  4. Frigate Adapter für ioBroker
    6.3k
383 Beiträge 48 Kommentatoren 140.6k Aufrufe 45 Beobachtet
  • S SidM
    @wal
    hier der auszug:
    {"Hof": {"camera_fps": 5.3, "process_fps": 5.3, "skipped_fps": 0.0, "detection_fps": 0.0, "detection_enabled": 1, "pid": 587, "capture_pid": 591, "ffmpeg_pid": 19034}, "Werkstatt": {"camera_fps": 5.3, "process_fps": 5.3, "skipped_fps": 0.0, "detection_fps": 0.0, "detection_enabled": 1, "pid": 588, "capture_pid": 594, "ffmpeg_pid": 19001}, "Flur": {"camera_fps": 5.0, "process_fps": 5.0, "skipped_fps": 0.0, "detection_fps": 0.0, "detection_enabled": 1, "pid": 590, "capture_pid": 597, "ffmpeg_pid": 15700}, "detectors": {"coral": {"inference_speed": 8.3, "detection_start": 0.0, "pid": 578}}, "detection_fps": 0.0, "gpu_usages": {"intel-vaapi": {"gpu": "3.55 %", "mem": "- %"}}, "cpu_usages": {"top": {"cpu": "users,", "mem": "load"}, "Tasks:": {"cpu": "stopped,", "mem": "0"}, "%Cpu(s):": {"cpu": "id,", "mem": "1.4"}, "MiB": {"cpu": "41291.2", "mem": "avail"}, "PID": {"cpu": "%CPU", "mem": "%MEM"}, "89": {"cpu": "10.0", "mem": "0.1"}, "580": {"cpu": "2.3", "mem": "0.3"}, "597": {"cpu": "5.3", "mem": "0.3"}, "15700": {"cpu": "5.0", "mem": "0.2"}, "19001": {"cpu": "5.6", "mem": "0.2"}, "1": {"cpu": "0.0", "mem": "0.0"}, "15": {"cpu": "0.0", "mem": "0.0"}, "16": {"cpu": "0.0", "mem": "0.0"}, "24": {"cpu": "0.0", "mem": "0.0"}, "25": {"cpu": "0.0", "mem": "0.0"}, "26": {"cpu": "0.0", "mem": "0.0"}, "27": {"cpu": "0.0", "mem": "0.0"}, "28": {"cpu": "0.0", "mem": "0.0"}, "29": {"cpu": "0.0", "mem": "0.0"}, "30": {"cpu": "0.0", "mem": "0.0"}, "31": {"cpu": "0.0", "mem": "0.0"}, "32": {"cpu": "0.0", "mem": "0.0"}, "41": {"cpu": "0.0", "mem": "0.0"}, "42": {"cpu": "0.0", "mem": "0.0"}, "80": {"cpu": "0.0", "mem": "0.0"}, "81": {"cpu": "0.0", "mem": "0.0"}, "82": {"cpu": "0.0", "mem": "0.0"}, "97": {"cpu": "0.0", "mem": "0.0"}, "98": {"cpu": "1.0", "mem": "0.7"}, "113": {"cpu": "0.0", "mem": "0.0"}, "134": {"cpu": "0.0", "mem": "0.0"}, "135": {"cpu": "0.0", "mem": "0.0"}, "136": {"cpu": "0.0", "mem": "0.0"}, "140": {"cpu": "0.0", "mem": "0.0"}, "157": {"cpu": "0.0", "mem": "0.0"}, "182": {"cpu": "0.0", "mem": "0.0"}, "211": {"cpu": "0.0", "mem": "0.0"}, "241": {"cpu": "0.0", "mem": "0.0"}, "272": {"cpu": "0.0", "mem": "0.0"}, "302": {"cpu": "0.0", "mem": "0.0"}, "323": {"cpu": "0.0", "mem": "0.0"}, "337": {"cpu": "0.0", "mem": "0.0"}, "571": {"cpu": "0.0", "mem": "0.1"}, "577": {"cpu": "0.0", "mem": "0.0"}, "578": {"cpu": "0.0", "mem": "0.3"}, "586": {"cpu": "0.0", "mem": "0.0"}, "587": {"cpu": "1.0", "mem": "0.3"}, "588": {"cpu": "0.7", "mem": "0.3"}, "589": {"cpu": "0.0", "mem": "0.0"}, "590": {"cpu": "0.7", "mem": "0.3"}, "591": {"cpu": "6.0", "mem": "0.3"}, "594": {"cpu": "7.6", "mem": "0.3"}, "602": {"cpu": "0.0", "mem": "0.0"}, "611": {"cpu": "0.0", "mem": "0.2"}, "15653": {"cpu": "0.7", "mem": "0.0"}, "16079": {"cpu": "1.0", "mem": "0.0"}, "16080": {"cpu": "1.0", "mem": "0.0"}, "16243": {"cpu": "0.7", "mem": "0.1"}, "17685": {"cpu": "0.7", "mem": "0.0"}, "19034": {"cpu": "5.3", "mem": "0.2"}, "19295": {"cpu": "0.3", "mem": "0.0"}, "19840": {"cpu": "0.0", "mem": "0.0"}, "19856": {"cpu": "0.0", "mem": "0.0"}}, "service": {"uptime": 