  4. npm Error bei mihome-vacuum Adapter Installation
33 Beiträge 7 Kommentatoren 3.9k Aufrufe 5 Beobachtet
  • WintermuteW Offline
    WintermuteW Offline
    Wintermute
    schrieb am zuletzt editiert von Wintermute
    Ich habe gerade das Update auf die 4.2.0 und habe das Problem, dass die Installation offenbar sauber durchläuft, der Adapter aber nicht mehr startet ("Verbunden mit Gerät oder Dienst" ist grün, der Rest rot)
    iob update und iob upgrade hab ich probiert, keine Resultate:
    C:\ioBroker>iob update
    Used repository: stable
    Adapter    "admin"        : 6.13.16  , installed 6.13.16
    Adapter    "backitup"     : 2.11.0   , installed 2.11.0
    Adapter    "bring"        : 1.8.4    , installed 1.8.4
    Adapter    "daswetter"    : 3.1.13   , installed 3.1.13
    Adapter    "deconz"       : 1.4.0    , installed 1.4.0
    Adapter    "discovery"    : 4.4.0    , installed 4.4.0
    Adapter    "echarts"      : 1.7.2    , installed 1.7.2
    Adapter    "email"        : 1.2.2    , installed 1.2.2
    Adapter    "fb-checkpresence": 1.2.4 , installed 1.2.4
    Adapter    "homeconnect"  : 1.3.0    , installed 1.3.0
    Adapter    "ical"         : 1.14.3   , installed 1.14.3
    Adapter    "javascript"   : 7.8.0    , installed 7.8.0
    Controller "js-controller": 5.0.19   , installed 5.0.19
    Adapter    "mihome-vacuum": 4.2.0    , installed 4.2.0
    Adapter    "nina"         : 0.0.25   , installed 0.0.25
    Adapter    "rssfeed"      : 2.6.1    , installed 2.6.1
    Adapter    "sayit"        : 3.0.5    , installed 3.0.5
    Adapter    "socketio"     : 6.6.1    , installed 6.6.1
    Adapter    "trashschedule": 3.2.0    , installed 3.2.0
    Adapter    "vis"          : 1.5.4    , installed 1.5.1  [Updatable]
    Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
    Adapter    "weatherunderground": 3.6.0, installed 3.6.0
    Adapter    "web"          : 6.2.5    , installed 6.2.5
    Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
    Adapter    "ws"           : 2.5.11   , installed 2.5.11
    C:\ioBroker>iob upgrade
    This upgrade of "vis" will introduce the following changes:
    -> 1.5.4:
    added the new binding operation for getting property of JSON or object
    Checked the initialization of the `local_` variables
    fixed subscribeOidAtRuntime
    Added dynamic web manifest
    Optimization for basic-view in widget8
    Changed binding regex to accept umlauts
    Corrected first installation of vis
    Would you like to upgrade vis from @1.5.1 to @1.5.4 now? [(y)es, (n)o]: n
    No upgrade of "vis" desired.
    Vis habe ich aus Gründen nicht aktualisiert, weil ansonsten einige ältere Tablets nicht mehr klarkommen.
    Ein "Iob fix" bringt:
    Need to install the following packages:
      @iobroker/fix@5.0.0
    Ok to proceed? (y) y
    "(" kann syntaktisch an dieser Stelle nicht verarbeitet werden.
    npm notice
    npm notice New major version of npm available! 9.5.0 -> 10.5.2
    npm notice Changelog: https://github.com/npm/cli/releases/tag/v10.5.2
    npm notice Run npm install -g npm@10.5.2 to update!
    npm notice
    Hat das Eine mit dem Anderen zu tun?
    Iobroker als Windows-VM auf einem Supermicro-Server
    WintermuteW ? 2 Antworten Letzte Antwort
    • WintermuteW Wintermute
      -> 1.5.4:
        @iobroker/fix@5.0.0
      npm notice
      npm notice
      WintermuteW Offline
      WintermuteW Offline
      Wintermute
      @wintermute sagte in npm Error bei mihome-vacuum Adapter Installation:
      -> 1.5.4:
        @iobroker/fix@5.0.0
      npm notice
      npm notice
      Zusätzlich noch "iob info":
      C:\ioBroker>iob info
      Cannot get disk information: Command failed: df -k /
      Der Befehl "df" ist entweder falsch geschrieben oder
      konnte nicht gefunden werden.
