  4. IKEA Trådfri The security code is incorrect or
34 Beiträge 2 Kommentatoren 3.8k Aufrufe 2 Beobachtet
    @dg19222
    Versionen? Log?
    dg19222
    @thomas-braun Version V 3.1.3
    2023-12-13 13:10:20.886 - error: tradfri.0 (2090) The security code is incorrect or something else went wrong with the authentication.
    2023-12-13 13:10:20.887 - error: tradfri.0 (2090) Please check your adapter settings and restart the adapter!
    reicht dir das oder brauchst mehr?
    Danke für dein hilfe
    • D dg19222
      @dg19222 sagte in IKEA Trådfri The security code is incorrect or:
      Das mal getan? Denn hier läuft der Adapter einwandfrei.
      Schau dir ggf.
      iob diag
      an.
        Schau dir ggf.
        iob diag
        an.
        dg19222
        @thomas-braun ```
        dg19222@Iobrocker:~$ curl -sLf https://iobroker.net/diag.sh
        #!/bin/bash
        iobroker diagnostics
        written to help getting information about the environment the ioBroker installation is running in
        DOCKER=/opt/scripts/.docker_config/.thisisdocker
        #if [[ -f "/opt/scripts/.docker_config/.thisisdocker" ]]
        if [ -f "$DOCKER" ]
        then
        echo "";
        elif [ "$(id -u)" = 0 ];
        then
        echo -e "This script must not be run as root! \nPlease use your standard user!"
        exit 1
        fi
        clear;
        echo "*** iob diag is starting up, please wait ***";
        VARIABLES
        export LC_ALL=C;
        SKRIPTV="2023-10-10"; #version of this script
        NODE_MAJOR=18 #this is the recommended major nodejs version for ioBroker, please adjust accordingly if the recommendation changes
        HOST=$(hostname)
        NODERECOM=$(iobroker state getValue system.host."$HOST".versions.nodeNewestNext); #recommended node version
        NPMRECOM=$(iobroker state getValue system.host."$HOST".versions.npmNewestNext); #recommended npm version
        NODEUSED=$(iobroker state getValue system.host."$HOST".versions.nodeCurrent); #current node version in use
        #NPMUSED=$(iobroker state getValue system.host."$HOST".versions.npmCurrent); #current npm version in use
        XORGTEST=0; #test for GUI
        APT=0;
        INSTENV=0;
        INSTENV2=0;
        SYSTDDVIRT="";
        NODENOTCORR=0;
        clear;
        echo "";
        echo -e "\033[34;107m*** ioBroker Diagnosis \033[0m";
        echo "";
        echo "Please stretch the window of your terminal programm (puTTY) as wide as possible or switch to full screen";
        echo "";
        echo "The following checks may give hints to potential malconfigurations or errors, please post them in our forum:";
        echo "";
        echo "https://forum.iobroker.net";
        echo "";
        echo "Just copy and paste the Summary Page, including the ``` characters at start and end.";
        echo "It helps us to help you!"
        echo "";
        # read -p "Press <Enter> to continue";
        echo "Press any key to continue";
        read -r -n 1 -s
        clear;
        echo "";
        echo -e "\033[33m======== Start marking the full check here =========\033[0m";
        echo "";
        echo "```";
        echo "Skript v.$SKRIPTV"
        echo "";
        BASE SYSTEM ***\033[0m";
        if [ -f "$DOCKER" ]; then
        echo -e "Hardware Vendor : $(cat /sys/devices/virtual/dmi/id/sys_vendor)";
        echo -e "Kernel : $(uname -m)";
        echo -e "Userland : $(dpkg --print-architecture)";
        echo -e "Docker : $(cat /opt/scripts/.docker_config/.thisisdocker)"
        else
        hostnamectl | grep -v 'Machine|Boot';
        echo "";
        grep -i model /proc/cpuinfo | tail -1;
        echo -e "Docker : false";
        fi;
        Alternativer DockerCheck - Nicht getestet:
        if [ -f /.dockerenv ]; then
        echo "I'm inside matrix ;(";
        else
        echo "I'm living in real world!";