21060, "version": "0.12.0-da3e197", "latest_version": "0.12.0", "storage": {"/media/frigate/recordings": {"total": 2000397.9, "used": 1099675.5, "free": 899521.9, "mount_type": "btrfs"}, "/media/frigate/clips": {"total": 2000397.9, "used": 1099675.5, "free": 899521.9, "mount_type": "btrfs"}, "/tmp/cache": {"total": 100.0, "used": 31.4, "free": 68.6, "mount_type": "tmpfs"}, "/dev/shm": {"total": 268.4, "used": 24.2, "free": 244.2, "mount_type": "tmpfs"}}, "temperatures": {}, "last_updated": 1683226289}}
    Wenn ich den Code richtig interpretiere, gibt es das nicht bei der USB Coralle.
    Und ist es normal das der Datenpunkt frigate.0.available nichts anzeigt? Ich hätte hier ein true/false erwartet.
    Erneut vielen Dank!
    WalW Offline
    WalW Offline
    Wal
    @sidm sagte in Test Frigate Adapter 0.1.8:
    So das Problem ist, das der Datenpunkt nur gesetzt wird beim Start und Beenden von Frigate. Wird der Adapter neu gestartet, bekommt er dementsprechend noch keine Nachricht.
    Da Frigate auch Online ist wenn Statsmeldungen eintrudeln, setze ich hiermit "available" auch auf "online".
    Development Pfad.
    Walter
    DoorIO-Adapter
    • WalW Offline
      WalW Offline
      Wal
      v0.1.9
      neue Objekte uptime, Version ...
      Walter
      DoorIO-Adapter
      • WalW Offline
        WalW Offline
        Wal
        v0.2.1
        Optimierungen im Code
        Walter
        DoorIO-Adapter
        • WalW Wal
          v0.2.1
          SidM
          @wal
          Super Walter! jetzt werden die stats angezeigt, available und auch die neuen Werte werden einwandfrei befüllt.
          Klasse Arbeit und besten Dank! Einen schönen Sonntag noch.:man-raising-hand:
          • WalW Offline
            WalW Offline
            Wal
            v0.2.2
            Übersetzungen in den Settings in mehreren Sprachen
            Walter
            DoorIO-Adapter
            • WalW Offline
              WalW Offline
              Wal
              v0.2.5
              https Url für frigateaufruf im Adapter gefixt
              Walter
              DoorIO-Adapter
              • U Offline
                U Offline
                umichel
                schrieb am zuletzt editiert von umichel
                Hmm ... der Adapter dürfte viele interessieren.
                Nur irgendwie bin ich zu dumm die Installation zu verstehen.
                Frigate als Docker installieren?
