  4. Parameter begrenzen (oder shedulen) in Modbus
42 Beiträge 5 Kommentatoren 2.2k Aufrufe 2 Beobachtet
  • D Delphinis
    @arteck said in Parameter begrenzen (oder shedulen) in Modbus:
    kannst du in der konsole aufrufen
    C:\ioBroker>iob diag
    iobroker [command]
    Commands:
      iobroker setup                                               Setup ioBroker
      iobroker start [all|<adapter>.<instance>|<adapter>]          Starts the js-controller or a specified adapter instance or all instances of an adapter
      iobroker stop [<adapter>.<instance>|<adapter>]               stops the js-controller or a specified adapter instance or all instances of an adapter
      iobroker restart [<adapter>.<instance>|<adapter>]            Restarts js-controller or a specified adapter instance or all instances of an adapter  [aliases: r]
      iobroker debug <adapter>[.<instance>]                        Starts a Node.js debugging session for the adapter instance
      iobroker info                                                Shows the host info
      iobroker logs [<adapter>]                                    Monitor log
      iobroker add <adapter> [desiredNumber]                       Add instance of adapter  [aliases: a]
      iobroker install <adapter>                                   Installs a specified adapter  [aliases: i]
      iobroker rebuild [<module>]                                  Rebuild all native modules or path
      iobroker url <url> [<name>]                                  Install adapter from specified url, e.g. GitHub
      iobroker del <adapter>                                       Remove adapter and all instances from this host  [aliases: delete]
      iobroker del <adapter>.<instance>                            Remove adapter instance  [aliases: delete]
      iobroker update [<repositoryUrl>]                            Update repository and list adapters
      iobroker upgrade                                             Upgrade management
      iobroker upload [all|<adapter>]                              Upload management  [aliases: u]
      iobroker object                                              Object management  [aliases: o]
      iobroker state                                               State management  [aliases: s]
      iobroker message <adapter>[.instance] <command> [<message>]  Send message to adapter instance/s
      iobroker list <type> [<filter>]                              List all entries, like objects
      iobroker chmod <mode> <file>                                 Change file rights
      iobroker chown <user> <group> <file>                         Change file ownership
      iobroker touch <file>                                        Touch file
      iobroker rm <file>                                           Remove file
      iobroker file                                                File management
      iobroker user                                                User commands
      iobroker group                                               group management
      iobroker host <hostname>                                     Set host to given hostname
      iobroker set <adapter>.<instance>                            Change settings of adapter config
      iobroker license <license.file or license.text>              Update license by given file
      iobroker cert                                                Certificate management
      iobroker clean <yes>                                         Clears all objects and states
      iobroker backup                                              Create backup
      iobroker restore <backup name or path>                       Restore a specified backup
      iobroker validate <backup name or path>                      Validate a specified backup
      iobroker status [all|<adapter>.<instance>]                   Status of ioBroker or adapter instance  [aliases: isrun]
      iobroker repo [<name>]                                       Show repo information
      iobroker uuid                                                Show uuid of the installation  [aliases: id]
      iobroker unsetup                                             Reset license, installation secret and language
      iobroker fix                                                 Execute the installation fixer script, this updates your ioBroker installation
      iobroker nodejs-update [<major-version>]                     Upgrade the Node.JS installation to the current LTS
      iobroker multihost                                           Multihost management
      iobroker compact                                             compact group management
      iobroker plugin                                              Plugin management
      iobroker vendor <passphrase> [<vendor.json>]                 Update the vendor information using given passphrase
      iobroker version [<adapter>]                                 Show version of js-controller or specified adapter  [aliases: v]
    arteckA Offline
    arteckA Offline
    arteck
    @delphinis ja auf windows gehts nich
    machmal
    iobroker info
    • arteckA arteck
      @delphinis die ip adresse passt da nicht
      check deine Einstellungen
      und
      iob diag
      Delphinis
      Muss da nicht die IP des WR rein?
      Ping auf diese Adresse geht.
      • D Delphinis
        arteckA Offline
        arteckA Offline
        arteck
        @delphinis ja da muss die WR ip rein
        hier steht aber was anderes
        und firewall regel checken.. nicht das die dir was blockieren
        • arteckA arteck
          Delphinis
          schrieb am zuletzt editiert von Delphinis
          @arteck Ach so, mein Fehler, hab inzwischen eine neue Instanz von Modbus gemacht, um auf der frischen Wiese anzfangen und da war diese noch falsch.
          • D Delphinis
            arteckA Offline
            arteckA Offline
            arteck
            @delphinis mach den noch rein
            und lass vorerst nur EINE instanz auf den WR
            • arteckA arteck
              Delphinis
              mach den noch rein
              Hab ich gemacht. Leider keine Änderung. Auch im Log die selben Meldungen.
              Mach ich schon
              Firewall hab ich alles abgeschalet, was ich in den Einstellungen gefunden hab (Win 11)
              • D Delphinis
                mach den noch rein
                Mach ich schon
                arteckA Offline
                arteckA Offline
                arteck
                @delphinis dann starte den WR mal neu
                • arteckA arteck
                  Delphinis
                  @arteck
                  Mach ich dann abends, mal. Jetzt ist der voll am Regeln und ich will gerade kein Stromausfall
                  Aber ich hab schon den Modbus im WR deaktiviert und wieder aktiviert, damit konnte ich schon mal das Problem beheben.
                  Hat aber heute nichts gebracht...
