  4. Lesekopf-probleme wegen udev-Bug
    5.1k
80 Beiträge 7 Kommentatoren 9.9k Aufrufe 4 Beobachtet
  • L lukas.g
    Frische Instanz mit USB-Auswahl:
    Debug Log:
    2023-07-20 22:48:32.300 - info: host.rpi-lg2 iobroker add smartmeter 0 --host rpi-lg2 --debug
    2023-07-20 22:48:49.549 - info: host.rpi-lg2 iobroker host.rpi-lg2 create instance smartmeter
    2023-07-20 22:48:49.672 - info: host.rpi-lg2 iobroker host.rpi-lg2 object system.adapter.smartmeter.0.alive created
    2023-07-20 22:48:49.742 - info: host.rpi-lg2 iobroker host.rpi-lg2 object system.adapter.smartmeter.0.connected created
    2023-07-20 22:48:49.809 - info: host.rpi-lg2 iobroker host.rpi-lg2 object system.adapter.smartmeter.0.compactMode created
    2023-07-20 22:48:49.885 - info: host.rpi-lg2 iobroker host.rpi-lg2 object system.adapter.smartmeter.0.cpu created
    2023-07-20 22:48:49.949 - info: host.rpi-lg2 iobroker host.rpi-lg2 object system.adapter.smartmeter.0.cputime created
    2023-07-20 22:48:50.007 - info: host.rpi-lg2 iobroker host.rpi-lg2 object system.adapter.smartmeter.0.memHeapUsed created
    2023-07-20 22:48:50.082 - info: host.rpi-lg2 iobroker host.rpi-lg2 object system.adapter.smartmeter.0.memHeapTotal created
    2023-07-20 22:48:50.143 - info: host.rpi-lg2 iobroker host.rpi-lg2 object system.adapter.smartmeter.0.memRss created
    2023-07-20 22:48:50.206 - info: host.rpi-lg2 iobroker host.rpi-lg2 object system.adapter.smartmeter.0.uptime created
    2023-07-20 22:48:50.277 - info: host.rpi-lg2 iobroker host.rpi-lg2 object system.adapter.smartmeter.0.inputCount created
    2023-07-20 22:48:50.333 - info: host.rpi-lg2 iobroker host.rpi-lg2 object system.adapter.smartmeter.0.outputCount created
    2023-07-20 22:48:50.463 - info: host.rpi-lg2 iobroker host.rpi-lg2 object system.adapter.smartmeter.0.eventLoopLag created
    2023-07-20 22:48:50.559 - info: host.rpi-lg2 iobroker host.rpi-lg2 object system.adapter.smartmeter.0.sigKill created
    2023-07-20 22:48:50.643 - info: host.rpi-lg2 iobroker host.rpi-lg2 object system.adapter.smartmeter.0.logLevel created
    2023-07-20 22:48:50.727 - info: host.rpi-lg2 iobroker host.rpi-lg2 object smartmeter.0.info created
    2023-07-20 22:48:50.798 - info: host.rpi-lg2 iobroker host.rpi-lg2 object smartmeter.0.info.connection created
    2023-07-20 22:48:50.832 - info: host.rpi-lg2 iobroker host.rpi-lg2 Set default value of smartmeter.0.info.connection: false
    2023-07-20 22:48:50.935 - info: host.rpi-lg2 iobroker host.rpi-lg2 object system.adapter.smartmeter.0 created
    2023-07-20 22:48:52.158 - info: host.rpi-lg2 iobroker exit 0
    2023-07-20 22:48:54.569 - info: host.rpi-lg2 instance system.adapter.smartmeter.0 started with pid 2385
    2023-07-20 22:48:55.329 - info: admin.0 (781) ==> Connected system.user.admin from ::ffff:192.168.100.202
    2023-07-20 22:49:15.281 - info: smartmeter.0 (2385) starting. Version 3.3.4 in /opt/iobroker/node_modules/iobroker.smartmeter, node: v16.20.1, js-controller: 4.0.24
    2023-07-20 22:49:15.488 - error: smartmeter.0 (2385) Serial port device is undefined, check your configuration!
