  4. BackItUp kein WOL an Buffalo NAS LinkStation
40 Beiträge 5 Kommentatoren 4.4k Aufrufe 4 Beobachtet
  • T ToK
    @glasfaser
    Bitte von unten nach oben lesen:
    backitup.0
    2023-10-09 19:19:00.381	error	[iobroker] Error: Command failed: sudo mount -t cifs -o username=Datensicherung,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.115.200/Datensicherung/Raspberry /opt/iobroker/backupsmount error(113): could not connect to 192.168.115.200Unable to find suitable address.
    backitup.0
    2023-10-09 19:19:00.381	error	[iobroker/mount] mount error(113): could not connect to 192.168.115.200Unable to find suitable address.
    backitup.0
    2023-10-09 19:19:00.380	error	[iobroker/mount] Error: Command failed: sudo mount -t cifs -o username=Datensicherung,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.115.200/Datensicherung/Raspberry /opt/iobroker/backups
    backitup.0
    2023-10-09 19:19:00.380	error	[iobroker/mount] mount error(113): could not connect to 192.168.115.200Unable to find suitable address.
    backitup.0
    2023-10-09 19:19:00.379	error	[iobroker/mount] [undefined Error: Command failed: sudo mount -t cifs -o username=Datensicherung,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.115.200/Datensicherung/Raspberry /opt/iobroker/backups
    backitup.0
    2023-10-09 19:18:54.244	debug	[iobroker/mount] cifs-mount command: "sudo mount -t cifs -o username=Datensicherung,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.115.200/Datensicherung/Raspberry /opt/iobroker/backups"
    backitup.0
    2023-10-09 19:18:54.242	debug	[iobroker/mount] first mount attempt with smb option failed. try next mount attempt without smb option ...
    backitup.0
    2023-10-09 19:18:48.054	debug	[iobroker/mount] cifs-mount command: "sudo mount -t cifs -o username=Datensicherung,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=1.0 //192.168.115.200/Datensicherung/Raspberry /opt/iobroker/backups"
    backitup.0
    2023-10-09 19:18:48.054	debug	[iobroker/mount] noserverino option: false
    backitup.0
    2023-10-09 19:16:48.053	debug	Backup has started ...
    backitup.0
    2023-10-09 19:16:48.052	debug	[iobroker/mount] Wake on LAN wait 120 Seconds for NAS!
    @tok sagte in BackItUp kein WOL an Buffalo NAS LinkStation:
    Schau in das 'richtige' Log:
    iob logs --watch
    Und poste den Text in CodeTags eingebettet.
    • T ToK
      @glasfaser
      backitup.0
      backitup.0
      backitup.0
      backitup.0
      backitup.0
      backitup.0
      backitup.0
      backitup.0
      backitup.0
      backitup.0
      backitup.0
      GlasfaserG Offline
      GlasfaserG Offline
      @tok
      was davor ist , ist Interessant
      und jetzt Logstufe Silly
      • T ToK
        @glasfaser
        backitup.0
        backitup.0
        backitup.0
        backitup.0
        backitup.0
        backitup.0
        backitup.0
        backitup.0
        backitup.0
        backitup.0
        backitup.0
        GlasfaserG Offline
        GlasfaserG Offline
        Kannst du von ioBroker aus die IP anpingen !?
        bzw.
        was du nicht geschrieben hast , funktioniert das normale Backup , also NAS dauer an und dann ein Backup ohne die Option WOL
        • GlasfaserG Glasfaser
          @tok
          ToK
          schrieb am zuletzt editiert von ToK
          @glasfaser
          2023-10-09 19:14:52.022  - info: admin.0 (1017) <== Disconnect system.user.admin from ::ffff:192.168.115.1
          2023-10-09 19:16:42.124  - info: admin.0 (1017) ==> Connected system.user.admin from ::ffff:192.168.115.1
          2023-10-09 19:16:42.206  - debug: backitup.0 (94212) The local storage check was completed successfully. On the host "raspberrypi" are currently 236370 MB free space available!
          2023-10-09 19:16:48.044  - debug: backitup.0 (94212) The local storage check was completed successfully. On the host "raspberrypi" are currently 236370 MB free space available!
          2023-10-09 19:16:48.052  - debug: backitup.0 (94212) [iobroker/mount] Wake on LAN wait 120 Seconds for NAS!
          2023-10-09 19:16:48.053  - debug: backitup.0 (94212) Backup has started ...
          2023-10-09 19:18:48.054  - debug: backitup.0 (94212) [iobroker/mount] noserverino option: false
          2023-10-09 19:18:48.054  - debug: backitup.0 (94212) [iobroker/mount] cifs-mount command: "sudo mount -t cifs -o username=Datensicherung,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=1.0 //192.168.115.200/Datensicherung/Raspberry /opt/iobroker/backups"
          2023-10-09 19:18:54.242  - debug: backitup.0 (94212) [iobroker/mount] first mount attempt with smb option failed. try next mount attempt without smb option ...
