  4. Hilfe beim Einrichten von Sonoff Zigbee 3.0 USB Dongle Plus
34 Beiträge 5 Kommentatoren 12.3k Aufrufe 5 Beobachtet
  • UHU01U UHU01
    Der Pfad scheint zu stimmen.
    Hier das LOG:
    2023-03-2515:10:58.569-info:host.raspberrypi"system.adapter.zigbee.0"disabled
    2023-03-2515:10:58.572-info:host.raspberrypistopInstancesystem.adapter.zigbee.0(force=false,process=true)
    2023-03-2515:10:58.581-info:zigbee.0(13088)GotterminatesignalTERMINATE_YOURSELF
    2023-03-2515:10:58.639-info:host.raspberrypistopInstancesystem.adapter.zigbee.0sendkillsignal
    2023-03-2515:10:58.583-info:zigbee.0(13088)cleanedeverythingup...
    2023-03-2515:10:58.586-info:zigbee.0(13088)Zigbee:disablingjoiningnewdevices.
    2023-03-2515:10:58.696-warn:zigbee.0(13088)Failedtostopzigbeeduringstartup
    2023-03-2515:10:58.697-info:zigbee.0(13088)terminating
    2023-03-2515:10:58.699-info:zigbee.0(13088)Terminated(ADAPTER_REQUESTED_TERMINATION):Withoutreason
    2023-03-2515:10:59.329-info:host.raspberrypiinstancesystem.adapter.zigbee.0terminatedwithcode11(ADAPTER_REQUESTED_TERMINATION)
    2023-03-2515:11:02.563-info:host.raspberrypi"system.adapter.zigbee.0"enabled
    2023-03-2515:11:03.121-info:host.raspberrypiinstancesystem.adapter.zigbee.0startedwithpid15126
    2023-03-2515:11:08.522-info:zigbee.0(15126)starting.Version1.8.10in/opt/iobroker/node_modules/iobroker.zigbee,node:v16.19.0,js-controller:4.0.24
    2023-03-2515:11:08.718-info:zigbee.0(15126)deleteoldBackupfiles.keeponlylast10
    2023-03-2515:11:08.721-info:zigbee.0(15126)StartingZigbeenpm...
    2023-03-2515:11:09.475-info:zigbee.0(15126)InstalledVersion:iobroker.zigbee@1.8.10
    2023-03-2515:11:09.654-error:zigbee.0(15126)Configurationisnotconsistentwithadapterstate/backup!
    2023-03-2515:11:09.655-error:zigbee.0(15126)-PANID:configured=6753,adapter=6754
    2023-03-2515:11:09.657-error:zigbee.0(15126)-ExtendedPANID:configured=00124b0026b877e1,adapter=00124b0026b877e1
    2023-03-2515:11:09.658-error:zigbee.0(15126)-NetworkKey:configured=01030507090b0d0f00020406080a0c0d,adapter=01030507090b0d0f00020406080a0c0d
    2023-03-2515:11:09.659-error:zigbee.0(15126)-ChannelList:configured=11,adapter=11
    2023-03-2515:11:09.660-error:zigbee.0(15126)Pleaseupdateconfigurationtopreventfurtherissues.
    2023-03-2515:11:09.660-error:zigbee.0(15126)Ifyouwishtore-commissionyournetwork,pleaseremovecoordinatorbackupat/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json.
    2023-03-2515:11:09.662-error:zigbee.0(15126)Re-commissioningyournetworkwillrequirere-pairingofalldevices!
    2023-03-2515:11:09.861-error:zigbee.0(15126)Startingzigbee-herdsmanproblem:"startupfailed-configuration-adaptermismatch-seelogsaboveformoreinformation"
    2023-03-2515:11:09.862-error:zigbee.0(15126)FailedtostartZigbee
    2023-03-2515:11:09.862-error:zigbee.0(15126)Errorherdsmanstart
    2023-03-2515:11:19.866-info:zigbee.0(15126)Trytoreconnect.1attemptsleft
    2023-03-2515:11:19.867-info:zigbee.0(15126)StartingZigbeenpm...
    2023-03-2515:11:19.897-info:zigbee.0(15126)InstalledVersion:iobroker.zigbee@1.8.10
    2023-03-2515:11:20.149-error:zigbee.0(15126)Startingzigbee-herdsmanproblem:"Errorwhileopeningserialport'Error:ErrorResourcetemporarilyunavailableCannotlockport'"
    2023-03-2515:11:20.152-error:zigbee.0(15126)FailedtostartZigbee
    2023-03-2515:11:20.154-error:zigbee.0(15126)Errorherdsmanstart
    @uhu01 sagte in Hilfe beim Einrichten von Sonoff Zigbee 3.0 USB Dongle Plus:
    Und wenn du genau schaust und die Ausgabe hier zum Besten gibst?
    Mit 'scheinbaren Dingen' aus Nacherzählungen kann man nix anfangen.
    Und wo sind die Leerzeichen hin?
    Wie kopierst du das womit woher?
