  4. Javascript Adapter stürzt immer ab: Restart loop detected
29 Beiträge 4 Kommentatoren 3.1k Aufrufe 3 Beobachtet
  • S selector
    :) Gerne. das sind 300 Zeilen, ich habe das mal als Datei angehängt:
    iob.diag.txt
    Skript v.2023-10-10
    *** BASE SYSTEM ***
       Static hostname: homeserver
             Icon name: computer-desktop
               Chassis: desktop
      Operating System: Ubuntu 20.04.5 LTS
                Kernel: Linux 5.4.0-173-generic
          Architecture: x86-64
    model name      : Intel(R) Core(TM) i5-6500T CPU @ 2.50GHz
    Docker          : false
    Virtualization  : none
    Kernel          : x86_64
    Userland        : amd64
    Systemuptime and Load:
     14:39:32 up 3 min,  1 user,  load average: 0.11, 0.16, 0.08
    CPU threads: 4
    *** Time and Time Zones ***
                   Local time: Sun 2024-03-17 14:39:32 UTC
               Universal time: Sun 2024-03-17 14:39:32 UTC
                     RTC time: Sun 2024-03-17 14:39:32
                    Time zone: Etc/UTC (UTC, +0000)
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    areith
    /home/areith
    areith adm cdrom sudo dip plugdev lxd docker iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            15G        1.5G         12G        1.0M        1.4G         14G
    Swap:          4.1G          0B        4.1G
    Total:          19G        1.5G         17G
            15886 M total memory
             1500 M used memory
             1791 M active memory
              657 M inactive memory
            12954 M free memory
              228 M buffer memory
             1201 M swap cache
             4095 M total swap
                0 M used swap
             4095 M free swap
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** FILESYSTEM ***
    Filesystem                        Type      Size  Used Avail Use% Mounted on
    udev                              devtmpfs  7.8G     0  7.8G   0% /dev
    tmpfs                             tmpfs     1.6G  1.6M  1.6G   1% /run
    /dev/mapper/ubuntu--vg-ubuntu--lv ext4       98G   16G   78G  18% /
    tmpfs                             tmpfs     7.8G     0  7.8G   0% /dev/shm
    tmpfs                             tmpfs     5.0M     0  5.0M   0% /run/lock
    tmpfs                             tmpfs     7.8G     0  7.8G   0% /sys/fs/cgroup
    /dev/sda2                         ext4      2.0G  209M  1.6G  12% /boot
    /dev/loop1                        squashfs   56M   56M     0 100% /snap/core18/2812
    /dev/loop2                        squashfs   64M   64M     0 100% /snap/core20/2182
    /dev/loop3                        squashfs   40M   40M     0 100% /snap/snapd/21184
    /dev/loop0                        squashfs   56M   56M     0 100% /snap/core18/2796
    /dev/loop4                        squashfs   92M   92M     0 100% /snap/lxd/24061
    /dev/loop6                        squashfs   68M   68M     0 100% /snap/lxd/22753
    /dev/loop5                        squashfs   41M   41M     0 100% /snap/snapd/20671
    /dev/loop7                        squashfs   64M   64M     0 100% /snap/core20/2105
    tmpfs                             tmpfs     1.6G     0  1.6G   0% /run/user/1000
    [Sun Mar 17 14:36:10 2024] EXT4-fs (dm-0): mounted filesystem with ordered data mode. Opts: (null)
    [Sun Mar 17 14:36:11 2024] EXT4-fs (dm-0): re-mounted. Opts: (null)
    [Sun Mar 17 14:36:12 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
    TARGET                SOURCE                            FSTYPE   OPTIONS
    /                     /dev/mapper/ubuntu--vg-ubuntu--lv ext4     rw,relatime
    |-/sys/kernel/tracing tracefs                           tracefs  rw,nosuid,nodev,noexec,relatime
    |-/boot               /dev/sda2                         ext4     rw,relatime
    |-/snap/core18/2812   /dev/loop1                        squashfs ro,nodev,relatime
    |-/snap/core20/2182   /dev/loop2                        squashfs ro,nodev,relatime
    |-/snap/snapd/21184   /dev/loop3                        squashfs ro,nodev,relatime
    |-/snap/core18/2796   /dev/loop0                        squashfs ro,nodev,relatime
    |-/snap/lxd/24061     /dev/loop4                        squashfs ro,nodev,relatime
    |-/snap/lxd/22753     /dev/loop6                        squashfs ro,nodev,relatime
    |-/snap/snapd/20671   /dev/loop5                        squashfs ro,nodev,relatime
    `-/snap/core20/2105   /dev/loop7                        squashfs ro,nodev,relatime
    /var:
    7.1G    /var/
    6.5G    /var/lib
    5.4G    /var/lib/docker
    3.4G    /var/lib/docker/overlay2
    2.0G    /var/lib/docker/volumes
    Archived and active journals take up 512.0M in the file system.
