  4. iob diag - Skript
iob diag - Skript
863 Beiträge 52 Kommentatoren 308.5k Aufrufe 40 Beobachtet
  • FeuersturmF Feuersturm
    @thomas-braun Da war ich wohl etwas zu schnell :-) So geht es mit der Summary weiter:
                         v.2023-08-12
     Static hostname: ioBrokerTestsystem
           Icon name: computer-container
             Chassis: container
          Machine ID: db91a8d9813048b3b0d9627361bf92a2
             Boot ID: 32a84dd282b744a48a6aa21ecc09b231
      Virtualization: lxc
    Operating System: Ubuntu 22.04.3 LTS
              Kernel: Linux 6.2.16-3-pve
        Architecture: x86-64
    Installation:           lxc
    Kernel:                 x86_64
    Userland:               amd64
    User-ID:                1001
    X-Server:               false
    Pending OS-Updates:     3
    Pending iob updates:    5
    Nodejs-Installation:    /usr/local/bin/nodejs
                            /usr/bin/node           v18.17.1
                            /usr/bin/npm            9.6.7
                            /usr/bin/npx            9.6.7
                            /usr/bin/corepack       0.18.0
    Recommended versions are nodejs 18.17.1 and npm 9.6.7
    *** nodejs is NOT correctly installed ***
    MEMORY:
    Mem:            4.1G        1.9G        1.1G        0.0K        1.1G        2.2G
    Swap:           512M        0.0K        511M
    Total:          4.6G        1.9G        1.6G
    Active iob-Instances:   23
    Active repo(s): beta
    ioBroker Core:          js-controller           5.0.11
                            admin                   6.8.0
    Objects type: jsonl
    States  type: jsonl
    + system.adapter.admin.0                  : admin                 : ioBrokerTestsystem                       -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.web.0                    : web                   : ioBrokerTestsystem                       -  enabled, port: 8082, bind: 192.168.178.77, run as: admin
    Objects:                13145
    States:                 11796
    Size of iob-Database:
    18M     /opt/iobroker/iobroker-data/objects.jsonl
    14M     /opt/iobroker/iobroker-data/objects.json.migrated
    14M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
    2.3M    /opt/iobroker/iobroker-data/objects_BACKUP_153020.json
    1.2M    /opt/iobroker/iobroker-data/objects_REMOTE_153020.json
    11M     /opt/iobroker/iobroker-data/states.jsonl
    5.3M    /opt/iobroker/iobroker-data/states.json.migrated
    5.3M    /opt/iobroker/iobroker-data/states.json.bak.migrated
    0       /opt/iobroker/iobroker-data/states.json.broken
    === Mark text until here for copying ===
    Your nodejs-Installation seems to be broken. Shall we try to fix it?
    DO NOT RUN FIX ON NON-LINUX-SYSTEMS!
    Press <y> to continue or any other key to quit
    Fixing your nodejs setup
    *** Deleting /usr/local/bin/nodejs ***
    Wrong paths have been fixed. Run \'iob diag\' again to check if your installation is fine now
    Danach erneut iob diag ausgeführt (github Variante)
    Skript v.2023-08-12
    *** BASE SYSTEM ***
             Chassis: container
      Virtualization: lxc
    model name      : Intel(R) Celeron(R) CPU  N3150  @ 1.60GHz
    Docker          : false
    Virtualization  : lxc
    Kernel          : x86_64
    Userland        : amd64
    Systemuptime and Load:
     21:10:04 up 17:57,  1 user,  load average: 14.54, 14.78, 14.78
    CPU threads: 4
    *** Time and Time Zones ***
                   Local time: Mon 2023-08-14 21:10:05 CEST
               Universal time: Mon 2023-08-14 19:10:05 UTC
                     RTC time: n/a
                  NTP service: inactive
              RTC in local TZ: no
    *** User and Groups ***
    proxmox
    /home/proxmox
    proxmox sudo iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
             4096 M total memory
             1885 M used memory
              544 M active memory
             2117 M inactive memory
             1125 M free memory
                0 M buffer memory
             1084 M swap cache
              512 M total swap
                0 M used swap
              511 M free swap
    *** FAILED SERVICES ***
      UNIT                   LOAD   ACTIVE SUB    DESCRIPTION
    * run-rpc_pipefs.mount   loaded failed failed RPC Pipe File System
    * sys-kernel-debug.mount loaded failed failed Kernel Debug File System
    2 loaded units listed.
    *** FILESYSTEM ***
    Filesystem                          Type   Size  Used Avail Use% Mounted on
    /dev/mapper/data2-vm--3108--disk--1 ext4    20G   13G  6.3G  67% /
    none                                tmpfs  492K  4.0K  488K   1% /dev
    tmpfs                               tmpfs  7.7G     0  7.7G   0% /dev/shm
    tmpfs                               tmpfs  3.1G  160K  3.1G   1% /run
    tmpfs                               tmpfs  5.0M     0  5.0M   0% /run/lock
    tmpfs                               tmpfs  1.0M     0  1.0M   0% /run/credentials/systemd-sysusers.service
    tmpfs                               tmpfs  1.6G     0  1.6G   0% /run/user/1001
    dmesg: read kernel buffer failed: Operation not permitted
    TARGET SOURCE                              FSTYPE OPTIONS
    /      /dev/mapper/data2-vm--3108--disk--1 ext4   rw,relatime,stripe=16
    /var:
    914M    /var/
    469M    /var/lib
    293M    /var/cache
    287M    /var/cache/apt
    201M    /var/cache/apt/archives
    Archived and active journals take up 16.0M in the file system.