    So (ähnlich) soll das aussehen:
    2023-03-25 15:18:36.256  - info: host.chet instance system.adapter.zigbee.0 started with pid 368095
    2023-03-25 15:18:40.908  - info: zigbee.0 (368095) starting. Version 1.8.10 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.15.0, js-controller: 4.0.24
    2023-03-25 15:18:41.056  - info: zigbee.0 (368095) delete old Backup files. keep only last 10
    2023-03-25 15:18:41.058  - info: zigbee.0 (368095) Starting Zigbee  npm ...
    2023-03-25 15:18:41.721  - info: zigbee.0 (368095) Installed Version: iobroker.zigbee@1.8.10
    2023-03-25 15:18:53.842  - info: zigbee.0 (368095) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20221226}}
    2023-03-25 15:18:53.854  - info: zigbee.0 (368095) Unable to disable LED, unsupported function.
    2023-03-25 15:18:53.876  - info: zigbee.0 (368095)   --> transmitPower : normal
    2023-03-25 15:18:53.883  - info: zigbee.0 (368095) Currently no devices.
    2023-03-25 15:18:53.885  - info: zigbee.0 (368095) Zigbee started
    • UHU01U UHU01
      Hier das LOG:
      Die PAN-ID muss übereinstimmen. Also im Adapter anpassen.
      UHU01U 1 Antwort Letzte Antwort
        UHU01U Offline
        UHU01U Offline
        UHU01
        schrieb am zuletzt editiert von UHU01
        hier die Ausgabe:
        lrwxrwxrwx 1 root root 13 25. Mär 12:47 usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0 -> ../../ttyUSB0
        Und der Eintrag im Adapter:
        /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
        Und nochnal ein neues Log. Ist direkt aus Putty kopiert.
        2023-03-25 15:37:07.313  - info: zigbee.0 (15126) List of port: [{"path":"/dev/ttyUSB0","manufacturer":"Silicon Labs","serialNumber":"0001","pnpId":"usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0","vendorId":"10c4","productId":"ea60"},{"path":"/dev/ttyAMA0"}]
        2023-03-25 15:37:20.987  - info: host.raspberrypi stopInstance system.adapter.zigbee.0 (force=false, process=true)
        2023-03-25 15:37:20.998  - info: zigbee.0 (15126) Got terminate signal TERMINATE_YOURSELF
        2023-03-25 15:37:21.041  - info: host.raspberrypi stopInstance system.adapter.zigbee.0 send kill signal
        2023-03-25 15:37:21.000  - info: zigbee.0 (15126) cleaned everything up...
        2023-03-25 15:37:21.006  - info: zigbee.0 (15126) Zigbee: disabling joining new devices.
        2023-03-25 15:37:21.125  - warn: zigbee.0 (15126) Failed to stop zigbee during startup
        2023-03-25 15:37:21.126  - info: zigbee.0 (15126) terminating
        2023-03-25 15:37:21.128  - info: zigbee.0 (15126) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2023-03-25 15:37:21.716  - info: admin.0 (8202) <== Disconnect system.user.admin from ::ffff:192.168.178.241
        2023-03-25 15:37:21.829  - info: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2023-03-25 15:37:24.299  - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 31775
        2023-03-25 15:37:30.150  - info: zigbee.0 (31775) starting. Version 1.8.10 in /opt/iobroker/node_modules/iobroker.zigbee, node: v16.19.0, js-controller: 4.0.24
        2023-03-25 15:37:30.295  - info: zigbee.0 (31775) delete old Backup files. keep only last 10
        2023-03-25 15:37:30.298  - info: zigbee.0 (31775) Starting Zigbee  npm ...
        2023-03-25 15:37:31.056  - info: zigbee.0 (31775) Installed Version: iobroker.zigbee@1.8.10
        2023-03-25 15:37:33.953  - info: zigbee.0 (31775) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20210708}}
        2023-03-25 15:37:33.966  - info: zigbee.0 (31775) Unable to disable LED, unsupported function.
        2023-03-25 15:37:34.032  - info: zigbee.0 (31775)   --> transmitPower : normal
        2023-03-25 15:37:34.041  - info: zigbee.0 (31775) Currently no devices.
        2023-03-25 15:37:34.044  - info: zigbee.0 (31775) Zigbee started
        2023-03-25 15:37:34.055  - error: zigbee.0 (31775) Unable to apply ExtPanID changes: Error: SRSP - SYS - osalNvRead after 0,2ms
        2023-03-25 15:37:34.242  - info: host.raspberrypi stopInstance system.adapter.zigbee.0 (force=false, process=true)
        2023-03-25 15:37:34.252  - info: zigbee.0 (31775) Got terminate signal TERMINATE_YOURSELF
        2023-03-25 15:37:34.254  - info: zigbee.0 (31775) cleaned everything up...
        2023-03-25 15:37:34.256  - info: zigbee.0 (31775) Zigbee: disabling joining new devices.
