  4. Vis2 ab 09.01.2024 im stable
422 Beiträge 79 Kommentatoren 167.5k Aufrufe 85 Beobachtet
  • wendy2702W wendy2702
    Gerade mal VIS 2 neu installiert. Lizenz hatte ich schon.
    VIS 2 Editor und VIS1 Editor nur noch weisse Seite im Browser. Auch nach löschen sämtlicher Browserdaten (Chrome und FF)
    Nach dem löschen geht wenigstens von VIS1 die Runtime wieder.
    Habe 2 Projekte aktiv.
    Nach installation von VIS2 kommt beim VIS1 Editor Aufruf das in der Konsole für mein Main Projekt:
    Uncaught SyntaxError: Unexpected non-whitespace character after JSON at position 5 (line 1 column 6)
        at JSON.parse (<anonymous>)
        at Object.unserialize (loStorage.js:2:567)
        at r.get (loStorage.js:2:1871)
        at Function.get (loStorage.js:2:2346)
        at Object.bindInstance (vis.js:576:54)
        at Object.initNext (vis.js:705:14)
        at Object.<anonymous> (vis.js:603:18)
        at Object.loadWidgetSets (vis.js:568:34)
        at Object.init (vis.js:602:14)
        at vis.js:3661:29
    Und das für mein Second:
        at vis.js:3694:29
    Im Vis 2 Editor kommt das in der Konsole:
    visEngine.jsx:1549 Someone installs handler without to remove it!
    Mt.registerChangeHandler @ visEngine.jsx:1549
    Ct @ visCanWidget.jsx:93
    Wo @ react-dom.production.min.js:147
    Ls @ react-dom.production.min.js:198
    yi @ react-dom.production.min.js:292
    xl @ react-dom.production.min.js:280
    zl @ react-dom.production.min.js:280
    gl @ react-dom.production.min.js:280
    rl @ react-dom.production.min.js:271
    ll @ react-dom.production.min.js:273
    Na @ react-dom.production.min.js:127
    (anonym) @ react-dom.production.min.js:283
    Vl @ react-dom.production.min.js:281
    ol @ react-dom.production.min.js:270
    V @ scheduler.production.min.js:13
    T @ scheduler.production.min.js:14
    14 weitere Frames anzeigen
    Weniger anzeigen
    react-dom.production.min.js:189 TypeError: Cannot add property g00002, object is not extensible
        at d (visUtils.jsx:386:37)
        at Ct.setupSubscriptions (visCanWidget.jsx:114:9)
        at new Ct (visCanWidget.jsx:91:14)
        at Wo (react-dom.production.min.js:147:172)
        at Ls (react-dom.production.min.js:198:97)
        at yi (react-dom.production.min.js:292:172)
        at xl (react-dom.production.min.js:280:389)
        at zl (react-dom.production.min.js:280:320)
        at gl (react-dom.production.min.js:280:180)
        at rl (react-dom.production.min.js:271:88)
    us @ react-dom.production.min.js:189
    c.callback @ react-dom.production.min.js:189
    Po @ react-dom.production.min.js:144
    Hi @ react-dom.production.min.js:262
    xi @ react-dom.production.min.js:260
    Mi @ react-dom.production.min.js:259
    15 weitere Frames anzeigen
    Weniger anzeigen
        at new c (visRxWidget.tsx:173:9)
        at new x (BasicHtml.jsx:23:1)
    Weniger anzeigen
    Weniger anzeigen
    4react-dom.production.min.js:189 TypeError: Cannot add property g00002, object is not extensible
    Was Möglicherweise auf ein Problem einer Widget Gruppe hindeutet.
    Wie bekomme ich am einfachsten mein VIS1 wieder vernünftig zum laufen?
    EDIT: Nach löschen VIS 2 Instanz, Adapter und Browser Daten geht VIS1 Editor wieder.
    foxriver76F Offline
    foxriver76F Offline
    foxriver76
    #124
    @wendy2702 mit der vis 2 Fehlermeldung ein issue wäre cool, glaube das lässt sich fixen
    Videotutorials & mehr
    • wendy2702W Online
      wendy2702W Online
      #125
      @foxriver76 sagte in Vis2 ab morgen im stable:
      Erledigt: https://github.com/ioBroker/ioBroker.vis-2/issues/322
        foxriver76F Offline
        foxriver76F Offline
        foxriver76
        #126
        @wendy2702 danke dir
        • LongbowL Offline
          LongbowL Offline
          Longbow
          #127
          Kann mir einer bitte behilflich sein, warum seit ich Vis 2 installiert habe, Jave spinnt?
          Das ist immer der gleiche Fehlercode, nur dass sich der Scriptname in der Fehlermeldung verändert.
          Vom Zeitstempel passt es, dass mit dem zusammen hängen muss.
          Ich habe auch wie @MK-66 es beschrieben gemacht, was das mit dem Adpater Web trifft.
          An was kann es nun liegen, das keine Scrpite mehr gehen?
          javascript.0
          16133	2024-01-19 07:29:37.357	error	at processImmediate (node:internal/timers:478:21)
          javascript.0
          16133	2024-01-19 07:29:37.357	error	at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.javascript/main.js:1636:17)
          javascript.0
          16133	2024-01-19 07:29:37.357	error	at /opt/iobroker/node_modules/iobroker.javascript/main.js:2161:17
          javascript.0
          16133	2024-01-19 07:29:37.357	error	at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:2063:37)
          javascript.0
          16133	2024-01-19 07:29:37.357	error	at createVM (/opt/iobroker/node_modules/iobroker.javascript/main.js:1810:21)
          javascript.0
          16133	2024-01-19 07:29:37.357	error	at new Script (node:vm:94:7
          javascript.0
          16133	2024-01-19 07:29:37.357	error	SyntaxError: Unexpected token '='
          javascript.0
          16133	2024-01-19 07:29:37.357	error	^
          javascript.0
          16133	2024-01-19 07:29:37.356	error	var = {};
          javascript.0
          16133	2024-01-19 07:29:37.356	error	script.js.Solar.Skript_1 compile failed: at script.js.Solar.Skript_1:2
          • E e-i-k-e
            Abend,
            ich habe seit längerem probleme das sich Werte nicht eigenständig aktuallisieren, sondern das nur "Null" angezeigt wird. Sobald ich zwischen zwei Views hin und her Wechsel, wird der Wert aktuallisiert.
