  4. Test Adapter Awtrix-Light (Awtrix 3)
2.2k Beiträge 167 Kommentatoren 1.5m Aufrufe 141 Beobachtet
  • FreunderNachtF FreunderNacht
    ich habe den Adapter seit gestern in Betrieb.
    nach einer gewissen Laufzeit des Adapters bekomme ich im Log folgende Warnmeldung:
    awtrix-light.0
    2023-08-12 13:36:43.509	warn	(custom?name=hausverbrauch) Unable to update custom app "hausverbrauch": AxiosError: Request failed with status code 500
    awtrix-light.0
    2023-08-12 13:36:43.509	warn	received 500 response from /api/custom?name=hausverbrauch with content: "ErrorParsingJson"
    awtrix-light.0
    2023-08-12 13:36:43.478	warn	(custom?name=pvproduktion) Unable to update custom app "pvproduktion": AxiosError: Request failed with status code 500
    awtrix-light.0
    2023-08-12 13:36:43.477	warn	received 500 response from /api/custom?name=pvproduktion with content: "ErrorParsingJson"
    awtrix-light.0
    2023-08-12 13:36:23.522	warn	(custom?name=pvproduktion) Unable to update custom app "pvproduktion": AxiosError: Request failed with status code 500
    awtrix-light.0
    2023-08-12 13:36:23.522	warn	received 500 response from /api/custom?name=pvproduktion with content: "ErrorParsingJson"
    awtrix-light.0
    2023-08-12 13:36:03.466	warn	(custom?name=pvproduktion) Unable to update custom app "pvproduktion": AxiosError: Request failed with status code 500
    awtrix-light.0
    2023-08-12 13:36:03.466	warn	received 500 response from /api/custom?name=pvproduktion with content: "ErrorParsingJson"
    awtrix-light.0
    2023-08-12 13:35:23.486	warn	(custom?name=hausverbrauch) Unable to update custom app "hausverbrauch": AxiosError: Request failed with status code 500
    awtrix-light.0
    2023-08-12 13:35:23.486	warn	received 500 response from /api/custom?name=hausverbrauch with content: "ErrorParsingJson"
    awtrix-light.0
    2023-08-12 13:35:23.461	warn	(custom?name=pvproduktion) Unable to update custom app "pvproduktion": AxiosError: Request failed with status code 500
    awtrix-light.0
    2023-08-12 13:35:23.461	warn	received 500 response from /api/custom?name=pvproduktion with content: "ErrorParsingJson"
    awtrix-light.0
    2023-08-12 13:35:03.426	warn	(custom?name=hausverbrauch) Unable to update custom app "hausverbrauch": AxiosError: Request failed with status code 500
    awtrix-light.0
    2023-08-12 13:35:03.426	warn	received 500 response from /api/custom?name=hausverbrauch with content: "ErrorParsingJson"
    awtrix-light.0
    2023-08-12 13:35:03.395	warn	(custom?name=pvproduktion) Unable to update custom app "pvproduktion": AxiosError: Request failed with status code 500
    awtrix-light.0
    2023-08-12 13:35:03.395	warn	received 500 response from /api/custom?name=pvproduktion with content: "ErrorParsingJson"
    Meine Adaptereinstellungen sind folgende:
    Diesen Wert habe ich schon auf 10 Sekunden erhöht:
    Jedoch ohne Änderung.
    Hat jemand eine Idee was ich noch anpassen kann?
    Hier mein System:
    Admin
    v6.7.2
    awtrix-light Adapter
    v0.7.1
    Awtrix Firmware
    v0.73
    Node.js
    v18.17.1
    NPM
    9.6.7
    js-controller
    v4.0.24
    haus-automatisierungH Offline
    #1133
    @freundernacht Gern auf GitHub mitdiskutieren. Da geht dem Gerät scheinbar der RAM aus. Muss noch genauer erörtert werden. Aber als Adapter-Entwickler kann ich da eh wenig machen, das muss in der Firmware gefixt werden
    📚 Meine Dokumentation
    • darkbluD Offline
      darkbluD Offline
      darkblu
      #1134
      Huhu,
      wie bekomme ich denn dieses Kalenderblatt vor der Uhrzeit weg ?
      Awtrix Light auf Ulanzi: 0.73
      Awtrix Light Adapter: v0.7.1
      Habe weder auf der Ulanzi was gefunden, noch in den Objekten, um das weg zu bekommen.
