  4. Support Adapter Energiefluss-erweitert
vis
4.6k Beiträge 206 Kommentatoren 6.5m Aufrufe 178 Beobachtet
  • SKBS SKB
    @wal Korrekt. Changelog steht ja oben ;)
    WalW Offline
    WalW Offline
    Wal
    #1340
    @skb ,
    habe den Adapter deinstalliert und die Alpha 16 installiert.
    Der Adapter startet ohne Probleme, danach ein Backup eingespielt und er stürtzt ab.
        "basic": {
            "enable_grid": true,
            "enable_animation": false,
            "enable_area_catch": true,
            "enable_config_icon": true,
            "enable_last_id": false,
            "enable_icon_proxy": false,
            "height": 540,
            "width": 600,
            "styles": "",
            "font": {
                "family": "\"Arial\", sans-serif",
                "size": "20",
                "color": "",
                "fill": "",
                "align": "middle"
            "rect": {
                "height": 100,
                "width": 100,
                "corners": 10
            "circle": {
                "radius": 50
            "elm": {
                "stroke_width": 5,
                "color": "",
                "fill": "",
                "pos_x": 50,
                "pos_y": 50
            "icon": {
                "height": 24,
                "width": 24,
                "color": ""
        "calculation": {
            "battery": {
                "dod": 0,
                "capacity": 0,
                "percent": -1,
                "charge": -1,
                "charge_prop": false,
                "charge_kw": false,
                "discharge": -1,
                "discharge_prop": false,
                "discharge_kw": false
            "consumption": {
                "production": [
                    -1
                "production_kw": false,
                "gridFeed": -1,
                "gridFeed_kw": false,
                "gridFeed_prop": false,
                "gridConsume": -1,
                "gridConsume_kw": false,
                "gridConsume_prop": false,
                "batteryCharge": -1,
                "batteryCharge_kw": false,
                "batteryCharge_prop": false,
                "batteryDischarge": -1,
                "batteryDischarge_kw": false,
                "batteryDischarge_prop": false
        "animation": {
            "stroke": "#ffce4a",
            "stroke_dasharray": "10 17 10 17 10  72",
            "stroke_width": "6",
            "animation_duration": "2000",
            "stroke_linecap": "round",
            "animation_timing_function": "linear"
        "animation_configuration": {
            "dots": "3",
            "distance": "17",
            "length": "10"
        "line": {
            "stroke_width": "8",
            "stroke": "#000000"
        "elements": {
            "2": {
                "position": 0,
                "type": "text",
                "subType": "datasource",
                "id": 2,
                "pos_x": 49,
                "pos_y": 41,
                "color": "none",
                "fill": "rgb(195, 255, 81)",
                "font_family": "Arial, sans-serif",
                "font_size": 18,
                "align": "middle",
                "text": "ID 2",
                "unit": "kW",
                "source": 2,
                "source_option": -1,
                "source_display": "value",
                "shadow": "",
                "threshold": 0,
                "calculate_kw": true,
                "convert": false,
                "decimal_places": 2,
                "action": "none",
                "subtract": [
                    -1
                "frame": "_overlay"
            "5": {
                "position": 0,
                "type": "rect",
                "id": 5,
                "rx": 10,
                "height": 100,
                "width": 100,
                "pos_x": 1,
                "pos_y": 1,
                "fill": "none",
                "color": "rgb(195, 255, 81)",
                "stroke": 2,
                "shadow": "rgba(0,0,0,0.7)",
                "frame": "_overlay",
                "fill_value": null,
                "fill_type": "percent",
                "fill_direction": 90,
                "fill_max": null,
                "border_value": null,
                "border_type": -1,
                "border_direction": "cw",
                "border_style": "round",
                "border_max": null,
                "border_reverse_value": null,
                "border_reverse": false,
                "border_start": 180,
                "source": 2,
                "threshold": 0
            "6": {
                "position": 0,
                "type": "icon",
                "id": "6",
                "icon": "mdi:solar-panel",
                "width": 24,
                "height": 24,
                "pos_x": "39",
                "pos_y": "5",
                "shadow": "",
                "source": -1,
                "threshold": 0,
                "action": "none"
            "7": {
                "position": 1,
                "type": "rect",
                "id": 7,
                "rx": 10,
                "height": 100,
                "width": 100,
                "pos_x": 221,
                "pos_y": 221,
                "fill": "none",
                "color": "rgb(0, 209, 255)",
                "stroke": 2,
                "fill_value": null,
                "fill_max": null,
                "border_type": -1,
                "border_max": null,
                "source": 1,
                "threshold": 0
            "9": {
                "position": 1,
                "type": "text",
                "id": 9,
