  4. iob node fix - Skript
198 Beiträge 34 Kommentatoren 94.8k Aufrufe 37 Beobachtet
  • F Frank579
    So sieht es bei mir aus ... keine 2x Nothing to do ..
    ioBroker nodejs fixer 2023-09-20
    Recommended nodejs-version is: 18.18.0
    Checking your installation now. Please be patient!
    Your current setup is:
    /usr/bin/nodejs         v18.17.1
    /usr/bin/node           v18.17.1
    /usr/bin/npm            9.6.7
    /usr/bin/npx            9.6.7
    /usr/bin/corepack       0.18.0
    We found these nodejs versions available for installation:
    nodejs:
      Installed: 18.17.1-deb-1nodesource1
      Candidate: 18.17.1-deb-1nodesource1
      Version table:
     *** 18.17.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x bookworm/main amd64 Packages
         18.13.0+dfsg1-1 500
            500 http://deb.debian.org/debian bookworm/main amd64 Packages
    Nothing to do, your installation is using the correct paths.
    You are running nodejs v18.17.1. Do you want to install recommended version 18.1        8.0?
    Press <y> to continue or any other key to quit
    Trying to fix your installation now. Please be patient.
    [sudo] password for frank:
    kvm
    Waiting for ioBroker to shut down - Give me a minute...
    *** These repos are active on your system:
    Hit:1 http://security.debian.org/debian-security bookworm-security InRelease
    Hit:2 http://deb.debian.org/debian bookworm InRelease
    Reading package lists... Done
    *** Installing ca-certificates, curl and gnupg, just in case they are missing.
    *** Creating new /etc/apt/sources.list.d/nodesource.list and pinning source
    deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x nodistro main
    Package: nodejs
    Pin: origin deb.nodesource.com
    Pin-Priority: 1001
    *** These repos are active after the adjustments:
    Get:4 https://deb.nodesource.com/node_18.x nodistro InRelease [12.1 kB]
    Get:5 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages [5247 B]
    Fetched 17.4 kB in 1s (27.2 kB/s)
    Installing the recommended nodejs version now!
    ./iob_node_update: line 308: [: : integer expression expected
    ./iob_node_update: line 323: [: : integer expression expected
    *** You need to manually restart your container now! ***
    We tried our best to fix your nodejs. Please run 'iob diag' again to verify.
    nach einem Neustart war laut iob diag immer noch die 18.17.1 drauf, aber 1 OS update fällig. update und upgrade ausgeführt und dann war auch die 18.18.0 drauf
    hier noch die diag Zusammenfassung
                         v.2023-06-20
     Static hostname: iobroker
           Icon name: computer-vm
             Chassis: vm 🖴
          Machine ID: 84546650dea94ae18d0b4591eabfa35d
             Boot ID: d517d6f1ff9047a7af8b77da764b2425
      Virtualization: kvm
              Kernel: Linux 6.1.0-12-amd64
        Architecture: x86-64
     Hardware Vendor: QEMU
      Hardware Model: Standard PC _i440FX + PIIX, 1996_
    Firmware Version: rel-1.16.2-0-gea1b7a073390-prebuilt.qemu.org
    Installation:           kvm
    Kernel:                 x86_64
    Userland:               amd64
    User-ID:                1000
    X-Server:               false
    Pending OS-Updates:     1
    Pending iob updates:    16
    Nodejs-Installation:    /usr/bin/nodejs         v18.17.1
                            /usr/bin/npm            9.6.7
                            /usr/bin/npx            9.6.7
    Recommended versions are nodejs 18.x.y and npm 9.x.y
    MEMORY:
    Mem:            8.3G        2.7G        5.1G        507K        734M        5.6G
    Swap:           1.0G          0B        1.0G
    Total:          9.3G        2.7G        6.2G
    Active iob-Instances:   21
    Active repo(s): beta
    ioBroker Core:          js-controller           5.0.12
                            admin                   6.8.0
    Objects type: jsonl
    States  type: jsonl
    + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
      system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    Objects:                19132
    States:                 17041
    Size of iob-Database:
    55M     /opt/iobroker/iobroker-data/objects.jsonl
    24M     /opt/iobroker/iobroker-data/states.jsonl
    IOBroker läuft auf Debian 12 Proxmox VM
    Edit:
    Diag nach update / Upgrade
                         v.2023-06-20
             Chassis: vm 🖴
      Virtualization: kvm
    Installation:           kvm
    Kernel:                 x86_64
    Userland:               amd64
    User-ID:                1000
    X-Server:               false
    Pending OS-Updates:     0
    Pending iob updates:    2
    Nodejs-Installation:    /usr/bin/nodejs         v18.18.0
                            /usr/bin/node           v18.18.0
                            /usr/bin/npm            9.8.1
                            /usr/bin/npx            9.8.1
    MEMORY:
    Mem:            8.3G        4.8G        2.7G        507K        1.1G        3.5G
    Swap:           1.0G          0B        1.0G
    Total:          9.3G        4.8G        3.8G
    Active iob-Instances:   44
    Active repo(s): stable
                            admin                   6.8.0
    Objects type: jsonl
    States  type: jsonl
    Objects:                19132
    States:                 17041
    64M     /opt/iobroker/iobroker-data/objects.jsonl
    36M     /opt/iobroker/iobroker-data/states.jsonl
    J
    J
    Jan1
    #109
    @frank579 sagte in iob node fix - Skript:
    Klar, ein Neustart installiert ja auch keine Node, sondern das System Update.
