  4. [Problem] Harmony stürzt regelmäßig ab
55 Beiträge 17 Kommentatoren 12.6k Aufrufe
  • N Offline
    N Offline
    Nabla
    Also an der Fritzbox geht es gar nicht richtig. Da scheint das wlan wirklich gestört zu sein, da funktioniert selbst Alexa nicht mehr korrekt
    mit dem Harmony Hub. Die Fritzbox steht auch rund 15 Meter und zwei Räume entfernt.
    harmony.0	2017-10-12 22:18:10.501	warn	could not connect to Harmony Hub 2: Error: Timed out after 5000 ms
    harmony.0	2017-10-12 22:18:03.491	info	connecting to Harmony Hub 2
    harmony.0	2017-10-12 22:18:03.444	info	discovered Harmony Hub 2
    harmony.0	2017-10-12 22:17:13.782	warn	lost Harmony Hub 2
    harmony.0	2017-10-12 22:16:59.400	warn	could not connect to Harmony Hub 2: Error: Timed out after 5000 ms
    harmony.0	2017-10-12 22:16:52.396	info	connecting to Harmony Hub 2
    harmony.0	2017-10-12 22:16:52.356	info	discovered Harmony Hub 2
    harmony.0	2017-10-12 22:16:08.766	warn	lost Harmony Hub 2
    harmony.0	2017-10-12 22:15:58.477	warn	could not connect to Harmony Hub 2: Error: Timed out after 5000 ms
    harmony.0	2017-10-12 22:15:51.472	info	connecting to Harmony Hub 2
    harmony.0	2017-10-12 22:15:51.428	info	discovered Harmony Hub 2
    harmony.0	2017-10-12 22:15:48.760	warn	lost Harmony Hub 2
    harmony.0	2017-10-12 22:15:22.542	warn	could not connect to Harmony Hub 2: Error: Timed out after 5000 ms
    harmony.0	2017-10-12 22:15:15.535	info	connecting to Harmony Hub 2
    harmony.0	2017-10-12 22:15:15.488	info	discovered Harmony Hub 2
    harmony.0	2017-10-12 22:15:11.510	warn	error changing activity, client offline
    harmony.0	2017-10-12 22:15:11.495	warn	error changing activity, client offline
    harmony.0	2017-10-12 22:15:08.755	warn	lost Harmony Hub 2
    harmony.0	2017-10-12 22:15:05.501	warn	could not connect to Harmony Hub 2: Error: Timed out after 5000 ms
    harmony.0	2017-10-12 22:14:58.495	info	connecting to Harmony Hub 2
    harmony.0	2017-10-12 22:14:58.466	info	discovered Harmony Hub 2
    Ich werde wieder auf die Powerlan WLAN-Spots switchen, da diese dichter dran sind. Leider wird das 5Ghz Netz nicht unterstützt, das wäre
    noch mal eine Alternative gewesen.
    • wendy2702W Offline
      wendy2702W Offline
      Ui,
      15m mit Wänden dazwischen ist auch schon eine Hausnummer.
      Du hast nicht zufällig zum testen ein langes Kabel und einen Repeater den du mal als Access Point näher an den Hub bringen könntest?
        @Nabla:
        neben einem Devolo 1200+ Adapter. `
        Power-LAN taugt da IMHO gar nicht.
        @Nabla:
        Die Fritzbox steht auch rund 15 Meter und zwei Räume entfernt. `
        ich habe damals einen AP in direkter Sichtlinie 5 Meter von dem Harmony-Hub installieren müssen, damit es problemlos funktioniert.
        Die WLAN anbindung des Hubs ist grottenschlecht.
        • eric2905E Offline
          eric2905E Offline
          eric2905
          Ich habe per DLAN die ganze Verteilung im Haus und keine Probleme damit.
          Allerdings habe ich jeweils einen UniFi-Switch am DLAN-Modul und dann dahinter die Endgeräte und/oder die UniFi-APs.
          Gruß,
          Eric
          Von unterwegs getippert
          • N Offline
            N Offline
            Nabla
            Nach einem Neustart des Hub ist es wieder besser. Ich betreibe ihn nun weiterhin am Devolo DLAN-Adapter.
