  4. npm Error bei mihome-vacuum Adapter Installation
33 Beiträge 7 Kommentatoren 3.9k Aufrufe 5 Beobachtet
  • R Redbeard_81
    @thomas-braun said in npm Error bei mihome-vacuum Adapter Installation:
    Ich kann dir mit der schwammigen Beschreibung nicht folgen.
    iob update
    iob upgrade
    sagt?
    Sorry, damit kann ich jetzt nichts Anfangen, wo stand das?
    @redbeard_81
    Das sollst du in dein Terminal hacken. Ausgabe dann wieder hier rein, in CodeeTags eingebettet.
    R 1 Antwort Letzte Antwort
      @redbeard_81
      Redbeard_81
      Der mihome-vacuum Adapter wird nicht angezeigt
      "iob update"
      Used repository: stable
      Adapter    "admin"        : 6.13.16  , installed 6.13.16
      Adapter    "backitup"     : 2.10.11  , installed 2.10.11
      Adapter    "daikin"       : 1.4.2    , installed 1.4.2
      Adapter    "discovery"    : 4.4.0    , installed 3.0.3  [Updatable]
      Adapter    "ems-esp"      : 3.0.3    , installed 2.8.0  [Updatable]
      Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
      Adapter    "hm-rpc"       : 1.16.0   , installed 1.16.0
      Adapter    "javascript"   : 7.8.0    , installed 7.8.0
      Controller "js-controller": 5.0.19   , installed 5.0.19
      Adapter    "modbus"       : 6.1.0    , installed 6.1.0
      Adapter    "node-red"     : 5.2.0    , installed 5.1.0  [Updatable]
      Adapter    "pushover"     : 3.0.6    , installed 3.0.6
      Adapter    "shelly"       : 6.8.0    , installed 6.6.1  [Updatable]
      Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
      Adapter    "socketio"     : 6.6.1    , installed 4.2.0  [Updatable]
      Adapter    "tado"         : 0.5.3    , installed 0.5.3
      Adapter    "tankerkoenig" : 3.3.7    , installed 2.1.1  [Updatable]
      Adapter    "tuya"         : 3.15.0   , installed 3.15.0
      Adapter    "web"          : 6.2.3    , installed 4.3.0  [Updatable]
      Adapter    "ws"           : 2.5.11   , installed 1.3.0  [Updatable]
      Adapter    "zigbee"       : 1.10.1   , installed 1.10.1
      "iob upgrade"
      This upgrade of "ws" will at least introduce the following changes:
      -> 2.5.11:
      Some packages were updated
      -> 2.5.10:
      updated ws-server to increase file limit to 500 MB
      -> 2.5.9:
      Corrected the crash if authentication is enabled
      -> 2.5.8:
      Corrected adapter termination if the alias has no target
      -> 2.5.7:
      upgraded socket-classes to fix vis problems
      -> 2.5.6:
      upgraded socket-classes to correct the error by unsubscribing on client disconnect
      -> 2.5.5:
      upgraded socket-classes to fix crash cases
      BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
      Would you like to upgrade ws from @1.3.0 to @2.5.11 now? [(y)es, (n)o]: Y
      Update ws from @1.3.0 to @2.5.11
      NPM version: 10.5.0
      Installing iobroker.ws@2.5.11... (System call)
      added 2 packages, removed 3 packages, and changed 1 package in 9s
      134 packages are looking for funding
        run `npm fund` for details
      upload [11] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/de/translations.json i18n/de/translations.json application/json
      upload [10] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/en/translations.json i18n/en/translations.json application/json
      upload [9] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/es/translations.json i18n/es/translations.json application/json
      upload [8] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
      upload [7] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/it/translations.json i18n/it/translations.json application/json
      upload [6] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
      upload [5] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
      upload [4] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
      upload [3] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
      upload [2] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
      upload [1] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/jsonConfig.json jsonConfig.json application/json
      upload [0] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/ws.png ws.png image/png
      This upgrade of "web" will at least introduce the following changes:
      -> 6.2.3:
      update websocket library to increase maximum file size from 100 MB to 500 MB
      -> 6.2.2:
      -> 6.2.1:
      Added the user access list option
      -> 6.1.10:
      Corrected the start screen
      -> 6.1.7:
      Added the public accessibility check
      -> 6.1.6:
      Corrected socket.io connection
      -> 6.1.4:
      upgrade socketio and ws dependencies to fix vis subscribe problem
      Would you like to upgrade web from @4.3.0 to @6.2.3 now? [(y)es, (n)o]: ^Y
      No upgrade of "web" desired.
