  4. Adapter lässt sich nicht löschen
25 Beiträge 10 Kommentatoren 2.8k Aufrufe 11 Beobachtet
  • I ichwersonst
    Skript v.2023-10-10
    *** BASE SYSTEM ***
       Static hostname: raspberrypi
             Icon name: computer
      Operating System: Raspbian GNU/Linux 11 (bullseye)
                Kernel: Linux 6.1.21-v8+
          Architecture: arm64
    Model           : Raspberry Pi 4 Model B Rev 1.5
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : armhf
    Systemuptime and Load:
     10:44:00 up 68 days, 18:24,  1 user,  load average: 1.06, 0.93, 0.68
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Tue 2024-02-27 10:44:01 CET
               Universal time: Tue 2024-02-27 09:44:01 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:            3.8G        1.2G        917M        1.0M        1.7G        2.5G
    Swap:            99M          0B         99M
    Total:          3.9G        1.2G        1.0G
             3793 M total memory
             1201 M used memory
             1495 M active memory
             1121 M inactive memory
              917 M free memory
              345 M buffer memory
             1328 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    *** FAILED SERVICES ***
      UNIT                  LOAD   ACTIVE SUB    DESCRIPTION
    * bthelper@hci0.service loaded failed failed Raspberry Pi bluetooth helper
    * deconz-init.service   loaded failed failed deCONZ: ZigBee gateway -- Initialisation
    * deconz-update.service loaded failed failed deCONZ: ZigBee gateway -- Update Service
    * deconz-wifi.service   loaded failed failed deCONZ: ZigBee gateway -- WIFI Service
    4 loaded units listed.
    *** FILESYSTEM ***
    /dev/root      ext4       56G  7.8G   46G  15% /
    devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
    tmpfs          tmpfs     759M  1.2M  758M   1% /run
    /dev/sda1      vfat      253M   51M  202M  20% /boot
    tmpfs          tmpfs     380M   16K  380M   1% /run/user/1000
    [Wed Dec 20 16:19:31 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:37:DD:BE vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=tty1 root=PARTUUID=2a31fda3-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
    [Wed Dec 20 16:19:34 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
    [Wed Dec 20 16:19:34 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
    [Wed Dec 20 16:19:36 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
    TARGET  SOURCE    FSTYPE OPTIONS
    /       /dev/sda2 ext4   rw,noatime
    `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    2.2G    /var/
    1.4G    /var/log/journal/5530f3d80baf4cc0bb1ed682675aa129
    1.4G    /var/log
    537M    /var/cache
    Archived and active journals take up 1.3G in the file system.
    /opt/iobroker/backups:
    59M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    788M    /opt/iobroker/iobroker-data/
    521M    /opt/iobroker/iobroker-data/history
    157M    /opt/iobroker/iobroker-data/files
    59M     /opt/iobroker/iobroker-data/backup-objects
    57M     /opt/iobroker/iobroker-data/files/javascript.admin
    34M     /opt/iobroker/iobroker-data/states.jsonl
    22M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map
    19M     /opt/iobroker/iobroker-data/objects.jsonl
    8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js
    7.0M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/675.d0c8b930.chunk.js.map
    USB-Devices by-id:
    /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2121476-if00
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.19.1
    /usr/bin/node           v18.19.1
    /usr/bin/npm            10.2.4
    /usr/bin/npx            10.2.4
    /usr/bin/corepack       0.22.0
    nodejs:
      Installed: 18.19.1-1nodesource1
      Candidate: 18.19.1-1nodesource1
      Version table:
     *** 18.19.1-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
         18.19.0-1nodesource1 1001
         18.18.2-1nodesource1 1001
         18.18.1-1nodesource1 1001
         18.18.0-1nodesource1 1001
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
         12.22.12~dfsg-1~deb11u4 500
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  5.0.19
    admin:          6.13.16
    javascript:     7.8.0
    Adapters from github:   1
    Adapter State
    + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
    + system.adapter.broadlink2.0             : broadlink2            : raspberrypi                              -  enabled
    + system.adapter.broadlink2.1             : broadlink2            : raspberrypi                              -  enabled
    + system.adapter.deconz.0                 : deconz                : raspberrypi                              -  enabled, port: 80
      system.adapter.flot.0                   : flot                  : raspberrypi                              -  enabled
    + system.adapter.history.0                : history               : raspberrypi                              -  enabled
      system.adapter.icons-icons8.0           : icons-icons8          : raspberrypi                              -  enabled
    + system.adapter.lgtv.0                   : lgtv                  : raspberrypi                              -  enabled
    + system.adapter.pushbullet.0             : pushbullet            : raspberrypi                              -  enabled
    + system.adapter.sayit.0                  : sayit                 : raspberrypi                              -  enabled
    + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.spotify-premium.0        : spotify-premium       : raspberrypi                              -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              -  enabled
      system.adapter.vis-map.0                : vis-map               : raspberrypi                              -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              -  enabled
