  4. iob diag - Skript
iob diag - Skript
863 Beiträge 52 Kommentatoren 308.5k Aufrufe 40 Beobachtet
  • FeuersturmF Feuersturm
    @thomas-braun Na dann wollen wir mal :-)
    iob fix vorab auf meinem Testsystem ausgeführt
    Skript v.2023-04-16
    *** BASE SYSTEM ***
    Architecture    : x86_64
    Docker          : false
    Virtualization  : lxc
    Distributor ID: Ubuntu
    Description:    Ubuntu 22.04.3 LTS
    Release:        22.04
    Codename:       jammy
    PRETTY_NAME="Ubuntu 22.04.3 LTS"
    NAME="Ubuntu"
    VERSION_ID="22.04"
    VERSION="22.04.3 LTS (Jammy Jellyfish)"
    VERSION_CODENAME=jammy
    ID=ubuntu
    ID_LIKE=debian
    HOME_URL="https://www.ubuntu.com/"
    SUPPORT_URL="https://help.ubuntu.com/"
    BUG_REPORT_URL="https://bugs.launchpad.net/ubuntu/"
    PRIVACY_POLICY_URL="https://www.ubuntu.com/legal/terms-and-policies/privacy-policy"
    UBUNTU_CODENAME=jammy
    Systemuptime and Load:
     20:04:08 up 16:51,  2 users,  load average: 18.21, 15.76, 15.08
    CPU threads: 4
    *** Time and Time Zones ***
                   Local time: Mon 2023-08-14 20:04:10 CEST
               Universal time: Mon 2023-08-14 18:04:10 UTC
                     RTC time: n/a
                  NTP service: inactive
              RTC in local TZ: no
    *** User and Groups ***
    proxmox
    /home/proxmox
    proxmox sudo iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            4.1G        2.1G        959M        0.0K        1.0G        2.0G
    Swap:           512M        0.0K        511M
    Total:          4.6G        2.1G        1.5G
             4096 M total memory
             2127 M used memory
              475 M active memory
             2344 M inactive memory
              958 M free memory
                0 M buffer memory
             1010 M swap cache
              512 M total swap
                0 M used swap
              511 M free swap
    *** FILESYSTEM ***
    Filesystem                          Type   Size  Used Avail Use% Mounted on
    /dev/mapper/data2-vm--3108--disk--1 ext4    20G   13G  6.3G  67% /
    none                                tmpfs  492K  4.0K  488K   1% /dev
    tmpfs                               tmpfs  7.7G     0  7.7G   0% /dev/shm
    tmpfs                               tmpfs  3.1G  156K  3.1G   1% /run
    tmpfs                               tmpfs  5.0M     0  5.0M   0% /run/lock
    tmpfs                               tmpfs  1.0M     0  1.0M   0% /run/credentials/systemd-sysusers.service
    tmpfs                               tmpfs  1.6G     0  1.6G   0% /run/user/1001
    dmesg: read kernel buffer failed: Operation not permitted
    TARGET SOURCE                              FSTYPE OPTIONS
    /      /dev/mapper/data2-vm--3108--disk--1 ext4   rw,relatime,stripe=16
    /var:
    914M    /var/
    469M    /var/lib
    293M    /var/cache
    287M    /var/cache/apt
    201M    /var/cache/apt/archives
    Archived and active journals take up 16.0M in the file system.
    /opt/iobroker/backups:
    93M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    731M    /opt/iobroker/iobroker-data/
    506M    /opt/iobroker/iobroker-data/files
    162M    /opt/iobroker/iobroker-data/backup-objects
    126M    /opt/iobroker/iobroker-data/files/vis
    118M    /opt/iobroker/iobroker-data/files/vis/widgets
    21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c4efe404.js.map
    20M     /opt/iobroker/iobroker-data/files/fullcalendar.admin/static/js/main.7f5fc837.js.map
    19M     /opt/iobroker/iobroker-data/files/scheduler.admin/static/js/main.df70fdfc.js.map
    17M     /opt/iobroker/iobroker-data/objects.jsonl
    14M     /opt/iobroker/iobroker-data/objects.json.migrated
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.17.1
    /usr/bin/node           v18.17.1
    /usr/bin/npm            9.6.7
    /usr/bin/npx            9.6.7
    nodejs:
      Installed: 18.17.1-deb-1nodesource1
      Candidate: 18.17.1-deb-1nodesource1
      Version table:
     *** 18.17.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x jammy/main amd64 Packages
         12.22.9~dfsg-1ubuntu3 500
            500 http://archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
    No problems detected
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  5.0.11
    admin:          6.8.0
    javascript:     7.1.4
    Adapters from github:   5
    Adapter State
    + system.adapter.admin.0                  : admin                 : ioBrokerTestsystem                       -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.backitup.0               : backitup              : ioBrokerTestsystem                       -  enabled
      system.adapter.benchmark.0              : benchmark             : ioBrokerTestsystem                       - disabled
      system.adapter.daswetter.0              : daswetter             : ioBrokerTestsystem                       -  enabled
    + system.adapter.device-watcher.0         : device-watcher        : ioBrokerTestsystem                       -  enabled
      system.adapter.devices.0                : devices               : ioBrokerTestsystem                       - disabled
      system.adapter.discovery.0              : discovery             : ioBrokerNew                              - disabled
      system.adapter.dwd.0                    : dwd                   : ioBrokerTestsystem                       -  enabled
    + system.adapter.fritzbox.0               : fritzbox              : ioBrokerTestsystem                       -  enabled
      system.adapter.fully-tablet-control.0   : fully-tablet-control  : ioBrokerTestsystem                       - disabled
      system.adapter.history.1                : history               : ioBrokerNew                              - disabled
    + system.adapter.hm-rega.0                : hm-rega               : ioBrokerTestsystem                       -  enabled
      system.adapter.hm-rpc.0                 : hm-rpc                : ioBrokerTestsystem                       -  enabled, port: 0
      system.adapter.hue.0                    : hue                   : ioBrokerTestsystem                       - disabled, port: 443
      system.adapter.ical.0                   : ical                  : ioBrokerTestsystem                       - disabled
      system.adapter.ical.1                   : ical                  : ioBrokerTestsystem                       - disabled
      system.adapter.ical.2                   : ical                  : ioBrokerTestsystem                       - disabled
      system.adapter.ical.3                   : ical                  : ioBrokerTestsystem                       - disabled
      system.adapter.ical.4                   : ical                  : ioBrokerTestsystem                       - disabled
      system.adapter.ical.5                   : ical                  : ioBrokerTestsystem                       -  enabled
      system.adapter.icons-material-png.0     : icons-material-png    : ioBrokerTestsystem                       - disabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ioBrokerTestsystem                       - disabled
      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : ioBrokerTestsystem                       - disabled
      system.adapter.influxdb.0               : influxdb              : ioBrokerTestsystem                       - disabled, port: 8086
    + system.adapter.info.0                   : info                  : ioBrokerTestsystem                       -  enabled
    + system.adapter.javascript.0             : javascript            : ioBrokerTestsystem                       -  enabled
      system.adapter.mqtt.0                   : mqtt                  : ioBrokerTestsystem                       - disabled, port: 1883, bind: 0.0.0.0
    + system.adapter.nina.0                   : nina                  : ioBrokerTestsystem                       -  enabled
      system.adapter.openweathermap.0         : openweathermap        : ioBrokerTestsystem                       -  enabled
    + system.adapter.proxmox.0                : proxmox               : ioBrokerTestsystem                       -  enabled, port: 8006
      system.adapter.rainbird.0               : rainbird              : ioBrokerTestsystem                       - disabled
    + system.adapter.samsung-community.0      : samsung-community     : ioBrokerTestsystem                       -  enabled
      system.adapter.sayit.0                  : sayit                 : ioBrokerTestsystem                       - disabled, port: 0
    + system.adapter.scenes.0                 : scenes                : ioBrokerTestsystem                       -  enabled
    + system.adapter.scheduler.0              : scheduler             : ioBrokerTestsystem                       -  enabled
    + system.adapter.simple-api.0             : simple-api            : ioBrokerTestsystem                       -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      system.adapter.socketio.0               : socketio              : ioBrokerTestsystem                       - disabled, port: 8084, bind: 192.168.178.77, run as: admin
      system.adapter.spotify-premium.0        : spotify-premium       : ioBrokerTestsystem                       - disabled
      system.adapter.sql.0                    : sql                   : ioBrokerNew                              - disabled, port: 3306
    + system.adapter.tankerkoenig.0           : tankerkoenig          : ioBrokerTestsystem                       -  enabled
