  4. Geekworm X1202 USV Variable in IObroker übernehmen
45 Beiträge 5 Kommentatoren 5.7k Aufrufe 3 Beobachtet
  • OliverIOO OliverIO
    @lieggie
    hier zum testen
    die beiden npm bibliotheken
    • i2c-bus
    • onoff
    müssen zuvor in den einstellungen des javascript adapters hinzugefügt werden
    const I2c = require('i2c-bus')
    const Gpio = require('onoff').Gpio;
    const dp_voltage ="0_userdata.usv.voltage"; //number
    const dp_voltagestate ="0_userdata.usv.voltagestate"; //number
    const dp_capacity ="0_userdata.usv.capacity"; //number
    const dp_powerstate ="0_userdata.usv.powerstate"; //string
    const X728_ADDR = 0x36
    const VOLTAGE_REG = 0x2
    const CAPACITY_REG = 0x4
    const extPower = new Gpio(6, 'in', 'both', {
        debounceTimeout: 300
    extPower.read((err, externalPowerLoss) => {
        if (err) {
            log(err,"error");
        } else {
            setPowerstate(externalPowerLoss);
    // notification actions on gpio change
    extPower.watch((err, externalPowerLoss) => {
        if (err) {
            if (err) log(err,"error");
        } else {
    function readGeekworm() {
        // open the i2c bus
        let i2c = I2c.open(1, (err) => {
        // read and publish battery voltage
        i2c.readWord(X728_ADDR, VOLTAGE_REG, (err, rawData) => {
            rawData = (rawData >> 8) + ((rawData & 0xff) << 8);
            let voltage = rawData * 1.25 / 1000 / 16;
            console.debug(`battery voltage: ${voltage} VDC`);
            setState(dp_voltage,voltage);
            getVoltageState(voltage);
        // read and publish battery charge capacity
        i2c.readWord(X728_ADDR, CAPACITY_REG, (err, rawData) => {
            let capacity = rawData / 256; //100% at 4.2VDC
            if (capacity > 1.0) capacity = 1.0; //cap at 1.0 if small rounding eror
            console.debug(`battery capacity: ${capacity} %`);
            setState(dp_capacity,capacity);
        // close the i2c bus
        i2c.close((err) => {
    function getVoltageState(voltage) {
        let state="unknown";
        if (voltage<=3.87 && voltage <=4.2) state="Full";
        if (voltage<=3.7  && voltage <3.87) state="High";
        if (voltage<=3.55 && voltage <3.7)  state="Medium";
        if (voltage<=3.4  && voltage <3.55) state="Low";
        if (voltage<3.4) state="Critical";
        setState(dp_voltagestate,state);
    function setPowerstate(externalPowerLoss) {
        if (externalPowerLoss) {
            setState(dp_powerstate,"battery");
        } else {
            setState(dp_powerstate,"power");
    schedule('* * * * *',readGeekworm); //every minute
    @oliverio sagte: "0_userdata.usv.voltagestate"; //number
    ... sollte vom Typ "string" sein.
    Das Schreiben der eigenen Datenpunkte sollte mit Bestätigung erfolgen.
    L 1 Antwort Letzte Antwort
      Lieggie
      schrieb am zuletzt editiert von Lieggie
      Hallo Ihr 2.....ich komme grad vom Einkaufen und sehe wie ihr 2 euch gedanken macht erstenmal vielen dank dafür.
      Ich habe in die Richtung noch nie was gemacht und war in den ersten IOB instalationsrutinen immer froh mit copy & Paste klar zukommen.
      Ich habe das Script nun in /opt/Iobroker verschoben, jetzt fragt er nicht mehr nach einem Passwort.
      Es ist für mich nun der erste Versuch Daten aus anderen Scripten zu holen.
      Aber ganz ehrlich das mit dem i2c ist mir zu viel da muss ich mich noch einarbeiten.
      @OliverIO wenn du magst kann ich dir den pi5 zur verfügung stellen ...aber dann lern ich nicht dabei.Er ist noch nicht im Betrieb
      Und ja du hast recht und der Überschrift ist ein R zuviel.
      Vielen dank für eure Hilfe
      OliverIOO HomoranH 2 Antworten Letzte Antwort
      • L Lieggie
        OliverIOO Offline
        OliverIOO Offline
        OliverIO
        @lieggie sagte in Greekworm X1202 USV Variable in IObroker übernehmen:
        dein python script nutzt das genau so.
        du sollst das skript einfach nur mal laufen lassen. i2c musst du dich nicht einarbeiten
        also datenpunkte einrichten, entweder nach meinen vorschlägen oder
        eigene benennen, anlegen und im skript eintragen.
        dann die bibliotheken in den js adapter einstellungen eintragen, fertig.
        Meine Adapter und Widgets
        Links im Profil
          Lieggie
          @oliverio
          Variable erstellt
          Minutliche ausführung
          nu komme ich nicht weiter weil mein merged.py so aussieht.
          wo soll ich deine Zeilen einfügen.
