  4. [Redesign] wioBrowser für Windows
689 Beiträge 33 Kommentatoren 208.4k Aufrufe 37 Beobachtet
  • WalW Wal
    @saeft_2003 ,
    Andere Versionen vom wioBrowser oder nur im wioBrowser ?
    Hast du HTML-Code zum testen für mich oder ist das ein bestimmtes Widget in der Vis ?
    saeft_2003
    #608
    @wal
    Beides. Im Firefox, Chrome, edge und wioWvWeb.exe (habe ich vorher genutzt) tritt das Problem nicht auf. Nur im wiobrowser.exe habe ich das Problem.
    Das Problem tritt nur bei den Zeitwidgets auf. Hier ein Beispiel:
    [{"tpl":"tplVis-materialdesign-Input","data":{"oid":"0_userdata.0.Pool.Pumpe_aus_Uhrzeit","g_fixed":true,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","inputType":"time","inputLayout":"solo","showInputMessageAlways":false,"showInputCounter":false,"clearIconShow":false,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"inputTextColor":"#b8b8b8","inputLabelText":"","inputLabelColor":"white","inputLayoutBorderColor":"#c4c4c4","inputLayoutBackgroundColorHover":"white","class":"mdui-value","inputTextFontSize":"20","inputTextFontFamily":"","clearIcon":"","inputAppendixFontSize":"-2","clearIconColor":"#FFFFFF","appendOuterIconColor":"#FFFFFF","appendIconColor":"#FFFFFF","prepandInnerIconColor":"#FFFFFF","prepandIconColor":"#FFFFFF","inputLayoutBackgroundColor":"","inputAlignment":"left","inputLayoutBorderColorHover":"#mdwTheme:vis-materialdesign.0.colors.input.border_hover","inputLayoutBorderColorSelected":"#mdwTheme:vis-materialdesign.0.colors.input.border_selected","inputLabelColorSelected":"#mdwTheme:vis-materialdesign.0.colors.input.label_selected","inputLabelFontFamily":"","inputLabelFontSize":"#mdwTheme:vis-materialdesign.0.fontSizes.input.label","inputAppendixColor":"#mdwTheme:vis-materialdesign.0.colors.input.appendix","inputAppendixFontFamily":"","inputMessageFontFamily":"#mdwTheme:vis-materialdesign.0.fonts.input.message","inputMessageFontSize":"#mdwTheme:vis-materialdesign.0.fontSizes.input.message","inputMessageColor":"#mdwTheme:vis-materialdesign.0.colors.input.message","inputCounterColor":"#mdwTheme:vis-materialdesign.0.colors.input.counter","inputCounterFontSize":"#mdwTheme:vis-materialdesign.0.fontSizes.input.counter","inputCounterFontFamily":"#mdwTheme:vis-materialdesign.0.fonts.input.counter"},"style":{"left":"487px","top":"716px","width":"80px","height":"39px","z-index":"9","font-size":"large"},"widgetSet":"materialdesign"}]
    WalW 1 Antwort Letzte Antwort
    • S saeft_2003
      @wal
      WalW Offline
      WalW Offline
      Wal
      #609
      @saeft_2003 ,
      wioBrowser_test_Language
      In der cefApp.ini
      Language=de-DE
      hinzufügen.
      Walter
      DoorIO-Adapter
      S P 3 Antworten Letzte Antwort
      • WalW Wal
        @saeft_2003 ,
        In der cefApp.ini
        Language=de-DE
        hinzufügen.
        saeft_2003
        #610
        @wal
        Danke. Teste ich heute Abend und melde mich dann…
        • WalW Wal
          @saeft_2003 ,
          In der cefApp.ini
          Language=de-DE
          hinzufügen.
          saeft_2003
          #611
          @wal sagte in [Redesign] wioBrowser für Windows:
          cefApp.ini
          Die Datei cefApp.ini find ich nicht und wenn ich die exe Datei aus wioBrowser_test_Language öffne kommt der Fehler:
          • S saeft_2003
            cefApp.ini
            WalW Offline
            WalW Offline
            Wal
            #612
            @saeft_2003 ,
            du brauchst für die Testversionen das aktualisierte Komplettpaket 2.0.10 vom ersten Thread.
            Walter
            DoorIO-Adapter
            • WalW Wal
              @saeft_2003 ,
              saeft_2003
              #613
              @wal
              Funktioniert! Vielen Dank machst hier echt einen super Job 👍
              • WalW Wal
                @hcker sagte in [Redesign] wioBrowser für Windows:
                Wenn du für deinen Aufwand eine Spende o. ä. haben willst, lass es mich wissen.
                Nein, das würde mich nur unter Druck setzen.
                Sachspenden um eine bestimmte Hardware zu unterstützen ist was anderes, da sagt man nicht nein.
                Ich denke die Sprechstelle wird 4stellig kosten und macht deshalb wenig Sinn. ;-)
                Ich kann sie auch nirgends von Telegärtner zum Kauf finden.
                Hcker
                #614
                @wal
                Hallo Walter, hast du eine Wishlist bzgl. Hardware, z. B. auf Amazon? Die Telegärtner Touch Entry XS kann ich dir leider nicht zur Verfügung stellen. Sie ist zwar Made in Germany, trotzdem funktioniert es mehr schlecht als Recht. Bin gerade dabei mir beim Hersteller (Adatis) Unterstützung zu holen, da sich auf der Anlage die Scheibe ablöst und Sie aktuell einige Fehlermeldungen produziert.
                Viele Grüße
                Christian
                • H Hcker
                  @wal
                  Viele Grüße
                  Christian
                  WalW Offline
                  WalW Offline
                  Wal
                  #615
                  @hcker ,
                  das war nur ein Joke.
