  4. iobroker Shutdown/Start unter Windows
18 Beiträge 5 Kommentatoren 2.3k Aufrufe 3 Beobachtet
  • GaspodeG Gaspode
    Ich habe jetzt mal ein Minimal System unter Windows auf den neuesten JS-Controller aktualisiert. Grundsätzlich läuft alles, aber das Log sieht etwas merkwürdig aus, oder sind diese "Already Running" meldungen normal?
    Sorry, wenn das schon Thema gewesen sein sollte, dann hab ich es übersehen.
    2024-05-24 08:42:58.450  - info: host.SmartHome5 iobroker.js-controller version 6.0.1 js-controller starting
    2024-05-24 08:42:58.451  - info: host.SmartHome5 Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
    2024-05-24 08:42:58.452  - info: host.SmartHome5 hostname: SmartHome5, node: v18.20.3
    2024-05-24 08:42:58.452  - info: host.SmartHome5 ip addresses: XXXXXXXXXXXXXXXXXXXXXXXXXXXX
    2024-05-24 08:42:58.570  - info: host.SmartHome5 connected to Objects and States
    2024-05-24 08:42:58.575  - info: host.SmartHome5 added notifications configuration of host
    2024-05-24 08:42:58.735  - info: host.SmartHome5 4 instances found
    2024-05-24 08:42:58.738  - info: host.SmartHome5 starting 3 instances
    2024-05-24 08:42:58.811  - info: host.SmartHome5 Delete state "system.host.SmartHome5.versions.nodeCurrent"
    2024-05-24 08:42:58.818  - info: host.SmartHome5 Delete state "system.host.SmartHome5.versions.nodeNewest"
    2024-05-24 08:42:58.828  - info: host.SmartHome5 instance system.adapter.admin.0 started with pid 3656
    2024-05-24 08:42:58.829  - info: host.SmartHome5 Delete state "system.host.SmartHome5.versions.nodeNewestNext"
    2024-05-24 08:42:58.831  - info: host.SmartHome5 Delete state "system.host.SmartHome5.versions.npmCurrent"
    2024-05-24 08:42:58.831  - info: host.SmartHome5 Delete state "system.host.SmartHome5.versions.npmNewest"
    2024-05-24 08:42:58.833  - info: host.SmartHome5 Delete state "system.host.SmartHome5.versions.npmNewestNext"
    2024-05-24 08:42:58.834  - info: host.SmartHome5 Some obsolete host states deleted.
    2024-05-24 08:42:59.582  - error: admin.0 (3656) admin.0 already running
    2024-05-24 08:42:59.583  - warn: admin.0 (3656) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2024-05-24 08:43:00.121  - error: host.SmartHome5 instance system.adapter.admin.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2024-05-24 08:43:00.121  - info: host.SmartHome5 Restart adapter system.adapter.admin.0 because enabled
    2024-05-24 08:43:02.835  - info: host.SmartHome5 instance system.adapter.backitup.0 started with pid 11512
    2024-05-24 08:43:03.342  - error: backitup.0 (11512) backitup.0 already running
    2024-05-24 08:43:03.343  - warn: backitup.0 (11512) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2024-05-24 08:43:03.872  - error: host.SmartHome5 instance system.adapter.backitup.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2024-05-24 08:43:03.872  - info: host.SmartHome5 Restart adapter system.adapter.backitup.0 because enabled
    2024-05-24 08:43:06.826  - info: host.SmartHome5 instance system.adapter.discovery.0 started with pid 40380
    2024-05-24 08:43:07.322  - error: discovery.0 (40380) discovery.0 already running
    2024-05-24 08:43:07.323  - warn: discovery.0 (40380) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2024-05-24 08:43:07.852  - error: host.SmartHome5 instance system.adapter.discovery.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2024-05-24 08:43:07.853  - info: host.SmartHome5 Restart adapter system.adapter.discovery.0 because enabled
    2024-05-24 08:43:30.223  - info: host.SmartHome5 instance system.adapter.admin.0 started with pid 26844
    2024-05-24 08:43:31.051  - info: admin.0 (26844) starting. Version 6.13.16 in C:/ioBroker/SmartHome5/node_modules/iobroker.admin, node: v18.20.3, js-controller: 6.0.1-alpha.0-20240523-1d3cb759c
    2024-05-24 08:43:31.062  - info: admin.0 (26844) requesting all objects
    2024-05-24 08:43:31.204  - info: admin.0 (26844) received all objects
    2024-05-24 08:43:31.248  - info: admin.0 (26844) socket.io server listening on port 8191
    2024-05-24 08:43:31.249  - info: admin.0 (26844) http server listening on port 8191
    2024-05-24 08:43:31.249  - info: admin.0 (26844) Use link "http://127.0.0.1:8191" to configure.
