  4. IKEA Trådfri The security code is incorrect or
34 Beiträge 2 Kommentatoren 3.8k Aufrufe 2 Beobachtet
    @dg19222 sagte in IKEA Trådfri The security code is incorrect or:
    restart the adapter!
    Das mal getan? Denn hier läuft der Adapter einwandfrei.
    Schau dir ggf.
    iob diag
    an.
    dg19222
    @thomas-braun ```
    dg19222@Iobrocker:~$ curl -sLf https://iobroker.net/diag.sh
    #!/bin/bash
    iobroker diagnostics
    written to help getting information about the environment the ioBroker installation is running in
    DOCKER=/opt/scripts/.docker_config/.thisisdocker
    #if [[ -f "/opt/scripts/.docker_config/.thisisdocker" ]]
    if [ -f "$DOCKER" ]
    then
    echo "";
    elif [ "$(id -u)" = 0 ];
    then
    echo -e "This script must not be run as root! \nPlease use your standard user!"
    exit 1
    fi
    clear;
    echo "*** iob diag is starting up, please wait ***";
    VARIABLES
    export LC_ALL=C;
    SKRIPTV="2023-10-10"; #version of this script
    NODE_MAJOR=18 #this is the recommended major nodejs version for ioBroker, please adjust accordingly if the recommendation changes
    HOST=$(hostname)
    NODERECOM=$(iobroker state getValue system.host."$HOST".versions.nodeNewestNext); #recommended node version
    NPMRECOM=$(iobroker state getValue system.host."$HOST".versions.npmNewestNext); #recommended npm version
    NODEUSED=$(iobroker state getValue system.host."$HOST".versions.nodeCurrent); #current node version in use
    #NPMUSED=$(iobroker state getValue system.host."$HOST".versions.npmCurrent); #current npm version in use
    XORGTEST=0; #test for GUI
    APT=0;
    INSTENV=0;
    INSTENV2=0;
    SYSTDDVIRT="";
    NODENOTCORR=0;
    clear;
    echo "";
    echo -e "\033[34;107m*** ioBroker Diagnosis \033[0m";
    echo "";
    echo "Please stretch the window of your terminal programm (puTTY) as wide as possible or switch to full screen";
    echo "";
    echo "The following checks may give hints to potential malconfigurations or errors, please post them in our forum:";
    echo "";
    echo "https://forum.iobroker.net";
    echo "";
    echo "Just copy and paste the Summary Page, including the ``` characters at start and end.";
    echo "It helps us to help you!"
    echo "";
    # read -p "Press <Enter> to continue";
    echo "Press any key to continue";
    read -r -n 1 -s
    clear;
    echo "";
    echo -e "\033[33m======== Start marking the full check here =========\033[0m";
    echo "";
    echo "```";
    echo "Skript v.$SKRIPTV"
    echo "";
    BASE SYSTEM ***\033[0m";
    if [ -f "$DOCKER" ]; then
    echo -e "Hardware Vendor : $(cat /sys/devices/virtual/dmi/id/sys_vendor)";
    echo -e "Kernel : $(uname -m)";
    echo -e "Userland : $(dpkg --print-architecture)";
    echo -e "Docker : $(cat /opt/scripts/.docker_config/.thisisdocker)"
    else
    hostnamectl | grep -v 'Machine|Boot';
    echo "";
    grep -i model /proc/cpuinfo | tail -1;
    echo -e "Docker : false";
    fi;
    Alternativer DockerCheck - Nicht getestet:
    if [ -f /.dockerenv ]; then
    echo "I'm inside matrix ;(";
    else
    echo "I'm living in real world!";
    fi
    SYSTDDVIRT=$(systemd-detect-virt 2>/dev/null)
    if [ "$SYSTDDVIRT" != "" ]; then
    echo -e "Virtualization : $(systemd-detect-virt)"
    else