        fi
        SYSTDDVIRT=$(systemd-detect-virt 2>/dev/null)
        if [ "$SYSTDDVIRT" != "" ]; then
        echo -e "Virtualization : $(systemd-detect-virt)"
        else
        echo "Virtualization : Docker"
        fi;
        echo "";
        echo "Systemuptime and Load:";
        uptime;
        echo "CPU threads: $(grep -c processor /proc/cpuinfo)"
        echo "";
        RASPBERRY only
        if [[ $(type -P "vcgencmd" 2>/dev/null) = *"/vcgencmd" ]]; then
        echo "Raspberry only:";
        vcgencmd get_throttled 2> /dev/null;
        echo "Other values than 0x0 hint to temperature/voltage problems";
        vcgencmd measure_temp;
        vcgencmd measure_volts;
        TEST CODE
        echo "";
        echo -e "\033[34;107m*** RASPBERRY THROTTLING ***\033[0m";
        CODE from https://github.com/alwye/get_throttled under MIT Licence
        ISSUES_MAP=(
        [0]="Under-voltage detected"
        [1]="Arm frequency capped"
        [2]="Currently throttled"
        [3]="Soft temperature limit active"
        [16]="Under-voltage has occurred"
        [17]="Arm frequency capping has occurred"
        [18]="Throttling has occurred"
        [19]="Soft temperature limit has occurred")
        HEX_BIN_MAP=(
        ["0"]="0000"
        ["1"]="0001"
        ["2"]="0010"
        ["3"]="0011"
        ["4"]="0100"
        ["5"]="0101"
        ["6"]="0110"
        ["7"]="0111"
        ["8"]="1000"
        ["9"]="1001"
        ["A"]="1010"
        ["B"]="1011"
        ["C"]="1100"
        ["D"]="1101"
        ["E"]="1110"
        ["F"]="1111"
        THROTTLED_OUTPUT=$(vcgencmd get_throttled)
        IFS='x'
        read -r -a strarr <<< "$THROTTLED_OUTPUT"
        THROTTLED_CODE_HEX=${strarr[1]}
        Display current issues
        echo "Current issues:"
        CURRENT_HEX=${THROTTLED_CODE_HEX:4:1}
        CURRENT_BIN=${HEX_BIN_MAP[$CURRENT_HEX]}
        if [ "$CURRENT_HEX" == "0" ] || [ -z "$CURRENT_HEX" ]; then
        echo "No throttling issues detected."
        else
        bit_n=0
        for (( i=${#CURRENT_BIN}-1; i>=0; i--)); do
        if [ "${CURRENT_BIN:$i:1}" = "1" ]; then
        echo "~ ${ISSUES_MAP[$bit_n]}"
        bit_n=$((bit_n+1))
        fi
        done
        fi
        echo ""
        Display past issues
        echo "Previously detected issues:"
        PAST_HEX=${THROTTLED_CODE_HEX:0:1}
        PAST_BIN=${HEX_BIN_MAP[$PAST_HEX]}
        if [ "$PAST_HEX" = "0" ]; then
        else
        bit_n=16
        for (( i=${#PAST_BIN}-1; i>=0; i--)); do
        if [ "${PAST_BIN:$i:1}" = "1" ]; then
        bit_n=$((bit_n+1))
        fi
        done
        fi
        fi
        if [[ -f "/var/run/reboot-required" ]]; then
        echo "";
        echo "This system needs to be REBOOTED!";
        echo "";
        fi
        echo "";
        echo -e "\033[34;107m*** Time and Time Zones ***\033[0m";
        date -u;
        date;
        date +"%Z %z";
        cat /etc/timezone;
        else
        timedatectl;
        fi;
        echo "";
        echo -e "\033[34;107m*** User and Groups \033[0m";
        whoami;
        echo "$HOME";
        groups;
        echo "";
        X-Server-Setup ***\033[0m";
        XORGTEST=$(pgrep -f "Xorg")
        XORGTEST=$(ps aux | grep -c 'Xorg')
        if [[ "$XORGTEST" -gt 1 ]];
        then
        echo -e "X-Server: \ttrue"
        else
        echo -e "X-Server: \tfalse"
        fi
        echo -e "Desktop: \t$DESKTOP_SESSION";
        echo -e "Terminal: \t$XDG_SESSION_TYPE";
        echo -e "";
        else
        echo -e "Boot Target: \t$(systemctl get-default)";
        fi;
        echo "";
        echo -e "\033[34;107m*** MEMORY ***\033[0m";
        free -th --mega;
        echo "";
        vmstat -S M -s | head -n 10;
        RASPBERRY only
        echo "";
        vcgencmd mem_oom;
        fi;
