  4. IKEA Trådfri The security code is incorrect or
34 Beiträge 2 Kommentatoren 3.0k Aufrufe 2 Beobachtet
    dg19222
    Huhu alle zusammen
    The security code is incorrect or something else went wrong with the authentication.
    Hat wer ne idee habe schon alles möglich probiert. Security code ist definitiv richtig. Mehrere Neustarts des Adapters des Iobrokers, und des getways.
    LG Daniel
    • D dg19222
      Huhu alle zusammen
      LG Daniel
      @dg19222
      Versionen? Log?
        @dg19222
        Versionen? Log?
        dg19222
        @thomas-braun Version V 3.1.3
        2023-12-13 13:10:20.886 - error: tradfri.0 (2090) The security code is incorrect or something else went wrong with the authentication.
        2023-12-13 13:10:20.887 - error: tradfri.0 (2090) Please check your adapter settings and restart the adapter!
        reicht dir das oder brauchst mehr?
        Danke für dein hilfe
        • D dg19222
          @dg19222 sagte in IKEA Trådfri The security code is incorrect or:
          Das mal getan? Denn hier läuft der Adapter einwandfrei.
          Schau dir ggf.
          iob diag
          an.
            Schau dir ggf.
            iob diag
            an.
            dg19222
            @thomas-braun ```
            dg19222@Iobrocker:~$ curl -sLf https://iobroker.net/diag.sh
            #!/bin/bash
            iobroker diagnostics
            written to help getting information about the environment the ioBroker installation is running in
            DOCKER=/opt/scripts/.docker_config/.thisisdocker
            #if [[ -f "/opt/scripts/.docker_config/.thisisdocker" ]]
            if [ -f "$DOCKER" ]
            then
            echo "";
            elif [ "$(id -u)" = 0 ];
            then
            echo -e "This script must not be run as root! \nPlease use your standard user!"
            exit 1
            fi
            clear;
            echo "*** iob diag is starting up, please wait ***";
            VARIABLES
            export LC_ALL=C;
            SKRIPTV="2023-10-10"; #version of this script
            NODE_MAJOR=18 #this is the recommended major nodejs version for ioBroker, please adjust accordingly if the recommendation changes
            HOST=$(hostname)
            NODERECOM=$(iobroker state getValue system.host."$HOST".versions.nodeNewestNext); #recommended node version
            NPMRECOM=$(iobroker state getValue system.host."$HOST".versions.npmNewestNext); #recommended npm version
            NODEUSED=$(iobroker state getValue system.host."$HOST".versions.nodeCurrent); #current node version in use
            #NPMUSED=$(iobroker state getValue system.host."$HOST".versions.npmCurrent); #current npm version in use
            XORGTEST=0; #test for GUI
            APT=0;
            INSTENV=0;
            INSTENV2=0;
            SYSTDDVIRT="";
            NODENOTCORR=0;
            clear;
            echo "";
            echo -e "\033[34;107m*** ioBroker Diagnosis \033[0m";
            echo "";
            echo "Please stretch the window of your terminal programm (puTTY) as wide as possible or switch to full screen";
            echo "";
            echo "The following checks may give hints to potential malconfigurations or errors, please post them in our forum:";
            echo "";
            echo "https://forum.iobroker.net";
            echo "";
            echo "Just copy and paste the Summary Page, including the ``` characters at start and end.";
            echo "It helps us to help you!"