    Das Script bereitet das vor, aber installieren musst das schon selber.
    F 1 Antwort Letzte Antwort
    • J Jan1
      F
      F
      Frank579
      schrieb am zuletzt editiert von Frank579
      #110
      @jan1 sagte in iob node fix - Skript:
      You are running nodejs v18.17.1. Do you want to install recommended version 18.18.0?
      Die abfrage habe ich anders verstanden...
      Wenns so ist Okay dann war ja alles Richtig.
      @Thomas-Braun ist das so ?
        @dpo99 sagte in iob node fix - Skript:
        Kann man das wiederherstellen oder iwo nachträglich auslesen?
        Nein, es wird kein (eigenes) Log vom skript geschrieben.
        D
        D
        DPO99
        #111
        @thomas-braun bei mir war es wie bei @Frank579. Realtiv ähnlich lief das Skript bei mir. Zwischendurch diese Info:
        Bei mir wurde auch nach einem Update auf die neuste Version gefragt:
        You are running nodejs v18.17.1. Do you want to install recommended version in tree 18.x        8.0?
        [sudo] password for iobroker:
        und endete mit dieser CodeZeile
        Im Verlauf der Installation war es auch so, dass er von 18.17.1 ein Downgrade auf 18.17.0 durchgeführt hat und dann wieder ein upgrade auf 18.18.0 inkl. NPM.
        Wie gesagt, sah am Ende dann alles korrekt aus, lief ohne Fehler und iob diag hat auch keine Fehler gemeldet.
        • D DPO99
          Thomas BraunT
          Thomas BraunT
          Most Active Developer
          #112
          Das wird gemacht, wenn aus den iob-States keine Recommended Version ausgelesen werden kann (slaves oder Datenbank läuft nicht oder sonst irgendwas).
          Ich hab den Code jetzt umgestellt, die Meldungen sollten jetzt schlüssiger sein.
          • M
            M
            mick70
            #113
            Hat hier funktioniert. Ebenfalls nach anfänglichem Downgrade auf 18.17.0 ist jetzt 18.18.0 installiert und erneuter Durchlauf berichtet wie erhofft 2x "nothing to do". Einwandfrei!
            • M mick70
              Thomas BraunT
              Thomas BraunT
              #114
              @mick70 sagte in iob node fix - Skript:
              Ist das ein Slave-Device? Oder warum musste dieser Fallback gemacht werden?
                M
                M
                mick70
                #115
                @thomas-braun Nein, ist eigentlich gar nix besonderes. Die Ursache fürs Fallback habe ich leider überlesen, falls sie irgendwo stand.
                • M mick70
                  Thomas BraunT
                  Thomas BraunT
                  #116
                  Die genaue Ursache steht nicht da, nur dass keine empfohlene Version gefunden werden konnte und daher der 18er-Zweig angelegt werden wird.
                  teletapiT 1 Antwort Letzte Antwort
                    teletapiT
                    teletapiT
                    teletapi
                    schrieb am zuletzt editiert von teletapi
                    #117
                    Funktioniert ganz klasse
                    Hab das heute mal drüber laufen lassen und das Update auf die 18.18.0 gemacht
                    /usr/bin/npm 9.6.7
                    /usr/bin/npx 9.6.7
                    nodejs:
                    Version table:
                    500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
                    12.22.12~dfsg-1~deb11u4 500
                    500 http://security.debian.org/debian-security bullseye-security/main ar m64 Packages
                    12.22.12~dfsg-1~deb11u3 500
                    500 http://deb.debian.org/debian bullseye/main arm64 Packages
                    Nothing to do - Your installation is using the correct paths.