      system.adapter.telegram.0               : telegram              : ioBrokerTestsystem                       - disabled, port: 8443, bind: 0.0.0.0
    + system.adapter.tr-064.0                 : tr-064                : ioBrokerTestsystem                       -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : ioBrokerTestsystem                       -  enabled
    + system.adapter.unifi.0                  : unifi                 : ioBrokerTestsystem                       -  enabled
    + system.adapter.valloxmv.0               : valloxmv              : ioBrokerTestsystem                       -  enabled, port: 80
    + system.adapter.vis-2-beta.0             : vis-2-beta            : ioBrokerTestsystem                       -  enabled
      system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : ioBrokerTestsystem                       -  enabled
      system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : ioBrokerTestsystem                       -  enabled
      system.adapter.vis-2-widgets-jaeger-design.0: vis-2-widgets-jaeger-design: ioBrokerTestsystem                       -  enabled
      system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: ioBrokerTestsystem                       -  enabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : ioBrokerTestsystem                       - disabled
      system.adapter.vis-google-fonts.0       : vis-google-fonts      : ioBrokerTestsystem                       -  enabled
      system.adapter.vis-history.0            : vis-history           : ioBrokerTestsystem                       - disabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : ioBrokerTestsystem                       -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBrokerTestsystem                       - disabled
      system.adapter.vis-justgage.0           : vis-justgage          : ioBrokerTestsystem                       - disabled
      system.adapter.vis-map.0                : vis-map               : ioBrokerTestsystem                       - disabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : ioBrokerTestsystem                       - disabled
      system.adapter.vis-metro.0              : vis-metro             : ioBrokerTestsystem                       -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBrokerTestsystem                       - disabled
      system.adapter.vis.0                    : vis                   : ioBrokerTestsystem                       -  enabled
    + system.adapter.web.0                    : web                   : ioBrokerTestsystem                       -  enabled, port: 8082, bind: 192.168.178.77, run as: admin
      system.adapter.worx.0                   : worx                  : ioBrokerTestsystem                       - disabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): beta
    Installed ioBroker-Instances
    Used repository: beta
    Adapter    "admin"        : 6.8.0    , installed 6.8.0
    Adapter    "backitup"     : 2.7.0    , installed 2.6.23 [Updatable]
    Adapter    "benchmark"    : 1.1.4    , installed 1.1.4
    Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
    Adapter    "device-watcher": 2.9.3   , installed 2.9.3
    Adapter    "devices"      : 1.1.5    , installed 1.1.5
    Adapter    "fritzbox"     : 0.5.0    , installed 0.5.0
    Adapter    "fullcalendar" : 2.2.6    , installed 2.2.2  [Updatable]
    Adapter    "hm-rega"      : 3.0.47   , installed 3.0.47
    Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
    Adapter    "hue"          : 3.9.5    , installed 3.9.5
    Adapter    "ical"         : 1.13.3   , installed 1.13.3
    Adapter    "javascript"   : 7.1.4    , installed 7.1.4
    Controller "js-controller": 5.0.11   , installed 5.0.11
    Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
    Adapter    "nina"         : 0.0.25   , installed 0.0.25
    Adapter    "openweathermap": 0.4.2   , installed 0.4.2
    Adapter    "proxmox"      : 1.3.5    , installed 1.3.5
    Adapter    "rainbird"     : 0.2.2    , installed 0.2.3
    Adapter    "sayit"        : 3.0.5    , installed 3.0.5
    Adapter    "scheduler"    : 1.1.9    , installed 1.1.9
    Adapter    "smartmeter"   : 3.3.4    , installed 3.3.4
    Adapter    "socketio"     : 6.5.2    , installed 6.4.0  [Updatable]
    Adapter    "spotify-premium": 1.2.2  , installed 1.2.2
    Adapter    "telegram"     : 1.16.0   , installed 1.16.0
    Adapter    "trashschedule": 2.2.0    , installed 2.2.0
    Adapter    "unifi"        : 0.6.6    , installed 0.6.6
    Adapter    "valloxmv"     : 1.2.0    , installed 1.2.0
    Adapter    "vis-2-widgets-energy": 0.2.3, installed 0.2.3
    Adapter    "vis-2-widgets-gauges": 0.2.0, installed 0.2.0
    Adapter    "vis-2-widgets-jaeger-design": 1.0.0, installed 1.0.0
    Adapter    "vis-2-widgets-material": 0.8.5, installed 0.8.5
    Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
    Adapter    "web"          : 6.1.0    , installed 6.0.3  [Updatable]
    Adapter    "worx"         : 2.3.2    , installed 2.3.2
    Adapter    "ws"           : 2.5.3    , installed 2.4.0  [Updatable]
    Objects and States
    Objects:        13145
    States:         11802
    Hit:1 http://archive.ubuntu.com/ubuntu jammy InRelease
    Hit:2 http://archive.ubuntu.com/ubuntu jammy-updates InRelease
    Hit:3 http://archive.ubuntu.com/ubuntu jammy-security InRelease
    Hit:4 https://deb.nodesource.com/node_18.x jammy InRelease
    Reading package lists...
    Pending Updates: 3
    *** Listening Ports ***
    tcp        0      0 192.168.178.77:8082     0.0.0.0:*               LISTEN      1000       316603498  35631/io.web.0
    tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      102        311048807  91/systemd-resolved
    tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1000       316587698  35266/iobroker.js-c
    tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1000       316585912  35266/iobroker.js-c
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          311049284  1/init
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          311047903  141/sshd: /usr/sbin
    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          311048905  305/master
    tcp6       0      0 :::8081                 :::*                    LISTEN      1000       316592190  35284/io.admin.0
    tcp6       0      0 :::8087                 :::*                    LISTEN      1000       316596098  35542/io.simple-api
    tcp6       0      0 :::111                  :::*                    LISTEN      0          311049286  1/init
    tcp6       0      0 :::22                   :::*                    LISTEN      0          311047905  141/sshd: /usr/sbin
    tcp6       0      0 :::3000                 :::*                    LISTEN      108        311049073  110/grafana-server
    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          311048906  305/master
    udp        0      0 127.0.0.53:53           0.0.0.0:*                           102        311048806  91/systemd-resolved
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          311049285  1/init
    udp6       0      0 :::111                  :::*                                0          311049287  1/init
    Log manuell entfernt
    Manipulation System
    proxmox@ioBrokerTestsystem:~$ sudo touch /usr/local/bin/nodejs
    proxmox@ioBrokerTestsystem:~$ sudo chmod +x /usr/local/bin/nodejs
    proxmox@ioBrokerTestsystem:~$ curl https://raw.githubusercontent.com/Grothesk242/iob_diag/main/iob_diag > iob_diag
      % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                     Dload  Upload   Total   Spent    Left  Speed
    100 19718  100 19718    0     0  28309      0 --:--:-- --:--:-- --:--:-- 28453
    proxmox@ioBrokerTestsystem:~$ ls
    github  iob_diag  package-lock.json
    proxmox@ioBrokerTestsystem:~$ chmod 744 iob_diag
    iob diag von github ausgeführt
    Skript v.2023-08-12
    *** BASE SYSTEM ***
     Static hostname: ioBrokerTestsystem
           Icon name: computer-container
             Chassis: container
          Machine ID: db91a8d9813048b3b0d9627361bf92a2
             Boot ID: 32a84dd282b744a48a6aa21ecc09b231
      Virtualization: lxc
    Operating System: Ubuntu 22.04.3 LTS
              Kernel: Linux 6.2.16-3-pve
        Architecture: x86-64
    model name      : Intel(R) Celeron(R) CPU  N3150  @ 1.60GHz
    Docker          : false
    Kernel          : x86_64
    Userland        : amd64
     20:15:09 up 17:02,  1 user,  load average: 15.12, 14.87, 15.12
    CPU threads: 4
                   Local time: Mon 2023-08-14 20:15:09 CEST
               Universal time: Mon 2023-08-14 18:15:09 UTC
                     RTC time: n/a
              RTC in local TZ: no
    proxmox
    /home/proxmox
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            4.1G        1.9G        1.2G        0.0K        1.1G        2.2G
    Total:          4.6G        1.9G        1.7G
             4096 M total memory
             1854 M used memory
              588 M active memory
             2045 M inactive memory
             1154 M free memory
                0 M buffer memory
             1087 M swap cache
              512 M total swap
                0 M used swap
              511 M free swap
    *** FAILED SERVICES ***
      UNIT                   LOAD   ACTIVE SUB    DESCRIPTION
    * run-rpc_pipefs.mount   loaded failed failed RPC Pipe File System
    * sys-kernel-debug.mount loaded failed failed Kernel Debug File System
    2 loaded units listed.