        2023-03-25 15:37:34.289  - info: host.raspberrypi stopInstance system.adapter.zigbee.0 send kill signal
        2023-03-25 15:37:34.755  - info: zigbee.0 (31775) terminating
        2023-03-25 15:37:34.758  - info: zigbee.0 (31775) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2023-03-25 15:37:35.295  - info: host.raspberrypi stopInstance system.adapter.zigbee.0 killing pid 31775
        2023-03-25 15:37:35.444  - info: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2023-03-25 15:37:37.465  - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 31980
        2023-03-25 15:37:42.769  - info: zigbee.0 (31980) starting. Version 1.8.10 in /opt/iobroker/node_modules/iobroker.zigbee, node: v16.19.0, js-controller: 4.0.24
        2023-03-25 15:37:42.932  - info: zigbee.0 (31980) delete old Backup files. keep only last 10
        2023-03-25 15:37:42.935  - info: zigbee.0 (31980) Starting Zigbee  npm ...
        2023-03-25 15:37:43.743  - info: zigbee.0 (31980) Installed Version: iobroker.zigbee@1.8.10
        2023-03-25 15:37:43.894  - error: zigbee.0 (31980) Configuration is not consistent with adapter state/backup!
        2023-03-25 15:37:43.895  - error: zigbee.0 (31980) - PAN ID: configured=6754, adapter=6754
        2023-03-25 15:37:43.895  - error: zigbee.0 (31980) - Extended PAN ID: configured=6b2ac77581741024, adapter=00124b0026b877e1
        2023-03-25 15:37:43.896  - error: zigbee.0 (31980) - Network Key: configured=01030507090b0d0f00020406080a0c0d, adapter=01030507090b0d0f00020406080a0c0d
        2023-03-25 15:37:43.897  - error: zigbee.0 (31980) - Channel List: configured=11, adapter=11
        2023-03-25 15:37:43.898  - error: zigbee.0 (31980) Please update configuration to prevent further issues.
        2023-03-25 15:37:43.899  - error: zigbee.0 (31980) If you wish to re-commission your network, please remove coordinator backup at /opt/iobroker/iobroker-data/zigbee_0/nvbackup.json.
        2023-03-25 15:37:43.899  - error: zigbee.0 (31980) Re-commissioning your network will require re-pairing of all devices!
        2023-03-25 15:37:44.068  - error: zigbee.0 (31980) Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
        2023-03-25 15:37:44.069  - error: zigbee.0 (31980) Failed to start Zigbee
        2023-03-25 15:37:44.070  - error: zigbee.0 (31980) Error herdsman start
        2023-03-25 15:37:54.075  - info: zigbee.0 (31980) Try to reconnect. 1 attempts left
        2023-03-25 15:37:54.076  - info: zigbee.0 (31980) Starting Zigbee  npm ...
        2023-03-25 15:37:54.120  - info: zigbee.0 (31980) Installed Version: iobroker.zigbee@1.8.10
        2023-03-25 15:37:54.372  - error: zigbee.0 (31980) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
        2023-03-25 15:37:54.373  - error: zigbee.0 (31980) Failed to start Zigbee
        2023-03-25 15:37:54.374  - error: zigbee.0 (31980) Error herdsman start
        2023-03-25 15:37:58.384  - info: host.raspberrypi "system.adapter.zigbee.0" disabled
        2023-03-25 15:37:58.384  - info: host.raspberrypi stopInstance system.adapter.zigbee.0 (force=false, process=true)
        2023-03-25 15:37:58.395  - info: zigbee.0 (31980) Got terminate signal TERMINATE_YOURSELF
        2023-03-25 15:37:58.397  - info: zigbee.0 (31980) cleaned everything up...
        2023-03-25 15:37:58.406  - info: zigbee.0 (31980) Zigbee: disabling joining new devices.
        2023-03-25 15:37:58.462  - warn: zigbee.0 (31980) Failed to stop zigbee during startup
        2023-03-25 15:37:58.463  - info: zigbee.0 (31980) terminating
        2023-03-25 15:37:58.466  - info: zigbee.0 (31980) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2023-03-25 15:37:58.588  - info: host.raspberrypi stopInstance system.adapter.zigbee.0 send kill signal
        2023-03-25 15:37:59.101  - info: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2023-03-25 15:38:01.241  - info: host.raspberrypi "system.adapter.zigbee.0" enabled
        2023-03-25 15:38:01.582  - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 32191
        2023-03-25 15:38:07.197  - info: zigbee.0 (32191) starting. Version 1.8.10 in /opt/iobroker/node_modules/iobroker.zigbee, node: v16.19.0, js-controller: 4.0.24
        2023-03-25 15:38:07.373  - info: zigbee.0 (32191) delete old Backup files. keep only last 10
        2023-03-25 15:38:07.376  - info: zigbee.0 (32191) Starting Zigbee  npm ...
        2023-03-25 15:38:08.268  - info: zigbee.0 (32191) Installed Version: iobroker.zigbee@1.8.10
        2023-03-25 15:38:08.421  - error: zigbee.0 (32191) Configuration is not consistent with adapter state/backup!