      This upgrade of "tankerkoenig" will at least introduce the following changes:
      -> 3.3.7:
      added difference to jsonTable #116
      added a log message for the error `parameter error`
      set the name length to 34 characters
      Added verification if the api key is encrypted
      updated the Dependencies
      -> 3.3.6:
      corrected the position of the warning message in the user interface
      Updated documentation and migration guide for stable version 3.3.6
      -> 3.3.5:
      fixed copy/paste bug in the UI
      -> 3.3.4:
      Fixed an issue where a zip code starting with 0 was displayed incorrectly [Issue #113].
      -> 3.3.3:
      fixed => adapter does not fetch data after a `requestData error` e.g. internet crash.
      added adapter migration guide from 3.1.x to 3.3.x or 3.2.x to 3.3.x
      Problem fixed [Problem #111]
      -> 3.3.2:
      Fixed TypeError: Cannot read property 'length' of undefined in addDiscount if value is `boolean / undefined`.
      Fixed error: DB closed when adapter is stopped
      Object creation optimized
      changed query interval default value to 10 minutes and minimum value to 10 minutes
      added check if station ID is already configured (in edit mode)
      Added price difference to last price
      added feature request cheapest station display [Issue #109]
      -> 3.3.1:
      Fixed TypeError: Cannot read properties of undefined Issue #104
      added complete street datapoint for each station
      Would you like to upgrade tankerkoenig from @2.1.1 to @3.3.7 now? [(y)es, (n)o]: Y
      Update tankerkoenig from @2.1.1 to @3.3.7
      host.raspberrypi-4-2 Adapter "system.adapter.tankerkoenig.0" is stopped.
      NPM version: 10.5.0
      Installing iobroker.tankerkoenig@3.3.7... (System call)
      removed 1 package, and changed 1 package in 8s
      Update "system.adapter.tankerkoenig.0"
      upload [4] tankerkoenig.admin /opt/iobroker/node_modules/iobroker.tankerkoenig/admin/build/index.js build/index.js application/javascript
      upload [3] tankerkoenig.admin /opt/iobroker/node_modules/iobroker.tankerkoenig/admin/build/index.js.map build/index.js.map application/json
      upload [2] tankerkoenig.admin /opt/iobroker/node_modules/iobroker.tankerkoenig/admin/index_m.html index_m.html text/html
      upload [1] tankerkoenig.admin /opt/iobroker/node_modules/iobroker.tankerkoenig/admin/style.css style.css text/css
      upload [0] tankerkoenig.admin /opt/iobroker/node_modules/iobroker.tankerkoenig/admin/tankerkoenig.png tankerkoenig.png image/png
      host.raspberrypi-4-2 Adapter "system.adapter.tankerkoenig.0" is started
      This upgrade of "socketio" will at least introduce the following changes:
      -> 6.6.1:
      Just some packages were updated
      -> 6.6.0:
      -> 6.5.7:
      upgrade socket-classes to fix error with vis subscriptions
      -> 6.5.6:
      -> 6.5.5:
      upgrade socket-classes to fix crash cases
      -> 6.5.4:
      -> 6.5.3:
      added missing node16 requirement
      Would you like to upgrade socketio from @4.2.0 to @6.6.1 now? [(y)es, (n)o]: Y
      Update socketio from @4.2.0 to @6.6.1
      ,NPM version: 10.5.0
      Installing iobroker.socketio@6.6.1... (System call)
      added 25 packages, removed 3 packages, and changed 1 package in 10s
      upload [11] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/de/translations.json i18n/de/translations.json application/json
      upload [10] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/en/translations.json i18n/en/translations.json application/json
      upload [9] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/es/translations.json i18n/es/translations.json application/json
      upload [8] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
      upload [7] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/it/translations.json i18n/it/translations.json application/json
      upload [6] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
      upload [5] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
      upload [4] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
      upload [3] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
      upload [2] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
      upload [1] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/jsonConfig.json jsonConfig.json application/json
      upload [0] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/socketio.png socketio.png image/png
      This upgrade of "shelly" will introduce the following changes:
      -> 6.8.0:
      Updated BLE script to 0.2 (new shelly motion firmware)
      Updated Shelly i3 number limits
      Added screenshots to instance configuration
      -> 6.7.0:
      Updated handling of ble payloads
      Added Shelly Wall Display
      Would you like to upgrade shelly from @6.6.1 to @6.8.0 now? [(y)es, (n)o]: Y
      Update shelly from @6.6.1 to @6.8.0
      NPM version: 10.5.0
      Installing iobroker.shelly@6.8.0... (System call)
      Update "system.adapter.shelly.0"