                "pos_x": 271,
                "pos_y": 263,
                "color": "none",
                "fill": "rgb(0, 209, 255)",
                "font_size": 18,
                "align": "middle",
                "text": "ID 9",
                "unit": "kW",
                "source": 1,
                "shadow": "",
                "threshold": 0,
                "convert": false,
                "action": "none",
                "subtract": [
                    -1
                "frame": "_overlay"
            "10": {
                "position": 2,
                "type": "text",
                "id": 10,
                "pos_x": 51,
                "pos_y": 74,
                "color": "none",
                "font_size": 14,
                "align": "middle",
                "text": "Produktion",
                "shadow": "",
                "frame": "_overlay"
            "11": {
                "position": 3,
                "type": "text",
                "id": 11,
                "pos_x": 271,
                "pos_y": 297,
                "color": "none",
                "font_size": 14,
                "align": "middle",
                "text": "Gesamt",
                "shadow": "",
                "frame": "_overlay"
            "12": {
                "position": 1,
                "type": "icon",
                "id": "12",
                "icon": "mdi:house-city",
                "width": 24,
                "height": 24,
                "pos_x": "259",
                "pos_y": "227",
                "shadow": "",
                "source": -1,
                "threshold": 0,
                "action": "none"
            "14": {
                "position": 2,
                "type": "rect",
                "id": 14,
                "rx": 10,
                "height": 100,
                "width": 100,
                "pos_x": 1,
                "pos_y": 301,
                "fill": "none",
                "color": "rgb(255, 0, 0)",
                "stroke": 2,
                "fill_value": null,
                "fill_max": null,
                "border_type": -1,
                "border_max": null,
                "source": 0,
                "threshold": 0
            "19": {
                "position": 4,
                "type": "text",
                "id": 19,
                "pos_x": 50,
                "pos_y": 343,
                "color": "none",
                "fill": "rgb(255, 0, 0)",
                "font_size": 18,
                "align": "middle",
                "text": "ID 19",
                "unit": "kW",
                "source": 0,
                "shadow": "",
                "threshold": 0,
                "convert": true,
                "action": "none",
                "subtract": [
                    -1
                "frame": "_overlay"
            "20": {
                "position": 2,
                "type": "icon",
                "id": "20",
                "icon": "mdi:electricity-from-grid",
                "width": 24,
                "height": 24,
                "pos_x": "38",
                "pos_y": "307",
                "shadow": "",
                "source": -1,
                "threshold": 0,
                "action": "none"
            "21": {
                "position": 5,
                "type": "text",
                "id": 21,
                "pos_x": 50,
                "pos_y": 377,
                "color": "none",
                "font_size": 14,
                "align": "middle",
                "text": "Netz",
                "shadow": "",
                "frame": "_overlay"
            "22": {
                "position": 3,
                "type": "rect",
                "id": 22,
                "rx": 10,
                "height": 100,
                "width": 100,
                "pos_x": 121,
                "pos_y": 1,
                "fill": "none",
                "color": "rgb(255, 206, 74)",
                "stroke": 2,
                "fill_value": null,
                "fill_max": null,
                "border_type": -1,
                "border_max": null,
                "source": -1,
                "threshold": 0
            "24": {
                "position": 6,
                "type": "text",
                "id": 24,
                "pos_x": 171,
                "pos_y": 77,
                "color": "none",
                "fill": "rgb(255, 206, 74)",
                "font_size": 14,
                "align": "middle",
                "text": "Proxmox",
                "shadow": "",
                "frame": "_overlay"
            "26": {
                "position": 7,
                "type": "text",
                "id": 26,
                "pos_x": 171,
                "pos_y": 43,
                "color": "none",
                "font_size": 18,
                "align": "middle",
                "text": "ID 26",
                "unit": "W",
                "source": 3,
                "shadow": "",
                "threshold": 0,
                "calculate_kw": false,
                "convert": false,
                "decimal_places": 0,
                "action": "none",
                "subtract": [
                    -1
                "frame": "_overlay"
            "27": {
                "position": 4,
                "type": "rect",
                "id": 27,
                "rx": 10,
                "height": 100,
                "width": 100,
                "pos_x": 241,
                "pos_y": 1,
                "fill": "none",
                "stroke": 2,
                "fill_value": null,
                "fill_max": null,
                "border_type": -1,
                "border_max": null,
