  4. Gelöst: Objekte-TAB braucht ewig zum laden
25 Beiträge 4 Kommentatoren 1.3k Aufrufe 3 Beobachtet
  • M michihorn
    *** BASE SYSTEM ***
       Static hostname: iobroker-pi
             Icon name: computer
      Operating System: Raspbian GNU/Linux 11 (bullseye)
                Kernel: Linux 6.1.21-v8+
          Architecture: arm64
    OS is similar to: debian
    Model           : Raspberry Pi 4 Model B Rev 1.5
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : 32 bit
    Systemuptime and Load:
     21:09:08 up  3:07,  1 user,  load average: 0.37, 0.39, 0.37
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Debian 'bullseye' is the current oldstable version. Please upgrade to the latest stable release 'bookworm' in due time!
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** TIME AND TIMEZONES ***
                   Local time: Mon 2024-11-25 21:09:08 CET
               Universal time: Mon 2024-11-25 20:09:08 UTC
                     RTC time: n/a
                    Time zone: Europe/Amsterdam (CET, +0100)
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    gthrn
    HOME=/home/gthrn
    GROUPS=gthrn adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    iobroker
    HOME=/home/iobroker
    *** DISPLAY-SERVER SETUP ***
    Display-Server: false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            7.9G        1.3G        5.4G        1.0M        1.2G        6.4G
    Swap:            99M          0B         99M
    Total:          8.0G        1.3G        5.5G
    Active iob-Instances:   23
             7862 M total memory
             1310 M used memory
             1362 M active memory
              920 M inactive memory
             5376 M free memory
              136 M buffer memory
             1038 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    top - 21:09:09 up  3:07,  1 user,  load average: 0.37, 0.39, 0.37
    Tasks: 163 total,   1 running, 162 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  1.5 us,  2.9 sy,  0.0 ni, 95.6 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   7862.2 total,   5377.3 free,   1309.7 used,   1175.2 buff/cache
    MiB Swap:    100.0 total,    100.0 free,      0.0 used.   6429.6 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    /dev/root      ext4       59G  9.7G   47G  18% /
    devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
    tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
    tmpfs          tmpfs     1.6G  1.1M  1.6G   1% /run
    /dev/sda1      vfat      255M   51M  205M  20% /boot
    tmpfs          tmpfs     787M     0  787M   0% /run/user/1000
    [Mon Nov 25 18:01:17 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:DE:B0:AA vc_mem.mem_base=0x3f000000 vc_mem.mem_size=0x3f600000  console=ttyS0,115200 console=tty1 root=PARTUUID=c7239adf-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Mon Nov 25 18:01:20 2024] EXT4-fs (sda2): INFO: recovery required on readonly filesystem
    [Mon Nov 25 18:01:20 2024] EXT4-fs (sda2): write access will be enabled during recovery
    [Mon Nov 25 18:01:20 2024] EXT4-fs (sda2): orphan cleanup on readonly fs
    [Mon Nov 25 18:01:20 2024] EXT4-fs (sda2): 7 orphan inodes deleted
    [Mon Nov 25 18:01:20 2024] EXT4-fs (sda2): recovery complete
    [Mon Nov 25 18:01:21 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
    [Mon Nov 25 18:01:21 2024] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
    [Mon Nov 25 18:01:23 2024] EXT4-fs (sda2): re-mounted. Quota mode: none.
    Show mounted filesystems:
    TARGET  SOURCE    FSTYPE OPTIONS
    /       /dev/sda2 ext4   rw,noatime
    `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    1.2G    /var/
    531M    /var/log
    529M    /var/log/journal/3f7e426fbacf414fbfbc4f1541fa25b4
    451M    /var/cache
    Archived and active journals take up 528.1M in the file system.
