  4. [gelöst] IOB per https nicht erreichbar / Zertifikat def.
iobroker nicht erreichbarssl error when loadingssl-zertifikatgelöst
39 Beiträge 6 Kommentatoren 4.8k Aufrufe 5 Beobachtet
  • S schneidy76
    Connecting to 192.168.0.115 port 22, please wait...
    login as: pi pi@192.168.0.115's password:
    Linux raspberrypi-Master 6.1.21-v8+ #1642 SMP PREEMPT Mon Apr  3 17:24:16 BST 2023 aarch64
    The programs included with the Debian GNU/Linux system are free software;
    the exact distribution terms for each program are described in the
    individual files in /usr/share/doc/*/copyright.
    Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
    permitted by applicable law.
    Last login: Wed Oct 25 16:23:32 2023 from 192.168.0.202
    SSH is enabled and the default password for the 'pi' user has not been changed.
    This is a security risk - please login as the 'pi' user and type 'passwd' to set a new password.
    Wi-Fi is currently blocked by rfkill.
    Use raspi-config to set the country before use.
    pi@raspberrypi-Master:~ $ iob restart admin
    The adapter "admin.0" was started.
    pi@raspberrypi-Master:~ $ iob diag
    The state system.host.raspberrypi-Master.versions.npmNewestNext was not found!
    The state system.host.raspberrypi-Master.versions.nodeCurrent was not found!
    *** ioBroker Diagnosis ***
    Please stretch the window of your terminal programm (puTTY) as wide as possible or switch to full screen
    The following checks may give hints to potential malconfigurations or errors, please post them in our forum:
    https://forum.iobroker.net
    Just copy and paste the Summary Page, including the ``` characters at start and end.
    It helps us to help you!
    Press any key to continue
    ======== Start marking the full check here =========
    Skript v.2023-10-10
    *** BASE SYSTEM ***
     Static hostname: raspberrypi-Master
           Icon name: computer
    Operating System: Raspbian GNU/Linux 12 (bookworm)
              Kernel: Linux 6.1.21-v8+
        Architecture: arm64
    Model    : Raspberry Pi 4 Model B Rev 1.4
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : armhf
    Systemuptime and Load:
     17:03:17 up  4:20,  3 users,  load average: 1.47, 0.78, 0.62
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    No throttling issues detected.
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Wed 2023-10-25 17:03:17 BST
               Universal time: Wed 2023-10-25 16:03:17 UTC
                     RTC time: n/a
                    Time zone: Europe/London (BST, +0100)
    System clock synchronized: yes
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:   false
    Desktop:
    Terminal:   tty
    Boot Target:   multi-user.target
    *** MEMORY ***
                   total        used        free      shared  buff/cache   available
    Mem:            1.9G        1.5G        222M         36K        250M        401M
    Swap:           104M        104M        630K
    Total:          2.0G        1.6G        222M
             1848 M total memory
             1464 M used memory
             1415 M active memory
               31 M inactive memory
              212 M free memory
                4 M buffer memory
              235 M swap cache
               99 M total swap
               99 M used swap
                0 M free swap
    Raspberry only:
    oom events: 0
    lifetime oom required: 0 Mbytes
    total time in oom handler: 0 ms
    max time spent in oom handler: 0 ms
    *** FAILED SERVICES ***
      UNIT LOAD ACTIVE SUB DESCRIPTION
    0 loaded units listed.
