  4. npm Error bei mihome-vacuum Adapter Installation
33 Beiträge 7 Kommentatoren 3.9k Aufrufe 5 Beobachtet
  • P Offline
    pusemuckel
    schrieb am zuletzt editiert von pusemuckel
    ich habe das gleiche Problem seit dem Update auf die neue Version
    host.iobroker
    	2024-04-19 16:31:31.427	error	instance system.adapter.mihome-vacuum.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.iobroker
    	2024-04-19 16:31:31.426	error	Caught by controller[1]: Node.js v20.12.2
    host.iobroker
    	2024-04-19 16:31:31.426	error	Caught by controller[0]: }
    host.iobroker
    	2024-04-19 16:31:31.425	error	Caught by controller[0]: code: 'ERR_INVALID_ARG_VALUE'
    host.iobroker
    	2024-04-19 16:31:31.425	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1369:14) {
    host.iobroker
    	2024-04-19 16:31:31.425	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.mihome-vacuum/node_modules/@iobroker/adapter-core/build/cjs/controllerTools.js:34:22)
    host.iobroker
    	2024-04-19 16:31:31.424	error	Caught by controller[0]: at require (node:internal/modules/helpers:179:18)
    host.iobroker
    	2024-04-19 16:31:31.424	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1231:19)
    host.iobroker
    	2024-04-19 16:31:31.424	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1022:12)
    host.iobroker
    	2024-04-19 16:31:31.424	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1206:32)
    host.iobroker
    	2024-04-19 16:31:31.423	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1427:10)
    host.iobroker
    	2024-04-19 16:31:31.423	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1369:14)
    host.iobroker
    	2024-04-19 16:31:31.418	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.mihome-vacuum/node_modules/@iobroker/adapter-core/build/cjs/helpers.js:36:53)
    host.iobroker
    	2024-04-19 16:31:31.418	error	Caught by controller[0]: at createRequire (node:internal/modules/cjs/loader:1506:13)
    host.iobroker
    	2024-04-19 16:31:31.418	error	Caught by controller[0]: TypeError [ERR_INVALID_ARG_VALUE]: The argument 'filename' must be a file URL object, file URL string, or absolute path string. Received 'file:// /opt/iobroker/node_modules/iobroker.mihome-vacuum/node_modules/@iobroker/adapter-core/build/cjs/helpers.js'
    host.iobroker
    	2024-04-19 16:31:31.417	error	Caught by controller[0]: ^
    host.iobroker
    	2024-04-19 16:31:31.417	error	Caught by controller[0]: throw new ERR_INVALID_ARG_VALUE('filename', filename,
    host.iobroker
    	2024-04-19 16:31:31.416	error	Caught by controller[0]: node:internal/modules/cjs/loader:1506
    Hat jemand eine Idee wo man schauen muss um das zu korrigieren ?
    Danke!
    • WintermuteW Wintermute
      Ich habe gerade das Update auf die 4.2.0 und habe das Problem, dass die Installation offenbar sauber durchläuft, der Adapter aber nicht mehr startet ("Verbunden mit Gerät oder Dienst" ist grün, der Rest rot)
      iob update und iob upgrade hab ich probiert, keine Resultate:
      C:\ioBroker>iob update
      Used repository: stable
      Adapter    "admin"        : 6.13.16  , installed 6.13.16
      Adapter    "backitup"     : 2.11.0   , installed 2.11.0
      Adapter    "bring"        : 1.8.4    , installed 1.8.4
      Adapter    "daswetter"    : 3.1.13   , installed 3.1.13
      Adapter    "deconz"       : 1.4.0    , installed 1.4.0
      Adapter    "discovery"    : 4.4.0    , installed 4.4.0
      Adapter    "echarts"      : 1.7.2    , installed 1.7.2
      Adapter    "email"        : 1.2.2    , installed 1.2.2
      Adapter    "fb-checkpresence": 1.2.4 , installed 1.2.4
      Adapter    "homeconnect"  : 1.3.0    , installed 1.3.0
      Adapter    "ical"         : 1.14.3   , installed 1.14.3
      Adapter    "javascript"   : 7.8.0    , installed 7.8.0
      Controller "js-controller": 5.0.19   , installed 5.0.19
      Adapter    "mihome-vacuum": 4.2.0    , installed 4.2.0
      Adapter    "nina"         : 0.0.25   , installed 0.0.25
      Adapter    "rssfeed"      : 2.6.1    , installed 2.6.1
      Adapter    "sayit"        : 3.0.5    , installed 3.0.5
      Adapter    "socketio"     : 6.6.1    , installed 6.6.1
      Adapter    "trashschedule": 3.2.0    , installed 3.2.0
      Adapter    "vis"          : 1.5.4    , installed 1.5.1  [Updatable]
      Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
      Adapter    "weatherunderground": 3.6.0, installed 3.6.0
      Adapter    "web"          : 6.2.5    , installed 6.2.5
      Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
      Adapter    "ws"           : 2.5.11   , installed 2.5.11
      C:\ioBroker>iob upgrade
      This upgrade of "vis" will introduce the following changes:
      -> 1.5.4:
      added the new binding operation for getting property of JSON or object
      Checked the initialization of the `local_` variables
      fixed subscribeOidAtRuntime
      Added dynamic web manifest
      Optimization for basic-view in widget8
      Changed binding regex to accept umlauts
      Corrected first installation of vis
      Would you like to upgrade vis from @1.5.1 to @1.5.4 now? [(y)es, (n)o]: n
      No upgrade of "vis" desired.