            Hatte jetzt nach 48h Stunden nur einen Reconnect. Vielleicht muss ich den Hub Abends mit vom Strom nehmen und
            morgens neu starten.
              wendy2702W Offline
              Gerade mal meine Logfiles der letzten 5 Tage durchsucht.
              Es gab einen restart bzw. reconnect weil ich am HUB gefummelt habe. Sonst scheint der Adapter bei mir gut zu laufen.
              Habe noch Version 0.7.0 installiert.
              Abstand Fritz AP <-> HUB ca. 2,50m
                andyb
                Nachdem ich grad aktuell Probleme hatte und eh am Rechner sitze….
                IOBroker findet den Hub nicht, aber an der Wlan Verbindung kann es nicht liegen, ich kann ihn anpingen.
                Adapter stoppen usw. brachte keine Besserung. Einschalten mit der Fernbedienung ging und danach hat ihn auch IOBroker wieder gefunden.
                  mike281176
                  Hallo ich habe mir bei den cyber Woche den Harmony Hub gekauft und eingerichtet
                  über Handy kann ich meinen Fernseher und andere Geräte bedienen
                  in iobrocker unter Objekte sind meine Geräte die ich eingerichtet habe auch gefunden wenn ich bei Objekte auf simulierten tasten klicke passiert leider nix
                  deinstallieren und neu installieren keine Änderung
                  sorry habe keinen plan mehr was ich noch versuchen soll
                  System Pi3 Jessi
                  wer rechtschreibfehler findet darf sie behalten und bei ebay versteigern
                    mike281176
                    Hallo habe noch etwas weiter probier
                    wenn ich über den Adapter cloud gehe dort zb Samsung power on über Harmony aufrufe und in der Alexa app aktualisiere dann kann ich es über alexa ansprechen.
                    wenn ich eine Szene erstell mit einer reihe von befehle alle über Harmony sie anschließend in dem Adapter cloud und Alexa dem entsprecht Aktivieren geht es nicht :?: :?: :?:
                    • uweklattU Offline
                      uweklattU Offline
                      uweklatt
                      Ich habe den gleichen Effekt:
                      Die Harmony-Tasten werden alle als Objekte eingelesen und reagieren aber nicht auf "Tastendruck".
                      Habe Harmony-Adapter 0.7.1 installiert. Die aktuelle Activity wird korrekt als Objekt angezeigt.
                      Tschau
                      Uwe
                      Intel i5/Proxmox/LXC/Docker/ioBroker
                        @uweklatt:
                        Die Harmony-Tasten werden alle als Objekte eingelesen und reagieren aber nicht auf "Tastendruck". `
                        Wie meinen?
                        Die Objekte reagieren nicht auf den Tastendruck auf der Harmony-FB. Diese Information liefert der HUB nicht.
                        Aber eine Änderung des Werts dieses Objekts durch ioBroker sollte über den Hub an das Gerät gesendet werden.
                        • uweklattU Offline
                          uweklattU Offline
                          uweklatt
                          Hallo Rainer,
                          wenn ich z.B. unter "Objekte" den Button "VolumeDown" eines Gerätes drücke, sendet der Hub nichts…
                          Ich habe nun die "Rolle" von "button" (so wird es automatisch eingerichtet) auf "value" geändert. Dann funktioniert auch das Senden, wenn man dort einen Wert einträgt!
                          Warum wird beim Einrichten des Adapters als Rolle "button" verwendet, wenn das nicht sauber funktioniert?
                          Tschau
                          Uwe
                          • DutchmanD Offline
                            DutchmanD Offline
                            Dutchman
                            @uweklatt:
                            Tschau
                            Uwe `
                            Komisch bei mir geht das Standard
                            Send from mobile device
                            • uweklattU Offline
                              uweklattU Offline
                              uweklatt
                              Hallo Dutchman, > Komisch bei mir geht das Standard
                              Wie testest Du das?