          2023-10-09 19:18:54.244  - debug: backitup.0 (94212) [iobroker/mount] cifs-mount command: "sudo mount -t cifs -o username=Datensicherung,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.115.200/Datensicherung/Raspberry /opt/iobroker/backups"
          2023-10-09 19:19:00.379  - error: backitup.0 (94212) [iobroker/mount] [undefined Error: Command failed: sudo mount -t cifs -o username=Datensicherung,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.115.200/Datensicherung/Raspberry /opt/iobroker/backups
          2023-10-09 19:19:00.380  - error: backitup.0 (94212) [iobroker/mount] mount error(113): could not connect to 192.168.115.200Unable to find suitable address.
          2023-10-09 19:19:00.380  - error: backitup.0 (94212) [iobroker/mount] Error: Command failed: sudo mount -t cifs -o username=Datensicherung,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.115.200/Datensicherung/Raspberry /opt/iobroker/backups
          2023-10-09 19:19:00.381  - error: backitup.0 (94212) [iobroker/mount] mount error(113): could not connect to 192.168.115.200Unable to find suitable address.
          2023-10-09 19:19:00.381  - error: backitup.0 (94212) [iobroker] Error: Command failed: sudo mount -t cifs -o username=Datensicherung,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.115.200/Datensicherung/Raspberry /opt/iobroker/backups
          2023-10-09 19:19:18.000  - info: admin.0 (1017) <== Disconnect system.user.admin from ::ffff:192.168.115.1
          die MAC Adresse sehe ich hier nicht
            bzw.
            ToK
            @glasfaser
            wenn die NAS "schläft" kann ich sie nicht anpingen - wenn sie über "sudo /usr/sbin/etherwake -i eth0 <Mac Adresse>" läuft schon.
            Das normale Backup funktioniert ohne WOL (bei laufender NAS) einwandfrei.
            • T ToK
              @glasfaser
              wieso auch?
              ich frage mich sowieso schon die ganze Zeit warum du dauernd die MAC Adresse ins Spiel bringst.
                wieso auch?
                @homoran sagte in BackItUp kein WOL an Buffalo NAS LinkStation:
                Weil das 'magic packet' an die MAC-Adresse gesendet wird, weil der Host ja schläft.
                T HomoranH 2 Antworten Letzte Antwort
                  ToK
                  ja genau ....
                    @thomas-braun sagte in BackItUp kein WOL an Buffalo NAS LinkStation:
                    macht das nicht der Router?
                      ToK
                      @homoran said in BackItUp kein WOL an Buffalo NAS LinkStation:
                      Als Router wird eine FritzBox 7590 verwendet
                      Thomas BraunT GlasfaserG 2 Antworten Letzte Antwort
                      • T ToK
                        Keine Ahnung ob das noch relevant ist:
                        https://www.ip-phone-forum.de/threads/fritzbox-7490-wake-on-lan-über-udp-port-9-klappt-nicht-mehr.284397/
                        • T ToK
                          GlasfaserG Offline
                          GlasfaserG Offline
                          @tok
                          Kannst du das mal testen
                          sudo -H -u iobroker /usr/sbin/etherwake -i eth0 <Mac Adresse>
                          @Thomas-Braun
                          Welche Rechte braucht dann
                          Thomas BraunT T 2 Antworten Letzte Antwort
                            @tok
                            @Thomas-Braun
                            @glasfaser sagte in BackItUp kein WOL an Buffalo NAS LinkStation:
                            @Thomas-Braun
                            Keine Ahnung, denn:
                            echad@chet:/opt/iobroker $ type -p etherwake
                              @tok
                              @Thomas-Braun
                              ToK
                              @glasfaser said in BackItUp kein WOL an Buffalo NAS LinkStation:
                              @tok
                              @Thomas-Braun
                                @Thomas-Braun
                                Keine Ahnung, denn:
                                GlasfaserG Offline
                                GlasfaserG Offline
                                etherwake
                                Das ist mit diesem NPM Paket !?
                                https://github.com/simatec/ioBroker.backitup/issues/978
                                  etherwake
                                  @glasfaser
                                  Wollte ich gerade schreiben. Das läuft nicht über das binairy, sondern über das node-Modul 'node-wol'. Und das ist schon Jahre nicht mehr angepackt worden.
                                    etherwake
                                    ToK
                                    etherwake
                                    verwende seit soeben die Version 2.8.2 - die Konfig im BackItUp sind ident wie zuvor - ob das NPM Paket aktiv ist (sollte seit 2.8.0 so sein) kann ich nicht beurteilen - es funktioniert leider noch immer nicht.
                                      kann da auch der arp-cache in die Suppe spucken?
                                        Nein, der ist IP-basiert.
                                        • T ToK
                                          etherwake
                                          GlasfaserG Offline
                                          GlasfaserG Offline
                                          @tok
                                          Zeige mal
                                          npm ls grep node-wol
                                          Bei mir
                                          iobroker.inst@3.0.0 /opt/iobroker
                                          └─┬ iobroker.backitup@2.8.2
                                            └── node-wol@0.1.1