                "source": -1,
                "threshold": 0
            "28": {
                "position": 8,
                "type": "text",
                "id": 28,
                "pos_x": 291,
                "pos_y": 77,
                "color": "none",
                "font_size": 14,
                "align": "middle",
                "text": "Tiefkühltruhe",
                "shadow": "",
                "frame": "_overlay"
            "29": {
                "position": 9,
                "type": "text",
                "id": 29,
                "pos_x": 291,
                "pos_y": 43,
                "color": "none",
                "font_size": 18,
                "align": "middle",
                "text": "ID 29",
                "unit": "W",
                "source": 4,
                "shadow": "",
                "threshold": 0,
                "convert": false,
                "action": "none",
                "subtract": [
                    -1
                "frame": "_overlay"
            "31": {
                "position": 5,
                "type": "rect",
                "id": 31,
                "rx": 10,
                "height": 100,
                "width": 100,
                "pos_x": 363,
                "pos_y": 1,
                "fill": "none",
                "stroke": 2,
                "fill_value": null,
                "fill_max": null,
                "border_type": -1,
                "border_max": null,
                "source": -1,
                "threshold": 0
            "32": {
                "position": 10,
                "type": "text",
                "id": 32,
                "pos_x": 413,
                "pos_y": 77,
                "color": "none",
                "font_size": 14,
                "align": "middle",
                "text": "Fernseher",
                "shadow": "",
                "frame": "_overlay"
            "33": {
                "position": 11,
                "type": "text",
                "id": 33,
                "pos_x": 413,
                "pos_y": 43,
                "color": "none",
                "font_size": 18,
                "align": "middle",
                "text": "ID 33",
                "unit": "W",
                "source": 5,
                "shadow": "",
                "threshold": 0,
                "convert": false,
                "action": "none",
                "subtract": [
                    -1
                "frame": "_overlay"
            "35": {
                "position": 3,
                "type": "icon",
                "id": "35",
                "width": 24,
                "height": 24,
                "pos_x": "158",
                "pos_y": "6",
                "shadow": "",
                "source": -1,
                "threshold": 0,
                "action": "none"
            "36": {
                "position": 4,
                "type": "icon",
                "id": "36",
                "width": 24,
                "height": 24,
                "pos_x": "278",
                "pos_y": "7",
                "shadow": "",
                "source": -1,
                "threshold": 0,
                "action": "none"
            "37": {
                "position": 5,
                "type": "icon",
                "id": "37",
                "width": 24,
                "height": 24,
                "pos_x": "401",
                "pos_y": "6",
                "shadow": "",
                "source": -1,
                "threshold": 0,
                "action": "none"
        "defs": {
            "path_5_7": {
                "type": "def",
                "id": "path_5_7",
                "d": "M31 102  V 131.8   V 236 A 15 15 0 0 0 46 251  H 220",
                "startSlot": "bottom_left",
                "endSlot": "left_top"
            "path_7_22": {
                "type": "def",
                "id": "path_7_22",
                "d": "M251 220  V 196.4 A 15 15 0 0 0 236 181.4  H 166 A 15 15 0 0 1 151 166.4   V 102",
                "startSlot": "top_left",
                "endSlot": "bottom_left"
            "path_7_27": {
                "type": "def",
                "id": "path_7_27",
                "d": "M271 220  V 102",
                "startSlot": "top",
            "path_7_31": {
                "type": "def",
                "id": "path_7_31",
                "d": "M291 220  V 196.4 A 15 15 0 0 1 306 181.4  H 378 A 15 15 0 0 0 393 166.4  V 102",
                "startSlot": "top_right",
            "path_14_7": {
                "type": "def",
                "id": "path_14_7",
                "d": "M71 300  V 294.2   V 285 A 14 14 0 0 1 85 271  H 220",
                "endSlot": "left"
        "lines": {
            "line_path_5_7": {
                "type": "line",
                "id": "line_path_5_7",
                "href": "#path_5_7",
                "color": "rgb(0, 0, 0)",
                "shadow": ""
            "line_path_7_22": {
                "type": "line",
                "id": "line_path_7_22",
                "href": "#path_7_22",
                "shadow": ""
            "line_path_7_27": {
                "type": "line",
                "id": "line_path_7_27",
                "href": "#path_7_27",
                "shadow": ""
            "line_path_7_31": {
                "type": "line",
                "id": "line_path_7_31",
                "href": "#path_7_31",
                "shadow": ""
            "line_path_14_7": {
                "type": "line",
                "id": "line_path_14_7",
                "href": "#path_14_7",
                "shadow": ""
        "animations": {
            "anim_path_5_7": {
                "type": "animation",
