  3. Off Topic
  4. Ertrag (Tag, Monat, Jahr) berechnen und in Datei speichern
    6.0k
190 Beiträge 5 Kommentatoren 31.2k Aufrufe 4 Beobachtet
  • B bitwicht
    @marc-berg said in Ertrag (Tag, Monat, Jahr) berechnen und in Datei speichern:
    sudo service influxdb status
    pi@raspberrypi:~ $ sudo service influxdb status
    ● influxdb.service - InfluxDB is an open-source, distributed, time series database
         Loaded: loaded (/lib/systemd/system/influxdb.service; enabled; vendor preset: enabled)
         Active: active (running) since Mon 2024-01-08 17:47:10 CET; 3h 5min ago
           Docs: https://docs.influxdata.com/influxdb/
       Main PID: 768 (influxd)
          Tasks: 10 (limit: 8754)
            CPU: 12.489s
         CGroup: /system.slice/influxdb.service
                 └─768 /usr/bin/influxd
    Jan 08 20:06:54 raspberrypi influxd-systemd-start.sh[768]: ts=2024-01-08T19:06:54.556226Z lvl=info msg=Unauthorized log_id=0mbVNo2G000 error="authorization not found"
    Jan 08 20:07:04 raspberrypi influxd-systemd-start.sh[768]: ts=2024-01-08T19:07:04.565325Z lvl=info msg=Unauthorized log_id=0mbVNo2G000 error="authorization not found"
    Jan 08 20:07:14 raspberrypi influxd-systemd-start.sh[768]: ts=2024-01-08T19:07:14.572711Z lvl=info msg=Unauthorized log_id=0mbVNo2G000 error="authorization not found"
    Jan 08 20:07:24 raspberrypi influxd-systemd-start.sh[768]: ts=2024-01-08T19:07:24.584166Z lvl=info msg=Unauthorized log_id=0mbVNo2G000 error="authorization not found"
    Jan 08 20:07:34 raspberrypi influxd-systemd-start.sh[768]: ts=2024-01-08T19:07:34.593064Z lvl=info msg=Unauthorized log_id=0mbVNo2G000 error="authorization not found"
    Jan 08 20:07:44 raspberrypi influxd-systemd-start.sh[768]: ts=2024-01-08T19:07:44.600902Z lvl=info msg=Unauthorized log_id=0mbVNo2G000 error="authorization not found"
    Jan 08 20:17:23 raspberrypi influxd-systemd-start.sh[768]: ts=2024-01-08T19:17:23.618886Z lvl=info msg="Retention policy deletion check (start)" log_id=0mbVNo2G000 service=retention op_name=retention_delete_check op_event=start
    Jan 08 20:17:23 raspberrypi influxd-systemd-start.sh[768]: ts=2024-01-08T19:17:23.618960Z lvl=info msg="Retention policy deletion check (end)" log_id=0mbVNo2G000 service=retention op_name=retention_delete_check op_event=end op_elapsed=0>
    Jan 08 20:47:23 raspberrypi influxd-systemd-start.sh[768]: ts=2024-01-08T19:47:23.618284Z lvl=info msg="Retention policy deletion check (start)" log_id=0mbVNo2G000 service=retention op_name=retention_delete_check op_event=start
    Jan 08 20:47:23 raspberrypi influxd-systemd-start.sh[768]: ts=2024-01-08T19:47:23.618352Z lvl=info msg="Retention policy deletion check (end)" log_id=0mbVNo2G000 service=retention op_name=retention_delete_check op_event=end op_elapsed=0>
    lines 1-20/20 (END)
    Marc BergM Offline
    Marc BergM Offline
    Marc Berg
    #107
    @bitwicht
    Okay.
    Schlecht: kein Backup vorhanden
    Wahrscheinlich gut: die alten Daten wurden nicht gelöscht.
    Habe erstmal familäre Pflichten zu erfüllen, bin gleich wieder da.
      bitwicht
      schrieb am zuletzt editiert von bitwicht
      #108
      @Marc-Berg
      OK. Was mir eingefallen ist. Der Backitup schreibt das Backup auf ein NAS.
      Das Backup wäre aber von heute Nacht. Vielleicht findest du die Dateien noch auf dem PI, falls sie nicht überschrieben wurden
      • B bitwicht
        @Marc-Berg
        Marc BergM Offline
        Marc BergM Offline
        Marc Berg
        #109
        @bitwicht sagte in Ertrag (Tag, Monat, Jahr) berechnen und in Datei speichern:
        Okay, dann haben wir eine Rückfalloption, falls das hier schief geht:
        sudo service influxdb stop
        sudo cp -pR /var/lib/influxdb/.influxdbv2/ /tmp
        sudo cp -pR /tmp/.influxdbv2/* /var/lib/influxdb/
        sudo service influxdb start
          bitwicht
          #110
          @Marc-Berg
          pi@raspberrypi:~ $ sudo service influxdb stop
          pi@raspberrypi:~ $ sudo cp -pR /var/lib/influxdb/.influxdbv2/ /tmp
          pi@raspberrypi:~ $ sudo cp -pR /tmp/.influxdbv2/* /var/lib/influxdb/
          {1}
          cp: cannot stat '/tmp/.influxdbv2/*': No such file or directory
          -bash: {1}: command not found
          pi@raspberrypi:~ $
          oder sind das 2 Befhle:
          • sudo cp -pR /tmp/.influxdbv2/* /var/lib/influxdb/
          • sudo service influxdb start
          • B bitwicht
            @Marc-Berg
            {1}
            pi@raspberrypi:~ $
            Marc BergM Offline
            Marc BergM Offline
            Marc Berg
            #111
            ja, genau
              bitwicht
              #112
              @marc-berg
              pi@raspberrypi:~ $
              • B bitwicht
                @marc-berg
                pi@raspberrypi:~ $
                Marc BergM Offline
                Marc BergM Offline
                Marc Berg
                #113
                /tmp/.influxdbv2
                sudo ls -lah /tmp/.influxdbv2
                  bitwicht
                  #114
                  @marc-berg
                  pi@raspberrypi:~ $ sudo ls -lah /tmp/.influxdbv2
                  total 220K
                  drwx------  3 influxdb influxdb 4.0K Nov 14  2022 .
