  4. BackItUp kein WOL an Buffalo NAS LinkStation
40 Beiträge 5 Kommentatoren 4.4k Aufrufe 4 Beobachtet
  • T ToK
    @glasfaser
    Hoffe es ist so besser lesbar ->
    2023-10-09 17:39:27.324 - error: backitup.0 (88902) Error: Command failed: sudo mount -t cifs -o username=XXXX,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.115.200/Datensicherung/Raspberry /opt/iobroker/backups
    mount error(113): could not connect to 192.168.115.200Unable to find suitable address.
    2023-10-09 17:41:32.893 - error: backitup.0 (88902) [iobroker/mount] [undefined Error: Command failed: sudo mount -t cifs -o username=XXXX,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.115.200/Datensicherung/Raspberry /opt/iobroker/backups
    2023-10-09 17:41:32.895 - error: backitup.0 (88902) [iobroker/mount] mount error(113): could not connect to 192.168.115.200Unable to find suitable address.
    2023-10-09 17:41:32.896 - error: backitup.0 (88902) [iobroker/mount] Error: Command failed: sudo mount -t cifs -o username=XXXX,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.115.200/Datensicherung/Raspberry
    2023-10-09 17:41:32.896 - error: backitup.0 (88902) [iobroker/mount] mount error(113): could not connect to 192.168.115.200Unable to find suitable address.
    2023-10-09 17:41:32.897 - error: backitup.0 (88902) [iobroker] Error: Command failed: sudo mount -t cifs -o username=XXXX,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.115.200/Datensicherung/Raspberry /opt/iobroker/backups
    Instanz Einstellungen:
    GlasfaserG Offline
    GlasfaserG Offline
    @tok
    Hier ist ein aktuelles Issues dazu , sieht genau so aus ,
    kannst ja auch dort schreiben .
    https://github.com/simatec/ioBroker.backitup/issues/999
    • T ToK
      @glasfaser
      @tok
      Lebt da was unter der Adresse?
        @tok
        ToK
        ja schon, den diese NAS lässt sich aus dem Terminal Putty mit dem Befehl "sudo /usr/sbin/etherwake -i eth0 <Mac Adresse>" jederzeit starten.
        • T ToK
          @tok
          Die Mac ist aber nicht die IP.
            @tok
            ToK
            schrieb am zuletzt editiert von ToK
            ist natürlich richtig - laut DEBUGLog sendet BackItUp ????
            In der Konfig ist die entsprechende Mac hinterlegt:
            Der Befehl "sudo /usr/sbin/etherwake -i eth0 <Mac Adresse>" sendet definitiv die Mac Adresse.
            GlasfaserG Thomas BraunT 2 Antworten Letzte Antwort
            • T ToK
              GlasfaserG Offline
              GlasfaserG Offline
              @tok
              das ist kein Debug Log
              Stelle die Logstufe bei der Instanz auf DEBUG .
              Dann nochmal ... und das Ergebnis hier posten.
              EDIT:
              • T ToK
                @tok
                SMB V1 wird hoffentlich nicht mehr verwendet.
                • GlasfaserG Glasfaser
                  @tok
                  EDIT:
                  ToK
                  @glasfaser
                  Bitte von unten nach oben lesen:
                  backitup.0
                  2023-10-09 19:19:00.381	error	[iobroker] Error: Command failed: sudo mount -t cifs -o username=Datensicherung,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.115.200/Datensicherung/Raspberry /opt/iobroker/backupsmount error(113): could not connect to 192.168.115.200Unable to find suitable address.
                  backitup.0
                  2023-10-09 19:19:00.381	error	[iobroker/mount] mount error(113): could not connect to 192.168.115.200Unable to find suitable address.
                  backitup.0
                  2023-10-09 19:19:00.380	error	[iobroker/mount] Error: Command failed: sudo mount -t cifs -o username=Datensicherung,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.115.200/Datensicherung/Raspberry /opt/iobroker/backups
                  backitup.0
                  2023-10-09 19:19:00.380	error	[iobroker/mount] mount error(113): could not connect to 192.168.115.200Unable to find suitable address.