    /opt/iobroker/backups:
    93M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    741M    /opt/iobroker/iobroker-data/
    506M    /opt/iobroker/iobroker-data/files
    162M    /opt/iobroker/iobroker-data/backup-objects
    126M    /opt/iobroker/iobroker-data/files/vis
    118M    /opt/iobroker/iobroker-data/files/vis/widgets
    21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c4efe404.js.map
    20M     /opt/iobroker/iobroker-data/files/fullcalendar.admin/static/js/main.7f5fc837.js.map
    19M     /opt/iobroker/iobroker-data/files/scheduler.admin/static/js/main.df70fdfc.js.map
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.17.1
    /usr/bin/npm            9.6.7
    /usr/bin/npx            9.6.7
    nodejs:
      Installed: 18.17.1-deb-1nodesource1
      Candidate: 18.17.1-deb-1nodesource1
      Version table:
     *** 18.17.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x jammy/main amd64 Packages
         12.22.9~dfsg-1ubuntu3 500
            500 http://archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  5.0.11
    admin:          6.8.0
    javascript:     7.1.4
    Adapters from github:   5
    Adapter State
    + system.adapter.backitup.0               : backitup              : ioBrokerTestsystem                       -  enabled
      system.adapter.benchmark.0              : benchmark             : ioBrokerTestsystem                       - disabled
      system.adapter.daswetter.0              : daswetter             : ioBrokerTestsystem                       -  enabled
    + system.adapter.device-watcher.0         : device-watcher        : ioBrokerTestsystem                       -  enabled
      system.adapter.devices.0                : devices               : ioBrokerTestsystem                       - disabled
      system.adapter.discovery.0              : discovery             : ioBrokerNew                              - disabled
      system.adapter.dwd.0                    : dwd                   : ioBrokerTestsystem                       -  enabled
    + system.adapter.fritzbox.0               : fritzbox              : ioBrokerTestsystem                       -  enabled
      system.adapter.fully-tablet-control.0   : fully-tablet-control  : ioBrokerTestsystem                       - disabled
      system.adapter.history.1                : history               : ioBrokerNew                              - disabled
    + system.adapter.hm-rega.0                : hm-rega               : ioBrokerTestsystem                       -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : ioBrokerTestsystem                       -  enabled, port: 0
      system.adapter.hue.0                    : hue                   : ioBrokerTestsystem                       - disabled, port: 443
      system.adapter.ical.0                   : ical                  : ioBrokerTestsystem                       - disabled
      system.adapter.ical.1                   : ical                  : ioBrokerTestsystem                       - disabled
      system.adapter.ical.2                   : ical                  : ioBrokerTestsystem                       - disabled
      system.adapter.ical.3                   : ical                  : ioBrokerTestsystem                       - disabled
      system.adapter.ical.4                   : ical                  : ioBrokerTestsystem                       - disabled
      system.adapter.ical.5                   : ical                  : ioBrokerTestsystem                       -  enabled
      system.adapter.icons-material-png.0     : icons-material-png    : ioBrokerTestsystem                       - disabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ioBrokerTestsystem                       - disabled
      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : ioBrokerTestsystem                       - disabled
      system.adapter.influxdb.0               : influxdb              : ioBrokerTestsystem                       - disabled, port: 8086
    + system.adapter.info.0                   : info                  : ioBrokerTestsystem                       -  enabled
    + system.adapter.javascript.0             : javascript            : ioBrokerTestsystem                       -  enabled
      system.adapter.mqtt.0                   : mqtt                  : ioBrokerTestsystem                       - disabled, port: 1883, bind: 0.0.0.0
    + system.adapter.nina.0                   : nina                  : ioBrokerTestsystem                       -  enabled
      system.adapter.openweathermap.0         : openweathermap        : ioBrokerTestsystem                       -  enabled
    + system.adapter.proxmox.0                : proxmox               : ioBrokerTestsystem                       -  enabled, port: 8006
      system.adapter.rainbird.0               : rainbird              : ioBrokerTestsystem                       - disabled
    + system.adapter.samsung-community.0      : samsung-community     : ioBrokerTestsystem                       -  enabled
      system.adapter.sayit.0                  : sayit                 : ioBrokerTestsystem                       - disabled, port: 0
    + system.adapter.scenes.0                 : scenes                : ioBrokerTestsystem                       -  enabled
    + system.adapter.scheduler.0              : scheduler             : ioBrokerTestsystem                       -  enabled
    + system.adapter.simple-api.0             : simple-api            : ioBrokerTestsystem                       -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      system.adapter.socketio.0               : socketio              : ioBrokerTestsystem                       - disabled, port: 8084, bind: 192.168.178.77, run as: admin
      system.adapter.spotify-premium.0        : spotify-premium       : ioBrokerTestsystem                       - disabled
      system.adapter.sql.0                    : sql                   : ioBrokerNew                              - disabled, port: 3306
    + system.adapter.tankerkoenig.0           : tankerkoenig          : ioBrokerTestsystem                       -  enabled
      system.adapter.telegram.0               : telegram              : ioBrokerTestsystem                       - disabled, port: 8443, bind: 0.0.0.0
    + system.adapter.tr-064.0                 : tr-064                : ioBrokerTestsystem                       -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : ioBrokerTestsystem                       -  enabled
    + system.adapter.unifi.0                  : unifi                 : ioBrokerTestsystem                       -  enabled
    + system.adapter.valloxmv.0               : valloxmv              : ioBrokerTestsystem                       -  enabled, port: 80
    + system.adapter.vis-2-beta.0             : vis-2-beta            : ioBrokerTestsystem                       -  enabled
      system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : ioBrokerTestsystem                       -  enabled
      system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : ioBrokerTestsystem                       -  enabled
      system.adapter.vis-2-widgets-jaeger-design.0: vis-2-widgets-jaeger-design: ioBrokerTestsystem                       -  enabled
      system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: ioBrokerTestsystem                       -  enabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : ioBrokerTestsystem                       - disabled
      system.adapter.vis-google-fonts.0       : vis-google-fonts      : ioBrokerTestsystem                       -  enabled
      system.adapter.vis-history.0            : vis-history           : ioBrokerTestsystem                       - disabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : ioBrokerTestsystem                       -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBrokerTestsystem                       - disabled
      system.adapter.vis-justgage.0           : vis-justgage          : ioBrokerTestsystem                       - disabled
      system.adapter.vis-map.0                : vis-map               : ioBrokerTestsystem                       - disabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : ioBrokerTestsystem                       - disabled
      system.adapter.vis-metro.0              : vis-metro             : ioBrokerTestsystem                       -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBrokerTestsystem                       - disabled
      system.adapter.vis.0                    : vis                   : ioBrokerTestsystem                       -  enabled
      system.adapter.worx.0                   : worx                  : ioBrokerTestsystem                       - disabled