            echo "";
            # read -p "Press <Enter> to continue";
            echo "Press any key to continue";
            read -r -n 1 -s
            clear;
            echo "";
            echo -e "\033[33m======== Start marking the full check here =========\033[0m";
            echo "";
            echo "```";
            echo "Skript v.$SKRIPTV"
            echo "";
            BASE SYSTEM ***\033[0m";
            if [ -f "$DOCKER" ]; then
            echo -e "Hardware Vendor : $(cat /sys/devices/virtual/dmi/id/sys_vendor)";
            echo -e "Kernel : $(uname -m)";
            echo -e "Userland : $(dpkg --print-architecture)";
            echo -e "Docker : $(cat /opt/scripts/.docker_config/.thisisdocker)"
            else
            hostnamectl | grep -v 'Machine|Boot';
            echo "";
            grep -i model /proc/cpuinfo | tail -1;
            echo -e "Docker : false";
            fi;
            Alternativer DockerCheck - Nicht getestet:
            if [ -f /.dockerenv ]; then
            echo "I'm inside matrix ;(";
            else
            echo "I'm living in real world!";
            fi
            SYSTDDVIRT=$(systemd-detect-virt 2>/dev/null)
            if [ "$SYSTDDVIRT" != "" ]; then
            echo -e "Virtualization : $(systemd-detect-virt)"
            else
            echo "Virtualization : Docker"
            fi;
            echo "";
            echo "Systemuptime and Load:";
            uptime;
            echo "CPU threads: $(grep -c processor /proc/cpuinfo)"
            echo "";
            RASPBERRY only
            if [[ $(type -P "vcgencmd" 2>/dev/null) = *"/vcgencmd" ]]; then
            echo "Raspberry only:";
            vcgencmd get_throttled 2> /dev/null;
            echo "Other values than 0x0 hint to temperature/voltage problems";
            vcgencmd measure_temp;
            vcgencmd measure_volts;
            TEST CODE
            echo "";
            echo -e "\033[34;107m*** RASPBERRY THROTTLING ***\033[0m";
            CODE from https://github.com/alwye/get_throttled under MIT Licence
            ISSUES_MAP=(
            [0]="Under-voltage detected"
            [1]="Arm frequency capped"
            [2]="Currently throttled"
            [3]="Soft temperature limit active"
            [16]="Under-voltage has occurred"
            [17]="Arm frequency capping has occurred"
            [18]="Throttling has occurred"
            [19]="Soft temperature limit has occurred")
            HEX_BIN_MAP=(
            ["0"]="0000"
            ["1"]="0001"
            ["2"]="0010"
            ["3"]="0011"
            ["4"]="0100"
            ["5"]="0101"
            ["6"]="0110"
            ["7"]="0111"
            ["8"]="1000"
            ["9"]="1001"
            ["A"]="1010"
            ["B"]="1011"
            ["C"]="1100"
            ["D"]="1101"
            ["E"]="1110"
            ["F"]="1111"
            THROTTLED_OUTPUT=$(vcgencmd get_throttled)
            IFS='x'
            read -r -a strarr <<< "$THROTTLED_OUTPUT"
            THROTTLED_CODE_HEX=${strarr[1]}
            Display current issues
            echo "Current issues:"
            CURRENT_HEX=${THROTTLED_CODE_HEX:4:1}
            CURRENT_BIN=${HEX_BIN_MAP[$CURRENT_HEX]}
            if [ "$CURRENT_HEX" == "0" ] || [ -z "$CURRENT_HEX" ]; then
            echo "No throttling issues detected."
            else
            bit_n=0
            for (( i=${#CURRENT_BIN}-1; i>=0; i--)); do
            if [ "${CURRENT_BIN:$i:1}" = "1" ]; then
            echo "~ ${ISSUES_MAP[$bit_n]}"
            bit_n=$((bit_n+1))
            fi
            done
            fi
            echo ""
            Display past issues
            echo "Previously detected issues:"
            PAST_HEX=${THROTTLED_CODE_HEX:0:1}
            PAST_BIN=${HEX_BIN_MAP[$PAST_HEX]}
            if [ "$PAST_HEX" = "0" ]; then
            else
            bit_n=16
            for (( i=${#PAST_BIN}-1; i>=0; i--)); do
            if [ "${PAST_BIN:$i:1}" = "1" ]; then
            bit_n=$((bit_n+1))
            fi
            done
            fi
            fi
            if [[ -f "/var/run/reboot-required" ]]; then
            echo "";
            echo "This system needs to be REBOOTED!";
            echo "";
            fi
            echo "";
            echo -e "\033[34;107m*** Time and Time Zones ***\033[0m";
            date -u;
            date;
            date +"%Z %z";
            cat /etc/timezone;
            else
            timedatectl;
            fi;
            echo "";
            echo -e "\033[34;107m*** User and Groups \033[0m";
            whoami;
            echo "$HOME";
            groups;
            echo "";
            X-Server-Setup ***\033[0m";
            XORGTEST=$(pgrep -f "Xorg")
            XORGTEST=$(ps aux | grep -c 'Xorg')
            if [[ "$XORGTEST" -gt 1 ]];
            then
            echo -e "X-Server: \ttrue"