                  backitup.0
                  2023-10-09 19:19:00.379	error	[iobroker/mount] [undefined Error: Command failed: sudo mount -t cifs -o username=Datensicherung,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.115.200/Datensicherung/Raspberry /opt/iobroker/backups
                  backitup.0
                  2023-10-09 19:18:54.244	debug	[iobroker/mount] cifs-mount command: "sudo mount -t cifs -o username=Datensicherung,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.115.200/Datensicherung/Raspberry /opt/iobroker/backups"
                  backitup.0
                  2023-10-09 19:18:54.242	debug	[iobroker/mount] first mount attempt with smb option failed. try next mount attempt without smb option ...
                  backitup.0
                  2023-10-09 19:18:48.054	debug	[iobroker/mount] cifs-mount command: "sudo mount -t cifs -o username=Datensicherung,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=1.0 //192.168.115.200/Datensicherung/Raspberry /opt/iobroker/backups"
                  backitup.0
                  2023-10-09 19:18:48.054	debug	[iobroker/mount] noserverino option: false
                  backitup.0
                  2023-10-09 19:16:48.053	debug	Backup has started ...
                  backitup.0
                  2023-10-09 19:16:48.052	debug	[iobroker/mount] Wake on LAN wait 120 Seconds for NAS!
                  Thomas BraunT GlasfaserG 3 Antworten Letzte Antwort
                  • T ToK
                    @glasfaser
                    backitup.0
                    backitup.0
                    backitup.0
                    backitup.0
                    backitup.0
                    backitup.0
                    backitup.0
                    backitup.0
                    backitup.0
                    backitup.0
                    backitup.0
                    @tok sagte in BackItUp kein WOL an Buffalo NAS LinkStation:
                    Schau in das 'richtige' Log:
                    iob logs --watch
                    Und poste den Text in CodeTags eingebettet.
                    • T ToK
                      @glasfaser
                      backitup.0
                      backitup.0
                      backitup.0
                      backitup.0
                      backitup.0
                      backitup.0
                      backitup.0
                      backitup.0
                      backitup.0
                      backitup.0
                      backitup.0
                      GlasfaserG Offline
                      GlasfaserG Offline
                      @tok
                      was davor ist , ist Interessant
                      und jetzt Logstufe Silly
                      • T ToK
                        @glasfaser
                        backitup.0
                        backitup.0
                        backitup.0
                        backitup.0
                        backitup.0
                        backitup.0
                        backitup.0
                        backitup.0
                        backitup.0
                        backitup.0
                        backitup.0
                        GlasfaserG Offline
                        GlasfaserG Offline
                        Kannst du von ioBroker aus die IP anpingen !?
                        bzw.
                        was du nicht geschrieben hast , funktioniert das normale Backup , also NAS dauer an und dann ein Backup ohne die Option WOL
                          @tok
                          ToK
                          @glasfaser
                          2023-10-09 19:14:52.022  - info: admin.0 (1017) <== Disconnect system.user.admin from ::ffff:192.168.115.1
                          2023-10-09 19:16:42.124  - info: admin.0 (1017) ==> Connected system.user.admin from ::ffff:192.168.115.1
                          2023-10-09 19:16:42.206  - debug: backitup.0 (94212) The local storage check was completed successfully. On the host "raspberrypi" are currently 236370 MB free space available!
                          2023-10-09 19:16:48.044  - debug: backitup.0 (94212) The local storage check was completed successfully. On the host "raspberrypi" are currently 236370 MB free space available!
                          2023-10-09 19:16:48.052  - debug: backitup.0 (94212) [iobroker/mount] Wake on LAN wait 120 Seconds for NAS!
                          2023-10-09 19:16:48.053  - debug: backitup.0 (94212) Backup has started ...