    *** FILESYSTEM ***
    tmpfs                               tmpfs  3.1G  160K  3.1G   1% /run
    /var:
    914M    /var/
    469M    /var/lib
    293M    /var/cache
    287M    /var/cache/apt
    734M    /opt/iobroker/iobroker-data/
    18M     /opt/iobroker/iobroker-data/objects.jsonl
    /usr/bin/npm            9.6.7
    /usr/bin/npx            9.6.7
    /usr/bin/corepack       0.18.0
    *** nodejs is NOT correctly installed ***
    nodejs:
      Version table:
    Errors in npm tree:
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    admin:          6.8.0
    javascript:     7.1.4
    Adapter State
    + system.adapter.hm-rpc.0                 : hm-rpc                : ioBrokerTestsystem                       -  enabled, port: 0
    + instance is alive
    Objects and States
    Objects:        13145
    States:         11802
    Reading package lists... Done
    Pending Updates: 3
    In diesem Abschnitt kommt jetzt in Rot *** nodejs is NOT correctly installed ***
    /usr/bin/npm            9.6.7
    /usr/bin/npx            9.6.7
    nodejs:
      Version table:
    Errors in npm tree:
    Etwas irritierend ist diese Ausgabe das dort erst steht No problems detected und dann Errors in npm tree: aber keine weitere Ausgabe
    Errors in npm tree:
    #546
    @feuersturm sagte in iob diag - Skript:
    Ja, da gebe ich dir recht, das ist verwirrend. Muss ich mir vielleicht was anderes ausdenken.
    No problems detected bezieht sich hier wirklich auf dieses npm8-Problem mit den kryptischen temp. Verzeichnissen und die andere Meldung auf richtige Fehler im npm tree.
    Keine Meldung hier = Keine Fehler im tree.
    Hat dich das Skript denn am Ende (nach der Summary) dazu aufgefordert die Fehler zu fixen?
      FeuersturmF Offline
      FeuersturmF Offline
      Feuersturm
      #547
      @thomas-braun Da war ich wohl etwas zu schnell :-) So geht es mit der Summary weiter:
                           v.2023-08-12
               Chassis: container
        Virtualization: lxc
      Installation:           lxc
      Kernel:                 x86_64
      Userland:               amd64
      User-ID:                1001
      X-Server:               false
      Pending OS-Updates:     3
      Pending iob updates:    5
      Nodejs-Installation:    /usr/local/bin/nodejs
                              /usr/bin/npm            9.6.7
                              /usr/bin/npx            9.6.7
      Recommended versions are nodejs 18.17.1 and npm 9.6.7
      MEMORY:
      Mem:            4.1G        1.9G        1.1G        0.0K        1.1G        2.2G
      Total:          4.6G        1.9G        1.6G
      Active iob-Instances:   23
      ioBroker Core:          js-controller           5.0.11
                              admin                   6.8.0
      Objects type: jsonl
      States  type: jsonl
      Objects:                13145
      States:                 11796
      Size of iob-Database:
      14M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
      2.3M    /opt/iobroker/iobroker-data/objects_BACKUP_153020.json
      1.2M    /opt/iobroker/iobroker-data/objects_REMOTE_153020.json
      11M     /opt/iobroker/iobroker-data/states.jsonl
      5.3M    /opt/iobroker/iobroker-data/states.json.migrated
      5.3M    /opt/iobroker/iobroker-data/states.json.bak.migrated
      0       /opt/iobroker/iobroker-data/states.json.broken
      === Mark text until here for copying ===
      Your nodejs-Installation seems to be broken. Shall we try to fix it?
      DO NOT RUN FIX ON NON-LINUX-SYSTEMS!
      Press <y> to continue or any other key to quit
      Fixing your nodejs setup
      *** Deleting /usr/local/bin/nodejs ***
      Wrong paths have been fixed. Run \'iob diag\' again to check if your installation is fine now
      Danach erneut iob diag ausgeführt (github Variante)
      Skript v.2023-08-12
      *** BASE SYSTEM ***
               Chassis: container
        Virtualization: lxc
      Docker          : false
      Kernel          : x86_64
      Userland        : amd64
       21:10:04 up 17:57,  1 user,  load average: 14.54, 14.78, 14.78
      CPU threads: 4
                     Local time: Mon 2023-08-14 21:10:05 CEST
                 Universal time: Mon 2023-08-14 19:10:05 UTC
                       RTC time: n/a
                RTC in local TZ: no
      proxmox
      /home/proxmox
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
               4096 M total memory
               1885 M used memory
                544 M active memory
               2117 M inactive memory
               1125 M free memory
                  0 M buffer memory
               1084 M swap cache
                512 M total swap
                  0 M used swap
                511 M free swap
      *** FILESYSTEM ***
      /var:
      914M    /var/
      469M    /var/lib
      293M    /var/cache
      287M    /var/cache/apt
      741M    /opt/iobroker/iobroker-data/
      /usr/bin/npm            9.6.7
      /usr/bin/npx            9.6.7
      nodejs:
        Version table:
      Errors in npm tree:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          6.8.0
      javascript:     7.1.4
      Adapter State
      + instance is alive
      Objects and States
      Objects:        13145
      States:         11796
      Hit:3 https://deb.nodesource.com/node_18.x jammy InRelease
      Hit:4 http://archive.ubuntu.com/ubuntu jammy-security InRelease
      Pending Updates: 3
      2023-08-14 21:10:40.535  - info: host.ioBrokerTestsystem Restart adapter system.adapter.hm-rpc.0 because enabled
      2023-08-14 21:11:10.916  - info: host.ioBrokerTestsystem instance system.adapter.hm-rpc.0 started with pid 41336
      2023-08-14 21:11:18.165  - info: hm-rpc.0 (41336) starting. Version 1.15.19 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v18.17.1, js-controller: 5.0.11
      2023-08-14 21:11:19.544  - info: hm-rpc.0 (41336) xmlrpc server is trying to listen on 192.168.178.77:2010
      2023-08-14 21:11:19.547  - info: hm-rpc.0 (41336) xmlrpc client is trying to connect to 192.168.178.84:2010/ with ["http://192.168.178.77:2010","ioBrokerTestsystem:hm-rpc.0:929dc2370363482799117e5946401b05"]
      2023-08-14 21:11:19.621  - error: hm-rpc.0 (41336) Init not possible, going to stop: Unknown XML-RPC tag 'TITLE'
      2023-08-14 21:11:49.617  - error: hm-rpc.0 (41336) Init not possible, going to stop: Unknown XML-RPC tag 'TITLE'
      2023-08-14 21:11:49.627  - info: hm-rpc.0 (41336) xmlrpc -> 192.168.178.84:2010/ init ["http://192.168.178.77:2010",""]
      2023-08-14 21:11:49.656  - error: hm-rpc.0 (41336) Cannot call init: [http://192.168.178.77:2010, ""] Unknown XML-RPC tag 'TITLE'
      2023-08-14 21:11:49.684  - info: hm-rpc.0 (41336) terminating
      2023-08-14 21:11:49.693  - info: hm-rpc.0 (41336) Terminated (NO_ERROR): Without reason
      2023-08-14 21:11:50.667  - info: host.ioBrokerTestsystem instance system.adapter.hm-rpc.0 terminated with code 0 (NO_ERROR)
      2023-08-14 21:11:50.669  - info: host.ioBrokerTestsystem Restart adapter system.adapter.hm-rpc.0 because enabled
      2023-08-14 21:12:21.244  - info: host.ioBrokerTestsystem instance system.adapter.hm-rpc.0 started with pid 41411