    echo "Virtualization : Docker"
    fi;
    echo "";
    echo "Systemuptime and Load:";
    uptime;
    echo "CPU threads: $(grep -c processor /proc/cpuinfo)"
    echo "";
    RASPBERRY only
    if [[ $(type -P "vcgencmd" 2>/dev/null) = *"/vcgencmd" ]]; then
    echo "Raspberry only:";
    vcgencmd get_throttled 2> /dev/null;
    echo "Other values than 0x0 hint to temperature/voltage problems";
    vcgencmd measure_temp;
    vcgencmd measure_volts;
    TEST CODE
    echo "";
    echo -e "\033[34;107m*** RASPBERRY THROTTLING ***\033[0m";
    CODE from https://github.com/alwye/get_throttled under MIT Licence
    ISSUES_MAP=(
    [0]="Under-voltage detected"
    [1]="Arm frequency capped"
    [2]="Currently throttled"
    [3]="Soft temperature limit active"
    [16]="Under-voltage has occurred"
    [17]="Arm frequency capping has occurred"
    [18]="Throttling has occurred"
    [19]="Soft temperature limit has occurred")
    HEX_BIN_MAP=(
    ["0"]="0000"
    ["1"]="0001"
    ["2"]="0010"
    ["3"]="0011"
    ["4"]="0100"
    ["5"]="0101"
    ["6"]="0110"
    ["7"]="0111"
    ["8"]="1000"
    ["9"]="1001"
    ["A"]="1010"
    ["B"]="1011"
    ["C"]="1100"
    ["D"]="1101"
    ["E"]="1110"
    ["F"]="1111"
    THROTTLED_OUTPUT=$(vcgencmd get_throttled)
    IFS='x'
    read -r -a strarr <<< "$THROTTLED_OUTPUT"
    THROTTLED_CODE_HEX=${strarr[1]}
    Display current issues
    echo "Current issues:"
    CURRENT_HEX=${THROTTLED_CODE_HEX:4:1}
    CURRENT_BIN=${HEX_BIN_MAP[$CURRENT_HEX]}
    if [ "$CURRENT_HEX" == "0" ] || [ -z "$CURRENT_HEX" ]; then
    echo "No throttling issues detected."
    else
    bit_n=0
    for (( i=${#CURRENT_BIN}-1; i>=0; i--)); do
    if [ "${CURRENT_BIN:$i:1}" = "1" ]; then
    echo "~ ${ISSUES_MAP[$bit_n]}"
    bit_n=$((bit_n+1))
    fi
    done
    fi
    echo ""
    Display past issues
    echo "Previously detected issues:"
    PAST_HEX=${THROTTLED_CODE_HEX:0:1}
    PAST_BIN=${HEX_BIN_MAP[$PAST_HEX]}
    if [ "$PAST_HEX" = "0" ]; then
    else
    bit_n=16
    for (( i=${#PAST_BIN}-1; i>=0; i--)); do
    if [ "${PAST_BIN:$i:1}" = "1" ]; then
    bit_n=$((bit_n+1))
    fi
    done
    fi
    fi
    if [[ -f "/var/run/reboot-required" ]]; then
    echo "";
    echo "This system needs to be REBOOTED!";
    echo "";
    fi
    echo "";
    echo -e "\033[34;107m*** Time and Time Zones ***\033[0m";
    date -u;
    date;
    date +"%Z %z";
    cat /etc/timezone;
    else
    timedatectl;
    fi;
    echo "";
    echo -e "\033[34;107m*** User and Groups \033[0m";
    whoami;
    echo "$HOME";
    groups;
    echo "";
    X-Server-Setup ***\033[0m";
    XORGTEST=$(pgrep -f "Xorg")
    XORGTEST=$(ps aux | grep -c 'Xorg')
    if [[ "$XORGTEST" -gt 1 ]];
    then
    echo -e "X-Server: \ttrue"
    else
    echo -e "X-Server: \tfalse"
    fi
    echo -e "Desktop: \t$DESKTOP_SESSION";
    echo -e "Terminal: \t$XDG_SESSION_TYPE";
    echo -e "";
    else
    echo -e "Boot Target: \t$(systemctl get-default)";
    fi;
    echo "";
    echo -e "\033[34;107m*** MEMORY ***\033[0m";
    free -th --mega;
    echo "";
    vmstat -S M -s | head -n 10;
    RASPBERRY only
    echo "";
    vcgencmd mem_oom;
    fi;
    echo "";
    else
    echo "";
    echo -e "\033[34;107m*** FAILED SERVICES \033[0m";
    echo "";
