  4. iob node fix - Skript
198 Beiträge 34 Kommentatoren 73.4k Aufrufe 37 Beobachtet
  • teletapiT teletapi
    Funktioniert ganz klasse
    Hab das heute mal drüber laufen lassen und das Update auf die 18.18.0 gemacht
    ioBroker nodejs fixer 2023-09-20
    Recommended nodejs-version is: 18.18.0
    Checking your installation now. Please be patient!
    Your current setup is:
    /usr/bin/nodejs v18.17.1
    /usr/bin/node v18.17.1
    /usr/bin/npm 9.6.7
    /usr/bin/npx 9.6.7
    /usr/bin/corepack 0.18.0
    We found these nodejs versions available for installation:
    nodejs:
    Installed: 18.17.1-deb-1nodesource1
    Candidate: 18.17.1-deb-1nodesource1
    Version table:
    *** 18.17.1-deb-1nodesource1 500
    500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
    12.22.12~dfsg-1~deb11u4 500
    500 http://security.debian.org/debian-security bullseye-security/main ar m64 Packages
    12.22.12~dfsg-1~deb11u3 500
    500 http://deb.debian.org/debian bullseye/main arm64 Packages
    Nothing to do - Your installation is using the correct paths.
    You are running nodejs v18.17.1. Do you want to install recommended version 18.1 8.0?
    Press <y> to continue or any other key to quit
    Trying to fix your installation now. Please be patient.
    Waiting for ioBroker to shut down - Give me a minute...
    *** These repos are active on your system:
    Hit:1 http://deb.debian.org/debian bullseye InRelease
    Get:2 http://deb.debian.org/debian bullseye-updates InRelease [44.1 kB]
    Get:3 http://security.debian.org/debian-security bullseye-security InRelease [48 .4 kB]
    Get:4 http://archive.raspberrypi.org/debian bullseye InRelease [23.6 kB]
    Hit:5 https://repos.influxdata.com/debian stable InRelease
    Get:6 https://apt.grafana.com stable InRelease [5984 B]
    Get:7 http://archive.raspberrypi.org/debian bullseye/main armhf Packages [314 kB ]
    Get:8 http://archive.raspberrypi.org/debian bullseye/main arm64 Packages [308 kB ]
    Fetched 744 kB in 1s (498 kB/s)
    Reading package lists... Done
    *** Installing ca-certificates, curl and gnupg, just in case they are missing.
    *** Creating new /etc/apt/sources.list.d/nodesource.list and pinning source
    deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node _18.x nodistro main
    Package: nodejs
    Pin: origin deb.nodesource.com
    Pin-Priority: 1001
    *** These repos are active after the adjustments:
    Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:6 https://apt.grafana.com stable InRelease
    Get:7 https://deb.nodesource.com/node_18.x nodistro InRelease [12.1 kB]
    Get:8 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages [5262 B]
    Get:9 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages [5267 B]
    Fetched 22.7 kB in 2s (13.8 kB/s)
    Installing the recommended nodejs version now!
    We tried our best to fix your nodejs. Please run iob diag again to verify.
    *** RESTARTING ioBroker NOW! ***
    Please refresh or restart your browser in a few moments.
    pi@iobroker:~ $ sudo apt update && sudo apt upgrade
    OK:1 http://security.debian.org/debian-security bullseye-security InRelease
    OK:2 http://deb.debian.org/debian bullseye InRelease
    OK:3 http://archive.raspberrypi.org/debian bullseye InRelease
    OK:4 http://deb.debian.org/debian bullseye-updates InRelease
    OK:5 https://repos.influxdata.com/debian stable InRelease
    OK:6 https://apt.grafana.com stable InRelease
    OK:7 https://deb.nodesource.com/node_18.x nodistro InRelease
    Aktualisierung für 1 Paket verfügbar. Führen Sie »apt list --upgradable« aus, um es anzuzeigen.
    Paketaktualisierung (Upgrade) wird berechnet… Fertig
    nodejs
    1 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
    Es müssen 28,7 MB an Archiven heruntergeladen werden.
