DMP8624 -> iobroker
Request Antwort Json print so ?
; Read the status JSON payload
U
gw=StatusNET#Gateway
print %gw% -
ok, dann mal ran an Lehrbrief 1 -> Übung 1 :-)
Button Websend einfügen, Websend ausführen, Antwort Request in Var schreiben.
1 und 2 sollte gehen, bei 3 haperts noch ;-)
>D ; Ralla gw="" Vmax=60 Cmax=24 v=0 V=0 c=0 C=0 sw=0 SW=0 ; Ralla WS=0 rV="01060000" vV="" rC="01060001" vC="" rSW="01060002000" vSW="" >BS +>subscribe V, cmnd/%topic%/tvolt +>subscribe C, cmnd/%topic%/tampere +>subscribe SW, cmnd/%topic%/tpow >B smlj=0 ->sensor53 r ; Ralla ; Request Status information. The response will trigger the `U` section +>status 5 >R smlj=0 >S if upsecs>30 then smlj=1 endif >W bu(SW "DPM Ein" "DPM Aus") ; Ralla bu(WS "WebSend" "Websend") nm(0.0 60.0 0.01 V "DPM Ausgang (V)" 200 2) nm(0.0 24.0 0.01 C "DPM Ausgang (A)" 200 2) >T sw=DC#sSwitch v=DC#sVolt c=DC#sCur if ((chg[sw]>0) and (SW!=sw)) then SW=sw +>publish stat/%topic%/RESULT {"tpow":%0sw%} endif if ((chg[v]>0) and (V!=v)) then V=v +>publish stat/%topic%/RESULT {"tvolt":%2v%} endif if ((chg[c]>0) and (C!=c)) then C=c +>publish stat/%topic%/RESULT {"tampere":%2c%} endif if chg[V]>0 then if V>Vmax then V=Vmax endif if V<0 then V=0 endif vV=rV+sb(hx((V*100)) 4 4) +>publish stat/%topic%/RESULT {"tvolt":%2V%} sml(1 3 vV) endif if chg[C]>0 then if C>Cmax then C=Cmax endif if C<0 then C=0 endif vC=rC+sb(hx((C*1000)) 4 4) +>publish stat/%topic%/RESULT {"tampere":%2C%} sml(1 3 vC) endif if ((chg[SW]>0) then vSW=rSW+s(SW) +>publish stat/%topic%/RESULT {"tpow":%0SW%} sml(1 3 vSW) endif ; Ralla if ((chg[WS]>0) then =>WebSend [192.168.2.28] /cm?cmnd=status&2010 ;Org Ralla IO http://192.168.2.28/cm?cmnd=status%2010 print Ralla websend endif ; Ralla ; Read the status JSON payload >U gw=StatusNET#Gateway ;gw=StatusSNS,MT175,Bezug_aktuell print %gw% print Ralla gw >M 1 +1,3,m,16,9600,DC,1,2,010300000001,010300010001,010300020001,010310010001,010310020001 1,010302SSssxxxx@i0:100,Spannung (set),V,sVolt,2 1,010302SSssxxxx@i1:1000,Strom (set),A,sCur,2 1,010302SSssxxxx@i2:1,Ausgang (set),,sSwitch,0 1,010302SSssxxxx@i3:100,Spannung (disp),V,dVolt,2 1,010302SSssxxxx@i4:1000,Strom (disp),A,vCur,2 #
UsectionB
+>status 5
Dann sollte ja U print ausgeführt sein, ist aber nicht, dann kann nur WebSend falsch sein -
UsectionB
+>status 5
UsectionB
+>status 5
@ralla66 ,
hier für dich falls du es noch nicht kennst.edit: Werde ich heute testen ob ich den aktuellen Verbrauch vom hichi holen kann wenn du nicht dazu kommst.
heute morgen war um 0:30 Feierabend :-)
den Link lese ich heute Abend,
habe boot error am ESP nach dem flashen / script einfügen, war eventuell schon übermüdet
meine .bin mit USE_WEBSEND_RESPONSE aktiviert lief nicht sauber.