      Vis habe ich aus Gründen nicht aktualisiert, weil ansonsten einige ältere Tablets nicht mehr klarkommen.
      Ein "Iob fix" bringt:
      Need to install the following packages:
        @iobroker/fix@5.0.0
      Ok to proceed? (y) y
      "(" kann syntaktisch an dieser Stelle nicht verarbeitet werden.
      npm notice
      npm notice New major version of npm available! 9.5.0 -> 10.5.2
      npm notice Changelog: https://github.com/npm/cli/releases/tag/v10.5.2
      npm notice Run npm install -g npm@10.5.2 to update!
      npm notice
      Hat das Eine mit dem Anderen zu tun?
      @wintermute
      bei Windows bin ich raus..
      WintermuteW 1 Antwort Letzte Antwort
      • P pusemuckel
        host.iobroker
        host.iobroker
        host.iobroker
        host.iobroker
        host.iobroker
        host.iobroker
        host.iobroker
        host.iobroker
        host.iobroker
        host.iobroker
        host.iobroker
        host.iobroker
        host.iobroker
        host.iobroker
        host.iobroker
        host.iobroker
        host.iobroker
        host.iobroker
        Danke!
        @pusemuckel
        ist nicht der gleiche Fehler, wie der TE hat, aber irgendein script scheint filename falsch deklariert zu haben.. sofern ich den Fehler richtig verstehe.. ist ja nur n Auschschnitt vom Ende des Fehlers.. man muesste da halt mal wissen:
        welches System?
        welche Version?
        Logfile von Begin an, wenn der Adapter startet...
        Dann natuerlich noch die Grundsaetzlichen infos aus iob diag.
        P 1 Antwort Letzte Antwort
          @pusemuckel
          welches System?
          welche Version?
          pusemuckel
          @ilovegym
          Danke für Deine Rückmeldung!
          			v.2023-10-10
          model name	: Intel(R) Celeron(R) CPU J3455 @ 1.50GHz
          Kernel          : x86_64
          Userland        : amd64
          Docker          : v9.1.2
          Installation: 		Docker
          Kernel: 		x86_64
          Userland: 		amd64
          Timezone: 		Etc/UTC
          User-ID: 		0
          X-Server: 		false
          Pending OS-Updates: 	0
          Pending iob updates: 	0
          Nodejs-Installation: 	/usr/bin/nodejs 	v20.12.2
          			/usr/bin/node 		v20.12.2
          			/usr/bin/npm 		10.5.0
          			/usr/bin/npx 		10.5.0
          			/usr/bin/corepack 	0.25.2
          Recommended versions are nodejs 18.20.2 and npm 10.5.0
          MEMORY:
          Mem:             12G        6.7G        822M        188M        5.4G        5.7G
          Swap:           9.6G         60M        9.5G
          Total:           21G        6.8G         10G
          Active iob-Instances: 	26
          Active repo(s): stable
          ioBroker Core: 		js-controller 		5.0.19
          			admin 			6.13.16
          ioBroker Status: 	iobroker is running on this host.