                "id": "anim_path_5_7",
                "source": 2,
                "threshold": 0,
                "animation_properties": "positive",
                "animation_option": false,
                "dots": 0,
                "duration": 0,
                "power": 0,
                "animation_type": -1
            "anim_path_7_22": {
                "id": "anim_path_7_22",
                "source": 3,
                "threshold": 0,
                "dots": 0,
                "duration": 0,
                "power": 0,
            "anim_path_7_27": {
                "id": "anim_path_7_27",
                "source": 4,
                "threshold": 0,
                "dots": 0,
                "duration": 0,
                "power": 0,
            "anim_path_7_31": {
                "id": "anim_path_7_31",
                "source": 5,
                "threshold": 0,
                "dots": 0,
                "duration": 0,
                "power": 0,
            "anim_path_14_7": {
                "id": "anim_path_14_7",
                "color": "rgb(255, 15, 67)",
                "source": 0,
                "threshold": 0,
                "dots": 0,
                "duration": 0,
                "power": 0,
        "datasources": {
            "0": {
                "source": "sonoff.0.Haus.Stromzähler.MT175_P",
                "alias": "Netzverbrauch"
            "1": {
                "source": "0_userdata.0.Stromverbrauch_aktuell",
                "alias": "Gesamtverbrauch"
            "2": {
                "source": "sonoff.0.Haus.Balkonkraftwerk.ENERGY_Power",
                "alias": "Balkonkraftwerk"
            "3": {
                "source": "sonoff.0.Test.Steckdose3.ENERGY_Power",
                "alias": "Proxmox"
            "4": {
                "source": "sonoff.0.Test.Steckdose.ENERGY_Power",
                "alias": "Tiefkühltruhe"
            "5": {
                "source": "sonoff.0.Test.Steckdose2.ENERGY_Power",
                "alias": "Fernseher"
    Walter
    DoorIO-Adapter
    SKBS 1 Antwort Letzte Antwort
    • WalW Wal
      @skb ,
          "basic": {
              "height": 540,
              "width": 600,
              "styles": "",
              "font": {
                  "size": "20",
                  "color": "",
                  "fill": "",
                  "align": "middle"
              "rect": {
                  "height": 100,
                  "width": 100,
                  "corners": 10
              "circle": {
                  "radius": 50
              "elm": {
                  "stroke_width": 5,
                  "color": "",
                  "fill": "",
                  "pos_x": 50,
                  "pos_y": 50
              "icon": {
                  "height": 24,
                  "width": 24,
                  "color": ""
          "calculation": {
              "battery": {
                  "dod": 0,
                  "capacity": 0,
                  "percent": -1,
                  "charge": -1,
                  "charge_kw": false,
                  "discharge": -1,
              "consumption": {
                  "production": [
                      -1
                  "gridFeed": -1,
                  "gridConsume": -1,
          "animation": {
              "dots": "3",
              "distance": "17",
              "length": "10"
          "line": {
              "stroke": "#000000"
          "elements": {
              "2": {
                  "position": 0,
                  "type": "text",
                  "id": 2,
                  "pos_x": 49,
                  "pos_y": 41,
                  "color": "none",
                  "font_size": 18,
                  "align": "middle",
                  "text": "ID 2",
                  "unit": "kW",
                  "source": 2,
                  "shadow": "",
                  "threshold": 0,
                  "convert": false,
                  "action": "none",
                  "subtract": [
                      -1
                  "frame": "_overlay"
              "5": {
                  "position": 0,
                  "type": "rect",
                  "id": 5,
                  "rx": 10,
                  "height": 100,
                  "width": 100,
                  "pos_x": 1,
                  "pos_y": 1,
                  "fill": "none",
                  "stroke": 2,
                  "fill_value": null,
                  "fill_max": null,
                  "border_type": -1,
                  "border_max": null,
                  "source": 2,
                  "threshold": 0
              "6": {
                  "position": 0,
                  "type": "icon",
                  "id": "6",
                  "width": 24,
                  "height": 24,
                  "pos_x": "39",
                  "pos_y": "5",
                  "shadow": "",
                  "source": -1,
                  "threshold": 0,
                  "action": "none"
              "7": {
                  "position": 1,
                  "type": "rect",
                  "id": 7,
                  "rx": 10,
                  "height": 100,
                  "width": 100,
                  "pos_x": 221,
                  "pos_y": 221,
                  "fill": "none",
                  "stroke": 2,
                  "fill_value": null,
                  "fill_max": null,
                  "border_type": -1,
                  "border_max": null,
                  "source": 1,
                  "threshold": 0
              "9": {
                  "position": 1,
                  "type": "text",
                  "id": 9,
                  "pos_x": 271,
