  4. [Redesign] wioBrowser für Windows
689 Beiträge 33 Kommentatoren 208.4k Aufrufe 37 Beobachtet
  • S saeft_2003
    @wal
    Beides. Im Firefox, Chrome, edge und wioWvWeb.exe (habe ich vorher genutzt) tritt das Problem nicht auf. Nur im wiobrowser.exe habe ich das Problem.
    Das Problem tritt nur bei den Zeitwidgets auf. Hier ein Beispiel:
    [{"tpl":"tplVis-materialdesign-Input","data":{"oid":"0_userdata.0.Pool.Pumpe_aus_Uhrzeit","g_fixed":true,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","inputType":"time","inputLayout":"solo","showInputMessageAlways":false,"showInputCounter":false,"clearIconShow":false,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"inputTextColor":"#b8b8b8","inputLabelText":"","inputLabelColor":"white","inputLayoutBorderColor":"#c4c4c4","inputLayoutBackgroundColorHover":"white","class":"mdui-value","inputTextFontSize":"20","inputTextFontFamily":"","clearIcon":"","inputAppendixFontSize":"-2","clearIconColor":"#FFFFFF","appendOuterIconColor":"#FFFFFF","appendIconColor":"#FFFFFF","prepandInnerIconColor":"#FFFFFF","prepandIconColor":"#FFFFFF","inputLayoutBackgroundColor":"","inputAlignment":"left","inputLayoutBorderColorHover":"#mdwTheme:vis-materialdesign.0.colors.input.border_hover","inputLayoutBorderColorSelected":"#mdwTheme:vis-materialdesign.0.colors.input.border_selected","inputLabelColorSelected":"#mdwTheme:vis-materialdesign.0.colors.input.label_selected","inputLabelFontFamily":"","inputLabelFontSize":"#mdwTheme:vis-materialdesign.0.fontSizes.input.label","inputAppendixColor":"#mdwTheme:vis-materialdesign.0.colors.input.appendix","inputAppendixFontFamily":"","inputMessageFontFamily":"#mdwTheme:vis-materialdesign.0.fonts.input.message","inputMessageFontSize":"#mdwTheme:vis-materialdesign.0.fontSizes.input.message","inputMessageColor":"#mdwTheme:vis-materialdesign.0.colors.input.message","inputCounterColor":"#mdwTheme:vis-materialdesign.0.colors.input.counter","inputCounterFontSize":"#mdwTheme:vis-materialdesign.0.fontSizes.input.counter","inputCounterFontFamily":"#mdwTheme:vis-materialdesign.0.fonts.input.counter"},"style":{"left":"487px","top":"716px","width":"80px","height":"39px","z-index":"9","font-size":"large"},"widgetSet":"materialdesign"}]
    WalW Offline
    WalW Offline
    Wal
    #609
    @saeft_2003 ,
    wioBrowser_test_Language
    In der cefApp.ini
    Language=de-DE
    hinzufügen.
    Walter
    DoorIO-Adapter
    S P 3 Antworten Letzte Antwort
    • WalW Wal
      @saeft_2003 ,
      In der cefApp.ini
      Language=de-DE
      hinzufügen.
      saeft_2003
      #610
      @wal
      Danke. Teste ich heute Abend und melde mich dann…
      • WalW Wal
        @saeft_2003 ,
        In der cefApp.ini
        Language=de-DE
        hinzufügen.
        saeft_2003
        #611
        @wal sagte in [Redesign] wioBrowser für Windows:
        cefApp.ini
        Die Datei cefApp.ini find ich nicht und wenn ich die exe Datei aus wioBrowser_test_Language öffne kommt der Fehler:
        WalW 1 Antwort Letzte Antwort
        • S saeft_2003
          cefApp.ini
          WalW Offline
          WalW Offline
          Wal
          #612
          @saeft_2003 ,
          du brauchst für die Testversionen das aktualisierte Komplettpaket 2.0.10 vom ersten Thread.
          Walter
          DoorIO-Adapter
          • WalW Wal
            @saeft_2003 ,
            saeft_2003
            #613
            @wal
            Funktioniert! Vielen Dank machst hier echt einen super Job 👍
            • WalW Wal
              @hcker sagte in [Redesign] wioBrowser für Windows:
              Wenn du für deinen Aufwand eine Spende o. ä. haben willst, lass es mich wissen.
              Nein, das würde mich nur unter Druck setzen.
              Sachspenden um eine bestimmte Hardware zu unterstützen ist was anderes, da sagt man nicht nein.
              Ich denke die Sprechstelle wird 4stellig kosten und macht deshalb wenig Sinn. ;-)
              Ich kann sie auch nirgends von Telegärtner zum Kauf finden.
              Hcker
              #614
              @wal
              Hallo Walter, hast du eine Wishlist bzgl. Hardware, z. B. auf Amazon? Die Telegärtner Touch Entry XS kann ich dir leider nicht zur Verfügung stellen. Sie ist zwar Made in Germany, trotzdem funktioniert es mehr schlecht als Recht. Bin gerade dabei mir beim Hersteller (Adatis) Unterstützung zu holen, da sich auf der Anlage die Scheibe ablöst und Sie aktuell einige Fehlermeldungen produziert.
              Viele Grüße
              Christian
              • H Hcker
                @wal
                Viele Grüße
                Christian
                WalW Offline
                WalW Offline
                Wal
                #615
                @hcker ,
                das war nur ein Joke.
                Es muss ja was in der Kommunikation zwischen Telegärtner und tSIP sein.
                Hast du den Log in tSIP mal ausgewertet ob was sichtbar ist.
                Hatte mit meiner Selbstbautürsprechstelle und mit anderen Sip-Clients noch keine Probleme.
