  4. Frigate Adapter für ioBroker
    6.3k
383 Beiträge 48 Kommentatoren 140.7k Aufrufe 45 Beobachtet
  • S SidM
    @wal
    hier der auszug:
    {"Hof": {"camera_fps": 5.3, "process_fps": 5.3, "skipped_fps": 0.0, "detection_fps": 0.0, "detection_enabled": 1, "pid": 587, "capture_pid": 591, "ffmpeg_pid": 19034}, "Werkstatt": {"camera_fps": 5.3, "process_fps": 5.3, "skipped_fps": 0.0, "detection_fps": 0.0, "detection_enabled": 1, "pid": 588, "capture_pid": 594, "ffmpeg_pid": 19001}, "Flur": {"camera_fps": 5.0, "process_fps": 5.0, "skipped_fps": 0.0, "detection_fps": 0.0, "detection_enabled": 1, "pid": 590, "capture_pid": 597, "ffmpeg_pid": 15700}, "detectors": {"coral": {"inference_speed": 8.3, "detection_start": 0.0, "pid": 578}}, "detection_fps": 0.0, "gpu_usages": {"intel-vaapi": {"gpu": "3.55 %", "mem": "- %"}}, "cpu_usages": {"top": {"cpu": "users,", "mem": "load"}, "Tasks:": {"cpu": "stopped,", "mem": "0"}, "%Cpu(s):": {"cpu": "id,", "mem": "1.4"}, "MiB": {"cpu": "41291.2", "mem": "avail"}, "PID": {"cpu": "%CPU", "mem": "%MEM"}, "89": {"cpu": "10.0", "mem": "0.1"}, "580": {"cpu": "2.3", "mem": "0.3"}, "597": {"cpu": "5.3", "mem": "0.3"}, "15700": {"cpu": "5.0", "mem": "0.2"}, "19001": {"cpu": "5.6", "mem": "0.2"}, "1": {"cpu": "0.0", "mem": "0.0"}, "15": {"cpu": "0.0", "mem": "0.0"}, "16": {"cpu": "0.0", "mem": "0.0"}, "24": {"cpu": "0.0", "mem": "0.0"}, "25": {"cpu": "0.0", "mem": "0.0"}, "26": {"cpu": "0.0", "mem": "0.0"}, "27": {"cpu": "0.0", "mem": "0.0"}, "28": {"cpu": "0.0", "mem": "0.0"}, "29": {"cpu": "0.0", "mem": "0.0"}, "30": {"cpu": "0.0", "mem": "0.0"}, "31": {"cpu": "0.0", "mem": "0.0"}, "32": {"cpu": "0.0", "mem": "0.0"}, "41": {"cpu": "0.0", "mem": "0.0"}, "42": {"cpu": "0.0", "mem": "0.0"}, "80": {"cpu": "0.0", "mem": "0.0"}, "81": {"cpu": "0.0", "mem": "0.0"}, "82": {"cpu": "0.0", "mem": "0.0"}, "97": {"cpu": "0.0", "mem": "0.0"}, "98": {"cpu": "1.0", "mem": "0.7"}, "113": {"cpu": "0.0", "mem": "0.0"}, "134": {"cpu": "0.0", "mem": "0.0"}, "135": {"cpu": "0.0", "mem": "0.0"}, "136": {"cpu": "0.0", "mem": "0.0"}, "140": {"cpu": "0.0", "mem": "0.0"}, "157": {"cpu": "0.0", "mem": "0.0"}, "182": {"cpu": "0.0", "mem": "0.0"}, "211": {"cpu": "0.0", "mem": "0.0"}, "241": {"cpu": "0.0", "mem": "0.0"}, "272": {"cpu": "0.0", "mem": "0.0"}, "302": {"cpu": "0.0", "mem": "0.0"}, "323": {"cpu": "0.0", "mem": "0.0"}, "337": {"cpu": "0.0", "mem": "0.0"}, "571": {"cpu": "0.0", "mem": "0.1"}, "577": {"cpu": "0.0", "mem": "0.0"}, "578": {"cpu": "0.0", "mem": "0.3"}, "586": {"cpu": "0.0", "mem": "0.0"}, "587": {"cpu": "1.0", "mem": "0.3"}, "588": {"cpu": "0.7", "mem": "0.3"}, "589": {"cpu": "0.0", "mem": "0.0"}, "590": {"cpu": "0.7", "mem": "0.3"}, "591": {"cpu": "6.0", "mem": "0.3"}, "594": {"cpu": "7.6", "mem": "0.3"}, "602": {"cpu": "0.0", "mem": "0.0"}, "611": {"cpu": "0.0", "mem": "0.2"}, "15653": {"cpu": "0.7", "mem": "0.0"}, "16079": {"cpu": "1.0", "mem": "0.0"}, "16080": {"cpu": "1.0", "mem": "0.0"}, "16243": {"cpu": "0.7", "mem": "0.1"}, "17685": {"cpu": "0.7", "mem": "0.0"}, "19034": {"cpu": "5.3", "mem": "0.2"}, "19295": {"cpu": "0.3", "mem": "0.0"}, "19840": {"cpu": "0.0", "mem": "0.0"}, "19856": {"cpu": "0.0", "mem": "0.0"}}, "service": {"uptime": 21060, "version": "0.12.0-da3e197", "latest_version": "0.12.0", "storage": {"/media/frigate/recordings": {"total": 2000397.9, "used": 1099675.5, "free": 899521.9, "mount_type": "btrfs"}, "/media/frigate/clips": {"total": 2000397.9, "used": 1099675.5, "free": 899521.9, "mount_type": "btrfs"}, "/tmp/cache": {"total": 100.0, "used": 31.4, "free": 68.6, "mount_type": "tmpfs"}, "/dev/shm": {"total": 268.4, "used": 24.2, "free": 244.2, "mount_type": "tmpfs"}}, "temperatures": {}, "last_updated": 1683226289}}
    Wenn ich den Code richtig interpretiere, gibt es das nicht bei der USB Coralle.
