  4. Test Adapter Energiefluss-erweitert v0.8.x GitHub/Latest
diagrammenergieflussenergiefluss-erweitertvisvisualisierungvisualization
1.7k Beiträge 78 Kommentatoren 1.1m Aufrufe 78 Beobachtet
  • U66U U66
    @skb
    energiefluss-erweitert.1
    	2024-08-11 15:09:55.954	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    	2024-08-11 15:09:55.953	info	terminating
    	2024-08-11 15:09:55.953	info	Cleared interval for relative values!
    	2024-08-11 15:09:55.951	error	Parameter "id" needs to be of type "string" but type "undefined" has been passed
    	2024-08-11 15:09:55.951	error	Error: Parameter "id" needs to be of type "string" but type "undefined" has been passed at Validator.assertString (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/validator.js:129:13) at EnergieflussErweitert.getForeignState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js:4538:32) at /opt/iobroker/node_modules/@iobroker/js-controller-common-db/build/cjs/lib/common/tools.js:1586:18 at new Promise (<anonymous>) at EnergieflussErweitert.getForeignStateAsync (/opt/iobroker/node_modules/@iobroker/js-controller-common-db/build/cjs/lib/common/tools.js:1584:12) at EnergieflussErweitert.calculateValue (/opt/iobroker/node_modules/iobroker.energiefluss-erweitert/main.js:311:29) at sourceRunner (/opt/iobroker/node_modules/iobroker.energiefluss-erweitert/main.js:828:20) at async EnergieflussErweitert.refreshData (/opt/iobroker/node_modules/iobroker.energiefluss-erweitert/main.js:845:7) at async EnergieflussErweitert.getConfig (/opt/iobroker/node_modules/iobroker.energiefluss-erweitert/main.js:1522:4)
    	2024-08-11 15:09:55.949	error	unhandled promise rejection: Parameter "id" needs to be of type "string" but type "undefined" has been passed
    	2024-08-11 15:09:55.949	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    SKBS Offline
    SKBS Offline
    SKB
    #303
    @u66 Könntest Du die Version von Gihub nochmals drüber installieren. Ich habe zum Testen einmal ein paar Ausgaben zugefügt. Nicht wundern - der Fehler sollte noch bestehen, aber die Ausgabe wären wichtig. Könntest Du diese dann hier einstellen?
    Danke!
    U66U 1 Antwort Letzte Antwort
    • SKBS SKB
      Danke!
      U66U Offline
      U66U Offline
      U66
      #304
      @skb
      Bin auch gerade unterwegs, wird erst am Abend
      • U66U U66
        @skb
        U66U Offline
        U66U Offline
        U66
        schrieb am zuletzt editiert von U66
        #305
        @u66 ```
        energiefluss-erweitert.0
        	2024-08-15 07:52:50.168	info	terminating
        web.0
        	2024-08-15 07:52:50.157	info	socket.io server listening on port 8082
        web.0
        	2024-08-15 07:52:50.037	info	starting. Version 6.2.5 in /opt/iobroker/node_modules/iobroker.web, node: v18.20.4, js-controller: 6.0.9
        	2024-08-15 07:52:49.667	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
        	2024-08-15 07:52:49.666	info	terminating
        	2024-08-15 07:52:49.666	info	Cleared interval for relative values!
        	2024-08-15 07:52:49.664	error	Error: Parameter "id" needs to be of type "string" but type "undefined" has been passed at Validator.assertString (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/validator.js:129:13) at EnergieflussErweitert.getForeignState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js:4538:32) at /opt/iobroker/node_modules/@iobroker/js-controller-common-db/build/cjs/lib/common/tools.js:1586:18 at new Promise (<anonymous>) at EnergieflussErweitert.getForeignStateAsync (/opt/iobroker/node_modules/@iobroker/js-controller-common-db/build/cjs/lib/common/tools.js:1584:12) at EnergieflussErweitert.calculateValue (/opt/iobroker/node_modules/iobroker.energiefluss-erweitert/main.js:311:29) at sourceRunner (/opt/iobroker/node_modules/iobroker.energiefluss-erweitert/main.js:828:20) at async EnergieflussErweitert.refreshData (/opt/iobroker/node_modules/iobroker.energiefluss-erweitert/main.js:845:7) at async EnergieflussErweitert.getConfig (/opt/iobroker/node_modules/iobroker.energiefluss-erweitert/main.js:1522:4)
        	2024-08-15 07:52:49.664	error	Parameter "id" needs to be of type "string" but type "undefined" has been passed
        	2024-08-15 07:52:49.663	error	unhandled promise rejection: Parameter "id" needs to be of type "string" but type "undefined" has been passed
        	2024-08-15 07:52:49.663	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        	2024-08-15 07:52:49.662	debug	Value-Settings for Element 466 found! Applying Settings!