            Jemand eine Idee?
            Sind vis-inventwo widgets.
            skvarelS Offline
            skvarelS Offline
            skvarel
            #128
            @e-i-k-e sagte in Vis2 ab morgen im stable:
            Abend,
            Jemand eine Idee?
            ... vis-inventwo wird auch nie VIS2 kompatibel werden. Das ist einfach nicht machbar, weil sich der ganze VIS2 Adapter zu sehr verändert hat.
            Jannis hat gestern entschieden, einen inventwo Adapter für VIS2 zu programmieren. Das Grundgerüst steht bereits und es geht langsam los!
            An dieser Stelle, vielen Dank an @Bluefox für die Unterstützung :)
            #TeamInventwo
            Unsere Adapter:
            jogibear9988J E 2 Antworten Letzte Antwort
            • skvarelS skvarel
              Abend,
              Jemand eine Idee?
              jogibear9988J Offline
              jogibear9988
              #129
              @skvarel said in Vis2 ab morgen im stable:
              Abend,
              Jemand eine Idee?
              Vlt könnten diese ja als Webcomponenten entwickelt werden (und für vis2 dann gewrappt (wenn das nötig ist), dann könnte man Sie an mehr stellen verwenden.
              Weiß denn jemand in wie weit webcomponenten in vis2 bzw. react unterstützt werden? Was da mgl. wäre?
              Check my ioBroker webui - a vis alternative
              see: https://github.com/iobroker-community-adapters/ioBroker.webui
              • foxriver76F foxriver76
                wendy2702W Online
                wendy2702W Online
                #130
                @foxriver76 Kannst du sagen wann die Version mit deinen Korrekturen zur Installation zur Verfügung steht?
                  foxriver76F Offline
                  foxriver76F Offline
                  foxriver76
                  #131
                  @wendy2702 2.9.21
                  • skvarelS skvarel
                    Abend,
                    Jemand eine Idee?
                    e-i-k-e
                    #132
                    @skvarel sagte in Vis2 ab morgen im stable:
                    Abend,
                    Jemand eine Idee?
                    Das klingt sehr gut, vielen Dank!
                    Bedeutet aber auch, dass ich meine vis welche mit vis-inventwo Version "vis1" erstellt worden sind, neu aufbauen muss?
                    skvarelS 1 Antwort Letzte Antwort
                      @wendy2702 2.9.21
                      wendy2702W Online
                      wendy2702W Online
                      #133
                      @foxriver76 Ab wann sollte die denn im Latest oder stable sein?
                      Aktuell noch immer die alte sichtbar:
                        FeuersturmF Offline
                        FeuersturmF Offline
                        Feuersturm
                        #134
                        @wendy2702 Ich hab gerade die 2.9.21 über den Admin installiert. Hast du mal auf das Icon "Adapter auf updates prüfen" geklickt?
                        Alternativ mal auf der Konsole folgendes ausführen, dann sollte dir die neue Version auf jeden Fall angeboten werden
                        iob update
                        • FeuersturmF Feuersturm
                          iob update
                          wendy2702W Online
                          wendy2702W Online
                          #135
                          @feuersturm Das war es. Spannend das ich es manuell anstoßen musste.
                            mcm1957M Online
                            mcm1957M Online
                            mcm1957
                            #136
                            @wendy2702
                            Die Repositories werden 2x täglich ab ca 2:00 und 14:00 aktualisiert. Ab deswegen, da dieser Scan / Updat einige Stunden dauert.
                            Die json Dateien der Repositories in denen Admin / js-controller nachsieht ob es was Neues gibt werden von deinem System per Default 1x täglich aktualisisert. Wenn du den aktualisieren Button drückst wird jedenfalls versucht die aktuellsten jsons downzuloaden.
                            Es kann daher bis zu 12 bis 15h nach Veröffentlichung dauern bis eine neue Release prinzipiell im Repository verfügbar ist. Und es kann danach noch bis zu einem Tage dauern bis die Info auf deinem System landet (bei Defaukteinstellung und ohne manuelles Prüfen).
                            Ein Update in Stable erfolgt über Aufforderung des Devs, außer in Notfällen allerdings frühestens ca. 7 Tage nach Veröffentlichung im Latest Repository.
                            Hoffe dies erklärt das Verhalten ein wenig.
                            mcm1957
                            Support Repositoryverwaltung.
                            LESEN - gute Forenbeitrage
                            • E e-i-k-e
                              Abend,
                              Jemand eine Idee?
                              skvarelS Offline
                              skvarelS Offline
                              skvarel
                              #137
                              Abend,
                              Jemand eine Idee?
                              ... das ist noch nicht ganz klar. Ich befürchte aber, ja. Es wird (bzw. es muss) ein komplett neuer inventwo Adapter werden.
                              #TeamInventwo
                              Unsere Adapter:
                              • skvarelS skvarel
                                Abend,
                                Jemand eine Idee?
                                ChaotC Offline
                                ChaotC Offline
                                Chaot
                                #138
                                @skvarel Danke. Das habe ich auch schon fast befürchtet.
                                Aber nachdem ich meine VIS 1 fast vollständig mit Inventwo Widgets aufgebaut habe möchte ich ungern zu anderen Widgets wechseln. Deine Teile funktionieren einfach genial.
                                Hast du mal darüber nachgedacht ob es eventuell möglich wäre ein Konvertierungstool für die Widgets zu bauen?
                                Mir ist klar, dass zuerst die neuen Widgets stehen müssen, aber vielleicht stellt sich ja dann heraus, dass es nur ein paar kleine Änderungen sind die man manuell anpassen müsste.