kannst du mal bitte die .bin hochladen mit Zeile 471 USE_WEBSEND_RESPONSE aktiviert
Wäre cool wenn du mit testes, macht das debuggen einfacher.Danke
erste Antwort, bekomme ein WEbQuery zurück
17:35:28.308 SCR: performs "WebSend [192.168.2.28] /cm?cmnd=status&2010" 17:35:29.951 MQT: stat/tasmota_3CECBB/RESULT = {"WebQuery":{"Status":{"Module":18,"DeviceName":"SMA","FriendlyName":["SMA"],"Topic":"tasmota_D35C9C","ButtonTopic":"0","Power":0,"PowerOnState":3,"LedState":1,"LedMask":"FFFF","SaveData":1,"SaveState":1,"SwitchTopic":"0","SwitchMode":[0,0,0,0,0,0,0,0],"ButtonRetain":0,"SwitchRetain":0,"SensorRetain":0,"PowerRetain":0,"InfoRetain":0,"StateRetain":0}}} 17:35:29.955 MQT: stat/tasmota_3CECBB/RESULT = {"WebSend":"Done"} 17:35:29.957 Ralla websend>D ; Ralla gw="" Vmax=60 Cmax=24 v=0 V=0 c=0 C=0 sw=0 SW=0 ; Ralla WS=0 rV="01060000" vV="" rC="01060001" vC="" rSW="01060002000" vSW="" >BS +>subscribe V, cmnd/%topic%/tvolt +>subscribe C, cmnd/%topic%/tampere +>subscribe SW, cmnd/%topic%/tpow >B smlj=0 ->sensor53 r ; Ralla ; Request Status information. The response will trigger the `U` section +>status 5 >R smlj=0 >S if upsecs>30 then smlj=1 endif >W bu(SW "DPM Ein" "DPM Aus") ; Ralla bu(WS "WebSend" "Websend") nm(0.0 60.0 0.01 V "DPM Ausgang (V)" 200 2) nm(0.0 24.0 0.01 C "DPM Ausgang (A)" 200 2) >T sw=DC#sSwitch v=DC#sVolt c=DC#sCur if ((chg[sw]>0) and (SW!=sw)) then SW=sw +>publish stat/%topic%/RESULT {"tpow":%0sw%} endif if ((chg[v]>0) and (V!=v)) then V=v +>publish stat/%topic%/RESULT {"tvolt":%2v%} endif if ((chg[c]>0) and (C!=c)) then C=c +>publish stat/%topic%/RESULT {"tampere":%2c%} endif if chg[V]>0 then if V>Vmax then V=Vmax endif if V<0 then V=0 endif vV=rV+sb(hx((V*100)) 4 4) +>publish stat/%topic%/RESULT {"tvolt":%2V%} sml(1 3 vV) endif if chg[C]>0 then if C>Cmax then C=Cmax endif if C<0 then C=0 endif vC=rC+sb(hx((C*1000)) 4 4) +>publish stat/%topic%/RESULT {"tampere":%2C%} sml(1 3 vC) endif if ((chg[SW]>0) then vSW=rSW+s(SW) +>publish stat/%topic%/RESULT {"tpow":%0SW%} sml(1 3 vSW) endif ; Ralla if ((chg[WS]>0) then =>WebSend [192.168.2.28] /cm?cmnd=status&2010 res=WebSend [192.168.2.28] /cm?cmnd=status&2010 ;Org Ralla IO http://192.168.2.28/cm?cmnd=status%2010 print Ralla websend endif ; Ralla ; Read the status JSON payload >U gw=StatusNET#Gateway ;gw=StatusSNS,MT175,Bezug_aktuell print %gw% print Ralla gw >M 1 +1,3,m,16,9600,DC,1,2,010300000001,010300010001,010300020001,010310010001,010310020001 1,010302SSssxxxx@i0:100,Spannung (set),V,sVolt,2 1,010302SSssxxxx@i1:1000,Strom (set),A,sCur,2 1,010302SSssxxxx@i2:1,Ausgang (set),,sSwitch,0 1,010302SSssxxxx@i3:100,Spannung (disp),V,dVolt,2 1,010302SSssxxxx@i4:1000,Strom (disp),A,vCur,2 # -
17:35:28.308 SCR: performs "WebSend [192.168.2.28] /cm?cmnd=status&2010" 17:35:29.951 MQT: stat/tasmota_3CECBB/RESULT = {"WebQuery":{"Status":{"Module":18,"DeviceName":"SMA","FriendlyName":["SMA"],"Topic":"tasmota_D35C9C","ButtonTopic":"0","Power":0,"PowerOnState":3,"LedState":1,"LedMask":"FFFF","SaveData":1,"SaveState":1,"SwitchTopic":"0","SwitchMode":[0,0,0,0,0,0,0,0],"ButtonRetain":0,"SwitchRetain":0,"SensorRetain":0,"PowerRetain":0,"InfoRetain":0,"StateRetain":0}}} 17:35:29.955 MQT: stat/tasmota_3CECBB/RESULT = {"WebSend":"Done"} 17:35:29.957 Ralla websend>D ; Ralla gw="" Vmax=60 Cmax=24 v=0 V=0 c=0 C=0 sw=0 SW=0 ; Ralla WS=0 rV="01060000" vV="" rC="01060001" vC="" rSW="01060002000" vSW="" >BS +>subscribe V, cmnd/%topic%/tvolt +>subscribe C, cmnd/%topic%/tampere +>subscribe SW, cmnd/%topic%/tpow >B smlj=0 ->sensor53 r ; Ralla ; Request Status information. The response will trigger the `U` section +>status 5 >R smlj=0 >S if upsecs>30 then smlj=1 endif >W bu(SW "DPM Ein" "DPM Aus") ; Ralla bu(WS "WebSend" "Websend") nm(0.0 60.0 0.01 V "DPM Ausgang (V)" 200 2) nm(0.0 24.0 0.01 C "DPM Ausgang (A)" 200 2) >T sw=DC#sSwitch v=DC#sVolt c=DC#sCur if ((chg[sw]>0) and (SW!=sw)) then SW=sw +>publish stat/%topic%/RESULT {"tpow":%0sw%} endif if ((chg[v]>0) and (V!=v)) then V=v +>publish stat/%topic%/RESULT {"tvolt":%2v%} endif if ((chg[c]>0) and (C!=c)) then C=c +>publish stat/%topic%/RESULT {"tampere":%2c%} endif if chg[V]>0 then if V>Vmax then V=Vmax endif if V<0 then V=0 endif vV=rV+sb(hx((V*100)) 4 4) +>publish stat/%topic%/RESULT {"tvolt":%2V%} sml(1 3 vV) endif if chg[C]>0 then if C>Cmax then C=Cmax endif if C<0 then C=0 endif vC=rC+sb(hx((C*1000)) 4 4) +>publish stat/%topic%/RESULT {"tampere":%2C%} sml(1 3 vC) endif if ((chg[SW]>0) then vSW=rSW+s(SW) +>publish stat/%topic%/RESULT {"tpow":%0SW%} sml(1 3 vSW) endif ; Ralla if ((chg[WS]>0) then =>WebSend [192.168.2.28] /cm?cmnd=status&2010 res=WebSend [192.168.2.28] /cm?cmnd=status&2010 ;Org Ralla IO http://192.168.2.28/cm?cmnd=status%2010 print Ralla websend endif ; Ralla ; Read the status JSON payload >U gw=StatusNET#Gateway ;gw=StatusSNS,MT175,Bezug_aktuell print %gw% print Ralla gw >M 1 +1,3,m,16,9600,DC,1,2,010300000001,010300010001,010300020001,010310010001,010310020001 1,010302SSssxxxx@i0:100,Spannung (set),V,sVolt,2 1,010302SSssxxxx@i1:1000,Strom (set),A,sCur,2 1,010302SSssxxxx@i2:1,Ausgang (set),,sSwitch,0 1,010302SSssxxxx@i3:100,Spannung (disp),V,dVolt,2 1,010302SSssxxxx@i4:1000,Strom (disp),A,vCur,2 #@ralla66 ,
Hichi:
>D aktuell=0 >B ->sensor53 r >T aktuell=MT175#P http("192.168.xxx.xxx" "/cm?cmnd=script>Aktuell="+s(aktuell)) >M 1 +1,3,s,16,9600,MT175 1,77070100010800ff@1000,E_in,kWh,E_in,1 1,77070100010801ff@1000,E_in_HT,kWh,E_in_HT,1 1,77070100010802ff@1000,E_in_NT,kWh,E_in_NT,1 1,77070100020800ff@1000,E_out,kWh,E_out,1 1,77070100100700ff@1,P,W,P,18 1,77070100000009ff@#,Server_ID,,Server_ID,0 #DPM8624:
>D Aktuell=0 >W Aktuelle Leistung{m} %0Aktuell% W -
@ralla66 ,
Hichi:
>D Aktuell=0 >W Aktuelle Leistung{m} %0Aktuell% WHabe die Data, %20 weglassen
18:10:08.057 SCR: performs "WebSend [192.168.2.28] /cm?cmnd=status 10" 18:10:08.622 MQT: stat/tasmota_3CECBB/RESULT = {"WebQuery":{"StatusSNS":{"Time":"2023-09-20T18:10:08","MT175":{"Geräte_ID":"","Verbrauch_Gesamt":37714,"Bezug_Tarif_1":37714.412,"Bezug_Tarif_2":0,"Netzeinspeisung":0,"Lieferung_Tarif_1":0,"Lieferung_Tarif_2":0,"Bezug_aktuell":9,"Phase_L1":17,"Phase_L2":-71,"Phase_L3":62}}}} 18:10:08.626 MQT: stat/tasmota_3CECBB/RESULT = {"WebSend":"Done"} 18:10:08.628 Ralla websend; Ralla if ((chg[WS]>0) then ;10 = show connected sensor information (replaces 'Status 8') =>WebSend [192.168.2.28] /cm?cmnd=status 10 print Ralla websend endifYeep :-)
jetzt noch zerlegen, Ideen ? mit U ?Teste mal mit Hichi ob Daten kommen
ok hast gewonnen :-)
wie machen wir weiter ?
