  3. Einsteigerfragen
  4. ioBroker auf neuer Maschine aufgesetzt und Adapter Probleme
    6.7k
267 Beiträge 8 Kommentatoren 63.7k Aufrufe 8 Beobachtet
  • G Gismoh
    @crunchip
    systemctl status bluetooth
    Liefert:
    ● bluetooth.service - Bluetooth service
         Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled; preset: en>
         Active: active (running) since Tue 2023-11-07 15:12:36 CET; 2min 58s ago
           Docs: man:bluetoothd(8)
       Main PID: 584 (bluetoothd)
         Status: "Running"
          Tasks: 1 (limit: 4623)
         Memory: 3.6M
            CPU: 42ms
         CGroup: /system.slice/bluetooth.service
                 └─584 /usr/libexec/bluetooth/bluetoothd
    Nov 07 15:12:37 ioBrokerVM bluetoothd[584]: Endpoint registered: sender=:1.28 p>
    lines 1-22/22 (END)
    hciconfig
    Liefert:
    hci0:   Type: Primary  Bus: USB
            BD Address: 0C:54:15:D0:86:93  ACL MTU: 1021:4  SCO MTU: 96:6
            UP RUNNING
            RX bytes:819 acl:0 sco:0 events:63 errors:0
            TX bytes:3692 acl:0 sco:0 commands:63 errors:0
    rfkill list all
    Liefert:
    -bash: rfkill: Kommando nicht gefunden.
    dmesg | egrep -i 'blue|firm'
    Liefert:
    [    0.266252] ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
    [    4.193119] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
    [    4.265674] Bluetooth: Core ver 2.22
    [    4.265696] NET: Registered PF_BLUETOOTH protocol family
    [    4.265698] Bluetooth: HCI device and connection manager initialized
    [    4.265740] Bluetooth: HCI socket layer initialized
    [    4.265744] Bluetooth: L2CAP socket layer initialized
    [    4.265748] Bluetooth: SCO socket layer initialized
    [    4.319533] Bluetooth: hci0: Firmware revision 0.1 build 19 week 44 2021
    [    4.380570] iwlwifi 0000:02:00.0: loaded firmware version 36.ca7b901d.0 8265-36.ucode op_mode iwlmvm
    [    4.938807] i915 0000:00:02.0: [drm] Finished loading DMC firmware i915/kbl_dmc_ver1_04.bin (v1.4)
    [    5.478986] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
    [    5.478990] Bluetooth: BNEP filters: protocol multicast
    [    5.478994] Bluetooth: BNEP socket layer initialized
    [    5.481078] Bluetooth: MGMT ver 1.22
    [   17.632400] Bluetooth: hci0: urb 000000003977ddce failed to resubmit (2)
    @gismoh sagte in ioBroker auf neuer Maschine aufgesetzt und Adapter Probleme:
    Moin,
    dann installier Dir mal rfkill
    # sudo apt install rfkill
    Bernd
    G 1 Antwort Letzte Antwort
      Moin,
      Bernd
      Gismoh
      @dp20eic
      rfkill list all
      Liefert:
      0: hci0: Bluetooth
              Soft blocked: no
              Hard blocked: no
      ioBroker auf: Lenovo ThinkCentre M910Q Tiny i5-7500T 16 GB mit proxmox in VM (Bookworm)
      • G Gismoh
        @dp20eic
        VM und ganze Maschine wurden bereits mehrfach neu gestartet.
        Den BLE hatte ich nicht wieder deinstalliert, sondern das Backup aufgespielt.
        Moin,
        kannst Du den Adapter jetzt einmal deinstallieren und dann noch einmal neu installieren und konfigurieren.
        Bernd
          Moin,
          Bernd
          Gismoh
          schrieb am zuletzt editiert von Gismoh
          @dp20eic
          Merci,
          dies hatte ich im Vorfeld auch bereits getan, allerdings mit "Hindernissen" ;)
          Schreibe nun mit, was passiert....