    Nach dieser Operation werden 859 kB Plattenplatz zusätzlich benutzt.
    Möchten Sie fortfahren? [J/n] J
    Holen:1 https://deb.nodesource.com/node_18.x nodistro/main arm64 nodejs arm64 18 .18.0-1nodesource1 [28,7 MB]
    Es wurden 28,7 MB in 2 s geholt (11,5 MB/s).
    Changelogs werden gelesen... Fertig
    (Lese Datenbank ... 117382 Dateien und Verzeichnisse sind derzeit installiert.)
    Vorbereitung zum Entpacken von .../nodejs_18.18.0-1nodesource1_arm64.deb ...
    Detected old npm client, removing...
    Entpacken von nodejs (18.18.0-1nodesource1) über (18.17.1-deb-1nodesource1) ...
    nodejs (18.18.0-1nodesource1) wird eingerichtet ...
    Trigger für man-db (2.9.4-2) werden verarbeitet ...
    pi@iobroker:~ $ iobroker stop
    pi@iobroker:~ $ iobroker fix
    library: loaded
    Library version=2022-12-09
    Welcome to the ioBroker installation fixer!
    Script version: 2023-04-02
    You might need to enter your password a couple of times.
    Installing prerequisites (1/5)
    OK:3 http://deb.debian.org/debian bullseye-updates InRelease
    OK:4 http://archive.raspberrypi.org/debian bullseye InRelease
    Installed gcc-c++
    Checking ioBroker user and directory permissions (2/5)
    Check and cleanup npm temporary directories (3/5)
    Done.
    Database maintenance (4/5)
    Checking for uncompressed JSONL databases... This might take a while!
    Compressing /opt/iobroker/iobroker-data/states.jsonl
    Compressing /opt/iobroker/iobroker-data/objects.jsonl
    Compressed 2 JSONL files. Done
    Checking autostart (5/5)
    Enabling autostart...
    Autostart enabled!
    Your installation was fixed successfully
    Run iobroker start to start ioBroker again!
    pi@iobroker:~ $ sudo reboot
    Und dann mal IOB Diag laufen lassen
    Skript v.2023-06-20
    *** BASE SYSTEM ***
       Static hostname: iobroker
             Icon name: computer
            Machine ID: a9f1eae0dc5a48ddbf0e2a62c2227673
               Boot ID: 30ea7719d00c47c7b8b94d2a5e591316
      Operating System: Debian GNU/Linux 11 (bullseye)
                Kernel: Linux 6.1.21-v8+
          Architecture: arm64
    Model           : Raspberry Pi 4 Model B Rev 1.5
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : arm64
    Systemuptime and Load:
     15:14:39 up 5 min,  1 user,  load average: 1.41, 1.78, 0.91
    CPU threads: 4
    Raspberry only:
    throttled=0x0
    Other values than 0x0 hint to temperature/voltage problems
    temp=46.7'C
    volt=0.9360V
    *** Time and Time Zones ***
                   Local time: Fri 2023-09-22 15:14:39 CEST
               Universal time: Fri 2023-09-22 13:14:39 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:            7.8G        2.3G        4.0G        1.0M        1.5G        5.4G
    Swap:            99M          0B         99M
    Total:          7.9G        2.3G        4.1G
             7811 M total memory
             2318 M used memory
             3162 M active memory
              446 M inactive memory
             4041 M free memory
               71 M buffer memory
             1380 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    *** FILESYSTEM ***
    /dev/root      ext4       59G  9.8G   47G  18% /
    devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
    tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
    tmpfs          tmpfs     1.6G  1.2M  1.6G   1% /run
    /dev/sda1      vfat      255M   31M  225M  13% /boot
    tmpfs          tmpfs     782M   16K  782M   1% /run/user/1000
    [Fri Sep 22 15:08:53 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:13:A5:D1 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=tty1 root=PARTUUID=2c0392e1-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
    [Fri Sep 22 15:08:55 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
    [Fri Sep 22 15:08:55 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
    [Fri Sep 22 15:08:56 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
    TARGET  SOURCE    FSTYPE OPTIONS
    /       /dev/sda2 ext4   rw,noatime
    `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    1.9G    /var/
    1.2G    /var/log/journal/a9f1eae0dc5a48ddbf0e2a62c2227673
    1.2G    /var/log
    477M    /var/lib
    Archived and active journals take up 1.1G in the file system.