Ein DPM Script für alle IR Leseköpfe bauen, also den Status SNS komplett abholen.
Dann den Bezugswert Filtern. Habe ja kein Hichi. Dieser Wert kann ja anders benannt sein,
Dann Script cleanen und die erste Beta 1.0 bauen.
Weiter dann mit der Berechnung Bezug -> DPM setzt V und A ?Gruß Ralla
Nachtrag, Leseköpfe ( Status SNS ) Json einlesen, dann würden auch Shelly PM gehen.
@ralla66 ,
ja schau mal ob du den Wert rausfiltern kannst.Mit http("192.168.xxx.xxx" "/cm?cmnd=script>Variablename=Wert) kannst du jeder Variable im Script einen Wert verpassen.
Mit Variable=http("192.168.xxx.xxx" "/cm?cmnd=script?Variablename) kannst du jeden Wert anfordern. -
@ralla66 ,
Mit Variable=http("192.168.xxx.xxx" "/cm?cmnd=script?Variablename) kannst du jeden Wert anfordern.Ok ich teste mal mit Bezug Aktuell,
dann brauche ich noch ein Ausgabefenster in der WEB UI mit Wert Bezug Aktuell
Bzw 2, Bezug Zähler und DPM Ausgang Watt
Du kannst das schneller :-)
Ziel ist ja erreicht, Feierabend ist heute früher.
Lehrbrief 1, Übung 1 mit Sehr Gut bestanden ;-) -
@ralla66 ,
so ?
>D ; Ralla Bezug Aktuell=0 >T ; alle 10 sec Telemetrieperiode eingestellt ; Ralla ; jeder Variable im Script einen Wert zuweisen http("192.168.2.28" "/cm?cmnd=script>Bezug Aktuell=Wert) print Bezug Aktuell %Bezug Aktuell% -
@ralla66 ,
http("192.168.2.28" "/cm?cmnd=script>Bezug Aktuell=Wert")mit dem Befehl sendest du den Wert an 192.168.2.28.
Im 192.168.2.28 muss es eine Variable Bezug Aktuell geben.ah ja, so ne Art send to
dann ist ja das hier vom Zähler ESP holen, jezz is klar :-)
Ne doch nich, der Pfad im Zähler ESP ist doch StatusSNS->MT175.>Bezug Aktuell->Wert.
Ich brauche ne Pause ------------------------->19:43:19.058 MQT: stat/tasmota_3CECBB/RESULT = {"WebQuery":{"StatusSNS":{"Time":"2023-09-20T19:43:16","MT175":{"Geräte_ID":"","Verbrauch_Gesamt":37715,"Bezug_Tarif_1":37714.529,"Bezug_Tarif_2":0,"Netzeinspeisung":0,"Lieferung_Tarif_1":0,"Lieferung_Tarif_2":0,"Bezug_aktuell":93,"Phase_L1":16,"Phase_L2":6,"Phase_L3":70}}}}>D ; Ralla Bezug Aktuell=0;Mit Variable=http("192.168.xxx.xxx" "/cm?cmnd=script?Variablename) kannst du ;jeden Wert anfordern Bezug Aktuell=http("192.168.2.28" "/cm?cmnd=script?Bezug_Aktuell) print Bezug Aktuell %Bezug Aktuell% -
@ralla66 ,
da musst du machenT
aktuell= MT175#Bezug AktuellDann kannst du aktuell senden oder anfordern.
Schaue in meiner Lösung von der vorherigen Seite.ok, Danke, heute nicht mehr.
Sackt langsam, das ist im Zähler ESP.
Das war bei mir nicht geplant, immer schwierig für Beginner wenn auf der Tasmota Seite
das SML angepasst werden muß. Einfacher wäre es nur in der DPM Script Var Deklaration
ein Paar Werte einzugeben. Das ist ja für mich schon sehr schwer.