    /opt/iobroker/backups:
    66M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    330M    /opt/iobroker/iobroker-data/
    230M    /opt/iobroker/iobroker-data/files
    75M     /opt/iobroker/iobroker-data/backup-objects
    57M     /opt/iobroker/iobroker-data/files/javascript.admin
    45M     /opt/iobroker/iobroker-data/files/devices.admin/static
    35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
    22M     /opt/iobroker/iobroker-data/objects.jsonl
    22M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map
    22M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.578d79d9.js.map
    8.8M    /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.578d79d9.js
    USB-Devices by-id:
    /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.19.0
    /usr/bin/node           v18.19.0
    /usr/bin/npm            10.2.3
    /usr/bin/npx            10.2.3
    /usr/bin/corepack       0.22.0
    nodejs:
      Installed: 18.19.0-1nodesource1
      Candidate: 18.19.1-1nodesource1
      Version table:
         18.19.1-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
     *** 18.19.0-1nodesource1 1001
         18.18.2-1nodesource1 1001
         18.18.1-1nodesource1 1001
         18.18.0-1nodesource1 1001
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
         10.19.0~dfsg-3ubuntu1.5 500
            500 http://de.archive.ubuntu.com/ubuntu focal-updates/universe amd64 Packages
            500 http://de.archive.ubuntu.com/ubuntu focal-security/universe amd64 Packages
         10.19.0~dfsg-3ubuntu1 500
            500 http://de.archive.ubuntu.com/ubuntu focal/universe amd64 Packages
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  5.0.19
    admin:          6.13.16
    javascript:     7.8.0
    Adapters from github:   0
    Adapter State
    + system.adapter.admin.0                  : admin                 : homeserver                               -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.backitup.0               : backitup              : homeserver                               -  enabled
      system.adapter.devices.0                : devices               : homeserver                               - disabled
      system.adapter.discovery.0              : discovery             : homeserver                               - disabled
    + system.adapter.go-e.0                   : go-e                  : homeserver                               -  enabled
    + system.adapter.govee-local.0            : govee-local           : homeserver                               -  enabled
    + system.adapter.ham.0                    : ham                   : homeserver                               -  enabled
    + system.adapter.influxdb.0               : influxdb              : homeserver                               -  enabled, port: 8086
    + system.adapter.javascript.0             : javascript            : homeserver                               -  enabled
    + system.adapter.modbus.0                 : modbus                : homeserver                               -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : homeserver                               -  enabled, port: 1883, bind: 0.0.0.0
      system.adapter.openweathermap.0         : openweathermap        : homeserver                               - disabled
    + system.adapter.pushover.0               : pushover              : homeserver                               -  enabled
      system.adapter.shelly.0                 : shelly                : homeserver                               - disabled, port: 1882, bind: 0.0.0.0
    + system.adapter.simple-api.0             : simple-api            : homeserver                               -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.sql.0                    : sql                   : homeserver                               -  enabled, port: 3306
    + system.adapter.telegram.0               : telegram              : homeserver                               -  enabled, port: 8443, bind: 0.0.0.0
      system.adapter.tr-064.0                 : tr-064                : homeserver                               - disabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : homeserver                               - disabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : homeserver                               -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : homeserver                               - disabled
      system.adapter.vis.0                    : vis                   : homeserver                               -  enabled