        2023-03-25 15:38:08.422  - error: zigbee.0 (32191) - PAN ID: configured=6754, adapter=6754
        2023-03-25 15:38:08.423  - error: zigbee.0 (32191) - Extended PAN ID: configured=6b2ac77581741024, adapter=00124b0026b877e1
        2023-03-25 15:38:08.424  - error: zigbee.0 (32191) - Network Key: configured=01030507090b0d0f00020406080a0c0d, adapter=01030507090b0d0f00020406080a0c0d
        2023-03-25 15:38:08.425  - error: zigbee.0 (32191) - Channel List: configured=11, adapter=11
        2023-03-25 15:38:08.425  - error: zigbee.0 (32191) Please update configuration to prevent further issues.
        2023-03-25 15:38:08.426  - error: zigbee.0 (32191) If you wish to re-commission your network, please remove coordinator backup at /opt/iobroker/iobroker-data/zigbee_0/nvbackup.json.
        2023-03-25 15:38:08.427  - error: zigbee.0 (32191) Re-commissioning your network will require re-pairing of all devices!
        2023-03-25 15:38:08.595  - error: zigbee.0 (32191) Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
        2023-03-25 15:38:08.596  - error: zigbee.0 (32191) Failed to start Zigbee
        2023-03-25 15:38:08.597  - error: zigbee.0 (32191) Error herdsman start
        2023-03-25 15:38:13.204  - info: admin.0 (8202) ==> Connected system.user.admin from ::ffff:192.168.178.241
        2023-03-25 15:38:13.362  - error: zigbee.0 (32191) getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
        2023-03-25 15:38:13.593  - info: zigbee.0 (32191) List of port: [{"path":"/dev/ttyUSB0","manufacturer":"Silicon Labs","serialNumber":"0001","pnpId":"usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0","vendorId":"10c4","productId":"ea60"},{"path":"/dev/ttyAMA0"}]
        2023-03-25 15:38:18.601  - info: zigbee.0 (32191) Try to reconnect. 1 attempts left
        2023-03-25 15:38:18.602  - info: zigbee.0 (32191) Starting Zigbee  npm ...
        2023-03-25 15:38:18.648  - info: zigbee.0 (32191) Installed Version: iobroker.zigbee@1.8.10
        2023-03-25 15:38:18.917  - error: zigbee.0 (32191) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
        2023-03-25 15:38:18.918  - error: zigbee.0 (32191) Failed to start Zigbee
        2023-03-25 15:38:18.918  - error: zigbee.0 (32191) Error herdsman start
        2023-03-25 15:38:26.219  - info: host.raspberrypi stopInstance system.adapter.zigbee.0 (force=false, process=true)
        2023-03-25 15:38:26.226  - info: zigbee.0 (32191) Got terminate signal TERMINATE_YOURSELF
        2023-03-25 15:38:26.269  - info: host.raspberrypi stopInstance system.adapter.zigbee.0 send kill signal
        2023-03-25 15:38:26.228  - info: zigbee.0 (32191) cleaned everything up...
        2023-03-25 15:38:26.236  - info: zigbee.0 (32191) Zigbee: disabling joining new devices.
        2023-03-25 15:38:26.288  - warn: zigbee.0 (32191) Failed to stop zigbee during startup
        2023-03-25 15:38:26.289  - info: zigbee.0 (32191) terminating
        2023-03-25 15:38:26.291  - info: zigbee.0 (32191) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2023-03-25 15:38:26.928  - info: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2023-03-25 15:38:27.067  - info: admin.0 (8202) <== Disconnect system.user.admin from ::ffff:192.168.178.241
        2023-03-25 15:38:29.749  - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 32552
        2023-03-25 15:38:34.927  - info: zigbee.0 (32552) starting. Version 1.8.10 in /opt/iobroker/node_modules/iobroker.zigbee, node: v16.19.0, js-controller: 4.0.24
        2023-03-25 15:38:35.116  - info: zigbee.0 (32552) delete old Backup files. keep only last 10
        2023-03-25 15:38:35.120  - info: zigbee.0 (32552) Starting Zigbee  npm ...
        2023-03-25 15:38:35.800  - info: zigbee.0 (32552) Installed Version: iobroker.zigbee@1.8.10
        2023-03-25 15:38:35.951  - error: zigbee.0 (32552) Configuration is not consistent with adapter state/backup!
        2023-03-25 15:38:35.952  - error: zigbee.0 (32552) - PAN ID: configured=6753, adapter=6754
        2023-03-25 15:38:35.953  - error: zigbee.0 (32552) - Extended PAN ID: configured=6b2ac77581741024, adapter=00124b0026b877e1
        2023-03-25 15:38:35.953  - error: zigbee.0 (32552) - Network Key: configured=01030507090b0d0f00020406080a0c0d, adapter=01030507090b0d0f00020406080a0c0d
        2023-03-25 15:38:35.954  - error: zigbee.0 (32552) - Channel List: configured=11, adapter=11
        2023-03-25 15:38:35.955  - error: zigbee.0 (32552) Please update configuration to prevent further issues.
        2023-03-25 15:38:35.956  - error: zigbee.0 (32552) If you wish to re-commission your network, please remove coordinator backup at /opt/iobroker/iobroker-data/zigbee_0/nvbackup.json.