          #!/usr/bin/python3
          import os
          import struct
          import smbus
          import time
          import logging
          import subprocess
          import gpiod
          from subprocess import call
          # User-configurable variables
          SHUTDOWN_THRESHOLD = 3  # Number of consecutive failures required for shutdown
          SLEEP_TIME = 60  # Time in seconds to wait between failure checks
          Loop =  False
          def readVoltage(bus):
              read = bus.read_word_data(address, 2)
              swapped = struct.unpack("<H", struct.pack(">H", read))[0]
              voltage = swapped * 1.25 / 1000 / 16
              return voltage
          def readCapacity(bus):
              read = bus.read_word_data(address, 4)
              capacity = swapped / 256
              return capacity
          def get_battery_status(voltage):
              if 3.87 <= voltage <= 4.2:
                  return "Full"
              elif 3.7 <= voltage < 3.87:
                  return "High"
              elif 3.55 <= voltage < 3.7:
                  return "Medium"
              elif 3.4 <= voltage < 3.55:
                  return "Low"
              elif voltage < 3.4:
                  return "Critical"
              else:
                  return "Unknown"
          # Ensure only one instance of the script is running
          pid = str(os.getpid())
          pidfile = "/run/X1200.pid"
          if os.path.isfile(pidfile):
              print("Script already running")
              exit(1)
          else:
              with open(pidfile, 'w') as f:
                  f.write(pid)
          try:
              bus = smbus.SMBus(1)
              address = 0x36
              PLD_PIN = 6
              chip = gpiod.Chip('gpiochip4')
              pld_line = chip.get_line(PLD_PIN)
              pld_line.request(consumer="PLD", type=gpiod.LINE_REQ_DIR_IN)
              while True:
                  failure_counter = 0
                  for _ in range(SHUTDOWN_THRESHOLD):
                      ac_power_state = pld_line.get_value()
                      voltage = readVoltage(bus)
                      battery_status = get_battery_status(voltage)
                      capacity = readCapacity(bus)
                      print(f"Capacity: {capacity:.2f}% ({battery_status}), AC Power State: {'Plugged in' if ac_power_state == 1 else 'Unplugged'}, Voltage: {voltage:.2f}V")
                      if capacity < 20:
                          print("Battery level critical.")
                          failure_counter += 1
                      elif voltage < 3.20:
                          print("Battery voltage critical.")
                      elif ac_power_state == 0:
                          print("UPS is unplugged or AC power loss detected.")
                      else:
                          failure_counter = 0
                          break
                      if failure_counter < SHUTDOWN_THRESHOLD:
                          time.sleep(SLEEP_TIME)
                  if failure_counter >= SHUTDOWN_THRESHOLD:
                      shutdown_reason = ""
                      if capacity < 20:
                          shutdown_reason = "due to critical battery level."
                          shutdown_reason = "due to critical battery voltage."
                          shutdown_reason = "due to AC power loss or UPS unplugged."
                      shutdown_message = f"Critical condition met {shutdown_reason} Initiating shutdown."
                      print(shutdown_message)
                      call("sudo nohup shutdown -h now", shell=True)
                  else:
                      #print("System operating within normal parameters. No action required.")
                      if Loop:
                      else:
                          exit(0)
          finally:
                  os.unlink(pidfile)
              exit(0)
          • OliverIOO Offline
            OliverIOO Offline
            OliverIO
            @lieggie
            nix blockly.
            du legst im javascript adapter ein neues skript an und wählst anstatt blockly
            den javascript knopf (auch nicht typescript und auch nicht rules)
            du gibts deinem skript einen namen.
            dann hast du ein textfenster.
            dort kopierst du das skript rein
            dann die namen der datenpunkte in den ersten paar zeilen des skripts anpassen
            und drückst oben auf den play button
            im unterne bereich des skripts ist ein log bereich.
            da mal reinschauen was da so kommt.
            wenn keine fehler erscheinen kannst du die datenpunkte überprüfen ob da die daten reingeschrieben wurden.
            Links im Profil
              @lieggie
              nix blockly.
              Lieggie
              @oliverio
              Guten Morgen , sorry das ich mich erst jetzt Melde .Ich war gestern verhindert.
              ich habe wie du gesagt hast nun das Script rin kopiert. bekomme aber nun diesen fehler
              javascript.0	10:12:51.180	info	Stopping script script.js.USV
              javascript.0	10:12:53.042	info	Start JavaScript script.js.USV (Javascript/js)
              javascript.0	10:12:53.058	error	script.js.USV: Error: EINVAL: invalid argument, write
              javascript.0	10:12:53.059	error	at script.js.USV:26:18
              javascript.0	10:12:53.060	error	at script.js.USV:169:3
              ich glaub hier ist noch was faul
              paul53P L 2 Antworten Letzte Antwort
              • L Lieggie
                jetzt nicht mehr!
