  3. Einsteigerfragen
  4. Installation
  5. [gelöst]Multi-Host installieren (läuft nicht)
17 Beiträge 7 Kommentatoren 1.8k Aufrufe 6 Beobachtet
  • B Bastler52
    Hier die Informationen zur Klärung. Sollten weitere Infos, Details oder Ergänzungen notwendig sein, würde ich mich über Eure Rückmeldung freuen. Vielen Dank für Eure Unterstützung im Voraus
    1 MASTER
    2 SLAVE am Ende die Meldung nach connect
    			v.2023-10-10
       Static hostname: raspberrypi
             Icon name: computer
      Operating System: Raspbian GNU/Linux 10 (buster)
                Kernel: Linux 5.10.103-v7l+
          Architecture: arm
    Installation: 		native
    Kernel: 		armv7l
    Userland: 		armhf
    Timezone: 		Europe/Berlin (CET, +0100)
    User-ID: 		1000
    X-Server: 		true
    Boot Target: 		graphical.target
    Pending OS-Updates: 	0
    Pending iob updates: 	0
    Nodejs-Installation: 	/usr/bin/nodejs 	v18.19.0
    			/usr/bin/node 		v18.19.0
    			/usr/bin/npm 		10.2.4
    			/usr/bin/npx 		10.2.4
    			/usr/bin/corepack 	0.22.0
    Recommended versions are nodejs Server Configured backup period 7200000 is larger than the supported maximum of 35791 minutes. Defaulting to 120 minutes.
    18.19.0 and npm Server Configured backup period 7200000 is larger than the supported maximum of 35791 minutes. Defaulting to 120 minutes.
    10.2.3
    MEMORY:
    Mem:           7.9G        320M        6.3G         71M        1.3G        7.2G
    Swap:           99M          0B         99M
    Total:         8.0G        320M        6.4G
    Active iob-Instances: 	1
    Active repo(s): stable
    ioBroker Core: 		js-controller 		5.0.16
    			admin 			6.12.0
    ioBroker Status: 	Server Configured backup period 7200000 is larger than the supported maximum of 35791 minutes. Defaulting to 120 minutes.
    iobroker is not running on this host.
    Objects type: jsonl
    States  type: jsonl
      system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    Objects: 		9136
    States: 		4427
    Size of iob-Database:
    15M	/opt/iobroker/iobroker-data/objects.jsonl
    2.1M	/opt/iobroker/iobroker-data/states.jsonl
    pi@raspberrypi:~ $ iobroker multihost enable
    Multihost discovery server activated on this host. If iobroker is currently not running please start befeore trying to discover this host.
    Important: Multihost discovery works with UDP packets. Make sure they are routed correctly in your network. If you use Docker you also need to configure this correctly.
    Multihost discovery will be automatically deactivated after 15 minutes. If you want to activate it permanently use the --persist flag
    Discovery authentication activated.
    Enter secret phrase for connection:
    Repeat secret phrase for connection:
    Please check the binding of the configured jsonl server to allow remote connections.
    Please restart ioBroker for the changes to take effect: "iobroker restart"
    Multihost discovery server: enabled
    Discovery authentication:   enabled
    Persistent activation:      disabled
    Objects:                    jsonl on 0.0.0.0
    States:                     jsonl on 0.0.0.0
    ^C
    pi@raspberrypi:~ $ iob restart
    			v.2023-10-10
       Static hostname: keller
             Icon name: computer
      Operating System: Debian GNU/Linux 11 (bullseye)
                Kernel: Linux 6.1.21-v8+
          Architecture: arm64
    Kernel: 		aarch64
    Userland: 		arm64
    User-ID: 		1000
    X-Server: 		true
    			/usr/bin/npm 		10.2.3
    			/usr/bin/npx 		10.2.3
    Recommended versions are nodejs 18.19.0 and npm 10.2.3
    MEMORY:
    Mem:            909M        240M        181M        7.0M        487M        597M
    Swap:            99M         37M         62M
    Total:          1.0G        278M        243M
    			admin 			6.12.0
    ioBroker Status: 	iobroker is not running on this host.
    Objects type: jsonl
    States  type: jsonl
      system.adapter.admin.0                  : admin                 : keller                                   -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.web.0                    : web                   : keller                                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    Objects: 		212
    States: 		106
    4.0M	/opt/iobroker/iobroker-data/objects.jsonl
    136K	/opt/iobroker/iobroker-data/states.jsonl
    franz@keller:~ $ iobroker multihost connect
    No Multihost server found. Make sure iobroker is running on the host where you enabled multihost discovery (and it is not this host)!
    franz@keller:~ $
    @bastler52
    Buster ist tot und muss ersetzt werden. Schalt die Desktops aus!