          -Adapter wurde deinstalliert,
          -ioBroker neugestartet
          beim Versuch ihn aus der Weboberfläche hinzuzufügen kommt folgende Fehlermeldung:
          $ iobroker add ble --host ioBrokerVM
          NPM version: 9.8.1
          Installing iobroker.ble@0.13.4... (System call)
          npm ERR! code 1npm ERR! path /opt/iobroker/node_modules/@abandonware/noblenpm ERR! command failednpm ERR! command sh -c node-gyp-buildnpm ERR! (node:2525) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.npm ERR! (Use `node --trace-deprecation ...` to show where the warning was created)npm ERR! Traceback (most recent call last):npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 51, in <module>npm ERR! sys.exit(gyp.script_main())npm ERR! ^^^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 670, in script_mainnpm ERR! return main(sys.argv[1:])npm ERR! ^^^^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 662, in mainnpm ERR! return gyp_main(args)npm ERR! ^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 629, in gyp_mainnpm ERR! [generator, flat_list, targets, data] = Load(npm ERR! ^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 150, in Loadnpm ERR! result = gyp.input.Load(npm ERR! ^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 3021, in Loadnpm ERR! LoadTargetBuildFile(npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 411, in LoadTargetBuildFilenpm ERR! build_file_data = LoadOneBuildFile(npm ERR! ^^^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 239, in LoadOneBuildFilenpm ERR! build_file_contents = open(build_file_path, "rU").read()npm ERR! ^^^^^^^^^^^^^^^^^^^^^^^^^^^npm ERR! ValueError: invalid mode: 'rU' while trying to load binding.gypnpm ERR! gyp ERR! configure error npm ERR! gyp ERR! stack Error: `gyp` failed with exit code: 1npm ERR! gyp ERR! stack at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:351:16)npm ERR! gyp ERR! stack at ChildProcess.emit (node:events:517:28)npm ERR! gyp ERR! stack at ChildProcess._handle.onexit (node:internal/child_process:292:12)npm ERR! gyp ERR! System Linux 6.1.0-13-amd64npm ERR! gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/@abandonware/noblenpm ERR! gyp ERR! node -v v18.18.2npm ERR! gyp ERR! node-gyp -v v7.1.2npm ERR! gyp ERR! not oknpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-07T15_10_54_825Z-debug-0.log
          host.ioBrokerVM Cannot install iobroker.ble@0.13.4: 1
          ERROR: Process exited with code 25
          Edit:
          Habe danach
          curl -sL http://iobroker.net/fix.sh | bash -
          und
          sudo -H -u iobroker npm cache verify
          gemacht, danach erneut versucht den BLE Adapter zu installieren, aber gleicher Fehler.
          da_WoodyD crunchipC 2 Antworten Letzte Antwort
          • G Gismoh
            @dp20eic
            Merci,
            NPM version: 9.8.1
            Edit:
            Habe danach
            und
            da_WoodyD Offline
            da_WoodyD Offline
            @gismoh bin kein Profi, aber wenn ich dein post so lese.
            Du hast iob installiert, dann ble. Da hat noch alles geklappt. Danach das Backup eingespielt und locker flockig den Port 8081 verbogen.
            Ob das so gut gehen kann?
            • G Gismoh
              @crunchip
              Liefert:
                   Status: "Running"
                   Memory: 3.6M
                      CPU: 42ms
              lines 1-22/22 (END)
              hciconfig
              Liefert:
                      UP RUNNING
              rfkill list all
              Liefert:
              Liefert:
              crunchipC Abwesend
              crunchipC Abwesend
              Sieht aber irgendwie so aus als wenn da etwas nicht stimmt, unabhängig von deinem npm Problem
              • G Gismoh
                @dp20eic
                Merci,
                NPM version: 9.8.1
                Edit:
                Habe danach
                und
                crunchipC Abwesend
                crunchipC Abwesend
                Ist mir gerade eingefallen, schau mal bei meinem issue
                https://github.com/AlCalzone/ioBroker.ble/issues/801
                • da_WoodyD da_Woody
                  Gismoh
                  @da_woody
                  Dachte Backitup, ist das "Mittel der Wahl"?
                  Habe allerdings nun das erste mal damit ein Backup widerhergestellt.
                  Um noch mal zu sehen, das ich mir das nicht eingebildet hatte, das vor dem einspielen des Backups ioBroker ersteinmal "Normal" lief, die VM wieder vom früheren Zeitpunkt widerhergestellt.
                  = Weboberfläche wieder mit :8081 aufrufbar, und ble ist grün und hat Geräte gefunden und aktualisiert die Werte.