        echo "";
        else
        echo "";
        echo -e "\033[34;107m*** FAILED SERVICES \033[0m";
        echo "";
        systemctl list-units --failed --no-pager;
        echo "";
        fi;
        FILESYSTEM ***\033[0m";
        df -PTh;
        echo "";
        echo -e "\033[32mMessages concerning ext4 filesystem in dmesg:\033[0m";
        sudo dmesg -T | grep -i ext4;
        echo "";
        echo -e "\033[32mShow mounted filesystems (real ones only):\033[0m";
        findmnt --real;
        echo "";
        if [[ -L "/opt/iobroker/backups" ]]; then
        echo "backups directory is linked to a different directory";
        echo "";
        fi
        echo -e "\033[32mFiles in neuralgic directories:\033[0m";
        echo "";
        echo -e "\033[32m/var:\033[0m";
        sudo du -h /var/ | sort -rh | head -5;
        echo -e "";
        echo -e ""
        else
        journalctl --disk-usage;
        fi;
        echo "";
        echo -e "\033[32m/opt/iobroker/backups:\033[0m";
        du -h /opt/iobroker/backups/ | sort -rh | head -5;
        echo "";
        echo -e "\033[32m/opt/iobroker/iobroker-data:\033[0m";
        du -h /opt/iobroker/iobroker-data/ | sort -rh | head -5;
        echo "";
        echo -e "\033[32mThe five largest files in iobroker-data are:\033[0m";
        find /opt/iobroker/iobroker-data -maxdepth 15 -type f -exec du -sh {} + | sort -rh | head -n 5;
        echo "";
        Detecting dev-links in /dev/serial/by-id
        echo -e "\033[32mUSB-Devices by-id:\033[0m";
        echo "USB-Sticks - Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id':";
        echo "";
        find /dev/serial/by-id/ -maxdepth 1 -mindepth 1;
        echo "";
        echo -e "\033[34;107m*** NodeJS-Installation ***\033[0m";
        echo "";
        echo -e "$(type -p nodejs) \t$(nodejs -v)";
        echo -e "$(type -p node) \t\t$(node -v)";
        echo -e "$(type -p npm) \t\t$(npm -v)";
        echo -e "$(type -p npx) \t\t$(npx -v)";
        echo -e "$(type -p corepack) \t$(corepack -v)";
        PATHAPT=$(type -p apt);
        PATHNODEJS=$(type -p nodejs);
        PATHNODE=$(type -p node);
        PATHNPM=$(type -p npm);
        PATHNPX=$(type -p npx);
        PATHCOREPACK=$(type -p corepack);
        VERNODEJS=$(nodejs -v);
        VERNODE=$(node -v);
        VERNPM=$(npm -v);
        VERNPX=$(npx -v);
        #VERCOREPACK=$(corepack -v);
        if
        [[ $PATHNODEJS != "/usr/bin/nodejs" ]];
        then
        NODENOTCORR=1
        echo -e "\033[0;31m*** nodejs is NOT correctly installed \033[0m";
        elif
        [[ $PATHNODE != "/usr/bin/node" ]];
        then
        NODENOTCORR=1
        echo -e "\033[0;31m
        elif
        [[ $PATHNPM != "/usr/bin/npm" ]];
        then
        NODENOTCORR=1
        echo -e "\033[0;31m
        elif
        [[ $PATHNPX != "/usr/bin/npx" ]];
        then
        NODENOTCORR=1
        echo -e "\033[0;31m
        elif
        [[ $VERNODEJS != "$VERNODE" ]];
        then
        NODENOTCORR=1
        echo -e "\033[0;31m
        elif
        [[ $VERNPM != "$VERNPX" ]];
        then
        NODENOTCORR=1
        echo -e "\033[0;31m
        elif
        [[ $PATHCOREPACK != "/usr/bin/corepack" ]];
        then
        NODENOTCORR=1
        echo -e "\033[0;31m
        nodejs is NOT correctly installed ***\033[0m";
        else
        echo "";
        fi
        echo "";
        apt-cache policy nodejs;
        echo "";
        npm doctor can be misleading, deactivated to avoid confusion
        echo -e "Calling 'npm doctor' for you. \033[32mPlease be patient!\033[0m";
        echo "";
        (cd /opt/iobroker && sudo -H -u iobroker npm doctor);
        echo "";
        echo "The recommended versions for ioBroker are nodeJS v$NODERECOM / npm v$NPMRECOM!";
        echo "Don't trust the doctor if he recommends different versions!"