    2023-07-20 22:49:17.488 - info: smartmeter.0 (2385) List of port: [{"path":"/dev/ttyAMA0"},{"path":"/dev/ttyUSB0","manufacturer":"Silicon Labs","serialNumber":"0001","pnpId":"usb-Silicon_Labs_CP2102_USB_to_UART_Bridge_Controller_0001-if00-port0","vendorId":"10c4","productId":"ea60"}]
    2023-07-20 22:50:48.066 - info: host.rpi-lg2 stopInstance system.adapter.smartmeter.0 (force=false, process=true)
    2023-07-20 22:50:48.111 - info: smartmeter.0 (2385) Got terminate signal TERMINATE_YOURSELF
    2023-07-20 22:50:48.185 - info: admin.0 (781) <== Disconnect system.user.admin from ::ffff:192.168.100.202
    2023-07-20 22:50:48.141 - info: smartmeter.0 (2385) terminating
    2023-07-20 22:50:48.170 - info: smartmeter.0 (2385) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-07-20 22:50:48.304 - info: host.rpi-lg2 stopInstance system.adapter.smartmeter.0 send kill signal
    2023-07-20 22:50:48.964 - info: host.rpi-lg2 instance system.adapter.smartmeter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-07-20 22:50:51.457 - info: host.rpi-lg2 instance system.adapter.smartmeter.0 started with pid 2401
    2023-07-20 22:51:11.310 - info: smartmeter.0 (2401) starting. Version 3.3.4 in /opt/iobroker/node_modules/iobroker.smartmeter, node: v16.20.1, js-controller: 4.0.24
    2023-07-20 22:51:17.340 - info: host.rpi-lg2 stopInstance system.adapter.smartmeter.0 (force=false, process=true)
    2023-07-20 22:51:17.389 - info: smartmeter.0 (2401) Got terminate signal TERMINATE_YOURSELF
    2023-07-20 22:51:17.447 - info: smartmeter.0 (2401) terminating
    2023-07-20 22:51:17.479 - info: smartmeter.0 (2401) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-07-20 22:51:17.559 - info: host.rpi-lg2 stopInstance system.adapter.smartmeter.0 send kill signal
    2023-07-20 22:51:18.307 - info: host.rpi-lg2 instance system.adapter.smartmeter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-07-20 22:51:20.701 - info: host.rpi-lg2 instance system.adapter.smartmeter.0 started with pid 2416
    2023-07-20 22:51:36.525 - debug: smartmeter.0 (2416) Redis Objects: Use Redis connection: 127.0.0.1:9001
    2023-07-20 22:51:36.859 - debug: smartmeter.0 (2416) Objects client ready ... initialize now
    2023-07-20 22:51:36.878 - debug: smartmeter.0 (2416) Objects create System PubSub Client
    2023-07-20 22:51:36.889 - debug: smartmeter.0 (2416) Objects create User PubSub Client
    2023-07-20 22:51:37.075 - debug: smartmeter.0 (2416) Objects client initialize lua scripts
    2023-07-20 22:51:37.147 - debug: smartmeter.0 (2416) Objects connected to redis: 127.0.0.1:9001
    2023-07-20 22:51:37.306 - debug: smartmeter.0 (2416) Redis States: Use Redis connection: 127.0.0.1:9000
    2023-07-20 22:51:37.380 - debug: smartmeter.0 (2416) States create System PubSub Client
    2023-07-20 22:51:37.391 - debug: smartmeter.0 (2416) States create User PubSub Client
    2023-07-20 22:51:37.527 - debug: smartmeter.0 (2416) States connected to redis: 127.0.0.1:9000
    2023-07-20 22:51:37.738 - debug: smartmeter.0 (2416) Plugin sentry Initialize Plugin (enabled=true)
    2023-07-20 22:51:40.509 - info: smartmeter.0 (2416) starting. Version 3.3.4 in /opt/iobroker/node_modules/iobroker.smartmeter, node: v16.20.1, js-controller: 4.0.24
    2023-07-20 22:51:40.708 - debug: smartmeter.0 (2416) SmartmeterObis options: {"debug":2,"protocol":"SmlProtocol","transport":"SerialResponseTransport","requestInterval":"300","anotherQueryDelay":"1000","transportSerialPort":"/dev/serial/by-id/usb-Silicon_Labs_CP2102_USB_to_UART_Bridge_Controller_0001-if00-port0","transportSerialBaudrate":null,"transportSerialMessageTimeout":null,"protocolSmlIgnoreInvalidCRC":false}
    2023-07-20 22:51:40.727 - debug: smartmeter.0 (2416) CREATE SERIALPORT: 9600 8 1 none
    2023-07-20 22:51:40.834 - debug: smartmeter.0 (2416) SERIALPORT OPEN
    2023-07-20 22:51:40.985 - debug: smartmeter.0 (2416) SET MESSAGE TIMEOUT TIMER: 120000
    2023-07-20 22:51:41.084 - debug: smartmeter.0 (2416) connected set to false
    2023-07-20 22:53:40.992 - debug: smartmeter.0 (2416) MESSAGE TIMEOUT TRIGGERED
    2023-07-20 22:53:41.002 - debug: smartmeter.0 (2416) Error: No or too long answer from Serial Device after last request.
