  4. Test Adapter pid (pid-Regler) V1.0.x
314 Beiträge 16 Kommentatoren 96.7k Aufrufe 14 Beobachtet
  • Q quorle
    @paul53 @mcm57
    Hab den DP "off" mal mit 50 befeuert. Aber der PID steht weiterhin bei y = 0.
    Sobald man in den DP "off" etwas einträgt, regelt der PID bis auf null herunter, anstatt rauf auf 100.
    Auszug aus dem LOG:
    pid.1
    2023-07-14 18:14:50.610	info	[C-PV-Heizstab] update() - {"ts":1689351290610,"act":2448,"set":0,"diff":-2448,"off":50,"err":-2448,"y":0,"lim":true,"dt":2001,"differr":null,"sumerr":-7552,"supr":false}
    pid.1
    2023-07-14 18:14:48.609	info	[C-PV-Heizstab] update() - {"ts":1689351288609,"act":2448,"set":0,"diff":-2448,"off":50,"err":-2448,"y":0,"lim":true,"dt":2001,"differr":null,"sumerr":-7552,"supr":false}
    pid.1
    2023-07-14 18:14:46.608	info	[C-PV-Heizstab] update() - {"ts":1689351286608,"act":2448,"set":0,"diff":-2448,"off":50,"err":-2448,"y":0,"lim":true,"dt":2000,"differr":null,"sumerr":-7552,"supr":false}
    pid.1
    2023-07-14 18:14:44.608	info	[C-PV-Heizstab] update() - {"ts":1689351284608,"act":2531,"set":0,"diff":-2531,"off":50,"err":-2531,"y":0,"lim":true,"dt":2001,"differr":null,"sumerr":-7469,"supr":false}
    pid.1
    2023-07-14 18:14:42.607	info	[C-PV-Heizstab] update() - {"ts":1689351282607,"act":2531,"set":0,"diff":-2531,"off":50,"err":-2531,"y":0,"lim":true,"dt":2001,"differr":null,"sumerr":-7469,"supr":false}
    pid.1
    2023-07-14 18:14:40.606	info	[C-PV-Heizstab] update() - {"ts":1689351280606,"act":2531,"set":0,"diff":-2531,"off":50,"err":-2531,"y":0,"lim":true,"dt":2001,"differr":null,"sumerr":-7469,"supr":false}
    pid.1
    2023-07-14 18:14:38.605	info	[C-PV-Heizstab] update() - {"ts":1689351278605,"act":2531,"set":0,"diff":-2531,"off":50,"err":-2531,"y":0.5439999999999969,"lim":false,"dt":2000,"differr":null,"sumerr":-7360.200000000001,"supr":false}
    pid.1
    2023-07-14 18:14:36.605	info	[C-PV-Heizstab] update() - {"ts":1689351276605,"act":2531,"set":0,"diff":-2531,"off":50,"err":-2531,"y":1.8094999999999928,"lim":false,"dt":2000,"differr":null,"sumerr":-7107.1,"supr":false}
    pid.1
    2023-07-14 18:14:34.605	info	[C-PV-Heizstab] update() - {"ts":1689351274605,"act":3146,"set":0,"diff":-3146,"off":50,"err":-3146,"y":0,"lim":true,"dt":2001,"differr":null,"sumerr":-6854,"supr":false}
    pid.1
    2023-07-14 18:14:32.604	info	[C-PV-Heizstab] update() - {"ts":1689351272604,"act":3146,"set":0,"diff":-3146,"off":50,"err":-3146,"y":0,"lim":true,"dt":2001,"differr":null,"sumerr":-6854,"supr":false}
    pid.1
    2023-07-14 18:14:30.603	info	[C-PV-Heizstab] update() - {"ts":1689351270603,"act":3146,"set":0,"diff":-3146,"off":50,"err":-3146,"y":0,"lim":true,"dt":2001,"differr":null,"sumerr":-6854,"supr":false}
    @mcm57
    Wenn man in den Adaptereinstellungen bei "Offset" einen Wert einträgt, wird dieser nicht im Datenpunkt "offset Value" übernommen. Zudem wenn man bei einer Adapter-Instanz das Logging einstellt, wird dies auf allen Adapterinstanzen angewandt.
    mcm1957M
    mcm1957M
    mcm1957
    #251
    @quorle
    Bitte für das offs problem um ein issue
    Das logging ist global für eine instanz. Ich nehme an du meinst das logging witd für alle controller einer instanz übernommen. Das ist so gedacht.
    Dass zwischen adapterinstanzen eine wechselwirkung existiert wäre überraschend.
    Support Repositoryverwaltung.