    /opt/iobroker/backups:
    516M    /opt/iobroker/backups/
    4.0K    /opt/iobroker/backups/zigbee_0
    /opt/iobroker/iobroker-data:
    1.3G    /opt/iobroker/iobroker-data/
    1.2G    /opt/iobroker/iobroker-data/files
    617M    /opt/iobroker/iobroker-data/files/javascript.admin
    560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
    558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
    41M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
    30M     /opt/iobroker/iobroker-data/objects.jsonl
    29M     /opt/iobroker/iobroker-data/files/telegram-menu.admin/build/index.js.map
    28M     /opt/iobroker/iobroker-data/states.jsonl
    19M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.6964fae2.js.map
    USB-Devices by-id:
    No Devices found 'by-id'
    HINT:
    Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
    tcp
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v20.18.1
    /usr/bin/node           v20.18.1
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    /usr/bin/corepack       0.29.4
    nodejs:
      Installed: 20.18.1-1nodesource1
      Candidate: 20.18.1-1nodesource1
      Version table:
     *** 20.18.1-1nodesource1 600
            500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages
         20.18.0-1nodesource1 600
         20.17.0-1nodesource1 600
         20.16.0-1nodesource1 600
         20.15.1-1nodesource1 600
         20.15.0-1nodesource1 600
         20.14.0-1nodesource1 600
         20.13.1-1nodesource1 600
         20.13.0-1nodesource1 600
         20.12.2-1nodesource1 600
         20.12.1-1nodesource1 600
         20.12.0-1nodesource1 600
         20.11.1-1nodesource1 600
         20.11.0-1nodesource1 600
         20.10.0-1nodesource1 600
         20.9.0-1nodesource1 600
         20.8.1-1nodesource1 600
         20.8.0-1nodesource1 600
         20.7.0-1nodesource1 600
         20.6.1-1nodesource1 600
         20.6.0-1nodesource1 600
         20.5.1-1nodesource1 600
         20.5.0-1nodesource1 600
         20.4.0-1nodesource1 600
         20.3.1-1nodesource1 600
         20.3.0-1nodesource1 600
         20.2.0-1nodesource1 600
         20.1.0-1nodesource1 600
         20.0.0-1nodesource1 600
         12.22.12~dfsg-1~deb11u5 500
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    GTHRN-pi            GTHRN-pi (version: 7.0.3, hostname: GTHRN-pi      , alive, uptime: 11260)
    Core adapters versions
    js-controller:  7.0.3
    admin:          7.4.1
    javascript:     8.8.3
    nodejs modules from github:     2
    +-- iobroker.espresense@0.4.4 (git+ssh://git@github.com/ticaki/ioBroker.espresense.git#6870bf91af08c860fdf00b3c1ec87ab6f66154fb)
    +-- iobroker.vis-materialdesign@0.5.94 (git+ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.git#8b7529d493f223dfc4f1d1f632553fcb35bbcc92)
    Adapter State
    + system.adapter.admin.0                  : admin                 : GTHRN-pi                                 -  enabled, compact disabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
    + system.adapter.backitup.0               : backitup              : GTHRN-pi                                 -  enabled, compact disabled
    + system.adapter.daikin.0                 : daikin                : GTHRN-pi                                 -  enabled, compact disabled
      system.adapter.daswetter.0              : daswetter             : GTHRN-pi                                 -  enabled, compact disabled
      system.adapter.device-watcher.0         : device-watcher        : GTHRN-pi                                 - disabled, compact disabled
    + system.adapter.espresense.0             : espresense            : GTHRN-pi                                 -  enabled, compact disabled
    + system.adapter.followthesun.0           : followthesun          : GTHRN-pi                                 -  enabled, compact disabled
    + system.adapter.fullybrowser.0           : fullybrowser          : GTHRN-pi                                 -  enabled, compact disabled
    + system.adapter.history.0                : history               : GTHRN-pi                                 -  enabled, compact disabled
    + system.adapter.hue.0                    : hue                   : GTHRN-pi                                 -  enabled, compact disabled, port: 443
      system.adapter.ical.0                   : ical                  : GTHRN-pi                                 - disabled, compact disabled
      system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: GTHRN-pi                                 - disabled