                    Hit:1 http://deb.debian.org/debian bullseye InRelease
                    Get:2 http://deb.debian.org/debian bullseye-updates InRelease [44.1 kB]
                    Get:3 http://security.debian.org/debian-security bullseye-security InRelease [48 .4 kB]
                    Get:4 http://archive.raspberrypi.org/debian bullseye InRelease [23.6 kB]
                    Hit:5 https://repos.influxdata.com/debian stable InRelease
                    Get:6 https://apt.grafana.com stable InRelease [5984 B]
                    Get:7 http://archive.raspberrypi.org/debian bullseye/main armhf Packages [314 kB ]
                    Get:8 http://archive.raspberrypi.org/debian bullseye/main arm64 Packages [308 kB ]
                    Fetched 744 kB in 1s (498 kB/s)
                    deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node _18.x nodistro main
                    Package: nodejs
                    Pin-Priority: 1001
                    Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
                    Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
                    Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
                    Hit:6 https://apt.grafana.com stable InRelease
                    Get:7 https://deb.nodesource.com/node_18.x nodistro InRelease [12.1 kB]
                    Get:8 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages [5262 B]
                    Get:9 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages [5267 B]
                    Fetched 22.7 kB in 2s (13.8 kB/s)
                    We tried our best to fix your nodejs. Please run iob diag again to verify.
                    *** RESTARTING ioBroker NOW! ***
                    Please refresh or restart your browser in a few moments.
                    pi@iobroker:~ $ sudo apt update && sudo apt upgrade
                    OK:1 http://security.debian.org/debian-security bullseye-security InRelease
                    OK:2 http://deb.debian.org/debian bullseye InRelease
                    OK:3 http://archive.raspberrypi.org/debian bullseye InRelease
                    OK:4 http://deb.debian.org/debian bullseye-updates InRelease
                    OK:5 https://repos.influxdata.com/debian stable InRelease
                    OK:6 https://apt.grafana.com stable InRelease
                    OK:7 https://deb.nodesource.com/node_18.x nodistro InRelease
                    Aktualisierung für 1 Paket verfügbar. Führen Sie »apt list --upgradable« aus, um es anzuzeigen.
                    Paketaktualisierung (Upgrade) wird berechnet… Fertig
                    nodejs
                    1 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
                    Es müssen 28,7 MB an Archiven heruntergeladen werden.
                    Nach dieser Operation werden 859 kB Plattenplatz zusätzlich benutzt.
                    Möchten Sie fortfahren? [J/n] J
                    Holen:1 https://deb.nodesource.com/node_18.x nodistro/main arm64 nodejs arm64 18 .18.0-1nodesource1 [28,7 MB]
                    Es wurden 28,7 MB in 2 s geholt (11,5 MB/s).
                    Changelogs werden gelesen... Fertig
                    (Lese Datenbank ... 117382 Dateien und Verzeichnisse sind derzeit installiert.)
                    Vorbereitung zum Entpacken von .../nodejs_18.18.0-1nodesource1_arm64.deb ...
                    Detected old npm client, removing...
                    Entpacken von nodejs (18.18.0-1nodesource1) über (18.17.1-deb-1nodesource1) ...
                    nodejs (18.18.0-1nodesource1) wird eingerichtet ...
                    Trigger für man-db (2.9.4-2) werden verarbeitet ...
                    pi@iobroker:~ $ iobroker stop
                    pi@iobroker:~ $ iobroker fix
                    library: loaded
                    Library version=2022-12-09
                    Welcome to the ioBroker installation fixer!
                    Script version: 2023-04-02
                    You might need to enter your password a couple of times.
                    Installing prerequisites (1/5)
                    OK:3 http://deb.debian.org/debian bullseye-updates InRelease
                    OK:4 http://archive.raspberrypi.org/debian bullseye InRelease
                    Installed gcc-c++
                    Checking ioBroker user and directory permissions (2/5)
                    Check and cleanup npm temporary directories (3/5)
                    Done.
                    Database maintenance (4/5)
                    Checking for uncompressed JSONL databases... This might take a while!
                    Compressing /opt/iobroker/iobroker-data/states.jsonl
                    Compressing /opt/iobroker/iobroker-data/objects.jsonl
                    Compressed 2 JSONL files. Done
                    Checking autostart (5/5)
                    Enabling autostart...
                    Autostart enabled!