    systemctl list-units --failed --no-pager;
    echo "";
    fi;
    FILESYSTEM ***\033[0m";
    df -PTh;
    echo "";
    echo -e "\033[32mMessages concerning ext4 filesystem in dmesg:\033[0m";
    sudo dmesg -T | grep -i ext4;
    echo "";
    echo -e "\033[32mShow mounted filesystems (real ones only):\033[0m";
    findmnt --real;
    echo "";
    if [[ -L "/opt/iobroker/backups" ]]; then
    echo "backups directory is linked to a different directory";
    echo "";
    fi
    echo -e "\033[32mFiles in neuralgic directories:\033[0m";
    echo "";
    echo -e "\033[32m/var:\033[0m";
    sudo du -h /var/ | sort -rh | head -5;
    echo -e "";
    echo -e ""
    else
    journalctl --disk-usage;
    fi;
    echo "";
    echo -e "\033[32m/opt/iobroker/backups:\033[0m";
    du -h /opt/iobroker/backups/ | sort -rh | head -5;
    echo "";
    echo -e "\033[32m/opt/iobroker/iobroker-data:\033[0m";
    du -h /opt/iobroker/iobroker-data/ | sort -rh | head -5;
    echo "";
    echo -e "\033[32mThe five largest files in iobroker-data are:\033[0m";
    find /opt/iobroker/iobroker-data -maxdepth 15 -type f -exec du -sh {} + | sort -rh | head -n 5;
    echo "";
    Detecting dev-links in /dev/serial/by-id
    echo -e "\033[32mUSB-Devices by-id:\033[0m";
    echo "USB-Sticks - Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id':";
    echo "";
    find /dev/serial/by-id/ -maxdepth 1 -mindepth 1;
    echo "";
    echo -e "\033[34;107m*** NodeJS-Installation ***\033[0m";
    echo "";
    echo -e "$(type -p nodejs) \t$(nodejs -v)";
    echo -e "$(type -p node) \t\t$(node -v)";
    echo -e "$(type -p npm) \t\t$(npm -v)";
    echo -e "$(type -p npx) \t\t$(npx -v)";
    echo -e "$(type -p corepack) \t$(corepack -v)";
    PATHAPT=$(type -p apt);
    PATHNODEJS=$(type -p nodejs);
    PATHNODE=$(type -p node);
    PATHNPM=$(type -p npm);
    PATHNPX=$(type -p npx);
    PATHCOREPACK=$(type -p corepack);
    VERNODEJS=$(nodejs -v);
    VERNODE=$(node -v);
    VERNPM=$(npm -v);
    VERNPX=$(npx -v);
    #VERCOREPACK=$(corepack -v);
    if
    [[ $PATHNODEJS != "/usr/bin/nodejs" ]];
    then
    NODENOTCORR=1
    echo -e "\033[0;31m*** nodejs is NOT correctly installed \033[0m";
    elif
    [[ $PATHNODE != "/usr/bin/node" ]];
    then
    NODENOTCORR=1
    echo -e "\033[0;31m
    elif
    [[ $PATHNPM != "/usr/bin/npm" ]];
    then
    NODENOTCORR=1
    echo -e "\033[0;31m
    elif
    [[ $PATHNPX != "/usr/bin/npx" ]];
    then
    NODENOTCORR=1
    echo -e "\033[0;31m
    elif
    [[ $VERNODEJS != "$VERNODE" ]];
    then
    NODENOTCORR=1
    echo -e "\033[0;31m
    elif
    [[ $VERNPM != "$VERNPX" ]];
    then
    NODENOTCORR=1
    echo -e "\033[0;31m
    elif
    [[ $PATHCOREPACK != "/usr/bin/corepack" ]];
    then
    NODENOTCORR=1
    echo -e "\033[0;31m
    nodejs is NOT correctly installed ***\033[0m";
    else
    echo "";
    fi
    echo "";
    apt-cache policy nodejs;
    echo "";
    npm doctor can be misleading, deactivated to avoid confusion
    echo -e "Calling 'npm doctor' for you. \033[32mPlease be patient!\033[0m";
    echo "";
    (cd /opt/iobroker && sudo -H -u iobroker npm doctor);
    echo "";
    echo "The recommended versions for ioBroker are nodeJS v$NODERECOM / npm v$NPMRECOM!";
    echo "Don't trust the doctor if he recommends different versions!"