    + instance is alive
    ioBroker-Repositories
    Installed ioBroker-Instances
    Used repository: beta
    Adapter    "admin"        : 6.8.0    , installed 6.8.0
    Adapter    "backitup"     : 2.7.0    , installed 2.6.23 [Updatable]
    Adapter    "benchmark"    : 1.1.4    , installed 1.1.4
    Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
    Adapter    "device-watcher": 2.9.3   , installed 2.9.3
    Adapter    "devices"      : 1.1.5    , installed 1.1.5
    Adapter    "fritzbox"     : 0.5.0    , installed 0.5.0
    Adapter    "fullcalendar" : 2.2.6    , installed 2.2.2  [Updatable]
    Adapter    "hm-rega"      : 3.0.47   , installed 3.0.47
    Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
    Adapter    "hue"          : 3.9.5    , installed 3.9.5
    Adapter    "ical"         : 1.13.3   , installed 1.13.3
    Adapter    "javascript"   : 7.1.4    , installed 7.1.4
    Controller "js-controller": 5.0.11   , installed 5.0.11
    Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
    Adapter    "nina"         : 0.0.25   , installed 0.0.25
    Adapter    "openweathermap": 0.4.2   , installed 0.4.2
    Adapter    "proxmox"      : 1.3.5    , installed 1.3.5
    Adapter    "rainbird"     : 0.2.2    , installed 0.2.3
    Adapter    "sayit"        : 3.0.5    , installed 3.0.5
    Adapter    "scheduler"    : 1.1.9    , installed 1.1.9
    Adapter    "smartmeter"   : 3.3.4    , installed 3.3.4
    Adapter    "socketio"     : 6.5.2    , installed 6.4.0  [Updatable]
    Adapter    "spotify-premium": 1.2.2  , installed 1.2.2
    Adapter    "telegram"     : 1.16.0   , installed 1.16.0
    Adapter    "trashschedule": 2.2.0    , installed 2.2.0
    Adapter    "unifi"        : 0.6.6    , installed 0.6.6
    Adapter    "valloxmv"     : 1.2.0    , installed 1.2.0
    Adapter    "vis-2-widgets-energy": 0.2.3, installed 0.2.3
    Adapter    "vis-2-widgets-gauges": 0.2.0, installed 0.2.0
    Adapter    "vis-2-widgets-jaeger-design": 1.0.0, installed 1.0.0
    Adapter    "vis-2-widgets-material": 0.8.5, installed 0.8.5
    Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
    Adapter    "web"          : 6.1.0    , installed 6.0.3  [Updatable]
    Adapter    "worx"         : 2.3.2    , installed 2.3.2
    Adapter    "ws"           : 2.5.3    , installed 2.4.0  [Updatable]
    Objects and States
    Objects:        13145
    States:         11796
    Hit:1 http://archive.ubuntu.com/ubuntu jammy InRelease
    Hit:2 http://archive.ubuntu.com/ubuntu jammy-updates InRelease
    Hit:3 https://deb.nodesource.com/node_18.x jammy InRelease
    Hit:4 http://archive.ubuntu.com/ubuntu jammy-security InRelease
    Reading package lists... Done
    Pending Updates: 3
    *** Listening Ports ***
    tcp        0      0 192.168.178.77:8082     0.0.0.0:*               LISTEN      1000       316603498  35631/io.web.0
    tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      102        311048807  91/systemd-resolved
    tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1000       316587698  35266/iobroker.js-c
    tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1000       316585912  35266/iobroker.js-c
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          311049284  1/init
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          311047903  141/sshd: /usr/sbin
    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          311048905  305/master
    tcp6       0      0 :::8081                 :::*                    LISTEN      1000       316592190  35284/io.admin.0
    tcp6       0      0 :::8087                 :::*                    LISTEN      1000       316596098  35542/io.simple-api
    tcp6       0      0 :::111                  :::*                    LISTEN      0          311049286  1/init
    tcp6       0      0 :::22                   :::*                    LISTEN      0          311047905  141/sshd: /usr/sbin
    tcp6       0      0 :::3000                 :::*                    LISTEN      108        311049073  110/grafana-server
    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          311048906  305/master
    udp        0      0 127.0.0.53:53           0.0.0.0:*                           102        311048806  91/systemd-resolved
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          311049285  1/init
    udp6       0      0 :::111                  :::*                                0          311049287  1/init
    2023-08-14 21:10:40.535  - info: host.ioBrokerTestsystem Restart adapter system.adapter.hm-rpc.0 because enabled
    2023-08-14 21:11:10.916  - info: host.ioBrokerTestsystem instance system.adapter.hm-rpc.0 started with pid 41336
    2023-08-14 21:11:18.165  - info: hm-rpc.0 (41336) starting. Version 1.15.19 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v18.17.1, js-controller: 5.0.11
    2023-08-14 21:11:19.544  - info: hm-rpc.0 (41336) xmlrpc server is trying to listen on 192.168.178.77:2010
    2023-08-14 21:11:19.547  - info: hm-rpc.0 (41336) xmlrpc client is trying to connect to 192.168.178.84:2010/ with ["http://192.168.178.77:2010","ioBrokerTestsystem:hm-rpc.0:929dc2370363482799117e5946401b05"]
    2023-08-14 21:11:19.621  - error: hm-rpc.0 (41336) Init not possible, going to stop: Unknown XML-RPC tag 'TITLE'
    2023-08-14 21:11:49.617  - error: hm-rpc.0 (41336) Init not possible, going to stop: Unknown XML-RPC tag 'TITLE'
    2023-08-14 21:11:49.627  - info: hm-rpc.0 (41336) xmlrpc -> 192.168.178.84:2010/ init ["http://192.168.178.77:2010",""]
    2023-08-14 21:11:49.656  - error: hm-rpc.0 (41336) Cannot call init: [http://192.168.178.77:2010, ""] Unknown XML-RPC tag 'TITLE'
    2023-08-14 21:11:49.684  - info: hm-rpc.0 (41336) terminating
    2023-08-14 21:11:49.693  - info: hm-rpc.0 (41336) Terminated (NO_ERROR): Without reason
    2023-08-14 21:11:50.667  - info: host.ioBrokerTestsystem instance system.adapter.hm-rpc.0 terminated with code 0 (NO_ERROR)
    2023-08-14 21:11:50.669  - info: host.ioBrokerTestsystem Restart adapter system.adapter.hm-rpc.0 because enabled
    2023-08-14 21:12:21.244  - info: host.ioBrokerTestsystem instance system.adapter.hm-rpc.0 started with pid 41411
    2023-08-14 21:12:28.488  - info: hm-rpc.0 (41411) starting. Version 1.15.19 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v18.17.1, js-controller: 5.0.11
    2023-08-14 21:12:29.389  - info: hm-rpc.0 (41411) xmlrpc server is trying to listen on 192.168.178.77:2010
    2023-08-14 21:12:29.403  - info: hm-rpc.0 (41411) xmlrpc client is trying to connect to 192.168.178.84:2010/ with ["http://192.168.178.77:2010","ioBrokerTestsystem:hm-rpc.0:37c6a758693e440730b66c6e2688cd46"]
    2023-08-14 21:12:29.581  - error: hm-rpc.0 (41411) Init not possible, going to stop: Unknown XML-RPC tag 'TITLE'
    2023-08-14 21:12:59.538  - error: hm-rpc.0 (41411) Init not possible, going to stop: Unknown XML-RPC tag 'TITLE'
    2023-08-14 21:12:59.595  - info: hm-rpc.0 (41411) xmlrpc -> 192.168.178.84:2010/ init ["http://192.168.178.77:2010",""]
    2023-08-14 21:12:59.633  - error: hm-rpc.0 (41411) Cannot call init: [http://192.168.178.77:2010, ""] Unknown XML-RPC tag 'TITLE'
    2023-08-14 21:12:59.661  - info: hm-rpc.0 (41411) terminating
    2023-08-14 21:12:59.665  - info: hm-rpc.0 (41411) Terminated (NO_ERROR): Without reason
    2023-08-14 21:13:00.498  - info: host.ioBrokerTestsystem instance system.adapter.hm-rpc.0 terminated with code 0 (NO_ERROR)
    2023-08-14 21:13:00.500  - info: host.ioBrokerTestsystem Restart adapter system.adapter.hm-rpc.0 because enabled
    und die summary
                         v.2023-08-12
             Chassis: container
      Virtualization: lxc
    Installation:           lxc
    Kernel:                 x86_64
    Userland:               amd64
    User-ID:                1001
    X-Server:               false
    Nodejs-Installation:    /usr/bin/nodejs         v18.17.1
                            /usr/bin/npm            9.6.7
                            /usr/bin/npx            9.6.7
    MEMORY:
    Mem:            4.1G        1.9G        1.2G        0.0K        1.1G        2.2G
    Total:          4.6G        1.9G        1.7G
    Active iob-Instances:   22
                            admin                   6.8.0
    Objects type: jsonl
    States  type: jsonl
    Objects:                13145
    States:                 11796
    13M     /opt/iobroker/iobroker-data/states.jsonl
    #548
    @feuersturm sagte in iob diag - Skript:
    Juhu! Tut! :)
      Juhu! Tut! :)
      FeuersturmF Offline
      FeuersturmF Offline
      Feuersturm
      #549
      @thomas-braun Was genau soll das Skript bzw. eine Variante denn alles fixen?
