  4. Test Adapter Energiefluss-erweitert v0.8.x GitHub/Latest
diagrammenergieflussenergiefluss-erweitertvisvisualisierungvisualization
1.7k Beiträge 78 Kommentatoren 1.1m Aufrufe 78 Beobachtet
  • SKBS SKB
    @u66 Das sieht mir nicht nach der neueren Version aus, da eine Menge Info Logs fehlen.
    Bitte über Benutzerdefiniert via Github Katze installieren, upload machen und dann die Ausgabe posten. Adapter muss nicht auf Debug stehen.
    U66U Offline
    U66U Offline
    U66
    schrieb am zuletzt editiert von U66
    #307
    @skb
    energiefluss-erweitert.0
    	2024-08-15 09:37:53.013	debug	State changed! New value for Source: alpha-ess.0.Realtime.PV_power_string_1 with Value: 770 belongs to Elements: 93,124
    	2024-08-15 09:37:53.013	debug	Value: 770 is greater than Threshold: 0. Applying Animation!
    	2024-08-15 09:37:53.013	debug	Animation has a positive factor!
    	2024-08-15 09:37:53.012	debug	Animation - Settings for Element anim_path_303_387 found! Applying Settings!
    	2024-08-15 09:37:53.012	debug	Found corresponding animations for ID: alpha-ess.0.Realtime.PV_power_string_1 !Applying!
    	2024-08-15 09:37:53.012	debug	Values for: 124 - Using source: 16 rawValue: 770 Settings: {"threshold":0,"type":"circle","source":16,"fill_type":-1,"border_type":-1,"source_type":"number"}
    	2024-08-15 09:37:53.012	debug	Value-Settings for Element 124 found! Applying Settings!
    	2024-08-15 09:37:52.990	debug	Threshold for: 93 is: 0
    	2024-08-15 09:37:52.990	debug	Values for: 93 - Using source: 16 rawValue: 770 Settings: {"threshold":0,"calculate_kw":"auto","decimal_places":1,"convert":false,"type":"text","source":16,"source_option":-1,"source_display":"value","subtract":[-1],"add":[-1],"override":{">=0":{"display":"fill","fill":"rgb(26,255,49","unit":" W","value":"val => val.toFixed(0)"},">=1000":{"unit":" kW","value":"val => parseFloat(val/1000).toFixed(2)","display":"fill","fill":"rgb(26,255,49"},">=9995":{"unit":" kW","value":"val => parseFloat(val/1000).toFixed(1)","display":"fill","fill":"rgb(26,255,49"},"<= -9995":{"unit":" kW","value":"val => parseFloat(val*-1/1000).toFixed(1)","display":"fill","fill":"rgb(34,139,34)"},"<= -1000":{"unit":" kW","value":"val => parseFloat(val*-1/1000).toFixed(2)","display":"fill","fill":"rgb(34,139,34)"},"default":{"unit":" W","value":"val => (val*-1).toFixed(0)","display":"fill","fill":"rgb(34,139,34)"}},"source_type":"number","text":"ID 93"}
    	2024-08-15 09:37:52.990	debug	Gathering override for ID: 93, Value: 770 and Override: {">=0":{"display":"fill","fill":"rgb(26,255,49","unit":" W","value":"val => val.toFixed(0)"},">=1000":{"unit":" kW","value":"val => parseFloat(val/1000).toFixed(2)","display":"fill","fill":"rgb(26,255,49"},">=9995":{"unit":" kW","value":"val => parseFloat(val/1000).toFixed(1)","display":"fill","fill":"rgb(26,255,49"},"<= -9995":{"unit":" kW","value":"val => parseFloat(val*-1/1000).toFixed(1)","display":"fill","fill":"rgb(34,139,34)"},"<= -1000":{"unit":" kW","value":"val => parseFloat(val*-1/1000).toFixed(2)","display":"fill","fill":"rgb(34,139,34)"},"default":{"unit":" W","value":"val => (val*-1).toFixed(0)","display":"fill","fill":"rgb(34,139,34)"}}
    	2024-08-15 09:37:52.989	debug	Updated through elmSources: {"1":62.4,"14":0,"15":17910,"16":770}
    	2024-08-15 09:37:52.989	debug	Current Value of alpha-ess.0.Realtime.PV_power_string_1: 770 - saved Value: undefined
    	2024-08-15 09:37:52.989	info	Loading initial for alpha-ess.0.Realtime.PV_power_string_1 with {"val":770,"ack":true,"ts":1723707460725,"q":0,"from":"system.adapter.alpha-ess.0","user":"system.user.admin","lc":1723707460725}
    	2024-08-15 09:37:52.989	debug	Value of alpha-ess.0.Realtime.PV_power_string_1 changed! Processing!
