  3. Off Topic
  4. Upgrade von Debian 11/Bullseye auf 12/Bookworm
upgrade bullseye bookworm
351 Beiträge 51 Kommentatoren 116.4k Aufrufe 52 Beobachtet
  • wendy2702W wendy2702
    habe vor einiger Zeit nach der Anleitung meine PI's 3B von Bullseye auf Bookworm gebracht.
    Heute dann mal ein update & upgrade machen wollen und bekomme das:
    sudo apt update
    Hit:1 http://archive.raspberrypi.org/debian bookworm InRelease
    Hit:2 http://deb.debian.org/debian bookworm InRelease
    Hit:4 http://security.debian.org/debian-security bookworm-security InRelease
    Hit:5 https://deb.nodesource.com/node_16.x bookworm InRelease
    Hit:6 https://deb.nodesource.com/node_18.x bookworm InRelease
    Reading package lists... Done
    1 package can be upgraded. Run 'apt list --upgradable' to see it.
    pi@pi-iobroker:~ $ sudo apt upgrade
    Calculating upgrade... Done
    The following packages have been kept back:
      libcamera-apps-lite
    0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
    2 not fully installed or removed.
    After this operation, 0 B of additional disk space will be used.
    Do you want to continue? [Y/n] y
    Setting up raspi-firmware (1:1.20231024+ds-1+rpt2) ...
    stat: cannot read file system information for '/boot/firmware': No such file or directory
    Error: missing /boot/firmware, did you forget to mount it?
    dpkg: error processing package raspi-firmware (--configure):
     installed raspi-firmware package post-installation script subprocess returned error exit status 1
    dpkg: dependency problems prevent configuration of rpi-eeprom:
     rpi-eeprom depends on raspi-firmware; however:
      Package raspi-firmware is not configured yet.
    dpkg: error processing package rpi-eeprom (--configure):
     dependency problems - leaving unconfigured
    Processing triggers for initramfs-tools (0.142) ...
    Errors were encountered while processing:
     raspi-firmware
     rpi-eeprom
    E: Sub-process /usr/bin/dpkg returned an error code (1)
    Hatte das sonst noch jemand?
    Habe mit Google diverse Lösungsansätze gefunden aber will jetzt nicht alle probieren.
    Wenn also jemand eine Lösung hat die dauerhaft ohne neu installation funktioniert wäre ich dankbar.
    un99known99U Offline
    un99known99
    schrieb am zuletzt editiert von un99known99
    #292
    @wendy2702
    habe mit einem bei rasperrypi kommuniziert und mein Googleergebnis gegenprüfen lassen, ist wohl ok und bei mir hats geklappt:
    Unmount your /boot directory with:
    umount /boot
    Make sure your /boot mount point is unmounted with the above command, "umount /boot" by doing:
    lsblk
    mkdir /boot/firmware
    /etc/fstab
    /boot => /boot/firmware
    systemctl daemon-reload
    mount -a
    • un99known99U un99known99
      @wendy2702
      umount /boot
      lsblk
      /etc/fstab
      mount -a
      #293
      @un99known99
      Da kommt allerdings auch noch das neue Kernel-Paket dazu. Siehe obigen Thread.
      un99known99U 1 Antwort Letzte Antwort
        @un99known99
        un99known99
        #294
        ich kann nur sagen das danach bei mir alles geklappt hat:
        raspi-firmware
        rpi-eeprom
        ließen sich problemlos installieren und seitdem keine weiteren Probleme
          raspi-firmware
          rpi-eeprom
          #295
          @un99known99
          Ja, aber das ist nicht die einzige Stelle, an der Raspberry OS 12 'Bookworm' Änderungen erfahren hat.
          • wendy2702W Online
            wendy2702W Online
            #296
            habe jetzt auch erstmal die hier und verlinkte Anleitung abgearbeitet.
            Aktuell läuft alles.
            Danke!
              Diamand2k22
              #297
              @wendy2702 said in Upgrade von Debian 11/Bullseye auf 12/Bookworm:
              sudo apt update
                libcamera-apps-lite
               raspi-firmware
               rpi-eeprom
              kommt der Fehler nur bei Raspberry Model < 4?
              Bei meinem Raspberry 4B kam der Fehler mit der Firmware nicht!
              W 1 Antwort Letzte Antwort
              • D Diamand2k22
                sudo apt update
                  libcamera-apps-lite
                 raspi-firmware
                 rpi-eeprom
                W Offline
                W Offline
                Wildbill
                #298
                @diamand2k22 Bei meinem 3B mit Deconz und PiVVCU auch nicht. Ich vermute, das betrifft eher die 5er Generation?!
                Gruss, Jürgen
                • Siggi0904S Offline
                  Siggi0904S Offline
                  Siggi0904
                  schrieb am zuletzt editiert von Siggi0904
                  #299
                  Nein, das Thema ist die verwendete Distribution.
                  Wie ihr in den Screens seht, wird einmal Debian und einmal Raspberry.org also Raspberry OS verwendet.