        #550
        @feuersturm
        Zwei Stufen: Bei den üblichen falschen Pfaden der nodejs-bins werden die Pfade gelöscht, meist ist es dann damit ja auch schon getan.
        Die zweite Stufe wird gezündet, wenn ein nodejs <> der aktuellen Empfehlung gefunden wird, dann wird angeboten diese zu installieren.
          @feuersturm
          FeuersturmF Offline
          FeuersturmF Offline
          Feuersturm
          #551
          @thomas-braun Wenn die zweite Stufe implementiert ist kann ich dies auch gerne einmal testen. Kann ja ein Downgrade auf z.B. nodejs 16 machen
          Thomas BraunT GlasfaserG 2 Antworten Letzte Antwort
            #552
            Ist schon drin. Wird nur angeboten, wenn eine abweichende Version läuft.
            Achtung, dein iobroker wird da gestoppt und du musst den Container dann neustarten. Gibt aber Hinweise im Text.
            Für einen geskripteten Restart eines Containers hab ich zu wenig Plan davon. Bei nativen Installationen wird der ioBroker auch wieder vom Skript gestartet.
              GlasfaserG Offline
              GlasfaserG Offline
              #553
              Was mir gerade einfällt :
              mit einem Buanet ioBroker Image kann man den Container mit
              maint restart -y
              neustarten.
              • GlasfaserG Glasfaser
                maint restart -y
                neustarten.
                #554
                @glasfaser
                Docker? Hab ich im Code ausgeschlossen.
                  @glasfaser
                  GlasfaserG Offline
                  GlasfaserG Offline
                  #555
                  Ja Docker ,
                  Sorry habe ich nicht dazu geschrieben :)
                    Ja Docker ,
                    #556
                    @glasfaser
                    Docker-Dosen kann ich rein gar nicht testen. Und ist mir auch 'zu anders' im Vergleich zu einem LXC oder einer nativen Installation.
                    Aber man topft das ganze doch ohnehin immer in einen neuen Übertopf um, oder nicht?
                    • FeuersturmF Offline
                      FeuersturmF Offline
                      Feuersturm
                      #557
                      Kurzfassung: Funktioniert :-)
                      Langfassung:
                      Downgrade nodejs von 18 auf 16
                      proxmox@ioBrokerTestsystem:/home$ apt policy nodejs
                      nodejs:
                        Version table:
                       *** 18.17.1-deb-1nodesource1 100
                           16.20.2-deb-1nodesource1 500
                              500 https://deb.nodesource.com/node_16.x jammy/main amd64 Packages
                      proxmox@ioBrokerTestsystem:/home$ sudo apt install nodejs=16.20.2-deb-1nodesource1
                      The following packages were automatically installed and are no longer required:
                        libllvm13 libvulkan1 libwayland-client0 mesa-vulkan-drivers
                      Use 'sudo apt autoremove' to remove them.
                      The following packages will be DOWNGRADED:
                        nodejs
                      0 upgraded, 0 newly installed, 1 downgraded, 0 to remove and 3 not upgraded.
                      Need to get 27.2 MB of archives.
                      After this operation, 60.4 MB disk space will be freed.
                      Do you want to continue? [Y/n] y
                      Get:1 https://deb.nodesource.com/node_16.x jammy/main amd64 nodejs amd64 16.20.2-deb-1nodesource1 [27.2 MB]
                      Fetched 27.2 MB in 4s (6498 kB/s)
                      dpkg: warning: downgrading nodejs from 18.17.1-deb-1nodesource1 to 16.20.2-deb-1nodesource1
                      (Reading database ... 46660 files and directories currently installed.)
                      Preparing to unpack .../nodejs_16.20.2-deb-1nodesource1_amd64.deb ...
                      Unpacking nodejs (16.20.2-deb-1nodesource1) over (18.17.1-deb-1nodesource1) ...
                      Setting up nodejs (16.20.2-deb-1nodesource1) ...
                      Processing triggers for man-db (2.10.2-1) ...
                      proxmox@ioBrokerTestsystem:/home$ nodejs -v && npm -v
                      v16.20.2
                      8.19.4
                      danach noch ein iob fix und dann ein iob start ausgeführt.