        echo "";
        ANZNPMTMP=$(find /opt/iobroker/node_modules -type d -iname '.*-????????' ! -iname '.local-chromium' | wc -l);
        echo -e "\033[32mTemp directories causing npm8 problem:\033[0m ""$ANZNPMTMP""";
        if [[ $ANZNPMTMP -gt 0 ]]
        then
        echo -e "Some problems detected, please run \e[031miob fix\e[0m";
        else
        echo "No problems detected"
        fi;
        echo "";
        echo -e "Temp directories being cleaned up now find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium" -exec rm -rf {} \;";
        find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium" -exec rm -rf {} \ &> /dev/null;
        echo -e "\033[32m1 - Temp directories causing npm8 problem:\033[0m `find /opt/iobroker/node_modules -type d -iname '.*-????????' ! -iname '.local-chromium'>e;
        echo "";
        echo "Errors in npm tree:";
        cd /opt/iobroker && npm ls -a | grep ERR;
        echo "";
        echo -e "\033[34;107m*** ioBroker-Installation ***\033[0m";
        echo "";
        echo -e "\033[32mioBroker Status\033[0m";
        iobroker status;
        echo "";
        multihost detection - wip
        iobroker multihost status
        iobroker status all | grep MULTIHOSTSERVICE/enabled
        echo -e "\033[32mCore adapters versions\033[0m"
        echo -e "js-controller: \t$(iob -v)";
        echo -e "admin: \t\t$(iob version admin)";
        echo -e "javascript: \t$(iob version javascript)";
        echo "";
        echo -e "Adapters from github: \t$( (cd /opt/iobroker && npm ls | grep -c 'git') )";
        echo "";
        echo -e "\033[32mAdapter State\033[0m";
        iob list instances;
        echo "";
        echo -e "\033[32mEnabled adapters with bindings\033[0m";
        iob list instances | grep enabled | grep port ;
        echo "";
        echo -e "\033[32mioBroker-Repositories\033[0m";
        iob repo list;
        echo "";
        echo -e "\033[32mInstalled ioBroker-Instances\033[0m";
        iob update -i;
        echo "";
        echo -e "\033[32mObjects and States\033[0m";
        echo "Please stand by - This may take a while";
        IOBOBJECTS=$(iob list objects 2>/dev/null | wc -l);
        echo -e "Objects: \t$IOBOBJECTS";
        IOBSTATES=$(iob list states 2>/dev/null | wc -l);
        echo -e "States: \t$IOBSTATES";
        echo "";
        echo -e "\033[34;107m*** OS-Repositories and Updates ***\033[0m";
        sudo apt-get update 1>/dev/null && sudo apt-get update
        APT=$(apt-get upgrade -s |grep -P '^\d+ upgraded'|cut -d" " -f1)
        echo -e "Pending Updates: $APT";
        echo "";
        echo -e "\033[34;107m*** Listening Ports ***\033[0m";
        sudo netstat -tulpen #| sed -n '1,2p;/LISTEN/p';
        Alternativ - ss ist nicht ueberall installiert
        sudo ss -tulwp | grep LISTEN;
        echo "";
        echo -e "\033[34;107m*** Log File - Last 25 Lines ***\033[0m";
        echo "";
        iobroker logs --lines 25;
        tail -n 25 /opt/iobroker/log/iobroker.current.log;
        echo "";
        echo "```";
        echo "";
        echo -e "\033[33m============ Mark until here for C&P =============\033[0m";
        echo "";
        echo "iob diag has finished.";
        echo "";
        echo "";
        # read -p "For a Summary please press <Enter>";
        echo "Press any key for a summary";
        read -r -n 1 -s
        echo "";
        clear;
        echo "Copy text starting here:";
        echo "";
        echo "```";
