  4. BackItUp kein WOL an Buffalo NAS LinkStation
40 Beiträge 5 Kommentatoren 4.4k Aufrufe 4 Beobachtet
  • GlasfaserG Glasfaser
    @tok sagte in BackItUp kein WOL an Buffalo NAS LinkStation:
    192.168.115.200Unable to find suitable address.
    Kannst du von ioBroker aus die IP anpingen !?
    bzw.
    was du nicht geschrieben hast , funktioniert das normale Backup , also NAS dauer an und dann ein Backup ohne die Option WOL
    ToK
    @glasfaser
    wenn die NAS "schläft" kann ich sie nicht anpingen - wenn sie über "sudo /usr/sbin/etherwake -i eth0 <Mac Adresse>" läuft schon.
    Das normale Backup funktioniert ohne WOL (bei laufender NAS) einwandfrei.
    • T ToK
      @glasfaser
      2023-10-09 19:14:52.022  - info: admin.0 (1017) <== Disconnect system.user.admin from ::ffff:192.168.115.1
      2023-10-09 19:16:42.124  - info: admin.0 (1017) ==> Connected system.user.admin from ::ffff:192.168.115.1
      2023-10-09 19:16:42.206  - debug: backitup.0 (94212) The local storage check was completed successfully. On the host "raspberrypi" are currently 236370 MB free space available!
      2023-10-09 19:16:48.044  - debug: backitup.0 (94212) The local storage check was completed successfully. On the host "raspberrypi" are currently 236370 MB free space available!
      2023-10-09 19:16:48.052  - debug: backitup.0 (94212) [iobroker/mount] Wake on LAN wait 120 Seconds for NAS!
      2023-10-09 19:16:48.053  - debug: backitup.0 (94212) Backup has started ...
      2023-10-09 19:18:48.054  - debug: backitup.0 (94212) [iobroker/mount] noserverino option: false
      2023-10-09 19:18:48.054  - debug: backitup.0 (94212) [iobroker/mount] cifs-mount command: "sudo mount -t cifs -o username=Datensicherung,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=1.0 //192.168.115.200/Datensicherung/Raspberry /opt/iobroker/backups"
      2023-10-09 19:18:54.242  - debug: backitup.0 (94212) [iobroker/mount] first mount attempt with smb option failed. try next mount attempt without smb option ...
      2023-10-09 19:18:54.244  - debug: backitup.0 (94212) [iobroker/mount] cifs-mount command: "sudo mount -t cifs -o username=Datensicherung,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.115.200/Datensicherung/Raspberry /opt/iobroker/backups"
      2023-10-09 19:19:00.379  - error: backitup.0 (94212) [iobroker/mount] [undefined Error: Command failed: sudo mount -t cifs -o username=Datensicherung,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.115.200/Datensicherung/Raspberry /opt/iobroker/backups
      2023-10-09 19:19:00.380  - error: backitup.0 (94212) [iobroker/mount] mount error(113): could not connect to 192.168.115.200Unable to find suitable address.
      2023-10-09 19:19:00.380  - error: backitup.0 (94212) [iobroker/mount] Error: Command failed: sudo mount -t cifs -o username=Datensicherung,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.115.200/Datensicherung/Raspberry /opt/iobroker/backups
      2023-10-09 19:19:00.381  - error: backitup.0 (94212) [iobroker/mount] mount error(113): could not connect to 192.168.115.200Unable to find suitable address.
      2023-10-09 19:19:00.381  - error: backitup.0 (94212) [iobroker] Error: Command failed: sudo mount -t cifs -o username=Datensicherung,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.115.200/Datensicherung/Raspberry /opt/iobroker/backups
      2023-10-09 19:19:18.000  - info: admin.0 (1017) <== Disconnect system.user.admin from ::ffff:192.168.115.1
      die MAC Adresse sehe ich hier nicht
      HomoranH Offline
      HomoranH Offline
      wieso auch?
      ich frage mich sowieso schon die ganze Zeit warum du dauernd die MAC Adresse ins Spiel bringst.
        wieso auch?
        @homoran sagte in BackItUp kein WOL an Buffalo NAS LinkStation:
        Weil das 'magic packet' an die MAC-Adresse gesendet wird, weil der Host ja schläft.