    2023-07-20 22:53:41.012 - warn: smartmeter.0 (2416) No or too long answer from Serial Device after last request.
    2023-07-20 22:53:41.017 - debug: smartmeter.0 (2416) Error: No or too long answer from Serial Device after last request.
    2023-07-20 22:53:41.022 - debug: smartmeter.0 (2416) Transport Reset!! Restart = true
    2023-07-20 22:53:41.043 - debug: smartmeter.0 (2416) SERIALPORT CLOSE
    2023-07-20 22:53:41.049 - debug: smartmeter.0 (2416) SCHEDULE NEXT RUN IN 300s
    2023-07-20 22:58:41.052 - debug: smartmeter.0 (2416) CREATE SERIALPORT: 9600 8 1 none
    2023-07-20 22:58:41.064 - debug: smartmeter.0 (2416) SERIALPORT OPEN
    2023-07-20 22:58:41.082 - debug: smartmeter.0 (2416) SET MESSAGE TIMEOUT TIMER: 120000
    2023-07-20 23:00:41.093 - debug: smartmeter.0 (2416) MESSAGE TIMEOUT TRIGGERED
    2023-07-20 23:00:41.097 - debug: smartmeter.0 (2416) Error: No or too long answer from Serial Device after last request.
    2023-07-20 23:00:41.101 - warn: smartmeter.0 (2416) No or too long answer from Serial Device after last request.
    2023-07-20 23:00:41.103 - debug: smartmeter.0 (2416) Error: No or too long answer from Serial Device after last request.
    2023-07-20 23:00:41.106 - debug: smartmeter.0 (2416) Transport Reset!! Restart = true
    2023-07-20 23:00:41.114 - debug: smartmeter.0 (2416) SERIALPORT CLOSE
    2023-07-20 23:00:41.118 - debug: smartmeter.0 (2416) SCHEDULE NEXT RUN IN 300s
    @homoran said in Adapter "smartmeter":
    wobei du da ggf. mit dem udev Bug zu kämpfen haben könntest
    Verrate mir bitte, was Du mit "dem udev Bug" meinst.
    @lukas-g sagte in Adapter "smartmeter":
    hat Thomas bereits gemacht. Jetzt bi ich gespannt, ob bei
    SERIALPORT OPEN
    trotzdem udev defekt sein kann
      SERIALPORT OPEN
      Irgendwas ist aber mit dem Port:
        @thomas-braun wieso sehe ich das nicht. 😢 könnte passen!
          @homoran sagte in Adapter "smartmeter":
          wieso sehe ich das nicht. könnte passen!
            @lukas-g
            sudo apt update
            apt policy udev
            ausführen.
            lukas.g
            lukas@rpi-lg2:~ $ sudo apt update
            Get:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease [15.0 kB]
            Get:2 http://archive.raspberrypi.org/debian bullseye InRelease [23.6 kB]
            Get:3 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages [13.2 MB]
            Get:4 http://archive.raspberrypi.org/debian bullseye/main armhf Packages [314 kB]
            Fetched 13.6 MB in 36s (376 kB/s)
            Reading package lists... Done
            4 packages can be upgraded. Run 'apt list --upgradable' to see them.