      Update "system.adapter.shelly.1"
      upload [17] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/de/translations.json i18n/de/translations.json application/json
      upload [16] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/en/translations.json i18n/en/translations.json application/json
      upload [15] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/es/translations.json i18n/es/translations.json application/json
      upload [14] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
      upload [13] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/it/translations.json i18n/it/translations.json application/json
      upload [12] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
      upload [11] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
      upload [10] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
      upload [9] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
      upload [8] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
      upload [7] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
      upload [6] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/img/mqttGen1.png img/mqttGen1.png image/png
      upload [5] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/img/mqttGen2.png img/mqttGen2.png image/png
      upload [4] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/img/restrictedLoginGen1.png img/restrictedLoginGen1.png image/png
      upload [3] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/img/restrictedLoginGen2.png img/restrictedLoginGen2.png image/png
      upload [2] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/jsonConfig.json jsonConfig.json application/json
      upload [1] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/shelly.png shelly.png image/png
      upload [0] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/words.js words.js application/javascript
      This upgrade of "node-red" will introduce the following changes:
      -> 5.2.0:
      Added persistence of context data (filesystem)
      Would you like to upgrade node-red from @5.1.0 to @5.2.0 now? [(y)es, (n)o]: Y
      Update node-red from @5.1.0 to @5.2.0
      host.raspberrypi-4-2 Adapter "system.adapter.node-red.0" is stopped.
      NPM version: 10.5.0
      Installing iobroker.node-red@5.2.0... (System call)
      Update "system.adapter.node-red.0"
      upload [13] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/de/translations.json i18n/de/translations.json application/json
      upload [12] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/en/translations.json i18n/en/translations.json application/json
      upload [11] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/es/translations.json i18n/es/translations.json application/json
      upload [10] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
      upload [9] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/it/translations.json i18n/it/translations.json application/json
      upload [8] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
      upload [7] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
      upload [6] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
      upload [5] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
      upload [4] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
      upload [3] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
      upload [2] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/jsonConfig.json jsonConfig.json application/json
      upload [1] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/node-red.png node-red.png image/png
      upload [0] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/words.js words.js application/javascript
      host.raspberrypi-4-2 Adapter "system.adapter.node-red.0" is started
      This upgrade of "ems-esp" will at least introduce the following changes:
      -> 3.0.3:
      improve km200 data read to avoid errors
      -> 3.0.2:
      improve km200 data read to avoid errors - try http get up to 3 times now - especially for recordings
      -> 3.0.1:
      change KM200 error messages for recordings
      -> 3.0.0:
      Node >= 18 required
      update heatdemand weight changes to be effective during active instance
      ems-esp gateway: Raw telegram search for EMS+ thermostats: switchPrograms and holidayModes (RC310/RC300)
      create writable objects / states for switchPrograms and holidayModes
      this function is only active when no km200 gateway is selected - ems-esp gateway only
      improve error messages for km200 (wrong ip / passwords)
      small changes within PDF adapter documentation
      -> 3.0.0-alpha.2:
      Node >= 18 required
      -> 3.0.0-alpha.1:
      -> 3.0.0-alpha.0:
      Search for ems-esp states for EMS+ thermostats: switchTimes and holidayModes (RC310/RC300)
      Implement raw telegram search for EMS+ entities and create writable objects / states
      The search is only active when no km200 gateway is selected
      Would you like to upgrade ems-esp from @2.8.0 to @3.0.3 now? [(y)es, (n)o]: Y
