  5. [gelöst] Lampe nach Zeit ein /ausschalten
93 Beiträge 6 Kommentatoren 6.2k Aufrufe 5 Beobachtet
  • DJMarc75D DJMarc75
    @alero Setz mal den Blocklycode hier rein bitte (in Codetags !)
    Alero
    @djmarc75
    BlocklyJavascriptTypeScriptRules
    09:15:46.110	info	javascript.0 (387) Stop script script.js.common.Beleuchtung_Terrasse_bei_Dunkelheit
    09:15:46.114	info	javascript.0 (387) Start javascript script.js.common.Beleuchtung_Terrasse_bei_Dunkelheit
    09:15:46.116	info	javascript.0 (387) script.js.common.Beleuchtung_Terrasse_bei_Dunkelheit: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
    Ausgewählte Blöcke exportieren
      <variables>
        <variable type="timeout" id="timeout">timeout</variable>
      </variables>
      <block type="on" id="$8mK_S~;;.n+OVN/l*pT" x="-2587" y="-1037">
        <field name="OID">hm-rpc.1.0007DA4989ADED.1.STATE</field>
        <statement name="STATEMENT">
          <block type="timeouts_cleartimeout" id="{fMDjAPthwDd!$(h;Out">
            <next>
              <block type="timeouts_settimeout" id="*5W]N|^l*s17C7RjPQ@b">
                <field name="DELAY">2</field>
                  <block type="controls_if" id=";P$ZuXjsa0pju+VGQ6zE">
                    <value name="IF0">
                      <block type="logic_operation" id="hdn09=,wjMGfhCmR=MUH" inline="false">
                        <field name="OP">AND</field>
                        <value name="A">
                          <block type="logic_negate" id="I|z;l8HNW-VAr^BiPsEa">
                            <value name="BOOL">
                              <block type="time_compare_ex" id="FyU~n,NxYnt!LMG{F[vl">
                                <mutation xmlns="http://www.w3.org/1999/xhtml" end_time="true" actual_time="true"></mutation>
                                <field name="USE_ACTUAL_TIME">TRUE</field>
                                <field name="OPTION">between</field>
                                <value name="START_TIME">
                                  <shadow type="text" id="QZO2@KmXY08z220b@:qT">
                                    <field name="TEXT">12:00</field>
                                  </shadow>
                                  <block type="time_astro" id="v_?#s)k:c/yX|-Cggqzy">
                                    <field name="TYPE">sunriseEnd</field>
                                    <field name="OFFSET">-30</field>
                                  </block>
                                </value>
                                <value name="END_TIME">
                                  <shadow type="text" id="U0rQ5owVf;Ib@,3*O)BM">
                                    <field name="TEXT">18:00</field>
                                  </shadow>
                                  <block type="time_astro" id="8e3P:).IV6S;65v55NqV">
                                    <field name="TYPE">sunsetStart</field>
                                    <field name="OFFSET">30</field>
                                  </block>
                                </value>
                              </block>
                            </value>
                          </block>
                        </value>
                        <value name="B">
                          <block type="logic_operation" id="K@JC8t@hv5z9rjG#kUm(" inline="false">
                            <value name="A">
                              <block type="logic_operation" id="N@z/~/a{S56VxM!AxGA!">
                                <value name="A">
                                  <block type="logic_compare" id="sb,u0q=s{IF8lHriGD#b">
                                    <field name="OP">EQ</field>
                                    <value name="A">
                                      <block type="get_value" id="%tUT{1TVmM8DH^u11lqK">
                                        <field name="OID">hm-rpc.0.IEQ0023606.1.STATE</field>
                                      </block>
                                    </value>
                                    <value name="B">
                                      <block type="logic_boolean" id="TR$Vc6O}GqRF~uhpNuCN">
                                      </block>
                                    </value>
                                  </block>
                                </value>
                                <value name="B">
                                  <block type="logic_compare" id="i~%W}{JE#i(]%g?H{aG=">
                                    <value name="A">
                                      <block type="get_value" id="}]t#7K,C_SB,H@JOy7BR">
                                      </block>
                                    </value>
                                    <value name="B">
                                      <block type="math_number" id="*X(l22/j.R!Us!T;GoWo">
                                        <field name="NUM">2</field>
                                      </block>
                                    </value>
                                  </block>
                                </value>
                              </block>
                            </value>
                            <value name="B">
                              <block type="logic_compare" id="d}8.NLBCiD(14qa^.td9">
                                <value name="A">
                                  <block type="get_value" id="^a5H%Rw~2$KtVF6+x4q8">
                                    <field name="OID">hm-rpc.1.000BDA499AEFB6.1.MOTION</field>
                                  </block>
                                </value>
                                <value name="B">
                                  <block type="logic_boolean" id="^VR(PB#ac#jQ$pnn4Rx9">
                                  </block>
                                </value>
                              </block>
                            </value>
                          </block>
                        </value>
                      </block>
                    </value>
                    <statement name="DO0">
                      <block type="control" id="?:kwasmBihapC9gm_@-@">
                        <value name="VALUE">
                          <block type="logic_boolean" id="gwxP/E2xby]_oUJ!jj)_">
                          </block>
                        </value>
                        <next>
                          <block type="debug" id="1P=);rXh2|w`:r#}kkNf">
                            <value name="TEXT">
                              <shadow type="text" id="U^^j?l~KJAj(WdV|Bl)s">
                              </shadow>
                              <block type="text" id="q12nXDgWSB0*D[1Qrr0Y">
                                <field name="TEXT">Terrassentuer wurde geöffnet mit Licht an</field>