                  Nachtrag: Hab das Backup einspielen bereits zwei mal durch gemacht, jeweils mit einem neuen Backup. Aber das Ergebnis war jeweils dasselbe.
                  crunchipC da_WoodyD 2 Antworten Letzte Antwort
                  • G Gismoh
                    @da_woody
                    crunchipC Abwesend
                    crunchipC Abwesend
                    @gismoh dann deinstalliere doch mal den ble jetzt und spiel anschliessend dein backup zurück
                      Gismoh
                      @crunchip
                      merci, werde ich dann heute später machen, muss nun ersteinmal vom Rechner weg - sonst holt die GG noch das Nudelholz 🤕
                      • G Gismoh
                        @da_woody
                        da_WoodyD Offline
                        da_WoodyD Offline
                        jo, auf einem nackten system.
                        offensichtlich knallt dir da was rein. warum sollte die oberfläche nachher nicht mehr über :8081 erreichbar sein?
                        das war, was mich nochmal nachlesen hat lassen...
                          crunchipC Abwesend
                          crunchipC Abwesend
                          @da_woody sagte in ioBroker auf neuer Maschine aufgesetzt und Adapter Probleme:
                          Möglich das der admin nicht gestartet war
                            Gismoh
                            @crunchip @da_Woody
                            Admin war zuerst nicht gestartet, das stimmt, hatte ich aber über die Console nachgeholt.
                            Aber auch danach war er unter :8081 nicht erreichbar. Erst nachdem ich über die Console einen "admin.1" installiert hatte, war dieser dann über :8091 erreichbar.
                            Spiele gerade erneut ein Restore mit dem Backitup Adapter ein, habe diesmal alle Instanzen außer "admin" und "backitup" auf der Zielmaschine vorher deinstalliert.
                            Mal sehen ;)
                            • G Gismoh
                              @crunchip @da_Woody
                              Mal sehen ;)
                              crunchipC Abwesend
                              crunchipC Abwesend
                              gebunden vllt an die IP?
                                Gismoh
                                @crunchip
                                würde mich wundern, denn vor der Backup Einspielung hatte es ja mit 8081 geklappt - sonst hatte ich ja nichts geändert.
                                Oder wird im iobroker selber die IP noch "bestimmt" ?
                                • G Gismoh
                                  @crunchip
                                  crunchipC Abwesend
                                  crunchipC Abwesend
                                  @gismoh klar, aber was ist denn in der alten Installation eingestellt, sprich deinem backup? diese Einstellungen spielst du ja durch dein backup ein
                                    Gismoh
                                    @crunchip
                                    wo wird denn im ioBroker die eigene IP gesetzt? Habe dort nichts gefunden.
                                    • G Gismoh
                                      @crunchip
                                      crunchipC Abwesend
                                      crunchipC Abwesend
                                      @gismoh in der admin Instanz...IP- Adresse
                                      sollte eigentlich auf 0.0.0.0 stehen
                                      G 2 Antworten Letzte Antwort
                                        Gismoh
                                        ioBroker wurde mit dem frischen Backup gefüttert, nun mit :8081 kein Zugriff.
                                        Dann update & upgrade abgesetzt, danach noch den fix.
                                        Kein Zugriff aufs Interface.