      Update ems-esp from @2.8.0 to @3.0.3
      NPM version: 10.5.0
      Installing iobroker.ems-esp@3.0.3... (System call)
      Update "system.adapter.ems-esp.0"
      upload [6] ems-esp.admin /opt/iobroker/node_modules/iobroker.ems-esp/admin/admin.d.ts admin.d.ts video/mp2t
      upload [5] ems-esp.admin /opt/iobroker/node_modules/iobroker.ems-esp/admin/ems-esp.png ems-esp.png image/png
      upload [4] ems-esp.admin /opt/iobroker/node_modules/iobroker.ems-esp/admin/index_m.html index_m.html text/html
      upload [3] ems-esp.admin /opt/iobroker/node_modules/iobroker.ems-esp/admin/index_m.js index_m.js application/javascript
      upload [2] ems-esp.admin /opt/iobroker/node_modules/iobroker.ems-esp/admin/km200.png km200.png image/png
      upload [1] ems-esp.admin /opt/iobroker/node_modules/iobroker.ems-esp/admin/style.css style.css text/css
      upload [0] ems-esp.admin /opt/iobroker/node_modules/iobroker.ems-esp/admin/words.js words.js application/javascript
      This upgrade of "discovery" will at least introduce the following changes:
      -> 4.4.0:
      Added WLED
      Added LaMetric
      Removed net-tools from proposals
      -> 4.3.0:
      Replaced vis with vis-2
      -> 4.2.0:
      Changed detection of myvbus and resol
      -> 4.1.0:
      Added detection of myvbus and resol
      -> 4.0.0:
      Added: frontier_silicon, sma-em, and speedwire
      Dropped node14 support, refactoring
      -> 3.2.0:
      Added iControl to the suggested adapters
      -> 3.1.0:
      Corrected syntax error in the german translation
      Would you like to upgrade discovery from @3.0.3 to @4.4.0 now? [(y)es, (n)o]: Y
      Update discovery from @3.0.3 to @4.4.0
      NPM version: 10.5.0
      Installing iobroker.discovery@4.4.0... (System call)
      added 1 package, removed 16 packages, and changed 1 package in 8s
      122 packages are looking for funding
      Update "system.adapter.discovery.0"
      upload [6] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/discovery.png discovery.png image/png
      upload [5] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index.html index.html text/html
      upload [4] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index_m.html index_m.html text/html
      upload [3] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings.html settings.html text/html
      upload [2] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings_m.html settings_m.html text/html
      upload [1] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/translateTools.js translateTools.js application/javascript
      upload [0] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/words.js words.js application/javascript
      • R Redbeard_81
        "iob update"
        "iob upgrade"
        -> 2.5.11:
        -> 2.5.10:
        -> 2.5.9:
        -> 2.5.8:
        -> 2.5.7:
        -> 2.5.6:
        -> 2.5.5:
        NPM version: 10.5.0
        -> 6.2.3:
        -> 6.2.2:
        -> 6.2.1:
        -> 6.1.10:
        -> 6.1.7:
        -> 6.1.6:
        -> 6.1.4:
        -> 3.3.7:
        -> 3.3.6:
        -> 3.3.5:
        -> 3.3.4:
        -> 3.3.3:
        -> 3.3.2:
        -> 3.3.1:
        NPM version: 10.5.0
        -> 6.6.1:
        -> 6.6.0:
        -> 6.5.7:
        -> 6.5.6:
        -> 6.5.5:
        -> 6.5.4:
        -> 6.5.3:
        -> 6.8.0:
        -> 6.7.0:
        NPM version: 10.5.0
        -> 5.2.0:
        NPM version: 10.5.0
        -> 3.0.3:
        -> 3.0.2:
        -> 3.0.1:
        -> 3.0.0:
        Node >= 18 required
        -> 3.0.0-alpha.2:
        Node >= 18 required
        -> 3.0.0-alpha.1:
        -> 3.0.0-alpha.0:
        NPM version: 10.5.0
        -> 4.4.0:
        Added WLED
        Added LaMetric
        -> 4.3.0:
        -> 4.2.0:
        -> 4.1.0:
        -> 4.0.0:
        -> 3.2.0:
        -> 3.1.0:
        NPM version: 10.5.0
        @redbeard_81
        Wo ist denn der mihome-vacuum nun hin?
          @redbeard_81
          Redbeard_81
          Der mihome-vacuum Adapter ist jetzt auch drin.
          Habe jetzt mein Backup eingespielt den Adapter als Beta installiert und nun scheint alles zu funktionieren.
          Danke für die Hilfe und geduld
          Adapter    "discovery"    : 4.4.0    , installed 4.4.0
          Adapter    "ems-esp"      : 3.0.3    , installed 3.0.3
          Adapter    "mihome-vacuum": 4.1.1    , installed 4.2.0
          Adapter    "node-red"     : 5.2.0    , installed 5.2.0
          Adapter    "shelly"       : 6.8.0    , installed 6.8.0
          Adapter    "socketio"     : 6.6.1    , installed 6.6.1
          Adapter    "ws"           : 2.5.11   , installed 2.5.11
          Thomas BraunT Siggi0904S 2 Antworten Letzte Antwort
          • R Redbeard_81
            @redbeard_81 sagte in npm Error bei mihome-vacuum Adapter Installation:
            Heb das auch hoch.
            • R Redbeard_81
              Siggi0904S Offline
              Siggi0904S Offline
              Siggi0904
              @redbeard_81 ja, das gleiche Problem hatte ich Anfang dieser Woche auch.