        echo "======================= SUMMARY =======================";
        echo -e "\t\t\tv.$SKRIPTV"
        echo "";
        echo "";
        INSTENV=2
        elif [ "$SYSTDDVIRT" != "none" ]; then
        INSTENV=1
        else
        INSTENV=0
        fi;
        INSTENV2=$(
        if [[ $INSTENV -eq 2 ]]; then
        echo "Docker";
        elif [ $INSTENV -eq 1 ]; then
        echo "$SYSTDDVIRT";
        else
        echo "native";
        fi;)
        if [[ -f "$DOCKER" ]]; then
        else
        fi;
        else
        fi;
        echo "";
        echo -e "Installation: \t\t$INSTENV2";
        echo -e "Kernel: \t\t$(uname -m)";
        echo -e "Userland: \t\t$(dpkg --print-architecture)";
        echo -e "Timezone: \t\t$(cat /etc/timezone)"
        else
        echo -e "Timezone: \t\t$(timedatectl | grep zone | cut -c28-80)";
        fi;
        echo -e "User-ID: \t\t$EUID";
        echo -e "X-Server: \t\t$(if [[ $XORGTEST -gt 1 ]]; then echo "true";else echo "false";fi)";
        echo -e "";
        else
        echo -e "Boot Target: \t\t$(systemctl get-default)";
        fi;
        echo "";
        echo -e "Pending OS-Updates: \t$APT";
        echo -e "Pending iob updates: \t$(iob update -u | grep -c 'Updatable|Updateable')";
        echo "";
        echo "This system needs to be REBOOTED NOW!";
        echo "";
        fi
        echo "";
        echo -e "Nodejs-Installation: \t$( type -p nodejs ) \t$( nodejs -v )";
        echo -e "\t\t\t$(type -P node) \t\t$(node -v)";
        echo -e "\t\t\t$(type -P npm) \t\t$(npm -v)";
        echo -e "\t\t\t$(type -P npx) \t\t$(npx -v)";
        echo -e "\t\t\t$(type -P corepack) \t$(corepack -v)";
        echo -e "";
        echo -e "Recommended versions are nodejs ""$NODERECOM"" and npm ""$NPMRECOM""";
        if
        then
        echo "*** nodejs is NOT correctly installed ";
        echo "Wrong installation path detected. This needs to be fixed.";
        elif
        then
        echo -e "\033[0;31m
        elif
        then
        echo -e "\033[0;31m
        elif
        then
        echo -e "\033[0;31m
        elif
        then
        echo -e "\033[0;31m
        echo "Wrong installation path detected. This needs to be fixed";
        elif
        then
        echo -e "\033[0;31m
        echo "nodejs and node versions do not match. This needs to be fixed.";
        elif
        then
        echo -e "\033[0;31mnodejs is NOT correctly installed\033[0m";
        echo "npm and npx versions do not match. This needs to be fixed.";
        else
        echo "Your nodejs installation is correct";
        fi
        if [[ $NODENOTCORR -eq 1 ]];
        then
        echo "";
        echo "Please check";
        echo "https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian";
        echo "for more information on how to fix these errors."
        fi;
        echo "";
        echo -e "Total Memory: \t\tfree -h | awk '/^Mem:/{print $2}'";
        echo "MEMORY: ";
        free -ht --mega;
        echo "";
        echo -e "Active iob-Instances: \t$(iob list instances | grep -c ^+)";
        iob repo list | tail -n1;
        echo "";
        echo -e "ioBroker Core: \t\tjs-controller \t\t$(iob -v)";
        echo -e "\t\t\tadmin \t\t\t$(iob version admin)";
        echo "";
        echo -e "ioBroker Status: \t$(iobroker status)";
        echo "";
        iobroker status all | grep MULTIHOSTSERVICE/enabled;
        echo "Status admin and web instance:";
        iobroker list instances | grep 'admin.|system.adapter.web.'
