  3. Off Topic
  4. Ertrag (Tag, Monat, Jahr) berechnen und in Datei speichern
    6.0k
190 Beiträge 5 Kommentatoren 31.2k Aufrufe 4 Beobachtet
  • B bitwicht
    @Marc-Berg
    pi@raspberrypi:~ $ sudo ls -lah /var/lib/influxdb
    total 200K
    drwxr-x---  8 influxdb influxdb 4.0K Jan  8 17:47 .
    drwxr-xr-x 31 root     root     4.0K Jan  6 07:46 ..
    drwxr-xr-x  3 influxdb influxdb 4.0K Nov 14  2022 .cache
    drwxr-xr-x  3 influxdb influxdb 4.0K Nov 14  2022 data
    drwxr-x---  4 influxdb influxdb 4.0K Jan  8 17:47 engine
    -rw-------  1 influxdb influxdb  64K Jan  8 17:47 influxd.bolt
    drwx------  3 influxdb influxdb 4.0K Nov 14  2022 .influxdbv2
    -rw-r-----  1 influxdb influxdb    4 Jan  8 17:47 influxd.pid
    -rw-r-----  1 influxdb influxdb 120K Jan  8 17:47 influxd.sqlite
    drwxr-xr-x  2 influxdb influxdb 4.0K Nov 14  2022 meta
    drwx------  3 influxdb influxdb 4.0K Nov 14  2022 wal
    pi@raspberrypi:~ $ sudo ls -lah /var/lib/influxdb/.influxdbv2
    total 220K
    drwxr-x--- 8 influxdb influxdb 4.0K Jan  8 17:47 ..
    drwxr-xr-x 5 influxdb influxdb 4.0K Nov 14  2022 engine
    -rw------- 1 influxdb influxdb 128K Jan  8 17:44 influxd.bolt
    -rw-r--r-- 1 influxdb influxdb 108K Nov 14  2022 influxd.sqlite
    pi@raspberrypi:~ $ sudo ls -la /opt/iobroker/backups/influx*
    ls: cannot access '/opt/iobroker/backups/influx*': No such file or directory
    pi@raspberrypi:~ $
    Marc BergM Offline
    Marc BergM Offline
    Marc Berg
    #105
    @bitwicht
    sudo service influxdb status
      bitwicht
      #106
      @marc-berg said in Ertrag (Tag, Monat, Jahr) berechnen und in Datei speichern:
      pi@raspberrypi:~ $ sudo service influxdb status
      ● influxdb.service - InfluxDB is an open-source, distributed, time series database
           Loaded: loaded (/lib/systemd/system/influxdb.service; enabled; vendor preset: enabled)
           Active: active (running) since Mon 2024-01-08 17:47:10 CET; 3h 5min ago
             Docs: https://docs.influxdata.com/influxdb/
         Main PID: 768 (influxd)
            Tasks: 10 (limit: 8754)
              CPU: 12.489s
           CGroup: /system.slice/influxdb.service
                   └─768 /usr/bin/influxd
      Jan 08 20:06:54 raspberrypi influxd-systemd-start.sh[768]: ts=2024-01-08T19:06:54.556226Z lvl=info msg=Unauthorized log_id=0mbVNo2G000 error="authorization not found"
      Jan 08 20:07:04 raspberrypi influxd-systemd-start.sh[768]: ts=2024-01-08T19:07:04.565325Z lvl=info msg=Unauthorized log_id=0mbVNo2G000 error="authorization not found"
      Jan 08 20:07:14 raspberrypi influxd-systemd-start.sh[768]: ts=2024-01-08T19:07:14.572711Z lvl=info msg=Unauthorized log_id=0mbVNo2G000 error="authorization not found"
      Jan 08 20:07:24 raspberrypi influxd-systemd-start.sh[768]: ts=2024-01-08T19:07:24.584166Z lvl=info msg=Unauthorized log_id=0mbVNo2G000 error="authorization not found"
      Jan 08 20:07:34 raspberrypi influxd-systemd-start.sh[768]: ts=2024-01-08T19:07:34.593064Z lvl=info msg=Unauthorized log_id=0mbVNo2G000 error="authorization not found"
      Jan 08 20:07:44 raspberrypi influxd-systemd-start.sh[768]: ts=2024-01-08T19:07:44.600902Z lvl=info msg=Unauthorized log_id=0mbVNo2G000 error="authorization not found"
      Jan 08 20:17:23 raspberrypi influxd-systemd-start.sh[768]: ts=2024-01-08T19:17:23.618886Z lvl=info msg="Retention policy deletion check (start)" log_id=0mbVNo2G000 service=retention op_name=retention_delete_check op_event=start