                    Your installation was fixed successfully
                    Run iobroker start to start ioBroker again!
                    pi@iobroker:~ $ sudo reboot
                    Und dann mal IOB Diag laufen lassen
                    Skript v.2023-06-20
                    *** BASE SYSTEM ***
                             Icon name: computer
                            Machine ID: a9f1eae0dc5a48ddbf0e2a62c2227673
                               Boot ID: 30ea7719d00c47c7b8b94d2a5e591316
                      Operating System: Debian GNU/Linux 11 (bullseye)
                                Kernel: Linux 6.1.21-v8+
                          Architecture: arm64
                    Model           : Raspberry Pi 4 Model B Rev 1.5
                    Docker          : false
                    Virtualization  : none
                    Kernel          : aarch64
                    Userland        : arm64
                    Systemuptime and Load:
                     15:14:39 up 5 min,  1 user,  load average: 1.41, 1.78, 0.91
                    CPU threads: 4
                    Raspberry only:
                    throttled=0x0
                    Other values than 0x0 hint to temperature/voltage problems
                    temp=46.7'C
                    volt=0.9360V
                    *** Time and Time Zones ***
                                   Local time: Fri 2023-09-22 15:14:39 CEST
                               Universal time: Fri 2023-09-22 13:14:39 UTC
                                     RTC time: n/a
                                  NTP service: active
                              RTC in local TZ: no
                    *** User and Groups ***
                    pi
                    /home/pi
                    pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
                    *** X-Server-Setup ***
                    X-Server:       false
                    Desktop:
                    Terminal:       tty
                    Boot Target:    multi-user.target
                    *** MEMORY ***
                    Mem:            7.8G        2.3G        4.0G        1.0M        1.5G        5.4G
                    Swap:            99M          0B         99M
                    Total:          7.9G        2.3G        4.1G
                             7811 M total memory
                             2318 M used memory
                             3162 M active memory
                              446 M inactive memory
                             4041 M free memory
                               71 M buffer memory
                             1380 M swap cache
                               99 M total swap
                                0 M used swap
                               99 M free swap
                    Raspberry only:
                    oom events: 0
                    *** FILESYSTEM ***
                    /dev/root      ext4       59G  9.8G   47G  18% /
                    devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
                    tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
                    tmpfs          tmpfs     1.6G  1.2M  1.6G   1% /run
                    /dev/sda1      vfat      255M   31M  225M  13% /boot
                    tmpfs          tmpfs     782M   16K  782M   1% /run/user/1000
                    [Fri Sep 22 15:08:53 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:13:A5:D1 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=tty1 root=PARTUUID=2c0392e1-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                    [Fri Sep 22 15:08:55 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
                    [Fri Sep 22 15:08:55 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
                    [Fri Sep 22 15:08:56 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
                    TARGET  SOURCE    FSTYPE OPTIONS
                    /       /dev/sda2 ext4   rw,noatime
                    `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                    /var:
                    1.9G    /var/
                    1.2G    /var/log/journal/a9f1eae0dc5a48ddbf0e2a62c2227673
                    1.2G    /var/log
                    477M    /var/lib
                    Archived and active journals take up 1.1G in the file system.
                    /opt/iobroker/backups:
                    1.2G    /opt/iobroker/backups/
                    /opt/iobroker/iobroker-data:
                    334M    /opt/iobroker/iobroker-data/
                    181M    /opt/iobroker/iobroker-data/files
                    71M     /opt/iobroker/iobroker-data/backup-objects
                    62M     /opt/iobroker/iobroker-data/node-red/node_modules
                    33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
                    21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
                    14M     /opt/iobroker/iobroker-data/objects.jsonl
                    8.5M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js
                    8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js
                    *** NodeJS-Installation ***
                    /usr/bin/npm            9.8.1
                    /usr/bin/npx            9.8.1
                    nodejs:
                      Installed: 18.18.0-1nodesource1
                      Candidate: 18.18.0-1nodesource1
                      Version table:
                     *** 18.18.0-1nodesource1 1001
                            500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
                         18.17.1-1nodesource1 1001
                         18.17.0-1nodesource1 1001
                         18.16.1-1nodesource1 1001
                         18.16.0-1nodesource1 1001
                         18.15.0-1nodesource1 1001
                         18.14.2-1nodesource1 1001
                         18.14.1-1nodesource1 1001
                         18.14.0-1nodesource1 1001
                         18.13.0-1nodesource1 1001
                         18.12.0-1nodesource1 1001
                         18.11.0-1nodesource1 1001
                         18.10.0-1nodesource1 1001
                         18.9.1-1nodesource1 1001
                         18.9.0-1nodesource1 1001
                         18.8.0-1nodesource1 1001
                         18.7.0-1nodesource1 1001
                         18.6.0-1nodesource1 1001
                         18.5.0-1nodesource1 1001
                         18.4.0-1nodesource1 1001
                         18.3.0-1nodesource1 1001
                         18.2.0-1nodesource1 1001
                         18.1.0-1nodesource1 1001
                         18.0.0-1nodesource1 1001
                            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                    No problems detected
                    Errors in npm tree: 0
                    *** ioBroker-Installation ***
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    No configuration change needed.