        	2024-08-15 07:52:49.662	debug	Values for: 466 - Using source: 36 rawValue: false Settings: {"threshold":0,"type":"image","source":36,"source_type":"boolean"}
        	2024-08-15 07:52:49.661	debug	Values for: 205 - Using source: 36 rawValue: false Settings: {"threshold":0,"calculate_kw":"none","decimal_places":0,"convert":false,"type":"text","source":36,"source_option":-1,"source_display":"own_text","subtract":[-1],"add":[-1],"source_type":"boolean","text":""}
        	2024-08-15 07:52:49.661	debug	Updated through elmSources: {"1":44,"14":0,"15":17910,"16":201,"17":184,"18":385,"19":80,"20":731,"21":0.11,"22":0,"23":3.31,"24":0.5,"25":266,"27":0,"28":0,"29":1,"30":"--:--h","32":0,"33":false,"34":false,"36":false}
        	2024-08-15 07:52:49.661	debug	Current Value of tuya.0.74500708e09806147e72.1: false - saved Value: undefined
        	2024-08-15 07:52:49.661	info	Loading initial for tuya.0.74500708e09806147e72.1 with {"val":false,"ack":true,"ts":1723701123604,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1723650417095}
        	2024-08-15 07:52:49.661	debug	Value of tuya.0.74500708e09806147e72.1 changed! Processing!
        	2024-08-15 07:52:49.661	debug	Value-Settings for Element 205 found! Applying Settings!
        SKBS 1 Antwort Letzte Antwort
        • U66U U66
          @u66 ```
          web.0
          web.0
          SKBS Offline
          SKBS Offline
          SKB
          #306
          @u66 Das sieht mir nicht nach der neueren Version aus, da eine Menge Info Logs fehlen.
          Bitte über Benutzerdefiniert via Github Katze installieren, upload machen und dann die Ausgabe posten. Adapter muss nicht auf Debug stehen.
          • SKBS SKB
            U66U Offline
            U66U Offline
            U66
            #307
            @skb
            	2024-08-15 09:37:53.013	debug	State changed! New value for Source: alpha-ess.0.Realtime.PV_power_string_1 with Value: 770 belongs to Elements: 93,124
            	2024-08-15 09:37:53.013	debug	Value: 770 is greater than Threshold: 0. Applying Animation!
            	2024-08-15 09:37:53.013	debug	Animation has a positive factor!
            	2024-08-15 09:37:53.012	debug	Animation - Settings for Element anim_path_303_387 found! Applying Settings!
            	2024-08-15 09:37:53.012	debug	Found corresponding animations for ID: alpha-ess.0.Realtime.PV_power_string_1 !Applying!
            	2024-08-15 09:37:53.012	debug	Values for: 124 - Using source: 16 rawValue: 770 Settings: {"threshold":0,"type":"circle","source":16,"fill_type":-1,"border_type":-1,"source_type":"number"}
            	2024-08-15 09:37:53.012	debug	Value-Settings for Element 124 found! Applying Settings!