      2023-08-14 21:12:28.488  - info: hm-rpc.0 (41411) starting. Version 1.15.19 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v18.17.1, js-controller: 5.0.11
      2023-08-14 21:12:29.389  - info: hm-rpc.0 (41411) xmlrpc server is trying to listen on 192.168.178.77:2010
      2023-08-14 21:12:29.403  - info: hm-rpc.0 (41411) xmlrpc client is trying to connect to 192.168.178.84:2010/ with ["http://192.168.178.77:2010","ioBrokerTestsystem:hm-rpc.0:37c6a758693e440730b66c6e2688cd46"]
      2023-08-14 21:12:29.581  - error: hm-rpc.0 (41411) Init not possible, going to stop: Unknown XML-RPC tag 'TITLE'
      2023-08-14 21:12:59.538  - error: hm-rpc.0 (41411) Init not possible, going to stop: Unknown XML-RPC tag 'TITLE'
      2023-08-14 21:12:59.595  - info: hm-rpc.0 (41411) xmlrpc -> 192.168.178.84:2010/ init ["http://192.168.178.77:2010",""]
      2023-08-14 21:12:59.633  - error: hm-rpc.0 (41411) Cannot call init: [http://192.168.178.77:2010, ""] Unknown XML-RPC tag 'TITLE'
      2023-08-14 21:12:59.661  - info: hm-rpc.0 (41411) terminating
      2023-08-14 21:12:59.665  - info: hm-rpc.0 (41411) Terminated (NO_ERROR): Without reason
      2023-08-14 21:13:00.498  - info: host.ioBrokerTestsystem instance system.adapter.hm-rpc.0 terminated with code 0 (NO_ERROR)
      2023-08-14 21:13:00.500  - info: host.ioBrokerTestsystem Restart adapter system.adapter.hm-rpc.0 because enabled
      und die summary
                           v.2023-08-12
               Chassis: container
        Virtualization: lxc
      Installation:           lxc
      Kernel:                 x86_64
      Userland:               amd64
      User-ID:                1001
      X-Server:               false
      Nodejs-Installation:    /usr/bin/nodejs         v18.17.1
                              /usr/bin/npm            9.6.7
                              /usr/bin/npx            9.6.7
      MEMORY:
      Active iob-Instances:   22
                              admin                   6.8.0
      Objects type: jsonl
      States  type: jsonl
      Objects:                13145
      States:                 11796
      13M     /opt/iobroker/iobroker-data/states.jsonl
                             v.2023-08-12
                 Chassis: container
          Virtualization: lxc
        Installation:           lxc
        Kernel:                 x86_64
        Userland:               amd64
        User-ID:                1001
        X-Server:               false
                                /usr/bin/npm            9.6.7
                                /usr/bin/npx            9.6.7
        MEMORY:
                                admin                   6.8.0
        Objects type: jsonl
        States  type: jsonl
        Objects:                13145
        States:                 11796
        Skript v.2023-08-12
        *** BASE SYSTEM ***
                 Chassis: container
          Virtualization: lxc
        Docker          : false
        Kernel          : x86_64
        Userland        : amd64
        CPU threads: 4
                         RTC time: n/a
                  RTC in local TZ: no
        proxmox
        /home/proxmox
        X-Server:       false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
                 4096 M total memory
                 1885 M used memory
                  544 M active memory
                 1125 M free memory
                    0 M buffer memory
                 1084 M swap cache
                  512 M total swap
                    0 M used swap
                  511 M free swap
        *** FILESYSTEM ***
        /var:
        914M    /var/
        469M    /var/lib
        293M    /var/cache
        287M    /var/cache/apt
        /usr/bin/npm            9.6.7
        /usr/bin/npx            9.6.7
        nodejs:
          Version table:
        Errors in npm tree:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        admin:          6.8.0
        javascript:     7.1.4
        Adapter State
        + instance is alive
        Objects and States
        Objects:        13145
        States:         11796
        Pending Updates: 3
        und die summary
                             v.2023-08-12
                 Chassis: container
          Virtualization: lxc
        Installation:           lxc
        Kernel:                 x86_64
        Userland:               amd64
        User-ID:                1001
        X-Server:               false
                                /usr/bin/npm            9.6.7
                                /usr/bin/npx            9.6.7
        MEMORY:
                                admin                   6.8.0
        Objects type: jsonl
        States  type: jsonl
        Objects:                13145
        States:                 11796
        #548
        Juhu! Tut! :)
          Juhu! Tut! :)
          FeuersturmF Offline
          FeuersturmF Offline
          Feuersturm
          #549
          @thomas-braun Was genau soll das Skript bzw. eine Variante denn alles fixen?
            #550
            @feuersturm
            Zwei Stufen: Bei den üblichen falschen Pfaden der nodejs-bins werden die Pfade gelöscht, meist ist es dann damit ja auch schon getan.
            Die zweite Stufe wird gezündet, wenn ein nodejs <> der aktuellen Empfehlung gefunden wird, dann wird angeboten diese zu installieren.
              @feuersturm
              FeuersturmF Offline
              FeuersturmF Offline
              Feuersturm
              #551
              @thomas-braun Wenn die zweite Stufe implementiert ist kann ich dies auch gerne einmal testen. Kann ja ein Downgrade auf z.B. nodejs 16 machen
              Thomas BraunT GlasfaserG 2 Antworten Letzte Antwort
                #552
                Ist schon drin. Wird nur angeboten, wenn eine abweichende Version läuft.
                Achtung, dein iobroker wird da gestoppt und du musst den Container dann neustarten. Gibt aber Hinweise im Text.
                Für einen geskripteten Restart eines Containers hab ich zu wenig Plan davon. Bei nativen Installationen wird der ioBroker auch wieder vom Skript gestartet.
                  GlasfaserG Offline
                  GlasfaserG Offline
                  #553
                  Was mir gerade einfällt :
                  mit einem Buanet ioBroker Image kann man den Container mit
                  maint restart -y
                  neustarten.
                  • GlasfaserG Glasfaser
                    maint restart -y
                    neustarten.
                    #554
                    @glasfaser
                    Docker? Hab ich im Code ausgeschlossen.
                      @glasfaser
                      GlasfaserG Offline
                      GlasfaserG Offline
                      #555
                      Ja Docker ,
                      Sorry habe ich nicht dazu geschrieben :)
                        Ja Docker ,
                        #556
                        @glasfaser
                        Docker-Dosen kann ich rein gar nicht testen. Und ist mir auch 'zu anders' im Vergleich zu einem LXC oder einer nativen Installation.