            else
            echo -e "X-Server: \tfalse"
            fi
            echo -e "Desktop: \t$DESKTOP_SESSION";
            echo -e "Terminal: \t$XDG_SESSION_TYPE";
            echo -e "";
            else
            echo -e "Boot Target: \t$(systemctl get-default)";
            fi;
            echo "";
            echo -e "\033[34;107m*** MEMORY ***\033[0m";
            free -th --mega;
            echo "";
            vmstat -S M -s | head -n 10;
            RASPBERRY only
            echo "";
            vcgencmd mem_oom;
            fi;
            echo "";
            else
            echo "";
            echo -e "\033[34;107m*** FAILED SERVICES \033[0m";
            echo "";
            systemctl list-units --failed --no-pager;
            echo "";
            fi;
            FILESYSTEM ***\033[0m";
            df -PTh;
            echo "";
            echo -e "\033[32mMessages concerning ext4 filesystem in dmesg:\033[0m";
            sudo dmesg -T | grep -i ext4;
            echo "";
            echo -e "\033[32mShow mounted filesystems (real ones only):\033[0m";
            findmnt --real;
            echo "";
            if [[ -L "/opt/iobroker/backups" ]]; then
            echo "backups directory is linked to a different directory";
            echo "";
            fi
            echo -e "\033[32mFiles in neuralgic directories:\033[0m";
            echo "";
            echo -e "\033[32m/var:\033[0m";
            sudo du -h /var/ | sort -rh | head -5;
            echo -e "";
            echo -e ""
            else
            journalctl --disk-usage;
            fi;
            echo "";
            echo -e "\033[32m/opt/iobroker/backups:\033[0m";
            du -h /opt/iobroker/backups/ | sort -rh | head -5;
            echo "";
            echo -e "\033[32m/opt/iobroker/iobroker-data:\033[0m";
            du -h /opt/iobroker/iobroker-data/ | sort -rh | head -5;
            echo "";
            echo -e "\033[32mThe five largest files in iobroker-data are:\033[0m";
            find /opt/iobroker/iobroker-data -maxdepth 15 -type f -exec du -sh {} + | sort -rh | head -n 5;
            echo "";
            Detecting dev-links in /dev/serial/by-id
            echo -e "\033[32mUSB-Devices by-id:\033[0m";
            echo "USB-Sticks - Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id':";
            echo "";
            find /dev/serial/by-id/ -maxdepth 1 -mindepth 1;
            echo "";
            echo -e "\033[34;107m*** NodeJS-Installation ***\033[0m";
            echo "";
            echo -e "$(type -p nodejs) \t$(nodejs -v)";
            echo -e "$(type -p node) \t\t$(node -v)";
            echo -e "$(type -p npm) \t\t$(npm -v)";
            echo -e "$(type -p npx) \t\t$(npx -v)";
            echo -e "$(type -p corepack) \t$(corepack -v)";
            PATHAPT=$(type -p apt);
            PATHNODEJS=$(type -p nodejs);
            PATHNODE=$(type -p node);
            PATHNPM=$(type -p npm);
            PATHNPX=$(type -p npx);
            PATHCOREPACK=$(type -p corepack);
            VERNODEJS=$(nodejs -v);
            VERNODE=$(node -v);
            VERNPM=$(npm -v);
            VERNPX=$(npx -v);
            #VERCOREPACK=$(corepack -v);
            if
            [[ $PATHNODEJS != "/usr/bin/nodejs" ]];
            then
            NODENOTCORR=1
            echo -e "\033[0;31m*** nodejs is NOT correctly installed \033[0m";
            elif
            [[ $PATHNODE != "/usr/bin/node" ]];
            then
            NODENOTCORR=1
            echo -e "\033[0;31m
            elif
            [[ $PATHNPM != "/usr/bin/npm" ]];
            then
            NODENOTCORR=1
            echo -e "\033[0;31m
            elif
            [[ $PATHNPX != "/usr/bin/npx" ]];
            then
            NODENOTCORR=1
            echo -e "\033[0;31m
            elif
            [[ $VERNODEJS != "$VERNODE" ]];
            then
            NODENOTCORR=1
            echo -e "\033[0;31m
            elif
            [[ $VERNPM != "$VERNPX" ]];
            then
            NODENOTCORR=1
            echo -e "\033[0;31m
            elif
            [[ $PATHCOREPACK != "/usr/bin/corepack" ]];
            then
            NODENOTCORR=1
            echo -e "\033[0;31m
            nodejs is NOT correctly installed ***\033[0m";
            else
            echo "";
            fi
            echo "";
            apt-cache policy nodejs;
            echo "";
            npm doctor can be misleading, deactivated to avoid confusion
            echo -e "Calling 'npm doctor' for you. \033[32mPlease be patient!\033[0m";
            echo "";
            (cd /opt/iobroker && sudo -H -u iobroker npm doctor);
            echo "";
            echo "The recommended versions for ioBroker are nodeJS v$NODERECOM / npm v$NPMRECOM!";
            echo "Don't trust the doctor if he recommends different versions!"