                                Ich erkläre mal was ich meine:
                                Meine Widgets sind zu großen Teilen Kopien eines einzelnen Widgets. Das habe ich erstellt für beispielsweise einen Schalter. Dann kopiere ich das und mache daraus 15 Schalter die auf der VIS zu sehen sind.
                                Ich müsste also beim Konvertieren nur eine handvoll Widgets tatsächlich neu erstellen (konvertieren) und die dann wie gewohnt kopieren. Dann wäre eine neue VIS 2 recht schnell wieder erstellt.
                                  mojo1986
                                  #139
                                  Hallo Zusammen
                                  Ich habe eine einfache Frage nehm ich an. Ich habs aber nicht herausgefunden.
                                  Wie stelle ich in einem HTML Widget in der vis 2 den Namen (common Name) von einem Alias Datenpunkt dar also in diesem Fall "Hue_Motion_Abstellraum_battery"?
                                  Das ist der Datenpunkt:
                                    "common": {
                                      "name": "Hue_Motion_Abstellraum_battery",
                                      "desc": "Manuell erzeugt",
                                      "role": "state",
                                      "type": "number",
                                      "read": true,
                                      "write": true,
                                      "def": 0,
                                      "unit": "%",
                                      "alias": {
                                        "id": "hue.0.Hue_Bridge.Hue_motion_Abstellraum.battery"
                                    "type": "state",
                                    "native": {},
                                    "_id": "alias.0.Batterien.Abstellraum.Hue_Motion_Abstellraum_battery",
                                    "acl": {
                                      "object": 1636,
                                      "state": 1636,
                                      "owner": "system.user.admin",
                                    "from": "system.adapter.cloud.0",
                                    "user": "system.user.admin",
                                    "ts": 1705496582357
                                  • M mojo1986
                                    Hallo Zusammen
                                      "common": {
                                        "role": "state",
                                        "type": "number",
                                        "read": true,
                                        "write": true,
                                        "def": 0,
                                        "unit": "%",
                                        "alias": {
                                      "type": "state",
                                      "native": {},
                                      "acl": {
                                        "object": 1636,
                                        "state": 1636,
                                      "ts": 1705496582357
                                    HomoranH Offline
                                    HomoranH Offline
                                    #140
                                    @mojo1986 sagte in Name von Alias:
                                    Ich hab jetzt ein paar mehr an dich.
                                    Du befindest dich im Unterforum "Einbindung von Geräten
                                    ich nehme an dass du Hue bereits eingebunden hast, oder?
                                    Laut Titel geht es um Aliasnamen.
                                    und gemäß Text geht es um HTML und vis2
                                    Ich hab jetzt das Problem, dass ich nicht weiß was ich mit dem Thread machen soll
                                      mojo1986
                                      #141
                                      @homoran Ups Sorry ja das ist natürlich am falschen Ort. Grundsätzlich geht es darum, dass ich den Namen von einem Alias Datenpunkt in einem Widget Anzeigen möchte in der Vis2. Hilft das weiter?
                                      • M mojo1986
                                        HomoranH Offline
                                        HomoranH Offline
                                        #142
                                        @mojo1986 ich hab das mal in den vis2 Thread geschoben.
                                        Ich denke hier kann msn dir besser helfen
                                        • wendy2702W Online
                                          wendy2702W Online
                                          #143
                                          habe gerade mal VIS-2 erneut installiert Version 2.9.21
                                          Bei mir ist der Editor nicht bedienbar, heisst Chrome "friert" gefühlt ein. Oft kommt das Fenster das die Seite nicht reagiert mit der Frage "Warten oder Schließen".
                                          Jetzt gerade reagiert die Seite überhaupt nicht mehr und Chrome reagiert nichtmal mehr auf "Forced Reload".
                                          ioBroker läuft auf einer VM auf Proxmox.
                                          Hier mal das diag in dem ich nur ein paar NPM Tree error als auffällig sehe mit ein 1 1/2 Auge.
                                          Skript v.2023-10-10
                                          *** BASE SYSTEM ***
                                          Static hostname: iobroker
                                                Icon name: computer-container
                                                  Chassis: container ☐
                                           Virtualization: lxc
                                                   Kernel: Linux 6.2.16-19-pve
                                             Architecture: x86-64
                                          model name      : Intel(R) Pentium(R) Silver J5040 CPU @ 2.00GHz
                                          Docker          : false
                                          Virtualization  : lxc
                                          Kernel          : x86_64
                                          Userland        : amd64
                                          Systemuptime and Load:
                                          13:39:56 up 67 days, 22:28,  2 users,  load average: 4.58, 5.57, 6.66
                                          CPU threads: 4
                                          *** Time and Time Zones ***
                                                        Local time: Mon 2024-01-22 13:39:57 CET
                                                    Universal time: Mon 2024-01-22 12:39:57 UTC
                                                          RTC time: n/a
                                                       NTP service: inactive
                                                   RTC in local TZ: no
                                          *** User and Groups ***
                                          mirko
                                          /home/mirko
                                          mirko sudo iobroker
                                          *** X-Server-Setup ***
                                          X-Server:       false
                                          Desktop:
                                          Terminal:       tty
                                          *** MEMORY ***
                                          Mem:             17G        8.2G        8.9G        102K         89M        9.0G
                                          Swap:             0B          0B          0B
                                          Total:           17G        8.2G        8.9G
                                                 16384 M total memory
                                                  7782 M used memory
                                                    56 M active memory
                                                  7461 M inactive memory
                                                  8516 M free memory
                                                     0 M buffer memory
                                                    85 M swap cache
                                                     0 M total swap
                                                     0 M used swap
                                                     0 M free swap
                                          *** FAILED SERVICES ***
                                           UNIT                    LOAD   ACTIVE SUB    DESCRIPTION
                                          * sys-kernel-config.mount loaded failed failed Kernel Configuration File System
                                          * sys-kernel-debug.mount  loaded failed failed Kernel Debug File System
                                          2 loaded units listed.