                Und der Adpater komuniziert dann über MQTT mit Frigate?
                Was muss ich denn jetzt genau dafür wo einstellen bzw. installieren?
                WalW 1 Antwort Letzte Antwort
                • U umichel
                  WalW Offline
                  WalW Offline
                  Wal
                  schrieb am zuletzt editiert von Wal
                  @umichel ,
                  frigate ist ein Docker-Container, wie das installiert wird steht in der Frigate Doku.
                  Nach der Installation wird MQTT in der Frigate Config aktiviert und mit dem ioBroker MQTT-Adapter der als Server läuft verbunden.
                  @umichel sagte in Test Frigate Adapter 0.2.5:
                  Ja.
                  Für Proxmox habe ich eine Anleitung erstellt.
                  Walter
                  DoorIO-Adapter
                  U crunchipC 2 Antworten Letzte Antwort
                  • WalW Wal
                    @umichel ,
                    Ja.
                    U Offline
                    U Offline
                    umichel
                    OK, danke.
                    Ich teste das mal mit einem Container unter einer OMV VM.
                    Der Nachteil dürfte die fehlende Hardwarebeschleunigung sein, wobei ich auch nicht weiss ob man die wirklich benötigt für Frigate.
                    • U umichel
                      OK, danke.
                      WalW Offline
                      WalW Offline
                      Wal
                      @umichel ,
                      ja die wird benötigt, da sonst die CPU-Last enorm hoch ist.
                      Bei 1 bis 2 Kameras geht es aber noch.
                      Walter
                      DoorIO-Adapter
                      H 1 Antwort Letzte Antwort
                      • WalW Wal
                        @umichel ,
                        Ja.
                        crunchipC Abwesend
                        crunchipC Abwesend
                        @wal sagte in Test Frigate Adapter 0.2.5:
                        werd ich mir die Tage auch mal ansehen, mit motioneye hab ich zu viele Fehlauslösungen, grad wenn sich die Lichtverhältnisse(Sonne) sich ändern
                          WalW Offline
                          WalW Offline
                          Wal
                          @crunchip ,
                          mit Frigate hatte ich bis jetzt lass mich kurz überlegen 0 Fehlauslösungen. ;-)
                          Walter
                          DoorIO-Adapter
                          • WalW Wal
                            @crunchip ,
                            crunchipC Abwesend
                            crunchipC Abwesend
                            @wal klingt gut, allerdings hab ich bisserl Bammel ob ich das mit allen Kameras zum laufen bekomm, bezogen auf Installation und Einstellungen
                              WalW Offline
                              WalW Offline
                              Wal
                              @crunchip ,
                              ja die Konfiguration und Installation ist nicht ohne.
                              Ohne Coral TPU kannst du den OpenVINO Detector nutzen, der ist mittlerweile auch sehr gut.
                              Walter
                              DoorIO-Adapter
                              • WalW Wal
                                @crunchip ,
                                crunchipC Abwesend
                                crunchipC Abwesend
                                ok, guck ich mal, da ich keine Coral TPU habe
                                • U Offline
                                  U Offline
                                  umichel
                                  Aktuell nutze ich auch MotionEye.
                                  Aber eigentlich nur für die Transcodierung fürs Tablet, nicht für eine Bewegungserkennung.
                                  Bei meiner Reolink funktioniert die Personenerkennung nicht wirklich gut bzw. bei Nachtsicht noch viel weniger.
                                  Wäre halt schön, wenn Frigate sowohl eine gute Personenerkennung und eine Transcodierung bietet?
                                  • U umichel
                                    WalW Offline
                                    WalW Offline
                                    Wal
                                    @umichel ,
                                    frigate nutzt go2rtc zum transcodieren , Personenerkennung bei mir 100%.
                                    Man braucht aber nicht glauben, das man langsamere Hardware als Motioneye braucht.