                  "pos_y": 263,
                  "color": "none",
                  "font_size": 18,
                  "align": "middle",
                  "text": "ID 9",
                  "unit": "kW",
                  "source": 1,
                  "shadow": "",
                  "threshold": 0,
                  "convert": false,
                  "action": "none",
                  "subtract": [
                      -1
                  "frame": "_overlay"
              "10": {
                  "position": 2,
                  "type": "text",
                  "id": 10,
                  "pos_x": 51,
                  "pos_y": 74,
                  "color": "none",
                  "font_size": 14,
                  "align": "middle",
                  "shadow": "",
                  "frame": "_overlay"
              "11": {
                  "position": 3,
                  "type": "text",
                  "id": 11,
                  "pos_x": 271,
                  "pos_y": 297,
                  "color": "none",
                  "font_size": 14,
                  "align": "middle",
                  "text": "Gesamt",
                  "shadow": "",
                  "frame": "_overlay"
              "12": {
                  "position": 1,
                  "type": "icon",
                  "id": "12",
                  "width": 24,
                  "height": 24,
                  "pos_x": "259",
                  "pos_y": "227",
                  "shadow": "",
                  "source": -1,
                  "threshold": 0,
                  "action": "none"
              "14": {
                  "position": 2,
                  "type": "rect",
                  "id": 14,
                  "rx": 10,
                  "height": 100,
                  "width": 100,
                  "pos_x": 1,
                  "pos_y": 301,
                  "fill": "none",
                  "stroke": 2,
                  "fill_value": null,
                  "fill_max": null,
                  "border_type": -1,
                  "border_max": null,
                  "source": 0,
                  "threshold": 0
              "19": {
                  "position": 4,
                  "type": "text",
                  "id": 19,
                  "pos_x": 50,
                  "pos_y": 343,
                  "color": "none",
                  "font_size": 18,
                  "align": "middle",
                  "text": "ID 19",
                  "unit": "kW",
                  "source": 0,
                  "shadow": "",
                  "threshold": 0,
                  "convert": true,
                  "action": "none",
                  "subtract": [
                      -1
                  "frame": "_overlay"
              "20": {
                  "position": 2,
                  "type": "icon",
                  "id": "20",
                  "width": 24,
                  "height": 24,
                  "pos_x": "38",
                  "pos_y": "307",
                  "shadow": "",
                  "source": -1,
                  "threshold": 0,
                  "action": "none"
              "21": {
                  "position": 5,
                  "type": "text",
                  "id": 21,
                  "pos_x": 50,
                  "pos_y": 377,
                  "color": "none",
                  "font_size": 14,
                  "align": "middle",
                  "text": "Netz",
                  "shadow": "",
                  "frame": "_overlay"
              "22": {
                  "position": 3,
                  "type": "rect",
                  "id": 22,
                  "rx": 10,
                  "height": 100,
                  "width": 100,
                  "pos_x": 121,
                  "pos_y": 1,
                  "fill": "none",
                  "stroke": 2,
                  "fill_value": null,
                  "fill_max": null,
                  "border_type": -1,
                  "border_max": null,
                  "source": -1,
                  "threshold": 0
              "24": {
                  "position": 6,
                  "type": "text",
                  "id": 24,
                  "pos_x": 171,
                  "pos_y": 77,
                  "color": "none",
                  "font_size": 14,
                  "align": "middle",
                  "text": "Proxmox",
                  "shadow": "",
                  "frame": "_overlay"
              "26": {
                  "position": 7,
                  "type": "text",
                  "id": 26,
                  "pos_x": 171,
                  "pos_y": 43,
                  "color": "none",
                  "font_size": 18,
                  "align": "middle",
                  "text": "ID 26",
                  "unit": "W",
                  "source": 3,
                  "shadow": "",
                  "threshold": 0,
                  "convert": false,
                  "action": "none",
                  "subtract": [
                      -1
                  "frame": "_overlay"
              "27": {
                  "position": 4,
                  "type": "rect",
                  "id": 27,
                  "rx": 10,
                  "height": 100,
                  "width": 100,
                  "pos_x": 241,
                  "pos_y": 1,
                  "fill": "none",
                  "stroke": 2,
                  "fill_value": null,
                  "fill_max": null,
                  "border_type": -1,
                  "border_max": null,
                  "source": -1,
                  "threshold": 0
              "28": {
                  "position": 8,