                                          *** FILESYSTEM ***
                                          Filesystem                       Type      Size  Used Avail Use% Mounted on
                                          /dev/mapper/pve-vm--101--disk--0 ext4       30G   12G   16G  43% /
                                          none                             tmpfs     492K  4.0K  488K   1% /dev
                                          udev                             devtmpfs   16G     0   16G   0% /dev/tty
                                          tmpfs                            tmpfs      16G     0   16G   0% /dev/shm
                                          tmpfs                            tmpfs     6.2G   96K  6.2G   1% /run
                                          tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
                                          tmpfs                            tmpfs     3.1G     0  3.1G   0% /run/user/1001
                                          dmesg: read kernel buffer failed: Operation not permitted
                                          TARGET SOURCE                           FSTYPE OPTIONS
                                          /      /dev/mapper/pve-vm--101--disk--0 ext4   rw,relatime,stripe=16
                                          /var:
                                          1.4G    /var/
                                          1.1G    /var/log/journal/c5b67cb2fb4c49678a4fd62f7e4a2b20
                                          1.1G    /var/log
                                          243M    /var/lib
                                          Archived and active journals take up 130.8M in the file system.
                                          /opt/iobroker/backups:
                                          324M    /opt/iobroker/backups/
                                          /opt/iobroker/iobroker-data:
                                          1.2G    /opt/iobroker/iobroker-data/
                                          751M    /opt/iobroker/iobroker-data/files
                                          237M    /opt/iobroker/iobroker-data/backup-objects
                                          177M    /opt/iobroker/iobroker-data/files/vis-2
                                          82M     /opt/iobroker/iobroker-data/files/vis
                                          28M     /opt/iobroker/iobroker-data/objects.jsonl
                                          26M     /opt/iobroker/iobroker-data/objects.json.migrated
                                          26M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
                                          25M     /opt/iobroker/iobroker-data/objects.json.org
                                          24M     /opt/iobroker/iobroker-data/states.jsonl
                                          USB-Devices by-id:
                                          find: '/dev/serial/by-id/': No such file or directory
                                          *** NodeJS-Installation ***
                                          /usr/bin/nodejs         v18.19.0
                                          /usr/bin/node           v18.19.0
                                          /usr/bin/npm            10.2.3
                                          /usr/bin/npx            10.2.3
                                          /usr/bin/corepack       0.22.0
                                          nodejs:
                                           Installed: 18.19.0-1nodesource1
                                           Candidate: 18.19.0-1nodesource1
                                           Version table:
                                              18.19.0+dfsg-6~deb12u1 500
                                                 500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
                                          *** 18.19.0-1nodesource1 1001
                                                 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                                              18.18.2-1nodesource1 1001
                                              18.18.1-1nodesource1 1001
                                              18.18.0-1nodesource1 1001
                                              18.17.1-1nodesource1 1001
                                              18.17.0-1nodesource1 1001
                                              18.16.1-1nodesource1 1001
                                              18.16.0-1nodesource1 1001
                                              18.15.0-1nodesource1 1001
                                              18.14.2-1nodesource1 1001
                                              18.14.1-1nodesource1 1001
                                              18.14.0-1nodesource1 1001
                                              18.13.0+dfsg1-1 500
                                                 500 http://deb.debian.org/debian bookworm/main amd64 Packages
                                              18.13.0-1nodesource1 1001
                                              18.12.0-1nodesource1 1001
                                              18.11.0-1nodesource1 1001
                                              18.10.0-1nodesource1 1001
                                              18.9.1-1nodesource1 1001
                                              18.9.0-1nodesource1 1001
                                              18.8.0-1nodesource1 1001
                                              18.7.0-1nodesource1 1001
                                              18.6.0-1nodesource1 1001
                                              18.5.0-1nodesource1 1001
                                              18.4.0-1nodesource1 1001
                                              18.3.0-1nodesource1 1001
                                              18.2.0-1nodesource1 1001
                                              18.1.0-1nodesource1 1001
                                              18.0.0-1nodesource1 1001
                                          No problems detected
                                          Errors in npm tree:
                                          npm ERR! code ELSPROBLEMS
                                          npm ERR! invalid: xml2js@0.4.23 /opt/iobroker/node_modules/xml2js
                                          npm ERR! invalid: node-hue-api@4.0.11 /opt/iobroker/node_modules/node-hue-api
                                          npm ERR! missing: fs@^0.0.1-security, required by iobroker.javascript@7.1.6
                                          npm ERR! missing: querystring@^0.2.1, required by iobroker.javascript@7.1.6
                                          npm ERR! missing: simple-ssh@^1.1.1, required by iobroker.javascript@7.1.6
                                          npm ERR! A complete log of this run can be found in: /home/mirko/.npm/_logs/2024-01-22T12_40_10_581Z-debug-0.log
                                          *** ioBroker-Installation ***
                                          ioBroker Status
                                          Objects type: jsonl
                                          States  type: jsonl
                                          Core adapters versions
                                          js-controller:  5.0.17
                                          admin:          6.13.15
                                          javascript:     7.1.6
                                          Adapters from github:   3
                                          Adapter State
                                          + system.adapter.admin.1                  : admin                 : pi-iobroker                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                           system.adapter.alias-manager.0          : alias-manager         : iobroker                                 -  enabled
                                           system.adapter.birthdays.1              : birthdays             : iobroker                                 -  enabled
                                           system.adapter.consumption.0            : consumption           : iobroker                                 - disabled
                                           system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
                                          + system.adapter.discovery.0              : discovery             : pi-iobroker                              -  enabled
                                           system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
                                          + system.adapter.email.0                  : email                 : iobroker                                 -  enabled
                                          + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker                                 -  enabled
                                          + system.adapter.energiefluss.0           : energiefluss          : iobroker                                 -  enabled
                                          + system.adapter.enigma2.0                : enigma2               : iobroker                                 -  enabled
                                          + system.adapter.enocean.0                : enocean               : pi-iobroker                              -  enabled
                                           system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
                                           system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
                                          + system.adapter.fritzbox.0               : fritzbox              : iobroker                                 -  enabled