            echo "";
            ANZNPMTMP=$(find /opt/iobroker/node_modules -type d -iname '.*-????????' ! -iname '.local-chromium' | wc -l);
            echo -e "\033[32mTemp directories causing npm8 problem:\033[0m ""$ANZNPMTMP""";
            if [[ $ANZNPMTMP -gt 0 ]]
            then
            echo -e "Some problems detected, please run \e[031miob fix\e[0m";
            else
            echo "No problems detected"
            fi;
            echo "";
            echo -e "Temp directories being cleaned up now find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium" -exec rm -rf {} \;";
            find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium" -exec rm -rf {} \ &> /dev/null;
            echo -e "\033[32m1 - Temp directories causing npm8 problem:\033[0m `find /opt/iobroker/node_modules -type d -iname '.*-????????' ! -iname '.local-chromium'>e;
            echo "";
            echo "Errors in npm tree:";
            cd /opt/iobroker && npm ls -a | grep ERR;
            echo "";
            echo -e "\033[34;107m*** ioBroker-Installation ***\033[0m";
            echo "";
            echo -e "\033[32mioBroker Status\033[0m";
            iobroker status;
            echo "";
            multihost detection - wip
            iobroker multihost status
            iobroker status all | grep MULTIHOSTSERVICE/enabled
            echo -e "\033[32mCore adapters versions\033[0m"
            echo -e "js-controller: \t$(iob -v)";
            echo -e "admin: \t\t$(iob version admin)";
            echo -e "javascript: \t$(iob version javascript)";
            echo "";
            echo -e "Adapters from github: \t$( (cd /opt/iobroker && npm ls | grep -c 'git') )";
            echo "";
            echo -e "\033[32mAdapter State\033[0m";
            iob list instances;
            echo "";
            echo -e "\033[32mEnabled adapters with bindings\033[0m";
            iob list instances | grep enabled | grep port ;
            echo "";
            echo -e "\033[32mioBroker-Repositories\033[0m";
            iob repo list;
            echo "";
            echo -e "\033[32mInstalled ioBroker-Instances\033[0m";
            iob update -i;
            echo "";
            echo -e "\033[32mObjects and States\033[0m";
            echo "Please stand by - This may take a while";
            IOBOBJECTS=$(iob list objects 2>/dev/null | wc -l);
            echo -e "Objects: \t$IOBOBJECTS";
            IOBSTATES=$(iob list states 2>/dev/null | wc -l);
            echo -e "States: \t$IOBSTATES";
            echo "";
            echo -e "\033[34;107m*** OS-Repositories and Updates ***\033[0m";
            sudo apt-get update 1>/dev/null && sudo apt-get update
            APT=$(apt-get upgrade -s |grep -P '^\d+ upgraded'|cut -d" " -f1)
            echo -e "Pending Updates: $APT";
            echo "";
            echo -e "\033[34;107m*** Listening Ports ***\033[0m";
            sudo netstat -tulpen #| sed -n '1,2p;/LISTEN/p';
            Alternativ - ss ist nicht ueberall installiert
            sudo ss -tulwp | grep LISTEN;
            echo "";
            echo -e "\033[34;107m*** Log File - Last 25 Lines ***\033[0m";
            echo "";
            iobroker logs --lines 25;
            tail -n 25 /opt/iobroker/log/iobroker.current.log;
            echo "";
            echo "```";
            echo "";
            echo -e "\033[33m============ Mark until here for C&P =============\033[0m";
            echo "";
            echo "iob diag has finished.";
            echo "";
            echo "";
            # read -p "For a Summary please press <Enter>";
            echo "Press any key for a summary";
            read -r -n 1 -s
            echo "";
            clear;
            echo "Copy text starting here:";
            echo "";
            echo "```";
            echo "======================= SUMMARY =======================";
