  4. Autostart Problem
Autostart Problem
47 Beiträge 14 Kommentatoren 21.9k Aufrufe
  • R Offline
    Revolution1993
    @BuZZy Wenn ich systemctl status iobroker.service eingebe bekomme ich folgende Ausgabe:
    root@raspberrypi:/home/pi# systemctl status iobroker.service
    ● iobroker.service - LSB: starts ioBroker
       Loaded: loaded (/etc/init.d/iobroker.sh)
       Active: failed (Result: exit-code) since Do 2017-11-16 10:37:52 CET; 1h 50min       ago
      Process: 773 ExecStart=/etc/init.d/iobroker.sh start (code=exited, status=1/FA      ILURE)
    Nov 16 10:37:52 raspberrypi systemd[1]: Starting LSB: starts ioBroker...
    Nov 16 10:37:52 raspberrypi iobroker.sh[773]: Starting ioBrokersudo: Uh, Sie…den
    Nov 16 10:37:52 raspberrypi systemd[1]: iobroker.service: control process ex...1
    Nov 16 10:37:52 raspberrypi systemd[1]: Failed to start LSB: starts ioBroker.
    Nov 16 10:37:52 raspberrypi systemd[1]: Unit iobroker.service entered failed....
    Hint: Some lines were ellipsized, use -l to show in full.
    @knopers1
    Die Datei /etc/init.d/iobroker.sh sieht bei mir momentan so aus:
    #!/bin/bash
    ### BEGIN INIT INFO
    # Provides:          iobroker.sh
    # Required-Start:    $network $local_fs $remote_fs
    # Required-Stop::    $network $local_fs $remote_fs
    # Default-Start:     2 3 4 5
    # Default-Stop:      0 1 6
    # Short-Description: starts ioBroker
    # Description:       starts ioBroker
    ### END INIT INFO
    (( EUID )) && echo .You need to have root privileges.. && exit 1
    PIDF=/opt/iobroker/node_modules/iobroker.js-controller/lib/iobroker.pid
    NODECMD=/usr/bin/node
    IOBROKERCMD=/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
    RETVAL=0
    IOBROKERUSER=root
    start() {
                export IOBROKER_HOME=/opt/iobroker
                echo -n "Starting ioBroker"
                sudo -u ${IOBROKERUSER} $NODECMD $IOBROKERCMD start
                RETVAL=$?
    stop() {
                echo -n "Stopping ioBroker"
                sudo -u ${IOBROKERUSER} $NODECMD $IOBROKERCMD stop
                RETVAL=$?
    case "$1" in
        start)
          start
        stop)
          stop
        restart)
          stop
          start
          echo "Usage: iobroker {start|stop|restart}"
          exit 1
    esac
    exit $RETVAL
    Dominik
      knopers1
      Ändere
      die Zeile
      in
      NODECMD=/usr/local/bin/node
      abspeichern und neustarten… und berichten.
      • R Offline
        Revolution1993
        Habe es zu diesem Pfad umbenannt, abgespeichert und neu gestartet, aber Iobroker startet leider immer noch nicht :(
        • BuZZyB Offline
          BuZZyB Offline
          BuZZy
          Die Ausgabe von systemctl status iobroker.service wurde "beschnitten"..
          Versuch nochmal````
          systemctl status -l iobroker.service
          (das -l hinter "status" ist ein kleines L)
          Dann nochmal die Ausgabe posten.
          Der Eintrag NODECMD=/usr/bin/node ist schon korrekt.. (Auf meinem Raspberry 3 stimmt er zumindest).
          • R Offline
            Revolution1993
            @Buzzy
            Ich erhalte dann folgende Ausgabe
            root@raspberrypi:/home/pi# systemctl status -l iobroker.service
               Active: failed (Result: exit-code) since Do 2017-11-16 13:09:29 CET; 10min ago
              Process: 737 ExecStart=/etc/init.d/iobroker.sh start (code=exited, status=1/FAILURE)
            Nov 16 13:09:29 raspberrypi iobroker.sh[737]: Starting ioBrokersudo: Uh, Sie müssen ein TTY haben, um sudo zu verwenden
            Nov 16 13:09:29 raspberrypi systemd[1]: iobroker.service: control process exited, code=exited status=1
            Nov 16 13:09:29 raspberrypi systemd[1]: Failed to start LSB: starts ioBroker.Nov 16 13:09:29 raspberrypi systemd[1]: Unit iobroker.service entered failed state.
            Dominik
            • BuZZyB Offline
              BuZZyB Offline
              BuZZy
              Da blockiert das System..
              Siehe````
              ... Starting ioBrokersudo: Uh, Sie müssen ein TTY haben, um sudo zu verwenden
              Welches Betriebssystem verwendest du bzw. welche Version?
              Raspbian Jessie?
              Raspbian Stretch?
              nano /etc/sudoers
              Hast du da irgendwo sowas wie
              Defaults requiretty
              (Im "Nano Editor" scrollen mit den Pfeiltasten der Tastatur, beenden des Bearbeitungsmodus mit STRG+X)
              • R Offline
                Revolution1993
                Hi Buzzy,
                Ich bin der Meinung dass auf meinem Raspberry momentan Raspian Jessie installiert ist.
                Hab mir Mal die Datei sudoers angeschaut, da ist tatsächlich etwas mit requiretty.