    + system.adapter.web.0                    : web                   : homeserver                               -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.zigbee.0                 : zigbee                : homeserver                               -  enabled, port: /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.13.16  , installed 6.13.16
    Adapter    "backitup"     : 2.10.11  , installed 2.10.11
    Adapter    "devices"      : 1.1.5    , installed 1.1.5
    Adapter    "discovery"    : 4.4.0    , installed 4.4.0
    Adapter    "go-e"         : 1.0.29   , installed 1.0.29
    Adapter    "govee-local"  : 0.2.5    , installed 0.2.5
    Adapter    "ham"          : 5.3.1    , installed 5.3.1
    Adapter    "javascript"   : 7.8.0    , installed 7.8.0
    Controller "js-controller": 5.0.19   , installed 5.0.19
    Adapter    "modbus"       : 6.1.0    , installed 6.1.0
    Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
    Adapter    "openweathermap": 1.0.4   , installed 1.0.4
    Adapter    "pushover"     : 3.0.6    , installed 3.0.6
    Adapter    "shelly"       : 6.6.1    , installed 6.6.1
    Adapter    "socketio"     : 6.6.0    , installed 6.6.0
    Adapter    "telegram"     : 3.1.0    , installed 3.1.0
    Adapter    "vis"          : 1.5.4    , installed 1.5.4
    Adapter    "vis-icontwo"  : 1.5.0    , installed 1.5.0
    Adapter    "web"          : 6.2.3    , installed 6.2.3
    Adapter    "ws"           : 2.5.10   , installed 2.5.10
    Adapter    "zigbee"       : 1.10.1   , installed 1.10.1
    Objects and States
    Objects:        1967
    States:         1621
    E: The repository 'https://download.docker.com/linux/debian \ Release' does not have a Release file.
    Pending Updates: 90
    *** Listening Ports ***
    sudo: netstat: command not found
    2024-03-17 14:39:57.682  - error: influxdb.0 (1467) Error: connect ECONNREFUSED 127.0.0.1:8086
    2024-03-17 14:40:00.004  - info: javascript.0 (1482) script.js.energy.periodicCalc: set attr 0_userdata.0.energy.current.houseConsumption to 569.79
    2024-03-17 14:40:00.004  - info: javascript.0 (1482) script.js.energy.periodicCalc: set attr 0_userdata.0.energy.current.totalConsumption to 2417.2
    2024-03-17 14:40:00.004  - info: javascript.0 (1482) script.js.energy.periodicCalc: set attr 0_userdata.0.energy.current.ownConsumption to 945
    2024-03-17 14:40:00.004  - info: javascript.0 (1482) script.js.energy.periodicCalc: set attr 0_userdata.0.energy.current.production to 945
    2024-03-17 14:40:00.004  - info: javascript.0 (1482) script.js.energy.periodicCalc: set attr 0_userdata.0.energy.current.supplied to 1472.1999999999998
    2024-03-17 14:40:00.004  - info: javascript.0 (1482) script.js.energy.periodicCalc: set attr 0_userdata.0.energy.current.carConsumption to 1813
    2024-03-17 14:40:00.005  - info: javascript.0 (1482) script.js.energy.periodicCalc: set attr 0_userdata.0.energy.current.heatingConsumption to 34.41
    2024-03-17 14:40:00.005  - info: javascript.0 (1482) script.js.energy.periodicCalc: set attr 0_userdata.0.energy.current.availableForCar to 340
    2024-03-17 14:40:00.005  - info: javascript.0 (1482) script.js.energy.periodicCalc: set attr 0_userdata.0.energy.current.consumptionWithoutCar to 604.1999999999999
    2024-03-17 14:40:00.005  - info: javascript.0 (1482) script.js.energy.periodicCalc: set attr 0_userdata.0.energy.current.feed to 0
    2024-03-17 14:40:00.007  - info: modbus.0 (3007) Scheduled restart.
    2024-03-17 14:40:00.013  - info: modbus.0 (3007) terminating
    2024-03-17 14:40:00.014  - info: modbus.0 (3007) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2024-03-17 14:40:00.020  - info: javascript.0 (1482) script.js.rooms.bathroom.heatingmirror: window open: false
    2024-03-17 14:40:00.020  - info: javascript.0 (1482) script.js.rooms.bathroom.heatingmirror: temperatour: 19.2
    2024-03-17 14:40:00.020  - info: javascript.0 (1482) script.js.rooms.bathroom.heatingmirror: t: 940 from 360 to 510
    2024-03-17 14:40:00.020  - info: javascript.0 (1482) script.js.rooms.bathroom.heatingmirror: stopping, not in time window
    2024-03-17 14:40:00.020  - info: javascript.0 (1482) script.js.rooms.bathroom.heatingmirror: t: 940 from 1260 to 1270
    2024-03-17 14:40:00.026  - info: javascript.0 (1482) script.js.rooms.house.effect-light: switch on
    2024-03-17 14:40:00.095  - info: javascript.0 (1482) script.js.rooms.basement.humidity: stop dehumidifier, because car is plugged (true), there is no overage (340W) or humidity (59.94) is lower than60
    2024-03-17 14:40:00.511  - info: modbus.0 (3007) terminating
    2024-03-17 14:40:00.551  - info: host.homeserver instance system.adapter.modbus.0 scheduled normal terminated and will be restarted on schedule.
