                            *** MEMORY ***
                            Swap:            99M         92M        7.0M
                                      921 M total memory
                                      517 M used memory
                                      300 M active memory
                                       74 M free memory
                                       22 M buffer memory
                                      307 M swap cache
                                       99 M total swap
                                       92 M used swap
                                        7 M free swap
                            *** FILESYSTEM ***
                            /var:
                            2.2G    /var/
                            1.9G    /var/log
                            123M    /var/cache
                            USB-Devices by-id:
                            zigbee.X
                            Extended Pan ID:
                            *** MASKED ***
                            Pan ID:
                            *** MASKED ***
                            Channel:
                            *** MASKED ***
                            Network Key:
                            *** MASKED ***
                            /usr/bin/npm            10.8.2
                            /usr/bin/npx            10.8.2
                            nodejs:
                              Version table:
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            Hosts:
                            admin:          7.1.5
                            javascript:     8.8.3
                            Adapter State
                            + instance is alive
                            Objects and States
                            Objects:        974
                            States:         665
                            Pending Updates: 0
                            Schau dir den an.
                            • Z Zimbl
                              ```bash
                              *** BASE SYSTEM ***
                                       Icon name: computer
                                    Architecture: arm
                              Docker          : false
                              Kernel          : armv7l
                              Userland        : 32 bit
                              CPU threads: 4
                              Current issues:
                                               RTC time: n/a
                                            NTP service: active
                                        RTC in local TZ: no
                              pi
                              HOME=/home/pi
                              iobroker
                              HOME=/home/iobroker
                              Desktop:
                              Terminal:       tty
                              *** MEMORY ***
                              Swap:            99M         92M        7.0M
                                        921 M total memory
                                        517 M used memory
                                        300 M active memory
                                         74 M free memory
                                         22 M buffer memory
                                        307 M swap cache
                                         99 M total swap
                                         92 M used swap
                                          7 M free swap
                              *** FILESYSTEM ***
                              /var:
                              2.2G    /var/
                              1.9G    /var/log
                              123M    /var/cache
                              USB-Devices by-id:
                              zigbee.X
                              Extended Pan ID:
                              *** MASKED ***
                              Pan ID:
                              *** MASKED ***
                              Channel:
                              *** MASKED ***
                              Network Key:
                              *** MASKED ***
                              /usr/bin/npm            10.8.2
                              /usr/bin/npx            10.8.2
                              nodejs:
                                Version table:
                              ioBroker Status
                              Objects type: jsonl
                              States  type: jsonl
                              Hosts:
                              admin:          7.1.5
                              javascript:     8.8.3
                              Adapter State
                              + instance is alive
                              Objects and States
                              Objects:        974
                              States:         665
                              Pending Updates: 0
                              @zimbl
                              Grundsätzlich sollte das Ding jetzt wieder schnurren.
                                @zimbl
                                Z Offline
                                Z Offline
                                Zimbl
                                schrieb am zuletzt editiert von Zimbl
                                Hallo Thomas,
                                ich habe mir nun einen Pi5 geholt und mit dem PI Imager auch das
                                Image drauf gemacht, soweit auch alles wie immer Konfiguriert.
                                Was nur komisch ist, meine ETH0 Schnittstelle funktioniert nicht,
                                ich stecke das Kabel rein, aber nichts.
                                Keine Verbindung.
                                ich meine früher war die immer Standard aktiv.
                                ist das nun nicht mehr ?
                                • Z Zimbl
                                  Hallo Thomas,
                                  Keine Verbindung.
                                  @zimbl
                                  Ja, eine Ethernet-Schnittstelle ist i.d.R. aktiv.
                                  schau dir
                                  ip a
                                  und
                                  ifconfig
                                  an.
                                  • Z Zimbl
                                    Hallo Thomas,
                                    Keine Verbindung.
                                    auch keine Aktionen an den LED der Netzwerkbuchse?
                                      Z Offline
                                      Z Offline
                                      Zimbl
                                      Ne überhaupt nichts.
                                      Das komische ist irgendwie auch, das in der dhcpcd.conf auch nichts
                                      drin steht.
                                      Gut aber wenn die nicht aktiv ist, würden ja die LEDs auch
                                      nicht funktionieren..
                                      Mit dem PI Imager habe ich 64-Bit Light installiert...
                                      • Z Zimbl
                                        drin steht.
                                        @zimbl kann ja noch ein Hardwaredefekt sein.
                                        Allerdings hatte ich so einen Effekt mal bei Armbian.
                                        Mit einer Version funktionierte das Netzwerk nicht.
                                        Aber ich glaube nicht dass das hier auch so ist.
                                        drin steht.
                                        ich kann dir gar nicht sagen, welche Konfiguration im aktuellen OS verwendet wird.
                                        Gibts da nicht auch was in raspi-config?
                                          drin steht.
                                          Z Offline
                                          Z Offline
                                          Zimbl
                                          ja ich hatte das bisher auch noch nicht und wenn ich die Befehle ausführe die Thomas geschrieben hat, da kann man auch nicht sehen, das die Schnittstelle ein Problem hat.
                                          1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
                                              link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
                                              inet 127.0.0.1/8 scope host lo
                                                 valid_lft forever preferred_lft forever
                                              inet6 ::1/128 scope host noprefixroute
                                          2: eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc pfifo_fast state DOWN group default qlen 1000
                                              link/ether 2c:cf:67:97:18:01 brd ff:ff:ff:ff:ff:ff
                                          3: wlan0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
                                              link/ether 2c:cf:67:97:18:02 brd ff:ff:ff:ff:ff:ff
                                              inet 192.168.1.114/24 brd 192.168.1.255 scope global dynamic noprefixroute wlan0
                                                 valid_lft 863543sec preferred_lft 863543sec
                                              inet6 2001:9e:d5e8:9100:134b:4abc:41f3:b3b0/64 scope global dynamic noprefixroute
                                                 valid_lft 6747sec preferred_lft 3147sec
                                              inet6 fe80::4bfa:4f8a:169e:c02e/64 scope link noprefixroute
                                          Für mich sieht das so aus, das die Schnittstelle einen Defekt hat?
                                          oder?
                                          mcm1957M HomoranH Thomas BraunT 3 Antworten Letzte Antwort