                    Multihost discovery server: disabled
                    Discovery authentication:   enabled
                    Persistent activation:      disabled
                    Objects:                    jsonl on 127.0.0.1
                    States:                     jsonl on 127.0.0.1
                    Core adapters versions
                    js-controller:  5.0.12
                    admin:          6.10.2
                    javascript:     7.1.4
                    Adapters from github:   2
                    Adapter State
                    + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
                      system.adapter.alias-manager.0          : alias-manager         : iobroker                                 - disabled
                    + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                    + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
                    + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
                    + system.adapter.energiefluss.0           : energiefluss          : iobroker                                 -  enabled
                    + system.adapter.energiefluss.1           : energiefluss          : iobroker                                 -  enabled
                    + system.adapter.fritzdect.0              : fritzdect             : iobroker                                 -  enabled
                    + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
                    + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 18701
                    + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 12001
                    + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 -  enabled, port: 12010
                    + system.adapter.hm-rpc.3                 : hm-rpc                : iobroker                                 -  enabled, port: 0
                    + system.adapter.hue-extended.0           : hue-extended          : iobroker                                 -  enabled
                      system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
                    + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
                    + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
                    + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
                    + system.adapter.jarvis.0                 : jarvis                : iobroker                                 -  enabled
                    + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                      system.adapter.modbus.0                 : modbus                : iobroker                                 - disabled
                    + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                    + system.adapter.net-tools.0              : net-tools             : iobroker                                 -  enabled
                    + system.adapter.node-red.0               : node-red              : iobroker                                 -  enabled, port: 1880, bind: 0.0.0.0
                    + system.adapter.nuki.0                   : nuki                  : iobroker                                 -  enabled
                    + system.adapter.opendtu.0                : opendtu               : iobroker                                 -  enabled
                    + system.adapter.panasonic-viera.0        : panasonic-viera       : iobroker                                 -  enabled
                    + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
                    + system.adapter.rpi2.0                   : rpi2                  : iobroker                                 -  enabled
                    + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 192.168.178.82, run as: admin
                      system.adapter.smartmeter.0             : smartmeter            : iobroker                                 - disabled
                      system.adapter.smartmeter.1             : smartmeter            : iobroker                                 - disabled
                    + system.adapter.socketio.0               : socketio              : iobroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                    + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1886, bind: 0.0.0.0
                    + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                    + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
                    + instance is alive
                    ioBroker-Repositories
                    Installed ioBroker-Instances
                    Used repository: beta
                    Adapter    "admin"        : 6.10.2   , installed 6.10.2
                    Adapter    "alexa2"       : 3.25.2   , installed 3.25.2
                    Adapter    "alias-manager": 1.2.6    , installed 1.2.6
                    Adapter    "backitup"     : 2.8.1    , installed 2.8.1
                    Adapter    "cloud"        : 4.4.1    , installed 4.4.1
                    Adapter    "discovery"    : 4.0.0    , installed 4.0.0
                    Adapter    "fritzdect"    : 2.3.1    , installed 2.3.1
                    Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
                    Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
                    Adapter    "hue-extended" : 2.0.0    , installed 2.0.0
                    Adapter    "ical"         : 1.13.3   , installed 1.13.3
                    Adapter    "info"         : 2.0.0    , installed 2.0.0
                    Adapter    "iot"          : 2.0.11   , installed 2.0.11
                    Adapter    "jarvis"       : 3.1.8    , installed 3.1.9-beta.3
                    Adapter    "javascript"   : 7.1.4    , installed 7.1.4
                    Controller "js-controller": 5.0.12   , installed 5.0.12
                    Adapter    "modbus"       : 5.0.11   , installed 5.0.11
                    Adapter    "mqtt"         : 5.0.0    , installed 5.0.0
                    Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
                    Adapter    "node-red"     : 4.0.3    , installed 4.0.3
                    Adapter    "nuki"         : 1.6.0    , installed 1.6.0
                    Adapter    "opendtu"      : 0.1.7    , installed 0.1.7
                    Adapter    "panasonic-viera": 2.0.0  , installed 2.0.0
                    Adapter    "smartmeter"   : 3.3.4    , installed 3.3.4
                    Adapter    "socketio"     : 6.5.5    , installed 6.5.5
                    Adapter    "sonoff"       : 2.5.7    , installed 2.5.7
                    Adapter    "telegram"     : 1.16.0   , installed 1.16.0
                    Adapter    "web"          : 6.1.2    , installed 6.1.2
                    Adapter    "ws"           : 2.5.5    , installed 2.5.5
                    Objects and States
                    Objects:        9883
                    States:         9205
                    Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
