  3. Einsteigerfragen
  4. ioBroker auf neuer Maschine aufgesetzt und Adapter Probleme
267 Beiträge 8 Kommentatoren 70.2k Aufrufe 8 Beobachtet
  • G Gismoh
    @dp20eic
    Merci,
    dies hatte ich im Vorfeld auch bereits getan, allerdings mit "Hindernissen" ;)
    Schreibe nun mit, was passiert....
    -Adapter wurde deinstalliert,
    -ioBroker neugestartet
    beim Versuch ihn aus der Weboberfläche hinzuzufügen kommt folgende Fehlermeldung:
    $ iobroker add ble --host ioBrokerVM
    NPM version: 9.8.1
    Installing iobroker.ble@0.13.4... (System call)
    npm ERR! code 1npm ERR! path /opt/iobroker/node_modules/@abandonware/noblenpm ERR! command failednpm ERR! command sh -c node-gyp-buildnpm ERR! (node:2525) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.npm ERR! (Use `node --trace-deprecation ...` to show where the warning was created)npm ERR! Traceback (most recent call last):npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 51, in <module>npm ERR! sys.exit(gyp.script_main())npm ERR! ^^^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 670, in script_mainnpm ERR! return main(sys.argv[1:])npm ERR! ^^^^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 662, in mainnpm ERR! return gyp_main(args)npm ERR! ^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 629, in gyp_mainnpm ERR! [generator, flat_list, targets, data] = Load(npm ERR! ^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 150, in Loadnpm ERR! result = gyp.input.Load(npm ERR! ^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 3021, in Loadnpm ERR! LoadTargetBuildFile(npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 411, in LoadTargetBuildFilenpm ERR! build_file_data = LoadOneBuildFile(npm ERR! ^^^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 239, in LoadOneBuildFilenpm ERR! build_file_contents = open(build_file_path, "rU").read()npm ERR! ^^^^^^^^^^^^^^^^^^^^^^^^^^^npm ERR! ValueError: invalid mode: 'rU' while trying to load binding.gypnpm ERR! gyp ERR! configure error npm ERR! gyp ERR! stack Error: `gyp` failed with exit code: 1npm ERR! gyp ERR! stack at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:351:16)npm ERR! gyp ERR! stack at ChildProcess.emit (node:events:517:28)npm ERR! gyp ERR! stack at ChildProcess._handle.onexit (node:internal/child_process:292:12)npm ERR! gyp ERR! System Linux 6.1.0-13-amd64npm ERR! gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/@abandonware/noblenpm ERR! gyp ERR! node -v v18.18.2npm ERR! gyp ERR! node-gyp -v v7.1.2npm ERR! gyp ERR! not oknpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-07T15_10_54_825Z-debug-0.log
    host.ioBrokerVM Cannot install iobroker.ble@0.13.4: 1
    ERROR: Process exited with code 25
    Edit:
    Habe danach
    curl -sL http://iobroker.net/fix.sh | bash -
    und
    sudo -H -u iobroker npm cache verify
    gemacht, danach erneut versucht den BLE Adapter zu installieren, aber gleicher Fehler.
    da_WoodyD
    da_WoodyD
    @gismoh bin kein Profi, aber wenn ich dein post so lese.
    Du hast iob installiert, dann ble. Da hat noch alles geklappt. Danach das Backup eingespielt und locker flockig den Port 8081 verbogen.
    Ob das so gut gehen kann?
    G 1 Antwort Letzte Antwort
    • G Gismoh
      @crunchip
      systemctl status bluetooth
      Liefert:
      ● bluetooth.service - Bluetooth service
           Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled; preset: en>
           Active: active (running) since Tue 2023-11-07 15:12:36 CET; 2min 58s ago
             Docs: man:bluetoothd(8)
         Main PID: 584 (bluetoothd)
           Status: "Running"
            Tasks: 1 (limit: 4623)
           Memory: 3.6M
              CPU: 42ms
           CGroup: /system.slice/bluetooth.service
                   └─584 /usr/libexec/bluetooth/bluetoothd
      Nov 07 15:12:37 ioBrokerVM bluetoothd[584]: Endpoint registered: sender=:1.28 p>
      lines 1-22/22 (END)
      hciconfig
      Liefert:
      hci0:   Type: Primary  Bus: USB
              BD Address: 0C:54:15:D0:86:93  ACL MTU: 1021:4  SCO MTU: 96:6
              UP RUNNING
              RX bytes:819 acl:0 sco:0 events:63 errors:0
              TX bytes:3692 acl:0 sco:0 commands:63 errors:0
      rfkill list all
      Liefert:
      -bash: rfkill: Kommando nicht gefunden.