        2023-03-25 15:38:35.956  - error: zigbee.0 (32552) Re-commissioning your network will require re-pairing of all devices!
        2023-03-25 15:38:36.123  - error: zigbee.0 (32552) Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
        2023-03-25 15:38:36.124  - error: zigbee.0 (32552) Failed to start Zigbee
        2023-03-25 15:38:36.124  - error: zigbee.0 (32552) Error herdsman start
        2023-03-25 15:38:46.130  - info: zigbee.0 (32552) Try to reconnect. 1 attempts left
        2023-03-25 15:38:46.131  - info: zigbee.0 (32552) Starting Zigbee  npm ...
        2023-03-25 15:38:46.183  - info: zigbee.0 (32552) Installed Version: iobroker.zigbee@1.8.10
        2023-03-25 15:38:46.470  - error: zigbee.0 (32552) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
        2023-03-25 15:38:46.471  - error: zigbee.0 (32552) Failed to start Zigbee
        2023-03-25 15:38:46.472  - error: zigbee.0 (32552) Error herdsman start
        2023-03-25 15:39:21.701  - info: admin.0 (8202) ==> Connected system.user.admin from ::ffff:192.168.178.241
        2023-03-25 15:39:21.973  - error: zigbee.0 (32552) getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
        2023-03-25 15:39:22.212  - info: zigbee.0 (32552) List of port: [{"path":"/dev/ttyUSB0","manufacturer":"Silicon Labs","serialNumber":"0001","pnpId":"usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0","vendorId":"10c4","productId":"ea60"},{"path":"/dev/ttyAMA0"}]
        2023-03-25 15:39:30.643  - info: host.raspberrypi "system.adapter.zigbee.0" disabled
        2023-03-25 15:39:30.644  - info: host.raspberrypi stopInstance system.adapter.zigbee.0 (force=false, process=true)
        2023-03-25 15:39:30.692  - info: zigbee.0 (32552) Got terminate signal TERMINATE_YOURSELF
        2023-03-25 15:39:30.693  - info: zigbee.0 (32552) cleaned everything up...
        2023-03-25 15:39:30.699  - info: zigbee.0 (32552) Zigbee: disabling joining new devices.
        2023-03-25 15:39:30.815  - warn: zigbee.0 (32552) Failed to stop zigbee during startup
        2023-03-25 15:39:30.817  - info: zigbee.0 (32552) terminating
        2023-03-25 15:39:30.819  - info: zigbee.0 (32552) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2023-03-25 15:39:30.914  - info: host.raspberrypi stopInstance system.adapter.zigbee.0 send kill signal
        2023-03-25 15:39:31.450  - info: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2023-03-25 15:39:33.294  - info: admin.0 (8202) <== Disconnect system.user.admin from ::ffff:192.168.178.241
        2023-03-25 15:39:37.090  - info: host.raspberrypi "system.adapter.zigbee.0" enabled
        2023-03-25 15:39:37.400  - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 858
        2023-03-25 15:39:42.719  - info: zigbee.0 (858) starting. Version 1.8.10 in /opt/iobroker/node_modules/iobroker.zigbee, node: v16.19.0, js-controller: 4.0.24
        2023-03-25 15:39:42.859  - info: zigbee.0 (858) delete old Backup files. keep only last 10
        2023-03-25 15:39:42.861  - info: zigbee.0 (858) Starting Zigbee  npm ...
        2023-03-25 15:39:43.741  - info: zigbee.0 (858) Installed Version: iobroker.zigbee@1.8.10
        2023-03-25 15:39:43.899  - error: zigbee.0 (858) Configuration is not consistent with adapter state/backup!
        2023-03-25 15:39:43.901  - error: zigbee.0 (858) - PAN ID: configured=6754, adapter=6754
        2023-03-25 15:39:43.902  - error: zigbee.0 (858) - Extended PAN ID: configured=6b2ac77581741024, adapter=00124b0026b877e1
        2023-03-25 15:39:43.903  - error: zigbee.0 (858) - Network Key: configured=01030507090b0d0f00020406080a0c0d, adapter=01030507090b0d0f00020406080a0c0d
        2023-03-25 15:39:43.904  - error: zigbee.0 (858) - Channel List: configured=11, adapter=11
        2023-03-25 15:39:43.906  - error: zigbee.0 (858) Please update configuration to prevent further issues.
        2023-03-25 15:39:43.907  - error: zigbee.0 (858) If you wish to re-commission your network, please remove coordinator backup at /opt/iobroker/iobroker-data/zigbee_0/nvbackup.json.
        2023-03-25 15:39:43.907  - error: zigbee.0 (858) Re-commissioning your network will require re-pairing of all devices!
        2023-03-25 15:39:44.094  - error: zigbee.0 (858) Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
        2023-03-25 15:39:44.095  - error: zigbee.0 (858) Failed to start Zigbee
        2023-03-25 15:39:44.096  - error: zigbee.0 (858) Error herdsman start
        2023-03-25 15:39:54.102  - info: zigbee.0 (858) Try to reconnect. 1 attempts left
        2023-03-25 15:39:54.103  - info: zigbee.0 (858) Starting Zigbee  npm ...
