  4. iob diag - Skript
iob diag - Skript
863 Beiträge 52 Kommentatoren 308.6k Aufrufe 40 Beobachtet
  • FeuersturmF Feuersturm
    Kurzfassung: Funktioniert :-)
    Langfassung:
    Downgrade nodejs von 18 auf 16
    proxmox@ioBrokerTestsystem:/home$ apt policy nodejs
    nodejs:
      Installed: 18.17.1-deb-1nodesource1
      Candidate: 18.17.1-deb-1nodesource1
      Version table:
     *** 18.17.1-deb-1nodesource1 100
         16.20.2-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_16.x jammy/main amd64 Packages
         12.22.9~dfsg-1ubuntu3 500
            500 http://archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
    proxmox@ioBrokerTestsystem:/home$ sudo apt install nodejs=16.20.2-deb-1nodesource1
    Reading package lists... Done
    The following packages were automatically installed and are no longer required:
      libllvm13 libvulkan1 libwayland-client0 mesa-vulkan-drivers
    Use 'sudo apt autoremove' to remove them.
    The following packages will be DOWNGRADED:
      nodejs
    0 upgraded, 0 newly installed, 1 downgraded, 0 to remove and 3 not upgraded.
    Need to get 27.2 MB of archives.
    After this operation, 60.4 MB disk space will be freed.
    Do you want to continue? [Y/n] y
    Get:1 https://deb.nodesource.com/node_16.x jammy/main amd64 nodejs amd64 16.20.2-deb-1nodesource1 [27.2 MB]
    Fetched 27.2 MB in 4s (6498 kB/s)
    dpkg: warning: downgrading nodejs from 18.17.1-deb-1nodesource1 to 16.20.2-deb-1nodesource1
    (Reading database ... 46660 files and directories currently installed.)
    Preparing to unpack .../nodejs_16.20.2-deb-1nodesource1_amd64.deb ...
    Unpacking nodejs (16.20.2-deb-1nodesource1) over (18.17.1-deb-1nodesource1) ...
    Setting up nodejs (16.20.2-deb-1nodesource1) ...
    Processing triggers for man-db (2.10.2-1) ...
    proxmox@ioBrokerTestsystem:/home$ nodejs -v && npm -v
    v16.20.2
    8.19.4
    danach noch ein iob fix und dann ein iob start ausgeführt.
    iob diag (github version)
    Skript v.2023-08-12
    *** BASE SYSTEM ***
     Static hostname: ioBrokerTestsystem
           Icon name: computer-container
             Chassis: container
          Machine ID: db91a8d9813048b3b0d9627361bf92a2
             Boot ID: 32a84dd282b744a48a6aa21ecc09b231
      Virtualization: lxc
    Operating System: Ubuntu 22.04.3 LTS
              Kernel: Linux 6.2.16-3-pve
        Architecture: x86-64
    model name      : Intel(R) Celeron(R) CPU  N3150  @ 1.60GHz
    Docker          : false
    Virtualization  : lxc
    Kernel          : x86_64
    Userland        : amd64
    Systemuptime and Load:
     22:12:14 up 18:59,  1 user,  load average: 12.95, 13.98, 14.17
    CPU threads: 4
    *** Time and Time Zones ***
                   Local time: Mon 2023-08-14 22:12:14 CEST
               Universal time: Mon 2023-08-14 20:12:14 UTC
                     RTC time: n/a
                  NTP service: inactive
              RTC in local TZ: no
    *** User and Groups ***
    proxmox
    /home/proxmox
    proxmox sudo iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            4.1G        1.8G        1.1G        0.0K        1.1G        2.3G
    Swap:           512M        0.0K        511M
    Total:          4.6G        1.8G        1.7G
             4096 M total memory
             1801 M used memory
              619 M active memory
             2020 M inactive memory
             1146 M free memory
                0 M buffer memory
             1147 M swap cache
              512 M total swap
                0 M used swap
              511 M free swap
    *** FAILED SERVICES ***
      UNIT                   LOAD   ACTIVE SUB    DESCRIPTION
    * run-rpc_pipefs.mount   loaded failed failed RPC Pipe File System
    * sys-kernel-debug.mount loaded failed failed Kernel Debug File System
    2 loaded units listed.
    *** FILESYSTEM ***
    Filesystem                          Type   Size  Used Avail Use% Mounted on
    /dev/mapper/data2-vm--3108--disk--1 ext4    20G   13G  6.3G  67% /
    none                                tmpfs  492K  4.0K  488K   1% /dev
    tmpfs                               tmpfs  7.7G     0  7.7G   0% /dev/shm
    tmpfs                               tmpfs  3.1G  160K  3.1G   1% /run
    tmpfs                               tmpfs  5.0M     0  5.0M   0% /run/lock
    tmpfs                               tmpfs  1.0M     0  1.0M   0% /run/credentials/systemd-sysusers.service
    tmpfs                               tmpfs  1.6G     0  1.6G   0% /run/user/1001
    dmesg: read kernel buffer failed: Operation not permitted
    TARGET SOURCE                              FSTYPE OPTIONS
    /      /dev/mapper/data2-vm--3108--disk--1 ext4   rw,relatime,stripe=16
    /var:
    914M    /var/
    469M    /var/lib
    293M    /var/cache
    287M    /var/cache/apt
    201M    /var/cache/apt/archives
    Archived and active journals take up 16.0M in the file system.