    Und ist es normal das der Datenpunkt frigate.0.available nichts anzeigt? Ich hätte hier ein true/false erwartet.
    Erneut vielen Dank!
    WalW Offline
    WalW Offline
    Wal
    @sidm ,
    ja die Coral USB zeigt keine Temperatur an. Der Speicherinfo wird mit deiner Stats korrekt bei mir erzeugt.
    @sidm sagte in Test Frigate Adapter 0.1.8:
    Das habe ich im Adapter noch nicht implementiert, der wird nur automatisch erzeugt. Werde mich drum kümmern. ;-)
    Für die Speicherinfo kannst du den Adapter mal auf debug stellen da muss das dann kommen:
    frigate.0
    2023-05-05 02:33:44.002	debug	{"total":67.1,"used":1.7,"free":65.4,"mount_type":"tmpfs"}
    frigate.0
    2023-05-05 02:33:43.803	debug	{"total":1000,"used":1.7,"free":998.3,"mount_type":"tmpfs"}
    frigate.0
    2023-05-05 02:33:43.602	debug	{"total":491105.5,"used":46096.8,"free":419986.6,"mount_type":"ext4"}
    frigate.0
    2023-05-05 02:33:43.403	debug	{"total":491105.5,"used":46096.8,"free":419986.6,"mount_type":"ext4"}
    Walter
    DoorIO-Adapter
    WalW 1 Antwort Letzte Antwort
    • WalW Wal
      @sidm ,
      frigate.0
      frigate.0
      frigate.0
      frigate.0
      WalW Offline
      WalW Offline
      Wal
      schrieb am zuletzt editiert von Wal
      @wal sagte in Test Frigate Adapter 0.1.8:
      @sidm ,
      frigate.0
      frigate.0
      frigate.0
      frigate.0
      Edit: Eben nochmal getestet und die Werte wurden nicht erzeugt. Ich melde mich. ;-)
      EditEdit: Fehler gefunden! Es liegt auch an dem Coral USB, ohne Temperatur wird ein Fehler erzeugt. Das werde ich abfangen.
      Walter
      DoorIO-Adapter
      • S SidM
        @wal
        hier der auszug:
        Erneut vielen Dank!
        WalW Offline
        WalW Offline
        Wal
        @sidm ,
        so sollte jetzt auf dem development Zweig funktionieren.
        Walter
        DoorIO-Adapter
        • S SidM
          @wal
          hier der auszug:
          Erneut vielen Dank!
          WalW Offline
          WalW Offline
          Wal
          So das Problem ist, das der Datenpunkt nur gesetzt wird beim Start und Beenden von Frigate. Wird der Adapter neu gestartet, bekommt er dementsprechend noch keine Nachricht.
          Da Frigate auch Online ist wenn Statsmeldungen eintrudeln, setze ich hiermit "available" auch auf "online".
          Development Pfad.
          Walter
          DoorIO-Adapter
          • WalW Offline
            WalW Offline
            Wal
            v0.1.9
            neue Objekte uptime, Version ...
            Walter
            DoorIO-Adapter
            • WalW Offline
              WalW Offline
              Wal
              v0.2.1
              Optimierungen im Code
              Walter
              DoorIO-Adapter
              • WalW Wal
                v0.2.1
                SidM
                @wal
                Super Walter! jetzt werden die stats angezeigt, available und auch die neuen Werte werden einwandfrei befüllt.