        2023-03-25 15:39:54.136  - info: zigbee.0 (858) Installed Version: iobroker.zigbee@1.8.10
        2023-03-25 15:39:54.505  - error: zigbee.0 (858) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
        2023-03-25 15:39:54.507  - error: zigbee.0 (858) Failed to start Zigbee
        2023-03-25 15:39:54.508  - error: zigbee.0 (858) Error herdsman start
        2023-03-25 15:41:21.022  - info: admin.0 (8202) ==> Connected system.user.admin from ::ffff:192.168.178.241
        2023-03-25 15:41:21.204  - error: zigbee.0 (858) getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
        2023-03-25 15:41:21.370  - info: zigbee.0 (858) List of port: [{"path":"/dev/ttyUSB0","manufacturer":"Silicon Labs","serialNumber":"0001","pnpId":"usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0","vendorId":"10c4","productId":"ea60"},{"path":"/dev/ttyAMA0"}]
        Thomas BraunT 3 Antworten Letzte Antwort
        • UHU01U UHU01
          hier die Ausgabe:
          Anpassen.
          • UHU01U UHU01
            hier die Ausgabe:
            node: v16.19.0
            könntest du auf die aktuelle Empfehlung nodejs@18 bringen.
            • UHU01U UHU01
              hier die Ausgabe:
              @uhu01
              Den Chipsatztyp musst du wohl auch von TI Z-Stack/CCxxxx
              auf Silicon Labs EZSP/EFR32 setzen.
              • UHU01U Offline
                UHU01U Offline
                UHU01
                nodejs aktualisiert,
                mehrfach die Extended PAN ID aktualisiert,
                mehrfach den Adaper neu gestartet,
                jetzt funktioniert es!
                Danke Dir vielmals!
                P.S. TI Z-Stack/CCxxxx war aber richtig, zumindest habe ich es nicht geändert.
                H 1 Antwort Letzte Antwort
                • UHU01U UHU01
                  Danke Dir vielmals!
                  Honnkoponko
                  @uhu01
                  hallo könntest du mir bitte sagen wie kann ich SonOff installieren?
                  Muss ich nur Instanz/Adapter einfügen oder zuerst muss ich etwas mit USB installieren? Gibt es eine Anleitung wie ich das machen soll?
                  • H Honnkoponko
                    @uhu01
                    AsgothianA Offline
                    AsgothianA Offline
                    Asgothian
                    @honnkoponko sagte in Hilfe beim Einrichten von Sonoff Zigbee 3.0 USB Dongle Plus:
                    @uhu01
                    unter der Bedingung das du einfach einen nativ installierten ioBroker hast:
                    • Zigbee Adapter installieren, NICHT starten
                    • Im Zigbee-Adapter den seriellen Port vom Sonoff Stick eintragen (entweder /dev/ttyAM... oder /dev/serial/by-id/...
                    • Korrekte Firmware aussuchen (ember bei Dongle-E, TI-ZStack bei Dongle-P)
                    • PanID und ExtPanID anpassen
                    • Adapter starten
                    A.
                    • AsgothianA Asgothian
                      @uhu01
                      • Adapter starten
                      A.
                      Honnkoponko
                      @asgothian
                      danke
                      wäre es möglich dass du mir schreibst wie jeder Punkt kann ich machen? Ich kenne mich nicht aus mit Befehle und Konsole leider...
                      • H Offline
                        Honnkoponko
                        Hallo @Thomas-Braun
                        Könntest du mir auch mit USB SonOff helfen ich bekomme folgendes Fehler
                        2024-11-18 11:51:00.730  - info: host.domiobroker77 "system.adapter.zigbee.0" disabled
                        2024-11-18 11:51:00.731  - info: host.domiobroker77 stopInstance system.adapter.zigbee.0 (force=false, process=true)
                        2024-11-18 11:51:00.739  - info: zigbee.0 (1725) Got terminate signal TERMINATE_YOURSELF
                        2024-11-18 11:51:00.742  - info: zigbee.0 (1725) cleaned everything up...
                        2024-11-18 11:51:00.754  - info: zigbee.0 (1725) Zigbee: disabling joining new devices.