          Objects type: jsonl
          States  type: redis
          + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
          Objects: 		15173
          States: 		11749
          Size of iob-Database:
          16M	/opt/iobroker/iobroker-data/objects.jsonl
          13M	/opt/iobroker/iobroker-data/objects.json.migrated
          13M	/opt/iobroker/iobroker-data/objects.json.bak.migrated
          3.5M	/opt/iobroker/iobroker-data/states.json.bak
          Adapter Log:
          host.iobroker
          	2024-04-19 17:08:23.959	info	Restart adapter system.adapter.mihome-vacuum.0 because enabled
          host.iobroker
          	2024-04-19 17:08:23.959	error	instance system.adapter.mihome-vacuum.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
          host.iobroker
          	2024-04-19 17:08:23.959	error	Caught by controller[0]: Node.js v20.12.2
          host.iobroker
          	2024-04-19 17:08:23.959	error	Caught by controller[0]: }
          host.iobroker
          	2024-04-19 17:08:23.958	error	Caught by controller[0]: code: 'ERR_INVALID_ARG_VALUE'
          host.iobroker
          	2024-04-19 17:08:23.958	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1369:14) {
          host.iobroker
          	2024-04-19 17:08:23.958	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.mihome-vacuum/node_modules/@iobroker/adapter-core/build/cjs/controllerTools.js:34:22)
          host.iobroker
          	2024-04-19 17:08:23.958	error	Caught by controller[0]: at require (node:internal/modules/helpers:179:18)
          host.iobroker
          	2024-04-19 17:08:23.958	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1231:19)
          host.iobroker
          	2024-04-19 17:08:23.957	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1022:12)
          host.iobroker
          	2024-04-19 17:08:23.957	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1206:32)
          host.iobroker
          	2024-04-19 17:08:23.957	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1427:10)
          host.iobroker
          	2024-04-19 17:08:23.957	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1369:14)
          host.iobroker
          	2024-04-19 17:08:23.956	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.mihome-vacuum/node_modules/@iobroker/adapter-core/build/cjs/helpers.js:36:53)
          host.iobroker
          	2024-04-19 17:08:23.956	error	Caught by controller[0]: at createRequire (node:internal/modules/cjs/loader:1506:13)
          host.iobroker
          	2024-04-19 17:08:23.956	error	Caught by controller[0]: TypeError [ERR_INVALID_ARG_VALUE]: The argument 'filename' must be a file URL object, file URL string, or absolute path string. Received 'file:// /opt/iobroker/node_modules/iobroker.mihome-vacuum/node_modules/@iobroker/adapter-core/build/cjs/helpers.js'
          host.iobroker
          	2024-04-19 17:08:23.956	error	Caught by controller[0]: ^
          host.iobroker
          	2024-04-19 17:08:23.955	error	Caught by controller[0]: throw new ERR_INVALID_ARG_VALUE('filename', filename,
          host.iobroker
          	2024-04-19 17:08:23.954	error	Caught by controller[0]: node:internal/modules/cjs/loader:1506
          host.iobroker
          	2024-04-19 17:08:23.723	info	instance system.adapter.mihome-vacuum.0 started with pid 5691
          Mehr log habe ich bzw. wo kann ich mehr log des Adapters finden ?
          ? mcm1957M 2 Antworten Letzte Antwort
          • P pusemuckel
            @ilovegym
            			v.2023-10-10
            Kernel          : x86_64
            Userland        : amd64
            Docker          : v9.1.2
            Kernel: 		x86_64
            Userland: 		amd64
            Timezone: 		Etc/UTC
            User-ID: 		0
            X-Server: 		false
            			/usr/bin/npm 		10.5.0
            			/usr/bin/npx 		10.5.0
            MEMORY:
            Swap:           9.6G         60M        9.5G
            Total:           21G        6.8G         10G
            			admin 			6.13.16
            Objects type: jsonl
            States  type: redis
            Objects: 		15173
            States: 		11749
            Adapter Log:
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            @pusemuckel
            mach mal in der Konsole des iobroker dockers ein "iob upload mihome-vacuum" und starte dann den Adapter nochmal.
            In die Konsole des Dockers kommst du im Terminal des Hosts (Synology? Proxmox? ) mit dem command
            sudo docker exec -tiu username containername /bin/bash
            bei mir ist das als user iobroker und der container heisst auch iobroker dann ein
            sudo docker exec -tiu iobroker iobroker /bin/bash
            danach bist du in /opt/iobroker und kannst als user iobroker die iob commands ausfuehren, ausser diejenigen, die ein iob maintenance brauchen..
            Ich gehe davon aus, dass du das buanet-docker-Image benutzt?
            edit:
            das Logfile bekommt man am schoensten, finde ich, in der Konsole mit dem command
            iob logs --watch
              @pusemuckel
              edit:
              iob logs --watch
              pusemuckel
              @ilovegym said in npm Error bei mihome-vacuum Adapter Installation:
              Das hatte ich schon gemacht, leider auch ohne Erfolg. Ich konnte es mit
              npm install iobroker/adapter-core
              korrigieren, danach lässt sich der Adapter wieder starten!