    /opt/iobroker/backups:
    1.2G    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    334M    /opt/iobroker/iobroker-data/
    181M    /opt/iobroker/iobroker-data/files
    71M     /opt/iobroker/iobroker-data/backup-objects
    62M     /opt/iobroker/iobroker-data/node-red/node_modules
    33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
    21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
    14M     /opt/iobroker/iobroker-data/objects.jsonl
    8.5M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js
    8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.18.0
    /usr/bin/node           v18.18.0
    /usr/bin/npm            9.8.1
    /usr/bin/npx            9.8.1
    nodejs:
      Installed: 18.18.0-1nodesource1
      Candidate: 18.18.0-1nodesource1
      Version table:
     *** 18.18.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    No configuration change needed.
    Multihost discovery server: disabled
    Discovery authentication:   enabled
    Persistent activation:      disabled
    Objects:                    jsonl on 127.0.0.1
    States:                     jsonl on 127.0.0.1
    Core adapters versions
    js-controller:  5.0.12
    admin:          6.10.2
    javascript:     7.1.4
    Adapters from github:   2
    Adapter State
    + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
      system.adapter.alias-manager.0          : alias-manager         : iobroker                                 - disabled
    + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
    + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
    + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
    + system.adapter.energiefluss.0           : energiefluss          : iobroker                                 -  enabled
    + system.adapter.energiefluss.1           : energiefluss          : iobroker                                 -  enabled
    + system.adapter.fritzdect.0              : fritzdect             : iobroker                                 -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 18701
    + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 12001
    + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 -  enabled, port: 12010
    + system.adapter.hm-rpc.3                 : hm-rpc                : iobroker                                 -  enabled, port: 0
    + system.adapter.hue-extended.0           : hue-extended          : iobroker                                 -  enabled
      system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
    + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
    + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
    + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
    + system.adapter.jarvis.0                 : jarvis                : iobroker                                 -  enabled
    + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
      system.adapter.modbus.0                 : modbus                : iobroker                                 - disabled
    + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.net-tools.0              : net-tools             : iobroker                                 -  enabled
    + system.adapter.node-red.0               : node-red              : iobroker                                 -  enabled, port: 1880, bind: 0.0.0.0
    + system.adapter.nuki.0                   : nuki                  : iobroker                                 -  enabled
    + system.adapter.opendtu.0                : opendtu               : iobroker                                 -  enabled
    + system.adapter.panasonic-viera.0        : panasonic-viera       : iobroker                                 -  enabled
    + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
    + system.adapter.rpi2.0                   : rpi2                  : iobroker                                 -  enabled
    + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 192.168.178.82, run as: admin
      system.adapter.smartmeter.0             : smartmeter            : iobroker                                 - disabled
      system.adapter.smartmeter.1             : smartmeter            : iobroker                                 - disabled
    + system.adapter.socketio.0               : socketio              : iobroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
    + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1886, bind: 0.0.0.0
    + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): beta
    Installed ioBroker-Instances
    Used repository: beta
    Adapter    "admin"        : 6.10.2   , installed 6.10.2
    Adapter    "alexa2"       : 3.25.2   , installed 3.25.2
    Adapter    "alias-manager": 1.2.6    , installed 1.2.6
    Adapter    "backitup"     : 2.8.1    , installed 2.8.1
    Adapter    "cloud"        : 4.4.1    , installed 4.4.1
    Adapter    "discovery"    : 4.0.0    , installed 4.0.0
    Adapter    "fritzdect"    : 2.3.1    , installed 2.3.1
    Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
    Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
    Adapter    "hue-extended" : 2.0.0    , installed 2.0.0
    Adapter    "ical"         : 1.13.3   , installed 1.13.3
    Adapter    "info"         : 2.0.0    , installed 2.0.0
    Adapter    "iot"          : 2.0.11   , installed 2.0.11
    Adapter    "jarvis"       : 3.1.8    , installed 3.1.9-beta.3
    Adapter    "javascript"   : 7.1.4    , installed 7.1.4
    Controller "js-controller": 5.0.12   , installed 5.0.12
    Adapter    "modbus"       : 5.0.11   , installed 5.0.11
    Adapter    "mqtt"         : 5.0.0    , installed 5.0.0
    Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
    Adapter    "node-red"     : 4.0.3    , installed 4.0.3
    Adapter    "nuki"         : 1.6.0    , installed 1.6.0
    Adapter    "opendtu"      : 0.1.7    , installed 0.1.7
    Adapter    "panasonic-viera": 2.0.0  , installed 2.0.0
    Adapter    "smartmeter"   : 3.3.4    , installed 3.3.4
    Adapter    "socketio"     : 6.5.5    , installed 6.5.5
    Adapter    "sonoff"       : 2.5.7    , installed 2.5.7
    Adapter    "telegram"     : 1.16.0   , installed 1.16.0
    Adapter    "web"          : 6.1.2    , installed 6.1.2
    Adapter    "ws"           : 2.5.5    , installed 2.5.5
    Objects and States
    Objects:        9883
    States:         9205
    Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:2 http://deb.debian.org/debian bullseye InRelease
    Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:5 https://apt.grafana.com stable InRelease
    Hit:6 https://repos.influxdata.com/debian stable InRelease
    Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 192.168.178.82:9092     0.0.0.0:*               LISTEN      1001       26915      2000/io.nuki.0
    tcp        0      0 192.168.178.82:2001     0.0.0.0:*               LISTEN      1001       15234      1458/io.hm-rpc.3
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13125      576/sshd: /usr/sbin
    tcp        0      0 192.168.178.82:18701    0.0.0.0:*               LISTEN      1001       17085      1315/io.hm-rpc.0
    tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       20213      1851/io.jarvis.0
    tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       18734      1558/io.sonoff.0
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      116        12257      561/mosquitto
    tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       17070      1235/node-red
    tcp        0      0 192.168.178.82:12010    0.0.0.0:*               LISTEN      1001       17212      1359/io.hm-rpc.2
    tcp        0      0 192.168.178.82:12001    0.0.0.0:*               LISTEN      1001       17960      1342/io.hm-rpc.1
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          13138      538/cupsd
    tcp        0      0 192.168.178.82:8087     0.0.0.0:*               LISTEN      1001       23788      2139/io.simple-api.
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       15479      654/iobroker.js-con
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       16497      654/iobroker.js-con
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          13137      538/cupsd
    tcp6       0      0 :::3000                 :::*                    LISTEN      117        16568      653/grafana
    tcp6       0      0 :::8086                 :::*                    LISTEN      999        13159      548/influxd
    tcp6       0      0 :::8084                 :::*                    LISTEN      1001       25135      2161/io.socketio.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       21930      1708/io.web.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       14838      954/io.admin.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          13127      576/sshd: /usr/sbin
    tcp6       0      0 :::1883                 :::*                    LISTEN      116        12258      561/mosquitto
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14601      461/dhcpcd
    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          13146      617/cups-browsed
    udp        0      0 0.0.0.0:49885           0.0.0.0:*                           108        13036      402/avahi-daemon: r
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13034      402/avahi-daemon: r
    udp6       0      0 :::56039                :::*                                108        13037      402/avahi-daemon: r
    udp6       0      0 :::546                  :::*                                0          13201      461/dhcpcd
    udp6       0      0 :::5353                 :::*                                108        13035      402/avahi-daemon: r
    2023-09-22 15:14:07.195  - info: admin.0 (954) ==> Connected system.user.admin from ::ffff:192.168.178.63
    2023-09-22 15:14:09.020  - info: host.iobroker Updating repository "beta" under "http://download.iobroker.net/sources-dist-latest.json"
    iob diag has finished.