                        2024-11-18 11:51:00.774  - warn: zigbee.0 (1725) Failed to stop zigbee during startup
                        2024-11-18 11:51:00.775  - info: zigbee.0 (1725) terminating
                        2024-11-18 11:51:00.776  - debug: zigbee.0 (1725) Plugin sentry destroyed
                        2024-11-18 11:51:00.777  - info: zigbee.0 (1725) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                        2024-11-18 11:51:00.830  - info: host.domiobroker77 stopInstance system.adapter.zigbee.0 send kill signal
                        2024-11-18 11:51:01.245  - info: zigbee.0 (1725) terminating
                        2024-11-18 11:51:01.366  - info: host.domiobroker77 instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                        2024-11-18 11:51:11.212  - info: host.domiobroker77 "system.adapter.zigbee.0" enabled
                        2024-11-18 11:51:11.663  - info: host.domiobroker77 instance system.adapter.zigbee.0 in version "1.10.3" started with pid 1835
                        2024-11-18 11:51:15.573  - debug: zigbee.0 (1835) Redis Objects: Use Redis connection: 127.0.0.1:9001
                        2024-11-18 11:51:15.620  - debug: zigbee.0 (1835) Objects client ready ... initialize now
                        2024-11-18 11:51:15.623  - debug: zigbee.0 (1835) Objects create System PubSub Client
                        2024-11-18 11:51:15.625  - debug: zigbee.0 (1835) Objects create User PubSub Client
                        2024-11-18 11:51:15.697  - debug: zigbee.0 (1835) Objects client initialize lua scripts
                        2024-11-18 11:51:15.709  - debug: zigbee.0 (1835) Objects connected to redis: 127.0.0.1:9001
                        2024-11-18 11:51:15.753  - debug: zigbee.0 (1835) Redis States: Use Redis connection: 127.0.0.1:9000
                        2024-11-18 11:51:15.773  - debug: zigbee.0 (1835) States create System PubSub Client
                        2024-11-18 11:51:15.775  - debug: zigbee.0 (1835) States create User PubSub Client
                        2024-11-18 11:51:15.847  - debug: zigbee.0 (1835) States connected to redis: 127.0.0.1:9000
                        2024-11-18 11:51:15.891  - debug: zigbee.0 (1835) Plugin sentry Initialize Plugin (enabled=true)
                        2024-11-18 11:51:16.397  - info: zigbee.0 (1835) starting. Version 1.10.3 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.16.0, js-controller: 6.0.9
                        2024-11-18 11:51:16.446  - debug: zigbee.0 (1835) Using zigbee-herdsman with settings: {"network":{"panID":6754,"channelList":[11],"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13],"extenedPanID":[139,122,111,94,77,60,43,26]},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","backupPath":"/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json","serialPort":{"baudRate":115200,"rtscts":false,"path":"/dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_5a52e2baefdbed118632e92d62c613ac-if00-port0","adapter":"zstack"},"adapter":{"forceStartWithInconsistentAdapterConfiguration":false},"legacy":false}
                        2024-11-18 11:51:16.535  - info: zigbee.0 (1835) delete old Backup files. keep only last 10
                        2024-11-18 11:51:16.537  - info: zigbee.0 (1835) Starting Zigbee  npm ...
                        2024-11-18 11:51:16.600  - debug: zigbee.0 (1835) Starting zigbee-herdsman...
                        2024-11-18 11:51:17.011  - info: zigbee.0 (1835) Installed Version: iobroker.zigbee@1.10.3
                        2024-11-18 11:51:17.405  - debug: zigbee.0 (1835) Backup /opt/iobroker/iobroker-data/zigbee_0/backup_2024_11_18-11_51_16.tar.gz success
                        2024-11-18 11:51:37.754  - error: zigbee.0 (1835) Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
                        2024-11-18 11:51:37.755  - error: zigbee.0 (1835) Failed to start Zigbee
                        2024-11-18 11:51:37.756  - error: zigbee.0 (1835) Error herdsman start
                        2024-11-18 11:51:47.761  - info: zigbee.0 (1835) Try to reconnect. 1 attempts left
                        2024-11-18 11:51:47.762  - info: zigbee.0 (1835) Starting Zigbee  npm ...
                        2024-11-18 11:51:47.769  - debug: zigbee.0 (1835) Starting zigbee-herdsman...
                        2024-11-18 11:51:47.779  - info: zigbee.0 (1835) Installed Version: iobroker.zigbee@1.10.3
                        2024-11-18 11:51:47.975  - error: zigbee.0 (1835) Starting zigbee-herdsman problem : "Error Resource temporarily unavailable Cannot lock port"
                        2024-11-18 11:51:47.978  - error: zigbee.0 (1835) Failed to start Zigbee
                        2024-11-18 11:51:47.979  - error: zigbee.0 (1835) Error herdsman start
                        Hier ich liste was ich gemacht habe:
                        1. Mit
                        /dev/serial/by-id/
                        Habe ich Device bekommen:
                        mwit@domiobroker77:~ $ ls /dev/serial/by-id/
                        1. In Adapter Setting habe ich das eingetragen (mit DevID und ExtDevID)
                        Adapter started und will nicht grün sein...;(
                        Was kann ich dort anpassen?
                        Wie kann ich aus Putty nur zigbee Logs zeigen?
                        Mit
                        mwit@domiobroker77:~ $ iob logs --watch | uniq
                        Zeig alle Adapter Logs. Kann ich das irgendwie filtern?
                        haselchenH Thomas BraunT 2 Antworten Letzte Antwort
                        • H Honnkoponko
                          Hallo @Thomas-Braun
                          1. Mit
                          /dev/serial/by-id/
                          Mit
                          haselchenH Offline
                          haselchenH Offline
                          haselchen
                          @honnkoponko
                          Es reicht ja wenn du das Log vom Adapterstart zeigst.
                          Eventuell im Adapter noch den Debug Modus anschalten.