    /opt/iobroker/backups:
    93M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    733M    /opt/iobroker/iobroker-data/
    506M    /opt/iobroker/iobroker-data/files
    162M    /opt/iobroker/iobroker-data/backup-objects
    126M    /opt/iobroker/iobroker-data/files/vis
    118M    /opt/iobroker/iobroker-data/files/vis/widgets
    21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c4efe404.js.map
    20M     /opt/iobroker/iobroker-data/files/fullcalendar.admin/static/js/main.7f5fc837.js.map
    19M     /opt/iobroker/iobroker-data/files/scheduler.admin/static/js/main.df70fdfc.js.map
    18M     /opt/iobroker/iobroker-data/objects.jsonl
    14M     /opt/iobroker/iobroker-data/objects.json.migrated
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v16.20.2
    /usr/bin/node           v16.20.2
    /usr/bin/npm            8.19.4
    /usr/bin/npx            8.19.4
    /usr/bin/corepack       0.17.0
    nodejs:
      Installed: 16.20.2-deb-1nodesource1
      Candidate: 16.20.2-deb-1nodesource1
      Version table:
     *** 16.20.2-deb-1nodesource1 500
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  5.0.11
    admin:          6.8.0
    javascript:     7.1.4
    Adapters from github:   5
    Adapter State
    + system.adapter.admin.0                  : admin                 : ioBrokerTestsystem                       -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.backitup.0               : backitup              : ioBrokerTestsystem                       -  enabled
      system.adapter.benchmark.0              : benchmark             : ioBrokerTestsystem                       - disabled
      system.adapter.daswetter.0              : daswetter             : ioBrokerTestsystem                       -  enabled
    + system.adapter.device-watcher.0         : device-watcher        : ioBrokerTestsystem                       -  enabled
      system.adapter.devices.0                : devices               : ioBrokerTestsystem                       - disabled
      system.adapter.discovery.0              : discovery             : ioBrokerNew                              - disabled
      system.adapter.dwd.0                    : dwd                   : ioBrokerTestsystem                       -  enabled
    + system.adapter.fritzbox.0               : fritzbox              : ioBrokerTestsystem                       -  enabled
      system.adapter.fully-tablet-control.0   : fully-tablet-control  : ioBrokerTestsystem                       - disabled
      system.adapter.history.1                : history               : ioBrokerNew                              - disabled
    + system.adapter.hm-rega.0                : hm-rega               : ioBrokerTestsystem                       -  enabled
      system.adapter.hm-rpc.0                 : hm-rpc                : ioBrokerTestsystem                       - disabled, port: 0
      system.adapter.hue.0                    : hue                   : ioBrokerTestsystem                       - disabled, port: 443
      system.adapter.ical.0                   : ical                  : ioBrokerTestsystem                       - disabled
      system.adapter.ical.1                   : ical                  : ioBrokerTestsystem                       - disabled
      system.adapter.ical.2                   : ical                  : ioBrokerTestsystem                       - disabled
      system.adapter.ical.3                   : ical                  : ioBrokerTestsystem                       - disabled
      system.adapter.ical.4                   : ical                  : ioBrokerTestsystem                       - disabled
      system.adapter.ical.5                   : ical                  : ioBrokerTestsystem                       -  enabled
      system.adapter.icons-material-png.0     : icons-material-png    : ioBrokerTestsystem                       - disabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ioBrokerTestsystem                       - disabled
      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : ioBrokerTestsystem                       - disabled
      system.adapter.influxdb.0               : influxdb              : ioBrokerTestsystem                       - disabled, port: 8086
    + system.adapter.info.0                   : info                  : ioBrokerTestsystem                       -  enabled
    + system.adapter.javascript.0             : javascript            : ioBrokerTestsystem                       -  enabled
      system.adapter.mqtt.0                   : mqtt                  : ioBrokerTestsystem                       - disabled, port: 1883, bind: 0.0.0.0
    + system.adapter.nina.0                   : nina                  : ioBrokerTestsystem                       -  enabled
      system.adapter.openweathermap.0         : openweathermap        : ioBrokerTestsystem                       -  enabled
    + system.adapter.proxmox.0                : proxmox               : ioBrokerTestsystem                       -  enabled, port: 8006
      system.adapter.rainbird.0               : rainbird              : ioBrokerTestsystem                       - disabled
    + system.adapter.samsung-community.0      : samsung-community     : ioBrokerTestsystem                       -  enabled
      system.adapter.sayit.0                  : sayit                 : ioBrokerTestsystem                       - disabled, port: 0
    + system.adapter.scenes.0                 : scenes                : ioBrokerTestsystem                       -  enabled
    + system.adapter.scheduler.0              : scheduler             : ioBrokerTestsystem                       -  enabled
    + system.adapter.simple-api.0             : simple-api            : ioBrokerTestsystem                       -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      system.adapter.socketio.0               : socketio              : ioBrokerTestsystem                       - disabled, port: 8084, bind: 192.168.178.77, run as: admin