                  Aber was mir noch aufgefallen ist:
                  Die neue Instanz von Modbus hat eine neue Kollonne namens Slave-ID (zweite von links):
                  Ach so ist das wegen "Mehrere Geräte ID's"?
                  • D Delphinis
                    @arteck
                    arteckA Offline
                    arteckA Offline
                    arteck
                    @delphinis da muss eine 3 rein
                    ist standard im wR hinterlegt... und wiso solltest du Stromausfall haben wenn der WR neu gestartet wird..
                    • arteckA arteck
                      Delphinis
                      @arteck
                      Da ist mein Hausnetz dran
                      Ich weiss ehrlich gesagt auch gerade nicht wie man den neu startet.
                      • D Delphinis
                        @arteck
                        arteckA Offline
                        arteckA Offline
                        arteck
                        @delphinis sagte in Parameter begrenzen (oder shedulen) in Modbus:
                        hä........
                        auf der linken Seite ist ein Schalter
                        ich will dir nicht zu nahe tretten ..aber Grundkentnisse solltest du schon haben wenn du mit Modbus rumhantieren willst
                        D W 2 Antworten Letzte Antwort
                          Delphinis
                          @arteck
                          Ist das ein Missverständnis wegen der Abkürzung? Ich meine WR = Wechselrichter
                          • arteckA arteck
                            hä........
                            Delphinis
                            Der schaltet nur die PV weg.
                              Delphinis
                              So,
                              hab jetzt den WR geresettet,
                              die Verbindung zum Modbus läuft jetzt wieder....
                              • arteckA arteck
                                hä........
                                W Offline
                                W Offline
                                warp735
                                @arteck sagte in Parameter begrenzen (oder shedulen) in Modbus:
                                hä........
                                scheint für dich ein Unding zu sein? Bei uns hängt auch das komplette Haus am WR. Hat den Vorteil, bei Stromausfall wird in 4ms auf Backup umgeschaltet und keiner bekommt den Stromausfall mit.
                                Nachteil: fahr ich den WR runter, ist die Bude dunkel ;)
                                • W warp735
                                  hä........
                                  Delphinis
                                  @warp735
                                  Leider hat der modbus nach Neustart des PC's wieder nicht mehr funktioniert.
                                  Eventuell hab ich das Problem aber jetzt gefunden. Ich hab die Option "Modbus P-Vorgaben auf Eingang 2" rausgenommen. Ich weiss zwar nicht was das ist, aber Modbus geht jetzt und das sunnyportal liefert auch seine Werte immer noch.
                                  In der Beschreibung steht:
                                  "Wirkleistungsvorgaben über Modbus werden auf Sollwerteingang 2 verarbeitet. Dadurch ist der Parallelbetrieb mit SMA Anlagensteuerung möglich."
                                  Hab ich wohl nicht...
                                  Aber ich bin immer noch unsicher, weil ich nicht genau weiss was das ist und auch im INet nichts genaueres darüber erfahren habe.
                                  Ich weiss nicht, ob das was mit der Begrenzung der Wirkleistung tun hat, was bei mir aber nicht notwendig ist.
                                  Sonst ist das Verhalten von WR, Solar und Batt normal.
                                  Ob das ganze anhält, werde ich morgen sehen, wenn ich den PC wieder über Nacht runterfahre. (Hab den iobroker im Moment nur zum testen/konfigurieren am Windows PC, den ich Nachts natürlich runter fahre. Ich werds auch gleich jetzt zum Test nochmals tun, um zu schauen, ob es mit dem Runter Fahren des iobrokers zu tun hat.
                                  So, hab jetzt den PC neu gestartet und der Modbus läuft jetzt immer noch/wieder.
                                  • D Delphinis
                                    @warp735
                                    Delphinis
                                    Nach ein paar Stunden ist der Modbus wieder ausgefallen, das war also noch nicht die Lösung.
                                    Mir ist aufgefallen, dass der PC in den Standby gegangen ist. Könnte das das Problem sein, dass der Modbus sich aufhängt?
                                    • D Delphinis
                                      wendy2702W Offline
                                      wendy2702W Offline
                                      @delphinis Welcher PC geht in den Standby? Der auf dem iobroker läuft bzw. die Modbus Instanz läuft?
                                      • wendy2702W wendy2702
                                        Delphinis
                                        @wendy2702
                                        Der auf dem iobroker läuft, das andere ist der Wechselrichter, der läuft immer.
                                        Ich hab den auf dem PC, weil da die Konfiguration einfacher ist und kopier das dann auf den Rechner wo es dann fortlaufend laufen soll.
                                        Ich schalte das Standby mal ab. Aber im Moment läuft es wieder nicht. Muss wohl wieder den WR reseten (vom Strom trennen). Aber das ist nicht so toll wenn alle im Haushalt Strom/Internet wollen :-)
                                        Und das kann ja nicht die Lösung sein...
                                        • D Delphinis
                                          @wendy2702
                                          wendy2702W Offline
                                          wendy2702W Offline
                                          Sorry, kann dir gerade nicht folgen.
                                          Was kopierst du von wo nach wo?
                                          Und nochmal, geht der Rechner auf dem IOB und damit die Modbus Instanz läuft in den Standby?
                                          Also wenn es so ist das der Windows Rechner auf dem IOB läuft in Standby geht kann es durchaus den Effekt haben das nach "aufwecken" des Rechner die Instanz keine Verbundung mehr herstellen kann.
                                          Einen "Server" was IOB eigentlich ist bzw. erfordert, lässt man 24/7 laufen damit solche Effekte eben nicht auftreten.