    *** FILESYSTEM ***
    Filesystem     Type      Size  Used Avail Use% Mounted on
    /dev/root      ext4      118G   13G  101G  11% /
    devtmpfs       devtmpfs  667M     0  667M   0% /dev
    tmpfs          tmpfs     925M     0  925M   0% /dev/shm
    tmpfs          tmpfs     370M  868K  369M   1% /run
    tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
    /dev/sda1      vfat      255M   51M  205M  20% /boot
    tmpfs          tmpfs     185M     0  185M   0% /run/user/1000
    Messages concerning ext4 filesystem in dmesg:
    [Wed Oct 25 12:42:31 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:37:E1:5C vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=043caf75-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Wed Oct 25 12:42:33 2023] EXT4-fs (sda2): INFO: recovery required on readonly filesystem
    [Wed Oct 25 12:42:33 2023] EXT4-fs (sda2): write access will be enabled during recovery
    [Wed Oct 25 12:42:33 2023] EXT4-fs (sda2): orphan cleanup on readonly fs
    [Wed Oct 25 12:42:33 2023] EXT4-fs (sda2): 11 orphan inodes deleted
    [Wed Oct 25 12:42:33 2023] EXT4-fs (sda2): recovery complete
    [Wed Oct 25 12:42:33 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
    [Wed Oct 25 12:42:33 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
    [Wed Oct 25 12:42:35 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
    Show mounted filesystems \(real ones only\):
    TARGET  SOURCE    FSTYPE OPTIONS
    /       /dev/sda2 ext4   rw,noatime
    `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    Files in neuralgic directories:
    /var:
    1.1G  /var/
    651M  /var/log
    646M  /var/log/journal/55a635084cf04e71bfee02b63eaea0f9
    167M  /var/cache
    Archived and active journals take up 645.4M in the file system.
    /opt/iobroker/backups:
    6.8G  /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    464M  /opt/iobroker/iobroker-data/
    243M  /opt/iobroker/iobroker-data/files
    97M  /opt/iobroker/iobroker-data/backup-objects
    92M  /opt/iobroker/iobroker-data/node-red/node_modules
    The five largest files in iobroker-data are:
    30M  /opt/iobroker/iobroker-data/objects.jsonl
    21M  /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
    19M  /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js.map
    8.9M  /opt/iobroker/iobroker-data/files/scenes.admin/static/js/2.7de3299d.chunk.js.map
    8.3M  /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js
    USB-Devices by-id:
    USB-Sticks -  Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id':
    find: '/dev/serial/by-id/': No such file or directory
    *** NodeJS-Installation ***
    /usr/bin/nodejs   v18.18.2
    /usr/bin/node     v18.18.2
    /usr/bin/npm     9.8.1
    /usr/bin/npx     9.8.1
    /usr/bin/corepack   0.19.0
    nodejs:
      Installed: 18.18.2-1nodesource1
      Candidate: 18.18.2-1nodesource1
      Version table:
     *** 18.18.2-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
            100 /var/lib/dpkg/status
         18.18.1-1nodesource1 1001
         18.18.0-1nodesource1 1001
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0+dfsg1-1+rpi1 500
            500 http://raspbian.raspberrypi.org/raspbian bookworm/main armhf Packages
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
    Temp directories causing npm8 problem: 0
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    iobroker is running on this host.
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:   5.0.12
    admin:     6.10.1
    javascript:   7.1.4
    Adapters from github:   5
    Adapter State
      system.adapter.admin.0                  : admin                 : raspberrypi-Master                       -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
    + system.adapter.alexa2.0                 : alexa2                : raspberrypi-Master                       -  enabled
    + system.adapter.backitup.0               : backitup              : raspberrypi-Master                       -  enabled
    + system.adapter.cloud.0                  : cloud                 : raspberrypi-Master                       -  enabled
      system.adapter.daswetter.0              : daswetter             : raspberrypi-Master                       -  enabled
    + system.adapter.denon.0                  : denon                 : raspberrypi-Master                       -  enabled
    + system.adapter.discovery.0              : discovery             : raspberrypi-Master                       -  enabled
      system.adapter.dwd.0                    : dwd                   : raspberrypi-Master                       -  enabled
    + system.adapter.email.0                  : email                 : raspberrypi-Master                       -  enabled
    + system.adapter.enigma2.0                : enigma2               : raspberrypi-Master                       -  enabled