                                           system.adapter.habpanel.0               : habpanel              : iobroker                                 -  enabled
                                          + system.adapter.harmony.0                : harmony               : iobroker                                 -  enabled
                                          + system.adapter.hass.0                   : hass                  : iobroker                                 -  enabled, port: 8123
                                          + system.adapter.history.0                : history               : iobroker                                 -  enabled
                                          + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
                                          + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
                                          + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
                                          + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 -  enabled, port: 0
                                           system.adapter.homeconnect.0            : homeconnect           : iobroker                                 - disabled
                                          + system.adapter.hue.0                    : hue                   : iobroker                                 -  enabled, port: 80
                                           system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
                                           system.adapter.ical.1                   : ical                  : iobroker                                 -  enabled
                                           system.adapter.ical.2                   : ical                  : iobroker                                 -  enabled
                                           system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: iobroker                                 - disabled
                                           system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : iobroker                                 - disabled
                                           system.adapter.icons-icons8.0           : icons-icons8          : iobroker                                 - disabled
                                           system.adapter.icons-material-png.0     : icons-material-png    : iobroker                                 - disabled
                                           system.adapter.icons-material-svg.0     : icons-material-svg    : iobroker                                 - disabled
                                           system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 - disabled
                                           system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 - disabled
                                           system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 - disabled
                                           system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobroker                                 - disabled
                                          + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
                                          + system.adapter.iqontrol.0               : iqontrol              : iobroker                                 -  enabled
                                          + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                                          + system.adapter.javascript.1             : javascript            : iobroker                                 -  enabled
                                          + system.adapter.javascript.2             : javascript            : iobroker                                 -  enabled
                                           system.adapter.js2fs.0                  : js2fs                 : iobroker                                 - disabled
                                          + system.adapter.linux-control.0          : linux-control         : iobroker                                 -  enabled
                                           system.adapter.lovelace.0               : lovelace              : iobroker                                 - disabled, port: 8091, bind: 0.0.0.0, run as: admin
                                          + system.adapter.mercedesme.0             : mercedesme            : iobroker                                 -  enabled
                                          + system.adapter.modbus.0                 : modbus                : iobroker                                 -  enabled
                                          + system.adapter.modbus.1                 : modbus                : iobroker                                 -  enabled
                                          + system.adapter.modbus.2                 : modbus                : iobroker                                 -  enabled
                                          + system.adapter.modbus.3                 : modbus                : pi-iobroker                              -  enabled
                                          + system.adapter.modbus.5                 : modbus                : iobroker                                 -  enabled
                                          + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                                           system.adapter.musiccast.0              : musiccast             : iobroker                                 - disabled
                                           system.adapter.nut.0                    : nut                   : iobroker                                 - disabled
                                          + system.adapter.philips-tv.0             : philips-tv            : iobroker                                 -  enabled
                                          + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
                                           system.adapter.roborock.0               : roborock              : iobroker                                 - disabled
                                          + system.adapter.sayit.0                  : sayit                 : iobroker                                 -  enabled, port: 0
                                          + system.adapter.sayit.2                  : sayit                 : iobroker                                 -  enabled
                                          + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 192.168.178.18
                                          + system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker                                 -  enabled
                                          + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8091, bind: 192.168.178.18, run as: admin
                                          + system.adapter.smartmeter.0             : smartmeter            : pi-iobroker                              -  enabled
                                          + system.adapter.smartstate.0             : smartstate            : iobroker                                 -  enabled
                                          + system.adapter.socketio.0               : socketio              : iobroker                                 -  enabled, port: 8084, bind: 192.168.178.18, run as: admin
                                          + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1884, bind: 0.0.0.0
                                          + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
                                          + system.adapter.sourceanalytix.1         : sourceanalytix        : iobroker                                 -  enabled
                                           system.adapter.sql.0                    : sql                   : iobroker                                 - disabled
                                          + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
                                          + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 192.168.178.18
                                          + system.adapter.tr-064.0                 : tr-064                : pi-iobroker                              -  enabled
                                          + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
                                          + system.adapter.vis-2.0                  : vis-2                 : iobroker                                 -  enabled
                                           system.adapter.vis-bars.0               : vis-bars              : iobroker                                 - disabled
                                           system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 - disabled
                                           system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 - disabled
                                           system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 - disabled
                                           system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobroker                                 -  enabled
                                           system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
                                           system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 -  enabled
                                          + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
                                           system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 - disabled
                                           system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 - disabled
                                           system.adapter.vis-keyboard.0           : vis-keyboard          : iobroker                                 - disabled