                    Hit:2 http://deb.debian.org/debian bullseye InRelease
                    Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
                    Hit:5 https://apt.grafana.com stable InRelease
                    Hit:6 https://repos.influxdata.com/debian stable InRelease
                    Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
                    Pending Updates: 0
                    *** Listening Ports ***
                    tcp        0      0 192.168.178.82:9092     0.0.0.0:*               LISTEN      1001       26915      2000/io.nuki.0
                    tcp        0      0 192.168.178.82:2001     0.0.0.0:*               LISTEN      1001       15234      1458/io.hm-rpc.3
                    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13125      576/sshd: /usr/sbin
                    tcp        0      0 192.168.178.82:18701    0.0.0.0:*               LISTEN      1001       17085      1315/io.hm-rpc.0
                    tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       20213      1851/io.jarvis.0
                    tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       18734      1558/io.sonoff.0
                    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      116        12257      561/mosquitto
                    tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       17070      1235/node-red
                    tcp        0      0 192.168.178.82:12010    0.0.0.0:*               LISTEN      1001       17212      1359/io.hm-rpc.2
                    tcp        0      0 192.168.178.82:12001    0.0.0.0:*               LISTEN      1001       17960      1342/io.hm-rpc.1
                    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          13138      538/cupsd
                    tcp        0      0 192.168.178.82:8087     0.0.0.0:*               LISTEN      1001       23788      2139/io.simple-api.
                    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       15479      654/iobroker.js-con
                    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       16497      654/iobroker.js-con
                    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          13137      538/cupsd
                    tcp6       0      0 :::3000                 :::*                    LISTEN      117        16568      653/grafana
                    tcp6       0      0 :::8086                 :::*                    LISTEN      999        13159      548/influxd
                    tcp6       0      0 :::8084                 :::*                    LISTEN      1001       25135      2161/io.socketio.0
                    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       21930      1708/io.web.0
                    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       14838      954/io.admin.0
                    tcp6       0      0 :::22                   :::*                    LISTEN      0          13127      576/sshd: /usr/sbin
                    tcp6       0      0 :::1883                 :::*                    LISTEN      116        12258      561/mosquitto
                    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14601      461/dhcpcd
                    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          13146      617/cups-browsed
                    udp        0      0 0.0.0.0:49885           0.0.0.0:*                           108        13036      402/avahi-daemon: r
                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13034      402/avahi-daemon: r
                    udp6       0      0 :::56039                :::*                                108        13037      402/avahi-daemon: r
                    udp6       0      0 :::546                  :::*                                0          13201      461/dhcpcd
                    udp6       0      0 :::5353                 :::*                                108        13035      402/avahi-daemon: r
                    2023-09-22 15:14:07.195  - info: admin.0 (954) ==> Connected system.user.admin from ::ffff:192.168.178.63
                    2023-09-22 15:14:09.020  - info: host.iobroker Updating repository "beta" under "http://download.iobroker.net/sources-dist-latest.json"
                    iob diag has finished.
                    • teletapiT teletapi
                      /usr/bin/npm 9.6.7
                      /usr/bin/npx 9.6.7
                      nodejs:
                      Version table:
                      Package: nodejs
                      Pin-Priority: 1001
                      nodejs
                      library: loaded
                      Installed gcc-c++
                      Done.
                      Autostart enabled!
                      Skript v.2023-06-20
                      *** BASE SYSTEM ***
                               Icon name: computer
                            Architecture: arm64
                      Docker          : false
                      Kernel          : aarch64
                      Userland        : arm64
                      CPU threads: 4
                      Raspberry only:
                      throttled=0x0
                      temp=46.7'C
                      volt=0.9360V
                                       RTC time: n/a
                                    NTP service: active
                                RTC in local TZ: no
                      pi
                      /home/pi
                      X-Server:       false
                      Desktop:
                      Terminal:       tty
                      *** MEMORY ***
                      Swap:            99M          0B         99M
                               7811 M total memory
                               2318 M used memory
                               4041 M free memory
                                 71 M buffer memory
                               1380 M swap cache
                                 99 M total swap
                                  0 M used swap
                                 99 M free swap
                      Raspberry only:
                      oom events: 0
                      *** FILESYSTEM ***
                      /var:
                      1.9G    /var/
                      1.2G    /var/log
                      477M    /var/lib
                      /usr/bin/npm            9.8.1
                      /usr/bin/npx            9.8.1
                      nodejs:
                        Version table:
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      admin:          6.10.2
                      javascript:     7.1.4
                      Adapter State
                      + instance is alive
                      Objects and States
                      Objects:        9883
                      States:         9205
                      Pending Updates: 0
                      Thomas BraunT
                      Thomas BraunT
                      #118
                      @teletapi
                      Das schaut gut aus.