      Platform       : Windows
      os             : win64
      Architecture   : x64
      CPUs           : 2
      Model          : Intel(R) Xeon(R) CPU 8460Y+ @ 2.0 GHz
      RAM            : 126 GB
      System uptime  : 2d. 20:25:52
      Node.js        : v18.15.0
      time           : 1713536349613
      timeOffset     : -120
      NPM            : 9.5.0
      adapters count : 538
      • P Offline
        pusemuckel
        schrieb am zuletzt editiert von pusemuckel
        ich habe das gleiche Problem seit dem Update auf die neue Version
        host.iobroker
        	2024-04-19 16:31:31.427	error	instance system.adapter.mihome-vacuum.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        host.iobroker
        	2024-04-19 16:31:31.426	error	Caught by controller[1]: Node.js v20.12.2
        host.iobroker
        	2024-04-19 16:31:31.426	error	Caught by controller[0]: }
        host.iobroker
        	2024-04-19 16:31:31.425	error	Caught by controller[0]: code: 'ERR_INVALID_ARG_VALUE'
        host.iobroker
        	2024-04-19 16:31:31.425	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1369:14) {
        host.iobroker
        	2024-04-19 16:31:31.425	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.mihome-vacuum/node_modules/@iobroker/adapter-core/build/cjs/controllerTools.js:34:22)
        host.iobroker
        	2024-04-19 16:31:31.424	error	Caught by controller[0]: at require (node:internal/modules/helpers:179:18)
        host.iobroker
        	2024-04-19 16:31:31.424	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1231:19)
        host.iobroker
        	2024-04-19 16:31:31.424	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1022:12)
        host.iobroker
        	2024-04-19 16:31:31.424	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1206:32)
        host.iobroker
        	2024-04-19 16:31:31.423	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1427:10)
        host.iobroker
        	2024-04-19 16:31:31.423	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1369:14)
        host.iobroker
        	2024-04-19 16:31:31.418	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.mihome-vacuum/node_modules/@iobroker/adapter-core/build/cjs/helpers.js:36:53)
        host.iobroker
        	2024-04-19 16:31:31.418	error	Caught by controller[0]: at createRequire (node:internal/modules/cjs/loader:1506:13)
        host.iobroker
        	2024-04-19 16:31:31.418	error	Caught by controller[0]: TypeError [ERR_INVALID_ARG_VALUE]: The argument 'filename' must be a file URL object, file URL string, or absolute path string. Received 'file:// /opt/iobroker/node_modules/iobroker.mihome-vacuum/node_modules/@iobroker/adapter-core/build/cjs/helpers.js'
        host.iobroker
        	2024-04-19 16:31:31.417	error	Caught by controller[0]: ^
        host.iobroker
        	2024-04-19 16:31:31.417	error	Caught by controller[0]: throw new ERR_INVALID_ARG_VALUE('filename', filename,
        host.iobroker
        	2024-04-19 16:31:31.416	error	Caught by controller[0]: node:internal/modules/cjs/loader:1506
        Hat jemand eine Idee wo man schauen muss um das zu korrigieren ?
        Danke!
          -> 1.5.4:
            @iobroker/fix@5.0.0
          npm notice
          npm notice
          @wintermute
          bei Windows bin ich raus..
          WintermuteW 1 Antwort Letzte Antwort
          • P pusemuckel
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            Danke!
            @pusemuckel
            ist nicht der gleiche Fehler, wie der TE hat, aber irgendein script scheint filename falsch deklariert zu haben.. sofern ich den Fehler richtig verstehe.. ist ja nur n Auschschnitt vom Ende des Fehlers.. man muesste da halt mal wissen:
            welches System?
            welche Version?
            Logfile von Begin an, wenn der Adapter startet...
            Dann natuerlich noch die Grundsaetzlichen infos aus iob diag.
            P 1 Antwort Letzte Antwort
              @pusemuckel
              welches System?
              welche Version?
              pusemuckel
              @ilovegym
              Danke für Deine Rückmeldung!
              			v.2023-10-10
              model name	: Intel(R) Celeron(R) CPU J3455 @ 1.50GHz
              Kernel          : x86_64
              Userland        : amd64
              Docker          : v9.1.2
              Installation: 		Docker
              Kernel: 		x86_64
              Userland: 		amd64
              Timezone: 		Etc/UTC
              User-ID: 		0
              X-Server: 		false
              Pending OS-Updates: 	0
              Pending iob updates: 	0
              Nodejs-Installation: 	/usr/bin/nodejs 	v20.12.2
              			/usr/bin/node 		v20.12.2
              			/usr/bin/npm 		10.5.0
              			/usr/bin/npx 		10.5.0
              			/usr/bin/corepack 	0.25.2
              Recommended versions are nodejs 18.20.2 and npm 10.5.0
              MEMORY:
              Mem:             12G        6.7G        822M        188M        5.4G        5.7G
              Swap:           9.6G         60M        9.5G
              Total:           21G        6.8G         10G
              Active iob-Instances: 	26
              Active repo(s): stable
              ioBroker Core: 		js-controller 		5.0.19
              			admin 			6.13.16
              ioBroker Status: 	iobroker is running on this host.