                  Bei Raspbian OS hat man wohl sehr viel geändert, sodass ein Upgrade auf das aktuelle Raspbian OS nicht empfohlen wird, sondern eine komplette Neuinstallation.
                  Hebel zum möglich beheben wurden z.B. nier besprochen:
                  https://forum.iobroker.net/topic/70165/raspi-firmware-update-nach-bookworm-update-gelöst/4?_=1700678987748
                  https://forum.iobroker.net/topic/70165/raspi-firmware-update-nach-bookworm-update-gelöst/12?_=1700678987750
                  • W Wildbill
                    Gruss, Jürgen
                    un99known99
                    #300
                    @Wildbill
                    umount /boot
                    lsblk
                    /etc/fstab
                    mount -a
                    W Thomas BraunT 2 Antworten Letzte Antwort
                      @Wildbill
                      umount /boot
                      lsblk
                      /etc/fstab
                      mount -a
                      W Offline
                      W Offline
                      Wildbill
                      #301
                      @un99known99 Was willst Du mir damit sagen? Bei mir läuft alles und ich bekomme bei apt update bzw apt upgrade keinerlei Fehler oder Warnungen angezeigt.
                      Gruss, Jürgen
                        @Wildbill
                        umount /boot
                        lsblk
                        /etc/fstab
                        mount -a
                        #302
                        @un99known99
                        Und die neuen Kernel-Pakete nicht vergessen.
                          @un99known99
                          un99known99
                          #303
                          was meinst Du damit? Kernel Upgrade kommt via apt update doch mit, oder?
                          raspi-firmware package und rpi-eeprom liessen sich problemlos installieren nach der Umstellung auf /boot/firmware - was / warum muss mit KERNEL gemacht werden?
                          Verzeichnis sieht so aus:
                          drwxr-xr-x 4 root root 4096 Jan 1 1970 firmware
                          drwxr-xr-x 18 root root 4096 Oct 24 13:25 ..
                          lrwxrwxrwx 1 root root 17 Nov 14 13:29 overlays -> firmware/overlays
                          drwxr-xr-x 3 root root 4096 Nov 14 13:29 .
                          sieht so aus als ob beim apt update/upgrade automatische Anlagen gemacht wurden
                            #304
                            @un99known99
                            Das Paket mit dem Kernel heißt aber nun anders, nicht mehr 'raspberrypi-kernel'. Das muss also auch passend zur verwendeten Hardware installiert werden.
                              @un99known99
                              un99known99
                              #305
                              d.h.
                              sudo apt install linux-image-rpi-v7 linux-headers-rpi-v7 # für 32bit?
                              Kommen dann KERNEL upgrades via apt-update?
                                d.h.
                                #306
                                @un99known99 sagte in Upgrade von Debian 11/Bullseye auf 12/Bookworm:
                                Dann kommen natürlich auch Aktualisierungen wieder über apt. Aber das passende Paket muss zuvor installiert sein.
                                  un99known99
                                  #307
                                  pi@jitsi:[/boot] $ sudo apt list | grep -i linux-image-rpi-v8
                                  WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
                                  linux-image-rpi-v8-dbg/stable 1:6.1.58-1+rpt2 arm64
                                  linux-image-rpi-v8/stable 1:6.1.58-1+rpt2 arm64
                                  pi@jitsi:[/boot] $ sudo apt list | grep -i linux-headers-rpi-v8
                                  linux-headers-rpi-v8/stable 1:6.1.58-1+rpt2 arm64
                                  ist schon da?
                                    ist schon da?
                                    #308
                                    ist schon da?
                                    Dann ist ja gut. Wird der auch geladen?
                                    uname -a
                                      ist schon da?
                                      uname -a
                                      un99known99
                                      #309
                                      @thomas-braun said in Upgrade von Debian 11/Bullseye auf 12/Bookworm:
                                      uname -a
                                      Linux jitsi 6.1.21-v8+ #1642 SMP PREEMPT Mon Apr 3 17:24:16 BST 2023 aarch64 GNU/Linux
                                      Passt das?
                                        uname -a
                                        Passt das?
                                        #310
                                        @un99known99
                                        Bei mir wird der aktuelle Kernel so gemeldet
                                        echad@chet:~ $ uname -a
                                        Linux chet 6.1.0-rpi6-rpi-v8 #1 SMP PREEMPT Debian 1:6.1.58-1+rpt2 (2023-10-27)
                                        aarch64 GNU/Linux
                                        echad@chet:~ $
                                        un99known99U 2 Antworten Letzte Antwort
                                          @un99known99
                                          aarch64 GNU/Linux
                                          echad@chet:~ $
                                          un99known99
                                          #311
                                          kann ja mal versuchen, ob
                                          # sudo apt install linux-image-rpi-v8 linux-headers-rpi-v8      # 64bit
                                          was bewirkt, grundsätzlich sieht Dein KERNEL neuer aus