      system.adapter.spotify-premium.0        : spotify-premium       : ioBrokerTestsystem                       - disabled
      system.adapter.sql.0                    : sql                   : ioBrokerNew                              - disabled, port: 3306
    + system.adapter.tankerkoenig.0           : tankerkoenig          : ioBrokerTestsystem                       -  enabled
      system.adapter.telegram.0               : telegram              : ioBrokerTestsystem                       - disabled, port: 8443, bind: 0.0.0.0
    + system.adapter.tr-064.0                 : tr-064                : ioBrokerTestsystem                       -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : ioBrokerTestsystem                       -  enabled
    + system.adapter.unifi.0                  : unifi                 : ioBrokerTestsystem                       -  enabled
    + system.adapter.valloxmv.0               : valloxmv              : ioBrokerTestsystem                       -  enabled, port: 80
    + system.adapter.vis-2-beta.0             : vis-2-beta            : ioBrokerTestsystem                       -  enabled
      system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : ioBrokerTestsystem                       -  enabled
      system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : ioBrokerTestsystem                       -  enabled
      system.adapter.vis-2-widgets-jaeger-design.0: vis-2-widgets-jaeger-design: ioBrokerTestsystem                       -  enabled
      system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: ioBrokerTestsystem                       -  enabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : ioBrokerTestsystem                       - disabled
      system.adapter.vis-google-fonts.0       : vis-google-fonts      : ioBrokerTestsystem                       -  enabled
      system.adapter.vis-history.0            : vis-history           : ioBrokerTestsystem                       - disabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : ioBrokerTestsystem                       -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBrokerTestsystem                       - disabled
      system.adapter.vis-justgage.0           : vis-justgage          : ioBrokerTestsystem                       - disabled
      system.adapter.vis-map.0                : vis-map               : ioBrokerTestsystem                       - disabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : ioBrokerTestsystem                       - disabled
      system.adapter.vis-metro.0              : vis-metro             : ioBrokerTestsystem                       -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBrokerTestsystem                       - disabled
      system.adapter.vis.0                    : vis                   : ioBrokerTestsystem                       -  enabled
    + system.adapter.web.0                    : web                   : ioBrokerTestsystem                       -  enabled, port: 8082, bind: 192.168.178.77, run as: admin
      system.adapter.worx.0                   : worx                  : ioBrokerTestsystem                       - disabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): beta
    Installed ioBroker-Instances
    Used repository: beta
    Adapter    "admin"        : 6.8.0    , installed 6.8.0
    Adapter    "backitup"     : 2.7.0    , installed 2.6.23 [Updatable]
    Adapter    "benchmark"    : 1.1.4    , installed 1.1.4
    Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
    Adapter    "device-watcher": 2.9.3   , installed 2.9.3
    Adapter    "devices"      : 1.1.5    , installed 1.1.5
    Adapter    "fritzbox"     : 0.5.0    , installed 0.5.0
    Adapter    "fullcalendar" : 2.2.6    , installed 2.2.2  [Updatable]
    Adapter    "hm-rega"      : 3.0.47   , installed 3.0.47
    Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
    Adapter    "hue"          : 3.9.5    , installed 3.9.5
    Adapter    "ical"         : 1.13.3   , installed 1.13.3
    Adapter    "javascript"   : 7.1.4    , installed 7.1.4
    Controller "js-controller": 5.0.11   , installed 5.0.11
    Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
    Adapter    "nina"         : 0.0.25   , installed 0.0.25
    Adapter    "openweathermap": 0.4.2   , installed 0.4.2
    Adapter    "proxmox"      : 1.3.5    , installed 1.3.5
    Adapter    "rainbird"     : 0.2.2    , installed 0.2.3
    Adapter    "sayit"        : 3.0.5    , installed 3.0.5
    Adapter    "scheduler"    : 1.1.9    , installed 1.1.9
    Adapter    "smartmeter"   : 3.3.4    , installed 3.3.4
    Adapter    "socketio"     : 6.5.2    , installed 6.4.0  [Updatable]
    Adapter    "spotify-premium": 1.2.2  , installed 1.2.2
    Adapter    "telegram"     : 1.16.0   , installed 1.16.0
    Adapter    "trashschedule": 2.2.0    , installed 2.2.0
    Adapter    "unifi"        : 0.6.6    , installed 0.6.6
    Adapter    "valloxmv"     : 1.2.0    , installed 1.2.0
    Adapter    "vis-2-widgets-energy": 0.2.3, installed 0.2.3
    Adapter    "vis-2-widgets-gauges": 0.2.0, installed 0.2.0
    Adapter    "vis-2-widgets-jaeger-design": 1.0.0, installed 1.0.0
    Adapter    "vis-2-widgets-material": 0.8.5, installed 0.8.5
    Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
    Adapter    "web"          : 6.1.0    , installed 6.0.3  [Updatable]
    Adapter    "worx"         : 2.3.2    , installed 2.3.2
    Adapter    "ws"           : 2.5.3    , installed 2.4.0  [Updatable]
    Objects and States
    Objects:        13145
    States:         11802
    Hit:1 https://deb.nodesource.com/node_16.x jammy InRelease
    Hit:2 http://archive.ubuntu.com/ubuntu jammy InRelease
    Hit:3 http://archive.ubuntu.com/ubuntu jammy-updates InRelease
    Hit:4 http://archive.ubuntu.com/ubuntu jammy-security InRelease
    Pending Updates: 3
    *** Listening Ports ***
    tcp        0      0 192.168.178.77:8082     0.0.0.0:*               LISTEN      1000       317245085  45156/io.web.0
    tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      102        311048807  91/systemd-resolved
    tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1000       317230619  44801/iobroker.js-c
    tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1000       317232637  44801/iobroker.js-c
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          311049284  1/init
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          311047903  141/sshd: /usr/sbin
    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          311048905  305/master
    tcp6       0      0 :::8081                 :::*                    LISTEN      1000       317233130  44829/io.admin.0
    tcp6       0      0 :::8087                 :::*                    LISTEN      1000       317245613  45066/io.simple-api
    tcp6       0      0 :::111                  :::*                    LISTEN      0          311049286  1/init
    tcp6       0      0 :::22                   :::*                    LISTEN      0          311047905  141/sshd: /usr/sbin
    tcp6       0      0 :::3000                 :::*                    LISTEN      108        311049073  110/grafana-server
    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          311048906  305/master
    udp        0      0 127.0.0.53:53           0.0.0.0:*                           102        311048806  91/systemd-resolved
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          311049285  1/init
    udp6       0      0 :::111                  :::*                                0          311049287  1/init
    2023-08-14 22:09:24.761  - info: hm-rpc.0 (45672) terminating
    2023-08-14 22:09:24.767  - info: hm-rpc.0 (45672) Terminated (NO_ERROR): Without reason
    2023-08-14 22:09:24.807  - info: hm-rpc.0 (45672) terminating
    2023-08-14 22:09:25.104  - info: hm-rpc.0 (45672) terminating with timeout
    2023-08-14 22:09:26.022  - info: host.ioBrokerTestsystem instance system.adapter.hm-rpc.0 terminated with code 0 (NO_ERROR)
    2023-08-14 22:09:26.027  - info: host.ioBrokerTestsystem Restart adapter system.adapter.hm-rpc.0 because enabled
    2023-08-14 22:09:56.356  - info: host.ioBrokerTestsystem instance system.adapter.hm-rpc.0 started with pid 45692
    2023-08-14 22:10:02.445  - info: hm-rpc.0 (45692) starting. Version 1.15.19 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v16.20.2, js-controller: 5.0.11
    2023-08-14 22:10:03.210  - info: hm-rpc.0 (45692) xmlrpc server is trying to listen on 192.168.178.77:2010
    2023-08-14 22:10:03.214  - info: hm-rpc.0 (45692) xmlrpc client is trying to connect to 192.168.178.84:2010/ with ["http://192.168.178.77:2010","ioBrokerTestsystem:hm-rpc.0:d96698d96618b7431e6c2903595df786"]
    2023-08-14 22:10:03.286  - error: hm-rpc.0 (45692) Init not possible, going to stop: Unknown XML-RPC tag 'TITLE'
    2023-08-14 22:10:33.320  - info: hm-rpc.0 (45692) xmlrpc -> 192.168.178.84:2010/ init ["http://192.168.178.77:2010",""]
    2023-08-14 22:10:33.429  - error: hm-rpc.0 (45692) Init not possible, going to stop: Unknown XML-RPC tag 'TITLE'
    2023-08-14 22:10:33.452  - error: hm-rpc.0 (45692) Cannot call init: [http://192.168.178.77:2010, ""] Unknown XML-RPC tag 'TITLE'
    2023-08-14 22:10:33.486  - info: hm-rpc.0 (45692) terminating
    2023-08-14 22:10:33.490  - info: hm-rpc.0 (45692) Terminated (NO_ERROR): Without reason
    2023-08-14 22:10:34.338  - info: host.ioBrokerTestsystem instance system.adapter.hm-rpc.0 terminated with code 0 (NO_ERROR)
    2023-08-14 22:10:34.341  - info: host.ioBrokerTestsystem Restart adapter system.adapter.hm-rpc.0 because enabled
    2023-08-14 22:11:04.698  - info: host.ioBrokerTestsystem instance system.adapter.hm-rpc.0 started with pid 46399
    2023-08-14 22:11:06.352  - info: host.ioBrokerTestsystem "system.adapter.hm-rpc.0" disabled
    2023-08-14 22:11:06.364  - info: host.ioBrokerTestsystem stopInstance system.adapter.hm-rpc.0 (force=false, process=true)
    2023-08-14 22:11:07.036  - info: host.ioBrokerTestsystem stopInstance system.adapter.hm-rpc.0 send kill signal
    2023-08-14 22:11:08.043  - info: host.ioBrokerTestsystem stopInstance system.adapter.hm-rpc.0 killing pid 46399
    2023-08-14 22:11:08.292  - warn: host.ioBrokerTestsystem instance system.adapter.hm-rpc.0 terminated due to SIGTERM
    2023-08-14 22:11:08.295  - info: host.ioBrokerTestsystem instance system.adapter.hm-rpc.0 terminated with code null ()
    Summary
                         v.2023-08-12
             Chassis: container
      Virtualization: lxc
    Installation:           lxc
    Kernel:                 x86_64
    Userland:               amd64
    User-ID:                1001
    X-Server:               false
    Pending OS-Updates:     3
    Pending iob updates:    5
    Nodejs-Installation:    /usr/bin/nodejs         v16.20.2
                            /usr/bin/npm            8.19.4
                            /usr/bin/npx            8.19.4
    Recommended versions are nodejs 18.17.1 and npm 9.6.7
    MEMORY:
    Mem:            4.1G        1.7G        1.2G        0.0K        1.1G        2.3G
    Active iob-Instances:   22
    ioBroker Core:          js-controller           5.0.11
                            admin                   6.8.0
    Objects type: jsonl
    States  type: jsonl
    Objects:                13145
    States:                 11802
    Size of iob-Database:
    14M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
    2.3M    /opt/iobroker/iobroker-data/objects_BACKUP_153020.json
    1.2M    /opt/iobroker/iobroker-data/objects_REMOTE_153020.json
    5.3M    /opt/iobroker/iobroker-data/states.json.migrated
    5.3M    /opt/iobroker/iobroker-data/states.json.bak.migrated
    4.4M    /opt/iobroker/iobroker-data/states.jsonl
    0       /opt/iobroker/iobroker-data/states.json.broken
    === Mark text until here for copying ===
    You are running nodejs v.16.20.2. Do you want to install recommended nodejs v.18.17.1?