            echo -e "\t\t\tv.$SKRIPTV"
            echo "";
            echo "";
            INSTENV=2
            elif [ "$SYSTDDVIRT" != "none" ]; then
            INSTENV=1
            else
            INSTENV=0
            fi;
            INSTENV2=$(
            if [[ $INSTENV -eq 2 ]]; then
            echo "Docker";
            elif [ $INSTENV -eq 1 ]; then
            echo "$SYSTDDVIRT";
            else
            echo "native";
            fi;)
            if [[ -f "$DOCKER" ]]; then
            else
            fi;
            else
            fi;
            echo "";
            echo -e "Installation: \t\t$INSTENV2";
            echo -e "Kernel: \t\t$(uname -m)";
            echo -e "Userland: \t\t$(dpkg --print-architecture)";
            echo -e "Timezone: \t\t$(cat /etc/timezone)"
            else
            echo -e "Timezone: \t\t$(timedatectl | grep zone | cut -c28-80)";
            fi;
            echo -e "User-ID: \t\t$EUID";
            echo -e "X-Server: \t\t$(if [[ $XORGTEST -gt 1 ]]; then echo "true";else echo "false";fi)";
            echo -e "";
            else
            echo -e "Boot Target: \t\t$(systemctl get-default)";
            fi;
            echo "";
            echo -e "Pending OS-Updates: \t$APT";
            echo -e "Pending iob updates: \t$(iob update -u | grep -c 'Updatable|Updateable')";
            echo "";
            echo "This system needs to be REBOOTED NOW!";
            echo "";
            fi
            echo "";
            echo -e "Nodejs-Installation: \t$( type -p nodejs ) \t$( nodejs -v )";
            echo -e "\t\t\t$(type -P node) \t\t$(node -v)";
            echo -e "\t\t\t$(type -P npm) \t\t$(npm -v)";
            echo -e "\t\t\t$(type -P npx) \t\t$(npx -v)";
            echo -e "\t\t\t$(type -P corepack) \t$(corepack -v)";
            echo -e "";
            echo -e "Recommended versions are nodejs ""$NODERECOM"" and npm ""$NPMRECOM""";
            if
            then
            echo "*** nodejs is NOT correctly installed ";
            echo "Wrong installation path detected. This needs to be fixed.";
            elif
            then
            echo -e "\033[0;31m
            elif
            then
            echo -e "\033[0;31m
            elif
            then
            echo -e "\033[0;31m
            elif
            then
            echo -e "\033[0;31m
            echo "Wrong installation path detected. This needs to be fixed";
            elif
            then
            echo -e "\033[0;31m
            echo "nodejs and node versions do not match. This needs to be fixed.";
            elif
            then
            echo -e "\033[0;31mnodejs is NOT correctly installed\033[0m";
            echo "npm and npx versions do not match. This needs to be fixed.";
            else
            echo "Your nodejs installation is correct";
            fi
            if [[ $NODENOTCORR -eq 1 ]];
            then
            echo "";
            echo "Please check";
            echo "https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian";
            echo "for more information on how to fix these errors."
            fi;
            echo "";
            echo -e "Total Memory: \t\tfree -h | awk '/^Mem:/{print $2}'";
            echo "MEMORY: ";
            free -ht --mega;
            echo "";
            echo -e "Active iob-Instances: \t$(iob list instances | grep -c ^+)";
            iob repo list | tail -n1;
            echo "";
            echo -e "ioBroker Core: \t\tjs-controller \t\t$(iob -v)";
            echo -e "\t\t\tadmin \t\t\t$(iob version admin)";
            echo "";
            echo -e "ioBroker Status: \t$(iobroker status)";
            echo "";
            iobroker status all | grep MULTIHOSTSERVICE/enabled;
            echo "Status admin and web instance:";
            iobroker list instances | grep 'admin.|system.adapter.web.'