                      Von welcher Version bist du denn gekommen? Der Auszug ist ja vermutlich von einem zweiten Durchlauf des Skripts.
                        @teletapi
                        Das schaut gut aus.
                        teletapiT
                        teletapiT
                        teletapi
                        #119
                        auf dem Produktivsystem hab ich das script nur einmal laufen lassen, danach dann direkt sudo apt update && sudo apt upgrade danach war alles bereits sauber erledigt
                        Zum schluss nochmal dein script drüber laufen lassen und beide "Nothing to do" am Schluss
                        Ich bin von der node.js 18.17.1
                        Nachdem ich per sudo apt update && sudo apt upgrade nicht auf die 18.18.0 kam hab ich dein script mit einer sicherungs Festplatte am RPI getestet nachdem das wunderbar funktioniert hat hab ich das dann auf meinem produktiv System ebenfalls gemacht
                          Thomas BraunT
                          Thomas BraunT
                          #120
                          @teletapi
                          Danke, das hilft!
                            Hinweis vorab: Wenn das Skript ausgeführt wurde und sein Werk getan hat, funktionieren Updates innerhalb der nodejs-Version wieder wie gehabt über
                            sudo apt update
                            sudo apt full-upgrade
                            Erneutes ausführen des Skriptes bei einem gewöhnlichen Update ist nicht notwendig!
                            __
                            BETA-TESTING
                            (Nachdem das Skript jetzt auch offiziell Teil vom ioBroker in Form des Kommandos iob nodejs-update geworden ist wird hier im Thread an Beta-Versionen gewerkelt. Mit den üblichen Gefahren. Es kann hier Code in jeglicher Form und Lauffähigkeit vorgefunden werden. Bitte hier nur 'todesmutige' Tester mit Backup für den Fall der Fälle. )
                            Ich habe mich ja lange dagegen ausgesprochen, so grundlegende Dinge wie die Installation von nodejs über windige 'Toolz' machen zu lassen. Aber sei es wie es ist, hier ist ein Skript, das verfummelte nodejs-Installationen wieder weitgehend gerade ziehen sollte und auch das aktuelle Repository für nodejs in der Version von nodesource inkl. der Schlüssel usw. installiert.
                            Flugs heruntergeladen und ausgeführt per
                            curl https://raw.githubusercontent.com/Grothesk242/iob_diag/main/iob_node_update.sh > iob_node_update
                            chmod 744 iob_node_update
                            ./iob_node_update
                            Optional kann man dem Skript auch einen nodejs-Zweig mit geben, dann wird die letzte Version aus diesem Zweig installiert.
                            ./iob_node_update XX
                            Wobei der Zweig natürlich existent sein muss. Zur Zeit ist also XX = 18 , 20 oder 22 möglich.
                            Noch ein Hinweis: Gegebenenfalls (wenn z. B. mehrere verschachtelte Fehler vorliegen) das Skript nochmal laufen lassen. Wenn alles senkrecht ist sieht die Meldung am Ende so aus:
                            Nothing to do, your installed version is the recommended one.
                            Also 2x 'nothing to do'.
                            (2x aber nur, wenn die Empfehlung aus dem iobroker herausgelesen werden konnte. Das funktioniert aber nicht immer, für Multihost-Setups z.B. nur für das Hauptsystem)
                            Meinungen? Anregungen? Wünsche?
                            Wer da tiefer einsteigen möchte und vielleicht selber kochen möchte:
                            https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
                            sissiwupS
                            sissiwupS
                            sissiwup
                            #121
                            eine Suche über alle Dateien kann lange dauern ...
                            Vlt. ist es hier sinnvoller eine positiv-Liste anzugeben? Ich habe mich beholfen mit einen weitern Ausschluss (/mnt)
                            if [[ "$VERNODE" != "v$NODERECOM" ]] && [[ "$NODERECOM" == [[:digit:]]*.[[:digit:]]*.[[:digit:]]* ]];
                            then
                                     echo -e "\nYou are running nodejs $VERNODE. Do you want to install recommended version $NODERECOM? ";
                                     echo -e "\nPress <y> to continue or any other key to quit";
                                     read -r -s -n 1 char;
                                     if
                                             [[ "$char" = "y" ]] || [[ "$char" = "Y" ]]
                                     then
                                             echo "Trying to fix your installation now. Please be patient."