    + system.adapter.vw-connect.0             : vw-connect            : raspberrypi                              -  enabled
      system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              -  enabled
    + system.adapter.wled.0                   : wled                  : raspberrypi                              -  enabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.13.16  , installed 6.13.16
    Adapter    "backitup"     : 2.10.11  , installed 2.10.11
    Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
    Adapter    "deconz"       : 1.3.23   , installed 1.3.23
    Adapter    "javascript"   : 7.8.0    , installed 7.8.0
    Controller "js-controller": 5.0.19   , installed 5.0.19
    Adapter    "lgtv"         : 2.1.2    , installed 2.1.2
    Adapter    "pushbullet"   : 2.0.1    , installed 2.0.1
    Adapter    "sayit"        : 3.0.5    , installed 3.0.5
    Adapter    "shelly"       : 6.6.1    , installed 6.6.1
    Adapter    "socketio"     : 6.6.0    , installed 6.6.0
    Adapter    "spotify-premium": 1.3.1  , installed 1.3.1
    Adapter    "vis"          : 1.5.4    , installed 1.5.4
    Adapter    "vis-map"      : 1.0.5    , installed 1.0.5
    Adapter    "vw-connect"   : 0.0.67   , installed 0.1.2
    Adapter    "weatherunderground": 3.6.0, installed 3.6.0
    Adapter    "web"          : 6.2.3    , installed 6.2.3
    Adapter    "wled"         : 0.7.2    , installed 0.7.2
    Adapter    "ws"           : 2.5.10   , installed 2.5.10
    Objects and States
    Objects:        11747
    States:         10419
    Hit:1 http://phoscon.de/apt/deconz bullseye InRelease
    Hit:2 http://deb.debian.org/debian bullseye-proposed-updates InRelease
    Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:4 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
    Get:6 https://pkgs.tailscale.com/stable/raspbian bullseye InRelease
    Fetched 6566 B in 1s (4577 B/s)
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          483729882  22009/sshd: /usr/sb
    tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       14972      407/deCONZ
    tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       17947      407/deCONZ
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          535940889  6919/cupsd
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       495196727  11394/iobroker.js-c
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       495197780  11394/iobroker.js-c
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       495195773  11492/io.shelly.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          483729884  22009/sshd: /usr/sb
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          535940888  6919/cupsd
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       495198963  11412/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       538970055  27524/io.web.0
    udp        0      0 0.0.0.0:54990           0.0.0.0:*                           1001       495199415  11812/io.broadlink2
    udp        0      0 0.0.0.0:34604           0.0.0.0:*                           1001       495195903  11577/io.broadlink2
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       495201669  12310/io.deconz.0
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       15021      407/deCONZ
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          16486      478/dhcpcd
    udp        0      0 0.0.0.0:39369           0.0.0.0:*                           1001       495200649  11812/io.broadlink2
    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          535940895  6922/cups-browsed
    udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       495199411  11812/io.broadlink2
    udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       495197971  11577/io.broadlink2
    udp        0      0 0.0.0.0:41895           0.0.0.0:*                           1001       495195861  11577/io.broadlink2
    udp        0      0 0.0.0.0:54233           0.0.0.0:*                           108        14849      401/avahi-daemon: r
    udp        0      0 0.0.0.0:46111           0.0.0.0:*                           1001       495195862  11577/io.broadlink2
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       495196928  11609/io.wled.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14847      401/avahi-daemon: r
    udp        0      0 0.0.0.0:48556           0.0.0.0:*                           1001       495199414  11812/io.broadlink2
    udp6       0      0 :::1900                 :::*                                1001       495201671  12310/io.deconz.0
    udp6       0      0 :::1900                 :::*                                1001       495201670  12310/io.deconz.0
    udp6       0      0 :::38919                :::*                                108        14850      401/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                108        14848      401/avahi-daemon: r
    2024-02-27 10:39:22.013  - info: host.raspberrypi iobroker exit 0
    2024-02-27 10:39:35.737  - info: host.raspberrypi iobroker del simple-api --debug
    2024-02-27 10:39:38.275  - info: host.raspberrypi iobroker Delete adapter "simple-api"
    2024-02-27 10:39:38.461  - info: host.raspberrypi iobroker host.raspberrypi Counted 1 meta of simple-api
    2024-02-27 10:39:38.465  - info: host.raspberrypi iobroker host.raspberrypi Counted 1 adapter for simple-api
    2024-02-27 10:39:38.733  - info: host.raspberrypi iobroker host.raspberrypi Counted 3 states (system.adapter.simple-api.*) from states
    2024-02-27 10:39:40.368  - info: host.raspberrypi iobroker host.raspberrypi file simple-api.admin deleted
    2024-02-27 10:39:40.376  - info: host.raspberrypi iobroker host.raspberrypi object simple-api deleted
    2024-02-27 10:39:40.388  - info: host.raspberrypi iobroker host.raspberrypi object simple-api.admin deleted
    2024-02-27 10:39:40.389  - info: host.raspberrypi iobroker host.raspberrypi Deleting 2 object(s).