    echo "";
    ANZNPMTMP=$(find /opt/iobroker/node_modules -type d -iname '.*-????????' ! -iname '.local-chromium' | wc -l);
    echo -e "\033[32mTemp directories causing npm8 problem:\033[0m ""$ANZNPMTMP""";
    if [[ $ANZNPMTMP -gt 0 ]]
    then
    echo -e "Some problems detected, please run \e[031miob fix\e[0m";
    else
    echo "No problems detected"
    fi;
    echo "";
    echo -e "Temp directories being cleaned up now find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium" -exec rm -rf {} \;";
    find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium" -exec rm -rf {} \ &> /dev/null;
    echo -e "\033[32m1 - Temp directories causing npm8 problem:\033[0m `find /opt/iobroker/node_modules -type d -iname '.*-????????' ! -iname '.local-chromium'>e;
    echo "";
    echo "Errors in npm tree:";
    cd /opt/iobroker && npm ls -a | grep ERR;
    echo "";
    echo -e "\033[34;107m*** ioBroker-Installation ***\033[0m";
    echo "";
    echo -e "\033[32mioBroker Status\033[0m";
    iobroker status;
    echo "";
    multihost detection - wip
    iobroker multihost status
    iobroker status all | grep MULTIHOSTSERVICE/enabled
    echo -e "\033[32mCore adapters versions\033[0m"
    echo -e "js-controller: \t$(iob -v)";
    echo -e "admin: \t\t$(iob version admin)";
    echo -e "javascript: \t$(iob version javascript)";
    echo "";
    echo -e "Adapters from github: \t$( (cd /opt/iobroker && npm ls | grep -c 'git') )";
    echo "";
    echo -e "\033[32mAdapter State\033[0m";
    iob list instances;
    echo "";
    echo -e "\033[32mEnabled adapters with bindings\033[0m";
    iob list instances | grep enabled | grep port ;
    echo "";
    echo -e "\033[32mioBroker-Repositories\033[0m";
    iob repo list;
    echo "";
    echo -e "\033[32mInstalled ioBroker-Instances\033[0m";
    iob update -i;
    echo "";
    echo -e "\033[32mObjects and States\033[0m";
    echo "Please stand by - This may take a while";
    IOBOBJECTS=$(iob list objects 2>/dev/null | wc -l);
    echo -e "Objects: \t$IOBOBJECTS";
    IOBSTATES=$(iob list states 2>/dev/null | wc -l);
    echo -e "States: \t$IOBSTATES";
    echo "";
    echo -e "\033[34;107m*** OS-Repositories and Updates ***\033[0m";
    sudo apt-get update 1>/dev/null && sudo apt-get update
    APT=$(apt-get upgrade -s |grep -P '^\d+ upgraded'|cut -d" " -f1)
    echo -e "Pending Updates: $APT";
    echo "";
    echo -e "\033[34;107m*** Listening Ports ***\033[0m";
    sudo netstat -tulpen #| sed -n '1,2p;/LISTEN/p';
    Alternativ - ss ist nicht ueberall installiert
    sudo ss -tulwp | grep LISTEN;
    echo "";
    echo -e "\033[34;107m*** Log File - Last 25 Lines ***\033[0m";
    echo "";
    iobroker logs --lines 25;
    tail -n 25 /opt/iobroker/log/iobroker.current.log;
    echo "";
    echo "```";
    echo "";
    echo -e "\033[33m============ Mark until here for C&P =============\033[0m";
    echo "";
    echo "iob diag has finished.";
    echo "";
    echo "";
    # read -p "For a Summary please press <Enter>";
    echo "Press any key for a summary";
    read -r -n 1 -s
    echo "";
    clear;
    echo "Copy text starting here:";
    echo "";