    2024-05-24 08:43:33.966  - info: host.SmartHome5 instance system.adapter.backitup.0 started with pid 2380
    2024-05-24 08:43:34.465  - info: admin.0 (26844) ==> Connected system.user.admin from ::1
    2024-05-24 08:43:34.657  - info: backitup.0 (2380) starting. Version 2.11.0 in C:/ioBroker/SmartHome5/node_modules/iobroker.backitup, node: v18.20.3, js-controller: 6.0.1-alpha.0-20240523-1d3cb759c
    2024-05-24 08:43:34.680  - info: backitup.0 (2380) [iobroker] backup will be activated at 02:48 every 1 day(s)
    2024-05-24 08:43:37.946  - info: host.SmartHome5 instance system.adapter.discovery.0 started with pid 39616
    2024-05-24 08:43:38.571  - info: discovery.0 (39616) starting. Version 4.4.0 in C:/ioBroker/SmartHome5/node_modules/iobroker.discovery, node: v18.20.3, js-controller: 6.0.1-alpha.0-20240523-1d3cb759c
    sigi234S
    sigi234S
    @gaspode sagte in Alpha Test js-controller Kiera (v6.0):
    Diese Meldungen habe ich schon ewig.
    • GaspodeG Gaspode
      mcm1957M
      mcm1957M
      mcm1957
      @gaspode
      Ich hab die Meldungen auch- Ich hab sie bisher auf mein sehr zähes Windows System geschoben. Wenn sie allerdings auch nach einem sauberen Shutdown und mit viiiel Wartezeit od. Host Reboot kommen dann wär das m.E. ein issue wert. Ev. wird da beim Systemstart irgenein Status nicht sauber gesetzt. ZU diesbezüglichen Hypothesen kann aber Foxriver76 sicher mehr sagen bzw sagen ob da was gezielt (und wie) getestet werden kann - soll ja nicht jede Analyse gleich bei ihm landen.
      Support Repositoryverwaltung.
      LESEN - gute Forenbeitrage
      GaspodeG 1 Antwort Letzte Antwort
      • mcm1957M mcm1957
        @gaspode
        GaspodeG
        GaspodeG
        Gaspode
        @mcm1957 said in Alpha Test js-controller Kiera (v6.0):
        Ich hab jetzt nochmal ein wenig rum probiert. Ich hab die Meldung auch mit dem aktuellen JS-Controller, wenn ich "kurz" zuvor ioBroker gestoppt habe und "gleich" wieder starte. Ist mir noch nie aufgefallen. Node.js Prozesse gibt es zu dieser Zeit allerdings keine mehr.
        Evtl. hängt es damit zusammen, dass auch "iob status" nach dem Stoppen noch eine Zeit lang fälschlicherweise sagt, "obroker is running on this host."
        Hat also wohl wirklich nix mit dem neuen Controller zu tun. Ich behalte das mal im Hinterkopf und mache bei Gelegenheit noch ein paar Tests. ggfs. folgt dann auch ein Issue.
        • GaspodeG Gaspode
          mcm1957M
          mcm1957M
          mcm1957
          @gaspode said in Alpha Test js-controller Kiera (v6.0):
          Ich tippe drauf, dass da was beim Shutdown unsauber abläuft und beim Start nicht wirklich bereinigt wird. Es betrifft (bei mir) ja nicht alle Adapter.
          Um 11:22 hab ich das System runtergefahren. Dabei wurde von 3 Adaptern (admin, backitup und notification manager) ein "unsauberer" shutdown mit nachfolgendem Restart gelogged.
          Und genau diese 3 Adapter haben beim Start ab 11:37 einen already running error gemeldet.
          @foxriver76
          Hast du da eine Idee dazu? Kann ich / wir da was testen um es weiter einzugrenzen?
          Auch wenn wahrscheinlich kein neues js-controlelr 6 issue ist könnte man es ev mit dem js-controller 6 fixen. Ist aber in jedem Fall eher cosmetic.
