  4. Vis2 ab 09.01.2024 im stable
422 Beiträge 79 Kommentatoren 167.5k Aufrufe 85 Beobachtet
  • wendy2702W Online
    wendy2702W Online
    #117
    Gerade mal VIS 2 neu installiert. Lizenz hatte ich schon.
    VIS 2 Editor und VIS1 Editor nur noch weisse Seite im Browser. Auch nach löschen sämtlicher Browserdaten (Chrome und FF)
    Nach dem löschen geht wenigstens von VIS1 die Runtime wieder.
    Habe 2 Projekte aktiv.
    Nach installation von VIS2 kommt beim VIS1 Editor Aufruf das in der Konsole für mein Main Projekt:
    Uncaught SyntaxError: Unexpected non-whitespace character after JSON at position 5 (line 1 column 6)
        at JSON.parse (<anonymous>)
        at Object.unserialize (loStorage.js:2:567)
        at r.get (loStorage.js:2:1871)
        at Function.get (loStorage.js:2:2346)
        at Object.bindInstance (vis.js:576:54)
        at Object.initNext (vis.js:705:14)
        at Object.<anonymous> (vis.js:603:18)
        at Object.loadWidgetSets (vis.js:568:34)
        at Object.init (vis.js:602:14)
        at vis.js:3661:29
    Und das für mein Second:
        at vis.js:3694:29
    Im Vis 2 Editor kommt das in der Konsole:
    visEngine.jsx:1549 Someone installs handler without to remove it!
    Mt.registerChangeHandler @ visEngine.jsx:1549
    Ct @ visCanWidget.jsx:93
    Wo @ react-dom.production.min.js:147
    Ls @ react-dom.production.min.js:198
    yi @ react-dom.production.min.js:292
    xl @ react-dom.production.min.js:280
    zl @ react-dom.production.min.js:280
    gl @ react-dom.production.min.js:280
    rl @ react-dom.production.min.js:271
    ll @ react-dom.production.min.js:273
    Na @ react-dom.production.min.js:127
    (anonym) @ react-dom.production.min.js:283
    Vl @ react-dom.production.min.js:281
    ol @ react-dom.production.min.js:270
    V @ scheduler.production.min.js:13
    T @ scheduler.production.min.js:14
    14 weitere Frames anzeigen
    Weniger anzeigen
    react-dom.production.min.js:189 TypeError: Cannot add property g00002, object is not extensible
        at d (visUtils.jsx:386:37)
        at Ct.setupSubscriptions (visCanWidget.jsx:114:9)
        at new Ct (visCanWidget.jsx:91:14)
        at Wo (react-dom.production.min.js:147:172)
        at Ls (react-dom.production.min.js:198:97)
        at yi (react-dom.production.min.js:292:172)
        at xl (react-dom.production.min.js:280:389)
        at zl (react-dom.production.min.js:280:320)
        at gl (react-dom.production.min.js:280:180)
        at rl (react-dom.production.min.js:271:88)
    us @ react-dom.production.min.js:189
    c.callback @ react-dom.production.min.js:189
    Po @ react-dom.production.min.js:144
    Hi @ react-dom.production.min.js:262
    xi @ react-dom.production.min.js:260
    Mi @ react-dom.production.min.js:259
    15 weitere Frames anzeigen
    Weniger anzeigen
        at new c (visRxWidget.tsx:173:9)
        at new x (BasicHtml.jsx:23:1)
    Weniger anzeigen
    Weniger anzeigen
    4react-dom.production.min.js:189 TypeError: Cannot add property g00002, object is not extensible
    Was Möglicherweise auf ein Problem einer Widget Gruppe hindeutet.
    Wie bekomme ich am einfachsten mein VIS1 wieder vernünftig zum laufen?
    EDIT: Nach löschen VIS 2 Instanz, Adapter und Browser Daten geht VIS1 Editor wieder.
    • P Offline
      Pingus
      schrieb am zuletzt editiert von Pingus
      #118
      Hi
      Bei mir zeigt es nach einer unbekannten Zeit keine Daten mehr an im vis 2. Alle Werte einfach auf 0
      Refresh im Browser hilft nichts.
      Im Editor zeigt es mir die Werte aber an.
      Keine Fehler in der vis-2 und der web Instanz
      Neustart der vis-2 oder der web Instanz hilft nichts
      Hat da jemand eine Idee?
      • wendy2702W Online
        wendy2702W Online
        #119
        @pingus Hier gab es mal was mit einem "null" Objekt. Weiss aber gerade nicht ob das bei VIS-2 oder 1 oder beidem war.
        Schau mal in deine Objekte ob du ein "Null" Objekt das.
        P 1 Antwort Letzte Antwort
        • wendy2702W wendy2702
          Pingus
          #120
          @wendy2702 Du meinst im Objektbaum? Dort habe ich zwei Ordner die null heissen. Ansonsten weder Objektnamen noch Objekt-ID's mit dem Name null.