                      iob diag (github version)
                      Skript v.2023-08-12
                      *** BASE SYSTEM ***
                               Chassis: container
                        Virtualization: lxc
                      Docker          : false
                      Kernel          : x86_64
                      Userland        : amd64
                       22:12:14 up 18:59,  1 user,  load average: 12.95, 13.98, 14.17
                      CPU threads: 4
                                     Local time: Mon 2023-08-14 22:12:14 CEST
                                 Universal time: Mon 2023-08-14 20:12:14 UTC
                                       RTC time: n/a
                                RTC in local TZ: no
                      proxmox
                      /home/proxmox
                      X-Server:       false
                      Desktop:
                      Terminal:       tty
                      *** MEMORY ***
                      Mem:            4.1G        1.8G        1.1G        0.0K        1.1G        2.3G
                      Total:          4.6G        1.8G        1.7G
                               4096 M total memory
                               1801 M used memory
                                619 M active memory
                               2020 M inactive memory
                               1146 M free memory
                                  0 M buffer memory
                               1147 M swap cache
                                512 M total swap
                                  0 M used swap
                                511 M free swap
                      *** FILESYSTEM ***
                      /var:
                      914M    /var/
                      469M    /var/lib
                      293M    /var/cache
                      287M    /var/cache/apt
                      733M    /opt/iobroker/iobroker-data/
                      /usr/bin/nodejs         v16.20.2
                      /usr/bin/node           v16.20.2
                      /usr/bin/npm            8.19.4
                      /usr/bin/npx            8.19.4
                      /usr/bin/corepack       0.17.0
                      nodejs:
                        Installed: 16.20.2-deb-1nodesource1
                        Candidate: 16.20.2-deb-1nodesource1
                        Version table:
                       *** 16.20.2-deb-1nodesource1 500
                      Errors in npm tree:
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      admin:          6.8.0
                      javascript:     7.1.4
                      Adapter State
                        system.adapter.hm-rpc.0                 : hm-rpc                : ioBrokerTestsystem                       - disabled, port: 0
                      + instance is alive
                      Objects and States
                      Objects:        13145
                      States:         11802
                      Hit:1 https://deb.nodesource.com/node_16.x jammy InRelease
                      Hit:2 http://archive.ubuntu.com/ubuntu jammy InRelease
                      Hit:3 http://archive.ubuntu.com/ubuntu jammy-updates InRelease
                      Pending Updates: 3
                      tcp        0      0 192.168.178.77:8082     0.0.0.0:*               LISTEN      1000       317245085  45156/io.web.0
                      tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1000       317230619  44801/iobroker.js-c
                      tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1000       317232637  44801/iobroker.js-c
                      tcp6       0      0 :::8081                 :::*                    LISTEN      1000       317233130  44829/io.admin.0
                      tcp6       0      0 :::8087                 :::*                    LISTEN      1000       317245613  45066/io.simple-api
                      2023-08-14 22:09:24.761  - info: hm-rpc.0 (45672) terminating
                      2023-08-14 22:09:24.767  - info: hm-rpc.0 (45672) Terminated (NO_ERROR): Without reason
                      2023-08-14 22:09:24.807  - info: hm-rpc.0 (45672) terminating
                      2023-08-14 22:09:25.104  - info: hm-rpc.0 (45672) terminating with timeout
                      2023-08-14 22:09:26.022  - info: host.ioBrokerTestsystem instance system.adapter.hm-rpc.0 terminated with code 0 (NO_ERROR)
                      2023-08-14 22:09:26.027  - info: host.ioBrokerTestsystem Restart adapter system.adapter.hm-rpc.0 because enabled
                      2023-08-14 22:09:56.356  - info: host.ioBrokerTestsystem instance system.adapter.hm-rpc.0 started with pid 45692
                      2023-08-14 22:10:02.445  - info: hm-rpc.0 (45692) starting. Version 1.15.19 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v16.20.2, js-controller: 5.0.11
                      2023-08-14 22:10:03.210  - info: hm-rpc.0 (45692) xmlrpc server is trying to listen on 192.168.178.77:2010
                      2023-08-14 22:10:03.214  - info: hm-rpc.0 (45692) xmlrpc client is trying to connect to 192.168.178.84:2010/ with ["http://192.168.178.77:2010","ioBrokerTestsystem:hm-rpc.0:d96698d96618b7431e6c2903595df786"]
                      2023-08-14 22:10:03.286  - error: hm-rpc.0 (45692) Init not possible, going to stop: Unknown XML-RPC tag 'TITLE'
                      2023-08-14 22:10:33.320  - info: hm-rpc.0 (45692) xmlrpc -> 192.168.178.84:2010/ init ["http://192.168.178.77:2010",""]
                      2023-08-14 22:10:33.429  - error: hm-rpc.0 (45692) Init not possible, going to stop: Unknown XML-RPC tag 'TITLE'
                      2023-08-14 22:10:33.452  - error: hm-rpc.0 (45692) Cannot call init: [http://192.168.178.77:2010, ""] Unknown XML-RPC tag 'TITLE'
                      2023-08-14 22:10:33.486  - info: hm-rpc.0 (45692) terminating
                      2023-08-14 22:10:33.490  - info: hm-rpc.0 (45692) Terminated (NO_ERROR): Without reason
                      2023-08-14 22:10:34.338  - info: host.ioBrokerTestsystem instance system.adapter.hm-rpc.0 terminated with code 0 (NO_ERROR)
                      2023-08-14 22:10:34.341  - info: host.ioBrokerTestsystem Restart adapter system.adapter.hm-rpc.0 because enabled
                      2023-08-14 22:11:04.698  - info: host.ioBrokerTestsystem instance system.adapter.hm-rpc.0 started with pid 46399
                      2023-08-14 22:11:06.352  - info: host.ioBrokerTestsystem "system.adapter.hm-rpc.0" disabled
                      2023-08-14 22:11:06.364  - info: host.ioBrokerTestsystem stopInstance system.adapter.hm-rpc.0 (force=false, process=true)
                      2023-08-14 22:11:07.036  - info: host.ioBrokerTestsystem stopInstance system.adapter.hm-rpc.0 send kill signal
                      2023-08-14 22:11:08.043  - info: host.ioBrokerTestsystem stopInstance system.adapter.hm-rpc.0 killing pid 46399
                      2023-08-14 22:11:08.292  - warn: host.ioBrokerTestsystem instance system.adapter.hm-rpc.0 terminated due to SIGTERM
                      2023-08-14 22:11:08.295  - info: host.ioBrokerTestsystem instance system.adapter.hm-rpc.0 terminated with code null ()
                      Summary
                                           v.2023-08-12
                               Chassis: container
                        Virtualization: lxc
                      Installation:           lxc
                      Kernel:                 x86_64
                      Userland:               amd64
                      User-ID:                1001
                      X-Server:               false
                      Nodejs-Installation:    /usr/bin/nodejs         v16.20.2
                                              /usr/bin/npm            8.19.4
                                              /usr/bin/npx            8.19.4
                      MEMORY:
                      Mem:            4.1G        1.7G        1.2G        0.0K        1.1G        2.3G
                                              admin                   6.8.0
                      Objects type: jsonl
                      States  type: jsonl
                      Objects:                13145
                      States:                 11802
                      4.4M    /opt/iobroker/iobroker-data/states.jsonl
                      You are running nodejs v.16.20.2. Do you want to install recommended nodejs v.18.17.1?
                      *** DO NOT TRY THIS FIX ON NON-LINUX-SYSTEMS! ***
                      lxc
                      Waiting for ioBroker to shut down - Give me a minute...
                      ## Installing the NodeSource Node.js 18.x repo...
                      ## Populating apt-get cache...
                      + apt-get update
                      Hit:3 http://archive.ubuntu.com/ubuntu jammy-security InRelease
                      ## Confirming "jammy" is supported...
                      + curl -sLf -o /dev/null 'https://deb.nodesource.com/node_18.x/dists/jammy/Release'
                      ## Adding the NodeSource signing key to your keyring...
                      + curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | gpg --dearmor | tee /usr/share/keyrings/nodesource.gpg >/dev/null
                      ## Creating apt sources list file for the NodeSource Node.js 18.x repo...
                      + echo 'deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x jammy main' > /etc/apt/sources.list.d/nodesource.list
                      + echo 'deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x jammy main' >> /etc/apt/sources.list.d/nodesource.list
                      ## Running `apt-get update` for you...
                      + apt-get update
                      Get:4 https://deb.nodesource.com/node_18.x jammy InRelease [4563 B]
                      Get:5 https://deb.nodesource.com/node_18.x jammy/main amd64 Packages [776 B]
                      Fetched 5339 B in 13s (404 B/s)
                      ## Run `sudo apt-get install -y nodejs` to install Node.js 18.x and npm
                      ## You may also need development tools to build native addons:
                           sudo apt-get install gcc g++ make
                      ## To install the Yarn package manager, run:
                           curl -sL https://dl.yarnpkg.com/debian/pubkey.gpg | gpg --dearmor | sudo tee /usr/share/keyrings/yarnkey.gpg >/dev/null
                           echo "deb [signed-by=/usr/share/keyrings/yarnkey.gpg] https://dl.yarnpkg.com/debian stable main" | sudo tee /etc/apt/sources.list.d/yarn.list
                           sudo apt-get update && sudo apt-get install yarn
                      The following packages will be upgraded:
                        nodejs
                      1 upgraded, 0 newly installed, 0 to remove and 3 not upgraded.