    *** DO NOT TRY THIS FIX ON NON-LINUX-SYSTEMS! ***
    Press <y> to continue or any other key to quit
    lxc
    Waiting for ioBroker to shut down - Give me a minute...
    ## Installing the NodeSource Node.js 18.x repo...
    ## Populating apt-get cache...
    + apt-get update
    Hit:1 http://archive.ubuntu.com/ubuntu jammy InRelease
    Hit:2 http://archive.ubuntu.com/ubuntu jammy-updates InRelease
    Hit:3 http://archive.ubuntu.com/ubuntu jammy-security InRelease
    ## Confirming "jammy" is supported...
    + curl -sLf -o /dev/null 'https://deb.nodesource.com/node_18.x/dists/jammy/Release'
    ## Adding the NodeSource signing key to your keyring...
    + curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | gpg --dearmor | tee /usr/share/keyrings/nodesource.gpg >/dev/null
    ## Creating apt sources list file for the NodeSource Node.js 18.x repo...
    + echo 'deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x jammy main' > /etc/apt/sources.list.d/nodesource.list
    + echo 'deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x jammy main' >> /etc/apt/sources.list.d/nodesource.list
    ## Running `apt-get update` for you...
    + apt-get update
    Get:4 https://deb.nodesource.com/node_18.x jammy InRelease [4563 B]
    Get:5 https://deb.nodesource.com/node_18.x jammy/main amd64 Packages [776 B]
    Fetched 5339 B in 13s (404 B/s)
    ## Run `sudo apt-get install -y nodejs` to install Node.js 18.x and npm
    ## You may also need development tools to build native addons:
         sudo apt-get install gcc g++ make
    ## To install the Yarn package manager, run:
         curl -sL https://dl.yarnpkg.com/debian/pubkey.gpg | gpg --dearmor | sudo tee /usr/share/keyrings/yarnkey.gpg >/dev/null
         echo "deb [signed-by=/usr/share/keyrings/yarnkey.gpg] https://dl.yarnpkg.com/debian stable main" | sudo tee /etc/apt/sources.list.d/yarn.list
         sudo apt-get update && sudo apt-get install yarn
    The following packages will be upgraded:
      nodejs
    1 upgraded, 0 newly installed, 0 to remove and 3 not upgraded.
    Need to get 28.9 MB of archives.
    After this operation, 60.4 MB of additional disk space will be used.
    Get:1 https://deb.nodesource.com/node_18.x jammy/main amd64 nodejs amd64 18.17.1-deb-1nodesource1 [28.9 MB]
    Fetched 28.9 MB in 7s (4254 kB/s)
    (Reading database ... 44173 files and directories currently installed.)
    Preparing to unpack .../nodejs_18.17.1-deb-1nodesource1_amd64.deb ...
    Unpacking nodejs (18.17.1-deb-1nodesource1) over (16.20.2-deb-1nodesource1) ...
    Setting up nodejs (18.17.1-deb-1nodesource1) ...
    Please restart your container
    We tried our best to fix your nodejs. Please run 'iob diag' again to verify.
    Die Meldung Please restart your container im Textfluss geht unter, wenn man nicht ganz genau hinsieht. Kannst du diesen Hinweis etwas prominenter darstellen?
    Danach erneut iob diag ausführen
    Skript v.2023-08-12
    *** BASE SYSTEM ***
             Chassis: container
             Boot ID: 3a75cdd6c2ce4a53a75e3c91157c7622
      Virtualization: lxc
    Docker          : false
    Kernel          : x86_64
    Userland        : amd64
     22:28:42 up 3 min,  1 user,  load average: 19.30, 17.42, 16.00
    CPU threads: 4
                   Local time: Mon 2023-08-14 22:28:42 CEST
               Universal time: Mon 2023-08-14 20:28:42 UTC
                     RTC time: n/a
              RTC in local TZ: no
    proxmox
    /home/proxmox
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            4.1G        1.7G        1.8G        0.0K        582M        2.4G
    Swap:           512M          0B        512M
    Total:          4.6G        1.7G        2.3G
             4096 M total memory
             1695 M used memory
              188 M active memory
             1972 M inactive memory
             1818 M free memory
                0 M buffer memory
              582 M swap cache
              512 M total swap
                0 M used swap
              512 M free swap
    *** FILESYSTEM ***
    tmpfs                               tmpfs  3.1G  148K  3.1G   1% /run
    [sudo] password for proxmox:
    /var:
    914M    /var/
    469M    /var/lib
    293M    /var/cache
    287M    /var/cache/apt
    737M    /opt/iobroker/iobroker-data/
    19M     /opt/iobroker/iobroker-data/objects.jsonl
    /usr/bin/nodejs         v18.17.1
    /usr/bin/node           v18.17.1
    /usr/bin/npm            9.6.7
    /usr/bin/npx            9.6.7
    /usr/bin/corepack       0.18.0
    nodejs:
      Version table:
     *** 18.17.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x jammy/main amd64 Packages
    Errors in npm tree:
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    admin:          6.8.0
    javascript:     7.1.4
    Adapter State
    + instance is alive
    Objects and States
    Objects:        13145
    States:         11802
    Hit:3 https://deb.nodesource.com/node_18.x jammy InRelease
    Pending Updates: 3
    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          317360475  312/master
    tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1000       317358721  118/iobroker.js-con
    tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1000       317358714  118/iobroker.js-con
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          317355939  1/init
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          317358193  133/sshd: /usr/sbin
    tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      102        317359166  91/systemd-resolved
    tcp        0      0 192.168.178.77:8082     0.0.0.0:*               LISTEN      1000       317371974  679/io.web.0
    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          317360476  312/master