    	2024-08-15 09:37:52.989	debug	Value-Settings for Element 93 found! Applying Settings!
    SKBS 1 Antwort Letzte Antwort
    • U66U U66
      @skb
      SKBS Offline
      SKBS Offline
      SKB
      #308
      @u66 Bitte den Adapter nicht auf Debug stellen, sondern einfach nur starten! Dann den Inhalt des Startes hier einstellen.
      Diese Log-Fetzen sind ja völlig aus dem Zusammenhang.
      U66U 1 Antwort Letzte Antwort
      • SKBS SKB
        U66U Offline
        U66U Offline
        U66
        #309
        @skb
        	2024-08-15 10:03:37.227	info	terminating
        	2024-08-15 10:03:36.726	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
        	2024-08-15 10:03:36.725	info	terminating
        	2024-08-15 10:03:36.725	info	Cleared interval for relative values!
        	2024-08-15 10:03:36.722	error	Parameter "id" needs to be of type "string" but type "undefined" has been passed
        	2024-08-15 10:03:36.722	error	Error: Parameter "id" needs to be of type "string" but type "undefined" has been passed at Validator.assertString (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/validator.js:129:13) at EnergieflussErweitert.getForeignState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js:4538:32) at /opt/iobroker/node_modules/@iobroker/js-controller-common-db/build/cjs/lib/common/tools.js:1586:18 at new Promise (<anonymous>) at EnergieflussErweitert.getForeignStateAsync (/opt/iobroker/node_modules/@iobroker/js-controller-common-db/build/cjs/lib/common/tools.js:1584:12) at EnergieflussErweitert.calculateValue (/opt/iobroker/node_modules/iobroker.energiefluss-erweitert/main.js:311:29) at sourceRunner (/opt/iobroker/node_modules/iobroker.energiefluss-erweitert/main.js:828:20) at async EnergieflussErweitert.refreshData (/opt/iobroker/node_modules/iobroker.energiefluss-erweitert/main.js:845:7) at async EnergieflussErweitert.getConfig (/opt/iobroker/node_modules/iobroker.energiefluss-erweitert/main.js:1522:4)
        SKBS 2 Antworten Letzte Antwort
        • U66U U66
          @skb
          SKBS Offline
          SKBS Offline
          SKB
          #310
          @u66 Da fehlen Info Ausgaben. Sowas wie:
          2024-08-15 09:47:55.415 - info: host.ioBroker-master instance system.adapter.energiefluss-erweitert.0 in version "0.5.1-alpha.4" started with pid 1671
          2024-08-15 09:47:55.910 - info: energiefluss-erweitert.0 (1671) starting. Version 0.5.1-alpha.4 in /opt/iobroker/node_modules/iobroker.energiefluss-erweitert, node: v18.17.1, js-controller: 6.0.9
          2024-08-15 09:47:55.925 - info: energiefluss-erweitert.0 (1671) Adapter started. Loading config!