        echo "";
        echo -e "Objects: \t\t$IOBOBJECTS";
        echo -e "States: \t\t$IOBSTATES";
        echo "";
        echo -e "Size of iob-Database:";
        echo "";
        find /opt/iobroker/iobroker-data -maxdepth 1 -type f -name *objects* -exec du -sh {} + |sort -rh | head -n 5;
        find /opt/iobroker/iobroker-data -maxdepth 1 -type f -name *states* -exec du -sh {} + |sort -rh | head -n 5;
        echo "";
        echo "";
        then
        echo -e "";
        echo -e "Some problems detected, please run \e[031miob fix\e[0m and try to have them fixed";
        echo -e "
        echo -e "";
        else
        echo ""
        fi;
        echo "=================== END OF SUMMARY ===================="
        echo -e "```";
        echo "";
        echo "=== Mark text until here for copying ===";
        D Thomas BraunT 2 Antworten Letzte Antwort
        • D dg19222
          @thomas-braun ```
          #!/bin/bash
          if [ -f "$DOCKER" ]
          then
          echo "";
          then
          exit 1
          fi
          clear;
          VARIABLES
          export LC_ALL=C;
          HOST=$(hostname)
          APT=0;
          INSTENV=0;
          INSTENV2=0;
          SYSTDDVIRT="";
          NODENOTCORR=0;
          clear;
          echo "";
          echo "";
          echo "";
          echo "";
          echo "";
          echo "";
          read -r -n 1 -s
          clear;
          echo "";
          echo "";
          echo "```";
          echo "";
          else
          echo "";
          fi;
          else
          fi
          else
          fi;
          echo "";
          uptime;
          echo "";
          RASPBERRY only
          TEST CODE
          echo "";
          ISSUES_MAP=(
          HEX_BIN_MAP=(
          ["0"]="0000"
          ["1"]="0001"
          ["2"]="0010"
          ["3"]="0011"
          ["4"]="0100"
          ["5"]="0101"
          ["6"]="0110"
          ["7"]="0111"
          ["8"]="1000"
          ["9"]="1001"
          ["A"]="1010"
          ["B"]="1011"
          ["C"]="1100"
          ["D"]="1101"
          ["E"]="1110"
          ["F"]="1111"
          IFS='x'
          else
          bit_n=0
          bit_n=$((bit_n+1))
          fi
          done
          fi
          echo ""
          Display past issues
          else
          bit_n=16
          bit_n=$((bit_n+1))
          fi
          done
          fi
          fi
          echo "";
          echo "";
          fi
          echo "";
          date -u;
          date;
          date +"%Z %z";
          cat /etc/timezone;
          else
          timedatectl;
          fi;
          echo "";
          whoami;
          echo "$HOME";
          groups;
          echo "";
          then
          else
          fi
          echo -e "";
          else
          fi;
          echo "";
          free -th --mega;
          echo "";
          RASPBERRY only
          echo "";
          vcgencmd mem_oom;
          fi;
          echo "";
          else
          echo "";
          echo "";
          echo "";
          fi;
          df -PTh;
          echo "";
          echo "";
          findmnt --real;
          echo "";
          echo "";
          fi
          echo "";
          echo -e "";
          echo -e ""
          else
          fi;
          echo "";
          echo "";
          echo "";
          echo "";
          echo "";
          echo "";
          echo "";
          VERNODE=$(node -v);
          VERNPM=$(npm -v);
          VERNPX=$(npx -v);
          if
          then
          NODENOTCORR=1
          elif
          then
          NODENOTCORR=1
          echo -e "\033[0;31m
          elif
          then
          NODENOTCORR=1
          echo -e "\033[0;31m
          elif
          then
          NODENOTCORR=1
          echo -e "\033[0;31m
          elif
          then
          NODENOTCORR=1
          echo -e "\033[0;31m
          elif
          then
          NODENOTCORR=1
          echo -e "\033[0;31m
          elif
          then
          NODENOTCORR=1
          echo -e "\033[0;31m
          else
          echo "";
          fi
          echo "";
          echo "";
          echo "";
          echo "";
          echo "";
          then
          else
          fi;
          echo "";
          echo "";
          echo "";
          echo "";
          iobroker status;
          echo "";
          echo "";
          echo "";
          iob list instances;
          echo "";
          echo "";
          iob repo list;
          echo "";
          iob update -i;
          echo "";
          echo "";
          echo "";
          echo "";
          echo "";
          echo "";
          echo "```";
          echo "";
          echo "";
          echo "";
          echo "";
          read -r -n 1 -s
          echo "";
          clear;
          echo "";
          echo "```";
          echo "";
          echo "";
          INSTENV=2
          INSTENV=1
          else
          INSTENV=0
          fi;
          INSTENV2=$(
          echo "Docker";
          echo "$SYSTDDVIRT";
          else
          echo "native";
          fi;)
          else
          fi;
          else
          fi;
          echo "";
          else
          fi;
          echo -e "";
          else
          fi;
          echo "";
          echo "";
          echo "";
          fi