                        Aber man topft das ganze doch ohnehin immer in einen neuen Übertopf um, oder nicht?
                        • FeuersturmF Offline
                          FeuersturmF Offline
                          Feuersturm
                          #557
                          Kurzfassung: Funktioniert :-)
                          Langfassung:
                          Downgrade nodejs von 18 auf 16
                          proxmox@ioBrokerTestsystem:/home$ apt policy nodejs
                          nodejs:
                            Version table:
                           *** 18.17.1-deb-1nodesource1 100
                               16.20.2-deb-1nodesource1 500
                                  500 https://deb.nodesource.com/node_16.x jammy/main amd64 Packages
                          proxmox@ioBrokerTestsystem:/home$ sudo apt install nodejs=16.20.2-deb-1nodesource1
                          The following packages were automatically installed and are no longer required:
                            libllvm13 libvulkan1 libwayland-client0 mesa-vulkan-drivers
                          Use 'sudo apt autoremove' to remove them.
                          The following packages will be DOWNGRADED:
                            nodejs
                          0 upgraded, 0 newly installed, 1 downgraded, 0 to remove and 3 not upgraded.
                          Need to get 27.2 MB of archives.
                          After this operation, 60.4 MB disk space will be freed.
                          Do you want to continue? [Y/n] y
                          Get:1 https://deb.nodesource.com/node_16.x jammy/main amd64 nodejs amd64 16.20.2-deb-1nodesource1 [27.2 MB]
                          Fetched 27.2 MB in 4s (6498 kB/s)
                          dpkg: warning: downgrading nodejs from 18.17.1-deb-1nodesource1 to 16.20.2-deb-1nodesource1
                          (Reading database ... 46660 files and directories currently installed.)
                          Preparing to unpack .../nodejs_16.20.2-deb-1nodesource1_amd64.deb ...
                          Unpacking nodejs (16.20.2-deb-1nodesource1) over (18.17.1-deb-1nodesource1) ...
                          Setting up nodejs (16.20.2-deb-1nodesource1) ...
                          Processing triggers for man-db (2.10.2-1) ...
                          proxmox@ioBrokerTestsystem:/home$ nodejs -v && npm -v
                          v16.20.2
                          8.19.4
                          danach noch ein iob fix und dann ein iob start ausgeführt.
                          iob diag (github version)
                          Skript v.2023-08-12
                          *** BASE SYSTEM ***
                                   Chassis: container
                            Virtualization: lxc
                          Docker          : false
                          Kernel          : x86_64
                          Userland        : amd64
                           22:12:14 up 18:59,  1 user,  load average: 12.95, 13.98, 14.17
                          CPU threads: 4
                                         Local time: Mon 2023-08-14 22:12:14 CEST
                                     Universal time: Mon 2023-08-14 20:12:14 UTC
                                           RTC time: n/a
                                    RTC in local TZ: no
                          proxmox
                          /home/proxmox
                          X-Server:       false
                          Desktop:
                          Terminal:       tty
                          *** MEMORY ***
                          Mem:            4.1G        1.8G        1.1G        0.0K        1.1G        2.3G
                          Total:          4.6G        1.8G        1.7G
                                   4096 M total memory
                                   1801 M used memory
                                    619 M active memory
                                   2020 M inactive memory
                                   1146 M free memory
                                      0 M buffer memory
                                   1147 M swap cache
                                    512 M total swap
                                      0 M used swap
                                    511 M free swap
                          *** FILESYSTEM ***
                          /var:
                          914M    /var/
                          469M    /var/lib
                          293M    /var/cache
                          287M    /var/cache/apt
                          733M    /opt/iobroker/iobroker-data/
                          /usr/bin/nodejs         v16.20.2
                          /usr/bin/node           v16.20.2
                          /usr/bin/npm            8.19.4
                          /usr/bin/npx            8.19.4
                          /usr/bin/corepack       0.17.0
                          nodejs:
                            Installed: 16.20.2-deb-1nodesource1
                            Candidate: 16.20.2-deb-1nodesource1
                            Version table:
                           *** 16.20.2-deb-1nodesource1 500
                          Errors in npm tree:
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          admin:          6.8.0
                          javascript:     7.1.4
                          Adapter State
                            system.adapter.hm-rpc.0                 : hm-rpc                : ioBrokerTestsystem                       - disabled, port: 0
                          + instance is alive
                          Objects and States
                          Objects:        13145
                          States:         11802
                          Hit:1 https://deb.nodesource.com/node_16.x jammy InRelease
                          Hit:2 http://archive.ubuntu.com/ubuntu jammy InRelease
                          Hit:3 http://archive.ubuntu.com/ubuntu jammy-updates InRelease
                          Pending Updates: 3
                          tcp        0      0 192.168.178.77:8082     0.0.0.0:*               LISTEN      1000       317245085  45156/io.web.0
                          tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1000       317230619  44801/iobroker.js-c
                          tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1000       317232637  44801/iobroker.js-c
                          tcp6       0      0 :::8081                 :::*                    LISTEN      1000       317233130  44829/io.admin.0
                          tcp6       0      0 :::8087                 :::*                    LISTEN      1000       317245613  45066/io.simple-api
                          2023-08-14 22:09:24.761  - info: hm-rpc.0 (45672) terminating
                          2023-08-14 22:09:24.767  - info: hm-rpc.0 (45672) Terminated (NO_ERROR): Without reason
                          2023-08-14 22:09:24.807  - info: hm-rpc.0 (45672) terminating
                          2023-08-14 22:09:25.104  - info: hm-rpc.0 (45672) terminating with timeout
                          2023-08-14 22:09:26.022  - info: host.ioBrokerTestsystem instance system.adapter.hm-rpc.0 terminated with code 0 (NO_ERROR)
                          2023-08-14 22:09:26.027  - info: host.ioBrokerTestsystem Restart adapter system.adapter.hm-rpc.0 because enabled
                          2023-08-14 22:09:56.356  - info: host.ioBrokerTestsystem instance system.adapter.hm-rpc.0 started with pid 45692
                          2023-08-14 22:10:02.445  - info: hm-rpc.0 (45692) starting. Version 1.15.19 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v16.20.2, js-controller: 5.0.11
                          2023-08-14 22:10:03.210  - info: hm-rpc.0 (45692) xmlrpc server is trying to listen on 192.168.178.77:2010
                          2023-08-14 22:10:03.214  - info: hm-rpc.0 (45692) xmlrpc client is trying to connect to 192.168.178.84:2010/ with ["http://192.168.178.77:2010","ioBrokerTestsystem:hm-rpc.0:d96698d96618b7431e6c2903595df786"]
                          2023-08-14 22:10:03.286  - error: hm-rpc.0 (45692) Init not possible, going to stop: Unknown XML-RPC tag 'TITLE'
                          2023-08-14 22:10:33.320  - info: hm-rpc.0 (45692) xmlrpc -> 192.168.178.84:2010/ init ["http://192.168.178.77:2010",""]
                          2023-08-14 22:10:33.429  - error: hm-rpc.0 (45692) Init not possible, going to stop: Unknown XML-RPC tag 'TITLE'
                          2023-08-14 22:10:33.452  - error: hm-rpc.0 (45692) Cannot call init: [http://192.168.178.77:2010, ""] Unknown XML-RPC tag 'TITLE'
                          2023-08-14 22:10:33.486  - info: hm-rpc.0 (45692) terminating
                          2023-08-14 22:10:33.490  - info: hm-rpc.0 (45692) Terminated (NO_ERROR): Without reason
                          2023-08-14 22:10:34.338  - info: host.ioBrokerTestsystem instance system.adapter.hm-rpc.0 terminated with code 0 (NO_ERROR)
                          2023-08-14 22:10:34.341  - info: host.ioBrokerTestsystem Restart adapter system.adapter.hm-rpc.0 because enabled
                          2023-08-14 22:11:04.698  - info: host.ioBrokerTestsystem instance system.adapter.hm-rpc.0 started with pid 46399
                          2023-08-14 22:11:06.352  - info: host.ioBrokerTestsystem "system.adapter.hm-rpc.0" disabled
                          2023-08-14 22:11:06.364  - info: host.ioBrokerTestsystem stopInstance system.adapter.hm-rpc.0 (force=false, process=true)
                          2023-08-14 22:11:07.036  - info: host.ioBrokerTestsystem stopInstance system.adapter.hm-rpc.0 send kill signal
                          2023-08-14 22:11:08.043  - info: host.ioBrokerTestsystem stopInstance system.adapter.hm-rpc.0 killing pid 46399
                          2023-08-14 22:11:08.292  - warn: host.ioBrokerTestsystem instance system.adapter.hm-rpc.0 terminated due to SIGTERM
                          2023-08-14 22:11:08.295  - info: host.ioBrokerTestsystem instance system.adapter.hm-rpc.0 terminated with code null ()
                          Summary
                                               v.2023-08-12
                                   Chassis: container
                            Virtualization: lxc
                          Installation:           lxc
                          Kernel:                 x86_64
                          Userland:               amd64
                          User-ID:                1001
                          X-Server:               false
                          Nodejs-Installation:    /usr/bin/nodejs         v16.20.2
                                                  /usr/bin/npm            8.19.4
                                                  /usr/bin/npx            8.19.4
                          MEMORY:
                          Mem:            4.1G        1.7G        1.2G        0.0K        1.1G        2.3G
                                                  admin                   6.8.0
                          Objects type: jsonl
                          States  type: jsonl
                          Objects:                13145
                          States:                 11802
                          4.4M    /opt/iobroker/iobroker-data/states.jsonl
                          You are running nodejs v.16.20.2. Do you want to install recommended nodejs v.18.17.1?