                                           system.adapter.vis-material-webfont.0   : vis-material-webfont  : iobroker                                 -  enabled
                                           system.adapter.vis-material.0           : vis-material          : iobroker                                 -  enabled
                                           system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 -  enabled
                                           system.adapter.vis-metro.0              : vis-metro             : iobroker                                 - disabled
                                           system.adapter.vis-plumb.0              : vis-plumb             : iobroker                                 - disabled
                                           system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker                                 - disabled
                                           system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
                                           system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
                                           system.adapter.weatherunderground.0     : weatherunderground    : iobroker                                 -  enabled
                                          + system.adapter.web.1                    : web                   : iobroker                                 -  enabled, port: 8085, bind: 0.0.0.0, run as: admin
                                          + system.adapter.ws.0                     : ws                    : iobroker                                 -  enabled, port: 8083, bind: 0.0.0.0, run as: admin
                                          + system.adapter.yahka.0                  : yahka                 : iobroker                                 -  enabled
                                          + system.adapter.yahka.1                  : yahka                 : iobroker                                 -  enabled
                                          + system.adapter.yahka.2                  : yahka                 : iobroker                                 -  enabled
                                          + system.adapter.yahka.3                  : yahka                 : iobroker                                 -  enabled
                                          + system.adapter.yahka.4                  : yahka                 : iobroker                                 -  enabled
                                          + system.adapter.yamaha.0                 : yamaha                : iobroker                                 -  enabled
                                           system.adapter.yr.0                     : yr                    : iobroker                                 -  enabled
                                          + instance is alive
                                          ioBroker-Repositories
                                          Stable (default): http://iobroker.live/repo/sources-dist.json
                                          Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
                                          Test          : http://iobroker.live/repo/sources-dist.json
                                          Active repo(s): Beta (latest)
                                          Installed ioBroker-Instances
                                          Used repository: Beta (latest)
                                          Adapter    "admin"        : 6.13.15  , installed 6.13.15
                                          Adapter    "alias-manager": 1.2.6    , installed 1.2.6
                                          Adapter    "birthdays"    : 2.4.1    , installed 2.4.1
                                          Adapter    "consumption"  : 1.0.1    , installed 1.0.1
                                          Adapter    "daswetter"    : 3.1.13   , installed 3.1.13
                                          Adapter    "email"        : 1.2.2    , installed 1.2.2
                                          Adapter    "energiefluss" : 3.6.0    , installed 3.6.0
                                          Adapter    "enigma2"      : 2.0.5    , installed 2.0.5
                                          Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
                                          Adapter    "fritzbox"     : 0.5.0    , installed 0.5.0
                                          Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
                                          Adapter    "harmony"      : 1.3.0    , installed 1.3.0
                                          Adapter    "hass"         : 1.4.0    , installed 1.4.0
                                          Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
                                          Adapter    "hm-rpc"       : 1.16.0   , installed 1.16.0
                                          Adapter    "homeconnect"  : 1.3.0    , installed 1.3.0
                                          Adapter    "hue"          : 3.10.2   , installed 3.10.2
                                          Adapter    "hue-extended" : 2.0.0    , installed 2.0.0
                                          Adapter    "ical"         : 1.14.0   , installed 1.14.0
                                          Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
                                          Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
                                          Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
                                          Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
                                          Adapter    "javascript"   : 7.7.0    , installed 7.1.6  [Updatable]
                                          Controller "js-controller": 5.0.17   , installed 5.0.17
                                          Adapter    "linux-control": 1.1.5    , installed 1.1.5
                                          Adapter    "lovelace"     : 4.1.2    , installed 4.1.2
                                          Adapter    "mercedesme"   : 0.1.6    , installed 0.1.6
                                          Adapter    "modbus"       : 6.1.0    , installed 6.1.0
                                          Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
                                          Adapter    "musiccast"    : 1.1.3    , installed 1.1.3
                                          Adapter    "nut"          : 1.6.0    , installed 1.6.0
                                          Adapter    "philips-tv"   : 0.5.3    , installed 0.5.3
                                          Adapter    "pushover"     : 3.0.6    , installed 3.0.6
                                          Adapter    "roborock"     : 0.4.4    , installed 0.4.4
                                          Adapter    "sayit"        : 3.0.5    , installed 3.0.5
                                          Adapter    "shelly"       : 6.7.0    , installed 6.7.0
                                          Adapter    "shuttercontrol": 1.6.3   , installed 1.6.3
                                          Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
                                          Adapter    "socketio"     : 6.6.0    , installed 6.6.0
                                          Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
                                          Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
                                          Adapter    "telegram"     : 3.0.1    , installed 3.0.1
                                          Adapter    "trashschedule": 3.1.3    , installed 3.1.3
                                          Adapter    "vis"          : 1.5.4    , installed 1.5.4
                                          Adapter    "vis-2"        : 2.9.21   , installed 2.9.21
                                          Adapter    "vis-icontwo"  : 1.5.0    , installed 1.5.0
                                          Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
                                          Adapter    "vis-justgage" : 2.1.0    , installed 2.1.0
                                          Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
                                          Adapter    "vis-material" : 0.1.3    , installed 0.1.3
                                          Adapter    "vis-material-webfont": 0.0.3, installed 0.0.3
                                          Adapter    "weatherunderground": 3.6.0, installed 3.6.0
                                          Adapter    "web"          : 6.2.3    , installed 6.2.3
                                          Adapter    "ws"           : 2.5.10   , installed 2.5.10
                                          Adapter    "yahka"        : 1.0.3    , installed 1.0.3
                                          Adapter    "yamaha"       : 0.5.3    , installed 0.5.3
                                          Adapter    "yr"           : 5.3.0    , installed 5.3.0
                                          Objects and States
                                          Objects:        25057
                                          States:         23693
                                          Hit:1 http://security.debian.org/debian-security bookworm-security InRelease
                                          Hit:2 http://deb.debian.org/debian bookworm InRelease
                                          Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
                                          Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
                                          Reading package lists...