                GNU nano 2.2.6           Datei: /etc/sudoers
                # This file MUST be edited with the 'visudo' command as root.
                # Please consider adding local content in /etc/sudoers.d/ instead of
                # directly modifying this file.
                # See the man page for details on how to write a sudoers file.
                Defaults        env_reset
                Defaults        mail_badpass
                Defaults        secure_path="/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/b$
                # Host alias specification
                # User alias specification
                # Cmnd alias specification
                # User privilege specification
                root    ALL=(ALL:ALL) ALL
                # Allow members of group sudo to execute any command
                %sudo   ALL=(ALL:ALL) ALL
                # See sudoers(5) for more information on "#include" directives:
                #includedir /etc/sudoers.d
                #Für fhem damit dieses scripte im shell ausführen darf
                Defaults requiretty
                Defaults:%dialout !requiretty
                Defaults:fhem !requiretty
                fhem ALL=(ALL) NOPASSWD: ALL
                Muss ich hier irgendwas anpassen?
                Dominik
                • BuZZyB Offline
                  BuZZyB Offline
                  BuZZy
                  Ja,
                  allerdings musst du jetzt zum Bearbeiten den Befehl````
                  visudo
                  Also:
                  visudo
                  Dann änderst du die vierte Zeile von unten:
                  von````
                  Defaults requiretty
                  ````in````
                  #Defaults requiretty
                  ````- also ein # vorne dran hängen um den Eintrag auszukommentieren. Dann speicherst du mit STRG+X und drückst J bzw. Y auf der Tastatur um das Überschreiben zu bestätigen. (je nachdem ob du deutsche oder englische Sprache auf dem Raspberry eingestellt hast).
                  Dann reboot und dann sollte es laufen.
                  Die Datei sollte nach dem Bearbeiten also so bei dir aussehen:
                  Defaults env_reset
                  • BuZZyB Offline
                    BuZZyB Offline
                    BuZZy
                    Und denk dran - diese Änderung die du vorhin vorgenommen hast rückgängig zu machen..
                    @knopers1:
                    Ändere die Zeile
                    ````..in..````
                    • R Offline
                      Revolution1993
                      Ihr seid die besten. :)
                      Jetzt funktioniert der Autostart :D
                      Ich habe die Änderungen in /etc/init.d wieder Rückgängig gemacht in NODECMD=/usr/bin/node.
                      Das auskommentieren des Befehls````
                      Jetzt startet das Programm wieder bei jedem neustart.
                      Besten Dank!
                      Dominik
                      • L Offline
                        LHBL2003
                        Siehe nächsten Eintrag:
                        • L Offline
                          LHBL2003
                          Hi, ich habe mir den Beitrag nochmal in Ruhe durchgelesen und hatte das selbe Problem.
                          Da man aus FEHM heraus gerne auch Linux System Befehle ausführen möchte, fügt man gerne kn die Datei
                          nano /etc/sudoers
                          Die folgenden Zeilen ein:
                          Defaults requiretty
                          Wobei die Zeile
                          Defaults requiretty
                          Gift für den Autostart vom ioBrocker ist.
                          Somit muss diese auskommentiert oder gelöscht werden:
                          Wobei ich noch nicht die Aufgabe von der Zeile geprüft habe, denn in FHEM kann ich dennoch SSH Befehle ausführen.
                          Dennoch danke für den Beitrag hier.
                            maik150
                            Ich habe einen Pi2 mit Raspbian Stretch und bei mir startet der iobroker auch nicht automatisch.
                            der befehl
                            funktioniert nicht, da kommt folgendes
                            Unit iobroker.service could not be found.
                            habe dann
                            in die
                            /etc/sudoers
                            eingefügt, brachte aber keinen erfolg
                            meine Datei /etc/init.d/iobroker.sh sieht auch etwas anders aus
                            #!/bin/bash
                            ### BEGIN INIT INFO
                            ### END INIT INFO
                            NODECMD=@@node
                            RETVAL=0
                            IOBROKERUSER=@@user
                            start() {
                                        RETVAL=$?
                            stop() {
                                        RETVAL=$?
                            case "$1" in
                                start)
                                  start
                                stop)
                                  stop
                                restart)
                                  stop
                                  start
                                  exit 1
                            esac
                            exit $RETVAL
                            Kann mir da einer weiterhelfen?
                            • BuZZyB Offline
                              BuZZyB Offline
                              BuZZy
                              Wenn dein System noch frisch ist und du noch nichts weiter konfiguriert hast, würde ich die Speicherkarte mit Raspbian Jessie neu beschreiben und dann nochmal iobroker frisch installieren.
                              Image Raspbian Jessie Lite gibt's hier:
                              https://downloads.raspberrypi.org/raspb … e-lite.zip
                                maik150
                                Weil auf Jessie läuft iobroker stabiler als auf Strech?
                                • BuZZyB Offline
                                  BuZZyB Offline
                                  BuZZy
                                  Hat bei mir mit Jessie sofort alles auf Anhieb geklappt und seit Installation nicht ein einziges mal Probleme gehabt. ;)
                                    Die npm dateien sind aber heute geändert worden.
                                    Müsste jetzt auch wieder mit stretch gehen.
                                    Gruß Rainer
                                      maik150
                                      @Homoran:
                                      Gruß Rainer `
                                      und was muss ich dafür tun? :D
                                      • DutchmanD Offline
                                        DutchmanD Offline
                                        Dutchman
                                        Neu drüber installieren
                                        Send from mobile device
                                        Das schöne ios hat Auto Korrektur zum k****
                                        Wer Schreibfehler findet darf sie behalten oder auf eBay verkaufen, mindest Umsatz 10% für die community
                                          maik150
                                          @Dutchman:
                                          Neu drüber installieren `
                                          "sudo iobroker update" reicht da nicht?