    echo "```";
    echo "======================= SUMMARY =======================";
    echo -e "\t\t\tv.$SKRIPTV"
    echo "";
    echo "";
    INSTENV=2
    elif [ "$SYSTDDVIRT" != "none" ]; then
    INSTENV=1
    else
    INSTENV=0
    fi;
    INSTENV2=$(
    if [[ $INSTENV -eq 2 ]]; then
    echo "Docker";
    elif [ $INSTENV -eq 1 ]; then
    echo "$SYSTDDVIRT";
    else
    echo "native";
    fi;)
    if [[ -f "$DOCKER" ]]; then
    else
    fi;
    else
    fi;
    echo "";
    echo -e "Installation: \t\t$INSTENV2";
    echo -e "Kernel: \t\t$(uname -m)";
    echo -e "Userland: \t\t$(dpkg --print-architecture)";
    echo -e "Timezone: \t\t$(cat /etc/timezone)"
    else
    echo -e "Timezone: \t\t$(timedatectl | grep zone | cut -c28-80)";
    fi;
    echo -e "User-ID: \t\t$EUID";
    echo -e "X-Server: \t\t$(if [[ $XORGTEST -gt 1 ]]; then echo "true";else echo "false";fi)";
    echo -e "";
    else
    echo -e "Boot Target: \t\t$(systemctl get-default)";
    fi;
    echo "";
    echo -e "Pending OS-Updates: \t$APT";
    echo -e "Pending iob updates: \t$(iob update -u | grep -c 'Updatable|Updateable')";
    echo "";
    echo "This system needs to be REBOOTED NOW!";
    echo "";
    fi
    echo "";
    echo -e "Nodejs-Installation: \t$( type -p nodejs ) \t$( nodejs -v )";
    echo -e "\t\t\t$(type -P node) \t\t$(node -v)";
    echo -e "\t\t\t$(type -P npm) \t\t$(npm -v)";
    echo -e "\t\t\t$(type -P npx) \t\t$(npx -v)";
    echo -e "\t\t\t$(type -P corepack) \t$(corepack -v)";
    echo -e "";
    echo -e "Recommended versions are nodejs ""$NODERECOM"" and npm ""$NPMRECOM""";
    if
    then
    echo "*** nodejs is NOT correctly installed ";
    echo "Wrong installation path detected. This needs to be fixed.";
    elif
    then
    echo -e "\033[0;31m
    elif
    then
    echo -e "\033[0;31m
    elif
    then
    echo -e "\033[0;31m
    elif
    then
    echo -e "\033[0;31m
    echo "Wrong installation path detected. This needs to be fixed";
    elif
    then
    echo -e "\033[0;31m
    echo "nodejs and node versions do not match. This needs to be fixed.";
    elif
    then
    echo -e "\033[0;31mnodejs is NOT correctly installed\033[0m";
    echo "npm and npx versions do not match. This needs to be fixed.";
    else
    echo "Your nodejs installation is correct";
    fi
    if [[ $NODENOTCORR -eq 1 ]];
    then
    echo "";
    echo "Please check";
    echo "https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian";
    echo "for more information on how to fix these errors."
    fi;
    echo "";
    echo -e "Total Memory: \t\tfree -h | awk '/^Mem:/{print $2}'";
    echo "MEMORY: ";
    free -ht --mega;
    echo "";
    echo -e "Active iob-Instances: \t$(iob list instances | grep -c ^+)";
    iob repo list | tail -n1;
    echo "";
    echo -e "ioBroker Core: \t\tjs-controller \t\t$(iob -v)";
    echo -e "\t\t\tadmin \t\t\t$(iob version admin)";
    echo "";
    echo -e "ioBroker Status: \t$(iobroker status)";
    echo "";
    iobroker status all | grep MULTIHOSTSERVICE/enabled;
    echo "Status admin and web instance:";
    iobroker list instances | grep 'admin.|system.adapter.web.'