      Jan 08 20:17:23 raspberrypi influxd-systemd-start.sh[768]: ts=2024-01-08T19:17:23.618960Z lvl=info msg="Retention policy deletion check (end)" log_id=0mbVNo2G000 service=retention op_name=retention_delete_check op_event=end op_elapsed=0>
      Jan 08 20:47:23 raspberrypi influxd-systemd-start.sh[768]: ts=2024-01-08T19:47:23.618284Z lvl=info msg="Retention policy deletion check (start)" log_id=0mbVNo2G000 service=retention op_name=retention_delete_check op_event=start
      Jan 08 20:47:23 raspberrypi influxd-systemd-start.sh[768]: ts=2024-01-08T19:47:23.618352Z lvl=info msg="Retention policy deletion check (end)" log_id=0mbVNo2G000 service=retention op_name=retention_delete_check op_event=end op_elapsed=0>
      lines 1-20/20 (END)
      • B bitwicht
                CPU: 12.489s
        lines 1-20/20 (END)
        Marc BergM Offline
        Marc BergM Offline
        Marc Berg
        #107
        @bitwicht
        Okay.
        Schlecht: kein Backup vorhanden
        Wahrscheinlich gut: die alten Daten wurden nicht gelöscht.
        Habe erstmal familäre Pflichten zu erfüllen, bin gleich wieder da.
          bitwicht
          schrieb am zuletzt editiert von bitwicht
          #108
          @Marc-Berg
          OK. Was mir eingefallen ist. Der Backitup schreibt das Backup auf ein NAS.
          Das Backup wäre aber von heute Nacht. Vielleicht findest du die Dateien noch auf dem PI, falls sie nicht überschrieben wurden
          • B bitwicht
            @Marc-Berg
            Marc BergM Offline
            Marc BergM Offline
            Marc Berg
            #109
            @bitwicht sagte in Ertrag (Tag, Monat, Jahr) berechnen und in Datei speichern:
            Okay, dann haben wir eine Rückfalloption, falls das hier schief geht:
            sudo service influxdb stop
            sudo cp -pR /var/lib/influxdb/.influxdbv2/ /tmp
            sudo cp -pR /tmp/.influxdbv2/* /var/lib/influxdb/
            sudo service influxdb start
              bitwicht
              #110
              @Marc-Berg
              pi@raspberrypi:~ $ sudo service influxdb stop
              pi@raspberrypi:~ $ sudo cp -pR /var/lib/influxdb/.influxdbv2/ /tmp
              pi@raspberrypi:~ $ sudo cp -pR /tmp/.influxdbv2/* /var/lib/influxdb/
              {1}
              cp: cannot stat '/tmp/.influxdbv2/*': No such file or directory
              -bash: {1}: command not found
              pi@raspberrypi:~ $
              oder sind das 2 Befhle:
              • sudo cp -pR /tmp/.influxdbv2/* /var/lib/influxdb/
              • sudo service influxdb start
              • B bitwicht
                @Marc-Berg
                {1}
                pi@raspberrypi:~ $
                Marc BergM Offline
                Marc BergM Offline
                Marc Berg
                #111
                ja, genau
                  bitwicht
                  #112
                  @marc-berg
                  pi@raspberrypi:~ $
                  • B bitwicht
                    @marc-berg
                    pi@raspberrypi:~ $
                    Marc BergM Offline
                    Marc BergM Offline
                    Marc Berg
                    #113
                    /tmp/.influxdbv2
                    sudo ls -lah /tmp/.influxdbv2
                      bitwicht
                      #114
                      @marc-berg
                      pi@raspberrypi:~ $ sudo ls -lah /tmp/.influxdbv2
                      total 220K
                      drwxrwxrwt 13 root     root     4.0K Jan  8 22:11 ..