                          *** DO NOT TRY THIS FIX ON NON-LINUX-SYSTEMS! ***
                          lxc
                          Waiting for ioBroker to shut down - Give me a minute...
                          ## Installing the NodeSource Node.js 18.x repo...
                          ## Populating apt-get cache...
                          + apt-get update
                          ## Confirming "jammy" is supported...
                          + curl -sLf -o /dev/null 'https://deb.nodesource.com/node_18.x/dists/jammy/Release'
                          ## Adding the NodeSource signing key to your keyring...
                          + curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | gpg --dearmor | tee /usr/share/keyrings/nodesource.gpg >/dev/null
                          ## Creating apt sources list file for the NodeSource Node.js 18.x repo...
                          + echo 'deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x jammy main' > /etc/apt/sources.list.d/nodesource.list
                          + echo 'deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x jammy main' >> /etc/apt/sources.list.d/nodesource.list
                          ## Running `apt-get update` for you...
                          + apt-get update
                          Get:4 https://deb.nodesource.com/node_18.x jammy InRelease [4563 B]
                          Get:5 https://deb.nodesource.com/node_18.x jammy/main amd64 Packages [776 B]
                          Fetched 5339 B in 13s (404 B/s)
                          ## Run `sudo apt-get install -y nodejs` to install Node.js 18.x and npm
                          ## You may also need development tools to build native addons:
                               sudo apt-get install gcc g++ make
                          ## To install the Yarn package manager, run:
                               curl -sL https://dl.yarnpkg.com/debian/pubkey.gpg | gpg --dearmor | sudo tee /usr/share/keyrings/yarnkey.gpg >/dev/null
                               echo "deb [signed-by=/usr/share/keyrings/yarnkey.gpg] https://dl.yarnpkg.com/debian stable main" | sudo tee /etc/apt/sources.list.d/yarn.list
                               sudo apt-get update && sudo apt-get install yarn
                          The following packages will be upgraded:
                            nodejs
                          1 upgraded, 0 newly installed, 0 to remove and 3 not upgraded.
                          Need to get 28.9 MB of archives.
                          After this operation, 60.4 MB of additional disk space will be used.
                          Get:1 https://deb.nodesource.com/node_18.x jammy/main amd64 nodejs amd64 18.17.1-deb-1nodesource1 [28.9 MB]
                          Fetched 28.9 MB in 7s (4254 kB/s)
                          (Reading database ... 44173 files and directories currently installed.)
                          Preparing to unpack .../nodejs_18.17.1-deb-1nodesource1_amd64.deb ...
                          Unpacking nodejs (18.17.1-deb-1nodesource1) over (16.20.2-deb-1nodesource1) ...
                          Setting up nodejs (18.17.1-deb-1nodesource1) ...
                          Please restart your container
                          We tried our best to fix your nodejs. Please run 'iob diag' again to verify.
                          Die Meldung Please restart your container im Textfluss geht unter, wenn man nicht ganz genau hinsieht. Kannst du diesen Hinweis etwas prominenter darstellen?
                          Danach erneut iob diag ausführen
                          Skript v.2023-08-12
                          *** BASE SYSTEM ***
                                   Chassis: container
                                   Boot ID: 3a75cdd6c2ce4a53a75e3c91157c7622
                            Virtualization: lxc
                          Docker          : false
                          Kernel          : x86_64
                          Userland        : amd64
                           22:28:42 up 3 min,  1 user,  load average: 19.30, 17.42, 16.00
                          CPU threads: 4
                                         Local time: Mon 2023-08-14 22:28:42 CEST
                                     Universal time: Mon 2023-08-14 20:28:42 UTC
                                           RTC time: n/a
                                    RTC in local TZ: no
                          proxmox
                          /home/proxmox
                          X-Server:       false
                          Desktop:
                          Terminal:       tty
                          *** MEMORY ***
                          Mem:            4.1G        1.7G        1.8G        0.0K        582M        2.4G
                          Swap:           512M          0B        512M
                          Total:          4.6G        1.7G        2.3G
                                   4096 M total memory
                                   1695 M used memory
                                    188 M active memory
                                   1972 M inactive memory
                                   1818 M free memory
                                      0 M buffer memory
                                    582 M swap cache
                                    512 M total swap
                                      0 M used swap
                                    512 M free swap
                          *** FILESYSTEM ***
                          tmpfs                               tmpfs  3.1G  148K  3.1G   1% /run
                          [sudo] password for proxmox:
                          /var:
                          914M    /var/
                          469M    /var/lib
                          293M    /var/cache
                          287M    /var/cache/apt
                          737M    /opt/iobroker/iobroker-data/
                          19M     /opt/iobroker/iobroker-data/objects.jsonl
                          /usr/bin/npm            9.6.7
                          /usr/bin/npx            9.6.7
                          nodejs:
                            Version table:
                          Errors in npm tree:
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          admin:          6.8.0
                          javascript:     7.1.4
                          Adapter State
                          + instance is alive
                          Objects and States
                          Objects:        13145
                          States:         11802
                          Pending Updates: 3
                          tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          317360475  312/master
                          tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1000       317358721  118/iobroker.js-con
                          tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1000       317358714  118/iobroker.js-con
                          tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          317355939  1/init
                          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          317358193  133/sshd: /usr/sbin
                          tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      102        317359166  91/systemd-resolved
                          tcp        0      0 192.168.178.77:8082     0.0.0.0:*               LISTEN      1000       317371974  679/io.web.0
                          tcp6       0      0 ::1:25                  :::*                    LISTEN      0          317360476  312/master
                          tcp6       0      0 :::8081                 :::*                    LISTEN      1000       317357878  372/io.admin.0
                          tcp6       0      0 :::8087                 :::*                    LISTEN      1000       317370670  608/io.simple-api.0
                          tcp6       0      0 :::111                  :::*                    LISTEN      0          317355941  1/init
                          tcp6       0      0 :::22                   :::*                    LISTEN      0          317358204  133/sshd: /usr/sbin
                          tcp6       0      0 :::3000                 :::*                    LISTEN      108        317358632  117/grafana-server
                          udp        0      0 127.0.0.53:53           0.0.0.0:*                           102        317359165  91/systemd-resolved
                          udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          317355940  1/init
                          udp6       0      0 :::111                  :::*                                0          317355942  1/init
                          2023-08-14 22:28:59.392  - info: hm-rega.0 (481) added/updated 6 programs
                          2023-08-14 22:28:59.400  - info: hm-rega.0 (481) deleted 0 programs
                          2023-08-14 22:28:59.533  - info: hm-rega.0 (481) update rooms to enum.rooms
                          2023-08-14 22:28:59.622  - info: info.0 (572) cpu Temp res = {"main":66,"cores":[68,66,64,64],"max":68,"socket":[],"chipset":null}
                          2023-08-14 22:29:00.413  - info: hm-rega.0 (481) update functions to enum.functions
                          2023-08-14 22:29:00.587  - info: hm-rega.0 (481) update favorites to enum.favorites
                          2023-08-14 22:29:03.929  - error: daswetter.0 (530) force terminate
                          2023-08-14 22:29:03.964  - warn: daswetter.0 (530) Terminated (UNKNOWN_ERROR): Without reason
                          2023-08-14 22:29:04.493  - error: daswetter.0 (530) exception in await insertIntoList [Error: DB closed]
                          2023-08-14 22:29:04.620  - error: daswetter.0 (530) exception in await insertIntoList [Error: DB closed]
                          2023-08-14 22:29:04.641  - error: daswetter.0 (530) Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_1.Hour_9.symbol_value2": Connection is closed.