    2024-02-27 10:39:40.442  - info: host.raspberrypi iobroker host.raspberrypi Deleting 3 state(s).
    2024-02-27 10:39:47.463  - info: host.raspberrypi iobroker
    2024-02-27 10:39:47.464  - info: host.raspberrypi iobroker up to date in 6s59 packages are looking for funding  run `npm fund` for details
    2024-02-27 10:39:48.526  - info: host.raspberrypi iobroker exit 0
    2024-02-27 10:40:12.643  - info: admin.0 (11412) <== Disconnect system.user.admin from ::ffff:192.168.178.202 admin
    2024-02-27 10:40:16.068  - info: admin.0 (11412) ==> Connected system.user.admin from ::ffff:192.168.178.202
    2024-02-27 10:40:31.630  - info: host.raspberrypi iobroker del simple-api --custom --debug
    2024-02-27 10:40:34.305  - info: host.raspberrypi iobroker Delete adapter "simple-api"
    2024-02-27 10:40:36.405  - info: host.raspberrypi iobroker host.raspberrypi object simple-api deleted
    2024-02-27 10:40:36.408  - info: host.raspberrypi iobroker host.raspberrypi object simple-api.admin deleted
    2024-02-27 10:40:43.422  - info: host.raspberrypi iobroker
    2024-02-27 10:40:43.423  - info: host.raspberrypi iobroker up to date in 6s
    2024-02-27 10:40:43.426  - info: host.raspberrypi iobroker 59 packages are looking for funding  run `npm fund` for details
    2024-02-27 10:40:44.487  - info: host.raspberrypi iobroker exit 0
    2024-02-27 10:44:42.546  - warn: spotify-premium.0 (10695) too many requests, wait 75369s
    Mir fällt auf jeden Fall auf, dass simple-api wohl noch irgendwie installiert ist sowie socket io und ws(web socket), die ich auch nicht mehr als Instanz habe und auch nicht mehr nutze.
    MartinPM Offline
    MartinPM Offline
    MartinP
    @ichwersonst Ich vermute, dass es teilweise Abhängigkeiten der Adapter voneinander gibt - also, wenn man Adapter X nutzt, muss auch Adapter Y installiert sein, socket io und ws wären solche Kandidaten, auf die andere Adapter ggfs. aufbauen ...
    https://github.com/ioBroker/ioBroker.socketio
    This adapter is used by WEB applications and adapters to communicate with ioBroker using websockets and the socket.io protocol.
    I 2 Antworten Letzte Antwort
    • MartinPM MartinP
      I Offline
      I Offline
      ichwersonst
      @martinp
      Das klingt erstmal schlüssig, das stimmt.
      Aber da bleibt für mich dennoch die Frage, warum sich simple-API nicht entfernen lässt.
      • MartinPM MartinP
        I Offline
        I Offline
        ichwersonst
        @martinp
        hmm simple-api scheint zum web Adapter zu gehören.
        Also wäre schon interessant, wenn noch jemand deine Vermutung bestätigen könnte :-)
        • I ichwersonst
          @martinp
          haus-automatisierungH Offline
          @ichwersonst sagte in Adapter lässt sich nicht löschen:
          Nicht zwingend. Kann genutzt werden, muss aber nicht. Das Paket wird zumindest mit web mitinstalliert
          https://github.com/ioBroker/ioBroker.web/blob/507c110b0dd20baec386cd2949d5727885c1e290/package.json#L30
          📚 Meine Dokumentation
            MartinPM Offline
            MartinPM Offline
            MartinP
            @haus-automatisierung Interessant ist, dass ja irgendeine Art von "Notbremse" das laut Logging erfolgte ...
            ... delete verhindert hat, ohne eine Spur im Logging zu hinterlassen ...
            Merkwürdig ...
            Irgendwo scheint jedenfalls innerhalb von Iobroker eine Art Abhängigkeiten-Verwaltung vorhanden zu sein, die Löschen verhindert.