              Schön zu sehen, dass dir erstens schnell geholfen wurde, zweitens ich nicht allein betroffen bin.
              • WintermuteW Offline
                WintermuteW Offline
                Wintermute
                schrieb am zuletzt editiert von Wintermute
                Ich habe gerade das Update auf die 4.2.0 und habe das Problem, dass die Installation offenbar sauber durchläuft, der Adapter aber nicht mehr startet ("Verbunden mit Gerät oder Dienst" ist grün, der Rest rot)
                iob update und iob upgrade hab ich probiert, keine Resultate:
                C:\ioBroker>iob update
                Adapter    "backitup"     : 2.11.0   , installed 2.11.0
                Adapter    "bring"        : 1.8.4    , installed 1.8.4
                Adapter    "daswetter"    : 3.1.13   , installed 3.1.13
                Adapter    "deconz"       : 1.4.0    , installed 1.4.0
                Adapter    "echarts"      : 1.7.2    , installed 1.7.2
                Adapter    "email"        : 1.2.2    , installed 1.2.2
                Adapter    "fb-checkpresence": 1.2.4 , installed 1.2.4
                Adapter    "homeconnect"  : 1.3.0    , installed 1.3.0
                Adapter    "ical"         : 1.14.3   , installed 1.14.3
                Adapter    "mihome-vacuum": 4.2.0    , installed 4.2.0
                Adapter    "nina"         : 0.0.25   , installed 0.0.25
                Adapter    "rssfeed"      : 2.6.1    , installed 2.6.1
                Adapter    "sayit"        : 3.0.5    , installed 3.0.5
                Adapter    "trashschedule": 3.2.0    , installed 3.2.0
                Adapter    "vis"          : 1.5.4    , installed 1.5.1  [Updatable]
                Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
                Adapter    "weatherunderground": 3.6.0, installed 3.6.0
                Adapter    "web"          : 6.2.5    , installed 6.2.5
                Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
                C:\ioBroker>iob upgrade
                This upgrade of "vis" will introduce the following changes:
                -> 1.5.4:
                added the new binding operation for getting property of JSON or object
                Checked the initialization of the `local_` variables
                fixed subscribeOidAtRuntime
                Added dynamic web manifest
                Optimization for basic-view in widget8
                Changed binding regex to accept umlauts
                Corrected first installation of vis
                Would you like to upgrade vis from @1.5.1 to @1.5.4 now? [(y)es, (n)o]: n
                No upgrade of "vis" desired.
                Vis habe ich aus Gründen nicht aktualisiert, weil ansonsten einige ältere Tablets nicht mehr klarkommen.
                Ein "Iob fix" bringt:
                Need to install the following packages:
                  @iobroker/fix@5.0.0
                Ok to proceed? (y) y
                "(" kann syntaktisch an dieser Stelle nicht verarbeitet werden.
                npm notice
                npm notice New major version of npm available! 9.5.0 -> 10.5.2
                npm notice Changelog: https://github.com/npm/cli/releases/tag/v10.5.2
                npm notice Run npm install -g npm@10.5.2 to update!
                npm notice
                Hat das Eine mit dem Anderen zu tun?
                Iobroker als Windows-VM auf einem Supermicro-Server
                WintermuteW ? 2 Antworten Letzte Antwort
                • WintermuteW Wintermute
                  -> 1.5.4:
                    @iobroker/fix@5.0.0
                  npm notice
                  npm notice
                  WintermuteW Offline
                  WintermuteW Offline
                  Wintermute
                  @wintermute sagte in npm Error bei mihome-vacuum Adapter Installation:
                  -> 1.5.4:
                    @iobroker/fix@5.0.0
                  npm notice
                  npm notice
                  Zusätzlich noch "iob info":
                  C:\ioBroker>iob info
                  Cannot get disk information: Command failed: df -k /
                  Der Befehl "df" ist entweder falsch geschrieben oder
                  konnte nicht gefunden werden.