                              Manuell mit dem Button unter "Objekte" oder in einem Script, das den "val" setzt?
                              Ersteres geht bei mir nicht.
                              Es geht um diese Buttons:
                              Tschau
                              Uwe
                              • DutchmanD Offline
                                DutchmanD Offline
                                Dutchman
                                Ich drücke einfach unter den Reiter objecte ;)
                                  Ducky
                                  noch mal ein Tipp von meiner Seite:
                                  Ich hatte auch mit regemäßigen Abstürzen des Adapters und der Warnmeldung "Hub lost" zu kämpfen.
                                  Das Logfile war voll davon.
                                  Weiter oben gab es den Hinweis die Fritzbox auf Auto-Kanal zu stellen um WLAN Störungen zu minimieren.
                                  Das habe ich gemacht und - schlagartig war Schluß mit den Meldungen im Log.
                                  Danke an wendy2702
                                  Liebe Grüße
                                  Ducky
                                  • R Offline
                                    renedivx
                                    ich habe seit Freitag problem mit Harmony und dem Adapter. Ich habe am Freitag den Hub und die Fernbedienung geupdatet. Danch fingen die Probleme an. Vorher hatte es wirklich super funktioniert.
                                    Und zwar hat seit dem Update die Alex Steuerung nur noch sporadisch funktioniert. Seit dem habe ich wirklich alles möglich probiert das wieder vernünftig ans laufen zu bekommen. Hab den Hub und die FB sogar auf Werkseinstellung zuzrück gesetzt, den Adapter in ioBroker gelöscht und neu installiert und jetzt zum Schluss die Firmware beim Hub und der FB wieder auf die vorherige Version downgegradet. Aber das Problem bleibt bestehen.
                                    Mir sind jetzt einige Dinge aufgefallen bei der Fehlersuche. Wenn ich den Adapter in ioBroker neustarte funktioniert es, aber nur kurz. Nach ein paar minuten wieder keine Reaktion. Es bleibt dann der Wert indicator.hubBlocked auf True stehen obwohl der Hub nicht genutzt wird und nichts ausführt. Ab diesem Moment geht nichts mehr und es hilft nur den Adapter in ioBroker neuzustarten. Dann funktioniert es wieder kurz aber auch nicht immer.
                                    Im ioBroker Log werden mir hier keine speziellen Fehler angezeigt außer Hub busy.
                                    Ich habe auch bereits inder Fritzbox den Tipp mit Autokanal probiert, aber leider vergebens.
                                    Über die Fernbedinung direkt lassen sich alle Aktionen problemlos starten und beenden. Nur über iobroker nicht mehr. Hänge jetzt schon fast das Ganze Wochenende dran und bekomme es einfach nicht mehr hin wie vorher.
                                    Hatte hier jemand noch eine Idee oder einen Tipp?
                                    Vielen Dank
                                    LG Rene
                                      @renedivx:
                                      Über die Fernbedinung direkt lassen sich alle Aktionen problemlos starten und beenden. `
                                      Das geht ja auch über Funk und nicht über WLAN.
                                      interessant wäre es ob die Harmony App vom Tablet/Handy noch funktioniert.
                                      • R Offline
                                        renedivx
                                        @Homoran:
                                        @renedivx:
                                        Rainer `
                                        Hi Rainer,
                                        danke für die schnelle Reaktion. Ja über die App funktioniert es auch. Auch kann ich den Hub anpingen im Netzwerk.
                                        LG Rene
                                          wendy2702W Offline
                                          Debug Logfile vom Adapter?
                                          Ist der Hub auch per Ping erreichbar wenn das Problem auftritt?
                                          Wie groß ist der Abstand Fritzbox - Hub?
                                          Eventuelle Verbindungsprobleme über WLAN können auch durch Störungen von außen verursacht werden.
                                          Wenn du schreibst es funktioniert immer nur kurz scheint der Fehler reproduzierbar zu sein. Da würde sich ein Paket Mitschnitt auf der Fritzbox anbieten um zu sehen ob a) iobroker nichts mehr an den Hub sendet oder b) der Hub nicht mehr antwortet.