                          2023-10-09 19:18:48.054  - debug: backitup.0 (94212) [iobroker/mount] noserverino option: false
                          2023-10-09 19:18:48.054  - debug: backitup.0 (94212) [iobroker/mount] cifs-mount command: "sudo mount -t cifs -o username=Datensicherung,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=1.0 //192.168.115.200/Datensicherung/Raspberry /opt/iobroker/backups"
                          2023-10-09 19:18:54.242  - debug: backitup.0 (94212) [iobroker/mount] first mount attempt with smb option failed. try next mount attempt without smb option ...
                          2023-10-09 19:18:54.244  - debug: backitup.0 (94212) [iobroker/mount] cifs-mount command: "sudo mount -t cifs -o username=Datensicherung,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.115.200/Datensicherung/Raspberry /opt/iobroker/backups"
                          2023-10-09 19:19:00.379  - error: backitup.0 (94212) [iobroker/mount] [undefined Error: Command failed: sudo mount -t cifs -o username=Datensicherung,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.115.200/Datensicherung/Raspberry /opt/iobroker/backups
                          2023-10-09 19:19:00.380  - error: backitup.0 (94212) [iobroker/mount] mount error(113): could not connect to 192.168.115.200Unable to find suitable address.
                          2023-10-09 19:19:00.380  - error: backitup.0 (94212) [iobroker/mount] Error: Command failed: sudo mount -t cifs -o username=Datensicherung,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.115.200/Datensicherung/Raspberry /opt/iobroker/backups
                          2023-10-09 19:19:00.381  - error: backitup.0 (94212) [iobroker/mount] mount error(113): could not connect to 192.168.115.200Unable to find suitable address.
                          2023-10-09 19:19:00.381  - error: backitup.0 (94212) [iobroker] Error: Command failed: sudo mount -t cifs -o username=Datensicherung,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.115.200/Datensicherung/Raspberry /opt/iobroker/backups
                          2023-10-09 19:19:18.000  - info: admin.0 (1017) <== Disconnect system.user.admin from ::ffff:192.168.115.1
                          die MAC Adresse sehe ich hier nicht
                            bzw.
                            ToK
                            @glasfaser
                            wenn die NAS "schläft" kann ich sie nicht anpingen - wenn sie über "sudo /usr/sbin/etherwake -i eth0 <Mac Adresse>" läuft schon.
                            Das normale Backup funktioniert ohne WOL (bei laufender NAS) einwandfrei.
                            • T ToK
                              @glasfaser
                              HomoranH Offline
                              HomoranH Offline
                              wieso auch?
                              ich frage mich sowieso schon die ganze Zeit warum du dauernd die MAC Adresse ins Spiel bringst.
                                wieso auch?
                                @homoran sagte in BackItUp kein WOL an Buffalo NAS LinkStation:
                                Weil das 'magic packet' an die MAC-Adresse gesendet wird, weil der Host ja schläft.
                                T HomoranH 2 Antworten Letzte Antwort
                                  ToK
                                  ja genau ....
                                    HomoranH Offline
                                    HomoranH Offline
                                    @thomas-braun sagte in BackItUp kein WOL an Buffalo NAS LinkStation:
                                    macht das nicht der Router?
                                      ToK
                                      @homoran said in BackItUp kein WOL an Buffalo NAS LinkStation:
                                      Als Router wird eine FritzBox 7590 verwendet
                                      Thomas BraunT GlasfaserG 2 Antworten Letzte Antwort
                                      • T ToK
                                        Keine Ahnung ob das noch relevant ist:
                                        https://www.ip-phone-forum.de/threads/fritzbox-7490-wake-on-lan-über-udp-port-9-klappt-nicht-mehr.284397/
                                        • T ToK
                                          GlasfaserG Offline
                                          GlasfaserG Offline
                                          @tok
                                          Kannst du das mal testen
                                          sudo -H -u iobroker /usr/sbin/etherwake -i eth0 <Mac Adresse>
                                          @Thomas-Braun
                                          Welche Rechte braucht dann
                                          Thomas BraunT T 2 Antworten Letzte Antwort