          • S schneidy76
            @mk-66 said in Vis2 ab morgen im stable:
            Bislang kann man das Problem ja über eine zweite web Instanz umgehen
            ...wie genau geht das? Dann könnte das hier auch funktionieren:
            View Vis1 als iframe in Vis2 (für Abfallkalender)
            VG Torsten
            MK-66
            #121
            @schneidy76 Man erzeugt im Admin über die Adapter einfach eine zusätzliche Web Instanz z.B. web.1.
            In der web.1 Instanz trägt man dann die IP Adresse des ioB Servers ein und der Port ist dann z.B. :8083 statt des üblichen :8082 Ports. Über die URL mit dem Port :8083 am Ende ruft man dann im Browser die vis2 runtime auf, z.B. in der Form http://192.168.178.222:8083/vis-2/?DeinProjektxxx#DeineSeite
            Über die ursprüngliche, normale web.0 Instanz und den Port :8082 ruft man dann im Browser immer nur die vis1 runtime auf, z.B. http://192.168.178.222:8082/vis/index.html?DeinProjektxxx#DeineSeite
            (Die genaue URL Deiner jeweiligen vis1 oder vis2 runtime steht ja nach Aufruf in der Brower-Adresszeile).
            So funktioniert das zumindest bei mir ganz gut, bislang ohne Browsercache löschen nach Aufruf der vis2.
            Zu der anderen Geschichte "View Vis1 als iframe in Vis2 (für Abfallkalender)" weiß ich nicht ob ein Link zur vis1 im iframe der vis2 angezeigt wird, einfach mal ausprobieren.
            Alternativ sonst evtl. einen Button mit URL Aufruf (Link) zur Deiner vis1 mit dem Abfallkalender einfügen und in der vis1 einen Button mit Link zur vis2 um auch wieder zurück zu kommen.
            • wendy2702W Online
              wendy2702W Online
              #122
              @pingus Schau mal hier
              https://forum.iobroker.net/topic/70819/vis-1-aktualisiert-nicht-mehr-regelmäßig/43?_=1705505356324
                Pingus
                #123
                @wendy2702 Ok, alles klar. Das liegt bei mir nicht vor. Ein Teil der nicht angezeigten Daten liegen im node-red.0 Baum, hat aber Werte dahinter, wenn ich das Objekt im vis-2 Editor ändere, also z.B. das letzte Zeichen lösche und wieder hin schreibe, dann wir mir der Wert manchmal angezeigt, aber nicht mehr in der Runtime ... Schon sehr schräg
                      at vis.js:3661:29
                      at vis.js:3694:29
                  Weniger anzeigen
                  Weniger anzeigen
                  Weniger anzeigen
                  Weniger anzeigen
                  foxriver76F Offline
                  foxriver76F Offline
                  foxriver76
                  #124
                  @wendy2702 mit der vis 2 Fehlermeldung ein issue wäre cool, glaube das lässt sich fixen
                  Videotutorials & mehr
                  • wendy2702W Online
                    wendy2702W Online
                    #125
                    @foxriver76 sagte in Vis2 ab morgen im stable:
                    Erledigt: https://github.com/ioBroker/ioBroker.vis-2/issues/322
                      foxriver76F Offline
                      foxriver76F Offline
                      foxriver76
                      #126
                      @wendy2702 danke dir
                      • LongbowL Offline
                        LongbowL Offline
                        Longbow
                        #127
                        Kann mir einer bitte behilflich sein, warum seit ich Vis 2 installiert habe, Jave spinnt?
                        Das ist immer der gleiche Fehlercode, nur dass sich der Scriptname in der Fehlermeldung verändert.
                        Vom Zeitstempel passt es, dass mit dem zusammen hängen muss.
                        Ich habe auch wie @MK-66 es beschrieben gemacht, was das mit dem Adpater Web trifft.
                        An was kann es nun liegen, das keine Scrpite mehr gehen?
                        javascript.0
                        16133	2024-01-19 07:29:37.357	error	at processImmediate (node:internal/timers:478:21)
                        javascript.0
                        16133	2024-01-19 07:29:37.357	error	at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.javascript/main.js:1636:17)
                        javascript.0
                        16133	2024-01-19 07:29:37.357	error	at /opt/iobroker/node_modules/iobroker.javascript/main.js:2161:17
                        javascript.0
                        16133	2024-01-19 07:29:37.357	error	at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:2063:37)
                        javascript.0
                        16133	2024-01-19 07:29:37.357	error	at createVM (/opt/iobroker/node_modules/iobroker.javascript/main.js:1810:21)
                        javascript.0
                        16133	2024-01-19 07:29:37.357	error	at new Script (node:vm:94:7
                        javascript.0
                        16133	2024-01-19 07:29:37.357	error	SyntaxError: Unexpected token '='
                        javascript.0
                        16133	2024-01-19 07:29:37.357	error	^
                        javascript.0
                        16133	2024-01-19 07:29:37.356	error	var = {};
                        javascript.0
                        16133	2024-01-19 07:29:37.356	error	script.js.Solar.Skript_1 compile failed: at script.js.Solar.Skript_1:2
                        • E e-i-k-e
                          Abend,
                          ich habe seit längerem probleme das sich Werte nicht eigenständig aktuallisieren, sondern das nur "Null" angezeigt wird. Sobald ich zwischen zwei Views hin und her Wechsel, wird der Wert aktuallisiert.