                                          Pending Updates: 0
                                          *** Listening Ports ***
                                          tcp        0      0 127.0.0.1:35173         0.0.0.0:*               LISTEN      1000       426521506  851595/io.yahka.2
                                          tcp        0      0 192.168.178.18:42001    0.0.0.0:*               LISTEN      1000       501178651  1925017/io.hm-rpc.0
                                          tcp        0      0 192.168.178.18:42010    0.0.0.0:*               LISTEN      1000       501179147  1925042/io.hm-rpc.2
                                          tcp        0      0 127.0.0.1:35031         0.0.0.0:*               LISTEN      1000       368878338  973571/io.yahka.0
                                          tcp        0      0 127.0.0.1:35785         0.0.0.0:*               LISTEN      1000       390209723  851677/io.yahka.4
                                          tcp        0      0 192.168.178.18:8701     0.0.0.0:*               LISTEN      1000       340729132  1291133/io.hm-rpc.1
                                          tcp        0      0 127.0.0.1:36171         0.0.0.0:*               LISTEN      1000       418311252  851677/io.yahka.4
                                          tcp        0      0 127.0.0.1:36191         0.0.0.0:*               LISTEN      1000       390208251  851677/io.yahka.4
                                          tcp        0      0 127.0.0.1:36663         0.0.0.0:*               LISTEN      1000       368911178  851640/io.yahka.3
                                          tcp        0      0 127.0.0.1:36525         0.0.0.0:*               LISTEN      1000       418311240  851580/io.yahka.1
                                          tcp        0      0 0.0.0.0:34723           0.0.0.0:*               LISTEN      1000       228594648  851640/io.yahka.3
                                          tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       479157811  1837349/io.mqtt.0
                                          tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1000       228586287  851357/io.sonoff.0
                                          tcp        0      0 127.0.0.1:32775         0.0.0.0:*               LISTEN      1000       416926423  973571/io.yahka.0
                                          tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          427181548  1632149/master
                                          tcp        0      0 127.0.0.1:33545         0.0.0.0:*               LISTEN      1000       418370685  851595/io.yahka.2
                                          tcp        0      0 127.0.0.1:33583         0.0.0.0:*               LISTEN      1000       418369167  851640/io.yahka.3
                                          tcp        0      0 127.0.0.1:33961         0.0.0.0:*               LISTEN      1000       368909052  851677/io.yahka.4
                                          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          427183198  1632308/sshd: /usr/
                                          tcp        0      0 127.0.0.1:40203         0.0.0.0:*               LISTEN      1000       368909721  851677/io.yahka.4
                                          tcp        0      0 127.0.0.1:40359         0.0.0.0:*               LISTEN      1000       368863169  851677/io.yahka.4
                                          tcp        0      0 127.0.0.1:40093         0.0.0.0:*               LISTEN      1000       406822983  973571/io.yahka.0
                                          tcp        0      0 127.0.0.1:40729         0.0.0.0:*               LISTEN      1000       368909045  851677/io.yahka.4
                                          tcp        0      0 127.0.0.1:40807         0.0.0.0:*               LISTEN      1000       418369948  851677/io.yahka.4
                                          tcp        0      0 127.0.0.1:40553         0.0.0.0:*               LISTEN      1000       228596276  851677/io.yahka.4
                                          tcp        0      0 127.0.0.1:37281         0.0.0.0:*               LISTEN      1000       394220104  851677/io.yahka.4
                                          tcp        0      0 127.0.0.1:38229         0.0.0.0:*               LISTEN      1000       368908775  973571/io.yahka.0
                                          tcp        0      0 127.0.0.1:38255         0.0.0.0:*               LISTEN      1000       418209190  851677/io.yahka.4
                                          tcp        0      0 127.0.0.1:38797         0.0.0.0:*               LISTEN      1000       394218298  973571/io.yahka.0
                                          tcp        0      0 127.0.0.1:38535         0.0.0.0:*               LISTEN      1000       390208256  851677/io.yahka.4
                                          tcp        0      0 192.168.178.18:1882     0.0.0.0:*               LISTEN      1000       340743723  1291249/io.shelly.0
                                          tcp        0      0 127.0.0.1:44385         0.0.0.0:*               LISTEN      1000       368864011  851677/io.yahka.4
                                          tcp        0      0 127.0.0.1:45045         0.0.0.0:*               LISTEN      1000       390208261  851677/io.yahka.4
                                          tcp        0      0 127.0.0.1:44749         0.0.0.0:*               LISTEN      1000       418311259  851677/io.yahka.4
                                          tcp        0      0 127.0.0.1:41439         0.0.0.0:*               LISTEN      1000       406820478  851677/io.yahka.4
                                          tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1000       228574986  850442/iobroker.js-
                                          tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1000       228575638  850442/iobroker.js-
                                          tcp        0      0 192.168.178.18:8084     0.0.0.0:*               LISTEN      1000       228597076  851695/io.socketio.
                                          tcp        0      0 192.168.178.18:8091     0.0.0.0:*               LISTEN      1000       228588455  851481/io.simple-ap
                                          tcp        0      0 127.0.0.1:45907         0.0.0.0:*               LISTEN      1000       418275620  973571/io.yahka.0
                                          tcp        0      0 127.0.0.1:45911         0.0.0.0:*               LISTEN      1000       368909057  851677/io.yahka.4
                                          tcp        0      0 127.0.0.1:46551         0.0.0.0:*               LISTEN      1000       368909834  851595/io.yahka.2
                                          tcp6       0      0 :::36731                :::*                    LISTEN      1000       228595121  851580/io.yahka.1
                                          tcp6       0      0 :::36229                :::*                    LISTEN      1000       260171208  973571/io.yahka.0
                                          tcp6       0      0 :::35525                :::*                    LISTEN      1000       228597834  851677/io.yahka.4
                                          tcp6       0      0 :::33711                :::*                    LISTEN      1000       228595179  851595/io.yahka.2
                                          tcp6       0      0 :::22                   :::*                    LISTEN      0          427183200  1632308/sshd: /usr/
                                          tcp6       0      0 :::8083                 :::*                    LISTEN      1000       270681701  1015603/io.ws.0
                                          tcp6       0      0 :::8082                 :::*                    LISTEN      1000       484399974  1857775/io.web.0
                                          tcp6       0      0 :::8081                 :::*                    LISTEN      1000       389494871  1480289/io.admin.0
                                          tcp6       0      0 :::8085                 :::*                    LISTEN      1000       484400865  1857782/io.web.1
                                          tcp6       0      0 :::40161                :::*                    LISTEN      1000       228597846  851677/io.yahka.4
                                          tcp6       0      0 :::42623                :::*                    LISTEN      1000       228597830  851677/io.yahka.4
                                          tcp6       0      0 :::41587                :::*                    LISTEN      1000       228597842  851677/io.yahka.4
                                          tcp6       0      0 :::46253                :::*                    LISTEN      1000       228597838  851677/io.yahka.4
                                          tcp6       0      0 :::61991                :::*                    LISTEN      1000       453991398  1736018/io.harmony.
                                          tcp6       0      0 ::1:25                  :::*                    LISTEN      0          427181549  1632149/master
                                          udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1000       453991399  1736018/io.harmony.