    2024-03-17 14:40:00.551  - info: host.homeserver Restart adapter system.adapter.modbus.0 because enabled
    @selector
    Wird langsam Zeit sich mit einem Upgrade auf eine aktuellere Version zu beschäftigen.
    Falsche Zeitzone.
    Boot Target: graphical.target
    Stell das auf multi-user.target
    Pending Updates: 90
    Einspielen. Das docker-Repo muss allerdings zuvor richtig eingestellt werden. Da klemmt es.
      @selector
      Falsche Zeitzone.
      Pending Updates: 90
      @thomas-braun sagte in Javascript Adapter stürzt immer ab: Restart loop detected:
      Das docker-Repo
      das hat mich auch irritiert
      @selector sagte in Javascript Adapter stürzt immer ab: Restart loop detected:
      Docker : false
        Das docker-Repo
        Docker : false
        Das braucht (?) man, um auf dem Server einen Docker laufen zu lassen.
        • S selector
          Ich kriege häufig eine Fehler des Javascript Adapters
          Adapter warnings
          Issues with frequently crashing adapter instances
          Javascript.0
          Logischerweise funktionieren dann meine ganzen Skripte nicht mehr. Wenn man den Adapter neustartet funktioniert es eine zeitlang wieder.
          Wenn ich über die Konsole
          iobroker debug Javascript0
          eingebe kriege ich folgende Exception angezeigt:
          Uncaught Rejection: TypeError: Cannot destructure property 'name' of 'CLITools.splitAdapterOrInstanceIdentifierWithVersion(...)' as it is null.
          at CLIDebug.execute (/opt/iobroker/node_modules/@iobroker/js-controller-cli/build/lib/cli/cliDebug.js:72:17)
          at processCommand (/opt/iobroker/node_modules/@iobroker/js-controller-cli/build/lib/setup.js:477:26)
          at Object.execute (/opt/iobroker/node_modules/@iobroker/js-controller-cli/build/lib/setup.js:2705:5)
          at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js:1:40)
          at Module._compile (node:internal/modules/cjs/loader:1356:14)
          at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
          at Module.load (node:internal/modules/cjs/loader:1197:32)
          at Module._load (node:internal/modules/cjs/loader:1013:12)
          at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
          at node:internal/main/run_main_module:28:49
          areith@homeserver:~$
          Hat jemand eine Idee wie man das beheben oder anders debuggen kann? Was ist z. B. CLITools.splitAdapterOrInstanceIdentifierWithVersion, wo der Fehler ja scheinbar auftritt. Auch über google finde ich nichts hilfreiches zu dem Problem.
          Danke für Hilfe!
          F Online
          F Online
          fastfoot
          Kleinschreibung hilft hier definitiv!
          Ansonsten tippe ich auf eines deiner Skripte als Ursache der Restart Loops...
            selector
            Ich denke das hängt damit zusammen, dass ich den ioBroker erst als Docker-Container laufen hatte. Ich habe aber den bluetooth-Adapter nicht ans Laufen gekriegt und dann iobroker so auf dem Rechner installiert und ein Backup eingespielt.
            Aktuell laufen nur noch mariadb, grafana und influxdb im Container. Influxdb stürzt aber auch oft ab und ich werde das demnächst so installieren
            • F fastfoot
              selector
              schrieb am zuletzt editiert von selector
              @fastfoot said in Javascript Adapter stürzt immer ab: Restart loop detected:
              Was meinst du?
              Hm, kann ein Fehler in einem Script den ganzen Adapter zum Absturz bringen? Es gibt da wissentlich nur einen Error im Log, das ein Datumsformat nicht geparst werden kann.