    echo "";
    echo -e "Objects: \t\t$IOBOBJECTS";
    echo -e "States: \t\t$IOBSTATES";
    echo "";
    echo -e "Size of iob-Database:";
    echo "";
    find /opt/iobroker/iobroker-data -maxdepth 1 -type f -name *objects* -exec du -sh {} + |sort -rh | head -n 5;
    find /opt/iobroker/iobroker-data -maxdepth 1 -type f -name *states* -exec du -sh {} + |sort -rh | head -n 5;
    echo "";
    echo "";
    then
    echo -e "";
    echo -e "Some problems detected, please run \e[031miob fix\e[0m and try to have them fixed";
    echo -e "
    echo -e "";
    else
    echo ""
    fi;
    echo "=================== END OF SUMMARY ===================="
    echo -e "```";
    echo "";
    echo "=== Mark text until here for copying ===";
    D Thomas BraunT 2 Antworten Letzte Antwort
    • D dg19222
      @thomas-braun ```
      #!/bin/bash
      if [ -f "$DOCKER" ]
      then
      echo "";
      then
      exit 1
      fi
      clear;
      VARIABLES
      export LC_ALL=C;
      HOST=$(hostname)
      APT=0;
      INSTENV=0;
      INSTENV2=0;
      SYSTDDVIRT="";
      NODENOTCORR=0;
      clear;
      echo "";
      echo "";
      echo "";
      echo "";
      echo "";
      echo "";
      read -r -n 1 -s
      clear;
      echo "";
      echo "";
      echo "```";
      echo "";
      else
      echo "";
      fi;
      else
      fi
      else
      fi;
      echo "";
      uptime;
      echo "";
      RASPBERRY only
      TEST CODE
      echo "";
      ISSUES_MAP=(
      HEX_BIN_MAP=(
      ["0"]="0000"
      ["1"]="0001"
      ["2"]="0010"
      ["3"]="0011"
      ["4"]="0100"
      ["5"]="0101"
      ["6"]="0110"
      ["7"]="0111"
      ["8"]="1000"
      ["9"]="1001"
      ["A"]="1010"
      ["B"]="1011"
      ["C"]="1100"
      ["D"]="1101"
      ["E"]="1110"
      ["F"]="1111"
      IFS='x'
      else
      bit_n=0
      bit_n=$((bit_n+1))
      fi
      done
      fi
      echo ""
      Display past issues
      else
      bit_n=16
      bit_n=$((bit_n+1))
      fi
      done
      fi
      fi
      echo "";
      echo "";
      fi
      echo "";
      date -u;
      date;
      date +"%Z %z";
      cat /etc/timezone;
      else
      timedatectl;
      fi;
      echo "";
      whoami;
      echo "$HOME";
      groups;
      echo "";
      then
      else
      fi
      echo -e "";
      else
      fi;
      echo "";
      free -th --mega;
      echo "";
      RASPBERRY only
      echo "";
      vcgencmd mem_oom;
      fi;
      echo "";
      else
      echo "";
      echo "";
      echo "";
      fi;
      df -PTh;
      echo "";
      echo "";
      findmnt --real;
      echo "";
      echo "";
      fi
      echo "";
      echo -e "";
      echo -e ""
      else
      fi;
      echo "";
      echo "";
      echo "";
      echo "";
      echo "";
      echo "";
      echo "";
      VERNODE=$(node -v);
      VERNPM=$(npm -v);
      VERNPX=$(npx -v);
      if
      then
      NODENOTCORR=1
      elif
      then
      NODENOTCORR=1
      echo -e "\033[0;31m
      elif
      then
      NODENOTCORR=1
      echo -e "\033[0;31m
      elif
      then
      NODENOTCORR=1
      echo -e "\033[0;31m
      elif
      then
      NODENOTCORR=1
      echo -e "\033[0;31m
      elif
      then
      NODENOTCORR=1
      echo -e "\033[0;31m
      elif
      then
      NODENOTCORR=1
      echo -e "\033[0;31m
      else
      echo "";
      fi
      echo "";
      echo "";
      echo "";
      echo "";
      echo "";
      then
      else
      fi;
      echo "";
      echo "";
      echo "";
      echo "";
      iobroker status;
      echo "";
      echo "";
      echo "";
      iob list instances;
      echo "";
      echo "";
      iob repo list;
      echo "";
      iob update -i;
      echo "";
      echo "";
      echo "";
      echo "";
      echo "";
      echo "";
      echo "```";
      echo "";
      echo "";
      echo "";
      echo "";
      read -r -n 1 -s
      echo "";
      clear;
      echo "";
      echo "```";
      echo "";
      echo "";
      INSTENV=2
      INSTENV=1
      else
      INSTENV=0
      fi;
      INSTENV2=$(
      echo "Docker";
      echo "$SYSTDDVIRT";
      else
      echo "native";
      fi;)
      else
      fi;
      else
      fi;
      echo "";
      else
      fi;
      echo -e "";
      else
      fi;
      echo "";
      echo "";
      echo "";
      fi
      echo "";
      echo -e "";
      if
      then
      elif
      then
      echo -e "\033[0;31m
      elif
      then
      echo -e "\033[0;31m
      elif
      then
      echo -e "\033[0;31m
      elif
      then
      echo -e "\033[0;31m
      elif
      then
      echo -e "\033[0;31m
      elif
      then
      else
      fi
      then
      echo "";
      fi;
      echo "";
      echo "MEMORY: ";
      free -ht --mega;
      echo "";
      echo "";
      echo "";
      echo "";
      echo "";
      echo "";
      echo "";
      echo "";
      echo "";
      then
      echo -e "";
      echo -e "
      echo -e "";
      else
      echo ""
      fi;