              Objects type: jsonl
              States  type: redis
              + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
              Objects: 		15173
              States: 		11749
              Size of iob-Database:
              16M	/opt/iobroker/iobroker-data/objects.jsonl
              13M	/opt/iobroker/iobroker-data/objects.json.migrated
              13M	/opt/iobroker/iobroker-data/objects.json.bak.migrated
              3.5M	/opt/iobroker/iobroker-data/states.json.bak
              Adapter Log:
              host.iobroker
              	2024-04-19 17:08:23.959	info	Restart adapter system.adapter.mihome-vacuum.0 because enabled
              host.iobroker
              	2024-04-19 17:08:23.959	error	instance system.adapter.mihome-vacuum.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
              host.iobroker
              	2024-04-19 17:08:23.959	error	Caught by controller[0]: Node.js v20.12.2
              host.iobroker
              	2024-04-19 17:08:23.959	error	Caught by controller[0]: }
              host.iobroker
              	2024-04-19 17:08:23.958	error	Caught by controller[0]: code: 'ERR_INVALID_ARG_VALUE'
              host.iobroker
              	2024-04-19 17:08:23.958	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1369:14) {
              host.iobroker
              	2024-04-19 17:08:23.958	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.mihome-vacuum/node_modules/@iobroker/adapter-core/build/cjs/controllerTools.js:34:22)
              host.iobroker
              	2024-04-19 17:08:23.958	error	Caught by controller[0]: at require (node:internal/modules/helpers:179:18)
              host.iobroker
              	2024-04-19 17:08:23.958	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1231:19)
              host.iobroker
              	2024-04-19 17:08:23.957	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1022:12)
              host.iobroker
              	2024-04-19 17:08:23.957	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1206:32)
              host.iobroker
              	2024-04-19 17:08:23.957	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1427:10)
              host.iobroker
              	2024-04-19 17:08:23.957	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1369:14)
              host.iobroker
              	2024-04-19 17:08:23.956	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.mihome-vacuum/node_modules/@iobroker/adapter-core/build/cjs/helpers.js:36:53)
              host.iobroker
              	2024-04-19 17:08:23.956	error	Caught by controller[0]: at createRequire (node:internal/modules/cjs/loader:1506:13)
              host.iobroker
              	2024-04-19 17:08:23.956	error	Caught by controller[0]: TypeError [ERR_INVALID_ARG_VALUE]: The argument 'filename' must be a file URL object, file URL string, or absolute path string. Received 'file:// /opt/iobroker/node_modules/iobroker.mihome-vacuum/node_modules/@iobroker/adapter-core/build/cjs/helpers.js'
              host.iobroker
              	2024-04-19 17:08:23.956	error	Caught by controller[0]: ^
              host.iobroker
              	2024-04-19 17:08:23.955	error	Caught by controller[0]: throw new ERR_INVALID_ARG_VALUE('filename', filename,
              host.iobroker
              	2024-04-19 17:08:23.954	error	Caught by controller[0]: node:internal/modules/cjs/loader:1506
              host.iobroker
              	2024-04-19 17:08:23.723	info	instance system.adapter.mihome-vacuum.0 started with pid 5691
              Mehr log habe ich bzw. wo kann ich mehr log des Adapters finden ?
              ? mcm1957M 2 Antworten Letzte Antwort
              • P pusemuckel
                @ilovegym
                			v.2023-10-10
                Kernel          : x86_64
                Userland        : amd64
                Docker          : v9.1.2
                Kernel: 		x86_64
                Userland: 		amd64
                Timezone: 		Etc/UTC
                User-ID: 		0
                X-Server: 		false
                			/usr/bin/npm 		10.5.0
                			/usr/bin/npx 		10.5.0
                MEMORY:
                Swap:           9.6G         60M        9.5G
                Total:           21G        6.8G         10G
                			admin 			6.13.16
                Objects type: jsonl
                States  type: redis
                Objects: 		15173
                States: 		11749
                Adapter Log:
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                @pusemuckel
                mach mal in der Konsole des iobroker dockers ein "iob upload mihome-vacuum" und starte dann den Adapter nochmal.
                In die Konsole des Dockers kommst du im Terminal des Hosts (Synology? Proxmox? ) mit dem command
                sudo docker exec -tiu username containername /bin/bash
                bei mir ist das als user iobroker und der container heisst auch iobroker dann ein
                sudo docker exec -tiu iobroker iobroker /bin/bash
                danach bist du in /opt/iobroker und kannst als user iobroker die iob commands ausfuehren, ausser diejenigen, die ein iob maintenance brauchen..