              Allerdings habe ich jetzt folgendes im Log entdeckt, das ist aber neu:
              host.homeserver
              2024-03-17 14:58:02.578	error	Please consider running the installation fixer when on Linux.
              host.homeserver
              2024-03-17 14:58:02.577	error	could not store process id list in /opt/iobroker/node_modules/iobroker.js-controller/pids.txt! Please check permissions and user ownership of this file. Was ioBroker started as a different user? Please also check left over processes when stopping ioBroker!Error: EACCES: permission denied, open '/opt/iobroker/node_modules/iobroker.js-controller/pids.txt'
              • S selector
                Was meinst du?
                host.homeserver
                host.homeserver
                @selector
                Hast du die Basics jetzt gerade? Erst dann ist es sinnvoll sich mit den nächsten Dinge zu beschäftigen.
                • S selector
                  Was meinst du?
                  host.homeserver
                  host.homeserver
                  getfacl /opt/iobroker/node_modules/iobroker.js-controller/pids.txt
                  sagt?
                    sagt?
                    selector
                    Es gibt die Datei nicht. Oben steht ja auch, dass er die nicht speichern kann. Aber die Rechte sind da wohl wirklich komisch. Ein ls -al in dem iobroker,js-controller zeigt für user und gruppe root mit -rw-r--r-- für Dateien und drwxr-xr-x für Verzeichnisse an.
                    Im Verzeichnis oberhalb, also dem node_modules Verzeichnis wird als owner und gruppe immer iobroker angezeigt. Ich selbst arbeite nicht als root an dem System.
                    Wie kann das entstehen?
                    Thomas BraunT 3 Antworten Letzte Antwort
                    • S selector
                      Durch rückkopieren von einer 'Installation' aus einem Docker. Da läuft das ja wohl als root.
                      • S selector
                        Nein, das steht da nicht. Da steht, das die Datei nicht gespeichert werden kann, weil die Rechte nicht passen.
                        iob stop
                        iob fix
                        iob start
                        • S selector
                          Zeigen...
                          Wobei hier ACLs gesetzt sind. Da bringt dir die Ausgabe von ls -la nix.
                            selector
                            @thomas-braun said in [Javascript Adapter stürzt immer ab: Restart loop detected]> > Wie kann das entstehen?
                            Das habe ich wie gesagt nicht. Ich habe ioBroker installiert und dann das Backup von der Installation aus dem Container eingespielt.
                            • S selector
                              selector
                              Ich verstehe den Zusammenhang nicht. Oben hat ja auch @thomas-braun angemerkt, das die Repo-Einstellungen komisch sind. Er meint aber wahrscheinlich nicht die iobroker repos, die stehen ja wie hier: https://www.iobroker.net/docu/index-234.htm?page_id=6227&lang=de#Verwahrungsorte_oder_Repositories sonder die OS Repos, also die Repositories des Betriebsystems:
                              Pending Updates: 90
                              Allerdings weiß ich nicht woher das kommt, wenn ich mir die Repos anzeigen lasse
                              cat /etc/apt/sources.list
                              dann ist da kein Repo mit docker zu finden.
                              Wenn das
                              iob fix
                              ausführe, dann werden aber auch docker repos verwendet,
                              Hit:1 http://de.archive.ubuntu.com/ubuntu focal InRelease
                              Hit:2 http://de.archive.ubuntu.com/ubuntu focal-updates InRelease
                              Hit:3 http://ppa.launchpad.net/deadsnakes/ppa/ubuntu focal InRelease
                              Hit:4 http://de.archive.ubuntu.com/ubuntu focal-backports InRelease
                              Hit:5 http://de.archive.ubuntu.com/ubuntu focal-security InRelease
                              Hit:6 https://deb.nodesource.com/node_18.x nodistro InRelease
                              Ign:7 https://download.docker.com/linux/debian \ InRelease
                              Err:8 https://download.docker.com/linux/debian \ Release
                                404  Not Found [IP: 65.9.66.72 443]
                              Reading package lists... Done
                              N: Updating from such a repository can't be done securely, and is therefore disabled by default.
                              N: See apt-secure(8) manpage for repository creation and user configuration details.