                Ich hab's für dich rausgenommen
                • L Lieggie
                  @oliverio
                  @lieggie sagte: hier ist noch was faul
                  Die roten Wellenlinien des Javascript-Editors kann man ignorieren, wenn die beiden NPM-Module in der Konfiguration der Javascript-Instanz eingetragen sind und es bei der Installation der Module keine Fehlermeldungen gab.
                  • L Lieggie
                    @oliverio
                    Lieggie
                    @lieggie said in Geekworm X1202 USV Variable in IObroker übernehmen:
                    @oliverio
                    avascript.0
                    	2024-09-15 10:34:58.719	error	at Script.runInContext (node:vm:148:12)
                    javascript.0
                    	2024-09-15 10:34:58.719	error	at script.js.USV:169:3
                    javascript.0
                    	2024-09-15 10:34:58.719	error	at script.js.USV:26:18
                    javascript.0
                    	2024-09-15 10:34:58.719	error	at new Gpio (/opt/iobroker/node_modules/@iobroker-javascript.0/onoff/onoff.js:172:36)
                    javascript.0
                    	2024-09-15 10:34:58.718	error	at exportGpio (/opt/iobroker/node_modules/@iobroker-javascript.0/onoff/onoff.js:18:8)
                    javascript.0
                    	2024-09-15 10:34:58.718	error	at Object.writeFileSync (node:fs:2368:20)
                    javascript.0
                    	2024-09-15 10:34:58.718	error	script.js.USV: Error: EINVAL: invalid argument, write
                      Lieggie
                      @paul53 said in Geekworm X1202 USV Variable in IObroker übernehmen:
                      ich habe die beiden instanzen instaliert da bei gab es keinen Fehler
                      sudo npm install onoff
                      sudo npm install i2c-bus
                      was mir nur aufgefallen ist das onoff nur bis Node 16 unterstützt wird. ich habe aber 20 am laufen
                      Thomas BraunT paul53P 2 Antworten Letzte Antwort
                      • L Lieggie
                        @lieggie
                        Knall dir BITTE KEINE npm-Module per root in das System!!!!
                        • L Lieggie
                          @lieggie sagte:
                          So ist es falsch! Der Javascript-Adapter installiert sie selbst in das richtige Verzeichnis, nachdem sie in der Konfiguration unter "Zusätzliche NPM-Module" eingetragen wurden.
                            @lieggie sagte:
                            Lieggie
                            @lieggie sagte:
                            dann müssen sie ja da sein weil eingetragen im Javascript Adapter sind sie ja
                            HomoranH paul53P Thomas BraunT 3 Antworten Letzte Antwort
                            • L Lieggie
                              @lieggie sagte:
                              @lieggie sagte in Geekworm X1202 USV Variable in IObroker übernehmen:
                              dann müssen sie ja da sein weil eingetragen im om adapter sind sie ja
                              Was willst du damit sagen?
                              Wo müssen sie sein?
                              Was ist der om Adapter?
                              • L Lieggie
                                @lieggie sagte:
                                @lieggie sagte: dann müssen sie ja da sein weil eingetragen im om adapter sind sie ja
                                Ja, denn die Fehlermeldung
                                zeigt das Vorhandensein im richtigen Verzeichnis.
                                  Wo müssen sie sein?
                                  Lieggie
                                  @homoran said in Geekworm X1202 USV Variable in IObroker übernehmen:
                                  Wo müssen sie sein?
                                  sollte natürlich Javascript Adapter sein...... so ist das mit 2 kleinen Kindern neben bei
                                  • L Lieggie
                                    @lieggie sagte:
                                    Dann schau nach...
                                    Und schau auch wo jetzt die per sudo reingeballerten Module liegen und hau die wieder raus.
                                    cd /opt/iobroker
                                    npm ls onoff
                                    npm ls i2c-bus
                                    • L Lieggie
                                      Wo müssen sie sein?
                                      @lieggie und wo müssen sie sein?
                                      selbst wenn durch den Eintrag im js Adapter
                                      @paul53 sagte in Geekworm X1202 USV Variable in IObroker übernehmen:
                                      vorliegt, kann durch
                                      es zusätzlich noch einmal woanders installiert sein
                                        Lieggie
                                        Sie lagen im home/pi habe sie nun mit
                                        sudo npm uninstall onoff
                                        wieder entfernt.
                                        ich sollte weiter mit blockly basteln das Script kram liegt mir nicht.
                                        Thomas BraunT OliverIOO 2 Antworten Letzte Antwort
                                        • L Lieggie
                                          wieder entfernt.
                                          @lieggie
                                          Und gewöhn dir den exzessiven Einsatz von sudo ab. Da ist im Kontext vom ioBroker eigentlich nie erforderlich und zu 99% einfach falsch.