                                    Walter
                                    DoorIO-Adapter
                                    EisteeE 1 Antwort Letzte Antwort
                                    • WalW Wal
                                      @umichel ,
                                      EisteeE Online
                                      EisteeE Online
                                      Eistee
                                      Hallo
                                      Kann mir jemand ein Beispiel zeigen wie ich z.B. eine von frigate erkannte Person als Foto oder Video per Telegram verschicken kann.
                                      Vielen Dank
                                      Gruß Alina
                                      • EisteeE Eistee
                                        Hallo
                                        Vielen Dank
                                        Gruß Alina
                                        WalW Offline
                                        WalW Offline
                                        Wal
                                        @eistee ,
                                        zum Beispiel so:
                                        var request = require('request');
                                        var fs      = require('fs');
                                        var bell = true;
                                        var snap = '';
                                        var url = '';
                                        function sendImage() {
                                            request.get({url: url, encoding: 'binary'}, function (err, response, body) {
                                                fs.writeFile(snap, body, 'binary', function(err) {
                                                if (err) {
                                                    console.error(err);
                                                } else {
                                                    console.log('Snapshot sent');
                                                    sendTo('telegram.0', {text: snap, caption: 'Bewegung erkannt'});
                                        on({id: 'frigate.0.doorbell.objects.person.web.snap.snap_0', change: 'any'}, function (obj) {
                                            if (bell) {
                                                url = obj.state.val;
                                                snap = '/tmp/snapshot.jpg';
                                                sendImage();
                                            bell = false;
                                            setTimeout(function() {
                                                bell = true;
                                              }, 120000);
                                        Walter
                                        DoorIO-Adapter
                                          MINKI
                                          schrieb am zuletzt editiert von MINKI
                                          Moin und zunächst ein Dankeschön für den Einsatz hier.
                                          Ich habe ein reproduzierbares Problem mit dem Adapter. Sobald ich mqtt auf enable setze und frigate neustarte, wird die Erkennung von definierten Objektarten ausgeschaltet. Obwohl ich diese in der frigate config gesetzt habe.
                                          Das ist meine Konfiguration:
                                          cameras:
                                            ######################################EINGANGSBEREICH######################################
                                            Eingangsbereich:
                                              ffmpeg:
                                                #hwaccel_args: preset-vaapi
                                                inputs:
                                                  - path: rtsp://127.0.0.1:8554/Eingangsbereich_low
                                                    input_args: preset-rtsp-restream
                                                    roles:
                                                      - detect
                                                    roles:
                                                      - record
                                                output_args:
                                                  record: -f segment -segment_time 10 -segment_format mp4 -reset_timestamps 1 -strftime 1 -c:v copy -c:a aac
                                              detect:
                                                enabled: True
                                                width: 640
                                                height: 360
                                                fps: 15
                                              objects:
                                                track:
                                                  - bicycle
                                                  - car
                                                  - person
                                                filters:
                                                  car:
                                                    threshold: 0.75
                                              record:
                                                enabled: true
                                                expire_interval: 60
                                                retain:
                                                  days: 2
                                              snapshots:
                                                enabled: true
                                                timestamp: true
                                                retain:
                                                  default: 365
                                              motion:
                                                mask:
                                                  - 640,0,640,100,572,93,574,0
                                              zones:
                                                Einfahrt:
                                                  coordinates: 564,131,640,142,640,105,571,97
                                                Stellflaeche:
                                                  coordinates: 245,196,230,151,373,119,437,136,552,126,640,144,612,330
                                                Tuerbereich:
                                                  coordinates: 600,330,595,360,76,360,50,253,242,191
                                              mqtt:
                                                enabled: true
                                                timestamp: true
                                                bounding_box: true
                                          Sobald ich mqtt einschalte, werden keine Personen mehr im Eingangsbereich erkannt. Der entsprechende Datenpunktunter frigate.0.objects wird auch nicht erstellt.
                                          Ich habe das selbe Verhalten bei allen Kameras die ich im Einsatz habe (Tapo C320WS).
                                          Was mache ich falsch?
                                          Grüße Robert