          2024-08-15 09:47:55.939 - info: energiefluss-erweitert.0 (1671) Sources: {"sonnen.0.status.userSoc":{"id":1,"factor":1,"elmSources":[13,18],"elmAnimations":[],"addSources":[],"subtractSources":[]},"sonnen.0.status.consumption":{"id":2,"factor":1,"elmSources":[7],"elmAnimations":[],"addSources":[],"subtractSources":[]},"sonnen.0.status.gridFeedIn":{"id":3,"factor":1,"elmSources":[19,20],"elmAnimations":["anim_path_5_14","anim_path_14_7"],"addSources":[],"subtractSources":[]},"sonnen.0.status.pacTotal":{"id":4,"factor":1,"elmSources":[16,28],"elmAnimations":["anim_path_5_13","anim_path_13_7"],"addSources":[],"subtractSources":[]},"evcc.0.loadpoint.1.status.chargePower":{"id":5,"factor":1,"elmSources":[23,26],"elmAnimations":["anim_path_7_22"],"addSources":[],"subtractSources":[9]},"evcc.0.loadpoint.1.status.vehicleSoc":{"id":6,"factor":1,"elmSources":[22,27],"elmAnimations":[],"addSources":[],"subtractSources":[]},"sonnen.0.status.production":{"id":7,"factor":1,"elmSources":[2,5,6],"elmAnimations":["anim_path_5_7"],"addSources":[],"subtractSources":[]},"pvforecast.0.summary.energy.today":{"id":8,"factor":1,"elmSources":[31,38,55],"elmAnimations":[],"addSources":[],"subtractSources":[]},"javascript.0.Solar.Produktion.heute":{"id":9,"factor":1,"elmSources":[34,39,54],"elmAnimations":[],"addSources":[],"subtractSources":[]},"energiefluss-erweitert.0.calculation.battery.remaining":{"id":10,"factor":1,"elmSources":[37],"elmAnimations":[],"addSources":[],"subtractSources":[]},"shelly.0.SHPLG-S#DE6919#1.Relay0.Power":{"id":11,"factor":1,"elmSources":[43],"elmAnimations":["anim_path_7_40"],"addSources":[],"subtractSources":[9]},"shelly.0.SHSW-PM#E89F6D847D4C#1.Relay0.Power":{"id":12,"factor":1,"elmSources":[46,48],"elmAnimations":["anim_path_7_45"],"addSources":[],"subtractSources":[9]},"0_userdata.0.Energiefluss_Test.verbrauch":{"id":13,"factor":1,"elmSources":[],"elmAnimations":[],"addSources":[],"subtractSources":[]},"0_userdata.0.Energiefluss_Test.Test-String":{"id":14,"factor":1,"elmSources":[],"elmAnimations":[],"addSources":[],"subtractSources":[]},"energiefluss-erweitert.0.calculation.battery.remaining_target_DT":{"id":15,"factor":1,"elmSources":[],"elmAnimations":[],"addSources":[],"subtractSources":[]},"shelly.0.SHSW-PM#84CCA8AC76BE#1.Relay0.Switch":{"id":16,"factor":1,"elmSources":[],"elmAnimations":[],"addSources":[],"subtractSources":[]},"energiefluss-erweitert.0.calculation.consumption.consumption":{"id":17,"factor":1,"elmSources":[9],"elmAnimations":[],"addSources":[],"subtractSources":[]},"sonnen.0.configurations.EM_USOC":{"id":19,"factor":1,"elmSources":[],"elmAnimations":[],"addSources":[],"subtractSources":[]},"sonnen.0.configurations.CM_MarketingModuleCapacity":{"id":20,"factor":1,"elmSources":[],"elmAnimations":[],"addSources":[],"subtractSources":[]},"shelly.0.SHPLG-S#DE6919#1.Relay0.Switch":{"id":21,"factor":1,"elmSources":[],"elmAnimations":[],"addSources":[],"subtractSources":[]},"weatherunderground.0.forecast.0d.iconURL":{"id":"weatherunderground.0.forecast.0d.iconURL","elmSources":["56"]}}
          2024-08-15 09:47:55.939 - info: energiefluss-erweitert.0 (1671) Loading initial for sonnen.0.status.userSoc with {"val":0,"ack":true,"ts":1723708073999,"q":0,"from":"system.adapter.sonnen.0","user":"system.user.admin","lc":1723510323475}
          Das sind die wichtigen Ausgaben.
          • U66U U66
            @skb
            SKBS Offline
            SKBS Offline
            SKB
            #311
            @u66 Wenn Du nochmal die Version von Github installierst, sollte der Fehler weg sein.
            @ralle Dein Fehler sollte damit auch "Geschichte" sein ;)
            U66U ralleR 2 Antworten Letzte Antwort
            • SKBS SKB
              U66U Offline
              U66U Offline
              U66
              #312
              @skb
              Ja haut alles wieder hin.....Danke
              • SKBS SKB
                ralleR Offline
                ralleR Offline
                ralle
                #313
                @skb said in Test Adapter Energiefluss-erweitert v0.5.x-alpha.x GitHub:
                tja nun hab ich alles neu gemacht, egal. Lag also nicht mir , hatte ich keinen Fehler gemacht...?