            Ein entsprechende "iobroker" Kommandozeilen-Kommando scheint es aber nicht zu geben...
            I haus-automatisierungH 2 Antworten Letzte Antwort
            • MartinPM MartinP
              Merkwürdig ...
              I Offline
              I Offline
              ichwersonst
              @martinp
              So würde ich das irgendwie auch sehen.
              Theoretisch müsste ja bei jedem, der KEINE Instanz von simple-api, websocket und socketio installiert hat aber z.B. eines Instanz des Web Adapter installiert hat, eine Versionsnummer in der "installiert" Spalte unter Adapter bei den 3 Adaptern stehen.
              • MartinPM MartinP
                Merkwürdig ...
                @martinp sagte in Adapter lässt sich nicht löschen:
                Ja, ich hätte mir jetzt auch mehr Infos erhofft. Welche js-controller Version ist denn installiert?
                EDIT: ah, js-controller: 5.0.19 - ich schau mal in den Code
                  Mh, normalerweise sollte es eine entsprechende Meldung geben, falls ein anderer Adapter diesen noch benötigt:
                  https://github.com/ioBroker/ioBroker.js-controller/blob/0af2f35efcf8b985e9278b89ef9f5f2fa6e53b26/packages/cli/src/lib/setup/setupInstall.ts#L1574-L1581
                  Uninstall npm wird aber fehlschlagen, weil ja der web adapter dieses npm paket gerne behalten würde. Eventuell kann @foxriver76 etwas dazu sagen
                  • I ichwersonst
                     iobroker delete simple-api --debug
                    up to date in 6s
                    foxriver76F Offline
                    foxriver76F Offline
                    foxriver76
                    up to date in 6s
                    Hm das Log ist komisch, schaut so aus als würde npm uninstall Befehl laufen aber normal ist im npm output eine Zeile removed 1 package in Xms vor dem funding Aufruf. Was mich darauf schließen lässt, dass das Package wahrscheinlich wirklich schon gelöscht ist oder da web es wohl als Abhängigkeit in der package.json hat, weigert sich npm das weg zu räumen. Ich weiß aktuell leider nicht ob da was mit npm v10 bekannt ist, allerdings ist das bislang die erste Meldung in die Richtung.
                    Du kannst mal checken ob es in deinem node_modules Folder noch da ist und ggf mal im /opt/iobroker den Befehl npm ls iobroker.simple-api ausführen und Ouput zeigen
                    Videotutorials & mehr
                    • foxriver76F foxriver76
                      up to date in 6s
                      mcm1957M Online
                      mcm1957M Online
                      mcm1957
                      @foxriver76
                      @apollon77
                      Ist es wirklich richtig, dass der Adapter ioBroker.web den Adapter ioBroker.simpl-api als npm dependency in package.json eingetragen hat:
                          "iobroker.simple-api": "^2.7.2",
                      Normalerweise sollten doch Abhängigkeiten zu anderen Adaptern via io-package.json in "dependencies" angefordert werden.
                      Oder bring ich da was durcheinander?
                      Edit:
                      web hat auch
                          "iobroker.ws": "2.5.11",
                          "iobroker.socketio": "6.6.1",
                      als npm dependencies eintragen in package.json.
                      Support Repositoryverwaltung.
                      LESEN - gute Forenbeitrage
                      • crunchipC Offline
                        crunchipC Offline
                        @mcm57 sagte in Adapter lässt sich nicht löschen:
                        web hat auch
                        "iobroker.ws": "2.5.11", "iobroker.socketio": "6.6.1",
                        daher bekomm ich wohl auch seit Ewigkeiten socketio nicht mehr deinstalliert und wird mir immer wieder bei einem update angezeigt
                        ist danach verschwunden, nach einem browser refresh steht er allerdings wieder drin
                        I 1 Antwort Letzte Antwort
                          web hat auch
                          I Offline
                          I Offline
                          ichwersonst
                          Guten Morgen alle miteinander,
                          es ist ja doch interessant, dass das Thema bei einigen Experten Fragezeichen aufwirft.
                          Also ich bin darüber mehr oder weniger durch Zufall gestolpert und wenn es so ist, dass andere Adapter verhindern das es nicht gelöscht werden kann, kann ich sehr gut damit leben, da ja ein Grund und kein Fehler dahinter liegt.
                          • mcm1957M mcm1957
                            @foxriver76
                            @apollon77
                            Edit:
                            web hat auch
                            apollon77A Online
                            apollon77A Online
                            @mcm57 ja das ist korrekt weil der web Adapter eine integrierten simple-api Funktionalität hat und die im zweifel parallel zu einem anders versionierten simple-api existiert.