              Schönes Wochenende!
                @wintermute
                WintermuteW Offline
                WintermuteW Offline
                Wintermute
                @ilovegym ...und ich bei Linux 😀
                Alle Reparaturversuche sind fehlgeschlagen - Einspielen des Updates von letzter Nacht hat meinem Iobroker und meinem Staubsauger aber wieder auf die Beine geholfen. Das Update auf die 4.2.0 werde ich dann mal besser auslassen...
                Iobroker als Windows-VM auf einem Supermicro-Server
                  Läuft.
                    Läuft.
                    WintermuteW Offline
                    WintermuteW Offline
                    Wintermute
                    @thomas-braun sagte in npm Error bei mihome-vacuum Adapter Installation:
                    Läuft.
                    Auf einem Windows-System? Hast Du irgendwelche Verrenkungen gemacht, damit der Adapter läuft?
                      Läuft.
                      @wintermute
                      Läuft natürlich auf einem Betriebssystem.
                      Gerade nochmal durchgestartet:
                      2024-04-19 18:46:09.700  - info: mihome-vacuum.0 (1232) Got terminate signal TERMINATE_YOURSELF
                      2024-04-19 18:46:09.727  - error: mihome-vacuum.0 (1232) Socket Close
                      2024-04-19 18:46:09.731  - info: mihome-vacuum.0 (1232) terminating
                      2024-04-19 18:46:09.734  - info: mihome-vacuum.0 (1232) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                      2024-04-19 18:46:10.221  - info: mihome-vacuum.0 (1232) terminating
                      2024-04-19 18:46:15.796  - info: mihome-vacuum.0 (680497) starting. Version 4.2.0 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v21.7.3, js-controller: 5.0.19
                      2024-04-19 18:46:15.867  - info: mihome-vacuum.0 (680497) IOT enabled, create state
                      2024-04-19 18:46:16.017  - info: mihome-vacuum.0 (680497) select standard vacuum protocol....
                      2024-04-19 18:46:16.494  - info: mihome-vacuum.0 (680497) create state for carpet_mode
                      2024-04-19 18:46:16.649  - info: mihome-vacuum.0 (680497) settest next timer: not available
                      Kein Ding, kommt sofort wieder hoch.
                      -1
                        @wintermute
                        WintermuteW Offline
                        WintermuteW Offline
                        Wintermute
                        @wintermute
                        Da bin ich mir sicher, dass es auf einem Betriebssystem läuft ;-)
                        Aber läuft es auch auf Meinem Betriebssystem?
                          @wintermute
                          @wintermute
                          Natürlich nicht.
                          • P pusemuckel
                            @ilovegym
                            			v.2023-10-10
                            Kernel          : x86_64
                            Userland        : amd64
                            Docker          : v9.1.2
                            Kernel: 		x86_64
                            Userland: 		amd64
                            Timezone: 		Etc/UTC
                            User-ID: 		0
                            X-Server: 		false
                            			/usr/bin/npm 		10.5.0
                            			/usr/bin/npx 		10.5.0
                            MEMORY:
                            Swap:           9.6G         60M        9.5G
                            Total:           21G        6.8G         10G
                            			admin 			6.13.16
                            Objects type: jsonl
                            States  type: redis
                            Objects: 		15173
                            States: 		11749
                            Adapter Log:
                            host.iobroker
                            host.iobroker
                            host.iobroker
                            host.iobroker
                            host.iobroker
                            host.iobroker
                            host.iobroker
                            host.iobroker
                            host.iobroker
                            host.iobroker
                            host.iobroker
                            host.iobroker
                            host.iobroker
                            host.iobroker
                            host.iobroker
                            host.iobroker
                            host.iobroker
                            host.iobroker
                            host.iobroker
                            host.iobroker
                            mcm1957M Online
                            mcm1957M Online
                            mcm1957
                            @pusemuckel
                            @wintermute
                            Siehe https://forum.iobroker.net/topic/74221/häufung-von-update-problemen/3
                            Support Repositoryverwaltung.
                            LESEN - gute Forenbeitrage
                            • mcm1957M mcm1957
                              @pusemuckel
                              @wintermute
                              mcm1957M Online
                              mcm1957M Online
                              mcm1957
                              Weiter gehts hier https://forum.iobroker.net/topic/74237/lösung-für-fehler-typeerror-err_invalid_arg_value