                              </block>
                            </value>
                          </block>
                        </next>
                      </block>
                    </statement>
                    <value name="IF1">
                      <block type="logic_operation" id="-yh6MwkBtMO^DYm*;B,C">
                        <field name="OP">OR</field>
                        <value name="A">
                          <block type="logic_compare" id="T61}Z-X{@Wr0c9ed8{0$">
                            <value name="A">
                              <block type="get_value" id="8k[RQ.IfRAETOrAX9R-T">
                              </block>
                            </value>
                            <value name="B">
                              <block type="math_number" id="=P*RC}Z-Gm@#W%PT,ToU">
                                <field name="NUM">0</field>
                              </block>
                            </value>
                          </block>
                        </value>
                        <value name="B">
                          <block type="logic_compare" id="uU:+n-#_N}_XM8SKMt:7">
                            <value name="A">
                              <block type="get_value" id="[/dat,l}`Uo*X#Bd6sml">
                              </block>
                            </value>
                            <value name="B">
                              <block type="math_number" id="Lh?eB@|q#RJGnOq~7bVc">
                                <field name="NUM">1</field>
                              </block>
                            </value>
                          </block>
                        </value>
                      </block>
                    </value>
                    <statement name="DO1">
                      <block type="control" id="^Px+:y4QRL,1Wr@W}q_O">
                          <block type="logic_boolean" id="1.+dV/%jto:XYqfj4;q@">
                          </block>
                        </value>
                        <next>
                          <block type="debug" id="@GsNKj4;9w{EvxmvHv-Z">
                            <value name="TEXT">
                              <shadow type="text" id="ycET$[i*MYq3GYrjok=u">
                              </shadow>
                              <block type="text" id="HS)$PHnT*}v6^Yn}79_m">
                                <field name="TEXT">Terrassentuer wurde gekippt oder geschlossen</field>
                              </block>
                            </value>
                          </block>
                        </next>
                      </block>
                    </statement>
                  </block>
                </statement>
              </block>
            </next>
          </block>
        </statement>
      </block>
    </xml>
      <variables>
      </variables>
            <next>
                    <value name="IF0">
                        <value name="A">
                            <value name="BOOL">
                                  </shadow>
                                  </block>
                                </value>
                                  </shadow>
                                  </block>
                                </value>
                              </block>
                            </value>
                          </block>
                        </value>
                        <value name="B">
                            <value name="A">
                                <value name="A">
                                    <value name="A">
                                      </block>
                                    </value>
                                    <value name="B">
                                      </block>
                                    </value>
                                  </block>
                                </value>
                                <value name="B">
                                    <value name="A">
                                      </block>
                                    </value>
                                    <value name="B">
                                      </block>
                                    </value>
                                  </block>
                                </value>
                              </block>
                            </value>
                            <value name="B">
                                <value name="A">
                                  </block>
                                </value>
                                <value name="B">
                                  </block>
                                </value>
                              </block>
                            </value>
                          </block>
                        </value>
                      </block>
                    </value>
                          </block>
                        </value>
                        <next>
                            <value name="TEXT">
                              </shadow>
                              </block>
                            </value>
                          </block>
                        </next>
                      </block>
                    </statement>
                    <value name="IF1">
                        <value name="A">
                            <value name="A">
                              </block>
                            </value>
                            <value name="B">
                              </block>
                            </value>
                          </block>
                        </value>
                        <value name="B">
                            <value name="A">
                              </block>
                            </value>
                            <value name="B">
                              </block>
                            </value>
                          </block>
                        </value>
                      </block>
                    </value>
                          </block>
                        </value>
                        <next>
                            <value name="TEXT">
                              </shadow>
                              </block>
                            </value>
                          </block>
                        </next>
                      </block>
                    </statement>
                  </block>
                </statement>
              </block>
            </next>
          </block>
        </statement>
      </block>
    </xml>
    das ist aber jetzt noch mit dem bewegungsmelder.