    #118
    @teletapi
    Das schaut gut aus.
    Von welcher Version bist du denn gekommen? Der Auszug ist ja vermutlich von einem zweiten Durchlauf des Skripts.
    teletapiT 1 Antwort Letzte Antwort
      @teletapi
      Das schaut gut aus.
      teletapiT Offline
      teletapiT Offline
      teletapi
      schrieb am zuletzt editiert von teletapi
      #119
      auf dem Produktivsystem hab ich das script nur einmal laufen lassen, danach dann direkt sudo apt update && sudo apt upgrade danach war alles bereits sauber erledigt
      Zum schluss nochmal dein script drüber laufen lassen und beide "Nothing to do" am Schluss
      Ich bin von der node.js 18.17.1
      Nachdem ich per sudo apt update && sudo apt upgrade nicht auf die 18.18.0 kam hab ich dein script mit einer sicherungs Festplatte am RPI getestet nachdem das wunderbar funktioniert hat hab ich das dann auf meinem produktiv System ebenfalls gemacht
        #120
        @teletapi
        Danke, das hilft!
          Hinweis vorab: Wenn das Skript ausgeführt wurde und sein Werk getan hat, funktionieren Updates innerhalb der nodejs-Version wieder wie gehabt über
          sudo apt update
          sudo apt full-upgrade
          Erneutes ausführen des Skriptes bei einem gewöhnlichen Update ist nicht notwendig!
          __
          BETA-TESTING
          (Nachdem das Skript jetzt auch offiziell Teil vom ioBroker in Form des Kommandos iob nodejs-update geworden ist wird hier im Thread an Beta-Versionen gewerkelt. Mit den üblichen Gefahren. Es kann hier Code in jeglicher Form und Lauffähigkeit vorgefunden werden. Bitte hier nur 'todesmutige' Tester mit Backup für den Fall der Fälle. )
          Ich habe mich ja lange dagegen ausgesprochen, so grundlegende Dinge wie die Installation von nodejs über windige 'Toolz' machen zu lassen. Aber sei es wie es ist, hier ist ein Skript, das verfummelte nodejs-Installationen wieder weitgehend gerade ziehen sollte und auch das aktuelle Repository für nodejs in der Version von nodesource inkl. der Schlüssel usw. installiert.
          Flugs heruntergeladen und ausgeführt per
          curl https://raw.githubusercontent.com/Grothesk242/iob_diag/main/iob_node_update.sh > iob_node_update
          chmod 744 iob_node_update
          ./iob_node_update
          Optional kann man dem Skript auch einen nodejs-Zweig mit geben, dann wird die letzte Version aus diesem Zweig installiert.
          ./iob_node_update XX
          Wobei der Zweig natürlich existent sein muss. Zur Zeit ist also XX = 18 , 20 oder 22 möglich.
          Noch ein Hinweis: Gegebenenfalls (wenn z. B. mehrere verschachtelte Fehler vorliegen) das Skript nochmal laufen lassen. Wenn alles senkrecht ist sieht die Meldung am Ende so aus:
          Nothing to do, your installation is using the correct paths.
          Nothing to do, your installed version is the recommended one.
          Also 2x 'nothing to do'.
          (2x aber nur, wenn die Empfehlung aus dem iobroker herausgelesen werden konnte. Das funktioniert aber nicht immer, für Multihost-Setups z.B. nur für das Hauptsystem)
          Meinungen? Anregungen? Wünsche?
          Wer da tiefer einsteigen möchte und vielleicht selber kochen möchte:
          https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
          sissiwupS Offline
          sissiwupS Offline
          sissiwup
          #121
          eine Suche über alle Dateien kann lange dauern ...
          Vlt. ist es hier sinnvoller eine positiv-Liste anzugeben? Ich habe mich beholfen mit einen weitern Ausschluss (/mnt)
          if [[ "$VERNODE" != "v$NODERECOM" ]] && [[ "$NODERECOM" == [[:digit:]]*.[[:digit:]]*.[[:digit:]]* ]];
          then
                   echo -e "\nYou are running nodejs $VERNODE. Do you want to install recommended version $NODERECOM? ";
                   echo -e "\nPress <y> to continue or any other key to quit";
                   read -r -s -n 1 char;
                   if
                           [[ "$char" = "y" ]] || [[ "$char" = "Y" ]]
                   then
                           echo "Trying to fix your installation now. Please be patient."