          Übrigends: Der js-controller logged scheinbar nicht, dass er den Befehl zum stoppen bekommen hat. Wär m.e. sinnvoll das im Log zu haben. Ich schreib dazu einen Feature Issue.
          v6.17.11
          22
          69
          Log-Größe: 26.8 KB
          Zeit
          debug
          Nachricht
          admin.0
          2024-05-24 11:42:36.689	info	==> Connected system.user.admin from ::1
          discovery.0
          2024-05-24 11:38:26.404	info	starting. Version 4.2.0 in C:/ioBroker/node_modules/iobroker.discovery, node: v20.13.1, js-controller: 6.0.1-alpha.0-20240523-1d3cb759c
          host.Envy
          2024-05-24 11:38:24.894	info	instance system.adapter.discovery.0 started with pid 23076
          notification-manager.0
          2024-05-24 11:38:18.271	info	Starting notification manager ...
          2024-05-24 11:38:18.260	info	starting. Version 1.1.2 in C:/ioBroker/node_modules/iobroker.notification-manager, node: v20.13.1, js-controller: 6.0.1-alpha.0-20240523-1d3cb759c
          host.Envy
          2024-05-24 11:38:16.979	info	instance system.adapter.notification-manager.0 started with pid 11636
          backitup.0
          2024-05-24 11:38:15.504	info	[iobroker] backup will be activated at 02:40 every 1 day(s)
          backitup.0
          2024-05-24 11:38:15.456	info	starting. Version 2.10.11 in C:/ioBroker/node_modules/iobroker.backitup, node: v20.13.1, js-controller: 6.0.1-alpha.0-20240523-1d3cb759c
          admin.0
          2024-05-24 11:38:13.322	info	Use link "http://127.0.0.1:8081" to configure.
          admin.0
          2024-05-24 11:38:13.322	info	http server listening on port 8081
          admin.0
          2024-05-24 11:38:13.320	info	socket.io server listening on port 8081
          host.Envy
          2024-05-24 11:38:13.302	info	instance system.adapter.backitup.0 started with pid 1460
          admin.0
          2024-05-24 11:38:13.023	info	received all objects
          admin.0
          2024-05-24 11:38:12.213	info	requesting all objects
          admin.0
          2024-05-24 11:38:12.192	info	starting. Version 6.17.11 in C:/ioBroker/node_modules/iobroker.admin, node: v20.13.1, js-controller: 6.0.1-alpha.0-20240523-1d3cb759c
          host.Envy
          2024-05-24 11:38:10.024	info	instance system.adapter.admin.0 started with pid 8660
          host.Envy
          2024-05-24 11:37:56.430	info	instance system.adapter.ical.1 terminated with code 0 (NO_ERROR)
          ical.1
          2024-05-24 11:37:55.908	info	Terminated (NO_ERROR): Without reason
          host.Envy
          2024-05-24 11:37:54.547	info	Restart adapter system.adapter.discovery.0 because enabled
          host.Envy
          2024-05-24 11:37:54.547	error	instance system.adapter.discovery.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
          discovery.0
          2024-05-24 11:37:54.012	warn	Terminated (ADAPTER_ALREADY_RUNNING): Without reason
          discovery.0
          2024-05-24 11:37:54.011	error	discovery.0 already running
          host.Envy
          2024-05-24 11:37:52.741	info	instance system.adapter.discovery.0 started with pid 10408
          ical.1
          2024-05-24 11:37:50.889	info	All calenders could not be processed, Do not clean up events
          ical.1
          2024-05-24 11:37:50.888	warn	Error reading "http://11111.ics": Cannot read URL: "http://11111.ics"
          ical.1
          2024-05-24 11:37:50.888	warn	Error reading from URL "http://11111.ics"
          ical.1
          2024-05-24 11:37:50.661	info	starting. Version 1.15.0 in C:/ioBroker/node_modules/iobroker.ical, node: v20.13.1, js-controller: 6.0.1-alpha.0-20240523-1d3cb759c
          host.Envy
          2024-05-24 11:37:48.837	info	instance system.adapter.ical.1 started with pid 16528
          host.Envy
          2024-05-24 11:37:48.829	info	instance scheduled system.adapter.ical.1 0,4 0,30 * * * *
          host.Envy
          2024-05-24 11:37:46.671	info	Restart adapter system.adapter.notification-manager.0 because enabled
          host.Envy
          2024-05-24 11:37:46.670	error	instance system.adapter.notification-manager.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
          2024-05-24 11:37:46.126	warn	Terminated (ADAPTER_ALREADY_RUNNING): Without reason
          2024-05-24 11:37:46.124	error	notification-manager.0 already running
          host.Envy
          2024-05-24 11:37:44.776	info	instance system.adapter.notification-manager.0 started with pid 14436
          host.Envy
          2024-05-24 11:37:42.774	info	Restart adapter system.adapter.backitup.0 because enabled
          host.Envy
          2024-05-24 11:37:42.774	error	instance system.adapter.backitup.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
          backitup.0
          2024-05-24 11:37:42.250	warn	Terminated (ADAPTER_ALREADY_RUNNING): Without reason
          backitup.0
          2024-05-24 11:37:42.249	error	backitup.0 already running
          host.Envy
          2024-05-24 11:37:40.733	info	instance system.adapter.backitup.0 started with pid 19664
          host.Envy
          2024-05-24 11:37:39.629	info	Restart adapter system.adapter.admin.0 because enabled
          host.Envy
          2024-05-24 11:37:39.629	error	instance system.adapter.admin.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
          admin.0
          2024-05-24 11:37:39.056	warn	Terminated (ADAPTER_ALREADY_RUNNING): Without reason
          admin.0
          2024-05-24 11:37:39.054	error	admin.0 already running
          host.Envy
          2024-05-24 11:37:36.798	info	Some obsolete host states deleted.