                      pi@raspberrypi:~ $
                      • B bitwicht
                        @marc-berg
                        total 220K
                        pi@raspberrypi:~ $
                        Marc BergM Offline
                        Marc BergM Offline
                        Marc Berg
                        #115
                        @bitwicht
                        sudo mv /tmp/.influxdbv2/ /tmp/influxdbv2
                        sudo cp -pR /tmp/influxdbv2/* /var/lib/influxdb/
                          bitwicht
                          #116
                          @Marc-Berg
                          pi@raspberrypi:/ $ sudo mv /tmp/.influxdbv2/ /tmp/influxdbv2
                          pi@raspberrypi:/ $ sudo cp -pR /tmp/influxdbv2/* /var/lib/influxdb/
                          cp: cannot stat '/tmp/influxdbv2/*': No such file or directory
                          pi@raspberrypi:/ $
                          das geht auch nicht
                          pi@raspberrypi:~ $ sudo mv /tmp/.influxdbv2/ /tmp/influxdbv2
                          pi@raspberrypi:~ $ sudo cp -pR /tmp/influxdbv2/* /var/lib/influxdb/
                          pi@raspberrypi:~ $
                          • B bitwicht
                            @Marc-Berg
                            pi@raspberrypi:/ $
                            das geht auch nicht
                            pi@raspberrypi:~ $
                            Marc BergM Offline
                            Marc BergM Offline
                            Marc Berg
                            #117
                            @bitwicht
                            sudo systemctl stop influxdb
                            sudo mv /tmp/influxdb2 /tmp/influxdb
                            sudo cp -pR /tmp/influxdb/ /var/lib
                            sudo systemctl start influxdb
                              bitwicht
                              #118
                              @marc-berg
                              pi@raspberrypi:~ $ sudo systemctl stop influxdb
                              pi@raspberrypi:~ $ sudo mv /tmp/influxdb2 /tmp/influxdb
                              mv: cannot stat '/tmp/influxdb2': No such file or directory
                              pi@raspberrypi:~ $
                              • B bitwicht
                                @marc-berg
                                pi@raspberrypi:~ $
                                Marc BergM Offline
                                Marc BergM Offline
                                Marc Berg
                                #119
                                sudo mv /tmp/influxdbv2 /tmp/influxdb
                                • Marc BergM Marc Berg
                                  bitwicht
                                  #120
                                  @marc-berg
                                  Das geht! Danke.
                                  Weboberfläche geht auch wieder.
                                  Sind die Daten jetzt im richtigen Ordner oder ist das jetzt alles verbogen?
                                  Geht es auch noch nach einem Reboot ?
                                  • B bitwicht
                                    @marc-berg
                                    Das geht! Danke.
                                    Marc BergM Offline
                                    Marc BergM Offline
                                    Marc Berg
                                    #121
                                    Das geht! Danke.
                                    Ja, geht alles. Kannst du gern testen. Wir müssen aber noch aufräumen:
                                    sudo rm -r /tmp/influxdb
                                    sudo rm -r /var/lib/influxdb/.influxdbv2
                                      bitwicht
                                      #122
                                      @Marc-Berg
                                      pi@raspberrypi:~ $ sudo rm -r /tmp/influxdbv2
                                      rm: cannot remove '/tmp/influxdbv2': No such file or directory
                                      pi@raspberrypi:~ $
                                      will er wieder nicht
                                      • B bitwicht
                                        @Marc-Berg
                                        pi@raspberrypi:~ $
                                        Marc BergM Offline
                                        Marc BergM Offline
                                        Marc Berg
                                        #123
                                        ja, habe ich oben korrigiert
                                          bitwicht
                                          #124
                                          @Marc-Berg
                                          passt:
                                          pi@raspberrypi:~ $ sudo rm -r /var/lib/influxdb/.influxdbv2
                                          pi@raspberrypi:~ $