                          • H Honnkoponko
                            Hallo @Thomas-Braun
                            1. Mit
                            /dev/serial/by-id/
                            Mit
                            Deutet auf Trouble mit der Firmware hin. Steck das Ding mal aus und nach ein paar Minuten wieder ein. Betreibst du den Stick an einer USB-Verlängerung?
                            Ordentlicher Reboot schadet auch nichts.
                              Honnkoponko
                              Reboot habe ich gemacht
                              Ich probiere noch mit rein und raus
                              Ich nutze USB Verlängerung (nicht möglich direkt in USB port einstecken)
                              Ist das fixierbar oder einfacher CC2652P Zigbee Dongle kaufen? (habe ich gelesen CC2531 haben Probleme)
                              Soll ich andere USB Port versuchen - macht das Sinn?
                              • H Honnkoponko
                                Ja, aber der Sonoff 3.0 hat ohnehin einen anderen Chipsatz, nicht den CC2531.
                                Ich weiß nie, welchen der beiden bei Sonoff gerade verwendet wird. Stell mal testweise den Stack auf EZSP (oder so ähnlich) um.
                                  Honnkoponko
                                  schrieb am zuletzt editiert von Honnkoponko
                                  Habe ich rein raus gemacht und nichts.
                                  Für EZSP EInstellung:
                                  zigbee.0
                                  PID
                                  Time
                                  debug
                                  Message
                                  zigbee.0
                                  2052	2024-11-18 12:48:57.567	error	Error herdsman start
                                  zigbee.0
                                  2052	2024-11-18 12:48:57.567	error	Failed to start Zigbee
                                  zigbee.0
                                  2052	2024-11-18 12:48:57.566	error	Starting zigbee-herdsman problem : "Failure to connect"
                                  zigbee.0
                                  2052	2024-11-18 12:48:27.322	info	Installed Version: iobroker.zigbee@1.10.3
                                  zigbee.0
                                  2052	2024-11-18 12:48:27.312	debug	Starting zigbee-herdsman...
                                  zigbee.0
                                  2052	2024-11-18 12:48:27.304	info	Starting Zigbee npm ...
                                  zigbee.0
                                  2052	2024-11-18 12:48:27.303	info	Try to reconnect. 1 attempts left
                                  zigbee.0
                                  2052	2024-11-18 12:48:17.297	error	Error herdsman start
                                  zigbee.0
                                  2052	2024-11-18 12:48:17.296	error	Failed to start Zigbee
                                  zigbee.0
                                  2052	2024-11-18 12:48:17.294	error	Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
                                  Ich habe ZBDongle-E so ich denke es ist CC2652P CHipset
                                  Einstellung sollte TI Z-Stack/CCxxxx sein
                                  Was kann ich noch probieren?
                                  Andere USB Port oder was?
                                  DOngle ist in USB 2.0 - soll ich USB 3.0 nutzen?
                                  Oder USB-Verlängerung ist zu lange - ich habe 5m...Kann das Probleme machen?
                                  AsgothianA haselchenH 2 Antworten Letzte Antwort
                                  • H Honnkoponko
                                    zigbee.0
                                    PID
                                    Time
                                    debug
                                    Message
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    AsgothianA Offline
                                    AsgothianA Offline
                                    Asgothian
                                    zigbee.0
                                    PID
                                    Time
                                    debug
                                    Message
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    Der Sonoff-ZBDongle-e sollte einen EZSP Chipsatz haben. Ansonsten beschwert sich der Adapter über eine inkonsistente Konfiguration. Daher bitte
                                    • Adapter anhalten
                                    • sicher gehen das kein Zigbee Prozess mehr läuft - das kann bis zu 20 Sekunden dauern
                                    • die Datei nvbackup.json im Verzeichnis /opt/iobroker/iobroker-data/zigbee_0 löschen
                                    • adapter wieder starten
                                    A.
                                    • H Honnkoponko
                                      zigbee.0
                                      PID
                                      Time
                                      debug
                                      Message
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      haselchenH Offline
                                      haselchenH Offline
                                      haselchen
                                      @honnkoponko
                                      Nun mal nicht so hippelig.
                                      Hast Du ein -E oder -P ?
                                      Welche Firmware ist auf dem Stick?
                                      Wenn wir das alles geklärt haben , versuch mal die PAN ID auf Ausgangslage zu setzen .
                                      Alles große D.
                                      Aber erst wenn das oben geklärt ist.
                                      • haselchenH haselchen
                                        @honnkoponko
                                        Alles große D.
                                        Honnkoponko
                                        @haselchen
                                        Ich habe ZBDongle-E mit Firmware 6.10.3.0 - ich kan auf 7.4.4.0 updaten wenn Sinn macht
                                        PAN_ID meinst du in Iobroker ExtID oder auf USB Geraät (nicht sicher wie ich das mache)
                                        • H Honnkoponko
                                          @haselchen
                                          haselchenH Offline
                                          haselchenH Offline
                                          haselchen
                                          @honnkoponko
                                          Bevor Du ein Update machst .
                                          Probier im Adapter aus, in der Zeile Network ID alles D reinzuschreiben.
                                          Gib dann mal Feedback mit Log Auszug bitte