      dmesg | egrep -i 'blue|firm'
      Liefert:
      [    0.266252] ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
      [    4.193119] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
      [    4.265674] Bluetooth: Core ver 2.22
      [    4.265696] NET: Registered PF_BLUETOOTH protocol family
      [    4.265698] Bluetooth: HCI device and connection manager initialized
      [    4.265740] Bluetooth: HCI socket layer initialized
      [    4.265744] Bluetooth: L2CAP socket layer initialized
      [    4.265748] Bluetooth: SCO socket layer initialized
      [    4.319533] Bluetooth: hci0: Firmware revision 0.1 build 19 week 44 2021
      [    4.380570] iwlwifi 0000:02:00.0: loaded firmware version 36.ca7b901d.0 8265-36.ucode op_mode iwlmvm
      [    4.938807] i915 0000:00:02.0: [drm] Finished loading DMC firmware i915/kbl_dmc_ver1_04.bin (v1.4)
      [    5.478986] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
      [    5.478990] Bluetooth: BNEP filters: protocol multicast
      [    5.478994] Bluetooth: BNEP socket layer initialized
      [    5.481078] Bluetooth: MGMT ver 1.22
      [   17.632400] Bluetooth: hci0: urb 000000003977ddce failed to resubmit (2)
      crunchipC
      crunchipC
      Developer Global Moderator Most Active Forum Testing
      @gismoh sagte in ioBroker auf neuer Maschine aufgesetzt und Adapter Probleme:
      Sieht aber irgendwie so aus als wenn da etwas nicht stimmt, unabhängig von deinem npm Problem
      • G Gismoh
        @dp20eic
        Merci,
        NPM version: 9.8.1
        Edit:
        Habe danach
        und
        crunchipC
        crunchipC
        Ist mir gerade eingefallen, schau mal bei meinem issue
        https://github.com/AlCalzone/ioBroker.ble/issues/801
        • da_WoodyD da_Woody
          G
          G
          Gismoh
          schrieb am zuletzt editiert von Gismoh
          @da_woody
          Dachte Backitup, ist das "Mittel der Wahl"?
          Habe allerdings nun das erste mal damit ein Backup widerhergestellt.
          Um noch mal zu sehen, das ich mir das nicht eingebildet hatte, das vor dem einspielen des Backups ioBroker ersteinmal "Normal" lief, die VM wieder vom früheren Zeitpunkt widerhergestellt.
          = Weboberfläche wieder mit :8081 aufrufbar, und ble ist grün und hat Geräte gefunden und aktualisiert die Werte.
          Nachtrag: Hab das Backup einspielen bereits zwei mal durch gemacht, jeweils mit einem neuen Backup. Aber das Ergebnis war jeweils dasselbe.
          ioBroker auf: Lenovo ThinkCentre M910Q Tiny i5-7500T 16 GB mit proxmox in VM (Bookworm)
          crunchipC da_WoodyD 2 Antworten Letzte Antwort
          • G Gismoh
            @da_woody
            crunchipC
            crunchipC
            @gismoh dann deinstalliere doch mal den ble jetzt und spiel anschliessend dein backup zurück
              G
              G
              Gismoh
              @crunchip
              merci, werde ich dann heute später machen, muss nun ersteinmal vom Rechner weg - sonst holt die GG noch das Nudelholz 🤕
              • G Gismoh
                @da_woody
                da_WoodyD
                da_WoodyD
                jo, auf einem nackten system.
                offensichtlich knallt dir da was rein. warum sollte die oberfläche nachher nicht mehr über :8081 erreichbar sein?
                das war, was mich nochmal nachlesen hat lassen...
                  crunchipC
                  crunchipC
                  @da_woody sagte in ioBroker auf neuer Maschine aufgesetzt und Adapter Probleme:
                  Möglich das der admin nicht gestartet war
                    G
                    G
                    Gismoh
                    @crunchip @da_Woody
                    Admin war zuerst nicht gestartet, das stimmt, hatte ich aber über die Console nachgeholt.