    tcp6       0      0 :::8081                 :::*                    LISTEN      1000       317357878  372/io.admin.0
    tcp6       0      0 :::8087                 :::*                    LISTEN      1000       317370670  608/io.simple-api.0
    tcp6       0      0 :::111                  :::*                    LISTEN      0          317355941  1/init
    tcp6       0      0 :::22                   :::*                    LISTEN      0          317358204  133/sshd: /usr/sbin
    tcp6       0      0 :::3000                 :::*                    LISTEN      108        317358632  117/grafana-server
    udp        0      0 127.0.0.53:53           0.0.0.0:*                           102        317359165  91/systemd-resolved
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          317355940  1/init
    udp6       0      0 :::111                  :::*                                0          317355942  1/init
    2023-08-14 22:28:59.392  - info: hm-rega.0 (481) added/updated 6 programs
    2023-08-14 22:28:59.400  - info: hm-rega.0 (481) deleted 0 programs
    2023-08-14 22:28:59.533  - info: hm-rega.0 (481) update rooms to enum.rooms
    2023-08-14 22:28:59.622  - info: info.0 (572) cpu Temp res = {"main":66,"cores":[68,66,64,64],"max":68,"socket":[],"chipset":null}
    2023-08-14 22:29:00.413  - info: hm-rega.0 (481) update functions to enum.functions
    2023-08-14 22:29:00.587  - info: hm-rega.0 (481) update favorites to enum.favorites
    2023-08-14 22:29:03.929  - error: daswetter.0 (530) force terminate
    2023-08-14 22:29:03.964  - warn: daswetter.0 (530) Terminated (UNKNOWN_ERROR): Without reason
    2023-08-14 22:29:04.493  - error: daswetter.0 (530) exception in await insertIntoList [Error: DB closed]
    2023-08-14 22:29:04.620  - error: daswetter.0 (530) exception in await insertIntoList [Error: DB closed]
    2023-08-14 22:29:04.641  - error: daswetter.0 (530) Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_1.Hour_9.symbol_value2": Connection is closed.
    2023-08-14 22:29:04.661  - error: daswetter.0 (530) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextHours.Location_1.Day_1.Hour_9.symbol_value2: Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_1.Hour_9.symbol_value2": Connection is closed.]
    2023-08-14 22:29:05.271  - error: host.ioBrokerTestsystem instance system.adapter.daswetter.0 terminated with code 15 (UNKNOWN_ERROR)
    2023-08-14 22:29:25.224  - info: tankerkoenig.0 (615) Start first request
    2023-08-14 22:29:38.220  - info: openweathermap.0 (500) Terminated (NO_ERROR): Without reason
    2023-08-14 22:29:39.128  - info: host.ioBrokerTestsystem instance system.adapter.openweathermap.0 terminated with code 0 (NO_ERROR)
    2023-08-14 22:30:00.188  - info: host.ioBrokerTestsystem instance system.adapter.dwd.0 started with pid 1358
    2023-08-14 22:30:04.578  - info: host.ioBrokerTestsystem instance system.adapter.ical.5 started with pid 1365
    2023-08-14 22:30:16.625  - info: dwd.0 (1358) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.11
    2023-08-14 22:30:17.904  - info: ical.5 (1365) starting. Version 1.13.3 in /opt/iobroker/node_modules/iobroker.ical, node: v18.17.1, js-controller: 5.0.11
    2023-08-14 22:30:19.239  - info: dwd.0 (1358) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-08-14 22:30:19.909  - info: host.ioBrokerTestsystem instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-08-14 22:30:22.333  - info: ical.5 (1365) processing URL: ioBrokerTesting https://calendar.google.com/calendar/ical/0g7gpl8tcsjsbacjrkunfg8l0c%40group.calendar.google.com/private-ee9dd402778b56aafd5eea5e6f591bd6/basic.ics
    2023-08-14 22:30:27.616  - info: ical.5 (1365) Terminated (NO_ERROR): Without reason
    2023-08-14 22:30:28.275  - info: host.ioBrokerTestsystem instance system.adapter.ical.5 terminated with code 0 (NO_ERROR)
                         v.2023-08-12
             Chassis: container
      Virtualization: lxc
    Installation:           lxc
    Kernel:                 x86_64
    Userland:               amd64
    User-ID:                1001
    X-Server:               false
    Nodejs-Installation:    /usr/bin/nodejs         v18.17.1
                            /usr/bin/npm            9.6.7
                            /usr/bin/npx            9.6.7
    MEMORY:
    Mem:            4.1G        1.6G        1.6G        0.0K        899M        2.5G
    Total:          4.6G        1.6G        2.1G
                            admin                   6.8.0
    Objects type: jsonl
    States  type: jsonl
    Objects:                13145
    States:                 11802
    20M     /opt/iobroker/iobroker-data/objects.jsonl
    7.0M    /opt/iobroker/iobroker-data/states.jsonl
    FeuersturmF Offline
    FeuersturmF Offline
    Feuersturm
    #558
    @Thomas-Braun Kleiner Nachtrag zu
                            /usr/bin/npm            8.19.4
                            /usr/bin/npx            8.19.4
    Anstatt Your nodejs installation is correct könnte man hier ausgeben Your nodejs installation is correct and supported but it is not the recommended version
      Langfassung:
      nodejs:
        Version table:
        nodejs
      v16.20.2
      8.19.4
      Skript v.2023-08-12
      *** BASE SYSTEM ***
               Chassis: container
        Virtualization: lxc
      Docker          : false
      Kernel          : x86_64
      Userland        : amd64
      CPU threads: 4
                       RTC time: n/a
                RTC in local TZ: no
      proxmox
      /home/proxmox
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
               4096 M total memory
               1801 M used memory
                619 M active memory
               1146 M free memory
                  0 M buffer memory
               1147 M swap cache
                512 M total swap
                  0 M used swap