      @bastler52
      Bastler52
      schrieb am zuletzt editiert von Bastler52
      @thomas-braun ist das ein bekannter Grund oder ist das eine sinnvolle Empfehlung?
      • B Bastler52
        @bastler52
        Eine sinnvolle Notwendigkeit.
        • B Bastler52
          1 MASTER
          			v.2023-10-10
                   Icon name: computer
                Architecture: arm
          Kernel: 		armv7l
          Userland: 		armhf
          User-ID: 		1000
          X-Server: 		true
          			/usr/bin/npm 		10.2.4
          			/usr/bin/npx 		10.2.4
          10.2.3
          MEMORY:
          Swap:           99M          0B         99M
          			admin 			6.12.0
          Objects type: jsonl
          States  type: jsonl
          Objects: 		9136
          States: 		4427
          ^C
          			v.2023-10-10
                   Icon name: computer
                Architecture: arm64
          Kernel: 		aarch64
          Userland: 		arm64
          User-ID: 		1000
          X-Server: 		true
          			/usr/bin/npm 		10.2.3
          			/usr/bin/npx 		10.2.3
          MEMORY:
          Swap:            99M         37M         62M
          			admin 			6.12.0
          Objects type: jsonl
          States  type: jsonl
          Objects: 		212
          States: 		106
          franz@keller:~ $
          @bastler52 sagte in Multi-Host installieren (läuft nicht):
          MASTER
          da seh ich nichts von
          @der-nordmann sagte in Multi-Host installieren (läuft nicht):
          Proxmox System unter Linux Ubuntu.
          und irgendwas ist da total schräg
          bahnuhrB B 2 Antworten Letzte Antwort
            MASTER
            bahnuhrB Online
            bahnuhrB Online
            bahnuhr
            @homoran sagte in Multi-Host installieren (läuft nicht):
            Hatte ich auch schon.
            Gibt es hier aber genügend thread um dies zu bereinigen.
            Danke.
              MASTER
              Bastler52
              @homoran irgendwas ist da verrutscht. Der Beitrag passt nicht zu meiner Frage. Ich habe zwei Raspberry (4 und 3)
              • Marc BergM Marc Berg
                Ich werde die entsprechende Antwort zusammenstellen und sie dir zusenden.
                Nicht MIR zusenden, sondern hier reinstellen!
                Bastler52
                @marc-berg und fällt in meinen Daten etwas auf.
                Im Forum sind sehr viele Beträge zu diesem Thema
                • B Bastler52
                  Marc BergM Offline
                  Marc BergM Offline
                  Marc Berg
                  @bastler52 Ich habe keine Ahnung von Multihost-Systemen. Erreichen sich denn beide Systeme per ping?
                  • B Bastler52
                    Hallo Experten,
                    ich schätze die umfassende Funktionalität von ioBroker sehr. Ich versuche derzeit, ein Multi-Host-System einzurichten, wobei der Master auf einem Raspberry Pi 4 und der Slave auf einem Raspberry Pi 3B+ läuft. Beide haben unterschiedliche Installationen.
                    Ich habe den Slave komplett neu konfiguriert, um Multi-Host einzurichten. Allerdings wird der Slave nicht erkannt. Liegt das möglicherweise an unterschiedlichen ioBroker-Installation oder eher an meiner Konfiguration?
                    Vielen Dank im Voraus für eure Unterstützung.
                    @bastler52
                    ich empfehle, erstmal beide Systeme auf den aktuellen Stand des Debian Systems zu bringen( Buster ist schon so alt, am besten beide neu aufsetzen), und damit sollte auch dieser Fehler von Node weg sein.
                    Dann schauen, ob das Netzwerk auf beiden richtig konfiguriert ist, damit die sich sehen. (hier fehlen uns alle Infos, um was dazu sagen zu koennen)
                    Und dann kann man erst testen, ob Multihost klappt.
                    Von den Befehlen, die du gemacht hast, war das so richtig, auf dem Master Multihost enablen, damit er fuer 15min offen ist, und auf dem Slave ein "iob multihost browse" - da sollte der Master sichtbar sein, und dann ein "iob multihost connect" hier werden dir dann alle Multihost-Server aufgelistet, und du waehlst (hast ja dann nur einen), diesen aus, er fragt nach Passwort, und dann ist die Verbindung da, und auf dem Master siehst du den Slave unter dem Tab Hosts.
                    • B Bastler52
                      und was ist jetzt der richtige Status?
                      inwiefern?
                      wie ist die denn jetzt?
                      Außer
                      sehe ich nichts zu deinen Multihost Einstellungen