                          Jemand eine Idee?
                          Sind vis-inventwo widgets.
                          skvarelS Offline
                          skvarelS Offline
                          skvarel
                          #128
                          @e-i-k-e sagte in Vis2 ab morgen im stable:
                          Abend,
                          Jemand eine Idee?
                          ... vis-inventwo wird auch nie VIS2 kompatibel werden. Das ist einfach nicht machbar, weil sich der ganze VIS2 Adapter zu sehr verändert hat.
                          Jannis hat gestern entschieden, einen inventwo Adapter für VIS2 zu programmieren. Das Grundgerüst steht bereits und es geht langsam los!
                          An dieser Stelle, vielen Dank an @Bluefox für die Unterstützung :)
                          #TeamInventwo
                          Unsere Adapter:
                          jogibear9988J E 2 Antworten Letzte Antwort
                          • skvarelS skvarel
                            Abend,
                            Jemand eine Idee?
                            jogibear9988J Offline
                            jogibear9988
                            #129
                            @skvarel said in Vis2 ab morgen im stable:
                            Abend,
                            Jemand eine Idee?
                            Vlt könnten diese ja als Webcomponenten entwickelt werden (und für vis2 dann gewrappt (wenn das nötig ist), dann könnte man Sie an mehr stellen verwenden.
                            Weiß denn jemand in wie weit webcomponenten in vis2 bzw. react unterstützt werden? Was da mgl. wäre?
                            Check my ioBroker webui - a vis alternative
                            see: https://github.com/iobroker-community-adapters/ioBroker.webui
                            • foxriver76F foxriver76
                              wendy2702W Online
                              wendy2702W Online
                              #130
                              @foxriver76 Kannst du sagen wann die Version mit deinen Korrekturen zur Installation zur Verfügung steht?
                                foxriver76F Offline
                                foxriver76F Offline
                                foxriver76
                                #131
                                @wendy2702 2.9.21
                                • skvarelS skvarel
                                  Abend,
                                  Jemand eine Idee?
                                  e-i-k-e
                                  #132
                                  @skvarel sagte in Vis2 ab morgen im stable:
                                  Abend,
                                  Jemand eine Idee?
                                  Das klingt sehr gut, vielen Dank!
                                  Bedeutet aber auch, dass ich meine vis welche mit vis-inventwo Version "vis1" erstellt worden sind, neu aufbauen muss?
                                  skvarelS 1 Antwort Letzte Antwort
                                    @wendy2702 2.9.21
                                    wendy2702W Online
                                    wendy2702W Online
                                    #133
                                    @foxriver76 Ab wann sollte die denn im Latest oder stable sein?
                                    Aktuell noch immer die alte sichtbar:
                                      FeuersturmF Offline
                                      FeuersturmF Offline
                                      Feuersturm
                                      #134
                                      @wendy2702 Ich hab gerade die 2.9.21 über den Admin installiert. Hast du mal auf das Icon "Adapter auf updates prüfen" geklickt?
                                      Alternativ mal auf der Konsole folgendes ausführen, dann sollte dir die neue Version auf jeden Fall angeboten werden
                                      iob update
                                      • FeuersturmF Feuersturm
                                        iob update
                                        wendy2702W Online
                                        wendy2702W Online
                                        #135
                                        @feuersturm Das war es. Spannend das ich es manuell anstoßen musste.
                                          mcm1957M Online
                                          mcm1957M Online
                                          mcm1957
                                          #136
                                          @wendy2702
                                          Die Repositories werden 2x täglich ab ca 2:00 und 14:00 aktualisiert. Ab deswegen, da dieser Scan / Updat einige Stunden dauert.
                                          Die json Dateien der Repositories in denen Admin / js-controller nachsieht ob es was Neues gibt werden von deinem System per Default 1x täglich aktualisisert. Wenn du den aktualisieren Button drückst wird jedenfalls versucht die aktuellsten jsons downzuloaden.
                                          Es kann daher bis zu 12 bis 15h nach Veröffentlichung dauern bis eine neue Release prinzipiell im Repository verfügbar ist. Und es kann danach noch bis zu einem Tage dauern bis die Info auf deinem System landet (bei Defaukteinstellung und ohne manuelles Prüfen).
                                          Ein Update in Stable erfolgt über Aufforderung des Devs, außer in Notfällen allerdings frühestens ca. 7 Tage nach Veröffentlichung im Latest Repository.
                                          Hoffe dies erklärt das Verhalten ein wenig.
                                          mcm1957
                                          Support Repositoryverwaltung.
                                          LESEN - gute Forenbeitrage