          echo "";
          echo -e "";
          if
          then
          elif
          then
          echo -e "\033[0;31m
          elif
          then
          echo -e "\033[0;31m
          elif
          then
          echo -e "\033[0;31m
          elif
          then
          echo -e "\033[0;31m
          elif
          then
          echo -e "\033[0;31m
          elif
          then
          else
          fi
          then
          echo "";
          fi;
          echo "";
          echo "MEMORY: ";
          free -ht --mega;
          echo "";
          echo "";
          echo "";
          echo "";
          echo "";
          echo "";
          echo "";
          echo "";
          echo "";
          then
          echo -e "";
          echo -e "
          echo -e "";
          else
          echo ""
          fi;
          echo -e "```";
          echo "";
          dg19222
          @dg19222 ich kann damit leider sehr wenig anfangen :-)
          • D dg19222
            @thomas-braun ```
            #!/bin/bash
            if [ -f "$DOCKER" ]
            then
            echo "";
            then
            exit 1
            fi
            clear;
            VARIABLES
            export LC_ALL=C;
            HOST=$(hostname)
            APT=0;
            INSTENV=0;
            INSTENV2=0;
            SYSTDDVIRT="";
            NODENOTCORR=0;
            clear;
            echo "";
            echo "";
            echo "";
            echo "";
            echo "";
            echo "";
            read -r -n 1 -s
            clear;
            echo "";
            echo "";
            echo "```";
            echo "";
            else
            echo "";
            fi;
            else
            fi
            else
            fi;
            echo "";
            uptime;
            echo "";
            RASPBERRY only
            TEST CODE
            echo "";
            ISSUES_MAP=(
            HEX_BIN_MAP=(
            ["0"]="0000"
            ["1"]="0001"
            ["2"]="0010"
            ["3"]="0011"
            ["4"]="0100"
            ["5"]="0101"
            ["6"]="0110"
            ["7"]="0111"
            ["8"]="1000"
            ["9"]="1001"
            ["A"]="1010"
            ["B"]="1011"
            ["C"]="1100"
            ["D"]="1101"
            ["E"]="1110"
            ["F"]="1111"
            IFS='x'
            else
            bit_n=0
            bit_n=$((bit_n+1))
            fi
            done
            fi
            echo ""
            Display past issues
            else
            bit_n=16
            bit_n=$((bit_n+1))
            fi
            done
            fi
            fi
            echo "";
            echo "";
            fi
            echo "";
            date -u;
            date;
            date +"%Z %z";
            cat /etc/timezone;
            else
            timedatectl;
            fi;
            echo "";
            whoami;
            echo "$HOME";
            groups;
            echo "";
            then
            else
            fi
            echo -e "";
            else
            fi;
            echo "";
            free -th --mega;
            echo "";
            RASPBERRY only
            echo "";
            vcgencmd mem_oom;
            fi;
            echo "";
            else
            echo "";
            echo "";
            echo "";
            fi;
            df -PTh;
            echo "";
            echo "";
            findmnt --real;
            echo "";
            echo "";
            fi
            echo "";
            echo -e "";
            echo -e ""
            else
            fi;
            echo "";
            echo "";
            echo "";
            echo "";
            echo "";
            echo "";
            echo "";
            VERNODE=$(node -v);
            VERNPM=$(npm -v);
            VERNPX=$(npx -v);
            if
            then
            NODENOTCORR=1
            elif
            then
            NODENOTCORR=1
            echo -e "\033[0;31m
            elif
            then
            NODENOTCORR=1
            echo -e "\033[0;31m
            elif
            then
            NODENOTCORR=1
            echo -e "\033[0;31m
            elif
            then
            NODENOTCORR=1
            echo -e "\033[0;31m
            elif
            then
            NODENOTCORR=1
            echo -e "\033[0;31m
            elif
            then
            NODENOTCORR=1
            echo -e "\033[0;31m
            else
            echo "";
            fi
            echo "";
            echo "";
            echo "";
            echo "";
            echo "";
            then
            else
            fi;
            echo "";
            echo "";
            echo "";
            echo "";
            iobroker status;
            echo "";
            echo "";
            echo "";
            iob list instances;
            echo "";
            echo "";
            iob repo list;
            echo "";
            iob update -i;
            echo "";
            echo "";
            echo "";
            echo "";
            echo "";
            echo "";
            echo "```";
            echo "";
            echo "";
            echo "";
            echo "";
            read -r -n 1 -s
            echo "";
            clear;
            echo "";