          host.Envy
          2024-05-24 11:37:36.795	info	Delete state "system.host.Envy.versions.npmNewestNext"
          host.Envy
          2024-05-24 11:37:36.791	info	Delete state "system.host.Envy.versions.npmNewest"
          host.Envy
          2024-05-24 11:37:36.787	info	Delete state "system.host.Envy.versions.npmCurrent"
          host.Envy
          2024-05-24 11:37:36.781	info	instance system.adapter.admin.0 started with pid 12684
          host.Envy
          2024-05-24 11:37:36.774	info	Delete state "system.host.Envy.versions.nodeNewestNext"
          host.Envy
          2024-05-24 11:37:36.766	info	Delete state "system.host.Envy.versions.nodeNewest"
          host.Envy
          2024-05-24 11:37:36.728	info	Delete state "system.host.Envy.versions.nodeCurrent"
          host.Envy
          2024-05-24 11:37:36.419	info	starting 5 instances
          host.Envy
          2024-05-24 11:37:36.404	info	17 instances found
          host.Envy
          2024-05-24 11:37:35.648	info	added notifications configuration of host
          host.Envy
          2024-05-24 11:37:35.632	info	connected to Objects and States
          host.Envy
          2024-05-24 11:37:35.136	info	ip addresses: 10.17.2.100 fe80::3089:3ca1:e684:7494 10.17.2.16
          host.Envy
          2024-05-24 11:37:35.136	info	hostname: Envy, node: v20.13.1
          host.Envy
          2024-05-24 11:37:35.136	info	Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
          host.Envy
          2024-05-24 11:37:35.133	info	iobroker.js-controller version 6.0.1 js-controller starting
          host.Envy
          2024-05-24 11:22:35.097	info	Restart adapter system.adapter.notification-manager.0 because enabled
          host.Envy
          2024-05-24 11:22:35.097	error	instance system.adapter.notification-manager.0 terminated with code 4294967295 ()
          host.Envy
          2024-05-24 11:22:34.914	info	Restart adapter system.adapter.backitup.0 because enabled
          host.Envy
          2024-05-24 11:22:34.914	error	instance system.adapter.backitup.0 terminated with code 4294967295 ()
          host.Envy
          2024-05-24 11:22:34.733	info	Restart adapter system.adapter.admin.0 because enabled
          host.Envy
          2024-05-24 11:22:34.732	error	instance system.adapter.admin.0 terminated with code 4294967295 ()
          sigi234S GaspodeG 2 Antworten Letzte Antwort
          • mcm1957M mcm1957
            @foxriver76
            v6.17.11
            22
            69
            Log-Größe: 26.8 KB
            Zeit
            debug
            Nachricht
            admin.0
            discovery.0
            host.Envy
            host.Envy
            backitup.0
            backitup.0
            admin.0
            admin.0
            admin.0
            host.Envy
            admin.0
            admin.0
            admin.0
            host.Envy
            host.Envy
            ical.1
            host.Envy
            host.Envy
            discovery.0
            discovery.0
            host.Envy
            ical.1
            ical.1
            ical.1
            ical.1
            host.Envy
            host.Envy
            host.Envy
            host.Envy
            host.Envy
            host.Envy
            host.Envy
            backitup.0
            backitup.0
            host.Envy
            host.Envy
            host.Envy
            admin.0
            admin.0
            host.Envy
            host.Envy
            host.Envy
            host.Envy
            host.Envy
            host.Envy
            host.Envy
            host.Envy
            host.Envy
            host.Envy
            host.Envy
            host.Envy
            host.Envy
            host.Envy
            host.Envy
            host.Envy
            host.Envy
            host.Envy
            host.Envy
            host.Envy
            host.Envy
            host.Envy
            sigi234S
            sigi234S
            @mcm1957 sagte in Alpha Test js-controller Kiera (v6.0):
            Bei mir sind es einige mehr. War aber immer schon so. Beruhigt sich nach einiger Zeit wieder. Bis zum Neustart eben.