            lukas@rpi-lg2:~ $ sudo apt list --upgradable
            Listing... Done
            libcamera-apps-lite/stable 1.2.1-1 armhf [upgradable from: 0~git20230301+54a781d-1]
            libcamera0/stable 0~git20230707+2783c8d8-1 armhf [upgradable from: 0~git20230302+923f5d70-1]
            python3-libcamera/stable 0~git20230707+2783c8d8-1 armhf [upgradable from: 0~git20230302+923f5d70-1]
            python3-picamera2/stable 0.3.12-1 all [upgradable from: 0.3.9-1]
            lukas@rpi-lg2:~ $ apt policy udev
            udev:
              Installed: 247.3-7+rpi1+deb11u2
              Candidate: 247.3-7+rpi1+deb11u2
              Version table:
             *** 247.3-7+rpi1+deb11u2 500
            • L lukas.g
              Listing... Done
              udev:
                Version table:
              @lukas-g
              Ja, das ist das kaputte udev.
              Gibt einen Thread dazu von @mickym
              L 1 Antwort Letzte Antwort
                tomasog
                leider bekomme ich meinen Adapter nicht installiert.
                Ich habe ein Landis+Gyr e350 und folgende Werte gemäß Volkszähler (https://wiki.volkszaehler.org/hardware/channels/meters/power/edl-ehz/landisgyr_e350) eingegeben:
                Könnt Ihr mir bitte weiterhelfen?
                Habe ich die Initialisierungssequenz richtig eingegeben?
                Vielen Dank für Eure Hilfe!
                • T tomasog
                  @tomasog sagte in Adapter "smartmeter":
                  Für dich gilt das selbe wie beim Fall unmittelbar davor!
                  Grundsätzlich erst mal alles auf default lassen!
                  lass alles leer bis auf de USB Port.
                  was steht im debug log beim Adapter start?
                    @lukas-g
                    lukas.g
                    @thomas-braun said in Adapter "smartmeter":
                    Sicher, dass es kaputt ist, auch wenn ls -la /dev/serial/by-id das Gerät wie erwartet anzeigt?
                    • L lukas.g
                      @lukas-g
                      Ja.
                      Ist die kaputte Version
                      • ? Offline
                        Moin,
                        kannst Du mal schauen, ob er Dir Binär etwas auf der Konsole ausgibt?
                        sudo cat /dev/ttyUSB0
                        Hast Du schon mal den die ID des Sticks genutzt?
                        ls -la /dev/serial/by-id/
                        Durch Umstecken kann sich das /dev/ttyU* mal ändern, die ID bleibt aber immer gleich.
                        Ich hoffe, dass es bei den Hitch-USB auch so ist, wie bei den Zigbee Sticks, dass er da etwas unter /dev/serial/ anlegen.
                        Bernd
                        P.S.: schon mal einen kompletten Reboot gemacht?
                        T L 2 Antworten Letzte Antwort
                          Moin,
                          Bernd
                          TT-Tom
                          @dp20eic sagte in Adapter "smartmeter":
                          meiner macht das, sollte also funktionieren
                          Gruß Tom
                          Public Transport
                          NSPanel Adapter Wiki
                          • T TT-Tom
                            Meister MopperM Online
                            Meister Mopper
                            v3.3.4, gelesen wird mit einem Hichi am Raspberry Pi 4
                            Schlagartig (21.07.2023,15:41 Uhr) werden keine Daten mehr geliefert und der Adapter kann sich nicht mehr mit dem Gerät verbinden.
                            Probeweise habe ich ohne Erfolg mal sentry ausgeschaltet, den Adapter gestoppt, den Hichi mal abgezogen und neu gesteckt => alles ohne Erfolg.