            echo "```";
            echo "";
            echo "";
            INSTENV=2
            INSTENV=1
            else
            INSTENV=0
            fi;
            INSTENV2=$(
            echo "Docker";
            echo "$SYSTDDVIRT";
            else
            echo "native";
            fi;)
            else
            fi;
            else
            fi;
            echo "";
            else
            fi;
            echo -e "";
            else
            fi;
            echo "";
            echo "";
            echo "";
            fi
            echo "";
            echo -e "";
            if
            then
            elif
            then
            echo -e "\033[0;31m
            elif
            then
            echo -e "\033[0;31m
            elif
            then
            echo -e "\033[0;31m
            elif
            then
            echo -e "\033[0;31m
            elif
            then
            echo -e "\033[0;31m
            elif
            then
            else
            fi
            then
            echo "";
            fi;
            echo "";
            echo "MEMORY: ";
            free -ht --mega;
            echo "";
            echo "";
            echo "";
            echo "";
            echo "";
            echo "";
            echo "";
            echo "";
            echo "";
            then
            echo -e "";
            echo -e "
            echo -e "";
            else
            echo ""
            fi;
            echo -e "```";
            echo "";
            @dg19222
            Wo hab ich denn geschrieben, dass du den Code per curl herunterladen sollst?
            iob diag
            eingeben, fertig.
              @dg19222
              iob diag
              eingeben, fertig.
              dg19222
              @thomas-braun ging net da kam die meldung das ich es runterladen mus
              wenn ich es jetzt eingeben will will er sudo passwort das ich leider vergessen habe
              • D dg19222
                Das ist schlecht. Aber wie pflegst du denn dein System, ohne Passwort?
                (Ich glaube, ich möchte die Antwort gar nicht wissen...)
                  dg19222
                  @thomas-braun das ging bis dato
                  • D dg19222
                    dg19222
                    @dg19222 Node is v18.19.0
                    npm is v10.2.3
                    • D dg19222
                      npm is v10.2.3
                      @dg19222
                      Und der Rest vom Fest?
                        @dg19222
                        dg19222
                        sag mir was du brauchst und ich schike es dir
                        • D dg19222
                          @dg19222
                          Die Ausgabe von
                          iob diag
                            dg19222
                            ok da komme ich leider net ran dann mus es halt leider ohne den adapter gehn
                            danke dir für die mühe
                            • D dg19222
                              Warum nicht?
                              Wenn da nodejs 18.19.0 installiert ist muss ja ein PW für den root vorhanden sein, sonst bekommt man das nicht ordentlich auf das System.
                              Und der root kann natürlich neue PW an die user vergeben.
                                Warum nicht?
                                dg19222
                                habe das system gestern aufgesetzt ging alles mit meinem pw nur das net
                                • D dg19222
                                  @dg19222
                                  Dann ist das wohl schief aufgesetzt, denn iob diag funktioniert natürlich grundsätzlich.
                                    @dg19222
                                    dg19222
                                    @thomas-braun ok wenn du meinst komisch das alles andere geht aber trozdem danke
                                    • D dg19222
                                      dg19222
                                      @dg19222 ich kann es netmal als root ausführen
                                      root@Iobrocker:/opt/iobroker# iob diag
                                      root@Iobrocker:/opt/iobroker# su dg19222
                                      dg19222@Iobrocker:/opt/iobroker$ iob diag
                                      [sudo] password for dg19222:
                                      Sorry, user dg19222 is not allowed to execute '/usr/bin/curl -sLf https://ioer.net/diag.sh --output /home/iobroker/.diag.sh' as iobroker on Iobrocker.
                                      • D dg19222
                                        Richtig. Das muss ja auch als user ausgeführt werden, direkt als root macht man eh nichts, man meldet sich nicht mal als root an.
                                        Dem user 'dg19222' fehlen wohl die notwendigen Rechte.
                                        groups
                                        sagt?
                                        Und genau das meine ich mit 'schief aufgesetzt'.
                                          groups
                                          sagt?
                                          dg19222
                                          dg19222 cdrom floppy audio dip video plugdev users netdev bluetoot