                  Platform       : Windows
                  os             : win64
                  Architecture   : x64
                  CPUs           : 2
                  Model          : Intel(R) Xeon(R) CPU 8460Y+ @ 2.0 GHz
                  RAM            : 126 GB
                  System uptime  : 2d. 20:25:52
                  Node.js        : v18.15.0
                  time           : 1713536349613
                  timeOffset     : -120
                  NPM            : 9.5.0
                  adapters count : 538
                  • P Offline
                    pusemuckel
                    schrieb am zuletzt editiert von pusemuckel
                    ich habe das gleiche Problem seit dem Update auf die neue Version
                    host.iobroker
                    	2024-04-19 16:31:31.427	error	instance system.adapter.mihome-vacuum.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                    host.iobroker
                    	2024-04-19 16:31:31.426	error	Caught by controller[1]: Node.js v20.12.2
                    host.iobroker
                    	2024-04-19 16:31:31.426	error	Caught by controller[0]: }
                    host.iobroker
                    	2024-04-19 16:31:31.425	error	Caught by controller[0]: code: 'ERR_INVALID_ARG_VALUE'
                    host.iobroker
                    	2024-04-19 16:31:31.425	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1369:14) {
                    host.iobroker
                    	2024-04-19 16:31:31.425	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.mihome-vacuum/node_modules/@iobroker/adapter-core/build/cjs/controllerTools.js:34:22)
                    host.iobroker
                    	2024-04-19 16:31:31.424	error	Caught by controller[0]: at require (node:internal/modules/helpers:179:18)
                    host.iobroker
                    	2024-04-19 16:31:31.424	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1231:19)
                    host.iobroker
                    	2024-04-19 16:31:31.424	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1022:12)
                    host.iobroker
                    	2024-04-19 16:31:31.424	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1206:32)
                    host.iobroker
                    	2024-04-19 16:31:31.423	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1427:10)
                    host.iobroker
                    	2024-04-19 16:31:31.423	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1369:14)
                    host.iobroker
                    	2024-04-19 16:31:31.418	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.mihome-vacuum/node_modules/@iobroker/adapter-core/build/cjs/helpers.js:36:53)
                    host.iobroker
                    	2024-04-19 16:31:31.418	error	Caught by controller[0]: at createRequire (node:internal/modules/cjs/loader:1506:13)
                    host.iobroker
                    	2024-04-19 16:31:31.418	error	Caught by controller[0]: TypeError [ERR_INVALID_ARG_VALUE]: The argument 'filename' must be a file URL object, file URL string, or absolute path string. Received 'file:// /opt/iobroker/node_modules/iobroker.mihome-vacuum/node_modules/@iobroker/adapter-core/build/cjs/helpers.js'
                    host.iobroker
                    	2024-04-19 16:31:31.417	error	Caught by controller[0]: ^
                    host.iobroker
                    	2024-04-19 16:31:31.417	error	Caught by controller[0]: throw new ERR_INVALID_ARG_VALUE('filename', filename,
                    host.iobroker
                    	2024-04-19 16:31:31.416	error	Caught by controller[0]: node:internal/modules/cjs/loader:1506
                    Hat jemand eine Idee wo man schauen muss um das zu korrigieren ?
                    Danke!
                      -> 1.5.4:
                        @iobroker/fix@5.0.0
                      npm notice
                      npm notice
                      @wintermute
                      bei Windows bin ich raus..
                      WintermuteW 1 Antwort Letzte Antwort
                      • P pusemuckel
                        host.iobroker
                        host.iobroker
                        host.iobroker
                        host.iobroker
                        host.iobroker
                        host.iobroker
                        host.iobroker
                        host.iobroker
                        host.iobroker
                        host.iobroker
                        host.iobroker
                        host.iobroker
                        host.iobroker
                        host.iobroker
                        host.iobroker
                        host.iobroker
                        host.iobroker
                        host.iobroker
                        Danke!
                        @pusemuckel
                        ist nicht der gleiche Fehler, wie der TE hat, aber irgendein script scheint filename falsch deklariert zu haben.. sofern ich den Fehler richtig verstehe.. ist ja nur n Auschschnitt vom Ende des Fehlers.. man muesste da halt mal wissen:
                        welches System?
                        welche Version?
                        Logfile von Begin an, wenn der Adapter startet...
                        Dann natuerlich noch die Grundsaetzlichen infos aus iob diag.
                        P 1 Antwort Letzte Antwort
                          @pusemuckel
                          welches System?
                          welche Version?
                          pusemuckel
                          @ilovegym
                          Danke für Deine Rückmeldung!