                      Need to get 28.9 MB of archives.
                      After this operation, 60.4 MB of additional disk space will be used.
                      Get:1 https://deb.nodesource.com/node_18.x jammy/main amd64 nodejs amd64 18.17.1-deb-1nodesource1 [28.9 MB]
                      Fetched 28.9 MB in 7s (4254 kB/s)
                      (Reading database ... 44173 files and directories currently installed.)
                      Preparing to unpack .../nodejs_18.17.1-deb-1nodesource1_amd64.deb ...
                      Unpacking nodejs (18.17.1-deb-1nodesource1) over (16.20.2-deb-1nodesource1) ...
                      Setting up nodejs (18.17.1-deb-1nodesource1) ...
                      Please restart your container
                      We tried our best to fix your nodejs. Please run 'iob diag' again to verify.
                      Die Meldung Please restart your container im Textfluss geht unter, wenn man nicht ganz genau hinsieht. Kannst du diesen Hinweis etwas prominenter darstellen?
                      Danach erneut iob diag ausführen
                      Skript v.2023-08-12
                      *** BASE SYSTEM ***
                               Chassis: container
                               Boot ID: 3a75cdd6c2ce4a53a75e3c91157c7622
                        Virtualization: lxc
                      Docker          : false
                      Kernel          : x86_64
                      Userland        : amd64
                       22:28:42 up 3 min,  1 user,  load average: 19.30, 17.42, 16.00
                      CPU threads: 4
                                     Local time: Mon 2023-08-14 22:28:42 CEST
                                 Universal time: Mon 2023-08-14 20:28:42 UTC
                                       RTC time: n/a
                                RTC in local TZ: no
                      proxmox
                      /home/proxmox
                      X-Server:       false
                      Desktop:
                      Terminal:       tty
                      *** MEMORY ***
                      Mem:            4.1G        1.7G        1.8G        0.0K        582M        2.4G
                      Swap:           512M          0B        512M
                      Total:          4.6G        1.7G        2.3G
                               4096 M total memory
                               1695 M used memory
                                188 M active memory
                               1972 M inactive memory
                               1818 M free memory
                                  0 M buffer memory
                                582 M swap cache
                                512 M total swap
                                  0 M used swap
                                512 M free swap
                      *** FILESYSTEM ***
                      tmpfs                               tmpfs  3.1G  148K  3.1G   1% /run
                      [sudo] password for proxmox:
                      /var:
                      914M    /var/
                      469M    /var/lib
                      293M    /var/cache
                      287M    /var/cache/apt
                      737M    /opt/iobroker/iobroker-data/
                      19M     /opt/iobroker/iobroker-data/objects.jsonl
                      /usr/bin/npm            9.6.7
                      /usr/bin/npx            9.6.7
                      nodejs:
                        Version table:
                      Errors in npm tree:
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      admin:          6.8.0
                      javascript:     7.1.4
                      Adapter State
                      + instance is alive
                      Objects and States
                      Objects:        13145
                      States:         11802
                      Pending Updates: 3
                      tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          317360475  312/master
                      tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1000       317358721  118/iobroker.js-con
                      tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1000       317358714  118/iobroker.js-con
                      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          317355939  1/init
                      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          317358193  133/sshd: /usr/sbin
                      tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      102        317359166  91/systemd-resolved
                      tcp        0      0 192.168.178.77:8082     0.0.0.0:*               LISTEN      1000       317371974  679/io.web.0
                      tcp6       0      0 ::1:25                  :::*                    LISTEN      0          317360476  312/master
                      tcp6       0      0 :::8081                 :::*                    LISTEN      1000       317357878  372/io.admin.0
                      tcp6       0      0 :::8087                 :::*                    LISTEN      1000       317370670  608/io.simple-api.0
                      tcp6       0      0 :::111                  :::*                    LISTEN      0          317355941  1/init
                      tcp6       0      0 :::22                   :::*                    LISTEN      0          317358204  133/sshd: /usr/sbin
                      tcp6       0      0 :::3000                 :::*                    LISTEN      108        317358632  117/grafana-server
                      udp        0      0 127.0.0.53:53           0.0.0.0:*                           102        317359165  91/systemd-resolved
                      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          317355940  1/init
                      udp6       0      0 :::111                  :::*                                0          317355942  1/init
                      2023-08-14 22:28:59.392  - info: hm-rega.0 (481) added/updated 6 programs
                      2023-08-14 22:28:59.400  - info: hm-rega.0 (481) deleted 0 programs
                      2023-08-14 22:28:59.533  - info: hm-rega.0 (481) update rooms to enum.rooms
                      2023-08-14 22:28:59.622  - info: info.0 (572) cpu Temp res = {"main":66,"cores":[68,66,64,64],"max":68,"socket":[],"chipset":null}
                      2023-08-14 22:29:00.413  - info: hm-rega.0 (481) update functions to enum.functions
                      2023-08-14 22:29:00.587  - info: hm-rega.0 (481) update favorites to enum.favorites
                      2023-08-14 22:29:03.929  - error: daswetter.0 (530) force terminate
                      2023-08-14 22:29:03.964  - warn: daswetter.0 (530) Terminated (UNKNOWN_ERROR): Without reason
                      2023-08-14 22:29:04.493  - error: daswetter.0 (530) exception in await insertIntoList [Error: DB closed]
                      2023-08-14 22:29:04.620  - error: daswetter.0 (530) exception in await insertIntoList [Error: DB closed]
                      2023-08-14 22:29:04.641  - error: daswetter.0 (530) Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_1.Hour_9.symbol_value2": Connection is closed.
                      2023-08-14 22:29:04.661  - error: daswetter.0 (530) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextHours.Location_1.Day_1.Hour_9.symbol_value2: Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_1.Hour_9.symbol_value2": Connection is closed.]