            host.SmartHome
            2024-05-24 11:58:49.508	error	instance system.adapter.upnp.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
            host.SmartHome
            2024-05-24 11:58:41.067	error	instance system.adapter.vis-inventwo.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
            host.SmartHome
            2024-05-24 11:58:37.231	error	instance system.adapter.sayit.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
            host.SmartHome
            2024-05-24 11:58:25.628	error	instance system.adapter.ecovacs-deebot.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
            host.SmartHome
            2024-05-24 11:58:22.100	error	instance system.adapter.vis-2.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
            host.SmartHome
            2024-05-24 11:58:16.992	error	instance system.adapter.parser.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
            host.SmartHome
            2024-05-24 11:58:13.106	error	instance system.adapter.tapo.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
            host.SmartHome
            2024-05-24 11:58:09.359	error	instance system.adapter.pollenflug.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
            host.SmartHome
            2024-05-24 11:58:05.571	error	instance system.adapter.musiccast.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
            host.SmartHome
            2024-05-24 11:58:01.679	error	instance system.adapter.web.1 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
            host.SmartHome
            2024-05-24 11:57:57.194	error	instance system.adapter.iot.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
            host.SmartHome
            2024-05-24 11:57:53.440	error	instance system.adapter.jarvis.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
            host.SmartHome
            2024-05-24 11:57:49.746	error	instance system.adapter.fb-checkpresence.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
            host.SmartHome
            2024-05-24 11:57:45.893	error	instance system.adapter.weather-warnings.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
            host.SmartHome
            2024-05-24 11:57:42.774	error	instance system.adapter.alarm.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
            host.SmartHome
            2024-05-24 11:57:32.892	error	instance system.adapter.socketio.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
            host.SmartHome
            2024-05-24 11:57:29.354	error	instance system.adapter.ws.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
            host.SmartHome
            2024-05-24 11:57:24.995	error	instance system.adapter.web.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
            host.SmartHome
            2024-05-24 11:57:17.208	error	instance system.adapter.snmp.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
            host.SmartHome
            2024-05-24 11:57:12.895	error	instance system.adapter.lgtv.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
            host.SmartHome
            2024-05-24 11:57:05.988	error	instance system.adapter.meross.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
            host.SmartHome
            2024-05-24 11:56:57.522	error	instance system.adapter.cloud.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
            host.SmartHome
            2024-05-24 11:56:50.507	error	instance system.adapter.alexa2.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
            host.SmartHome
            2024-05-24 11:56:45.626	error	instance system.adapter.yamaha.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
            host.SmartHome
            2024-05-24 11:56:42.406	error	instance system.adapter.tr-064.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
            host.SmartHome
            2024-05-24 11:56:37.747	error	instance system.adapter.hm-rpc.1 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
            host.SmartHome
            2024-05-24 11:56:32.874	error	instance system.adapter.hm-rega.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
            host.SmartHome
            2024-05-24 11:56:28.974	error	instance system.adapter.hm-rpc.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
            host.SmartHome
            2024-05-24 11:56:24.950	error	instance system.adapter.hue.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
            host.SmartHome
            2024-05-24 11:56:20.873	error	instance system.adapter.backitup.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
            host.SmartHome
            2024-05-24 11:56:16.888	error	instance system.adapter.email.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
            host.SmartHome
            2024-05-24 11:56:13.251	error	instance system.adapter.javascript.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
            host.SmartHome
            2024-05-24 11:56:09.200	error	instance system.adapter.history.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
            host.SmartHome
            2024-05-24 11:56:05.239	error	instance system.adapter.admin.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