                    Aber auch danach war er unter :8081 nicht erreichbar. Erst nachdem ich über die Console einen "admin.1" installiert hatte, war dieser dann über :8091 erreichbar.
                    Spiele gerade erneut ein Restore mit dem Backitup Adapter ein, habe diesmal alle Instanzen außer "admin" und "backitup" auf der Zielmaschine vorher deinstalliert.
                    Mal sehen ;)
                    • G Gismoh
                      @crunchip @da_Woody
                      Mal sehen ;)
                      crunchipC
                      crunchipC
                      gebunden vllt an die IP?
                        G
                        G
                        Gismoh
                        @crunchip
                        würde mich wundern, denn vor der Backup Einspielung hatte es ja mit 8081 geklappt - sonst hatte ich ja nichts geändert.
                        Oder wird im iobroker selber die IP noch "bestimmt" ?
                        • G Gismoh
                          @crunchip
                          crunchipC
                          crunchipC
                          @gismoh klar, aber was ist denn in der alten Installation eingestellt, sprich deinem backup? diese Einstellungen spielst du ja durch dein backup ein
                            G
                            G
                            Gismoh
                            @crunchip
                            wo wird denn im ioBroker die eigene IP gesetzt? Habe dort nichts gefunden.
                            • G Gismoh
                              @crunchip
                              crunchipC
                              crunchipC
                              @gismoh in der admin Instanz...IP- Adresse
                              sollte eigentlich auf 0.0.0.0 stehen
                              G 2 Antworten Letzte Antwort
                                G
                                G
                                Gismoh
                                ioBroker wurde mit dem frischen Backup gefüttert, nun mit :8081 kein Zugriff.
                                Dann update & upgrade abgesetzt, danach noch den fix.
                                Kein Zugriff aufs Interface.
                                • G Gismoh
                                  G
                                  G
                                  Gismoh
                                  iobroker list instances
                                  liefert:
                                  root@ioBrokerVM:~# iobroker list instances
                                  + system.adapter.admin.0                  : admin                 : ioBrokerVM                               -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                                    system.adapter.alarm.0                  : alarm                 : ioBrokerVM                               - disabled
                                    system.adapter.alexa2.0                 : alexa2                : ioBrokerVM                               - disabled
                                  + system.adapter.backitup.0               : backitup              : ioBrokerVM                               -  enabled
                                    system.adapter.ble.0                    : ble                   : ioBrokerVM                               - disabled
                                    system.adapter.daikin-cloud.0           : daikin-cloud          : ioBrokerVM                               - disabled
                                    system.adapter.daswetter.0              : daswetter             : ioBrokerVM                               - disabled
                                    system.adapter.deconz.0                 : deconz                : ioBrokerVM                               - disabled, port: 8090
                                    system.adapter.device-reminder.0        : device-reminder       : ioBrokerVM                               - disabled
                                    system.adapter.discovery.0              : discovery             : ioBrokerVM                               - disabled
                                    system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : ioBrokerVM                               - disabled
                                    system.adapter.enigma2.0                : enigma2               : ioBrokerVM                               - disabled
                                    system.adapter.fb-checkpresence.0       : fb-checkpresence      : ioBrokerVM                               - disabled
                                    system.adapter.fiat.0                   : fiat                  : ioBrokerVM                               - disabled
                                    system.adapter.flot.0                   : flot                  : ioBrokerVM                               - disabled
                                    system.adapter.fullybrowser.0           : fullybrowser          : ioBrokerVM                               - disabled
                                    system.adapter.go-e.0                   : go-e                  : ioBrokerVM                               - disabled
                                    system.adapter.go-e.1                   : go-e                  : ioBrokerVM                               - disabled
                                    system.adapter.ham.0                    : ham                   : ioBrokerVM                               - disabled
                                    system.adapter.harmony.0                : harmony               : ioBrokerVM                               - disabled
                                    system.adapter.hue-extended.0           : hue-extended          : ioBrokerVM                               - disabled
                                    system.adapter.hue.0                    : hue                   : ioBrokerVM                               - disabled, port: 443
                                    system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ioBrokerVM                               - disabled
                                    system.adapter.influxdb.0               : influxdb              : ioBrokerVM                               - disabled, port: 8086
                                    system.adapter.info.0                   : info                  : ioBrokerVM                               - disabled
                                    system.adapter.iot.0                    : iot                   : ioBrokerVM                               - disabled