                Ich gehe davon aus, dass du das buanet-docker-Image benutzt?
                edit:
                das Logfile bekommt man am schoensten, finde ich, in der Konsole mit dem command
                iob logs --watch
                  @pusemuckel
                  edit:
                  iob logs --watch
                  pusemuckel
                  @ilovegym said in npm Error bei mihome-vacuum Adapter Installation:
                  Das hatte ich schon gemacht, leider auch ohne Erfolg. Ich konnte es mit
                  npm install iobroker/adapter-core
                  korrigieren, danach lässt sich der Adapter wieder starten!
                  Schönes Wochenende!
                    @wintermute
                    WintermuteW Offline
                    WintermuteW Offline
                    Wintermute
                    @ilovegym ...und ich bei Linux 😀
                    Alle Reparaturversuche sind fehlgeschlagen - Einspielen des Updates von letzter Nacht hat meinem Iobroker und meinem Staubsauger aber wieder auf die Beine geholfen. Das Update auf die 4.2.0 werde ich dann mal besser auslassen...
                      Läuft.
                        Läuft.
                        WintermuteW Offline
                        WintermuteW Offline
                        Wintermute
                        @thomas-braun sagte in npm Error bei mihome-vacuum Adapter Installation:
                        Läuft.
                        Auf einem Windows-System? Hast Du irgendwelche Verrenkungen gemacht, damit der Adapter läuft?
                          Läuft.
                          @wintermute
                          Läuft natürlich auf einem Betriebssystem.
                          Gerade nochmal durchgestartet:
                          2024-04-19 18:46:09.700  - info: mihome-vacuum.0 (1232) Got terminate signal TERMINATE_YOURSELF
                          2024-04-19 18:46:09.727  - error: mihome-vacuum.0 (1232) Socket Close
                          2024-04-19 18:46:09.731  - info: mihome-vacuum.0 (1232) terminating
                          2024-04-19 18:46:09.734  - info: mihome-vacuum.0 (1232) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                          2024-04-19 18:46:10.221  - info: mihome-vacuum.0 (1232) terminating
                          2024-04-19 18:46:15.796  - info: mihome-vacuum.0 (680497) starting. Version 4.2.0 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v21.7.3, js-controller: 5.0.19
                          2024-04-19 18:46:15.867  - info: mihome-vacuum.0 (680497) IOT enabled, create state
                          2024-04-19 18:46:16.017  - info: mihome-vacuum.0 (680497) select standard vacuum protocol....
                          2024-04-19 18:46:16.494  - info: mihome-vacuum.0 (680497) create state for carpet_mode
                          2024-04-19 18:46:16.649  - info: mihome-vacuum.0 (680497) settest next timer: not available
                          Kein Ding, kommt sofort wieder hoch.
                          -1
                            @wintermute
                            WintermuteW Offline
                            WintermuteW Offline
                            Wintermute
                            @wintermute
                            Da bin ich mir sicher, dass es auf einem Betriebssystem läuft ;-)
                            Aber läuft es auch auf Meinem Betriebssystem?
                              @wintermute
                              @wintermute
                              Natürlich nicht.
                              • P pusemuckel
                                @ilovegym
                                			v.2023-10-10
                                Kernel          : x86_64
                                Userland        : amd64
                                Docker          : v9.1.2
                                Kernel: 		x86_64
                                Userland: 		amd64
                                Timezone: 		Etc/UTC
                                User-ID: 		0
                                X-Server: 		false
                                			/usr/bin/npm 		10.5.0
                                			/usr/bin/npx 		10.5.0
                                MEMORY:
                                Swap:           9.6G         60M        9.5G
                                Total:           21G        6.8G         10G
                                			admin 			6.13.16
                                Objects type: jsonl
                                States  type: redis
                                Objects: 		15173
                                States: 		11749
                                Adapter Log:
                                host.iobroker
                                host.iobroker
                                host.iobroker
                                host.iobroker
                                host.iobroker
                                host.iobroker
                                host.iobroker
                                host.iobroker
                                host.iobroker
                                host.iobroker
                                host.iobroker
                                host.iobroker
                                host.iobroker
                                host.iobroker
                                host.iobroker
                                host.iobroker
                                host.iobroker
                                host.iobroker
                                host.iobroker
                                host.iobroker
                                mcm1957M Online
                                mcm1957M Online
                                mcm1957
                                @pusemuckel
                                @wintermute
                                Siehe https://forum.iobroker.net/topic/74221/häufung-von-update-problemen/3
                                Support Repositoryverwaltung.
                                LESEN - gute Forenbeitrage
                                • mcm1957M mcm1957
                                  @pusemuckel
                                  @wintermute
                                  mcm1957M Online
                                  mcm1957M Online
                                  mcm1957
                                  Weiter gehts hier https://forum.iobroker.net/topic/74237/lösung-für-fehler-typeerror-err_invalid_arg_value