            host.SmartHome
            2024-05-24 11:55:52.252	error	instance system.adapter.vis-inventwo.0 terminated with code 4294967295 ()
            host.SmartHome
            2024-05-24 11:55:52.143	error	instance system.adapter.sayit.0 terminated with code 4294967295 ()
            host.SmartHome
            2024-05-24 11:55:52.042	error	instance system.adapter.ecovacs-deebot.0 terminated with code 4294967295 ()
            host.SmartHome
            2024-05-24 11:55:51.928	error	instance system.adapter.vis-2.0 terminated with code 4294967295 ()
            host.SmartHome
            2024-05-24 11:55:51.827	error	instance system.adapter.parser.0 terminated with code 4294967295 ()
            host.SmartHome
            2024-05-24 11:55:51.724	error	instance system.adapter.tapo.0 terminated with code 4294967295 ()
            host.SmartHome
            2024-05-24 11:55:51.540	error	instance system.adapter.pollenflug.0 terminated with code 4294967295 ()
            host.SmartHome
            2024-05-24 11:55:51.400	error	instance system.adapter.musiccast.0 terminated with code 4294967295 ()
            host.SmartHome
            2024-05-24 11:55:51.300	error	instance system.adapter.web.1 terminated with code 4294967295 ()
            host.SmartHome
            2024-05-24 11:55:51.182	error	instance system.adapter.iot.0 terminated with code 4294967295 ()
            host.SmartHome
            2024-05-24 11:55:51.081	error	instance system.adapter.jarvis.0 terminated with code 4294967295 ()
            host.SmartHome
            2024-05-24 11:55:50.961	error	instance system.adapter.fb-checkpresence.0 terminated with code 4294967295 ()
            host.SmartHome
            2024-05-24 11:55:50.853	error	instance system.adapter.weather-warnings.0 terminated with code 4294967295 ()
            host.SmartHome
            2024-05-24 11:55:50.752	error	instance system.adapter.alarm.0 terminated with code 4294967295 ()
            host.SmartHome
            2024-05-24 11:55:50.652	error	instance system.adapter.socketio.0 terminated with code 4294967295 ()
            host.SmartHome
            2024-05-24 11:55:50.553	error	instance system.adapter.ws.0 terminated with code 4294967295 ()
            host.SmartHome
            2024-05-24 11:55:50.447	error	instance system.adapter.web.0 terminated with code 4294967295 ()
            host.SmartHome
            2024-05-24 11:55:50.347	error	instance system.adapter.snmp.0 terminated with code 4294967295 ()
            host.SmartHome
            2024-05-24 11:55:50.250	error	instance system.adapter.lgtv.0 terminated with code 4294967295 ()
            host.SmartHome
            2024-05-24 11:55:50.149	error	instance system.adapter.meross.0 terminated with code 4294967295 ()
            host.SmartHome
            2024-05-24 11:55:50.050	error	instance system.adapter.cloud.0 terminated with code 4294967295 ()
            host.SmartHome
            2024-05-24 11:55:49.944	error	instance system.adapter.alexa2.0 terminated with code 4294967295 ()
            host.SmartHome
            2024-05-24 11:55:49.825	error	instance system.adapter.yamaha.0 terminated with code 4294967295 ()
            host.SmartHome
            2024-05-24 11:55:49.697	error	instance system.adapter.tr-064.0 terminated with code 4294967295 ()
            host.SmartHome
            2024-05-24 11:55:49.576	error	instance system.adapter.hm-rpc.1 terminated with code 4294967295 ()
            host.SmartHome
            2024-05-24 11:55:49.471	error	instance system.adapter.hm-rega.0 terminated with code 4294967295 ()
            host.SmartHome
            2024-05-24 11:55:49.363	error	instance system.adapter.hm-rpc.0 terminated with code 4294967295 ()
            host.SmartHome
            2024-05-24 11:55:49.226	error	instance system.adapter.hue.0 terminated with code 4294967295 ()
            host.SmartHome
            2024-05-24 11:55:49.091	error	instance system.adapter.backitup.0 terminated with code 4294967295 ()
            host.SmartHome
            2024-05-24 11:55:48.983	error	instance system.adapter.email.0 terminated with code 4294967295 ()
            host.SmartHome
            2024-05-24 11:55:48.883	error	instance system.adapter.javascript.0 terminated with code 4294967295 ()
            host.SmartHome
            2024-05-24 11:55:48.747	error	instance system.adapter.history.0 terminated with code 4294967295 ()
            host.SmartHome
            2024-05-24 11:55:48.583	error	instance system.adapter.admin.0 terminated with code 4294967295 ()
            • mcm1957M mcm1957
              @sigi234
              OK, aber auch diese haben einen "ungewöhnlichen" Existstatus beim Beenden.
              sigi234S
              sigi234S
              @sigi234
              Jupp, hat wahrscheinlich nix mit js-controller Kiera zu tun, ev. sollte man das abtrennen in einen Neuen Beitrag?
              • sigi234S sigi234
                @sigi234
                mcm1957M
                mcm1957M
                mcm1957
                @sigi234 said in Alpha Test js-controller Kiera (v6.0):
                @sigi234
                Jaein.