        T HomoranH 2 Antworten Letzte Antwort
          ToK
          ja genau ....
            HomoranH Offline
            HomoranH Offline
            @thomas-braun sagte in BackItUp kein WOL an Buffalo NAS LinkStation:
            macht das nicht der Router?
              ToK
              @homoran said in BackItUp kein WOL an Buffalo NAS LinkStation:
              Als Router wird eine FritzBox 7590 verwendet
              Thomas BraunT GlasfaserG 2 Antworten Letzte Antwort
              • T ToK
                Keine Ahnung ob das noch relevant ist:
                https://www.ip-phone-forum.de/threads/fritzbox-7490-wake-on-lan-über-udp-port-9-klappt-nicht-mehr.284397/
                • T ToK
                  GlasfaserG Offline
                  GlasfaserG Offline
                  @tok
                  Kannst du das mal testen
                  sudo -H -u iobroker /usr/sbin/etherwake -i eth0 <Mac Adresse>
                  @Thomas-Braun
                  Welche Rechte braucht dann
                  Thomas BraunT T 2 Antworten Letzte Antwort
                    @tok
                    @Thomas-Braun
                    @glasfaser sagte in BackItUp kein WOL an Buffalo NAS LinkStation:
                    @Thomas-Braun
                    Keine Ahnung, denn:
                    echad@chet:/opt/iobroker $ type -p etherwake
                      @tok
                      @Thomas-Braun
                      ToK
                      @glasfaser said in BackItUp kein WOL an Buffalo NAS LinkStation:
                      @tok
                      @Thomas-Braun
                        @Thomas-Braun
                        Keine Ahnung, denn:
                        GlasfaserG Offline
                        GlasfaserG Offline
                        etherwake
                        Das ist mit diesem NPM Paket !?
                        https://github.com/simatec/ioBroker.backitup/issues/978
                          etherwake
                          @glasfaser
                          Wollte ich gerade schreiben. Das läuft nicht über das binairy, sondern über das node-Modul 'node-wol'. Und das ist schon Jahre nicht mehr angepackt worden.
                            etherwake
                            ToK
                            etherwake
                            verwende seit soeben die Version 2.8.2 - die Konfig im BackItUp sind ident wie zuvor - ob das NPM Paket aktiv ist (sollte seit 2.8.0 so sein) kann ich nicht beurteilen - es funktioniert leider noch immer nicht.
                            • HomoranH Offline
                              HomoranH Offline
                              kann da auch der arp-cache in die Suppe spucken?
                                Nein, der ist IP-basiert.
                                • T ToK
                                  etherwake
                                  GlasfaserG Offline
                                  GlasfaserG Offline
                                  @tok
                                  Zeige mal
                                  npm ls grep node-wol
                                  Bei mir
                                  iobroker.inst@3.0.0 /opt/iobroker
                                  └─┬ iobroker.backitup@2.8.2
                                    └── node-wol@0.1.1
                                    @tok
                                    Zeige mal
                                    Bei mir
                                      └── node-wol@0.1.1
                                    ToK
                                    @tok
                                    Zeige mal
                                    Bei mir
                                      └── node-wol@0.1.1
                                    totzk@raspberrypi:~ $ npm ls grep node-wol
                                    /home/totzk
                                    └── (empty)
                                    GlasfaserG Thomas BraunT 2 Antworten Letzte Antwort
                                    • T ToK
                                      @tok
                                      Zeige mal
                                      Bei mir
                                        └── node-wol@0.1.1
                                      /home/totzk
                                      └── (empty)
                                      GlasfaserG Offline
                                      GlasfaserG Offline
                                      @tok
                                      auch im Verzeichniss
                                      cd /opt/iobroker
                                      • T ToK
                                        @tok
                                        Zeige mal
                                        Bei mir
                                          └── node-wol@0.1.1
                                        /home/totzk
                                        └── (empty)
                                        cd /opt/iobroker && npm ls grep node-wol
                                          @tok
                                          cd /opt/iobroker
                                          ToK
                                          @tok
                                          cd /opt/iobroker
                                          totzk@raspberrypi:~ $ cd /opt/iobroker
                                          totzk@raspberrypi:/opt/iobroker $ npm ls grep node-wol
                                            └── node-wol@0.1.1
                                          GlasfaserG simatecS 2 Antworten Letzte Antwort