                  drwxrwxrwt 13 root     root     4.0K Jan  8 22:11 ..
                  drwxr-xr-x  5 influxdb influxdb 4.0K Nov 14  2022 engine
                  -rw-------  1 influxdb influxdb 128K Jan  8 17:44 influxd.bolt
                  -rw-r--r--  1 influxdb influxdb 108K Nov 14  2022 influxd.sqlite
                  pi@raspberrypi:~ $
                  • B bitwicht
                    @marc-berg
                    total 220K
                    pi@raspberrypi:~ $
                    Marc BergM Offline
                    Marc BergM Offline
                    Marc Berg
                    #115
                    @bitwicht
                    sudo mv /tmp/.influxdbv2/ /tmp/influxdbv2
                    sudo cp -pR /tmp/influxdbv2/* /var/lib/influxdb/
                      bitwicht
                      #116
                      @Marc-Berg
                      pi@raspberrypi:/ $ sudo mv /tmp/.influxdbv2/ /tmp/influxdbv2
                      pi@raspberrypi:/ $ sudo cp -pR /tmp/influxdbv2/* /var/lib/influxdb/
                      cp: cannot stat '/tmp/influxdbv2/*': No such file or directory
                      pi@raspberrypi:/ $
                      das geht auch nicht
                      pi@raspberrypi:~ $ sudo mv /tmp/.influxdbv2/ /tmp/influxdbv2
                      pi@raspberrypi:~ $ sudo cp -pR /tmp/influxdbv2/* /var/lib/influxdb/
                      pi@raspberrypi:~ $
                      • B bitwicht
                        @Marc-Berg
                        pi@raspberrypi:/ $
                        das geht auch nicht
                        pi@raspberrypi:~ $
                        Marc BergM Offline
                        Marc BergM Offline
                        Marc Berg
                        #117
                        @bitwicht
                        sudo systemctl stop influxdb
                        sudo mv /tmp/influxdb2 /tmp/influxdb
                        sudo cp -pR /tmp/influxdb/ /var/lib
                        sudo systemctl start influxdb
                          bitwicht
                          #118
                          @marc-berg
                          pi@raspberrypi:~ $ sudo systemctl stop influxdb
                          pi@raspberrypi:~ $ sudo mv /tmp/influxdb2 /tmp/influxdb
                          mv: cannot stat '/tmp/influxdb2': No such file or directory
                          pi@raspberrypi:~ $
                          • B bitwicht
                            @marc-berg
                            pi@raspberrypi:~ $
                            Marc BergM Offline
                            Marc BergM Offline
                            Marc Berg
                            #119
                            sudo mv /tmp/influxdbv2 /tmp/influxdb
                            • Marc BergM Marc Berg
                              bitwicht
                              #120
                              @marc-berg
                              Das geht! Danke.
                              Weboberfläche geht auch wieder.
                              Sind die Daten jetzt im richtigen Ordner oder ist das jetzt alles verbogen?
                              Geht es auch noch nach einem Reboot ?
                              • B bitwicht
                                @marc-berg
                                Das geht! Danke.
                                Marc BergM Offline
                                Marc BergM Offline
                                Marc Berg
                                #121
                                Das geht! Danke.
                                Ja, geht alles. Kannst du gern testen. Wir müssen aber noch aufräumen:
                                sudo rm -r /tmp/influxdb
                                sudo rm -r /var/lib/influxdb/.influxdbv2
                                  bitwicht
                                  #122
                                  @Marc-Berg
                                  pi@raspberrypi:~ $ sudo rm -r /tmp/influxdbv2
                                  rm: cannot remove '/tmp/influxdbv2': No such file or directory
                                  pi@raspberrypi:~ $
                                  will er wieder nicht
                                  • B bitwicht
                                    @Marc-Berg
                                    pi@raspberrypi:~ $
                                    Marc BergM Offline
                                    Marc BergM Offline
                                    Marc Berg
                                    #123
                                    ja, habe ich oben korrigiert
                                      bitwicht
                                      #124
                                      @Marc-Berg
                                      passt:
                                      pi@raspberrypi:~ $ sudo rm -r /var/lib/influxdb/.influxdbv2
                                      pi@raspberrypi:~ $
                                      • B bitwicht
                                        @Marc-Berg
                                        passt:
                                        pi@raspberrypi:~ $
                                        Marc BergM Offline
                                        Marc BergM Offline
                                        Marc Berg
                                        #125
                                        passt:
                                        und jetzt neu starten
                                          bitwicht
                                          #126
                                          @Marc-Berg
                                          Schaut auch gut nach dem reboot aus.
                                          InfluxDB v2.7.4
                                          Was aber immer noch nicht geht, die Daten einzutragen :-(
                                          Das kann doch nicht sein, dass es bei dir geht aber bei mir nicht