                            debug log beim Starten des Adapters:
                            smartmeter.0	2023-07-25 10:23:16.448	debug	Redis Objects: Use Redis connection: 192.168.178.10:9001
                            smartmeter.0	2023-07-25 10:23:16.508	debug	Objects client ready ... initialize now
                            smartmeter.0	2023-07-25 10:23:16.512	debug	Objects create System PubSub Client
                            smartmeter.0	2023-07-25 10:23:16.513	debug	Objects create User PubSub Client
                            smartmeter.0	2023-07-25 10:23:16.588	debug	Objects client initialize lua scripts
                            smartmeter.0	2023-07-25 10:23:16.597	debug	Objects connected to redis: 192.168.178.10:9001
                            smartmeter.0	2023-07-25 10:23:16.646	debug	Redis States: Use Redis connection: 192.168.178.10:6379
                            smartmeter.0	2023-07-25 10:23:16.657	debug	States create System PubSub Client
                            smartmeter.0	2023-07-25 10:23:16.659	debug	States create User PubSub Client
                            smartmeter.0	2023-07-25 10:23:16.673	debug	States connected to redis: 192.168.178.10:6379
                            smartmeter.0	2023-07-25 10:23:16.718	debug	Plugin sentry Initialize Plugin (enabled=true)
                            smartmeter.0	2023-07-25 10:23:17.078	info	starting. Version 3.3.4 in /opt/iobroker/node_modules/iobroker.smartmeter, node: v18.17.0, js-controller: 4.0.24
                            smartmeter.0	2023-07-25 10:23:17.120	debug	SmartmeterObis options: {"debug":2,"protocol":"SmlProtocol","transport":"SerialResponseTransport","requestInterval":"10","anotherQueryDelay":"1000","transportSerialPort":"/dev/serial/by-id/usb-1a86_USB_Serial-if00-port0","transportSerialBaudrate":null,"transportSerialMessageTimeout":null,"protocolSmlIgnoreInvalidCRC":false}
                            smartmeter.0	2023-07-25 10:23:17.124	debug	CREATE SERIALPORT: 9600 8 1 none
                            smartmeter.0	2023-07-25 10:23:17.133	debug	SET MESSAGE TIMEOUT TIMER: 120000
                            smartmeter.0	2023-07-25 10:23:17.155	debug	connected set to false
                            Der Zähler ist ein Itron, neu installiert im März 2022.
                            Ich habe hier gelesen, dass die LED der Zähler schnell altersschwach werden und nicht mehr ausgelesen werden können. Kann das sein?
                            Proxmox und HA ...
                            Ich schreibe den Code nicht mehr selbst – ich schimpfe mit der KI, bis er funktioniert.
                            HomoranH ? 2 Antworten Letzte Antwort
                              @meister-mopper sagte in Adapter "smartmeter":
                              Kann das sein?
                              ja.
                              Alternativ kann auch der Lesekopf defekt sein
                              Gemacht hast du nichts?
                              Stromausfall war auch nicht?
                              • auch nicht eine Sekunde?
                              Meister MopperM HomoranH 2 Antworten Letzte Antwort
                                Kann das sein?
                                ja.
                                Meister Mopper
                                schrieb am zuletzt editiert von Meister Mopper
                                Nein, nein, das hätte mir die USV gemeldet. Ach ja, ich habe natürlich auch nachgesehen, ob der PIN noch drin war, habe ihn sogar deaktiviert und neu eingegeben.
                                Edit:
                                • Am Donnerstag kommt ein Mitarbeiter des Netzbetreibers und schaut sich den Zähler an.
                                • Einen neuen Hichi habe ich sicherheitshalber auch bestellt.
                                Proxmox und HA ...
                                  Moin,
                                  ich lese hin und wieder, dass man das mittels Handy Cam checken kann, wenn die Sendeleistung schwächer wird, dann ist es im Bild wohl zu sehen.
                                  Bernd
                                    Moin,
                                    Bernd
                                    nur wenn die CAM keinen IR Sperrfilter hat, was neuere Modelle oft haben.
                                    ggf. vorher mit einer IR Fernbedienung prüfen
                                      Meister Mopper
                                      Wie geht man da vor?
                                      Proxmox und HA ...
                                        @meister-mopper per camera draufsehen
                                        wenn kein IR Sperrfilter drin ist siehst du es blinken.
                                        genauso bei einer IR Fernbedienung wenn du einen Knopf drückst
                                          Moin,
                                          ich verstehe das so, dass man den Hichi abnimmt, um freie Sicht auf die IR zu haben, dann die Cam des Handys öffnen und mit der Linse auf die IR Öffnung halten, ein paar cm muss man probieren, wegen Fokus und so, ist die IR LED noch gut, dann sieht man ein deutliches Flackern, der IR LED, ist sie schon altersschwach, dann sieht man meist nur ein glimmen.
                                          Bernd
                                          P.S.: natürlich hat @Homoran recht, die Cam darf kein IR Sperrfilter haben. Aber egal ausprobieren kostet ja nichts :)
                                          HomoranH Meister MopperM 2 Antworten Letzte Antwort