                          			v.2023-10-10
                          model name	: Intel(R) Celeron(R) CPU J3455 @ 1.50GHz
                          Kernel          : x86_64
                          Userland        : amd64
                          Docker          : v9.1.2
                          Installation: 		Docker
                          Kernel: 		x86_64
                          Userland: 		amd64
                          Timezone: 		Etc/UTC
                          User-ID: 		0
                          X-Server: 		false
                          Pending OS-Updates: 	0
                          Pending iob updates: 	0
                          Nodejs-Installation: 	/usr/bin/nodejs 	v20.12.2
                          			/usr/bin/node 		v20.12.2
                          			/usr/bin/npm 		10.5.0
                          			/usr/bin/npx 		10.5.0
                          			/usr/bin/corepack 	0.25.2
                          Recommended versions are nodejs 18.20.2 and npm 10.5.0
                          MEMORY:
                          Mem:             12G        6.7G        822M        188M        5.4G        5.7G
                          Swap:           9.6G         60M        9.5G
                          Total:           21G        6.8G         10G
                          Active iob-Instances: 	26
                          Active repo(s): stable
                          ioBroker Core: 		js-controller 		5.0.19
                          			admin 			6.13.16
                          ioBroker Status: 	iobroker is running on this host.
                          Objects type: jsonl
                          States  type: redis
                          + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                          Objects: 		15173
                          States: 		11749
                          Size of iob-Database:
                          16M	/opt/iobroker/iobroker-data/objects.jsonl
                          13M	/opt/iobroker/iobroker-data/objects.json.migrated
                          13M	/opt/iobroker/iobroker-data/objects.json.bak.migrated
                          3.5M	/opt/iobroker/iobroker-data/states.json.bak
                          Adapter Log:
                          host.iobroker
                          	2024-04-19 17:08:23.959	info	Restart adapter system.adapter.mihome-vacuum.0 because enabled
                          host.iobroker
                          	2024-04-19 17:08:23.959	error	instance system.adapter.mihome-vacuum.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                          host.iobroker
                          	2024-04-19 17:08:23.959	error	Caught by controller[0]: Node.js v20.12.2
                          host.iobroker
                          	2024-04-19 17:08:23.959	error	Caught by controller[0]: }
                          host.iobroker
                          	2024-04-19 17:08:23.958	error	Caught by controller[0]: code: 'ERR_INVALID_ARG_VALUE'
                          host.iobroker
                          	2024-04-19 17:08:23.958	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1369:14) {
                          host.iobroker
                          	2024-04-19 17:08:23.958	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.mihome-vacuum/node_modules/@iobroker/adapter-core/build/cjs/controllerTools.js:34:22)
                          host.iobroker
                          	2024-04-19 17:08:23.958	error	Caught by controller[0]: at require (node:internal/modules/helpers:179:18)
                          host.iobroker
                          	2024-04-19 17:08:23.958	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1231:19)
                          host.iobroker
                          	2024-04-19 17:08:23.957	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1022:12)
                          host.iobroker
                          	2024-04-19 17:08:23.957	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1206:32)
                          host.iobroker
                          	2024-04-19 17:08:23.957	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1427:10)
                          host.iobroker
                          	2024-04-19 17:08:23.957	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1369:14)
                          host.iobroker
                          	2024-04-19 17:08:23.956	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.mihome-vacuum/node_modules/@iobroker/adapter-core/build/cjs/helpers.js:36:53)
                          host.iobroker
                          	2024-04-19 17:08:23.956	error	Caught by controller[0]: at createRequire (node:internal/modules/cjs/loader:1506:13)
                          host.iobroker
                          	2024-04-19 17:08:23.956	error	Caught by controller[0]: TypeError [ERR_INVALID_ARG_VALUE]: The argument 'filename' must be a file URL object, file URL string, or absolute path string. Received 'file:// /opt/iobroker/node_modules/iobroker.mihome-vacuum/node_modules/@iobroker/adapter-core/build/cjs/helpers.js'
                          host.iobroker
                          	2024-04-19 17:08:23.956	error	Caught by controller[0]: ^
                          host.iobroker
                          	2024-04-19 17:08:23.955	error	Caught by controller[0]: throw new ERR_INVALID_ARG_VALUE('filename', filename,
                          host.iobroker
                          	2024-04-19 17:08:23.954	error	Caught by controller[0]: node:internal/modules/cjs/loader:1506
                          host.iobroker
                          	2024-04-19 17:08:23.723	info	instance system.adapter.mihome-vacuum.0 started with pid 5691
                          Mehr log habe ich bzw. wo kann ich mehr log des Adapters finden ?