            	2024-08-15 09:37:52.990	debug	Threshold for: 93 is: 0
            	2024-08-15 09:37:52.990	debug	Values for: 93 - Using source: 16 rawValue: 770 Settings: {"threshold":0,"calculate_kw":"auto","decimal_places":1,"convert":false,"type":"text","source":16,"source_option":-1,"source_display":"value","subtract":[-1],"add":[-1],"override":{">=0":{"display":"fill","fill":"rgb(26,255,49","unit":" W","value":"val => val.toFixed(0)"},">=1000":{"unit":" kW","value":"val => parseFloat(val/1000).toFixed(2)","display":"fill","fill":"rgb(26,255,49"},">=9995":{"unit":" kW","value":"val => parseFloat(val/1000).toFixed(1)","display":"fill","fill":"rgb(26,255,49"},"<= -9995":{"unit":" kW","value":"val => parseFloat(val*-1/1000).toFixed(1)","display":"fill","fill":"rgb(34,139,34)"},"<= -1000":{"unit":" kW","value":"val => parseFloat(val*-1/1000).toFixed(2)","display":"fill","fill":"rgb(34,139,34)"},"default":{"unit":" W","value":"val => (val*-1).toFixed(0)","display":"fill","fill":"rgb(34,139,34)"}},"source_type":"number","text":"ID 93"}
            	2024-08-15 09:37:52.990	debug	Gathering override for ID: 93, Value: 770 and Override: {">=0":{"display":"fill","fill":"rgb(26,255,49","unit":" W","value":"val => val.toFixed(0)"},">=1000":{"unit":" kW","value":"val => parseFloat(val/1000).toFixed(2)","display":"fill","fill":"rgb(26,255,49"},">=9995":{"unit":" kW","value":"val => parseFloat(val/1000).toFixed(1)","display":"fill","fill":"rgb(26,255,49"},"<= -9995":{"unit":" kW","value":"val => parseFloat(val*-1/1000).toFixed(1)","display":"fill","fill":"rgb(34,139,34)"},"<= -1000":{"unit":" kW","value":"val => parseFloat(val*-1/1000).toFixed(2)","display":"fill","fill":"rgb(34,139,34)"},"default":{"unit":" W","value":"val => (val*-1).toFixed(0)","display":"fill","fill":"rgb(34,139,34)"}}
            	2024-08-15 09:37:52.989	debug	Updated through elmSources: {"1":62.4,"14":0,"15":17910,"16":770}
            	2024-08-15 09:37:52.989	debug	Current Value of alpha-ess.0.Realtime.PV_power_string_1: 770 - saved Value: undefined
            	2024-08-15 09:37:52.989	info	Loading initial for alpha-ess.0.Realtime.PV_power_string_1 with {"val":770,"ack":true,"ts":1723707460725,"q":0,"from":"system.adapter.alpha-ess.0","user":"system.user.admin","lc":1723707460725}
            	2024-08-15 09:37:52.989	debug	Value of alpha-ess.0.Realtime.PV_power_string_1 changed! Processing!
            	2024-08-15 09:37:52.989	debug	Value-Settings for Element 93 found! Applying Settings!
            • U66U U66
              @skb
              SKBS Offline
              SKBS Offline
              SKB
              #308
              @u66 Bitte den Adapter nicht auf Debug stellen, sondern einfach nur starten! Dann den Inhalt des Startes hier einstellen.
              Diese Log-Fetzen sind ja völlig aus dem Zusammenhang.
              • SKBS SKB
                U66U Offline
                U66U Offline
                U66
                #309
                @skb
                	2024-08-15 10:03:37.227	info	terminating
                	2024-08-15 10:03:36.726	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                	2024-08-15 10:03:36.725	info	terminating
                	2024-08-15 10:03:36.725	info	Cleared interval for relative values!
                	2024-08-15 10:03:36.722	error	Parameter "id" needs to be of type "string" but type "undefined" has been passed
                	2024-08-15 10:03:36.722	error	Error: Parameter "id" needs to be of type "string" but type "undefined" has been passed at Validator.assertString (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/validator.js:129:13) at EnergieflussErweitert.getForeignState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js:4538:32) at /opt/iobroker/node_modules/@iobroker/js-controller-common-db/build/cjs/lib/common/tools.js:1586:18 at new Promise (<anonymous>) at EnergieflussErweitert.getForeignStateAsync (/opt/iobroker/node_modules/@iobroker/js-controller-common-db/build/cjs/lib/common/tools.js:1584:12) at EnergieflussErweitert.calculateValue (/opt/iobroker/node_modules/iobroker.energiefluss-erweitert/main.js:311:29) at sourceRunner (/opt/iobroker/node_modules/iobroker.energiefluss-erweitert/main.js:828:20) at async EnergieflussErweitert.refreshData (/opt/iobroker/node_modules/iobroker.energiefluss-erweitert/main.js:845:7) at async EnergieflussErweitert.getConfig (/opt/iobroker/node_modules/iobroker.energiefluss-erweitert/main.js:1522:4)
                SKBS 2 Antworten Letzte Antwort
                • U66U U66
                  @skb
                  SKBS Offline
                  SKBS Offline
                  SKB
                  #310
                  @u66 Da fehlen Info Ausgaben. Sowas wie:
                  2024-08-15 09:47:55.415 - info: host.ioBroker-master instance system.adapter.energiefluss-erweitert.0 in version "0.5.1-alpha.4" started with pid 1671
                  2024-08-15 09:47:55.910 - info: energiefluss-erweitert.0 (1671) starting. Version 0.5.1-alpha.4 in /opt/iobroker/node_modules/iobroker.energiefluss-erweitert, node: v18.17.1, js-controller: 6.0.9
                  2024-08-15 09:47:55.925 - info: energiefluss-erweitert.0 (1671) Adapter started. Loading config!
