  3. Off Topic
  4. Upgrade von Debian 11/Bullseye auf 12/Bookworm
upgrade bullseye bookworm
351 Beiträge 51 Kommentatoren 116.4k Aufrufe 52 Beobachtet
  • wendy2702W Online
    wendy2702W Online
    #290
    habe vor einiger Zeit nach der Anleitung meine PI's 3B von Bullseye auf Bookworm gebracht.
    Heute dann mal ein update & upgrade machen wollen und bekomme das:
    sudo apt update
    Hit:1 http://archive.raspberrypi.org/debian bookworm InRelease
    Hit:2 http://deb.debian.org/debian bookworm InRelease
    Hit:4 http://security.debian.org/debian-security bookworm-security InRelease
    Hit:5 https://deb.nodesource.com/node_16.x bookworm InRelease
    Hit:6 https://deb.nodesource.com/node_18.x bookworm InRelease
    Reading package lists... Done
    1 package can be upgraded. Run 'apt list --upgradable' to see it.
    pi@pi-iobroker:~ $ sudo apt upgrade
    Calculating upgrade... Done
    The following packages have been kept back:
      libcamera-apps-lite
    0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
    2 not fully installed or removed.
    After this operation, 0 B of additional disk space will be used.
    Do you want to continue? [Y/n] y
    Setting up raspi-firmware (1:1.20231024+ds-1+rpt2) ...
    stat: cannot read file system information for '/boot/firmware': No such file or directory
    Error: missing /boot/firmware, did you forget to mount it?
    dpkg: error processing package raspi-firmware (--configure):
     installed raspi-firmware package post-installation script subprocess returned error exit status 1
    dpkg: dependency problems prevent configuration of rpi-eeprom:
     rpi-eeprom depends on raspi-firmware; however:
      Package raspi-firmware is not configured yet.
    dpkg: error processing package rpi-eeprom (--configure):
     dependency problems - leaving unconfigured
    Processing triggers for initramfs-tools (0.142) ...
    Errors were encountered while processing:
     raspi-firmware
     rpi-eeprom
    E: Sub-process /usr/bin/dpkg returned an error code (1)
    Hatte das sonst noch jemand?
    Habe mit Google diverse Lösungsansätze gefunden aber will jetzt nicht alle probieren.
    Wenn also jemand eine Lösung hat die dauerhaft ohne neu installation funktioniert wäre ich dankbar.
    Thomas BraunT un99known99U 2 Antworten Letzte Antwort
    • wendy2702W wendy2702
      sudo apt update
        libcamera-apps-lite
       raspi-firmware
       rpi-eeprom
      #291
      @wendy2702 sagte in Upgrade von Debian 11/Bullseye auf 12/Bookworm:
      Ja, @mickym hatte das kürzlich. Das liegt daran, das Raspberry OS hier bei deren Geschmacksrichtung vom 'Bookworm' einiges umgestellt haben.
      Und weil das nicht so ganz trivial ist geht die Empfehlung diesmal noch mehr als sonst schon dahin, den ganzen Sums frisch von Grund auf neuaufzusetzen.
      Hier der Fred dazu:
      https://forum.iobroker.net/topic/70165/raspi-firmware-update-nach-bookworm-update-gelöst
        sudo apt update
          libcamera-apps-lite
         raspi-firmware
         rpi-eeprom
        un99known99U Offline
        un99known99
        schrieb am zuletzt editiert von un99known99
        #292
        @wendy2702
        habe mit einem bei rasperrypi kommuniziert und mein Googleergebnis gegenprüfen lassen, ist wohl ok und bei mir hats geklappt:
        Unmount your /boot directory with:
        umount /boot
        Make sure your /boot mount point is unmounted with the above command, "umount /boot" by doing:
        lsblk
        mkdir /boot/firmware
        /etc/fstab
        /boot => /boot/firmware
        systemctl daemon-reload
        mount -a
        • un99known99U un99known99
          @wendy2702
          umount /boot
          lsblk
          /etc/fstab
          mount -a
          #293
          @un99known99
          Da kommt allerdings auch noch das neue Kernel-Paket dazu. Siehe obigen Thread.
          un99known99U 1 Antwort Letzte Antwort
            @un99known99
            un99known99
            #294
            ich kann nur sagen das danach bei mir alles geklappt hat:
            raspi-firmware
            rpi-eeprom
            ließen sich problemlos installieren und seitdem keine weiteren Probleme
              raspi-firmware
              rpi-eeprom
              #295
              @un99known99
              Ja, aber das ist nicht die einzige Stelle, an der Raspberry OS 12 'Bookworm' Änderungen erfahren hat.
              • wendy2702W Online
                wendy2702W Online
                #296
                habe jetzt auch erstmal die hier und verlinkte Anleitung abgearbeitet.
                Aktuell läuft alles.
                Danke!
                  Diamand2k22
                  #297
                  @wendy2702 said in Upgrade von Debian 11/Bullseye auf 12/Bookworm:
                  sudo apt update
                    libcamera-apps-lite
                   raspi-firmware
                   rpi-eeprom
                  kommt der Fehler nur bei Raspberry Model < 4?