                511 M free swap
      *** FILESYSTEM ***
      /var:
      914M    /var/
      469M    /var/lib
      293M    /var/cache
      287M    /var/cache/apt
      /usr/bin/npm            8.19.4
      /usr/bin/npx            8.19.4
      nodejs:
        Version table:
      Errors in npm tree:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          6.8.0
      javascript:     7.1.4
      Adapter State
      + instance is alive
      Objects and States
      Objects:        13145
      States:         11802
      Pending Updates: 3
      Summary
                           v.2023-08-12
               Chassis: container
        Virtualization: lxc
      Installation:           lxc
      Kernel:                 x86_64
      Userland:               amd64
      User-ID:                1001
      X-Server:               false
                              /usr/bin/npm            8.19.4
                              /usr/bin/npx            8.19.4
      MEMORY:
                              admin                   6.8.0
      Objects type: jsonl
      States  type: jsonl
      Objects:                13145
      States:                 11802
      lxc
      + apt-get update
      + apt-get update
        nodejs
      Skript v.2023-08-12
      *** BASE SYSTEM ***
               Chassis: container
        Virtualization: lxc
      Docker          : false
      Kernel          : x86_64
      Userland        : amd64
      CPU threads: 4
                       RTC time: n/a
                RTC in local TZ: no
      proxmox
      /home/proxmox
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:           512M          0B        512M
               4096 M total memory
               1695 M used memory
                188 M active memory
               1818 M free memory
                  0 M buffer memory
                582 M swap cache
                512 M total swap
                  0 M used swap
                512 M free swap
      *** FILESYSTEM ***
      /var:
      914M    /var/
      469M    /var/lib
      293M    /var/cache
      287M    /var/cache/apt
      /usr/bin/npm            9.6.7
      /usr/bin/npx            9.6.7
      nodejs:
        Version table:
      Errors in npm tree:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          6.8.0
      javascript:     7.1.4
      Adapter State
      + instance is alive
      Objects and States
      Objects:        13145
      States:         11802
      Pending Updates: 3
                           v.2023-08-12
               Chassis: container
        Virtualization: lxc
      Installation:           lxc
      Kernel:                 x86_64
      Userland:               amd64
      User-ID:                1001
      X-Server:               false
                              /usr/bin/npm            9.6.7
                              /usr/bin/npx            9.6.7
      MEMORY:
                              admin                   6.8.0
      Objects type: jsonl
      States  type: jsonl
      Objects:                13145
      States:                 11802
      #559
      @feuersturm
      Jaaaaa, so hatte ich mir das vorgestellt.
      Text so besser?
      *** You need to manually restart your container now! ***
        @feuersturm
        Text so besser?
        FeuersturmF Offline
        FeuersturmF Offline
        Feuersturm
        #560
        @thomas-braun Ja, das fällt besser auf.
          #561
          @feuersturm
          Habs gerade auf github hochgeschubst.
          • andreA Offline
            andreA Offline
            andre
            #562
            Bin ich der Einzige der es irgendwie bedenklich findet wenn ein Diagnose-Script auch gefundene Probleme korrigiert statt nur darüber zu informieren? Meines Erachtens sollte ein Diagnosescript 100% safe sein. Also ausschließlich Informationen auslesen.
            Wo wäre dann sonst der Unterschied zum Fixer-Script? Dann können wir die Diag-Ausgabe doch eigentlich auch direkt in den Fixer einbauen, oder sehe ich das falsch?
            @apollon77 @foxriver76 @AlCalzone @Bluefox
            Habt ihr eine Meinung dazu? Sollte das Thema vielleicht auf die Dev-Meeting-Liste? Ich denke das ist in jedem Fall zumindest diskussionswürdig.
            MfG,
            André
            Thomas BraunT HomoranH mcm1957M 3 Antworten Letzte Antwort
            • andreA andre
              MfG,
              André
              #563
              @andre sagte in iob diag - Skript:
              Da bin ich dabei.
              Ist ja auch eine Beta-Version zum herumspielen. Den Code kann man easy da wieder rausnehmen und in den Fixer (oder ein eigenes Skript integrieren).
              War nur für den Moment einfacher das an 'iob diag' anzuhängen.
              Den Fix musst du aber auch bestätigen und damit wollen, der wird ja nicht hinterrücks plötzlich ausgeführt.
              andreA 1 Antwort Letzte Antwort
                Da bin ich dabei.
                andreA Offline
                andreA Offline
                andre
                #564
                Ok, wollte nur darauf hinweisen, bevor aus dem Diag-Script die "eierlegende Wollmilchsau" wird. So wie das m. E. leider mit dem Backitup-Adapter passiert ist. :)
                @thomas-braun sagte in iob diag - Skript:
                Ja, das ist richtig. Aber du kennst ja auch die unerfahrenen User... Da erzählt ein Script was von node Version und schon ist ein ioBroker Einsteiger und Linux Neuling gnadenlos überfordert...
                MfG,
                André
                • andreA andre
                  MfG,
                  André
                  #565
                  Die Resultate der bisherigen Überforderung soll das Ding ja gerade wieder ausbügeln... Bislang schaut das auch ganz gut aus. Tut was es soll.