            echo "";
            echo -e "Objects: \t\t$IOBOBJECTS";
            echo -e "States: \t\t$IOBSTATES";
            echo "";
            echo -e "Size of iob-Database:";
            echo "";
            find /opt/iobroker/iobroker-data -maxdepth 1 -type f -name *objects* -exec du -sh {} + |sort -rh | head -n 5;
            find /opt/iobroker/iobroker-data -maxdepth 1 -type f -name *states* -exec du -sh {} + |sort -rh | head -n 5;
            echo "";
            echo "";
            then
            echo -e "";
            echo -e "Some problems detected, please run \e[031miob fix\e[0m and try to have them fixed";
            echo -e "
            echo -e "";
            else
            echo ""
            fi;
            echo "=================== END OF SUMMARY ===================="
            echo -e "```";
            echo "";
            echo "=== Mark text until here for copying ===";
            D Thomas BraunT 2 Antworten Letzte Antwort
            • D dg19222
              @thomas-braun ```
              #!/bin/bash
              if [ -f "$DOCKER" ]
              then
              echo "";
              then
              exit 1
              fi
              clear;
              VARIABLES
              export LC_ALL=C;
              HOST=$(hostname)
              APT=0;
              INSTENV=0;
              INSTENV2=0;
              SYSTDDVIRT="";
              NODENOTCORR=0;
              clear;
              echo "";
              echo "";
              echo "";
              echo "";
              echo "";
              echo "";
              read -r -n 1 -s
              clear;
              echo "";
              echo "";
              echo "```";
              echo "";
              else
              echo "";
              fi;
              else
              fi
              else
              fi;
              echo "";
              uptime;
              echo "";
              RASPBERRY only
              TEST CODE
              echo "";
              ISSUES_MAP=(
              HEX_BIN_MAP=(
              ["0"]="0000"
              ["1"]="0001"
              ["2"]="0010"
              ["3"]="0011"
              ["4"]="0100"
              ["5"]="0101"
              ["6"]="0110"
              ["7"]="0111"
              ["8"]="1000"
              ["9"]="1001"
              ["A"]="1010"
              ["B"]="1011"
              ["C"]="1100"
              ["D"]="1101"
              ["E"]="1110"
              ["F"]="1111"
              IFS='x'
              else
              bit_n=0
              bit_n=$((bit_n+1))
              fi
              done
              fi
              echo ""
              Display past issues
              else
              bit_n=16
              bit_n=$((bit_n+1))
              fi
              done
              fi
              fi
              echo "";
              echo "";
              fi
              echo "";
              date -u;
              date;
              date +"%Z %z";
              cat /etc/timezone;
              else
              timedatectl;
              fi;
              echo "";
              whoami;
              echo "$HOME";
              groups;
              echo "";
              then
              else
              fi
              echo -e "";
              else
              fi;
              echo "";
              free -th --mega;
              echo "";
              RASPBERRY only
              echo "";
              vcgencmd mem_oom;
              fi;
              echo "";
              else
              echo "";
              echo "";
              echo "";
              fi;
              df -PTh;
              echo "";
              echo "";
              findmnt --real;
              echo "";
              echo "";
              fi
              echo "";
              echo -e "";
              echo -e ""
              else
              fi;
              echo "";
              echo "";
              echo "";
              echo "";
              echo "";
              echo "";
              echo "";
              VERNODE=$(node -v);
              VERNPM=$(npm -v);
              VERNPX=$(npx -v);
              if
              then
              NODENOTCORR=1
              elif
              then
              NODENOTCORR=1
              echo -e "\033[0;31m
              elif
              then
              NODENOTCORR=1
              echo -e "\033[0;31m
              elif
              then
              NODENOTCORR=1
              echo -e "\033[0;31m
              elif
              then
              NODENOTCORR=1
              echo -e "\033[0;31m
              elif
              then
              NODENOTCORR=1
              echo -e "\033[0;31m
              elif
              then
              NODENOTCORR=1
              echo -e "\033[0;31m
              else
              echo "";
              fi
              echo "";
              echo "";
              echo "";
              echo "";
              echo "";
              then
              else
              fi;
              echo "";
              echo "";
              echo "";
              echo "";
              iobroker status;
              echo "";
              echo "";
              echo "";
              iob list instances;
              echo "";
              echo "";
              iob repo list;
              echo "";
              iob update -i;
              echo "";
              echo "";
              echo "";
              echo "";
              echo "";
              echo "";
              echo "```";
              echo "";
              echo "";
              echo "";
              echo "";
              read -r -n 1 -s
              echo "";
              clear;
              echo "";
              echo "```";
              echo "";
              echo "";
              INSTENV=2
              INSTENV=1
              else
              INSTENV=0
              fi;
              INSTENV2=$(