      system.adapter.feiertage.0              : feiertage             : raspberrypi-Master                       -  enabled
    + system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi-Master                       -  enabled
    + system.adapter.harmony.0                : harmony               : raspberrypi-Master                       -  enabled
    + system.adapter.history.0                : history               : raspberrypi-Master                       -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : raspberrypi-Master                       -  enabled
    + system.adapter.hm-rpc.3                 : hm-rpc                : raspberrypi-Master                       -  enabled, port: 0
    + system.adapter.hm-rpc.4                 : hm-rpc                : raspberrypi-Master                       -  enabled, port: 0
    + system.adapter.hm-rpc.5                 : hm-rpc                : raspberrypi-Master                       -  enabled, port: 0
    + system.adapter.hue.0                    : hue                   : raspberrypi-Master                       -  enabled, port: 80
      system.adapter.ical.0                   : ical                  : raspberrypi-Master                       -  enabled
    + system.adapter.iot.0                    : iot                   : raspberrypi-Master                       -  enabled
    + system.adapter.javascript.0             : javascript            : raspberrypi-Master                       -  enabled
    + system.adapter.javascript.2             : javascript            : raspberrypi                              -  enabled
    + system.adapter.knx.0                    : knx                   : raspberrypi-Master                       -  enabled, bind: 192.168.0.115
      system.adapter.labcom.0                 : labcom                : raspberrypi-Master                       -  enabled
    + system.adapter.mihome-vacuum.0          : mihome-vacuum         : raspberrypi-Master                       -  enabled, port: 54321
    + system.adapter.node-red.0               : node-red              : raspberrypi-Master                       -  enabled, port: 1880, bind: 0.0.0.0
      system.adapter.openweathermap.0         : openweathermap        : raspberrypi-Master                       -  enabled
    + system.adapter.parcel.0                 : parcel                : raspberrypi-Master                       -  enabled
    + system.adapter.sayit.0                  : sayit                 : raspberrypi-Master                       -  enabled
    + system.adapter.scenes.0                 : scenes                : raspberrypi-Master                       -  enabled
    + system.adapter.simple-api.0             : simple-api            : raspberrypi-Master                       -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.smartmeter.0             : smartmeter            : raspberrypi                              -  enabled
    + system.adapter.smartmeter.1             : smartmeter            : raspberrypi                              -  enabled
    + system.adapter.socketio.0               : socketio              : raspberrypi-Master                       -  enabled, port: 8084, bind: 192.168.0.115, run as: admin
    + system.adapter.solarlog.0               : solarlog              : raspberrypi-Master                       -  enabled, port: 80
      system.adapter.sonoff.0                 : sonoff                : raspberrypi                              - disabled, port: 1883, bind: 0.0.0.0
      system.adapter.sql.0                    : sql                   : raspberrypi-Master                       - disabled, port: 3306
    + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi-Master                       -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : raspberrypi-Master                       -  enabled
    + system.adapter.tuya.0                   : tuya                  : raspberrypi-Master                       -  enabled
      system.adapter.vis-metro.0              : vis-metro             : raspberrypi-Master                       -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi-Master                       -  enabled
      system.adapter.vis-weather.0            : vis-weather           : raspberrypi-Master                       -  enabled
      system.adapter.vis.0                    : vis                   : raspberrypi-Master                       -  enabled
      system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi-Master                       -  enabled
    + system.adapter.web.0                    : web                   : raspberrypi-Master                       -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      system.adapter.wifilight.0              : wifilight             : raspberrypi-Master                       - disabled
    + instance is alive
    Enabled adapters with bindings