                              Installed libavahi-compat-libdnssd-dev
                              Installed libpam0g-dev
                              Installed pkg-config
                              was hat es mit den Repos auf sich?
                              • S selector
                                Pending Updates: 90
                                Wenn das
                                iob fix
                                Die .list-Datei dazu liegt in /etc/apt/sources.list.d/ herum. Wenn es nicht verwendet wird, raus damit.
                                Ebenso tote Schlangen aus dem launchpad sowie backports.
                                Will man alles auf einem Server nicht haben.
                                  selector
                                  ich habe jetzt die pakete aktualisiert und die docker registry ausgetragen. Die Fileownership in dem node_modues/...javascript Verzeichnis liegen jetzt auch bei iobroker.
                                  Meinst du denn das war das Problem warum der Adapter immer abgeschmiert ist?
                                  Danke für Deinen Support!
                                  • S selector
                                    Kann ich nicht sagen.
                                    iob diag
                                    sieht nun wie aus?
                                      iob diag
                                      sieht nun wie aus?
                                      selector
                                      Skript v.2023-10-10
                                      *** BASE SYSTEM ***
                                                 Chassis: desktop
                                        Operating System: Ubuntu 20.04.6 LTS
                                      Docker          : false
                                      Kernel          : x86_64
                                      Userland        : amd64
                                       17:21:06 up 19 min,  1 user,  load average: 0.07, 0.06, 0.09
                                      CPU threads: 4
                                                     Local time: Sun 2024-03-17 17:21:06 UTC
                                                 Universal time: Sun 2024-03-17 17:21:06 UTC
                                                       RTC time: Sun 2024-03-17 17:21:06
                                                    NTP service: active
                                                RTC in local TZ: no
                                      areith
                                      /home/areith
                                      X-Server:       false
                                      Desktop:
                                      Terminal:       tty
                                      *** MEMORY ***
                                      Mem:            15G        1.8G         12G        1.0M        1.4G         13G
                                      Swap:          4.1G          0B        4.1G
                                      Total:          19G        1.8G         16G
                                               1820 M used memory
                                               2315 M active memory
                                                459 M inactive memory
                                              12619 M free memory
                                                235 M buffer memory
                                               1210 M swap cache
                                               4095 M total swap
                                                  0 M used swap
                                               4095 M free swap
                                      *** FILESYSTEM ***
                                      /dev/mapper/ubuntu--vg-ubuntu--lv ext4       98G   17G   77G  18% /
                                      /dev/loop2                        squashfs   64M   64M     0 100% /snap/core20/2105
                                      /dev/loop5                        squashfs   68M   68M     0 100% /snap/lxd/22753
                                      /dev/loop3                        squashfs   64M   64M     0 100% /snap/core20/2182
                                      /dev/loop6                        squashfs   41M   41M     0 100% /snap/snapd/20671
                                      /dev/loop7                        squashfs   40M   40M     0 100% /snap/snapd/21184
                                      [Sun Mar 17 17:01:42 2024] EXT4-fs (dm-0): mounted filesystem with ordered data mode. Opts: (null)
                                      [Sun Mar 17 17:01:43 2024] EXT4-fs (dm-0): re-mounted. Opts: (null)
                                      [Sun Mar 17 17:01:44 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
                                      |-/snap/core20/2105   /dev/loop2                        squashfs ro,nodev,relatime
                                      |-/snap/lxd/22753     /dev/loop5                        squashfs ro,nodev,relatime
                                      |-/snap/core20/2182   /dev/loop3                        squashfs ro,nodev,relatime
                                      |-/snap/snapd/20671   /dev/loop6                        squashfs ro,nodev,relatime
                                      `-/snap/snapd/21184   /dev/loop7                        squashfs ro,nodev,relatime
                                      /var:
                                      7.3G    /var/
                                      6.5G    /var/lib
                                      326M    /opt/iobroker/iobroker-data/
                                      20M     /opt/iobroker/iobroker-data/objects.jsonl
                                      USB-Devices by-id:
                                      /usr/bin/nodejs         v18.19.1
                                      /usr/bin/node           v18.19.1
                                      /usr/bin/npm            10.2.4