              echo "Docker";
              echo "$SYSTDDVIRT";
              else
              echo "native";
              fi;)
              else
              fi;
              else
              fi;
              echo "";
              else
              fi;
              echo -e "";
              else
              fi;
              echo "";
              echo "";
              echo "";
              fi
              echo "";
              echo -e "";
              if
              then
              elif
              then
              echo -e "\033[0;31m
              elif
              then
              echo -e "\033[0;31m
              elif
              then
              echo -e "\033[0;31m
              elif
              then
              echo -e "\033[0;31m
              elif
              then
              echo -e "\033[0;31m
              elif
              then
              else
              fi
              then
              echo "";
              fi;
              echo "";
              echo "MEMORY: ";
              free -ht --mega;
              echo "";
              echo "";
              echo "";
              echo "";
              echo "";
              echo "";
              echo "";
              echo "";
              echo "";
              then
              echo -e "";
              echo -e "
              echo -e "";
              else
              echo ""
              fi;
              echo -e "```";
              echo "";
              dg19222
              @dg19222 ich kann damit leider sehr wenig anfangen :-)
              • D dg19222
                @thomas-braun ```
                #!/bin/bash
                if [ -f "$DOCKER" ]
                then
                echo "";
                then
                exit 1
                fi
                clear;
                VARIABLES
                export LC_ALL=C;
                HOST=$(hostname)
                APT=0;
                INSTENV=0;
                INSTENV2=0;
                SYSTDDVIRT="";
                NODENOTCORR=0;
                clear;
                echo "";
                echo "";
                echo "";
                echo "";
                echo "";
                echo "";
                read -r -n 1 -s
                clear;
                echo "";
                echo "";
                echo "```";
                echo "";
                else
                echo "";
                fi;
                else
                fi
                else
                fi;
                echo "";
                uptime;
                echo "";
                RASPBERRY only
                TEST CODE
                echo "";
                ISSUES_MAP=(
                HEX_BIN_MAP=(
                ["0"]="0000"
                ["1"]="0001"
                ["2"]="0010"
                ["3"]="0011"
                ["4"]="0100"
                ["5"]="0101"
                ["6"]="0110"
                ["7"]="0111"
                ["8"]="1000"
                ["9"]="1001"
                ["A"]="1010"
                ["B"]="1011"
                ["C"]="1100"
                ["D"]="1101"
                ["E"]="1110"
                ["F"]="1111"
                IFS='x'
                else
                bit_n=0
                bit_n=$((bit_n+1))
                fi
                done
                fi
                echo ""
                Display past issues
                else
                bit_n=16
                bit_n=$((bit_n+1))
                fi
                done
                fi
                fi
                echo "";
                echo "";
                fi
                echo "";
                date -u;
                date;
                date +"%Z %z";
                cat /etc/timezone;
                else
                timedatectl;
                fi;
                echo "";
                whoami;
                echo "$HOME";
                groups;
                echo "";
                then
                else
                fi
                echo -e "";
                else
                fi;
                echo "";
                free -th --mega;
                echo "";
                RASPBERRY only
                echo "";
                vcgencmd mem_oom;
                fi;
                echo "";
                else
                echo "";
                echo "";
                echo "";
                fi;
                df -PTh;
                echo "";
                echo "";
                findmnt --real;
                echo "";
                echo "";
                fi
                echo "";
                echo -e "";
                echo -e ""
                else
                fi;
                echo "";
                echo "";
                echo "";
                echo "";
                echo "";
                echo "";
                echo "";
                VERNODE=$(node -v);
                VERNPM=$(npm -v);
                VERNPX=$(npx -v);
                if
                then
                NODENOTCORR=1
                elif
                then
                NODENOTCORR=1
                echo -e "\033[0;31m
                elif
                then
                NODENOTCORR=1
                echo -e "\033[0;31m
                elif
                then
                NODENOTCORR=1
                echo -e "\033[0;31m
                elif
                then
                NODENOTCORR=1
                echo -e "\033[0;31m
                elif
                then
                NODENOTCORR=1
                echo -e "\033[0;31m
                elif
                then
                NODENOTCORR=1
                echo -e "\033[0;31m
                else
                echo "";
                fi
                echo "";
                echo "";
                echo "";
                echo "";
                echo "";
                then