      system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : GTHRN-pi                                 - disabled
      system.adapter.icons-freepic.0          : icons-freepic         : GTHRN-pi                                 - disabled
      system.adapter.icons-icons8.0           : icons-icons8          : GTHRN-pi                                 - disabled
      system.adapter.icons-material-png.0     : icons-material-png    : GTHRN-pi                                 - disabled
      system.adapter.icons-material-svg.0     : icons-material-svg    : GTHRN-pi                                 - disabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : GTHRN-pi                                 - disabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : GTHRN-pi                                 - disabled
      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: GTHRN-pi                                 - disabled
      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : GTHRN-pi                                 - disabled
    + system.adapter.iot.0                    : iot                   : GTHRN-pi                                 -  enabled, compact disabled
    + system.adapter.iot.1                    : iot                   : GTHRN-pi                                 -  enabled, compact disabled
    + system.adapter.iot.2                    : iot                   : GTHRN-pi                                 -  enabled, compact disabled
    + system.adapter.javascript.0             : javascript            : GTHRN-pi                                 -  enabled, compact disabled
      system.adapter.material.0               : material              : GTHRN-pi                                 - disabled
    + system.adapter.mqtt-client.0            : mqtt-client           : GTHRN-pi                                 -  enabled, compact disabled, port: 3020
    + system.adapter.mqtt-client.1            : mqtt-client           : GTHRN-pi                                 -  enabled, compact disabled, port: 3020
    + system.adapter.mqtt.0                   : mqtt                  : GTHRN-pi                                 -  enabled, compact disabled, port: 3020, bind: 0.0.0.0
    + system.adapter.mqtt.1                   : mqtt                  : GTHRN-pi                                 -  enabled, compact disabled, port: 3002, bind: 0.0.0.0
    + system.adapter.ping.0                   : ping                  : GTHRN-pi                                 -  enabled, compact disabled
      system.adapter.ring.0                   : ring                  : GTHRN-pi                                 - disabled, compact disabled
      system.adapter.telegram-menu.0          : telegram-menu         : GTHRN-pi                                 - disabled, compact disabled
      system.adapter.telegram.0               : telegram              : GTHRN-pi                                 - disabled, compact disabled, port: 8443, bind: 0.0.0.0
    + system.adapter.tuya.0                   : tuya                  : GTHRN-pi                                 -  enabled, compact disabled
      system.adapter.tvprogram.0              : tvprogram             : GTHRN-pi                                 - disabled, compact disabled
      system.adapter.uv-protect.0             : uv-protect            : GTHRN-pi                                 - disabled, compact disabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : GTHRN-pi                                 - disabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : GTHRN-pi                                 - disabled
      system.adapter.vis-google-fonts.0       : vis-google-fonts      : GTHRN-pi                                 -  enabled, compact disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : GTHRN-pi                                 - disabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : GTHRN-pi                                 - disabled, compact disabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : GTHRN-pi                                 -  enabled, compact disabled
      system.adapter.vis-justgage.0           : vis-justgage          : GTHRN-pi                                 - disabled
      system.adapter.vis-keyboard.0           : vis-keyboard          : GTHRN-pi                                 - disabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : GTHRN-pi                                 - disabled