      echo -e "```";
      echo "";
      dg19222
      @dg19222 ich kann damit leider sehr wenig anfangen :-)
      • D dg19222
        @thomas-braun ```
        #!/bin/bash
        if [ -f "$DOCKER" ]
        then
        echo "";
        then
        exit 1
        fi
        clear;
        VARIABLES
        export LC_ALL=C;
        HOST=$(hostname)
        APT=0;
        INSTENV=0;
        INSTENV2=0;
        SYSTDDVIRT="";
        NODENOTCORR=0;
        clear;
        echo "";
        echo "";
        echo "";
        echo "";
        echo "";
        echo "";
        read -r -n 1 -s
        clear;
        echo "";
        echo "";
        echo "```";
        echo "";
        else
        echo "";
        fi;
        else
        fi
        else
        fi;
        echo "";
        uptime;
        echo "";
        RASPBERRY only
        TEST CODE
        echo "";
        ISSUES_MAP=(
        HEX_BIN_MAP=(
        ["0"]="0000"
        ["1"]="0001"
        ["2"]="0010"
        ["3"]="0011"
        ["4"]="0100"
        ["5"]="0101"
        ["6"]="0110"
        ["7"]="0111"
        ["8"]="1000"
        ["9"]="1001"
        ["A"]="1010"
        ["B"]="1011"
        ["C"]="1100"
        ["D"]="1101"
        ["E"]="1110"
        ["F"]="1111"
        IFS='x'
        else
        bit_n=0
        bit_n=$((bit_n+1))
        fi
        done
        fi
        echo ""
        Display past issues
        else
        bit_n=16
        bit_n=$((bit_n+1))
        fi
        done
        fi
        fi
        echo "";
        echo "";
        fi
        echo "";
        date -u;
        date;
        date +"%Z %z";
        cat /etc/timezone;
        else
        timedatectl;
        fi;
        echo "";
        whoami;
        echo "$HOME";
        groups;
        echo "";
        then
        else
        fi
        echo -e "";
        else
        fi;
        echo "";
        free -th --mega;
        echo "";
        RASPBERRY only
        echo "";
        vcgencmd mem_oom;
        fi;
        echo "";
        else
        echo "";
        echo "";
        echo "";
        fi;
        df -PTh;
        echo "";
        echo "";
        findmnt --real;
        echo "";
        echo "";
        fi
        echo "";
        echo -e "";
        echo -e ""
        else
        fi;
        echo "";
        echo "";
        echo "";
        echo "";
        echo "";
        echo "";
        echo "";
        VERNODE=$(node -v);
        VERNPM=$(npm -v);
        VERNPX=$(npx -v);
        if
        then
        NODENOTCORR=1
        elif
        then
        NODENOTCORR=1
        echo -e "\033[0;31m
        elif
        then
        NODENOTCORR=1
        echo -e "\033[0;31m
        elif
        then
        NODENOTCORR=1
        echo -e "\033[0;31m
        elif
        then
        NODENOTCORR=1
        echo -e "\033[0;31m
        elif
        then
        NODENOTCORR=1
        echo -e "\033[0;31m
        elif
        then
        NODENOTCORR=1
        echo -e "\033[0;31m
        else
        echo "";
        fi
        echo "";
        echo "";
        echo "";
        echo "";
        echo "";
        then
        else
        fi;
        echo "";
        echo "";
        echo "";
        echo "";
        iobroker status;
        echo "";
        echo "";
        echo "";
        iob list instances;
        echo "";
        echo "";
        iob repo list;
        echo "";
        iob update -i;
        echo "";
        echo "";
        echo "";
        echo "";
        echo "";
        echo "";
        echo "```";
        echo "";
        echo "";
        echo "";
        echo "";
        read -r -n 1 -s
        echo "";
        clear;
        echo "";
        echo "```";
        echo "";
        echo "";
        INSTENV=2
        INSTENV=1
        else
        INSTENV=0
        fi;
        INSTENV2=$(
        echo "Docker";
        echo "$SYSTDDVIRT";
        else
        echo "native";
        fi;)
        else
        fi;
        else
        fi;
        echo "";
        else
        fi;
        echo -e "";
        else
        fi;
        echo "";
        echo "";
        echo "";
        fi
        echo "";
        echo -e "";
        if
        then
        elif
        then
        echo -e "\033[0;31m
        elif
        then
        echo -e "\033[0;31m
        elif
        then
        echo -e "\033[0;31m
        elif
        then
        echo -e "\033[0;31m
        elif
        then
        echo -e "\033[0;31m
        elif
        then
        else
        fi
        then
        echo "";
        fi;
        echo "";
        echo "MEMORY: ";
        free -ht --mega;
        echo "";
        echo "";
        echo "";
        echo "";
        echo "";
        echo "";
        echo "";
        echo "";
        echo "";
        then
        echo -e "";
        echo -e "
        echo -e "";
        else
        echo ""
        fi;
        echo -e "```";
        echo "";
        @dg19222
        Wo hab ich denn geschrieben, dass du den Code per curl herunterladen sollst?