                  Bei meinem Raspberry 4B kam der Fehler mit der Firmware nicht!
                  W 1 Antwort Letzte Antwort
                  • D Diamand2k22
                    sudo apt update
                      libcamera-apps-lite
                     raspi-firmware
                     rpi-eeprom
                    W Offline
                    W Offline
                    Wildbill
                    #298
                    @diamand2k22 Bei meinem 3B mit Deconz und PiVVCU auch nicht. Ich vermute, das betrifft eher die 5er Generation?!
                    Gruss, Jürgen
                    • Siggi0904S Offline
                      Siggi0904S Offline
                      Siggi0904
                      schrieb am zuletzt editiert von Siggi0904
                      #299
                      Nein, das Thema ist die verwendete Distribution.
                      Wie ihr in den Screens seht, wird einmal Debian und einmal Raspberry.org also Raspberry OS verwendet.
                      Bei Raspbian OS hat man wohl sehr viel geändert, sodass ein Upgrade auf das aktuelle Raspbian OS nicht empfohlen wird, sondern eine komplette Neuinstallation.
                      Hebel zum möglich beheben wurden z.B. nier besprochen:
                      https://forum.iobroker.net/topic/70165/raspi-firmware-update-nach-bookworm-update-gelöst/4?_=1700678987748
                      https://forum.iobroker.net/topic/70165/raspi-firmware-update-nach-bookworm-update-gelöst/12?_=1700678987750
                      • W Wildbill
                        Gruss, Jürgen
                        un99known99
                        #300
                        @Wildbill
                        umount /boot
                        lsblk
                        /etc/fstab
                        mount -a
                        W Thomas BraunT 2 Antworten Letzte Antwort
                          @Wildbill
                          umount /boot
                          lsblk
                          /etc/fstab
                          mount -a
                          W Offline
                          W Offline
                          Wildbill
                          #301
                          @un99known99 Was willst Du mir damit sagen? Bei mir läuft alles und ich bekomme bei apt update bzw apt upgrade keinerlei Fehler oder Warnungen angezeigt.
                          Gruss, Jürgen
                            @Wildbill
                            umount /boot
                            lsblk
                            /etc/fstab
                            mount -a
                            #302
                            @un99known99
                            Und die neuen Kernel-Pakete nicht vergessen.
                              @un99known99
                              un99known99
                              #303
                              was meinst Du damit? Kernel Upgrade kommt via apt update doch mit, oder?
                              raspi-firmware package und rpi-eeprom liessen sich problemlos installieren nach der Umstellung auf /boot/firmware - was / warum muss mit KERNEL gemacht werden?
                              Verzeichnis sieht so aus:
                              drwxr-xr-x 4 root root 4096 Jan 1 1970 firmware
                              drwxr-xr-x 18 root root 4096 Oct 24 13:25 ..
                              lrwxrwxrwx 1 root root 17 Nov 14 13:29 overlays -> firmware/overlays
                              drwxr-xr-x 3 root root 4096 Nov 14 13:29 .
                              sieht so aus als ob beim apt update/upgrade automatische Anlagen gemacht wurden
                                #304
                                @un99known99
                                Das Paket mit dem Kernel heißt aber nun anders, nicht mehr 'raspberrypi-kernel'. Das muss also auch passend zur verwendeten Hardware installiert werden.
                                  @un99known99
                                  un99known99
                                  #305
                                  d.h.
                                  sudo apt install linux-image-rpi-v7 linux-headers-rpi-v7 # für 32bit?
                                  Kommen dann KERNEL upgrades via apt-update?
                                    d.h.
                                    #306
                                    @un99known99 sagte in Upgrade von Debian 11/Bullseye auf 12/Bookworm:
                                    Dann kommen natürlich auch Aktualisierungen wieder über apt. Aber das passende Paket muss zuvor installiert sein.
                                      un99known99
                                      #307
                                      pi@jitsi:[/boot] $ sudo apt list | grep -i linux-image-rpi-v8
                                      WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
                                      linux-image-rpi-v8-dbg/stable 1:6.1.58-1+rpt2 arm64
                                      linux-image-rpi-v8/stable 1:6.1.58-1+rpt2 arm64
                                      pi@jitsi:[/boot] $ sudo apt list | grep -i linux-headers-rpi-v8
                                      linux-headers-rpi-v8/stable 1:6.1.58-1+rpt2 arm64
                                      ist schon da?
                                        ist schon da?
                                        #308
                                        ist schon da?
                                        Dann ist ja gut. Wird der auch geladen?
                                        uname -a
                                          ist schon da?
                                          uname -a
                                          un99known99
                                          #309
                                          @thomas-braun said in Upgrade von Debian 11/Bullseye auf 12/Bookworm:
                                          uname -a
                                          Linux jitsi 6.1.21-v8+ #1642 SMP PREEMPT Mon Apr 3 17:24:16 BST 2023 aarch64 GNU/Linux
                                          Passt das?