                          2023-08-14 22:29:04.661  - error: daswetter.0 (530) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextHours.Location_1.Day_1.Hour_9.symbol_value2: Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_1.Hour_9.symbol_value2": Connection is closed.]
                          2023-08-14 22:29:05.271  - error: host.ioBrokerTestsystem instance system.adapter.daswetter.0 terminated with code 15 (UNKNOWN_ERROR)
                          2023-08-14 22:29:25.224  - info: tankerkoenig.0 (615) Start first request
                          2023-08-14 22:29:38.220  - info: openweathermap.0 (500) Terminated (NO_ERROR): Without reason
                          2023-08-14 22:29:39.128  - info: host.ioBrokerTestsystem instance system.adapter.openweathermap.0 terminated with code 0 (NO_ERROR)
                          2023-08-14 22:30:00.188  - info: host.ioBrokerTestsystem instance system.adapter.dwd.0 started with pid 1358
                          2023-08-14 22:30:04.578  - info: host.ioBrokerTestsystem instance system.adapter.ical.5 started with pid 1365
                          2023-08-14 22:30:16.625  - info: dwd.0 (1358) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.11
                          2023-08-14 22:30:17.904  - info: ical.5 (1365) starting. Version 1.13.3 in /opt/iobroker/node_modules/iobroker.ical, node: v18.17.1, js-controller: 5.0.11
                          2023-08-14 22:30:19.239  - info: dwd.0 (1358) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                          2023-08-14 22:30:19.909  - info: host.ioBrokerTestsystem instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                          2023-08-14 22:30:22.333  - info: ical.5 (1365) processing URL: ioBrokerTesting https://calendar.google.com/calendar/ical/0g7gpl8tcsjsbacjrkunfg8l0c%40group.calendar.google.com/private-ee9dd402778b56aafd5eea5e6f591bd6/basic.ics
                          2023-08-14 22:30:27.616  - info: ical.5 (1365) Terminated (NO_ERROR): Without reason
                          2023-08-14 22:30:28.275  - info: host.ioBrokerTestsystem instance system.adapter.ical.5 terminated with code 0 (NO_ERROR)
                                               v.2023-08-12
                                   Chassis: container
                            Virtualization: lxc
                          Installation:           lxc
                          Kernel:                 x86_64
                          Userland:               amd64
                          User-ID:                1001
                          X-Server:               false
                                                  /usr/bin/npm            9.6.7
                                                  /usr/bin/npx            9.6.7
                          MEMORY:
                          Mem:            4.1G        1.6G        1.6G        0.0K        899M        2.5G
                          Total:          4.6G        1.6G        2.1G
                                                  admin                   6.8.0
                          Objects type: jsonl
                          States  type: jsonl
                          Objects:                13145
                          States:                 11802
                          20M     /opt/iobroker/iobroker-data/objects.jsonl
                          7.0M    /opt/iobroker/iobroker-data/states.jsonl
                          FeuersturmF Thomas BraunT 2 Antworten Letzte Antwort
                            Langfassung:
                            nodejs:
                              Version table:
                              nodejs
                            v16.20.2
                            8.19.4
                            Skript v.2023-08-12
                            *** BASE SYSTEM ***
                                     Chassis: container
                              Virtualization: lxc
                            Docker          : false
                            Kernel          : x86_64
                            Userland        : amd64
                            CPU threads: 4
                                             RTC time: n/a
                                      RTC in local TZ: no
                            proxmox
                            /home/proxmox
                            X-Server:       false
                            Desktop:
                            Terminal:       tty
                            *** MEMORY ***
                                     4096 M total memory
                                     1801 M used memory
                                      619 M active memory
                                     1146 M free memory
                                        0 M buffer memory
                                     1147 M swap cache
                                      512 M total swap
                                        0 M used swap
                                      511 M free swap
                            *** FILESYSTEM ***
                            /var:
                            914M    /var/
                            469M    /var/lib
                            293M    /var/cache
                            287M    /var/cache/apt
                            /usr/bin/npm            8.19.4
                            /usr/bin/npx            8.19.4
                            nodejs:
                              Version table:
                            Errors in npm tree:
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            admin:          6.8.0
                            javascript:     7.1.4
                            Adapter State
                            + instance is alive
                            Objects and States
                            Objects:        13145
                            States:         11802
                            Pending Updates: 3
                            Summary
                                                 v.2023-08-12
                                     Chassis: container
                              Virtualization: lxc
                            Installation:           lxc
                            Kernel:                 x86_64
                            Userland:               amd64
                            User-ID:                1001
                            X-Server:               false
                                                    /usr/bin/npm            8.19.4
                                                    /usr/bin/npx            8.19.4
                            MEMORY:
                                                    admin                   6.8.0
                            Objects type: jsonl
                            States  type: jsonl
                            Objects:                13145
                            States:                 11802
                            lxc
                            + apt-get update
                            + apt-get update
                              nodejs
                            Skript v.2023-08-12
                            *** BASE SYSTEM ***
                                     Chassis: container
                              Virtualization: lxc
                            Docker          : false
                            Kernel          : x86_64
                            Userland        : amd64
                            CPU threads: 4
                                             RTC time: n/a
                                      RTC in local TZ: no
                            proxmox
                            /home/proxmox
                            X-Server:       false
                            Desktop:
                            Terminal:       tty
                            *** MEMORY ***
                            Swap:           512M          0B        512M
                                     4096 M total memory
                                     1695 M used memory
                                      188 M active memory
                                     1818 M free memory
                                        0 M buffer memory
                                      582 M swap cache
                                      512 M total swap
                                        0 M used swap
                                      512 M free swap
                            *** FILESYSTEM ***
                            /var:
                            914M    /var/
                            469M    /var/lib
                            293M    /var/cache
                            287M    /var/cache/apt
                            /usr/bin/npm            9.6.7
                            /usr/bin/npx            9.6.7
                            nodejs:
                              Version table:
                            Errors in npm tree:
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            admin:          6.8.0
                            javascript:     7.1.4
                            Adapter State
                            + instance is alive
                            Objects and States
                            Objects:        13145
                            States:         11802
                            Pending Updates: 3
                                                 v.2023-08-12
                                     Chassis: container
                              Virtualization: lxc
                            Installation:           lxc
                            Kernel:                 x86_64
                            Userland:               amd64
                            User-ID:                1001
                            X-Server:               false
                                                    /usr/bin/npm            9.6.7
                                                    /usr/bin/npx            9.6.7
                            MEMORY:
                                                    admin                   6.8.0
                            Objects type: jsonl
                            States  type: jsonl
                            Objects:                13145
                            States:                 11802
                            FeuersturmF Offline
                            FeuersturmF Offline
                            Feuersturm
                            #558
                            @Thomas-Braun Kleiner Nachtrag zu
                                                    /usr/bin/npm            8.19.4
                                                    /usr/bin/npx            8.19.4
                            Anstatt Your nodejs installation is correct könnte man hier ausgeben Your nodejs installation is correct and supported but it is not the recommended version
                              Langfassung:
                              nodejs:
                                Version table:
                                nodejs
                              v16.20.2
                              8.19.4
                              Skript v.2023-08-12