                  Es muss ja was in der Kommunikation zwischen Telegärtner und tSIP sein.
                  Hast du den Log in tSIP mal ausgewertet ob was sichtbar ist.
                  Hatte mit meiner Selbstbautürsprechstelle und mit anderen Sip-Clients noch keine Probleme.
                  Walter
                  DoorIO-Adapter
                  H 1 Antwort Letzte Antwort
                  • WalW Offline
                    WalW Offline
                    Wal
                    #616
                    Hier zum testen, wioBrowser wird nur einmal gestartet.
                    Ein Doppelstart wird verhindert, war ein Issues auf Github.
                    wioBrowser OneInstance
                    Walter
                    DoorIO-Adapter
                    skvarelS 1 Antwort Letzte Antwort
                    • WalW Wal
                      skvarelS Offline
                      skvarelS Offline
                      skvarel
                      #617
                      @wal .. inkl. Fenstermodus usw. ? Kann ich bedenkenlos hier immer die aktuellste Version installieren?
                      #TeamInventwo
                      Unsere Adapter:
                      • skvarelS skvarel
                        WalW Offline
                        WalW Offline
                        Wal
                        #618
                        @skvarel ,
                        die Testversionen entstehen immer aus der letzten Version es wird nichts entfernt außer offensichtliche Bugs.
                        Walter
                        DoorIO-Adapter
                        • WalW Wal
                          @hcker ,
                          Hcker
                          schrieb am zuletzt editiert von Hcker
                          #619
                          @wal Das mit dem Log mach ich. Bin im Moment viel unterwegs. Sobald ich zu Hause bin schau ich mir das an.
                          Christian
                          • H Hcker
                            Christian
                            WalW Offline
                            WalW Offline
                            Wal
                            #620
                            @hcker ,
                            habe eine Version mit den Sip Objekten zum steuern erstellt.
                            wioBrowser_SipAction
                            Die Objekte findest du unter sip.action.
                            Den wioBrowser-Adapter mußt du über Github im ioBroker installieren.
                            Walter
                            DoorIO-Adapter
                            • WalW Wal
                              @hcker ,
                              Hcker
                              #621
                              @wal Perfekt, danke dir!
                              Christian
                              • H Offline
                                Hcker
                                #622
                                @wal Hallo Walter, ich habe deine aktualisierte Version des wioBrowsers getestet. Die 3 Datenpunkte (answer, hang up, video off) führen die gewünschte Aktion aus, sofern ich zumindest ca. 1 Sekunde, zwischen dem ersten Klingeln der Türsprechstelle und dem Annehmen, warte. Das wäre für mich aber in Ordnung. Mag aber vielleicht auch daran liegen, dass mein Raspi 4 inzwischen gut zu tun hat. Reagiere ich schneller, wird der Befehl nicht angenommen und ich muss ihn wiederholen.
                                Was mir aufgefallen ist, die Datenpunkte "answer" und "hang up" muss ich den Haken bei "bestätigt" setzen.
                                Beim Datenpunkt "video off" funktioniert es nur ohne den Haken "bestätigt". Ist das so gewollt? Bzgl. Door Open fehlt mir gerade die Fantasie wie ich das testen könnte. Mein elektrisches Türschloss ist noch nicht angeschlossen und leider nicht innerhalb weniger Tage umsetzbar. Ich habe etwas mit Test Request Seiten ( z. B.: https://webhook.site) expermimentiert, kann aber nicht mit Sicherheit sagen ob der Datenpunkt funktioniert. Wenn du einen Hinweis hast wie ich das testen könnte, mach ich das gerne. Ansonsten vielen Dank für deine Arbeit!!!
                                Christian
                                WalW 2 Antworten Letzte Antwort
                                • H Hcker
                                  Christian
                                  WalW Offline
                                  WalW Offline
                                  Wal
                                  schrieb am zuletzt editiert von Wal
                                  #623
                                  @hcker ,
                                  das habe ich jetzt nicht bewusst gemacht und auch nicht getestet, ich schau mir das an.
                                  Beim Türöffnen mit DTMF Pin müsste man die Töne hören beim auslösen, bei einer Url kann man über die simple API z.B. ein Datenpunkt setzen und dazu findest du bestimmt eine Anleitung hier im Forum.
                                  Walter
                                  DoorIO-Adapter
                                  • H Hcker
                                    Christian
                                    WalW Offline
                                    WalW Offline
                                    Wal
                                    #624
                                    @hcker ,
                                    habe die Sip Actions durch getestet und habe dein Problem nicht, geht alles ohne Haken.
                                    Keine Ahnung was bei dir schief läuft, evtl. den wioBrowser-Adapter neu installieren ?
                                    Walter
                                    DoorIO-Adapter
                                    • WalW Wal
                                      @hcker ,
                                      Hcker
                                      #625
                                      @wal Ok, probier ich aus.
                                      • H Nicht stören
                                        H Nicht stören
                                        Hansi1234
                                        #626
                                        ich teste mich hier auch gerade ran. Hat jemand die interne Kamera seines Tablets schon als Bewegungserkennung verwendet? Wenn ja, wie?
                                        • H Hansi1234
                                          WalW Offline
                                          WalW Offline
                                          Wal
                                          #627
                                          @hansi1234 ,
                                          gemacht habe ich es noch nicht.
                                          Evtl. mit VLC die Kamera ins Netz streamen und mit Frigate den Stream holen und die Objekterkennung aktivieren.
                                          Walter
                                          DoorIO-Adapter