    ioBroker-Repositories
    sources       : conf/sources-dist.json
    online        : https://raw.githubusercontent.com/ioBroker/ioBroker.repositories/master/sources-dist.json
    stable        : http://download.iobroker.net/sources-dist.json
    beta          : http://download.iobroker.net/sources-dist-latest.json
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.10.1   , installed 6.10.1
    Adapter    "alexa2"       : 3.25.2   , installed 3.25.2
    Adapter    "backitup"     : 2.8.1    , installed 2.8.1
    Adapter    "cec2"         : 0.1.1    , installed 0.1.1
    Adapter    "cloud"        : 4.4.1    , installed 4.4.1
    Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
    Adapter    "denon"        : 1.15.4   , installed 1.15.4
    Adapter    "discovery"    : 3.1.0    , installed 3.1.0
    Adapter    "dwd"          : 2.8.5    , installed 2.8.5
    Adapter    "email"        : 1.2.0    , installed 1.2.0
    Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
    Adapter    "flot"         : 1.12.0   , installed 1.12.0
    Adapter    "fritzbox"     : 0.5.0    , installed 0.5.0
    Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
    Adapter    "harmony"      : 1.2.2    , installed 1.2.2
    Adapter    "history"      : 3.0.1    , installed 2.2.6  [Updatable]
    Adapter    "hm-rega"      : 3.0.47   , installed 3.0.47
    Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
    Adapter    "hue"          : 3.10.1   , installed 3.10.0 [Updatable]
    Adapter    "ical"         : 1.13.3   , installed 1.13.3
    Adapter    "icons-addictive-flavour-png": 0.1.0, installed 0.1.0
    Adapter    "icons-material-png": 0.1.0, installed 0.1.0
    Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
    Adapter    "icons-mfd-svg": 1.1.0    , installed 1.1.0
    Adapter    "icons-ultimate-png": 1.0.1, installed 1.0.1
    Adapter    "iot"          : 1.14.5   , installed 1.14.5
    Adapter    "javascript"   : 7.1.4    , installed 7.1.4
    Controller "js-controller": 5.0.12   , installed 5.0.12
    Adapter    "knx"          : 2.0.22   , installed 2.0.22
    Adapter    "mihome-vacuum": 4.0.0    , installed 4.0.0
    Adapter    "mobile"       : 1.0.1    , installed 1.0.1
    Adapter    "node-red"     : 4.0.3    , installed 4.0.3
    Adapter    "openweathermap": 0.3.9   , installed 0.3.9
    Adapter    "parcel"       : 0.0.27   , installed 0.0.27
    Adapter    "ph803w"       : 1.1.1    , installed 1.1.1
    Adapter    "sayit"        : 3.0.5    , installed 3.0.5
    Adapter    "scenes"       : 2.3.9    , installed 2.3.9
    Adapter    "simple-api"   : 2.7.2    , installed 2.7.2
    Adapter    "socketio"     : 6.5.5    , installed 6.5.5
    Adapter    "solarlog"     : 2.2.8    , installed 2.2.6  [Updatable]
    Adapter    "sonos"        : 2.3.1    , installed 2.3.1
    Adapter    "spotify-premium": 1.2.2  , installed 1.2.2
    Adapter    "sql"          : 2.2.0    , installed 2.2.0
    Adapter    "tankerkoenig" : 3.3.7    , installed 3.3.7
    Adapter    "trashschedule": 2.2.0    , installed 2.2.0
    Adapter    "tuya"         : 3.14.2   , installed 3.14.2
    Adapter    "vis"          : 1.4.16   , installed 1.4.16
    Adapter    "vis-bars"     : 0.1.4    , installed 0.1.4
    Adapter    "vis-canvas-gauges": 1.0.1, installed 1.0.1
    Adapter    "vis-colorpicker": 2.0.3  , installed 2.0.3
    Adapter    "vis-fancyswitch": 1.1.0  , installed 1.1.0
    Adapter    "vis-hqwidgets": 1.4.0    , installed 1.4.0
    Adapter    "vis-jqui-mfd" : 1.0.12   , installed 1.0.12
    Adapter    "vis-justgage" : 1.0.2    , installed 1.0.2
    Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
    Adapter    "vis-material-advanced": 1.7.4, installed 1.7.4
    Adapter    "vis-metro"    : 1.2.0    , installed 1.2.0
    Adapter    "vis-timeandweather": 1.2.2, installed 1.2.2
    Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
    Adapter    "weatherunderground": 3.6.0, installed 3.6.0
    Adapter    "web"          : 6.1.2    , installed 6.1.2
    Adapter    "wifilight"    : 1.1.4    , installed 1.1.4
    Adapter    "ws"           : 2.5.5    , installed 2.5.5
    Objects and States
    Please stand by - This may take a while
    Objects:   14467
    States:   10597
    *** OS-Repositories and Updates ***
    W: http://raspbian.raspberrypi.org/raspbian/dists/bookworm/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
    Hit:1 http://raspbian.raspberrypi.org/raspbian bookworm InRelease
    Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    Active Internet connections (only servers)
    Proto Recv-Q Send-Q Local Address           Foreign Address         State       User       Inode      PID/Program name
    tcp        0      0 192.168.0.115:8701      0.0.0.0:*               LISTEN      1001       62182      7806/io.hm-rpc.5
    tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1001       63203      7739/node-red