                Walter
                DoorIO-Adapter
                H 1 Antwort Letzte Antwort
                • WalW Offline
                  WalW Offline
                  Wal
                  #616
                  Hier zum testen, wioBrowser wird nur einmal gestartet.
                  Ein Doppelstart wird verhindert, war ein Issues auf Github.
                  wioBrowser OneInstance
                  Walter
                  DoorIO-Adapter
                  skvarelS 1 Antwort Letzte Antwort
                  • WalW Wal
                    skvarelS Offline
                    skvarelS Offline
                    skvarel
                    #617
                    @wal .. inkl. Fenstermodus usw. ? Kann ich bedenkenlos hier immer die aktuellste Version installieren?
                    #TeamInventwo
                    Unsere Adapter:
                    • skvarelS skvarel
                      WalW Offline
                      WalW Offline
                      Wal
                      #618
                      @skvarel ,
                      die Testversionen entstehen immer aus der letzten Version es wird nichts entfernt außer offensichtliche Bugs.
                      Walter
                      DoorIO-Adapter
                      • WalW Wal
                        @hcker ,
                        Hcker
                        schrieb am zuletzt editiert von Hcker
                        #619
                        @wal Das mit dem Log mach ich. Bin im Moment viel unterwegs. Sobald ich zu Hause bin schau ich mir das an.
                        Christian
                        • H Hcker
                          Christian
                          WalW Offline
                          WalW Offline
                          Wal
                          #620
                          @hcker ,
                          habe eine Version mit den Sip Objekten zum steuern erstellt.
                          wioBrowser_SipAction
                          Die Objekte findest du unter sip.action.
                          Den wioBrowser-Adapter mußt du über Github im ioBroker installieren.
                          Walter
                          DoorIO-Adapter
                          • WalW Wal
                            @hcker ,
                            Hcker
                            #621
                            @wal Perfekt, danke dir!
                            Christian
                            • H Offline
                              Hcker
                              #622
                              @wal Hallo Walter, ich habe deine aktualisierte Version des wioBrowsers getestet. Die 3 Datenpunkte (answer, hang up, video off) führen die gewünschte Aktion aus, sofern ich zumindest ca. 1 Sekunde, zwischen dem ersten Klingeln der Türsprechstelle und dem Annehmen, warte. Das wäre für mich aber in Ordnung. Mag aber vielleicht auch daran liegen, dass mein Raspi 4 inzwischen gut zu tun hat. Reagiere ich schneller, wird der Befehl nicht angenommen und ich muss ihn wiederholen.
                              Was mir aufgefallen ist, die Datenpunkte "answer" und "hang up" muss ich den Haken bei "bestätigt" setzen.
                              Beim Datenpunkt "video off" funktioniert es nur ohne den Haken "bestätigt". Ist das so gewollt? Bzgl. Door Open fehlt mir gerade die Fantasie wie ich das testen könnte. Mein elektrisches Türschloss ist noch nicht angeschlossen und leider nicht innerhalb weniger Tage umsetzbar. Ich habe etwas mit Test Request Seiten ( z. B.: https://webhook.site) expermimentiert, kann aber nicht mit Sicherheit sagen ob der Datenpunkt funktioniert. Wenn du einen Hinweis hast wie ich das testen könnte, mach ich das gerne. Ansonsten vielen Dank für deine Arbeit!!!
                              Christian
                              WalW 2 Antworten Letzte Antwort
                              • H Hcker
                                Christian
                                WalW Offline
                                WalW Offline
                                Wal
                                schrieb am zuletzt editiert von Wal
                                #623
                                @hcker ,
                                das habe ich jetzt nicht bewusst gemacht und auch nicht getestet, ich schau mir das an.
                                Beim Türöffnen mit DTMF Pin müsste man die Töne hören beim auslösen, bei einer Url kann man über die simple API z.B. ein Datenpunkt setzen und dazu findest du bestimmt eine Anleitung hier im Forum.
                                Walter
                                DoorIO-Adapter
                                • H Hcker
                                  Christian
                                  WalW Offline
                                  WalW Offline
                                  Wal
                                  #624
                                  @hcker ,
                                  habe die Sip Actions durch getestet und habe dein Problem nicht, geht alles ohne Haken.
                                  Keine Ahnung was bei dir schief läuft, evtl. den wioBrowser-Adapter neu installieren ?
                                  Walter
                                  DoorIO-Adapter
                                  • WalW Wal
                                    @hcker ,
                                    Hcker
                                    #625
                                    @wal Ok, probier ich aus.
                                    • H Nicht stören
                                      H Nicht stören
                                      Hansi1234
                                      #626
                                      ich teste mich hier auch gerade ran. Hat jemand die interne Kamera seines Tablets schon als Bewegungserkennung verwendet? Wenn ja, wie?
                                      • H Hansi1234
                                        WalW Offline
                                        WalW Offline
                                        Wal
                                        #627
                                        @hansi1234 ,
                                        gemacht habe ich es noch nicht.
                                        Evtl. mit VLC die Kamera ins Netz streamen und mit Frigate den Stream holen und die Objekterkennung aktivieren.
                                        Walter
                                        DoorIO-Adapter
                                        • WalW Wal
                                          @hansi1234 ,
                                          H Nicht stören
                                          H Nicht stören
                                          Hansi1234
                                          #628
                                          @wal
                                          ich versuche es mal mit ispy. Andere Frage. Spielt der Browser Videos ab? Über deinen Frigate Browser werden Clips bereitsgestellt. Diese will ich in Jarvis integrieren. Das funktioniert auch sehr gut am Handy als auch auf dem PC (Firefox und Chrome). Leider aber nicht über deinen Browser.