                                          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          28128      84/dhclient
                                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       260171209  973571/io.yahka.0
                                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       228597847  851677/io.yahka.4
                                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       228597843  851677/io.yahka.4
                                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       228597839  851677/io.yahka.4
                                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       228597835  851677/io.yahka.4
                                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       228597831  851677/io.yahka.4
                                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       228594650  851640/io.yahka.3
                                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       228594649  851640/io.yahka.3
                                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       228595180  851595/io.yahka.2
                                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       228593058  851580/io.yahka.1
                                          2024-01-22 13:34:00.157  - info: host.iobroker instance system.adapter.ical.1 started with pid 2101965
                                          2024-01-22 13:34:04.132  - info: ical.1 (2101965) starting. Version 1.14.0 in /opt/iobroker/node_modules/iobroker.ical, node: v18.19.0, js-controller: 5.0.17
                                          2024-01-22 13:34:04.579  - info: web.0 (1857775) <== Disconnect system.user.admin from ::ffff:192.168.178.169 vis.0
                                          2024-01-22 13:34:09.031  - info: javascript.0 (1920795) script.js.common.Tablet_Steuerung.Laden_Tablet_OG_Ubuntu: Batterielevel Tablet OG aktualisiert 95.09%
                                          2024-01-22 13:34:17.867  - info: ical.1 (2101965) processing URL: Familien Kalender https://192.168.178.38/remote.php/dav/calendars/Familie/familie-familienkalender/?export
                                          2024-01-22 13:34:25.478  - info: ical.1 (2101965) Terminated (NO_ERROR): Without reason
                                          2024-01-22 13:34:26.029  - info: host.iobroker instance system.adapter.ical.1 terminated with code 0 (NO_ERROR)
                                          2024-01-22 13:34:51.988  - info: linux-control.0 (1919631) getting data from VIS-OG (192.168.178.215:22)
                                          2024-01-22 13:35:03.977  - info: linux-control.0 (1919631) successful received data from VIS-OG (192.168.178.215:22)
                                          2024-01-22 13:35:42.824  - info: linux-control.0 (1919631) getting data from VIS-EG (192.168.178.216:22)
                                          2024-01-22 13:35:56.910  - info: linux-control.0 (1919631) successful received data from VIS-EG (192.168.178.216:22)
                                          2024-01-22 13:36:33.312  - info: javascript.0 (1920795) script.js.common.Tablet_Steuerung.Laden_Tablet_EG_Ubuntu: Batterielevel Tablet EG aktualisiert 90.56%
                                          2024-01-22 13:36:44.654  - info: javascript.0 (1920795) script.js.common.Tablet_Steuerung.Laden_Ipad_Küche: Aktualisiert Batterie IPAD Küche
                                          2024-01-22 13:37:10.031  - info: javascript.0 (1920795) script.js.common.Tablet_Steuerung.Laden_Tablet_OG_Ubuntu: Batterielevel Tablet OG aktualisiert 95.09%
                                          2024-01-22 13:39:33.826  - info: javascript.0 (1920795) script.js.common.Tablet_Steuerung.Laden_Tablet_EG_Ubuntu: Batterielevel Tablet EG aktualisiert 90.56%
                                          2024-01-22 13:40:00.013  - info: javascript.0 (1920795) script.js.common.Sonnen_Auf_Untergang.Sonnenstand: Script Sonnenstand; Erfolgreich gelaufen, Werte akzeptiert
                                          2024-01-22 13:40:00.291  - info: host.iobroker instance system.adapter.dwd.0 started with pid 2102206
                                          2024-01-22 13:40:03.979  - info: linux-control.0 (1919631) getting data from VIS-OG (192.168.178.215:22)
                                          2024-01-22 13:40:08.362  - info: dwd.0 (2102206) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.19.0, js-controller: 5.0.17
                                          2024-01-22 13:40:11.085  - info: javascript.0 (1920795) script.js.common.Tablet_Steuerung.Laden_Tablet_OG_Ubuntu: Batterielevel Tablet OG aktualisiert 95.09%
                                          2024-01-22 13:40:13.810  - info: dwd.0 (2102206) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                          2024-01-22 13:40:15.396  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                          2024-01-22 13:40:18.270  - info: linux-control.0 (1919631) successful received data from VIS-OG (192.168.178.215:22)
                                          2024-01-22 13:40:56.911  - info: linux-control.0 (1919631) getting data from VIS-EG (192.168.178.216:22)
                                          2024-01-22 13:41:26.294  - info: linux-control.0 (1919631) successful received data from VIS-EG (192.168.178.216:22)
                                          Hier noch das Summary:
        v.2023-10-10
                                           Virtualization: lxc
                                          Installation:           lxc
                                          Kernel:                 x86_64
                                          Userland:               amd64
                                          Timezone:               Europe/Berlin (CET, +0100)
                                          User-ID:                1001
                                          X-Server:               false
                                          Pending OS-Updates:     0
                                          Pending iob updates:    1
                                          Nodejs-Installation:    /usr/bin/nodejs         v18.19.0
        /usr/bin/npm            10.2.3
        /usr/bin/npx            10.2.3
                                          Recommended versions are nodejs 18.19.0 and npm 10.2.3
                                          MEMORY:
                                          Mem:             17G        8.1G        8.9G        102K        127M        9.1G
                                          Swap:             0B          0B          0B
                                          Total:           17G        8.1G        8.9G
                                          Active iob-Instances:   59
                                          ioBroker Core:          js-controller           5.0.17
        admin                   6.13.15
                                          Objects type: jsonl
                                          States  type: jsonl
                                          Objects:                25057
                                          States:                 23693
                                          Size of iob-Database:
                                          37M     /opt/iobroker/iobroker-data/objects.jsonl
                                          24M     /opt/iobroker/iobroker-data/objects.json.broken
                                          25M     /opt/iobroker/iobroker-data/states.jsonl
                                          8.5M    /opt/iobroker/iobroker-data/states.json.broken
                                          5.2M    /opt/iobroker/iobroker-data/states.json.migrated
                                          5.2M    /opt/iobroker/iobroker-data/states.json.bak.migrated
                                          Und hier mal das log von Chrome nachdem die Seite sich mal bewegt hat. Leider als txt file da zuviele Zeichen.
                                          VIS2_Chome_console.txt
                                          Wie kann ich wenn ich VIS-2 deinstalliere alles davon sicher entfernen so das bei erneuter Installation wieder ein Import von VIS-1 gemacht wird?
                                          Ist das ein Adapter oder lokales Problem?