      system.adapter.vis-metro.0              : vis-metro             : GTHRN-pi                                 - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : GTHRN-pi                                 - disabled
      system.adapter.vis-weather.0            : vis-weather           : GTHRN-pi                                 - disabled
      system.adapter.vis.0                    : vis                   : GTHRN-pi                                 -  enabled, compact disabled
    + system.adapter.web.0                    : web                   : GTHRN-pi                                 -  enabled, compact disabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : GTHRN-pi                                 -  enabled, compact disabled
    + system.adapter.zigbee.0                 : zigbee                : GTHRN-pi                                 -  enabled, compact disabled, port: tcp://192.168.188.120:6638
    + instance is alive
    ioBroker-Repositories
    Active repo(s): beta
    Upgrade policy: none
    Installed ioBroker-Instances
    Used repository: beta
    Cannot download repository hash file from "http://download.iobroker.net/sources-dist-latest-hash.json":
    Adapter    "admin"        : 7.4.1    , installed 7.4.1
    Adapter    "backitup"     : 3.0.27   , installed 3.0.27
    Adapter    "daikin"       : 1.4.2    , installed 1.4.2
    Adapter    "daswetter"    : 3.1.16   , installed 3.1.16
    Adapter    "device-watcher": 2.12.1  , installed 2.12.1
    Adapter    "espresense"   : 0.4.4    , installed 0.4.4
    Adapter    "followthesun" : 0.5.1    , installed 0.5.1
    Adapter    "fullybrowser" : 3.0.12   , installed 3.0.12
    Adapter    "hue"          : 3.13.1   , installed 3.13.1
    Adapter    "ical"         : 1.16.1   , installed 1.16.1
    Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
    Adapter    "icons-freepic": 1.0.0    , installed 1.0.0
    Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
    Adapter    "iot"          : 3.4.3    , installed 3.4.3
    Adapter    "javascript"   : 8.8.3    , installed 8.8.3
    Controller "js-controller": 7.0.3    , installed 7.0.3
    Adapter    "material"     : 1.3.1    , installed 1.3.1
    Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
    Adapter    "mqtt-client"  : 2.1.0    , installed 2.1.0
    Adapter    "ping"         : 1.7.9    , installed 1.7.9
    Adapter    "ring"         : 6.3.0    , installed 6.3.0
    Adapter    "telegram"     : 3.9.0    , installed 3.5.3  [Updatable]
    Adapter    "telegram-menu": 2.1.4    , installed 2.1.4
    Adapter    "tuya"         : 3.16.0   , installed 3.16.0
    Adapter    "tvprogram"    : 2.1.0    , installed 2.1.0
    Adapter    "uv-protect"   : 0.6.4    , installed 0.6.3  [Updatable]
    Adapter    "vis-icontwo"  : 1.9.0    , installed 1.8.1  [Updatable]
    Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
    Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
    Adapter    "vis-materialdesign": 0.5.9, installed 0.5.94
    Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
    Adapter    "web"          : 6.3.1    , installed 6.3.1
    Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
    Adapter    "zigbee"       : 1.10.13  , installed 1.10.13
    Objects and States
    Objects:        8139
    States:         6922
    Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:3 https://deb.nodesource.com/node_20.x nodistro InRelease
    Reading package lists... Done
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:3020            0.0.0.0:*               LISTEN      1001       16160      1218/io.mqtt.0
    tcp        0      0 0.0.0.0:3002            0.0.0.0:*               LISTEN      1001       16180      1233/io.mqtt.1
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       13813      493/iobroker.js-con
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       15583      493/iobroker.js-con
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12698      521/sshd: /usr/sbin
    tcp6       0      0 :::3030                 :::*                    LISTEN      1001       18615      1366/io.espresense.
    tcp6       0      0 :::3001                 :::*                    LISTEN      1001       18566      1403/io.fullybrowse
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       17043      1551/io.web.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       23961      2074/io.admin.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          12700      521/sshd: /usr/sbin
    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       17510      1285/io.tuya.0