                  "type": "text",
                  "id": 28,
                  "pos_x": 291,
                  "pos_y": 77,
                  "color": "none",
                  "font_size": 14,
                  "align": "middle",
                  "shadow": "",
                  "frame": "_overlay"
              "29": {
                  "position": 9,
                  "type": "text",
                  "id": 29,
                  "pos_x": 291,
                  "pos_y": 43,
                  "color": "none",
                  "font_size": 18,
                  "align": "middle",
                  "text": "ID 29",
                  "unit": "W",
                  "source": 4,
                  "shadow": "",
                  "threshold": 0,
                  "convert": false,
                  "action": "none",
                  "subtract": [
                      -1
                  "frame": "_overlay"
              "31": {
                  "position": 5,
                  "type": "rect",
                  "id": 31,
                  "rx": 10,
                  "height": 100,
                  "width": 100,
                  "pos_x": 363,
                  "pos_y": 1,
                  "fill": "none",
                  "stroke": 2,
                  "fill_value": null,
                  "fill_max": null,
                  "border_type": -1,
                  "border_max": null,
                  "source": -1,
                  "threshold": 0
              "32": {
                  "position": 10,
                  "type": "text",
                  "id": 32,
                  "pos_x": 413,
                  "pos_y": 77,
                  "color": "none",
                  "font_size": 14,
                  "align": "middle",
                  "shadow": "",
                  "frame": "_overlay"
              "33": {
                  "position": 11,
                  "type": "text",
                  "id": 33,
                  "pos_x": 413,
                  "pos_y": 43,
                  "color": "none",
                  "font_size": 18,
                  "align": "middle",
                  "text": "ID 33",
                  "unit": "W",
                  "source": 5,
                  "shadow": "",
                  "threshold": 0,
                  "convert": false,
                  "action": "none",
                  "subtract": [
                      -1
                  "frame": "_overlay"
              "35": {
                  "position": 3,
                  "type": "icon",
                  "id": "35",
                  "width": 24,
                  "height": 24,
                  "pos_x": "158",
                  "pos_y": "6",
                  "shadow": "",
                  "source": -1,
                  "threshold": 0,
                  "action": "none"
              "36": {
                  "position": 4,
                  "type": "icon",
                  "id": "36",
                  "width": 24,
                  "height": 24,
                  "pos_x": "278",
                  "pos_y": "7",
                  "shadow": "",
                  "source": -1,
                  "threshold": 0,
                  "action": "none"
              "37": {
                  "position": 5,
                  "type": "icon",
                  "id": "37",
                  "width": 24,
                  "height": 24,
                  "pos_x": "401",
                  "pos_y": "6",
                  "shadow": "",
                  "source": -1,
                  "threshold": 0,
                  "action": "none"
          "defs": {
              "path_5_7": {
                  "type": "def",
                  "id": "path_5_7",
              "path_7_22": {
                  "type": "def",
                  "id": "path_7_22",
              "path_7_27": {
                  "type": "def",
                  "id": "path_7_27",
                  "startSlot": "top",
              "path_7_31": {
                  "type": "def",
                  "id": "path_7_31",
              "path_14_7": {
                  "type": "def",
                  "id": "path_14_7",
                  "endSlot": "left"
          "lines": {
              "line_path_5_7": {
                  "type": "line",
                  "shadow": ""
              "line_path_7_22": {
                  "type": "line",
                  "shadow": ""
              "line_path_7_27": {
                  "type": "line",
                  "shadow": ""
              "line_path_7_31": {
                  "type": "line",
                  "shadow": ""
              "line_path_14_7": {
                  "type": "line",
                  "shadow": ""
          "animations": {
              "anim_path_5_7": {
                  "source": 2,
                  "threshold": 0,
                  "dots": 0,
                  "duration": 0,
                  "power": 0,
              "anim_path_7_22": {
                  "source": 3,
                  "threshold": 0,
                  "dots": 0,
                  "duration": 0,
                  "power": 0,
              "anim_path_7_27": {
                  "source": 4,
                  "threshold": 0,
                  "dots": 0,
                  "duration": 0,
                  "power": 0,
              "anim_path_7_31": {
                  "source": 5,
                  "threshold": 0,
                  "dots": 0,
                  "duration": 0,
                  "power": 0,
              "anim_path_14_7": {
                  "source": 0,
                  "threshold": 0,
                  "dots": 0,
                  "duration": 0,
                  "power": 0,
          "datasources": {