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          11243      552/sshd: /usr/sbin
    tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       63194      7739/node-red
    tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       63916      7595/iobroker.js-co
    tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       61183      7595/iobroker.js-co
    tcp        0      0 192.168.0.115:2001      0.0.0.0:*               LISTEN      1001       61392      7776/io.hm-rpc.3
    tcp        0      0 192.168.0.115:2010      0.0.0.0:*               LISTEN      1001       63168      7791/io.hm-rpc.4
    tcp        0      0 192.168.0.115:8084      0.0.0.0:*               LISTEN      1001       65716      8101/io.socketio.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          11245      552/sshd: /usr/sbin
    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       65757      8135/io.simple-api.
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       66688      8086/io.web.0
    tcp6       0      0 :::61991                :::*                    LISTEN      1001       65580      8011/io.harmony.0
    udp        0      0 192.168.0.115:40058     0.0.0.0:*                           1001       80043      8161/io.knx.0
    udp        0      0 192.168.0.115:52383     0.0.0.0:*                           1001       81433      8161/io.knx.0
    udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       62372      7913/io.mihome-vacu
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        11059      392/avahi-daemon: r
    udp        0      0 192.168.0.115:57675     0.0.0.0:*                           1001       63229      7739/node-red
    udp        0      0 192.168.0.115:46558     0.0.0.0:*                           1001       66752      8161/io.knx.0
    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       64680      7898/io.tuya.0
    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       64681      7898/io.tuya.0
    udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       65581      8011/io.harmony.0
    udp        0      0 192.168.0.115:35494     0.0.0.0:*                           1001       80850      8161/io.knx.0
    udp        0      0 192.168.0.115:43869     0.0.0.0:*                           1001       78660      8161/io.knx.0
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       63202      7739/node-red
    udp        0      0 0.0.0.0:54151           0.0.0.0:*                           108        11061      392/avahi-daemon: r
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15451      800/dhcpcd
    udp6       0      0 :::52333                :::*                                108        11062      392/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                108        11060      392/avahi-daemon: r
    udp6       0      0 :::546                  :::*                                0          13152      800/dhcpcd
    *** Log File - Last 25 Lines ***
    2023-10-25 17:00:15.764  - info: daswetter.0 (9535) cleaned everything up...
    2023-10-25 17:00:15.780  - info: host.raspberrypi-Master instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-10-25 17:00:18.622  - info: ical.0 (9565) Terminated (NO_ERROR): Without reason
    2023-10-25 17:00:19.153  - info: host.raspberrypi-Master instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
    2023-10-25 17:01:00.068  - info: host.raspberrypi-Master instance system.adapter.dwd.0 started with pid 9582
    2023-10-25 17:01:03.129  - info: dwd.0 (9582) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.18.2, js-controller: 5.0.12
    2023-10-25 17:01:04.128  - info: dwd.0 (9582) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-10-25 17:01:04.666  - info: host.raspberrypi-Master instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-10-25 17:02:00.090  - info: host.raspberrypi-Master instance system.adapter.openweathermap.0 started with pid 9597
    2023-10-25 17:02:03.010  - info: openweathermap.0 (9597) starting. Version 0.3.9 in /opt/iobroker/node_modules/iobroker.openweathermap, node: v18.18.2, js-controller: 5.0.12
    2023-10-25 17:02:20.699  - info: openweathermap.0 (9597) Terminated (NO_ERROR): Without reason
    2023-10-25 17:02:21.232  - info: host.raspberrypi-Master instance system.adapter.openweathermap.0 terminated with code 0 (NO_ERROR)
    2023-10-25 17:02:52.970  - info: host.raspberrypi-Master instance system.adapter.admin.0 started with pid 9666
    2023-10-25 17:02:57.004  - info: admin.0 (9666) starting. Version 6.10.1 in /opt/iobroker/node_modules/iobroker.admin, node: v18.18.2, js-controller: 5.0.12
    2023-10-25 17:02:57.066  - info: admin.0 (9666) requesting all objects
    2023-10-25 17:03:00.301  - info: admin.0 (9666) received all objects
    2023-10-25 17:03:01.130  - info: admin.0 (9666) Request actual repository...