                  2024-08-15 09:47:55.939 - info: energiefluss-erweitert.0 (1671) Sources: {"sonnen.0.status.userSoc":{"id":1,"factor":1,"elmSources":[13,18],"elmAnimations":[],"addSources":[],"subtractSources":[]},"sonnen.0.status.consumption":{"id":2,"factor":1,"elmSources":[7],"elmAnimations":[],"addSources":[],"subtractSources":[]},"sonnen.0.status.gridFeedIn":{"id":3,"factor":1,"elmSources":[19,20],"elmAnimations":["anim_path_5_14","anim_path_14_7"],"addSources":[],"subtractSources":[]},"sonnen.0.status.pacTotal":{"id":4,"factor":1,"elmSources":[16,28],"elmAnimations":["anim_path_5_13","anim_path_13_7"],"addSources":[],"subtractSources":[]},"evcc.0.loadpoint.1.status.chargePower":{"id":5,"factor":1,"elmSources":[23,26],"elmAnimations":["anim_path_7_22"],"addSources":[],"subtractSources":[9]},"evcc.0.loadpoint.1.status.vehicleSoc":{"id":6,"factor":1,"elmSources":[22,27],"elmAnimations":[],"addSources":[],"subtractSources":[]},"sonnen.0.status.production":{"id":7,"factor":1,"elmSources":[2,5,6],"elmAnimations":["anim_path_5_7"],"addSources":[],"subtractSources":[]},"pvforecast.0.summary.energy.today":{"id":8,"factor":1,"elmSources":[31,38,55],"elmAnimations":[],"addSources":[],"subtractSources":[]},"javascript.0.Solar.Produktion.heute":{"id":9,"factor":1,"elmSources":[34,39,54],"elmAnimations":[],"addSources":[],"subtractSources":[]},"energiefluss-erweitert.0.calculation.battery.remaining":{"id":10,"factor":1,"elmSources":[37],"elmAnimations":[],"addSources":[],"subtractSources":[]},"shelly.0.SHPLG-S#DE6919#1.Relay0.Power":{"id":11,"factor":1,"elmSources":[43],"elmAnimations":["anim_path_7_40"],"addSources":[],"subtractSources":[9]},"shelly.0.SHSW-PM#E89F6D847D4C#1.Relay0.Power":{"id":12,"factor":1,"elmSources":[46,48],"elmAnimations":["anim_path_7_45"],"addSources":[],"subtractSources":[9]},"0_userdata.0.Energiefluss_Test.verbrauch":{"id":13,"factor":1,"elmSources":[],"elmAnimations":[],"addSources":[],"subtractSources":[]},"0_userdata.0.Energiefluss_Test.Test-String":{"id":14,"factor":1,"elmSources":[],"elmAnimations":[],"addSources":[],"subtractSources":[]},"energiefluss-erweitert.0.calculation.battery.remaining_target_DT":{"id":15,"factor":1,"elmSources":[],"elmAnimations":[],"addSources":[],"subtractSources":[]},"shelly.0.SHSW-PM#84CCA8AC76BE#1.Relay0.Switch":{"id":16,"factor":1,"elmSources":[],"elmAnimations":[],"addSources":[],"subtractSources":[]},"energiefluss-erweitert.0.calculation.consumption.consumption":{"id":17,"factor":1,"elmSources":[9],"elmAnimations":[],"addSources":[],"subtractSources":[]},"sonnen.0.configurations.EM_USOC":{"id":19,"factor":1,"elmSources":[],"elmAnimations":[],"addSources":[],"subtractSources":[]},"sonnen.0.configurations.CM_MarketingModuleCapacity":{"id":20,"factor":1,"elmSources":[],"elmAnimations":[],"addSources":[],"subtractSources":[]},"shelly.0.SHPLG-S#DE6919#1.Relay0.Switch":{"id":21,"factor":1,"elmSources":[],"elmAnimations":[],"addSources":[],"subtractSources":[]},"weatherunderground.0.forecast.0d.iconURL":{"id":"weatherunderground.0.forecast.0d.iconURL","elmSources":["56"]}}
                  2024-08-15 09:47:55.939 - info: energiefluss-erweitert.0 (1671) Loading initial for sonnen.0.status.userSoc with {"val":0,"ack":true,"ts":1723708073999,"q":0,"from":"system.adapter.sonnen.0","user":"system.user.admin","lc":1723510323475}
                  Das sind die wichtigen Ausgaben.