              "0": {
              "1": {
              "2": {
              "3": {
                  "alias": "Proxmox"
              "4": {
              "5": {
      SKBS Offline
      SKBS Offline
      SKB
      #1341
      @wal Welche Fehlermeldung kommt beim Absturz?
      WalW 1 Antwort Letzte Antwort
      • SKBS SKB
        WalW Offline
        WalW Offline
        Wal
        #1342
        @skb ,
        siehe Log den ich gepostet habe.
        Walter
        DoorIO-Adapter
        ArmilarA SKBS 2 Antworten Letzte Antwort
        • WalW Wal
          @skb ,
          ArmilarA Offline
          ArmilarA Offline
          Armilar
          Most Active Forum Testing
          #1343
          @wal
          @SKB
          energiefluss-erweitert.0
          2023-09-01 10:49:56.407	info	Requesting the following states: energiefluss-erweitert.0.configuration,mqtt.0.PV.Terrassendach.total.P_AC,sonoff.0.DZG_DWSB20_2H.DZG_Leistung_Aktuell,0_userdata.0.PV_Akku_Emulation.Akkustand,0_userdata.0.PV_Akku_Emulation.Leistung,shelly.0.shellypro3em#shellypro3em#1.EM0.TotalActivePower,0_userdata.0.Energiebilanz.Leistung.Verbrauch,sonoff.0.Kuehlschrank_Kueche.ENERGY_Power,sonoff.0.Waschmaschine.ENERGY_Power,sonoff.0.Geschirrspuelmaschine.ENERGY_Power,tuya.0.581550838caab5731891.5,sonoff.0.Mikrowelle.ENERGY_Power,sonoff.0.Kuehlschrank_HW.ENERGY_Power,sonoff.0.HW_LED_Unterbau.ENERGY_Power,0_userdata.0.Energiebilanz.Leistung.Verbrauch_HW,0_userdata.0.Energiebilanz.Leistung.Verbrauch_Kueche,0_userdata.0.Energiebilanz.Leistung.Verbrauch_Buero,sonoff.0.Airbowl_Buero.ENERGY_Power,sonoff.0.Buero_Schreibtisch.ENERGY_Power,sonoff.0.Buero_Server.ENERGY_Power,sonoff.0.Pool.ENERGY_Power,sonoff.0.Kaffemaschine.ENERGY_Power,0_userdata.0.Energiebilanz.Leistung.Verbrauch_Rest,sonoff.0.Fritteuse.ENERGY_Power,pvforecast.0.summary.power.now,0_userdata.0.Stromzaehler.Aktuell.Bezug,0_userdata.0.Stromzaehler.Aktuell.EinspeisungWh,0_userdata.0.Stromzaehler.Aktuell.Bedarf,mqtt.0.PV.Terrassendach.total.YieldDay,0_userdata.0.Energiebilanz.Leistung.Verbrauch_Esszimmer,shelly.0.SHDM-1#F3C218#1.lights.Power,sonoff.0.Esszimmer_Schreibtisch.ENERGY_Power,mqtt.0.PV.Terrassendach.Terrassendach.ch0.P_AC,mqtt.0.PV.Terrassendach.Terassendach2.ch0.P_AC,followthesun.0.current.altitude,followthesun.0.current.azimuth,0_userdata.0.Waermepumpe.Tag.Verbrauch_Total,0_userdata.0.Astro.01 - sunrise,0_userdata.0.Astro.07 - sunset,0_userdata.0.Zeit.Aktuell,mqtt.0.PV.Terrassendach.Terrassendach.ch0.active_PowerLimit,mqtt.0.PV.Terrassendach.Terassendach2.ch0.active_PowerLimit,sonoff.0.Pool.ENERGY_Today,sonoff.0.Kuehlschrank_Kueche.ENERGY_Today,sonoff.0.Kaffemaschine.ENERGY_Today,sonoff.0.Buero_Server.ENERGY_Today,sonoff.0.Buero_Schreibtisch.ENERGY_Today,sonoff.0.Esszimmer_Schreibtisch.ENERGY_Today,0_userdata.0.Energiebilanz.Leistung.Verbrauch_Flur,sonoff.0.Treppenbeleuchtung_EG.Virtual_Energy_Power,shelly.0.SHSW-L#3C6105E43DD2#1.Relay0.Virtual_Energy_Power,sonoff.0.Licht_Flur_Vorne_EG.Virtual_Energy_Power,shelly.0.SHSW-L#84CCA8AE12A1#1.Relay0.Virtual_Energy_Power,0_userdata.0.Energiebilanz.Leistung.Verbrauch_Naehzimmer,0_userdata.0.Energiebilanz.Leistung.Verbrauch_GaesteWC,sonoff.0.Geschirrspuelmaschine.ENERGY_Today,sonoff.0.Waschmaschine.ENERGY_Today,sonoff.0.Kuehlschrank_HW.ENERGY_Today,sonoff.0.HW_LED_Unterbau.ENERGY_Today
          2023-09-01 10:49:56.406	info	Configuration loaded!
          2023-09-01 10:49:56.271	info	Adapter started. Loading config!
          2023-09-01 10:49:56.231	info	starting. Version 0.0.2-alpha.16 (non-npm: SKB-CGN/ioBroker.energiefluss-erweitert#b7d0fd6df1e7181a917b26c4e162aa1fe8c54078) in /opt/iobroker/node_modules/iobroker.energiefluss-erweitert, node: v18.17.1, js-controller: 5.0.12
          2023-09-01 10:49:24.528	info	terminating
          2023-09-01 10:49:24.026	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
          2023-09-01 10:49:24.025	info	terminating
          2023-09-01 10:49:24.025	info	Cleared interval for relative values!
          2023-09-01 10:49:24.023	error	Cannot read properties of undefined (reading 'log')
          2023-09-01 10:49:24.023	error	TypeError: Cannot read properties of undefined (reading 'log') at EnergieflussErweitert.getConfig (/opt/iobroker/node_modules/iobroker.energiefluss-erweitert/main.js:1148:19)
          2023-09-01 10:49:24.022	error	unhandled promise rejection: Cannot read properties of undefined (reading 'log')
          2023-09-01 10:49:24.022	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          2023-09-01 10:49:23.961	warn	The adapter could not find the state 'shelly.0.SHSW-L#84CCA8AE12A1#1.Relay0.Virtual_Energy_Power'! Please review your configuration of the adapter!
          2023-09-01 10:49:23.959	warn	The adapter could not find the state 'shelly.0.SHSW-L#3C6105E43DD2#1.Relay0.Virtual_Energy_Power'! Please review your configuration of the adapter!
          2023-09-01 10:49:23.893	info	Adapter started. Loading config!
          2023-09-01 10:49:23.857	info	starting. Version 0.0.2-alpha.16 (non-npm: SKB-CGN/ioBroker.energiefluss-erweitert#b7d0fd6df1e7181a917b26c4e162aa1fe8c54078) in /opt/iobroker/node_modules/iobroker.energiefluss-erweitert, node: v18.17.1, js-controller: 5.0.12
          habe den ioBroker auch mal neu gestartet. Folgendes steht im log - Habe auch den Eindruck, dass sich nicht alle Datasources sauber aktualisieren...
          • ArmilarA Armilar
            @wal
            @SKB
            SKBS Offline
            SKBS Offline
            SKB
            #1344
            @armilar sagte in Test Adapter Energiefluss-erweitert v0.0.x GitHub/Latest:
            @wal
            @SKB
            Ist ja auch so, da die States nicht gefunden werden.