                Klasse Arbeit und besten Dank! Einen schönen Sonntag noch.:man-raising-hand:
                • WalW Offline
                  WalW Offline
                  Wal
                  v0.2.2
                  Übersetzungen in den Settings in mehreren Sprachen
                  Walter
                  DoorIO-Adapter
                  • WalW Offline
                    WalW Offline
                    Wal
                    v0.2.5
                    https Url für frigateaufruf im Adapter gefixt
                    Walter
                    DoorIO-Adapter
                    • U Offline
                      U Offline
                      umichel
                      schrieb am zuletzt editiert von umichel
                      Hmm ... der Adapter dürfte viele interessieren.
                      Nur irgendwie bin ich zu dumm die Installation zu verstehen.
                      Frigate als Docker installieren?
                      Und der Adpater komuniziert dann über MQTT mit Frigate?
                      Was muss ich denn jetzt genau dafür wo einstellen bzw. installieren?
                      • U umichel
                        WalW Offline
                        WalW Offline
                        Wal
                        @umichel ,
                        frigate ist ein Docker-Container, wie das installiert wird steht in der Frigate Doku.
                        Nach der Installation wird MQTT in der Frigate Config aktiviert und mit dem ioBroker MQTT-Adapter der als Server läuft verbunden.
                        @umichel sagte in Test Frigate Adapter 0.2.5:
                        Ja.
                        Für Proxmox habe ich eine Anleitung erstellt.
                        Walter
                        DoorIO-Adapter
                        U crunchipC 2 Antworten Letzte Antwort
                        • WalW Wal
                          @umichel ,
                          Ja.
                          U Offline
                          U Offline
                          umichel
                          OK, danke.
                          Ich teste das mal mit einem Container unter einer OMV VM.
                          Der Nachteil dürfte die fehlende Hardwarebeschleunigung sein, wobei ich auch nicht weiss ob man die wirklich benötigt für Frigate.
                          • U umichel
                            OK, danke.
                            WalW Offline
                            WalW Offline
                            Wal
                            @umichel ,
                            ja die wird benötigt, da sonst die CPU-Last enorm hoch ist.
                            Bei 1 bis 2 Kameras geht es aber noch.
                            Walter
                            DoorIO-Adapter
                            H 1 Antwort Letzte Antwort
                            • WalW Wal
                              @umichel ,
                              Ja.
                              crunchipC Offline
                              crunchipC Offline
                              @wal sagte in Test Frigate Adapter 0.2.5:
                              werd ich mir die Tage auch mal ansehen, mit motioneye hab ich zu viele Fehlauslösungen, grad wenn sich die Lichtverhältnisse(Sonne) sich ändern
                                WalW Offline
                                WalW Offline
                                Wal
                                @crunchip ,
                                mit Frigate hatte ich bis jetzt lass mich kurz überlegen 0 Fehlauslösungen. ;-)
                                Walter
                                DoorIO-Adapter
                                • WalW Wal
                                  @crunchip ,
                                  crunchipC Offline
                                  crunchipC Offline
                                  @wal klingt gut, allerdings hab ich bisserl Bammel ob ich das mit allen Kameras zum laufen bekomm, bezogen auf Installation und Einstellungen
                                    WalW Offline
                                    WalW Offline
                                    Wal
                                    @crunchip ,
                                    ja die Konfiguration und Installation ist nicht ohne.
                                    Ohne Coral TPU kannst du den OpenVINO Detector nutzen, der ist mittlerweile auch sehr gut.
                                    Walter
                                    DoorIO-Adapter
                                    • WalW Wal
                                      @crunchip ,
                                      crunchipC Offline
                                      crunchipC Offline
                                      ok, guck ich mal, da ich keine Coral TPU habe
                                      • U Offline
                                        U Offline
                                        umichel
                                        Aktuell nutze ich auch MotionEye.
                                        Aber eigentlich nur für die Transcodierung fürs Tablet, nicht für eine Bewegungserkennung.
                                        Bei meiner Reolink funktioniert die Personenerkennung nicht wirklich gut bzw. bei Nachtsicht noch viel weniger.
                                        Wäre halt schön, wenn Frigate sowohl eine gute Personenerkennung und eine Transcodierung bietet?
                                        • U umichel
                                          WalW Offline
                                          WalW Offline
                                          Wal
                                          @umichel ,
                                          frigate nutzt go2rtc zum transcodieren , Personenerkennung bei mir 100%.
                                          Man braucht aber nicht glauben, das man langsamere Hardware als Motioneye braucht.
                                          Walter
                                          DoorIO-Adapter
                                          EisteeE 1 Antwort Letzte Antwort