        iob diag
        eingeben, fertig.
          @dg19222
          iob diag
          eingeben, fertig.
          dg19222
          @thomas-braun ging net da kam die meldung das ich es runterladen mus
          wenn ich es jetzt eingeben will will er sudo passwort das ich leider vergessen habe
          • D dg19222
            Das ist schlecht. Aber wie pflegst du denn dein System, ohne Passwort?
            (Ich glaube, ich möchte die Antwort gar nicht wissen...)
              dg19222
              @thomas-braun das ging bis dato
              • D dg19222
                dg19222
                @dg19222 Node is v18.19.0
                npm is v10.2.3
                • D dg19222
                  npm is v10.2.3
                  @dg19222
                  Und der Rest vom Fest?
                    @dg19222
                    dg19222
                    sag mir was du brauchst und ich schike es dir
                    • D dg19222
                      @dg19222
                      Die Ausgabe von
                      iob diag
                        dg19222
                        ok da komme ich leider net ran dann mus es halt leider ohne den adapter gehn
                        danke dir für die mühe
                        • D dg19222
                          Warum nicht?
                          Wenn da nodejs 18.19.0 installiert ist muss ja ein PW für den root vorhanden sein, sonst bekommt man das nicht ordentlich auf das System.
                          Und der root kann natürlich neue PW an die user vergeben.
                            Warum nicht?
                            dg19222
                            habe das system gestern aufgesetzt ging alles mit meinem pw nur das net
                            • D dg19222
                              @dg19222
                              Dann ist das wohl schief aufgesetzt, denn iob diag funktioniert natürlich grundsätzlich.
                                @dg19222
                                dg19222
                                @thomas-braun ok wenn du meinst komisch das alles andere geht aber trozdem danke
                                • D dg19222
                                  dg19222
                                  @dg19222 ich kann es netmal als root ausführen
                                  root@Iobrocker:/opt/iobroker# iob diag
                                  root@Iobrocker:/opt/iobroker# su dg19222
                                  dg19222@Iobrocker:/opt/iobroker$ iob diag
                                  [sudo] password for dg19222:
                                  Sorry, user dg19222 is not allowed to execute '/usr/bin/curl -sLf https://ioer.net/diag.sh --output /home/iobroker/.diag.sh' as iobroker on Iobrocker.
                                  • D dg19222
                                    Richtig. Das muss ja auch als user ausgeführt werden, direkt als root macht man eh nichts, man meldet sich nicht mal als root an.
                                    Dem user 'dg19222' fehlen wohl die notwendigen Rechte.
                                    groups
                                    sagt?
                                    Und genau das meine ich mit 'schief aufgesetzt'.
                                      groups
                                      sagt?
                                      dg19222
                                      dg19222 cdrom floppy audio dip video plugdev users netdev bluetoot
                                      • D dg19222
                                        @dg19222
                                        Der user fehlt in den Gruppen sudo, dialout und iobroker.
                                        Als root:
                                        apt update
                                        apt install sudo
                                        usermod -a -G sudo,dialout,iobroker dg19222
                                        exit
                                        Den dg19222 aus- und wieder einloggen, niemehr als root herumhampeln.
                                          @dg19222
                                          Als root:
                                          apt update
                                          apt install sudo
                                          exit
                                          dg19222
                                          root@Iobrocker:/opt/iobroker# usermod -a -G sudo,dialout,iobroker dg19222
                                          bash: usermod: command not found