                                    system.adapter.javascript.0             : javascript            : ioBrokerVM                               - disabled
                                    system.adapter.meross.0                 : meross                : ioBrokerVM                               - disabled
                                    system.adapter.mihome-vacuum.0          : mihome-vacuum         : ioBrokerVM                               - disabled, port: 54321
                                    system.adapter.mihome-vacuum.2          : mihome-vacuum         : ioBrokerVM                               - disabled, port: 54321
                                    system.adapter.mobile.0                 : mobile                : ioBrokerVM                               - disabled
                                    system.adapter.openweathermap.0         : openweathermap        : ioBrokerVM                               - disabled
                                    system.adapter.pi-hole.0                : pi-hole               : ioBrokerVM                               - disabled
                                    system.adapter.pushover.0               : pushover              : ioBrokerVM                               - disabled
                                    system.adapter.pvforecast.0             : pvforecast            : ioBrokerVM                               - disabled
                                    system.adapter.radar2.0                 : radar2                : ioBrokerVM                               - disabled
                                    system.adapter.shelly.0                 : shelly                : ioBrokerVM                               - disabled, port: 1882, bind: 0.0.0.0
                                    system.adapter.shelly.1                 : shelly                : ioBrokerVM                               - disabled, port: 1882, bind: 0.0.0.0
                                    system.adapter.smartcontrol.0           : smartcontrol          : ioBrokerVM                               - disabled
                                    system.adapter.socketio.0               : socketio              : ioBrokerVM                               - disabled, port: 8084, bind: 0.0.0.0, run as: admin
                                    system.adapter.sonoff.0                 : sonoff                : ioBrokerVM                               - disabled, port: 1883, bind: 0.0.0.0
                                    system.adapter.tado.0                   : tado                  : ioBrokerVM                               - disabled
                                    system.adapter.telegram.0               : telegram              : ioBrokerVM                               - disabled, port: 8443, bind: 0.0.0.0
                                    system.adapter.tibberlink.0             : tibberlink            : ioBrokerVM                               - disabled
                                    system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBrokerVM                               - disabled
                                    system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBrokerVM                               - disabled
                                    system.adapter.vis-material-advanced.0  : vis-material-advanced : ioBrokerVM                               - disabled
                                    system.adapter.vis-metro.0              : vis-metro             : ioBrokerVM                               - disabled
                                    system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBrokerVM                               - disabled
                                    system.adapter.vis.0                    : vis                   : ioBrokerVM                               - disabled
                                    system.adapter.weatherunderground.0     : weatherunderground    : ioBrokerVM                               - disabled
                                    system.adapter.web.0                    : web                   : ioBrokerVM                               - disabled, port: 8082, bind: 0.0.0.0, run as: admin
                                    system.adapter.worx.0                   : worx                  : ioBrokerVM                               - disabled
                                  + instance is alive
                                  • G Gismoh
                                    liefert:
                                    + instance is alive
                                    G
                                    G
                                    Gismoh
                                    Ah, mit https:// komme ich drauf ;)
                                    vorher war ohne .... argh (schäm)
                                    Mal sehen, was nun die anderen Adapter sagen.
                                    • G Gismoh
                                      G
                                      G
                                      Gismoh
                                      sehe bereits, das einige adapter laufen, aber manche auch nicht (habe noch nicht alle ausprobiert).
                                      ble ist z.B. rot:
                                      verbunden mit host = rot
                                      lebenszeichen = rot
                                      Verbunden mit gerät oder dienst = grün.
                                      Komme nicht in die Einstellungen des Adapters rein, es wird 404, File Index_m.html not found angezeigt.
                                      bei VIS, ebenso 404.
                                      Werde nun mal die Konfiguration über Backitup einspielen, mal sehen ob es daran liegt. (mache aber vorher eine Sicherung der VM)
                                        G
                                        G
                                        Gismoh
                                        @crunchip
                                        Leider auch keine Änderung, außer das ich nun ohne zweiten admin adapter reinkomme (mit https) ansonsten keine Änderung .
                                        • G Gismoh
                                          ble ist z.B. rot:
                                          lebenszeichen = rot
                                          crunchipC
                                          crunchipC
                                          wenn du das backup einspielst, musst du schon ne weile warten, alles Adapter müssen erst wieder neu gebaut werden.
                                          vis muss vor dem backup einspielen, schon manuell installiert werden
                                          83.8k