      @alero sagte in Lampe nach Zeit ein /ausschalten:
      wenn der griff auf open (2) steht
      Der Trigger ist ja der Griff.
      Alero
      @djmarc75
      es soll nur das Licht angehen wenn die Tür offen ist , es dunkel ist und in dem fall der Bm eine Bewegung erkannt hat.
      Der Tpüürgriff steht auch so schon mal auf offen obwohl keiner nach draussen geht.(wegen der Rollade)
        crunchipC Offline
        crunchipC Offline
        @djmarc75 hab ich jetzt nen Denkfehler oder schaltet sich zu gegebener Uhrzeit das Licht ein und gleich wieder aus, wenn ich die Tür kippe?
        Griffbewegung
        zu=0
        offen=2
        kippen=1
        A DJMarc75D 2 Antworten Letzte Antwort
        • A Alero
          @djmarc75
          CodierknechtC Offline
          Codierknecht
          @alero
          Dann ist der Trigger der BWM und der Griff nur eine Bedingung.
          HmIP|ZigBee|Tasmota|Unifi
          Zabbix Certified Specialist
            Griffbewegung
            zu=0
            offen=2
            kippen=1
            Alero
            schrieb am zuletzt editiert von Alero
            @crunchip
            es sollte so sein dass wenn es dunkel ist und der fenstergriff auf 2 steht (offen) und der BM eine Bewegung erkannt hat , dann soll das Licht auf der terrasse angehen. so der plan.
            crunchipC A CodierknechtC 3 Antworten Letzte Antwort
            • A Alero
              @crunchip
              crunchipC Offline
              crunchipC Offline
              @alero ist mir schon klar, ich bezog mich auf @DJMarc75 script Beispiel
              Licht soll ja nur angehen, wenn BWM, also trigger BWM
              aber nur, wenn Tür = 2, schalte Licht
              • A Alero
                @crunchip
                Alero
                und während des schreibens dachte ich es wäre vielleicht besser wenn ich das " fenster offen " über den Fensterkontakt mache. weil die Tür (der fenstergriff) auch schon mal auf offen steht obwohl keiner raus geht. dann soll das licht natürlich nicht angehen.
                  Griffbewegung
                  zu=0
                  offen=2
                  kippen=1
                  DJMarc75D Offline
                  DJMarc75D Offline
                  DJMarc75
                  @crunchip sagte in Lampe nach Zeit ein /ausschalten:
                  In dem Fall ja, habe den Datenpunkt vom BWM vergessen (in meinem Beispiel)
                  es sollte so sein dass wenn es dunkel ist und der fenstergriff auf 2 steht (offen) und der BM eine Bewegung erkannt hat , dann soll das Lickt auf der terrasse angehen.
                  dann sollte:
                  @codierknecht sagte in Lampe nach Zeit ein /ausschalten:
                  Lehrling seit 1975 !!!
                  • A Alero
                    @crunchip
                    Codierknecht
                    @alero
                    Also so:
                    Wenn der BWM auslöst, prüfst Du, ob die Terrassentür offen und es Nacht ist (ggf. zusätzlich den Griff).
                    => Licht an + Timer starten
                    Eine erneute Bewegung bei gleichen Bedingungen startet den Timer neu.
                    Wenn Timer abgelaufen => Licht aus.
                    • DJMarc75D Offline
                      DJMarc75D Offline
                      DJMarc75
                        dann sollte:
                        Alero
                        @djmarc75
                        also ich versuchs noch mal zu erklären.
                        ich habe eine Terrassentür. dort befinden sich ein Kontakt Fenstergriff (offen, zu, gekippt) und ein Fensterkontakt der ooffen und zu meldet.