                          ? mcm1957M 2 Antworten Letzte Antwort
                          • P pusemuckel
                            @ilovegym
                            			v.2023-10-10
                            Kernel          : x86_64
                            Userland        : amd64
                            Docker          : v9.1.2
                            Kernel: 		x86_64
                            Userland: 		amd64
                            Timezone: 		Etc/UTC
                            User-ID: 		0
                            X-Server: 		false
                            			/usr/bin/npm 		10.5.0
                            			/usr/bin/npx 		10.5.0
                            MEMORY:
                            Swap:           9.6G         60M        9.5G
                            Total:           21G        6.8G         10G
                            			admin 			6.13.16
                            Objects type: jsonl
                            States  type: redis
                            Objects: 		15173
                            States: 		11749
                            Adapter Log:
                            host.iobroker
                            host.iobroker
                            host.iobroker
                            host.iobroker
                            host.iobroker
                            host.iobroker
                            host.iobroker
                            host.iobroker
                            host.iobroker
                            host.iobroker
                            host.iobroker
                            host.iobroker
                            host.iobroker
                            host.iobroker
                            host.iobroker
                            host.iobroker
                            host.iobroker
                            host.iobroker
                            host.iobroker
                            host.iobroker
                            @pusemuckel
                            mach mal in der Konsole des iobroker dockers ein "iob upload mihome-vacuum" und starte dann den Adapter nochmal.
                            In die Konsole des Dockers kommst du im Terminal des Hosts (Synology? Proxmox? ) mit dem command
                            sudo docker exec -tiu username containername /bin/bash
                            bei mir ist das als user iobroker und der container heisst auch iobroker dann ein
                            sudo docker exec -tiu iobroker iobroker /bin/bash
                            danach bist du in /opt/iobroker und kannst als user iobroker die iob commands ausfuehren, ausser diejenigen, die ein iob maintenance brauchen..
                            Ich gehe davon aus, dass du das buanet-docker-Image benutzt?
                            edit:
                            das Logfile bekommt man am schoensten, finde ich, in der Konsole mit dem command
                            iob logs --watch
                              @pusemuckel
                              edit:
                              iob logs --watch
                              pusemuckel
                              @ilovegym said in npm Error bei mihome-vacuum Adapter Installation:
                              Das hatte ich schon gemacht, leider auch ohne Erfolg. Ich konnte es mit
                              npm install iobroker/adapter-core
                              korrigieren, danach lässt sich der Adapter wieder starten!
                              Schönes Wochenende!
                                @wintermute
                                WintermuteW Offline
                                WintermuteW Offline
                                Wintermute
                                @ilovegym ...und ich bei Linux 😀
                                Alle Reparaturversuche sind fehlgeschlagen - Einspielen des Updates von letzter Nacht hat meinem Iobroker und meinem Staubsauger aber wieder auf die Beine geholfen. Das Update auf die 4.2.0 werde ich dann mal besser auslassen...
                                  Läuft.
                                    Läuft.
                                    WintermuteW Offline
                                    WintermuteW Offline
                                    Wintermute
                                    @thomas-braun sagte in npm Error bei mihome-vacuum Adapter Installation:
                                    Läuft.
                                    Auf einem Windows-System? Hast Du irgendwelche Verrenkungen gemacht, damit der Adapter läuft?
                                      Läuft.
                                      @wintermute
                                      Läuft natürlich auf einem Betriebssystem.
                                      Gerade nochmal durchgestartet:
                                      2024-04-19 18:46:09.700  - info: mihome-vacuum.0 (1232) Got terminate signal TERMINATE_YOURSELF
                                      2024-04-19 18:46:09.727  - error: mihome-vacuum.0 (1232) Socket Close
                                      2024-04-19 18:46:09.731  - info: mihome-vacuum.0 (1232) terminating
                                      2024-04-19 18:46:09.734  - info: mihome-vacuum.0 (1232) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                      2024-04-19 18:46:10.221  - info: mihome-vacuum.0 (1232) terminating
                                      2024-04-19 18:46:15.796  - info: mihome-vacuum.0 (680497) starting. Version 4.2.0 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v21.7.3, js-controller: 5.0.19
                                      2024-04-19 18:46:15.867  - info: mihome-vacuum.0 (680497) IOT enabled, create state
                                      2024-04-19 18:46:16.017  - info: mihome-vacuum.0 (680497) select standard vacuum protocol....
                                      2024-04-19 18:46:16.494  - info: mihome-vacuum.0 (680497) create state for carpet_mode
                                      2024-04-19 18:46:16.649  - info: mihome-vacuum.0 (680497) settest next timer: not available
                                      Kein Ding, kommt sofort wieder hoch.
                                      -1
                                        @wintermute
                                        WintermuteW Offline
                                        WintermuteW Offline
                                        Wintermute
                                        @wintermute
                                        Da bin ich mir sicher, dass es auf einem Betriebssystem läuft ;-)
                                        Aber läuft es auch auf Meinem Betriebssystem?
                                          @wintermute
                                          @wintermute
                                          Natürlich nicht.