    2023-10-25 17:03:01.178  - error: admin.0 (9666) Cannot create web-server: Error: error:05800074:x509 certificate routines::key values mismatch
    2023-10-25 17:03:01.182  - info: admin.0 (9666) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-10-25 17:03:01.551  - error: admin.0 (9666) Cannot update news: TypeError: newNews.forEach is not a function
    2023-10-25 17:03:01.772  - warn: admin.0 (9666) Cannot check node.js/npm version
    2023-10-25 17:03:02.162  - info: admin.0 (9666) terminating https server on port 8081
    2023-10-25 17:03:02.565  - info: host.raspberrypi-Master Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
    2023-10-25 17:03:02.938  - info: host.raspberrypi-Master instance system.adapter.admin.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
    2023-10-25 17:03:02.939  - info: host.raspberrypi-Master Do not restart adapter system.adapter.admin.0 because desired by instance
    ============ Mark until here for C&P =============
    iob diag has finished.
    Press any key for a summary
    Copy text starting here:
    ======================= SUMMARY =======================
          v.2023-10-10
           Icon name: computer
        Architecture: arm64
    Installation:     native
    Kernel:     aarch64
    Userland:     armhf
    Timezone:     Europe/London (BST, +0100)
    User-ID:     1000
    X-Server:     false
    Pending OS-Updates:   0
    Pending iob updates:   3
    Nodejs-Installation:   /usr/bin/nodejs   v18.18.2
          /usr/bin/npm     9.8.1
          /usr/bin/npx     9.8.1
    Recommended versions are nodejs  and npm
    Your nodejs installation is correct
    MEMORY:
    Mem:            1.9G        1.5G        112M         36K        348M        389M
    Swap:           104M        104M        245K
    Total:          2.0G        1.7G        112M
    Active iob-Instances:   34
    ioBroker Core:     js-controller     5.0.12
          admin       6.10.1
    ioBroker Status:   iobroker is running on this host.
    Objects type: jsonl
    States  type: jsonl
    Status admin and web instance:
    Objects:     14467
    States:     10597
    Size of iob-Database:
    4.0M  /opt/iobroker/iobroker-data/states.jsonl
    =================== END OF SUMMARY ====================
    === Mark text until here for copying ===
    schneidy76
    @schneidy76
    bin den Weg über eine zusätzliche Admin Instance gegangen. Ohne SSL geht es. Sobald ich das aktiviere, bekomme ich den Adapter nicht mehr grün.
    Raspberry Matic (RP3), LIVE PV Monitoring mit Smartmeter, Poolsteuerung mit NodeRed, KNX Ausbau (ersetzt stückweise HM & klassische Installation), ioBroker Multihost (RP4 &RP2), Visu mit VIS
    • S schneidy76
      @schneidy76
      bahnuhrB Online
      bahnuhrB Online
      bahnuhr
      @schneidy76 sagte in Admin Webseite nicht mehr erreichbar:
      SSL
      was haste denn vor mit dem ssl ?
      Danke.
      • bahnuhrB bahnuhr
        SSL
        CodierknechtC Offline
        Codierknecht
        @bahnuhr sagte in Admin Webseite nicht mehr erreichbar:
        SSL
        @schneidy76
        Eben.