    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       17511      1285/io.tuya.0
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          1677       698/dhcpcd
    udp        0      0 0.0.0.0:37669           0.0.0.0:*                           108        12633      372/avahi-daemon: r
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12631      372/avahi-daemon: r
    udp6       0      0 :::546                  :::*                                0          1690       698/dhcpcd
    udp6       0      0 :::5353                 :::*                                108        12632      372/avahi-daemon: r
    udp6       0      0 :::55488                :::*                                108        12634      372/avahi-daemon: r
    2024-11-25 21:09:50.821  - silly: mqtt.0 (1218) States user redis pmessage mqtt.0.*/mqtt.0.hm-rpc.0.KEQ1039660.4.ACTUAL_TEMPERATURE:{"val":18.8,"ack":true,"ts":1732565390288,"q":0,"from":"system.adapter.hm-rpc.0","user":"system.user.admin","lc":1732565390288}
    2024-11-25 21:09:50.822  - debug: mqtt.0 (1218) stateChange mqtt.0.hm-rpc.0.KEQ1039660.4.ACTUAL_TEMPERATURE: {"val":18.8,"ack":true,"ts":1732565390288,"q":0,"from":"system.adapter.hm-rpc.0","user":"system.user.admin","lc":1732565390288}
    2024-11-25 21:09:50.822  - debug: mqtt.0 (1218) onStateChange mqtt.0.hm-rpc.0.KEQ1039660.4.ACTUAL_TEMPERATURE: {"val":18.8,"ack":true,"ts":1732565390288,"q":0,"from":"system.adapter.hm-rpc.0","user":"system.user.admin","lc":1732565390288}
    2024-11-25 21:09:51.316  - debug: mqtt.1 (1233) Client [LOGGER connect NL] pingreq
    2024-11-25 21:09:52.602  - debug: mqtt.0 (1218) Client [Sender_nach_GTHRN] pingreq
    2024-11-25 21:09:58.318  - silly: mqtt.0 (1218) States user redis pmessage mqtt.0.*/mqtt.0.system.host.rp5.mem:{"val":56,"ack":true,"ts":1732565398286,"q":0,"from":"system.host.rp5","user":"system.user.admin","lc":1732565398286}
    2024-11-25 21:09:58.318  - debug: mqtt.0 (1218) stateChange mqtt.0.system.host.rp5.mem: {"val":56,"ack":true,"ts":1732565398286,"q":0,"from":"system.host.rp5","user":"system.user.admin","lc":1732565398286}
    2024-11-25 21:09:58.318  - debug: mqtt.0 (1218) onStateChange mqtt.0.system.host.rp5.mem: {"val":56,"ack":true,"ts":1732565398286,"q":0,"from":"system.host.rp5","user":"system.user.admin","lc":1732565398286}
    2024-11-25 21:09:58.480  - silly: mqtt.0 (1218) States user redis pmessage mqtt.0.*/mqtt.0.system.host.rp5.freemem:{"val":3534,"ack":true,"ts":1732565398286,"q":0,"from":"system.host.rp5","user":"system.user.admin","lc":1732565398286}
    2024-11-25 21:09:58.481  - debug: mqtt.0 (1218) stateChange mqtt.0.system.host.rp5.freemem: {"val":3534,"ack":true,"ts":1732565398286,"q":0,"from":"system.host.rp5","user":"system.user.admin","lc":1732565398286}
    2024-11-25 21:09:58.482  - debug: mqtt.0 (1218) onStateChange mqtt.0.system.host.rp5.freemem: {"val":3534,"ack":true,"ts":1732565398286,"q":0,"from":"system.host.rp5","user":"system.user.admin","lc":1732565398286}
    2024-11-25 21:09:58.483  - silly: mqtt.0 (1218) States user redis pmessage mqtt.0.*/mqtt.0.system.host.rp5.cpu:{"val":14.13,"ack":true,"ts":1732565398305,"q":0,"from":"system.host.rp5","user":"system.user.admin","lc":1732565398305}
    2024-11-25 21:09:58.484  - debug: mqtt.0 (1218) stateChange mqtt.0.system.host.rp5.cpu: {"val":14.13,"ack":true,"ts":1732565398305,"q":0,"from":"system.host.rp5","user":"system.user.admin","lc":1732565398305}
    2024-11-25 21:09:58.484  - debug: mqtt.0 (1218) onStateChange mqtt.0.system.host.rp5.cpu: {"val":14.13,"ack":true,"ts":1732565398305,"q":0,"from":"system.host.rp5","user":"system.user.admin","lc":1732565398305}
    2024-11-25 21:09:58.485  - silly: mqtt.0 (1218) States user redis pmessage mqtt.0.*/mqtt.0.0_userdata.0.System.RP5_FreeMem:{"val":44,"ack":false,"ts":1732565398293,"q":0,"c":"script.js.SYSTEM.Health_Check","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1732565398293}
    2024-11-25 21:09:58.486  - debug: mqtt.0 (1218) stateChange mqtt.0.0_userdata.0.System.RP5_FreeMem: {"val":44,"ack":false,"ts":1732565398293,"q":0,"c":"script.js.SYSTEM.Health_Check","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1732565398293}
    2024-11-25 21:09:58.486  - debug: mqtt.0 (1218) onStateChange mqtt.0.0_userdata.0.System.RP5_FreeMem: {"val":44,"ack":false,"ts":1732565398293,"q":0,"c":"script.js.SYSTEM.Health_Check","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1732565398293}
    2024-11-25 21:10:00.068  - info: javascript.0 (917) script.js.SYSTEM.Temp_CPU: 43.8°C