                      2023-08-14 22:29:05.271  - error: host.ioBrokerTestsystem instance system.adapter.daswetter.0 terminated with code 15 (UNKNOWN_ERROR)
                      2023-08-14 22:29:25.224  - info: tankerkoenig.0 (615) Start first request
                      2023-08-14 22:29:38.220  - info: openweathermap.0 (500) Terminated (NO_ERROR): Without reason
                      2023-08-14 22:29:39.128  - info: host.ioBrokerTestsystem instance system.adapter.openweathermap.0 terminated with code 0 (NO_ERROR)
                      2023-08-14 22:30:00.188  - info: host.ioBrokerTestsystem instance system.adapter.dwd.0 started with pid 1358
                      2023-08-14 22:30:04.578  - info: host.ioBrokerTestsystem instance system.adapter.ical.5 started with pid 1365
                      2023-08-14 22:30:16.625  - info: dwd.0 (1358) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.11
                      2023-08-14 22:30:17.904  - info: ical.5 (1365) starting. Version 1.13.3 in /opt/iobroker/node_modules/iobroker.ical, node: v18.17.1, js-controller: 5.0.11
                      2023-08-14 22:30:19.239  - info: dwd.0 (1358) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                      2023-08-14 22:30:19.909  - info: host.ioBrokerTestsystem instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                      2023-08-14 22:30:22.333  - info: ical.5 (1365) processing URL: ioBrokerTesting https://calendar.google.com/calendar/ical/0g7gpl8tcsjsbacjrkunfg8l0c%40group.calendar.google.com/private-ee9dd402778b56aafd5eea5e6f591bd6/basic.ics
                      2023-08-14 22:30:27.616  - info: ical.5 (1365) Terminated (NO_ERROR): Without reason
                      2023-08-14 22:30:28.275  - info: host.ioBrokerTestsystem instance system.adapter.ical.5 terminated with code 0 (NO_ERROR)
                                           v.2023-08-12
                               Chassis: container
                        Virtualization: lxc
                      Installation:           lxc
                      Kernel:                 x86_64
                      Userland:               amd64
                      User-ID:                1001
                      X-Server:               false
                                              /usr/bin/npm            9.6.7
                                              /usr/bin/npx            9.6.7
                      MEMORY:
                      Mem:            4.1G        1.6G        1.6G        0.0K        899M        2.5G
                      Total:          4.6G        1.6G        2.1G
                                              admin                   6.8.0
                      Objects type: jsonl
                      States  type: jsonl
                      Objects:                13145
                      States:                 11802
                      20M     /opt/iobroker/iobroker-data/objects.jsonl
                      7.0M    /opt/iobroker/iobroker-data/states.jsonl
                      FeuersturmF Thomas BraunT 2 Antworten Letzte Antwort
                        Langfassung:
                        nodejs:
                          Version table:
                          nodejs
                        v16.20.2
                        8.19.4
                        Skript v.2023-08-12
                        *** BASE SYSTEM ***
                                 Chassis: container
                          Virtualization: lxc
                        Docker          : false
                        Kernel          : x86_64
                        Userland        : amd64
                        CPU threads: 4
                                         RTC time: n/a
                                  RTC in local TZ: no
                        proxmox
                        /home/proxmox
                        X-Server:       false
                        Desktop:
                        Terminal:       tty
                        *** MEMORY ***
                                 4096 M total memory
                                 1801 M used memory
                                  619 M active memory
                                 1146 M free memory
                                    0 M buffer memory
                                 1147 M swap cache
                                  512 M total swap
                                    0 M used swap
                                  511 M free swap
                        *** FILESYSTEM ***
                        /var:
                        914M    /var/
                        469M    /var/lib
                        293M    /var/cache
                        287M    /var/cache/apt
                        /usr/bin/npm            8.19.4
                        /usr/bin/npx            8.19.4
                        nodejs:
                          Version table:
                        Errors in npm tree:
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        admin:          6.8.0
                        javascript:     7.1.4
                        Adapter State
                        + instance is alive
                        Objects and States
                        Objects:        13145
                        States:         11802
                        Pending Updates: 3
                        Summary
                                             v.2023-08-12
                                 Chassis: container
                          Virtualization: lxc
                        Installation:           lxc
                        Kernel:                 x86_64
                        Userland:               amd64
                        User-ID:                1001
                        X-Server:               false
                                                /usr/bin/npm            8.19.4
                                                /usr/bin/npx            8.19.4
                        MEMORY:
                                                admin                   6.8.0
                        Objects type: jsonl
                        States  type: jsonl
                        Objects:                13145
                        States:                 11802
                        lxc
                        + apt-get update
                        + apt-get update
                          nodejs
                        Skript v.2023-08-12
                        *** BASE SYSTEM ***
                                 Chassis: container
                          Virtualization: lxc
                        Docker          : false
                        Kernel          : x86_64
                        Userland        : amd64
                        CPU threads: 4
                                         RTC time: n/a
                                  RTC in local TZ: no
                        proxmox
                        /home/proxmox
                        X-Server:       false
                        Desktop:
                        Terminal:       tty
                        *** MEMORY ***
                        Swap:           512M          0B        512M
                                 4096 M total memory
                                 1695 M used memory
                                  188 M active memory
                                 1818 M free memory
                                    0 M buffer memory
                                  582 M swap cache
                                  512 M total swap
                                    0 M used swap
                                  512 M free swap
                        *** FILESYSTEM ***
                        /var:
                        914M    /var/
                        469M    /var/lib
                        293M    /var/cache
                        287M    /var/cache/apt
                        /usr/bin/npm            9.6.7
                        /usr/bin/npx            9.6.7
                        nodejs:
                          Version table:
                        Errors in npm tree:
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        admin:          6.8.0
                        javascript:     7.1.4
                        Adapter State
                        + instance is alive
                        Objects and States
                        Objects:        13145
                        States:         11802
                        Pending Updates: 3
                                             v.2023-08-12
                                 Chassis: container
                          Virtualization: lxc
                        Installation:           lxc
                        Kernel:                 x86_64
                        Userland:               amd64
                        User-ID:                1001
                        X-Server:               false
                                                /usr/bin/npm            9.6.7
                                                /usr/bin/npx            9.6.7
                        MEMORY:
                                                admin                   6.8.0
                        Objects type: jsonl
                        States  type: jsonl
                        Objects:                13145
                        States:                 11802
                        FeuersturmF Offline
                        FeuersturmF Offline
                        Feuersturm
                        #558
                        @Thomas-Braun Kleiner Nachtrag zu
                                                /usr/bin/npm            8.19.4
                                                /usr/bin/npx            8.19.4
                        Anstatt Your nodejs installation is correct könnte man hier ausgeben Your nodejs installation is correct and supported but it is not the recommended version
                          Langfassung:
                          nodejs:
                            Version table:
                            nodejs
                          v16.20.2
                          8.19.4
                          Skript v.2023-08-12
                          *** BASE SYSTEM ***
                                   Chassis: container
                            Virtualization: lxc
                          Docker          : false
                          Kernel          : x86_64
                          Userland        : amd64
                          CPU threads: 4
                                           RTC time: n/a
                                    RTC in local TZ: no
                          proxmox