                Warten wir mal ab ob / was @Foxriver76 sagt. Wenn es ein js-controller Problem ist kann es ev. auch hier bleiben. Wenn wir mehr Suchdiskussion brauchen ists ev. extra besser. Aber im Prinzip ist im Moment wahrscheinlich alles geschrieben bis wer der den betreffenden Code gut kennt sagen kann was da los ist bzw. zu suchen wäre. Ist jedenfalls kein Einzelfall.
                • mcm1957M mcm1957
                  @foxriver76
                  v6.17.11
                  22
                  69
                  Log-Größe: 26.8 KB
                  Zeit
                  debug
                  Nachricht
                  admin.0
                  discovery.0
                  host.Envy
                  host.Envy
                  backitup.0
                  backitup.0
                  admin.0
                  admin.0
                  admin.0
                  host.Envy
                  admin.0
                  admin.0
                  admin.0
                  host.Envy
                  host.Envy
                  ical.1
                  host.Envy
                  host.Envy
                  discovery.0
                  discovery.0
                  host.Envy
                  ical.1
                  ical.1
                  ical.1
                  ical.1
                  host.Envy
                  host.Envy
                  host.Envy
                  host.Envy
                  host.Envy
                  host.Envy
                  host.Envy
                  backitup.0
                  backitup.0
                  host.Envy
                  host.Envy
                  host.Envy
                  admin.0
                  admin.0
                  host.Envy
                  host.Envy
                  host.Envy
                  host.Envy
                  host.Envy
                  host.Envy
                  host.Envy
                  host.Envy
                  host.Envy
                  host.Envy
                  host.Envy
                  host.Envy
                  host.Envy
                  host.Envy
                  host.Envy
                  host.Envy
                  host.Envy
                  host.Envy
                  host.Envy
                  host.Envy
                  host.Envy
                  host.Envy
                  GaspodeG
                  GaspodeG
                  Gaspode
                  schrieb am zuletzt editiert von Gaspode
                  Hmm, ich denke immer noch, dass da grundsätzlich was krumm ist unter Windows.
                  Versuch(t) mal folgendes bei gestartetem ioBroker:
                  iob stop
                  iob status
                  iob status
                  iob start
                  Bei mir antwortet "iob status" Nummer 1 "iobroker is running on this host.", obwohl keinerlei Node.js-Prozess auf dem Rechner läuft. Aufruf Nummer 2 liefert "iobroker is not running on this host.", wie es sein soll. Der nächste Start erfolgt dann bei mir sauber OHNE diese ADAPTER_ALREADY_RUNNING Meldungen.
                  2024-05-24 13:05:28.210  - info: host.SmartHome5 iobroker.js-controller version 6.0.1 js-controller starting
                  2024-05-24 13:05:28.211  - info: host.SmartHome5 Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
                  2024-05-24 13:05:28.211  - info: host.SmartHome5 hostname: SmartHome5, node: v20.13.1
                  2024-05-24 13:05:28.211  - info: host.SmartHome5 ip addresses: XXXXXXXXXXXXXXXXXXXXXXX
                  2024-05-24 13:05:28.335  - info: host.SmartHome5 connected to Objects and States
                  2024-05-24 13:05:28.339  - info: host.SmartHome5 added notifications configuration of host
                  2024-05-24 13:05:28.478  - info: host.SmartHome5 4 instances found
                  2024-05-24 13:05:28.479  - info: host.SmartHome5 starting 3 instances
                  2024-05-24 13:05:28.543  - info: host.SmartHome5 Delete state "system.host.SmartHome5.versions.nodeCurrent"
                  2024-05-24 13:05:28.548  - info: host.SmartHome5 Delete state "system.host.SmartHome5.versions.nodeNewest"
                  2024-05-24 13:05:28.558  - info: host.SmartHome5 instance system.adapter.admin.0 started with pid 31324
                  2024-05-24 13:05:28.559  - info: host.SmartHome5 Delete state "system.host.SmartHome5.versions.nodeNewestNext"
                  2024-05-24 13:05:28.560  - info: host.SmartHome5 Delete state "system.host.SmartHome5.versions.npmCurrent"
                  2024-05-24 13:05:28.561  - info: host.SmartHome5 Delete state "system.host.SmartHome5.versions.npmNewest"
                  2024-05-24 13:05:28.562  - info: host.SmartHome5 Delete state "system.host.SmartHome5.versions.npmNewestNext"
                  2024-05-24 13:05:28.562  - info: host.SmartHome5 Some obsolete host states deleted.