                • ralleR ralle
                  SKBS Offline
                  SKBS Offline
                  SKB
                  #314
                  @ralle ... Geduld ist eine Tugend 😉
                  Wenn ein Programm durch den Benutzer abstürzt, hat nicht der Benutzer den Fehler begangen, sondern der Programmierer schlampig gearbeitet oder schlichtweg etwas übersehen :)
                  ralleR 1 Antwort Letzte Antwort
                  • SKBS SKB
                    ralleR Offline
                    ralleR Offline
                    ralle
                    #315
                    Das kann man so nicht stehen lassen...... vielen Dank das du diesen Adapter Programmiert hast und so viel Zeit investierst. So etwas zu Programmieren muss man auch erst mal können.
                    .......und, nur wer Arbeitet kann Fehler machen, wer behauptet er würde keine Fehler machen der Arbeitet auch nicht!
                    • ralleR ralle
                      SKBS Offline
                      SKBS Offline
                      SKB
                      #316
                      @ralle Danke Dir! Freut mich, wenn der Adapter dir gefällt, einen Nutzen und Freude bringt 👍😉
                      Ja, da hast Du allerdings Recht!
                      • SKBS Offline
                        SKBS Offline
                        SKB
                        #317
                        Hallo Zusammen,
                        ich hatte die Idee, noch ein Kontextmenü beim Rechtsklick anzubieten. Welche hilfreichen Eigenschaften könnte man hier Eurer Meinung nach unterbringen?
                        2024-08-16 17_53_56-Energiefluss - erweitert Configuration – Mozilla Firefox.png
                        • SKBS SKB
                          Hallo Zusammen,
                          U66U Offline
                          U66U Offline
                          U66
                          #318
                          @skb
                          Zuweisung eines Datenpunktes ?
                          falls ich das richtig verstanden habe.............
                          • U66U U66
                            @skb
                            SKBS Offline
                            SKBS Offline
                            SKB
                            #319
                            @u66 Auch eine Idee.
                            Aber da denke ich, das dies über die Configbar besser ist?!
                            • SKBS SKB
                              U66U Offline
                              U66U Offline
                              U66
                              #320
                              @skb
                              Hallo
                              hab mal noch was
                              mein Sonnenaufgang zeigt mir jetzt wohl die sekunden an...
                              Wie bekomme ich die denn wieder weg.
                              • U66U U66
                                @skb
                                Hallo
                                hab mal noch was
                                SKBS Offline
                                SKBS Offline
                                SKB
                                #321
                                @u66 Umformatieren und dann in eigenen Datenpunkt.
                                Gibt keine Formatierung. Vielleicht mal drüber überlegen.
                                • SKBS SKB
                                  U66U Offline
                                  U66U Offline
                                  U66
                                  #322
                                  @skb
                                  Ja ist ja kein Thema
                                  wunderte mich nur, weil es erst bei dem neuesten Adapterupdate zusehen war.
                                  habs auch heute erst vernommen.
                                  Ich leg einfach ein kleines Rechteck mit Hintergrundfarbe drüber, geht ja auch
                                  • U66U U66
                                    @skb
                                    SKBS Offline
                                    SKBS Offline
                                    SKB
                                    #323
                                    @u66 Wo bekommst Du denn die Werte her? Kann man dort nicht die Bedingungen einstellen, das keine Sekunden kommen?
                                    • U66U Offline
                                      U66U Offline
                                      U66
                                      #324
                                      @skb
                                      Astrozeiten sind fest im Javascript Adapter drinn
                                      Die sek. sind wohl durch ein Update dazugekommen.
                                      Ist ja nicht weiter schlimm, hatte mich nur gewundert
                                      früher
                                      • U66U U66
                                        @skb
                                        früher
                                        SKBS Offline
                                        SKBS Offline
                                        SKB
                                        #325
                                        @u66 Gucke ich mir mal an.
                                        Vielleicht kann ich da etwas hinzufügen.
                                        • U66U Offline
                                          U66U Offline
                                          U66
                                          #326
                                          @skb
                                          noch was ist mir aufgefallen
                                          wenn ich eine neue Instanz habe und füge ein Bild ein kann ich es nicht markieren.
                                          füge ich dagegen ein 2.Bild hinzu läst sich dieses wie gewohnt markieren und bearbeiten.
                                          Das 1. Bild kann aber weiterhin nicht gelöscht bzw.bearbeitet werden.
                                          Das betrifft wie ich sehe nur eine komplett leere Instanz in der auch zuvor die Vorgaben gelöscht wurden..............
                                          Der Post kann ignoriert werden......😕