                        dann noch einen Bewegungsmelder der auf die Terrassentür gerichtet ist.
                        Das Licht wird über einen schalter mit false und ture geschaltet.
                        Ich denke den Fenstergriff kann ich nicht nhemen, da wir öffter die Tür auf open stehen haben ( wegen der Rollade) aber nicht herausgehen. in diesem Fall soll das Licht nicht angehen. Daher dachte ich es wäre vielleicht besser den Fensterkontakt zu nehmen da er ja betätigt woird wenn man raus geht.
                        Desweíteren ist das Terrassenlicht noch teil einer Garten beleutung. also muss wahrscheinlcih vorher noch geprüft werden ob das licht schon an ist.
                        So ich hoffe ich habe mich jetzt besser ausgedrückt. sorry das ich mich vielleicht nicht sauber ausgedrückt habe.
                        HomoranH CodierknechtC 2 Antworten Letzte Antwort
                        • A Alero
                          @djmarc75
                          @alero so ganz kann ich dir nicht folgen
                          aber die Tür ist doch offen!?
                            Alero
                            der fenstergriffkontakt (HmIP-SRH) hat 3 stellungen Open, close und gekippt. Wenn er auf open steht heisst es noch nicht das die Tür auch wirklich offen ist. Anders beim Fensterkontakt (HMIP-SWDO) Hier zeigt er an wenn die Tür wirklich auf ist oder zu.
                            • A Alero
                              @djmarc75
                              Codierknecht
                              @alero
                              Du gehst da von der falschen Seite ran.
                              Was, wenn die Tür geöffnet wird und niemand rausgeht?
                              Dann soll das Licht ja in der Regel aus bleiben.
                              Dein Trigger muss der BWM sein!
                              Wenn der auslöst und dazu noch die anderen Bedingungen zutreffen (Fensterkontakt, Uhrzeit), soll das Licht an- und wenn keine Bewegung mehr erkannt wird nach X Minuten ausgehen.
                              • A Alero
                                DJMarc75D Offline
                                DJMarc75D Offline
                                DJMarc75
                                Anderes beim Fensterkontakt (HMIP-SWDO) Hier zeigt er an wenn die Tür wirklich auf ist oder zu
                                Und was liefert dieser DP an Werten? 0 & 1 oder true & false ?
                                Bei letzterem musst Du eben bei meinem Vorschlag die 2 durch true ersetzen.
                                Ist mir grad aber auch fast zu kompliziert - man hat ja nicht die gleiche Hardware wie Du um das alles so einfach nachzustellen ;)
                                  Alero
                                  @djmarc75
                                  hi,
                                  die Hardware sollte doch kein Problem sein.
                                  die fensterkontakte eben mit open close und ggf gekippt (0,1und 2).
                                  Das Licht wird mit einenm State true oder false gesetzt.
                                  • A Alero
                                    @djmarc75
                                    hi,
                                    never!
                                    zeig mal die Objektdaten in code-tags
                                    und gekippt schon gar nicht
                                    • A Alero
                                      @djmarc75
                                      hi,
                                      Codierknecht
                                      @alero
                                      Das Prinzip hat Dir @DJMarc75 doch schon gezeigt:
                                      Das sollte zumindest wie gewünscht funktionieren.
                                      Wenn eine Lampe bereits an ist und nochmal eingeschaltet wird, passiert ja nix.
                                      Kann man aber wegen Funkhygiene auch noch abfangen.
                                      Probier's erstmal aus.
                                        never!
                                        Alero
                                        Licht Terrasse
                                        Fensterkontakt
                                        Fenstergriffkontakt
                                        CodierknechtC DJMarc75D 2 Antworten Letzte Antwort
                                        • A Alero
                                          Licht Terrasse
                                          Fensterkontakt
                                          Fenstergriffkontakt
                                          Codierknecht
                                          @alero
                                          Mit "Objektdaten" ist sowas gemeint:
                                            "common": {
                                              "name": "SwitchState",
                                              "desc": "Manuell erzeugt",
                                              "role": "state",
                                              "type": "boolean",
                                              "read": true,
                                              "write": true,
                                              "def": false
                                            "type": "state",
                                            "native": {},
                                            "_id": "0_userdata.0.Test.test_bool",
                                            "acl": {
                                              "object": 1636,
                                              "state": 1636,
                                              "owner": "system.user.admin",
                                            "user": "system.user.admin",
                                            "ts": 1679403446220