    2024-11-25 21:10:00.157  - silly: mqtt.0 (1218) States user redis pmessage mqtt.0.*/mqtt.0.0_userdata.0.System.RP5_Uptime:{"val":"11 Tag, 10 Std, 28 Min","ack":false,"ts":1732565400049,"q":0,"c":"script.js.SYSTEM.Health_Check","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1732565400049}
    2024-11-25 21:10:00.158  - debug: mqtt.0 (1218) stateChange mqtt.0.0_userdata.0.System.RP5_Uptime: {"val":"11 Tag, 10 Std, 28 Min","ack":false,"ts":1732565400049,"q":0,"c":"script.js.SYSTEM.Health_Check","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1732565400049}
    2024-11-25 21:10:00.159  - debug: mqtt.0 (1218) onStateChange mqtt.0.0_userdata.0.System.RP5_Uptime: {"val":"11 Tag, 10 Std, 28 Min","ack":false,"ts":1732565400049,"q":0,"c":"script.js.SYSTEM.Health_Check","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1732565400049}
    2024-11-25 21:10:00.247  - silly: mqtt.0 (1218) States user redis pmessage mqtt.0.*/mqtt.0.0_userdata.0.System.RP5_Temp:{"val":"57.6°C","ack":false,"ts":1732565400084,"q":0,"c":"script.js.SYSTEM.CPU_RP5_Temp","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1732565400084}
    2024-11-25 21:10:00.248  - debug: mqtt.0 (1218) stateChange mqtt.0.0_userdata.0.System.RP5_Temp: {"val":"57.6°C","ack":false,"ts":1732565400084,"q":0,"c":"script.js.SYSTEM.CPU_RP5_Temp","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1732565400084}
    2024-11-25 21:10:00.249  - debug: mqtt.0 (1218) onStateChange mqtt.0.0_userdata.0.System.RP5_Temp: {"val":"57.6°C","ack":false,"ts":1732565400084,"q":0,"c":"script.js.SYSTEM.CPU_RP5_Temp","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1732565400084}
    2024-11-25 21:10:04.481  - info: admin.0 (2074) <== Disconnect system.user.admin from ::ffff:192.168.178.36 admin
    @michihorn sagte in Objekte-TAB braucht ewig zum laden:
    Dein Dateisystem hat 'nen Schuss.
    Und wenn du mqtt in silly loggst musst du dich auch nicht wundern, wenn die Kiste lahmt.
    HomoranH M 2 Antworten Letzte Antwort
    • M Online
      M Online
      michihorn
      @homoran Inkognito bringt auch nichts, gleiches Ergebnis
        @thomas-braun sagte in Objekte-TAB braucht ewig zum laden:
        das tut sie nicht!
        das Problem wird im Frontend liegen
          das tut sie nicht!
          @homoran sagte in Objekte-TAB braucht ewig zum laden:
          Oder am wurmstichigen Filesystem.
          • M michihorn
            Das wundert mich jetzt wirklich.
            Der Zustand der Knoten sollte im incognito Modus nicht bekannt sein und daher alle nodes geschlossen sein!
              Oder am wurmstichigen Filiesystem.
              das wäre noch möglich.
              @michihorn
              sagt denn die Browserkondole was?
                M Online
                M Online
                michihorn
                @thomas-braun Ich komme ja noch auf die Instanzen, habe die mqtt's auf Info gesetzt, und siehe da.... ich komme wieder auf die Objekte. Danke an alle die mich Unterstützt haben, Ihr seit SUPER
                • M michihorn
                  @michihorn
                  Das System würde ich aber dennoch beizeiten auf eine andere Basis setzen.
                    @michihorn
                    M Online
                    M Online
                    michihorn
                    @thomas-braun Hast Du dazu ein Workaround ohne Datenverlust?
                    • M michihorn
                      CodierknechtC Offline
                      Codierknecht
                      @michihorn
                      Backup ziehen, Neu aufsetzen, Backup rein.
                      HmIP|ZigBee|Tasmota|Unifi
                      Zabbix Certified Specialist
                      • CodierknechtC Codierknecht
                        @michihorn
                        M Online
                        M Online
                        michihorn
                        @codierknecht Du meinst das Backup über den Backup-Adapter?
                        • M michihorn
                          Codierknecht
                          @michihorn sagte in Gelöst: Objekte-TAB braucht ewig zum laden:
                          Yes!
                          Solange da nicht noch zusätzlicher Kram wie Influx, Grafana oder sonstiges auf der Kiste läuft, sollte die Kiste in max. 1-2 Stunden wieder am Start sein.
                          Wie das geht, hat @Thomas-Braun hier gut verständlich beschrieben.
                          https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