                                             # Finding nodesource.gpg or nodesource.key and deleting. Current key is pulled in later.
                                             $SUDOX rm "$($SUDOX find / \( -path /proc -o -path /dev -o -path /sys -o -path /lost+found -o -path /mnt \) -prune -o -name nodesource.[gk]* -print)";
                                             # Deleting nodesource.list Will be recreated later.
                                             $SUDOX rm /etc/apt/sources.list.d/nodesource.lis*;
                                     else
                                             echo "We are not fixing your installation. Exiting.";
                                     exit;
                                     fi;
                            fi;
                            Wer doch als root arbeiten möchte Zeile 82-86 löschen :
                             77 if [ -f "$DOCKER" ];
                             78 then
                             79         echo "Fixing Docker is not supported, please update your Docker Container";
                             80         unset LC_ALL;
                             81         exit 1;
                             82         elif [ "$(id -u)" -eq 0 ];
                             83                  then
                             84                          echo -e "This script must not be run as root! \nPlease use your standard user!"
                             85         unset LC_ALL;
                             86         exit 1;
                             87 fi;
                            MfG
                            Sissi
                            1 CCU3 1 CCU2-Gateway 1 LanGateway 1 Pi-Gateway 1 I7 für ioBroker/MySQL
                            Thomas BraunT HomoranH 3 Antworten Letzte Antwort
                            -1
                            • sissiwupS sissiwup
                              then
                                       if
                                       then
                                       else
                                       exit;
                                       fi;
                              fi;
                               78 then
                               80         unset LC_ALL;
                               81         exit 1;
                               83                  then
                               85         unset LC_ALL;
                               86         exit 1;
                               87 fi;
                              Thomas BraunT
                              Thomas BraunT
                              #122
                              @sissiwup sagte in iob node fix - Skript:
                              Es gibt keinen Grund dafür.
                                then
                                         if
                                         then
                                         else
                                         exit;
                                         fi;
                                fi;
                                 78 then
                                 80         unset LC_ALL;
                                 81         exit 1;
                                 83                  then
                                 85         unset LC_ALL;
                                 86         exit 1;
                                 87 fi;
                                #123
                                die gibt es nicht!
                                  then
                                           if
                                           then
                                           else
                                           exit;
                                           fi;
                                  fi;
                                   78 then
                                   80         unset LC_ALL;
                                   81         exit 1;
                                   83                  then
                                   85         unset LC_ALL;
                                   86         exit 1;
                                   87 fi;
                                  Thomas BraunT
                                  Thomas BraunT
                                  #124
                                  Nein, beide Codepassagen sind genauso richtig und bedürfen keiner Anpassung.
                                  AlexAtHomeA 1 Antwort Letzte Antwort
                                    AlexAtHomeA
                                    AlexAtHomeA
                                    AlexAtHome
                                    #125
                                    @thomas-braun Vielen Dank für das Script, es hat mir gerade das Leben sehr einfach gemacht (Upgrade von NodeJS 16.20.2 auf 18.18.0). Worked like a charm :-)
                                    • ofri2607O
                                      ofri2607O
                                      ofri2607
                                      #126
                                      @Thomas-Braun
                                      auch von meiner Seite einen herzlichen Dank; war wirklich easy und problemlos.
                                      Beide Systeme 1x master und 1x slave (beides Raspi 4 mit bullseye) von v18.17.1 auf 18.18.0
                                      Den master hatte ich vor einiger Zeit entsprechend deinem HowTo gemacht, aber die notwendigen Änderungen (31.08.2023) noch nicht; hier script laufen lassen und danach sudo apt update && sudo apt upgrade.
                                      Der slave ist relativ neu frisch aufgesetzt, hier hatte das script ein downgrade auf 18.17.0 gemacht und anschließend selbstständig die 18.18.0 installiert.
                                      Ich denke, alles genauso, wie von dir geplant und gewollt.
                                      • ofri2607O ofri2607
                                        @Thomas-Braun
                                        Thomas BraunT
                                        Thomas BraunT
                                        #127
                                        @ofri2607 sagte in iob node fix - Skript:
                                        Ja, so soll das.
                                        sissiwupS 1 Antwort Letzte Antwort
                                          Ja, so soll das.
                                          sissiwupS
                                          sissiwupS
                                          sissiwup
                                          #128
                                          bei mir kommt under debian:
                                          N: Das Laden der konfigurierten Datei »main/binary-i386/Packages« wird übersprungen, da das Depot »https://deb.nodesource.com/node_18.x nodistro InRelease« die Architektur »i386« nicht unterstützt.
                                          Das kann man lösen durch:
                                          deb [arch=amd64 signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x nodistro main
                                          Also konkrete Angabe der Architektur. Vlt. hat ja auch ein anderer das Problem...
                                          MfG
                                          Sissi
                                          33.2k
                                          84.3k