                  2024-05-24 13:05:29.331  - info: admin.0 (31324) starting. Version 6.13.16 in C:/ioBroker/SmartHome5/node_modules/iobroker.admin, node: v20.13.1, js-controller: 6.0.1-alpha.0-20240523-1d3cb759c
                  2024-05-24 13:05:29.343  - info: admin.0 (31324) requesting all objects
                  2024-05-24 13:05:29.479  - info: admin.0 (31324) received all objects
                  2024-05-24 13:05:29.523  - info: admin.0 (31324) socket.io server listening on port 8191
                  2024-05-24 13:05:29.523  - info: admin.0 (31324) http server listening on port 8191
                  2024-05-24 13:05:29.523  - info: admin.0 (31324) Use link "http://127.0.0.1:8191" to configure.
                  2024-05-24 13:05:32.566  - info: host.SmartHome5 instance system.adapter.backitup.0 started with pid 36456
                  2024-05-24 13:05:33.240  - info: backitup.0 (36456) starting. Version 2.11.0 in C:/ioBroker/SmartHome5/node_modules/iobroker.backitup, node: v20.13.1, js-controller: 6.0.1-alpha.0-20240523-1d3cb759c
                  2024-05-24 13:05:33.261  - info: backitup.0 (36456) [iobroker] backup will be activated at 02:48 every 1 day(s)
                  2024-05-24 13:05:36.571  - info: host.SmartHome5 instance system.adapter.discovery.0 started with pid 32412
                  2024-05-24 13:05:37.209  - info: discovery.0 (32412) starting. Version 4.4.0 in C:/ioBroker/SmartHome5/node_modules/iobroker.discovery, node: v20.13.1, js-controller: 6.0.1-alpha.0-20240523-1d3cb759c
                  Das verhält sich bei mir gleich mit Controller 5 und 6. also evtl. doch abtrennen, um das hier übersichtlicher zu halten?
                  • GaspodeG Gaspode
                    iob stop
                    iob status
                    iob status
                    iob start
                    wenn gewünscht, bitte Link zum ersten abzutrennenden Post.
                      GaspodeG
                      GaspodeG
                      Gaspode
                      @homoran said in Alpha Test js-controller Kiera (v6.0):
                      Lass uns mal warten, ob und was @foxriver76 dazu meint.
                      Betroffen sind diese Beiträge:
                      https://forum.iobroker.net/post/1162260
                      https://forum.iobroker.net/post/1162264
                      https://forum.iobroker.net/post/1162266
                      https://forum.iobroker.net/post/1162267
                      https://forum.iobroker.net/post/1162311
                      https://forum.iobroker.net/post/1162316
                      https://forum.iobroker.net/post/1162317
                      https://forum.iobroker.net/post/1162327
                      https://forum.iobroker.net/post/1162329
                      https://forum.iobroker.net/post/1162355
                      foxriver76F HomoranH 2 Antworten Letzte Antwort
                      • GaspodeG Gaspode
                        foxriver76F
                        foxriver76F
                        foxriver76
                        @gaspode @Homoran gerne abtrennen, das ist alles Controller Shutdown unter Windows, was schon immer abrupt passiert ist, da bräuchte man mal Infos wie das überhaupt gestoppt wird von Usern normalerweise. Und ich habe da auch aktuell eher keinen Fokus drauf.
                        Videotutorials & mehr
                        • GaspodeG Gaspode
                          @gaspode Danke fpr die Liste, hat aber leider beim selektieren nicht geholfen, wenn ich im Auswahlmenü bin.
                          ich hoffe ich habe alles und nicht zu viel.
                          wie immer
                          ggf. provisorischen Threadtitel anpassen
                            wie immer
                            GaspodeG
                            GaspodeG
                            Gaspode
                            @homoran said in iobroker Shutdown unter Windowe:
                            Sieht gut aus, Danke.
                            • foxriver76F
                              foxriver76F
                              foxriver76
                              schrieb am zuletzt editiert von foxriver76
                              Falscher Thread ;-)
                              • foxriver76F foxriver76
                                Falscher Thread ;-)
                                mcm1957M
                                mcm1957M
                                mcm1957
                                -- obsoleter Text ---
                                • GaspodeG
                                  GaspodeG
                                  Gaspode
                                  Hier geht es weiter:
                                  https://forum.iobroker.net/topic/75829
                                  @Homoran
                                  Ich denke, dieser Thread hier kann geschlossen werden. Wärst du so nett? Danke. :)
                                  • GaspodeG Gaspode
                                    @Homoran
                                    @gaspode erledigt!
                                    84.2k