                              *** BASE SYSTEM ***
                                       Chassis: container
                                Virtualization: lxc
                              Docker          : false
                              Kernel          : x86_64
                              Userland        : amd64
                              CPU threads: 4
                                               RTC time: n/a
                                        RTC in local TZ: no
                              proxmox
                              /home/proxmox
                              X-Server:       false
                              Desktop:
                              Terminal:       tty
                              *** MEMORY ***
                                       4096 M total memory
                                       1801 M used memory
                                        619 M active memory
                                       1146 M free memory
                                          0 M buffer memory
                                       1147 M swap cache
                                        512 M total swap
                                          0 M used swap
                                        511 M free swap
                              *** FILESYSTEM ***
                              /var:
                              914M    /var/
                              469M    /var/lib
                              293M    /var/cache
                              287M    /var/cache/apt
                              /usr/bin/npm            8.19.4
                              /usr/bin/npx            8.19.4
                              nodejs:
                                Version table:
                              Errors in npm tree:
                              ioBroker Status
                              Objects type: jsonl
                              States  type: jsonl
                              admin:          6.8.0
                              javascript:     7.1.4
                              Adapter State
                              + instance is alive
                              Objects and States
                              Objects:        13145
                              States:         11802
                              Pending Updates: 3
                              Summary
                                                   v.2023-08-12
                                       Chassis: container
                                Virtualization: lxc
                              Installation:           lxc
                              Kernel:                 x86_64
                              Userland:               amd64
                              User-ID:                1001
                              X-Server:               false
                                                      /usr/bin/npm            8.19.4
                                                      /usr/bin/npx            8.19.4
                              MEMORY:
                                                      admin                   6.8.0
                              Objects type: jsonl
                              States  type: jsonl
                              Objects:                13145
                              States:                 11802
                              lxc
                              + apt-get update
                              + apt-get update
                                nodejs
                              Skript v.2023-08-12
                              *** BASE SYSTEM ***
                                       Chassis: container
                                Virtualization: lxc
                              Docker          : false
                              Kernel          : x86_64
                              Userland        : amd64
                              CPU threads: 4
                                               RTC time: n/a
                                        RTC in local TZ: no
                              proxmox
                              /home/proxmox
                              X-Server:       false
                              Desktop:
                              Terminal:       tty
                              *** MEMORY ***
                              Swap:           512M          0B        512M
                                       4096 M total memory
                                       1695 M used memory
                                        188 M active memory
                                       1818 M free memory
                                          0 M buffer memory
                                        582 M swap cache
                                        512 M total swap
                                          0 M used swap
                                        512 M free swap
                              *** FILESYSTEM ***
                              /var:
                              914M    /var/
                              469M    /var/lib
                              293M    /var/cache
                              287M    /var/cache/apt
                              /usr/bin/npm            9.6.7
                              /usr/bin/npx            9.6.7
                              nodejs:
                                Version table:
                              Errors in npm tree:
                              ioBroker Status
                              Objects type: jsonl
                              States  type: jsonl
                              admin:          6.8.0
                              javascript:     7.1.4
                              Adapter State
                              + instance is alive
                              Objects and States
                              Objects:        13145
                              States:         11802
                              Pending Updates: 3
                                                   v.2023-08-12
                                       Chassis: container
                                Virtualization: lxc
                              Installation:           lxc
                              Kernel:                 x86_64
                              Userland:               amd64
                              User-ID:                1001
                              X-Server:               false
                                                      /usr/bin/npm            9.6.7
                                                      /usr/bin/npx            9.6.7
                              MEMORY:
                                                      admin                   6.8.0
                              Objects type: jsonl
                              States  type: jsonl
                              Objects:                13145
                              States:                 11802
                              #559
                              @feuersturm
                              Jaaaaa, so hatte ich mir das vorgestellt.
                              Text so besser?
                              *** You need to manually restart your container now! ***
                                @feuersturm
                                Text so besser?
                                FeuersturmF Offline
                                FeuersturmF Offline
                                Feuersturm
                                #560
                                @thomas-braun Ja, das fällt besser auf.
                                  #561
                                  @feuersturm
                                  Habs gerade auf github hochgeschubst.
                                  • andreA Offline
                                    andreA Offline
                                    andre
                                    #562
                                    Bin ich der Einzige der es irgendwie bedenklich findet wenn ein Diagnose-Script auch gefundene Probleme korrigiert statt nur darüber zu informieren? Meines Erachtens sollte ein Diagnosescript 100% safe sein. Also ausschließlich Informationen auslesen.
                                    Wo wäre dann sonst der Unterschied zum Fixer-Script? Dann können wir die Diag-Ausgabe doch eigentlich auch direkt in den Fixer einbauen, oder sehe ich das falsch?
                                    @apollon77 @foxriver76 @AlCalzone @Bluefox
                                    Habt ihr eine Meinung dazu? Sollte das Thema vielleicht auf die Dev-Meeting-Liste? Ich denke das ist in jedem Fall zumindest diskussionswürdig.
                                    MfG,
                                    André
                                    Thomas BraunT HomoranH mcm1957M 3 Antworten Letzte Antwort
                                    • andreA andre
                                      MfG,
                                      André
                                      #563
                                      @andre sagte in iob diag - Skript:
                                      Da bin ich dabei.
                                      Ist ja auch eine Beta-Version zum herumspielen. Den Code kann man easy da wieder rausnehmen und in den Fixer (oder ein eigenes Skript integrieren).
                                      War nur für den Moment einfacher das an 'iob diag' anzuhängen.
                                      Den Fix musst du aber auch bestätigen und damit wollen, der wird ja nicht hinterrücks plötzlich ausgeführt.
                                      andreA 1 Antwort Letzte Antwort
                                        Da bin ich dabei.
                                        andreA Offline
                                        andreA Offline
                                        andre
                                        #564
                                        Ok, wollte nur darauf hinweisen, bevor aus dem Diag-Script die "eierlegende Wollmilchsau" wird. So wie das m. E. leider mit dem Backitup-Adapter passiert ist. :)
                                        @thomas-braun sagte in iob diag - Skript:
                                        Ja, das ist richtig. Aber du kennst ja auch die unerfahrenen User... Da erzählt ein Script was von node Version und schon ist ein ioBroker Einsteiger und Linux Neuling gnadenlos überfordert...
                                        MfG,
                                        André
                                        • andreA andre
                                          MfG,
                                          André
                                          #565
                                          Die Resultate der bisherigen Überforderung soll das Ding ja gerade wieder ausbügeln... Bislang schaut das auch ganz gut aus. Tut was es soll.
                                          Komplett zerballerte Dreifach-Installationen von nodejs bekommst du auch mit dem Skript nicht gebändigt. Jedenfalls nicht im ersten Anlauf.