                else
                fi;
                echo "";
                echo "";
                echo "";
                echo "";
                iobroker status;
                echo "";
                echo "";
                echo "";
                iob list instances;
                echo "";
                echo "";
                iob repo list;
                echo "";
                iob update -i;
                echo "";
                echo "";
                echo "";
                echo "";
                echo "";
                echo "";
                echo "```";
                echo "";
                echo "";
                echo "";
                echo "";
                read -r -n 1 -s
                echo "";
                clear;
                echo "";
                echo "```";
                echo "";
                echo "";
                INSTENV=2
                INSTENV=1
                else
                INSTENV=0
                fi;
                INSTENV2=$(
                echo "Docker";
                echo "$SYSTDDVIRT";
                else
                echo "native";
                fi;)
                else
                fi;
                else
                fi;
                echo "";
                else
                fi;
                echo -e "";
                else
                fi;
                echo "";
                echo "";
                echo "";
                fi
                echo "";
                echo -e "";
                if
                then
                elif
                then
                echo -e "\033[0;31m
                elif
                then
                echo -e "\033[0;31m
                elif
                then
                echo -e "\033[0;31m
                elif
                then
                echo -e "\033[0;31m
                elif
                then
                echo -e "\033[0;31m
                elif
                then
                else
                fi
                then
                echo "";
                fi;
                echo "";
                echo "MEMORY: ";
                free -ht --mega;
                echo "";
                echo "";
                echo "";
                echo "";
                echo "";
                echo "";
                echo "";
                echo "";
                echo "";
                then
                echo -e "";
                echo -e "
                echo -e "";
                else
                echo ""
                fi;
                echo -e "```";
                echo "";
                @dg19222
                Wo hab ich denn geschrieben, dass du den Code per curl herunterladen sollst?
                iob diag
                eingeben, fertig.
                  @dg19222
                  iob diag
                  eingeben, fertig.
                  dg19222
                  @thomas-braun ging net da kam die meldung das ich es runterladen mus
                  wenn ich es jetzt eingeben will will er sudo passwort das ich leider vergessen habe
                  • D dg19222
                    Das ist schlecht. Aber wie pflegst du denn dein System, ohne Passwort?
                    (Ich glaube, ich möchte die Antwort gar nicht wissen...)
                      dg19222
                      @thomas-braun das ging bis dato
                      • D dg19222
                        dg19222
                        @dg19222 Node is v18.19.0
                        npm is v10.2.3
                        • D dg19222
                          npm is v10.2.3
                          @dg19222
                          Und der Rest vom Fest?
                            @dg19222
                            dg19222
                            sag mir was du brauchst und ich schike es dir
                            • D dg19222
                              @dg19222
                              Die Ausgabe von
                              iob diag
                                dg19222
                                ok da komme ich leider net ran dann mus es halt leider ohne den adapter gehn
                                danke dir für die mühe
                                • D dg19222
                                  Warum nicht?
                                  Wenn da nodejs 18.19.0 installiert ist muss ja ein PW für den root vorhanden sein, sonst bekommt man das nicht ordentlich auf das System.
                                  Und der root kann natürlich neue PW an die user vergeben.
                                    Warum nicht?
                                    dg19222
                                    habe das system gestern aufgesetzt ging alles mit meinem pw nur das net
                                    • D dg19222
                                      @dg19222
                                      Dann ist das wohl schief aufgesetzt, denn iob diag funktioniert natürlich grundsätzlich.
                                        @dg19222
                                        dg19222
                                        @thomas-braun ok wenn du meinst komisch das alles andere geht aber trozdem danke
                                        • D dg19222
                                          dg19222
                                          @dg19222 ich kann es netmal als root ausführen
                                          root@Iobrocker:/opt/iobroker# iob diag
                                          root@Iobrocker:/opt/iobroker# su dg19222
                                          dg19222@Iobrocker:/opt/iobroker$ iob diag
                                          [sudo] password for dg19222:
                                          Sorry, user dg19222 is not allowed to execute '/usr/bin/curl -sLf https://ioer.net/diag.sh --output /home/iobroker/.diag.sh' as iobroker on Iobrocker.
                                          82.8k