      Raspi 4, 4GB für Influxdb 1.8 und Grafana
      Raspi 5, 8 GB für ioBroker
      Threadnetzwerk per Apple
      P FreunderNachtF 2 Antworten Letzte Antwort
      • darkbluD darkblu
        Huhu,
        pfeiferj12
        #1135
        @darkblu settings/timeStyle auf 0 setzen ;-)
        darkbluD 1 Antwort Letzte Antwort
        • darkbluD darkblu
          Huhu,
          FreunderNachtF Offline
          FreunderNacht
          schrieb am zuletzt editiert von FreunderNacht
          #1136
          @darkblu
          das geht direkt an der Uhr.
          Mittler Knopf lang drücken, dann kommst du in das Menü.
          Dort unter Apps kannst du die Standard Apps deaktivieren und aktivieren.
          Steht auch in der Doku:
          Doku
          Doku 2
          Intel NUC mit Proxmox
          IO Broker (Homematic IP / CCU3 / Shelly / Tasmota / Zigbee)
          Influx DB
          Grafana
          PiHole
          PiVPN
          • P pfeiferj12
            darkbluD Offline
            darkbluD Offline
            darkblu
            #1137
            @pfeiferj12 said in Test Adapter Awtrix-Light:
            Danke, da muss man erst mal drauf kommen
              @darkblu
              Doku
              Doku 2
              DJMarc75D Offline
              DJMarc75D Offline
              DJMarc75
              #1138
              @freundernacht
              Bitte erst genau lesen was gefragt wird !!!
              @darkblu sagte in Test Adapter Awtrix-Light:
              Da hilft sowas als Antwort wohl kaum !
              @freundernacht sagte in Test Adapter Awtrix-Light:
              Lehrling seit 1975 !!!
              • chucky666C Online
                chucky666C Online
                chucky666
                schrieb am zuletzt editiert von chucky666
                #1139
                Danke für den Adapter und der Tipp mit der Uhr
                habe meine seit gestern und bin begeistert
                kann man bei den Custom apps , es auch so einstellen das zum beispiel ab 150w PV leistung erst etwas angezeigt wird ?
                Was bedeutet im Blocky das Stapeln ?
                • darkbluD Offline
                  darkbluD Offline
                  darkblu
                  #1140
                  Sodele, nachdem ich gestern auf
                  aktualisiert habe ist die erste Ulanzi nun schon nach ca. 2 Monaten kaputt.
                  Mit den Updates ist wohl Zufall.
                  Das Ding verliert nach ca. 2 Minuten die W LAN Verbindung 😥
                  Neu flashen hat auch nicht geholfen.
                  Werde jetzt mal eine neue bestellen, Rabattcode U15 ist immer noch gültig, bin gespannt wie lange die dann hält.
                  DiginixD chucky666C 2 Antworten Letzte Antwort
                  • darkbluD darkblu
                    DiginixD Offline
                    DiginixD Offline
                    Diginix
                    #1141
                    @darkblu An der Firmware kann es nicht liegen. Du kannst auch die originale von der Ulanzi Website herunterladen und über das Webinterface flashen. Der einzig bekannte Hardware Designfehler ist der Spannugsregler der bei zu starken Netzteilen kaputt gehen kann. Bisher haben alle, die es in der Discord Gruppe geschrieben haben, eine neue von Ulanzi erhalten. Bei dem Bug ist die Uhr aber dann dauerhaft tot und verliert nicht nur die WLAN Verbindung wie bei dir. Ich würde erstmal das Netzwerk prüfen, die Firmware ggf. mir erase erneut flashen usw.
                    ..:: So long! Tom ::..
                    • darkbluD darkblu
                      chucky666C Online
                      chucky666C Online
                      chucky666
                      #1142
                      @darkblu welches Netzteil benutzt du ? habe irgendwo gelesen ,das ein zu starkes Netzteil nicht gut ist für die Uhr
                      • chucky666C chucky666
                        DiginixD Offline
                        DiginixD Offline
                        Diginix
                        #1143
                        @chucky666 Der dadurch möglicherweise auftretende Schaden resultiert aber in einer toten Uhr und nicht in einer die Netzwerkprobleme hat. Dennoch kann es nicht schaden auch mal das Netzteil zu tauschen oder nur im Akkubetrieb den Fehler zu analysieren.