            EDIT: Habe den Fehler mit dem "Log" beseitigt. Bitte nochmal drüber installieren und schauen, was passiert.
            • WalW Wal
              @skb ,
              SKBS Offline
              SKBS Offline
              SKB
              #1345
              @wal Kannst Du nochmal drüber installieren und schauen, ob der Fehler noch auftritt?
              WalW 2 Antworten Letzte Antwort
              • SKBS SKB
                WalW Offline
                WalW Offline
                Wal
                #1346
                @skb ,
                ja ist weg. 👍
                Walter
                DoorIO-Adapter
                • WalW Wal
                  @skb ,
                  ja ist weg. 👍
                  SKBS Offline
                  SKBS Offline
                  SKB
                  #1347
                  @wal Danke für den Hinweis und die Rückmeldung :)
                  • SKBS SKB
                    WalW Offline
                    WalW Offline
                    Wal
                    #1348
                    @skb ,
                    die Animation ist nicht mehr flüssig, die stockt alle 3sec. ist aber i. M. nicht wichtig. ;-)
                    Walter
                    DoorIO-Adapter
                    • WalW Wal
                      @skb ,
                      SKBS Offline
                      SKBS Offline
                      SKB
                      #1349
                      @wal Dann wird dies vorher schon gewesen sein - an den Animationen habe ich seit einigen Versionen nichts geändert.
                      WalW 3 Antworten Letzte Antwort
                      • SKBS SKB
                        WalW Offline
                        WalW Offline
                        Wal
                        #1350
                        @skb ,
                        leider nein, das stocken ist erst seit alpha 16.
                        Ich mache nochmal den recheck.
                        Walter
                        DoorIO-Adapter
                        • SKBS SKB
                          WalW Offline
                          WalW Offline
                          Wal
                          #1351
                          @skb sagte in Test Adapter Energiefluss-erweitert v0.0.x GitHub/Latest:
                          Bin zurück gegangen und kein stocken, mach dir aber erst mal kein Stress.
                          Walter
                          DoorIO-Adapter
                          • WalW Wal
                            SKBS Offline
                            SKBS Offline
                            SKB
                            #1352
                            @wal Kannst du mal ein Beispiel aufnehmen?
                            • SKBS SKB
                              WalW Offline
                              WalW Offline
                              Wal
                              #1353
                              @skb ,
                              da legst dich nieder, wieder zurück auf die Neuste und auch kein stocken. ;-)
                              Walter
                              DoorIO-Adapter
                              • WalW Wal
                                @skb ,
                                SKBS Offline
                                SKBS Offline
                                SKB
                                #1354
                                @wal vielleicht der Upload unvollständig. Aber gut, wenn es geht ;)
                                • SKBS SKB
                                  ArmilarA Offline
                                  ArmilarA Offline
                                  Armilar
                                  #1355
                                  @skb
                                  Merkwürdig... Habe 2 Datenpunkte auf 0_userdate.0... vom Typ state/number. Damit errechne ich den Gesamtverbrauch und den Restverbrauch per JS. Wenn ich die GUI speicher und verlasse, dann stimmen die beiden Werte, jedoch werden sie in der GUI danach nicht mehr aktualisiert.
                                  Bei allen anderen ID's aktualisieren sich die Werte.
                                  Ist in der vorherigen Version nicht so...
                                  EDIT: im ioBroker ändern sich die Werte sekündlich...
                                  • ArmilarA Armilar
                                    @skb
                                    SKBS Offline
                                    SKBS Offline
                                    SKB
                                    #1356
                                    @armilar Danke für den Hinweis. Gemäß den Bestimmungen von ioBroker sollen Adapter bei fremden Datenpunkten nur reagieren, wenn "ACK" true gesetzt wird.
                                    Du kannst in deinen Javascripts, die die Punkte bearbeiten, einfach ein "ACK" true mitgeben:
                                    setState(Datenpunkt, Wert, true); // true am Ende
                                    ArmilarA F 2 Antworten Letzte Antwort
                                    • SKBS SKB
                                      ArmilarA Offline
                                      ArmilarA Offline
                                      Armilar
                                      #1357
                                      @skb
                                      okay... das wars... aktualisieren sich wieder
                                      • ArmilarA Armilar
                                        @skb
                                        SKBS Offline
                                        SKBS Offline
                                        SKB
                                        #1358
                                        @armilar na perfekt :)
                                        • ArmilarA Armilar
                                          @skb
                                          Hier der versprochene Screenshot
                                          Die Tapete wächst aber noch ;-) Sind noch lange nicht alle drin und der Akku (aktuell fake) ist auch erst in ein paar Tagen aktiv...
                                          Pascal
                                          #1359
                                          @armilar Wie stellst Du die Linien Animation für "Verbrauch Büro" ein? Dass diese läuft, wenn 1 oder mehrer Verbraucher an sind.
                                          Lob für den Screenshot. Schaut Cool aus.
                                          Pascal