                  Komplett zerballerte Dreifach-Installationen von nodejs bekommst du auch mit dem Skript nicht gebändigt. Jedenfalls nicht im ersten Anlauf.
                    #566
                    Hab jetzt noch einen Hinweis auf den Beta Code drin:
                    !!! THIS CODE IS IN BETA STAGE. TRY IT AT YOUR OWN RISK !!!
                    You are running nodejs v.$NODEUSED. Do you want to install recommended nodejs v.$NODERECOM?
                    Press <y> to continue or any other key to quit"
                      @feuersturm sagte in iob diag - Skript:
                      Wenn die zweite Stufe implementiert ist kann ich dies auch gerne einmal testen.
                      Ist schon drin. Wird nur angeboten, wenn eine abweichende Version läuft.
                      Achtung, dein iobroker wird da gestoppt und du musst den Container dann neustarten. Gibt aber Hinweise im Text.
                      Für einen geskripteten Restart eines Containers hab ich zu wenig Plan davon. Bei nativen Installationen wird der ioBroker auch wieder vom Skript gestartet.
                      FeuersturmF Offline
                      FeuersturmF Offline
                      Feuersturm
                      #567
                      wenn ich im Terminal von meinem LXC Container ein
                      sudo reboot
                      ausführe, wird das System neu gestartet. Hilft dir das?
                      • andreA andre
                        MfG,
                        André
                        #568
                        nein! zumal da noch ein paar offene Fragen sind
                        z.B.
                        @homoran sagte in iob diag - Skript:
                        @thomas-braun Wenn ich das quer durch's Forum richtig verfolgt habe, waren ältere Versionen von nicht mehr unterstützen Node-Versionen der Auslöser für diese sinnvolle Erweiterung/Ergänzung.
                        Was passiert denn wenn ein User mit node 6 (oder realistischer mit node 14) jetzt iob diag aufruft?
                        auch deine Anregung
                        Ich denke
                        iob fix
                        wäre der richtige Aufruf für Änderungen/ Korrekturen.
                        halte ich nicht unbedingt für due beste Alternative.
                        Bisher hat iob fix nur die Berechtigungen geradegebogen. das wurde auch jahrelang so kommuniziert.
                        Wenn dann ein weiterer Befehl dazukommt sollte er anders heißen. Ich hab da auch noch keine Eingebung.
                        Wir begeben uns hier auf ganz neues Terrain, auch wenn es für Noobs sehr zu wünschen ist, sind wir jetzt außerhalb von iobroker.
                        Und um gerade das Zielklientel zu erreichen, die bisher ihre Systeme nicht antatschten, muss das ganze wirklich sauber zu Ende gedacht und ggf. alles mögliche abgefangen werden können
                          sudo reboot
                          #569
                          Das wäre easy. Was meinen die anderen Container-Schiffer?
                            z.B.
                            auch deine Anregung
                            Ich denke
                            iob fix
                            #570
                            iob nodefix vielleicht?
                            HomoranH andreA 2 Antworten Letzte Antwort
                              #571
                              das war mein bisheriger Favorit, da ohne iob node fix nicht gerade sauber sein wird
                                #572
                                Nein,
                                node fix
                                geht nicht, node command ist eine andere Baustelle.
                                  Nein,
                                  node fix
                                  #573
                                  Nein,
                                  node fix
                                  eben! aber da es nix mit iob zu tun hat wollte ich am liebsten auch kein iob im Befehl haben.
                                  Wird aber wahrscheinlich kein anderer merken.
                                  Als nächstes dann iob OS fix
                                  Thomas BraunT FeuersturmF 2 Antworten Letzte Antwort
                                    Nein,
                                    node fix
                                    #574
                                    Nein, rein technisch natürlich nicht. Wird der Zielgruppe aber vermutlich relativ schnuppe sein.
                                      Nein,
                                      node fix
                                      FeuersturmF Offline
                                      FeuersturmF Offline
                                      Feuersturm
                                      #575
                                      @homoran Ich würde argumentieren, das es ein Helferlein für ioBroker ist, um das Grundgerüst von iobroker zu reparieren. ich finde ein iob nodefix daher sehr sprechend.
                                        z.B.
                                        auch deine Anregung
                                        Ich denke
                                        iob fix
                                        #576
                                        Wobei das ja auch nicht stimmt. setcaps und einige Pakete werden auch (neu)installiert. Ein bischen mehr als nur die Berechtigungen macht iob fix bzw. der Installer auch schon. Das nachinstallieren von 'cmake' ist aus Sicht der Systemsicherheit eigentlich auch ein Alptraum. Damit gibst du z. B. einem Eindringling ein weiteres Werkzeug zum bauen von Schadcode an die Hand.
                                        Das würde dir jeder Sysadmin rechts und links um die Ohren hauen. Zu recht.
                                          #577
                                          richtig, sehe ich auch so.
                                          wo fängt das an und wo hört es auf?
                                          Bitte icht missverstehen!
                                          für die Zielgruppe ist so etwas Gold wert!
                                          es wir nur sehr wenige geben, due in Linux so frei jonglieren können wie Thomas, und immer noch wenige, due sich da rantrauen, die HowTos nachzubauen.
                                          So ganz abwegig war daher der iob linuxfix auch nicht, wenn ich da per Knopfdruck "nur" die Quellen auf den neuen Namen schreiben muss, ein update und ein full-upgrade fahren, und alle sind up to date und glücklich.