        Was willst Du mit SSL im Heimnetz?
        HmIP|ZigBee|Tasmota|Unifi
        Zabbix Certified Specialist
          schneidy76
          Ich nutze unter anderen den KNX Adapter (habe eine immer steigende Anzahl an KNX Teilnehmer bei uns im Haus). Unter anderen auch KNX-RF Geräte. Eine KNX-RF Linie benötigt eine Domain, ab da muss ich das KNX Projekt verschlüsseln.
          Um das Projekt, und damit die Gruppenadressen, korrekt einzulesen, benötige ich ebenfalls eine SSL Verschlüsselung von ioBroker.
          Warum, keine Ahnung, aber es ist eben so.... 😏
          Das Ganze lief ja auch 2 Jahre ohne Probleme.
          VG Torsten
          • S schneidy76
            VG Torsten
            bahnuhrB Online
            bahnuhrB Online
            bahnuhr
            Na, wenns so is, dann isses so.
            Ich bin damit aber raus.
            Danke.
            CodierknechtC S 2 Antworten Letzte Antwort
            • bahnuhrB bahnuhr
              Codierknecht
              Ich auch.
              Security sucks! :-(
              • bahnuhrB bahnuhr
                schneidy76
                @bahnuhr Trotzdem Danke
                • CodierknechtC Codierknecht
                  Ich auch.
                  Security sucks! :-(
                  schneidy76
                  @codierknecht ich habe den Betreff mal aktualisiert, vielleicht kann ja jemand helfen
                  • Marc BergM Online
                    Marc BergM Online
                    Marc Berg
                    @schneidy76 sagte in Admin Webseite nicht mehr erreichbar / SSL Keys defekt?:
                    Wenn du jetzt eine weitere Admin-Instanz am Start hast, kannst du doch jetzt mal das Debug Log der Instanz "0" aktivieren, diese Instanz neu starten und das Log (nicht "iob diag"!) hier posten. Eine entsprechende Frage von @Thomas-Braun hattest du noch nicht beantwortet.
                    • Marc BergM Marc Berg
                      schneidy76
                      @marc-berg said in Admin Webseite nicht mehr erreichbar / SSL Keys defekt?:
                      Hallo Marc,
                      stelle ich den Log auf Debug um und starte die Admin.0 Instance mit SSL Authentifizierung, bekomme ich trotz den nicht startenden Adapter keine Meldung ins Log.
                      Also zurück auf INFO?
                      • S schneidy76
                        Hallo Marc,
                        Marc BergM Online
                        Marc BergM Online
                        Marc Berg
                        Gegenprobe: bekommst du bei der Instanz.1 Meldungen im Log, wenn du auf "debug" schaltest?
                          schneidy76
                          schrieb am zuletzt editiert von schneidy76
                          @marc-berg
                          Gegenprobe 1: Admin.0 steht auf "Alles" und nichts kommt an
                          Gegenprobe 2: Admin.1 steht auf "Debug" Meldungen mit Level Debug kommen
                          1. Habe ein Update (Edit: auf Admin 6.12.0) angeboten bekommen und dieses ausgeführt. Augenscheinlich durchgelaufen, aber Fehler:
                          SyntaxError: Unexpected token '<', "<!doctype "... is not valid JSON
                          im Dialogfenster.
                          Vg Torsten
                          • S schneidy76
                            @marc-berg
                            im Dialogfenster.
                            Vg Torsten
                            schneidy76
                            Zwischenstand:
                            bin nun auf einen RP4 mit 8GB RAM umgestiegen.
                            Es gab einige Probleme beim Zurückspielen des Backups, die ich aber lösen konnte.
                            Jetzt läuft der ioBroker wieder stabil mit genügend Reserven.
                            Ich habe derzeit (zum Testen) 2 Admin Instanzen laufen:
                            Admin.0 mit https und Authentifizierung Port 8081
                            Admin.1 ohne SSL Port 8089
                            Instanz Admin.0 konnte ich starten, nachdem ich den Befehl:
                            iob cert create
                            gefunden habe.