                                      /usr/bin/npx            10.2.4
                                      nodejs:
                                        Installed: 18.19.1-1nodesource1
                                        Version table:
                                       *** 18.19.1-1nodesource1 1001
                                      Errors in npm tree:
                                      ioBroker Status
                                      Objects type: jsonl
                                      States  type: jsonl
                                      admin:          6.13.16
                                      javascript:     7.8.0
                                      Adapter State
                                      + instance is alive
                                      Objects and States
                                      Objects:        1967
                                      States:         1606
                                      Hit:1 http://ppa.launchpad.net/deadsnakes/ppa/ubuntu focal InRelease
                                      Hit:2 http://de.archive.ubuntu.com/ubuntu focal InRelease
                                      Hit:3 http://de.archive.ubuntu.com/ubuntu focal-updates InRelease
                                      Pending Updates: 0
                                      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          13294      1/init
                                      tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      101        23863      671/systemd-resolve
                                      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          27845      746/sshd: /usr/sbin
                                      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       32441      1639/io.mqtt.0
                                      tcp        0      0 0.0.0.0:3808            0.0.0.0:*               LISTEN      0          30229      1142/docker-proxy
                                      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       31803      697/iobroker.js-con
                                      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       30304      697/iobroker.js-con
                                      tcp        0      0 0.0.0.0:3306            0.0.0.0:*               LISTEN      0          29662      1165/docker-proxy
                                      tcp6       0      0 :::111                  :::*                    LISTEN      0          13298      1/init
                                      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       32071      1352/io.admin.0
                                      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       31683      1724/io.web.0
                                      tcp6       0      0 :::22                   :::*                    LISTEN      0          27847      746/sshd: /usr/sbin
                                      tcp6       0      0 :::8087                 :::*                    LISTEN      1001       32590      1754/io.simple-api.
                                      tcp6       0      0 :::3808                 :::*                    LISTEN      0          29655      1150/docker-proxy
                                      tcp6       0      0 :::3306                 :::*                    LISTEN      0          28558      1170/docker-proxy
                                      udp        0      0 0.0.0.0:4002            0.0.0.0:*                           1001       34290      1739/io.govee-local
                                      udp        0      0 127.0.0.53:53           0.0.0.0:*                           101        23862      671/systemd-resolve
                                      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          13295      1/init
                                      udp6       0      0 :::111                  :::*                                0          12114      1/init
                                      udp6       0      0 fe80::6e4b:90ff:fe1:546 :::*                                100        24937      668/systemd-network
                                      2024-03-17 17:21:08.306  - info: modbus.0 (4439) Disconnected from slave 192.168.1.112
                                      2024-03-17 17:21:09.530  - info: influxdb.0 (1473) Connecting http://localhost:8086/ ...
                                      2024-03-17 17:21:09.530  - info: influxdb.0 (1473) Influx DB Version used: 2.x
                                      2024-03-17 17:21:09.531  - error: influxdb.0 (1473) Error: connect ECONNREFUSED 127.0.0.1:8086
                                      2024-03-17 17:21:09.718  - warn: zigbee.0 (1654) Send command to 0x3425b4fffec698ef failed with: Code 205 (No network route)
                                      2024-03-17 17:21:14.087  - info: javascript.0 (1488) script.js.rooms.bed.cabinetIlumination: no motion since: 330
                                      2024-03-17 17:21:14.088  - info: javascript.0 (1488) script.js.rooms.bed.cabinetIlumination: calc with 330 lux 30 hours: 17
                                      2024-03-17 17:21:19.531  - info: influxdb.0 (1473) Connecting http://localhost:8086/ ...
                                      2024-03-17 17:21:19.531  - info: influxdb.0 (1473) Influx DB Version used: 2.x
                                      2024-03-17 17:21:19.532  - error: influxdb.0 (1473) Error: connect ECONNREFUSED 127.0.0.1:8086
                                      2024-03-17 17:21:24.087  - info: javascript.0 (1488) script.js.rooms.bed.cabinetIlumination: no motion since: 340
                                      2024-03-17 17:21:24.088  - info: javascript.0 (1488) script.js.rooms.bed.cabinetIlumination: calc with 340 lux 30 hours: 17
                                      2024-03-17 17:21:29.533  - info: influxdb.0 (1473) Connecting http://localhost:8086/ ...