                           # Finding nodesource.gpg or nodesource.key and deleting. Current key is pulled in later.
                           $SUDOX rm "$($SUDOX find / \( -path /proc -o -path /dev -o -path /sys -o -path /lost+found -o -path /mnt \) -prune -o -name nodesource.[gk]* -print)";
                           # Deleting nodesource.list Will be recreated later.
                           $SUDOX rm /etc/apt/sources.list.d/nodesource.lis*;
                   else
                           echo "We are not fixing your installation. Exiting.";
                   exit;
                   fi;
          fi;
          Wer doch als root arbeiten möchte Zeile 82-86 löschen :
           77 if [ -f "$DOCKER" ];
           78 then
           79         echo "Fixing Docker is not supported, please update your Docker Container";
           80         unset LC_ALL;
           81         exit 1;
           82         elif [ "$(id -u)" -eq 0 ];
           83                  then
           84                          echo -e "This script must not be run as root! \nPlease use your standard user!"
           85         unset LC_ALL;
           86         exit 1;
           87 fi;
          MfG
          Sissi
          1 CCU3 1 CCU2-Gateway 1 LanGateway 1 Pi-Gateway 1 I7 für ioBroker/MySQL
          Thomas BraunT HomoranH 3 Antworten Letzte Antwort
          -1
          • sissiwupS sissiwup
            then
                     if
                     then
                     else
                     exit;
                     fi;
            fi;
             78 then
             80         unset LC_ALL;
             81         exit 1;
             83                  then
             85         unset LC_ALL;
             86         exit 1;
             87 fi;
            #122
            @sissiwup sagte in iob node fix - Skript:
            Es gibt keinen Grund dafür.
              then
                       if
                       then
                       else
                       exit;
                       fi;
              fi;
               78 then
               80         unset LC_ALL;
               81         exit 1;
               83                  then
               85         unset LC_ALL;
               86         exit 1;
               87 fi;
              #123
              die gibt es nicht!
                then
                         if
                         then
                         else
                         exit;
                         fi;
                fi;
                 78 then
                 80         unset LC_ALL;
                 81         exit 1;
                 83                  then
                 85         unset LC_ALL;
                 86         exit 1;
                 87 fi;
                #124
                Nein, beide Codepassagen sind genauso richtig und bedürfen keiner Anpassung.
                AlexAtHomeA 1 Antwort Letzte Antwort
                  AlexAtHomeA Offline
                  AlexAtHomeA Offline
                  AlexAtHome
                  #125
                  @thomas-braun Vielen Dank für das Script, es hat mir gerade das Leben sehr einfach gemacht (Upgrade von NodeJS 16.20.2 auf 18.18.0). Worked like a charm :-)
                  • ofri2607O Online
                    ofri2607O Online
                    ofri2607
                    #126
                    @Thomas-Braun
                    auch von meiner Seite einen herzlichen Dank; war wirklich easy und problemlos.
                    Beide Systeme 1x master und 1x slave (beides Raspi 4 mit bullseye) von v18.17.1 auf 18.18.0
                    Den master hatte ich vor einiger Zeit entsprechend deinem HowTo gemacht, aber die notwendigen Änderungen (31.08.2023) noch nicht; hier script laufen lassen und danach sudo apt update && sudo apt upgrade.
                    Der slave ist relativ neu frisch aufgesetzt, hier hatte das script ein downgrade auf 18.17.0 gemacht und anschließend selbstständig die 18.18.0 installiert.
                    Ich denke, alles genauso, wie von dir geplant und gewollt.
                    • ofri2607O ofri2607
                      @Thomas-Braun
                      #127
                      @ofri2607 sagte in iob node fix - Skript:
                      Ja, so soll das.
                      sissiwupS 1 Antwort Letzte Antwort
                        Ja, so soll das.