                  • U66U U66
                    @skb
                    SKBS Offline
                    SKBS Offline
                    SKB
                    #311
                    @u66 Wenn Du nochmal die Version von Github installierst, sollte der Fehler weg sein.
                    @ralle Dein Fehler sollte damit auch "Geschichte" sein ;)
                    U66U ralleR 2 Antworten Letzte Antwort
                    • SKBS SKB
                      U66U Offline
                      U66U Offline
                      U66
                      #312
                      @skb
                      Ja haut alles wieder hin.....Danke
                      • SKBS SKB
                        ralleR Offline
                        ralleR Offline
                        ralle
                        #313
                        @skb said in Test Adapter Energiefluss-erweitert v0.5.x-alpha.x GitHub:
                        tja nun hab ich alles neu gemacht, egal. Lag also nicht mir , hatte ich keinen Fehler gemacht...?
                        • ralleR ralle
                          SKBS Offline
                          SKBS Offline
                          SKB
                          #314
                          @ralle ... Geduld ist eine Tugend 😉
                          Wenn ein Programm durch den Benutzer abstürzt, hat nicht der Benutzer den Fehler begangen, sondern der Programmierer schlampig gearbeitet oder schlichtweg etwas übersehen :)
                          ralleR 1 Antwort Letzte Antwort
                          • SKBS SKB
                            ralleR Offline
                            ralleR Offline
                            ralle
                            #315
                            Das kann man so nicht stehen lassen...... vielen Dank das du diesen Adapter Programmiert hast und so viel Zeit investierst. So etwas zu Programmieren muss man auch erst mal können.
                            .......und, nur wer Arbeitet kann Fehler machen, wer behauptet er würde keine Fehler machen der Arbeitet auch nicht!
                            • ralleR ralle
                              SKBS Offline
                              SKBS Offline
                              SKB
                              #316
                              @ralle Danke Dir! Freut mich, wenn der Adapter dir gefällt, einen Nutzen und Freude bringt 👍😉
                              Ja, da hast Du allerdings Recht!
                              • SKBS Offline
                                SKBS Offline
                                SKB
                                #317
                                Hallo Zusammen,
                                ich hatte die Idee, noch ein Kontextmenü beim Rechtsklick anzubieten. Welche hilfreichen Eigenschaften könnte man hier Eurer Meinung nach unterbringen?
                                2024-08-16 17_53_56-Energiefluss - erweitert Configuration – Mozilla Firefox.png
                                • SKBS SKB
                                  Hallo Zusammen,
                                  U66U Offline
                                  U66U Offline
                                  U66
                                  #318
                                  @skb
                                  Zuweisung eines Datenpunktes ?
                                  falls ich das richtig verstanden habe.............
                                  • U66U U66
                                    @skb
                                    SKBS Offline
                                    SKBS Offline
                                    SKB
                                    #319
                                    @u66 Auch eine Idee.
                                    Aber da denke ich, das dies über die Configbar besser ist?!
                                    • SKBS SKB
                                      U66U Offline
                                      U66U Offline
                                      U66
                                      #320
                                      @skb
                                      Hallo
                                      hab mal noch was
                                      mein Sonnenaufgang zeigt mir jetzt wohl die sekunden an...
                                      Wie bekomme ich die denn wieder weg.
                                      • U66U U66
                                        @skb
                                        Hallo
                                        hab mal noch was
                                        SKBS Offline
                                        SKBS Offline
                                        SKB
                                        #321
                                        @u66 Umformatieren und dann in eigenen Datenpunkt.
                                        Gibt keine Formatierung. Vielleicht mal drüber überlegen.
                                        • SKBS SKB
                                          U66U Offline
                                          U66U Offline
                                          U66
                                          #322
                                          @skb
                                          Ja ist ja kein Thema
                                          wunderte mich nur, weil es erst bei dem neuesten Adapterupdate zusehen war.
                                          habs auch heute erst vernommen.
                                          Ich leg einfach ein kleines Rechteck mit Hintergrundfarbe drüber, geht ja auch