                            Ich kann aber noch nicht per https zugreifen. Die Browser melden zurück:
                            192.x.x.x erfüllt die Sicherheitsstandards nicht.
                            ERR_SSL_SERVER_CERT_BAD_FORMAT
                            Hat jemand ne Idee?
                            Danke und VG Torsten
                            • S schneidy76
                              Zwischenstand:
                              iob cert create
                              gefunden habe.
                              Hat jemand ne Idee?
                              Marc BergM Online
                              Marc BergM Online
                              Marc Berg
                              @schneidy76 sagte in Admin per https nicht erreichbar / Zertifikatprobleme:
                              Ich weiß ja nicht, welchen Browser du nutzt, normalerweise muss man ja das Verwenden von selbstsignierten Zertifikaten am Browser explizit bestätigen.
                              Ein weiterer Klassiker bei solchen Fehlern ist ein falsch eingestellte Zeitzone und/oder Zeit. Prüf das mal.
                                schneidy76
                                @marc-berg
                                Hi Marc, den Firefox konnte ich überreden, die Website per https anzuzeigen.
                                Ich musste dazu den erweiterten Schutz deaktivieren und explizit bestätigen, dass ich mir dem Risiko bewusst bin.
                                Google Chrom konnte ich noch nicht dazu bewegen - Safe Browsing habe ich dort nun ebenfalls deaktiviert. Trotzdem zeigt der mir die Seite nicht an...
                                Ich teste weiter... 💪
                                • S schneidy76
                                  @marc-berg
                                  schneidy76
                                  Lösung:
                                  So nun habe ich es endlich hinbekommen. Der Ausflug zu letsencrypt ging schief, nach einigen schlaflosen durchdachten Nächten, habe ich eine Lösung gefunden:
                                  • Backup der bestehenden Installation erstellen und per WinSCP (o.ä.) auf dem PC sichern
                                  • iob stop
                                  • ioBroker Installation per sudo rm -r /opt/iobroker plattmachen
                                  • ioBroker nach der Anleitung: Klick mich neu installieren
                                  • Im Assistenten "Authentifizierung erforderlich" auswählen und Admin Password vergeben
                                  • Nach dem Abschluss die ioBroker Einstellungen öffnen und zum Reiter Zertifikate gehen
                                  • Beide Zertifikate einzeln komplett markieren und als "Nur Text" in einer separaten WordPad Datei speichern.
                                  • Backup mit WinSCP (o.ä.) zurückspielen und per iob restore 0 wiederherstellen
                                  • iob rebuild durchlaufen lassen und anschließend den ioBroker gestartet
                                  • wieder in die Einstellungen des ioBroker gehen und in dem Reiter Zertifikate die bestehenden Zertifikate mit X löschen
                                  • die vorher gesicherten Zertifikate aus den Dateien ersetzen
                                  • Sichern und Schließen --> anschließend Instance "Admin" neu starten
                                  • FERTIG
                                  • S schneidy76
                                    Lösung:
                                    • iob stop
                                    • FERTIG
                                    Rechte des Verzeichnisses /opt auf 777 setzen
                                    per sudo rm -r /opt plattmachen
                                    Warum das? Hört sich komplett unnötig, gefährlich und planlos an.
                                      schneidy76
                                      leider alternativlos denn ich brauche dringend den Zugang über https für mein KNX Projekt:
                                      Issues 251 GitHub
                                      • S schneidy76
                                        Issues 251 GitHub
                                        @schneidy76
                                        Ich meine das grobschlächtige löschen von /opt.
                                        Und warum setzt man das auf 'frei blasen für alle und jeden', wenn man das dann im nächsten Schritt ohnehin als root wegsenst?
                                          @schneidy76
                                          schneidy76
                                          @thomas-braun jaa, vielleicht wäre das eleganter gegangen, aber Hauptsache alles ist erstmal wech und clean...
                                          Bei der Installation werden die Rechte ohnehin wieder richtig vergeben - und zur Not gibt es ja noch den Fixer......😁