                        chucky666C 1 Antwort Letzte Antwort
                        • DiginixD Diginix
                          chucky666C Online
                          chucky666C Online
                          chucky666
                          #1144
                          @diginix weißt du welche spannung empfohlen wird ?
                            DiginixD Offline
                            DiginixD Offline
                            Diginix
                            #1145
                            @chucky666 Bei mir laufen 3 Uhren dauerhaft an USB Netzteilen. Zwei davon schon seit April, alle aber mit reinen 5V Netzteilen. Eines hat 1A eines 2A und eines 1,5A. Andere sagen nur 5V mit 1A wäre gut. Ich würde eher sagen nur 5V ist wichtig aber Strom ist egal. Also keine Quickcharger oder PD USB Netztteile, die 5, 9, 12 und 20 Volt liefern. Es ist ja mWn auch der Spannungsregler der kaputt geht und der ist eben auf eine Eingangsspannung von 5V ausgelegt. Liefert das Netzteil aber auch mal mehr dann opfert sich das Bauteil. Lässt sich aber sogar selbst reparieren wenn man mit Lötkolben umgehen kann.
                            • darkbluD Offline
                              darkbluD Offline
                              darkblu
                              #1146
                              erstmal Danke für die Hinweise,
                              mir ist gerade aufgefallen, dass die Ulanzi offline geht, wenn sie mit dem ioBroker (sprich mit dem Awtrix-Light Adapter) verbunden ist.
                              Ulanzi mit Awtrix-Light Adapter (ioBroker) verbunden, verliert nach ca. 2 Minuten die online Verbindung.
                              Awtrix-Light Adapter stoppen, Ulanzi neu starten (Knöppe links und rechts drücken für aus und dann wieder für an) Ulanzi bleibt online.
                              Werde jetzt mal alle Apps der Reihen nach löschen, vielleicht komm ich da zu einem Verursacher.
                              • darkbluD Offline
                                darkbluD Offline
                                darkblu
                                #1147
                                Sodele, Fehler scheinbar gefunden.
                                Ich hatte die Idee, mir per Blockly während der Musikwiedergabe Titel und Interpret auf der Ulanzi Anzeigen zu lassen
                                Offenbar sorgt das aber dafür, dass wenn das Blockly ausgeführt wird, also während der Musikwiedergabe, alle Custom Apps
                                ihre Daten nicht mehr an die Ulanzi senden können.
                                Das ioBroker Log läuft dann mit 100en Warnmeldungen der Custom Apps voll und die Ulanzi geht offline. Schade.
                                Hat vielleicht jemand eine andere Idee, wie ich mir Titel und Interpret anzeigen lassen kann ?
                                Das war für den kurzen Moment für Frau und Kind der Hit, besser als die drögen Daten. 😞
                                • darkbluD darkblu
                                  #1148
                                  @darkblu Eventuell ist die Dauer auch zu lang. 50 Sekunden ist ja echt viel. Wenn Du dann 2-3x direkt ein Lied weiter machst, dann stauen sich die Notifications ja
                                    darkbluD Offline
                                    darkbluD Offline
                                    darkblu
                                    schrieb am zuletzt editiert von darkblu
                                    #1149
                                    @haus-automatisierung ,
                                    … und weil ich ja mit “erstelle Text aus“ 2 Texten mache sind es 100 Sekunden. Das dann über viele Songs…
                                    Da kommt einiges zusammen.
                                    Dann brauch ich wohl doch noch eine weitere Ulanzi ohne Custom Apps, die dann nur für die Musik zuständig ist.
                                    Edit: gesagt, getan. Nummer 3 ist unterwegs
                                    • darkbluD darkblu
                                      #1150
                                      @darkblu Mh? Ne die Zeit bleibt die gleiche, auch für längere Texte
                                      • darkbluD Offline
                                        darkbluD Offline
                                        darkblu
                                        #1151
                                        @haus-automatisierung , hast Recht.
                                        Ich hätte schwören können, gut das ichˋs nicht gemacht habe.
                                        • BravestarrB Offline
                                          BravestarrB Offline
                                          Bravestarr
                                          #1152
                                          Ich habe mal meine echten JavaScript-Snippets in ein Repo auf GitHub gesteckt. Das kann gerne erweitert und genutzt werden. Und wenn es nur eine Inspiration ist für die eigenen Projekte. Ich freue mich natürlich über Pull Requests. https://github.com/mtoensing/ulanzi-awtrix-iobroker-javascript-snippets/