                        sissiwupS Offline
                        sissiwupS Offline
                        sissiwup
                        #128
                        bei mir kommt under debian:
                        N: Das Laden der konfigurierten Datei »main/binary-i386/Packages« wird übersprungen, da das Depot »https://deb.nodesource.com/node_18.x nodistro InRelease« die Architektur »i386« nicht unterstützt.
                        Das kann man lösen durch:
                        deb [arch=amd64 signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x nodistro main
                        Also konkrete Angabe der Architektur. Vlt. hat ja auch ein anderer das Problem...
                        MfG
                        Sissi
                          #129
                          @sissiwup wie passt denn
                          arch=amd64
                          zu
                          Architektur »i386«
                          • Thomas BraunT Online
                            #130
                            @sissiwup
                            Die Meldung fängt man sich nur ein, wenn (in der Vergangenheit) falsche Pakete (für die falsche Architektur) installiert wurden. Bei 'ordentlichen' Installationen passiert das nicht.
                              @sissiwup
                              sissiwupS Offline
                              sissiwupS Offline
                              sissiwup
                              #131
                              @thomas-braun sagte in iob node fix - Skript:
                              @sissiwup
                              oder wenn man multi-arch support aktiviert hat (für nicht 64-bit Softwarepakete)
                              dpkg --print-foreign-architectures
                              i386
                              Wer das nicht braucht:
                              dpkg --remove-architecture i386
                              MfG
                              Sissi
                                @sissiwup
                                i386
                                #132
                                @sissiwup gib mal die Langfassung von iob diag
                                  sudo apt update
                                  __
                                  BETA-TESTING
                                  ./iob_node_update
                                  reutli
                                  schrieb am zuletzt editiert von reutli
                                  #133
                                  warum kommt denn nach erfolgreichem update auf 18.18.0 und erneutem Aufruf trotzdem nochmals die Abfrage ob man auf 18.18.0 updaten möchte?
                                  ioBroker nodejs fixer 2023-09-24
                                  No recommendation for nodejs version found on your system. We recommend to install latest version from nodejs v18 tree.
                                  /usr/bin/npm 		9.8.1
                                  /usr/bin/npx 		9.8.1
                                  /usr/bin/corepack 	0.19.0
                                  nodejs:
                                    Version table:
                                  You are running nodejs v18.18.0. Do you want to install recommended version v.18 ?
                                  pi@iobroker:/opt/iobroker $
                                  es kommt zwar die Meldung
                                  aber eins drüber meint er, er könnte von .18 auf .18 updaten...
                                  iobroker in Debian-VM auf Proxmox Server (Ryzen 7 / 32GB / 1TB NVMe SSD) als Master - mehrere Raspberry Pis (3+4) als Slaves. InfluxDB V2 und Grafana auf LXC.
                                  *Wer freundlich ist, dem wird freundlich geholfen *
                                  • R reutli
                                    /usr/bin/npm 		9.8.1
                                    /usr/bin/npx 		9.8.1
                                    nodejs:
                                      Version table:
                                    #134
                                    @reutli sagte in iob node fix - Skript:
                                    Weil für dein System keine empfohlene Version ausgelesen werden kann und daher kein Abgleich dagegen möglich ist.
                                    Ist das z. B. ein Multihost-Slave?
                                    R 1 Antwort Letzte Antwort
                                    • F Offline
                                      firebowl
                                      #135
                                      Sehr geile Sache das Script. :)
                                      Leider aktualisiert es bei mir die Version nicht auf 18.18.0
                                      Es wird erkannt, dass sie vorhanden ist und installiert werde soll.
                                      Nach dem Lauf ist aber weiterhin die 18.17.1 installiert. :(
                                      R Thomas BraunT 2 Antworten Letzte Antwort
                                      • F firebowl
                                        reutli
                                        #136
                                        @firebowl
                                        Die Ausgabe zeigen hilft, damit einem geholfen wird...
                                          reutli
                                          #137
                                          Ja exakt, ist ein Slave