                          /home/proxmox
                          X-Server:       false
                          Desktop:
                          Terminal:       tty
                          *** MEMORY ***
                                   4096 M total memory
                                   1801 M used memory
                                    619 M active memory
                                   1146 M free memory
                                      0 M buffer memory
                                   1147 M swap cache
                                    512 M total swap
                                      0 M used swap
                                    511 M free swap
                          *** FILESYSTEM ***
                          /var:
                          914M    /var/
                          469M    /var/lib
                          293M    /var/cache
                          287M    /var/cache/apt
                          /usr/bin/npm            8.19.4
                          /usr/bin/npx            8.19.4
                          nodejs:
                            Version table:
                          Errors in npm tree:
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          admin:          6.8.0
                          javascript:     7.1.4
                          Adapter State
                          + instance is alive
                          Objects and States
                          Objects:        13145
                          States:         11802
                          Pending Updates: 3
                          Summary
                                               v.2023-08-12
                                   Chassis: container
                            Virtualization: lxc
                          Installation:           lxc
                          Kernel:                 x86_64
                          Userland:               amd64
                          User-ID:                1001
                          X-Server:               false
                                                  /usr/bin/npm            8.19.4
                                                  /usr/bin/npx            8.19.4
                          MEMORY:
                                                  admin                   6.8.0
                          Objects type: jsonl
                          States  type: jsonl
                          Objects:                13145
                          States:                 11802
                          lxc
                          + apt-get update
                          + apt-get update
                            nodejs
                          Skript v.2023-08-12
                          *** BASE SYSTEM ***
                                   Chassis: container
                            Virtualization: lxc
                          Docker          : false
                          Kernel          : x86_64
                          Userland        : amd64
                          CPU threads: 4
                                           RTC time: n/a
                                    RTC in local TZ: no
                          proxmox
                          /home/proxmox
                          X-Server:       false
                          Desktop:
                          Terminal:       tty
                          *** MEMORY ***
                          Swap:           512M          0B        512M
                                   4096 M total memory
                                   1695 M used memory
                                    188 M active memory
                                   1818 M free memory
                                      0 M buffer memory
                                    582 M swap cache
                                    512 M total swap
                                      0 M used swap
                                    512 M free swap
                          *** FILESYSTEM ***
                          /var:
                          914M    /var/
                          469M    /var/lib
                          293M    /var/cache
                          287M    /var/cache/apt
                          /usr/bin/npm            9.6.7
                          /usr/bin/npx            9.6.7
                          nodejs:
                            Version table:
                          Errors in npm tree:
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          admin:          6.8.0
                          javascript:     7.1.4
                          Adapter State
                          + instance is alive
                          Objects and States
                          Objects:        13145
                          States:         11802
                          Pending Updates: 3
                                               v.2023-08-12
                                   Chassis: container
                            Virtualization: lxc
                          Installation:           lxc
                          Kernel:                 x86_64
                          Userland:               amd64
                          User-ID:                1001
                          X-Server:               false
                                                  /usr/bin/npm            9.6.7
                                                  /usr/bin/npx            9.6.7
                          MEMORY:
                                                  admin                   6.8.0
                          Objects type: jsonl
                          States  type: jsonl
                          Objects:                13145
                          States:                 11802
                          #559
                          @feuersturm
                          Jaaaaa, so hatte ich mir das vorgestellt.
                          Text so besser?
                          *** You need to manually restart your container now! ***
                            @feuersturm
                            Text so besser?
                            FeuersturmF Offline
                            FeuersturmF Offline
                            Feuersturm
                            #560
                            @thomas-braun Ja, das fällt besser auf.
                              #561
                              @feuersturm
                              Habs gerade auf github hochgeschubst.
                              • andreA Offline
                                andreA Offline
                                andre
                                #562
                                Bin ich der Einzige der es irgendwie bedenklich findet wenn ein Diagnose-Script auch gefundene Probleme korrigiert statt nur darüber zu informieren? Meines Erachtens sollte ein Diagnosescript 100% safe sein. Also ausschließlich Informationen auslesen.
                                Wo wäre dann sonst der Unterschied zum Fixer-Script? Dann können wir die Diag-Ausgabe doch eigentlich auch direkt in den Fixer einbauen, oder sehe ich das falsch?
                                @apollon77 @foxriver76 @AlCalzone @Bluefox
                                Habt ihr eine Meinung dazu? Sollte das Thema vielleicht auf die Dev-Meeting-Liste? Ich denke das ist in jedem Fall zumindest diskussionswürdig.
                                MfG,
                                André
                                Thomas BraunT HomoranH mcm1957M 3 Antworten Letzte Antwort
                                • andreA andre
                                  MfG,
                                  André
                                  #563
                                  @andre sagte in iob diag - Skript:
                                  Da bin ich dabei.
                                  Ist ja auch eine Beta-Version zum herumspielen. Den Code kann man easy da wieder rausnehmen und in den Fixer (oder ein eigenes Skript integrieren).
                                  War nur für den Moment einfacher das an 'iob diag' anzuhängen.
                                  Den Fix musst du aber auch bestätigen und damit wollen, der wird ja nicht hinterrücks plötzlich ausgeführt.
                                  andreA 1 Antwort Letzte Antwort
                                    Da bin ich dabei.
                                    andreA Offline
                                    andreA Offline
                                    andre
                                    #564
                                    Ok, wollte nur darauf hinweisen, bevor aus dem Diag-Script die "eierlegende Wollmilchsau" wird. So wie das m. E. leider mit dem Backitup-Adapter passiert ist. :)
                                    @thomas-braun sagte in iob diag - Skript:
                                    Ja, das ist richtig. Aber du kennst ja auch die unerfahrenen User... Da erzählt ein Script was von node Version und schon ist ein ioBroker Einsteiger und Linux Neuling gnadenlos überfordert...
                                    MfG,
                                    André
                                    • andreA andre
                                      MfG,
                                      André
                                      #565
                                      Die Resultate der bisherigen Überforderung soll das Ding ja gerade wieder ausbügeln... Bislang schaut das auch ganz gut aus. Tut was es soll.
                                      Komplett zerballerte Dreifach-Installationen von nodejs bekommst du auch mit dem Skript nicht gebändigt. Jedenfalls nicht im ersten Anlauf.
                                        #566
                                        Hab jetzt noch einen Hinweis auf den Beta Code drin:
                                        !!! THIS CODE IS IN BETA STAGE. TRY IT AT YOUR OWN RISK !!!
                                        You are running nodejs v.$NODEUSED. Do you want to install recommended nodejs v.$NODERECOM?
                                        Press <y> to continue or any other key to quit"
                                          FeuersturmF Offline
                                          FeuersturmF Offline
                                          Feuersturm
                                          #567
                                          wenn ich im Terminal von meinem LXC Container ein
                                          sudo reboot
                                          ausführe, wird das System neu gestartet. Hilft dir das?