                                      2024-03-17 17:21:29.533  - info: influxdb.0 (1473) Influx DB Version used: 2.x
                                      2024-03-17 17:21:29.534  - error: influxdb.0 (1473) Error: connect ECONNREFUSED 127.0.0.1:8086
                                      2024-03-17 17:21:30.003  - info: javascript.0 (1488) script.js.energy.periodicCalc: set attr 0_userdata.0.energy.current.houseConsumption to 569.79
                                      2024-03-17 17:21:30.003  - info: javascript.0 (1488) script.js.energy.periodicCalc: set attr 0_userdata.0.energy.current.totalConsumption to 2417.2
                                      2024-03-17 17:21:30.003  - info: javascript.0 (1488) script.js.energy.periodicCalc: set attr 0_userdata.0.energy.current.ownConsumption to 0
                                      2024-03-17 17:21:30.003  - info: javascript.0 (1488) script.js.energy.periodicCalc: set attr 0_userdata.0.energy.current.production to 0
                                      2024-03-17 17:21:30.003  - info: javascript.0 (1488) script.js.energy.periodicCalc: set attr 0_userdata.0.energy.current.supplied to 2417.2
                                      2024-03-17 17:21:30.003  - info: javascript.0 (1488) script.js.energy.periodicCalc: set attr 0_userdata.0.energy.current.carConsumption to 1813
                                      2024-03-17 17:21:30.003  - info: javascript.0 (1488) script.js.energy.periodicCalc: set attr 0_userdata.0.energy.current.heatingConsumption to 34.41
                                      2024-03-17 17:21:30.005  - info: javascript.0 (1488) script.js.energy.periodicCalc: set attr 0_userdata.0.energy.current.availableForCar to 0
                                      2024-03-17 17:21:30.006  - info: javascript.0 (1488) script.js.energy.periodicCalc: set attr 0_userdata.0.energy.current.consumptionWithoutCar to 604.1999999999999
                                      2024-03-17 17:21:30.006  - info: javascript.0 (1488) script.js.energy.periodicCalc: set attr 0_userdata.0.energy.current.feed to 0
                                      iob diag has finished.
                                      Press any key for a summary
                                      • S selector
                                        Skript v.2023-10-10
                                        *** BASE SYSTEM ***
                                                   Chassis: desktop
                                        Docker          : false
                                        Kernel          : x86_64
                                        Userland        : amd64
                                        CPU threads: 4
                                                      NTP service: active
                                                  RTC in local TZ: no
                                        areith
                                        /home/areith
                                        X-Server:       false
                                        Desktop:
                                        Terminal:       tty
                                        *** MEMORY ***
                                        Swap:          4.1G          0B        4.1G
                                        Total:          19G        1.8G         16G
                                                 1820 M used memory
                                                12619 M free memory
                                                  235 M buffer memory
                                                 1210 M swap cache
                                                 4095 M total swap
                                                    0 M used swap
                                                 4095 M free swap
                                        *** FILESYSTEM ***
                                        /var:
                                        7.3G    /var/
                                        6.5G    /var/lib
                                        USB-Devices by-id:
                                        /usr/bin/npm            10.2.4
                                        /usr/bin/npx            10.2.4
                                        nodejs:
                                          Version table:
                                        Errors in npm tree:
                                        ioBroker Status
                                        Objects type: jsonl
                                        States  type: jsonl
                                        admin:          6.13.16
                                        javascript:     7.8.0
                                        Adapter State
                                        + instance is alive
                                        Objects and States
                                        Objects:        1967
                                        States:         1606
                                        Pending Updates: 0
                                        Du hast den falschen Kram ja immer noch nicht angepackt...
                                        Setz die richtig! Das ist WICHTIG!
                                        sudo timedatectl set-timezone "Europe/Berlin"
                                        Oder in welcher Zeitzone du auch immer lebst.
                                        Setz das auf multi-user.target
                                        sudo systemctl set-default multi-user.target
                                        Rauskicken, wenn du nicht weißt warum das aktiv ist:
                                          selector
                                          So habe die Repos entfernt und die Timezone richtig eingestellt. Das mit der Timezone erklärt auch Probleme die ich mit den Javascripten hatte, wo Date() immer eine Stunde "falsch gegangen" ist. Komisch war, dass die Logeinträge über den IOBroker immer die richtige Zeit hatten.
                                          Bin gespannt wie sich jetzt der JS-Adapter verhält.
                                          Nochmal danke für den Support