                                        • G Gismoh
                                          Gismoh
                                          iobroker list instances
                                          liefert:
                                          root@ioBrokerVM:~# iobroker list instances
                                          + system.adapter.admin.0                  : admin                 : ioBrokerVM                               -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                                            system.adapter.alarm.0                  : alarm                 : ioBrokerVM                               - disabled
                                            system.adapter.alexa2.0                 : alexa2                : ioBrokerVM                               - disabled
                                          + system.adapter.backitup.0               : backitup              : ioBrokerVM                               -  enabled
                                            system.adapter.ble.0                    : ble                   : ioBrokerVM                               - disabled
                                            system.adapter.daikin-cloud.0           : daikin-cloud          : ioBrokerVM                               - disabled
                                            system.adapter.daswetter.0              : daswetter             : ioBrokerVM                               - disabled
                                            system.adapter.deconz.0                 : deconz                : ioBrokerVM                               - disabled, port: 8090
                                            system.adapter.device-reminder.0        : device-reminder       : ioBrokerVM                               - disabled
                                            system.adapter.discovery.0              : discovery             : ioBrokerVM                               - disabled
                                            system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : ioBrokerVM                               - disabled
                                            system.adapter.enigma2.0                : enigma2               : ioBrokerVM                               - disabled
                                            system.adapter.fb-checkpresence.0       : fb-checkpresence      : ioBrokerVM                               - disabled
                                            system.adapter.fiat.0                   : fiat                  : ioBrokerVM                               - disabled
                                            system.adapter.flot.0                   : flot                  : ioBrokerVM                               - disabled
                                            system.adapter.fullybrowser.0           : fullybrowser          : ioBrokerVM                               - disabled
                                            system.adapter.go-e.0                   : go-e                  : ioBrokerVM                               - disabled
                                            system.adapter.go-e.1                   : go-e                  : ioBrokerVM                               - disabled
                                            system.adapter.ham.0                    : ham                   : ioBrokerVM                               - disabled
                                            system.adapter.harmony.0                : harmony               : ioBrokerVM                               - disabled
                                            system.adapter.hue-extended.0           : hue-extended          : ioBrokerVM                               - disabled
                                            system.adapter.hue.0                    : hue                   : ioBrokerVM                               - disabled, port: 443
                                            system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ioBrokerVM                               - disabled
                                            system.adapter.influxdb.0               : influxdb              : ioBrokerVM                               - disabled, port: 8086
                                            system.adapter.info.0                   : info                  : ioBrokerVM                               - disabled
                                            system.adapter.iot.0                    : iot                   : ioBrokerVM                               - disabled
                                            system.adapter.javascript.0             : javascript            : ioBrokerVM                               - disabled
                                            system.adapter.meross.0                 : meross                : ioBrokerVM                               - disabled
                                            system.adapter.mihome-vacuum.0          : mihome-vacuum         : ioBrokerVM                               - disabled, port: 54321
                                            system.adapter.mihome-vacuum.2          : mihome-vacuum         : ioBrokerVM                               - disabled, port: 54321
                                            system.adapter.mobile.0                 : mobile                : ioBrokerVM                               - disabled
                                            system.adapter.openweathermap.0         : openweathermap        : ioBrokerVM                               - disabled
                                            system.adapter.pi-hole.0                : pi-hole               : ioBrokerVM                               - disabled
                                            system.adapter.pushover.0               : pushover              : ioBrokerVM                               - disabled
                                            system.adapter.pvforecast.0             : pvforecast            : ioBrokerVM                               - disabled
                                            system.adapter.radar2.0                 : radar2                : ioBrokerVM                               - disabled
                                            system.adapter.shelly.0                 : shelly                : ioBrokerVM                               - disabled, port: 1882, bind: 0.0.0.0
                                            system.adapter.shelly.1                 : shelly                : ioBrokerVM                               - disabled, port: 1882, bind: 0.0.0.0
                                            system.adapter.smartcontrol.0           : smartcontrol          : ioBrokerVM                               - disabled
                                            system.adapter.socketio.0               : socketio              : ioBrokerVM                               - disabled, port: 8084, bind: 0.0.0.0, run as: admin
                                            system.adapter.sonoff.0                 : sonoff                : ioBrokerVM                               - disabled, port: 1883, bind: 0.0.0.0
                                            system.adapter.tado.0                   : tado                  : ioBrokerVM                               - disabled
                                            system.adapter.telegram.0               : telegram              : ioBrokerVM                               - disabled, port: 8443, bind: 0.0.0.0
                                            system.adapter.tibberlink.0             : tibberlink            : ioBrokerVM                               - disabled
                                            system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBrokerVM                               - disabled
                                            system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBrokerVM                               - disabled
                                            system.adapter.vis-material-advanced.0  : vis-material-advanced : ioBrokerVM                               - disabled
                                            system.adapter.vis-metro.0              : vis-metro             : ioBrokerVM                               - disabled
                                            system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBrokerVM                               - disabled
                                            system.adapter.vis.0                    : vis                   : ioBrokerVM                               - disabled
                                            system.adapter.weatherunderground.0     : weatherunderground    : ioBrokerVM                               - disabled
                                            system.adapter.web.0                    : web                   : ioBrokerVM                               - disabled, port: 8082, bind: 0.0.0.0, run as: admin
                                            system.adapter.worx.0                   : worx                  : ioBrokerVM                               - disabled
                                          + instance is alive