    LESEN - gute Forenbeitrage
    • Q quorle
      Ja da gebe ich dir Recht, aber der Regler regelt im Netzbezug dann auf 100 und bei Netzeinspeisung sinkt der Wert nicht mehr. Habe ich gerade ausprobiert mit invertieren.
      paul53P
      paul53P
      #252
      @quorle sagte: Regler regelt im Netzbezug dann auf 100
      Die Richtung würde schon mal stimmen: Bei Netzbezug soll der WR mehr Leistung liefern. Setze mal den I-Anteil zurück (macht das der Button "reset controller"?).
      mcm1957M 2 Antworten Letzte Antwort
        mcm1957M
        mcm1957M
        mcm1957
        #253
        Zu den xalc teaces
        Drr regler ist voll am Anschlag.
        Beispiel
        Set 0
        Act 2800
        Y bei k = 1 wäre -2800. Da nutzt der offset nix mehr.
        Ich ver mute dass der proportionalanteil zu gross ist. Und invertieren müsste nan auch ( oder nan invertuert act gleich extern)
        mcm1957M paul53P 2 Antworten Letzte Antwort
        • mcm1957M mcm1957
          Zu den xalc teaces
          Beispiel
          Set 0
          Act 2800
          mcm1957M
          mcm1957M
          mcm1957
          #254
          Ich wütd auch den integrallanteil mal welassen bis der prop anteil mal halbwegs passt
            mcm1957M
            mcm1957M
            mcm1957
            #255
            Ja reset resettet den p anteil
            • Q quorle
              @paul53 @mcm57
              Auszug aus dem LOG:
              pid.1
              pid.1
              pid.1
              pid.1
              pid.1
              pid.1
              pid.1
              pid.1
              pid.1
              pid.1
              pid.1
              @mcm57
              paul53P
              paul53P
              #256
              @quorle
              Mit schwankenden Werten die generelle Funktion zu testen, ist schwierig. Übergebe mal an "actual value" einen konstanten Wert von 1000 (= 1000 W Überschuss). Das richtige Verhalten von "output value" nach einem Reset wäre dann der Start mit 57,5 % und alle 2 s Erhöhung um 0,5 %.
              • mcm1957M mcm1957
                Zu den xalc teaces
                Beispiel
                Set 0
                Act 2800
                paul53P
                paul53P
                #257
                @mcm57 sagte: Drr regler ist voll am Anschlag.
                Durch den I-Anteil. kp ist 0,005.
                • mcm1957M mcm1957
                  paul53P
                  paul53P
                  #258
                  @mcm57 sagte: resettet den p anteil
                  Du meinst den I-Anteil?
                  @mcm57 sagte in Test neuer Adapter pid (pid-Regler) V0.0.x:
                  Tn = 0 deaktiviert den I-Anteil?
                  Q 1 Antwort Letzte Antwort
                    Q
                    Q
                    quorle
                    #259
                    Also irgendwie komme ich damit nicht klar. Der Regler macht was er will, egal was ich einstelle. Hab es auch mit einem festen Wert von 1000 am "set" versucht. Aber wenn er regelt, regelt er nur auf 100%, dann wieder runter und wieder hoch.
                    Hat irgendeiner den Adapter schon anderweitig im Einsatz, außer Temperaturen zu regeln? Um den Heizstab zur PV-Einspeiseleistung regeln zu können, sollte der PID schnell reagieren, ohne sehr große Sprünge zu machen
                    • Q quorle
                      paul53P
                      paul53P
                      #260
                      @quorle sagte: Der Regler macht was er will
                      Habe gestern mal den Regler getestet und festgestellt, dass sich der Ausgang nicht wie erwartet verhält.
                      @quorle sagte in Test neuer Adapter pid (pid-Regler) V0.0.x:
                      Der Modbus Adapter holt alle 10 Sekunden die Werte aus dem Wechselrichter.
                      Die Reaktionsgeschwindigkeit ist durch den Abfragezyklus von Modbus begrenzt. Kann man den verkürzen?
                      Der folgende Regler verwendet als Zykluszeit den Modbus-Abfragezyklus. Tn = 20 s bezieht sich auf einen Abfragezyklus von 10 s. Verringert man den Abfragezyklus, kann man auch Tn entsprechend verringern.
                      Ich habe den Regler mit einem Datenpunkt "EVU-Einspeisung", der alle 10 s auf 1000 gesetzt wird, getestet.
                      11:14:27.406	info	javascript.1 (2139) script.js.blockly.Test3_Blockly: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                      11:14:30.007	info	javascript.1 (2139) script.js.blockly.Test3_Blockly: 57.49825
                      11:14:40.004	info	javascript.1 (2139) script.js.blockly.Test3_Blockly: 59.998
                      11:14:50.011	info	javascript.1 (2139) script.js.blockly.Test3_Blockly: 62.4995
                      11:15:00.011	info	javascript.1 (2139) script.js.blockly.Test3_Blockly: 64.9985
                      11:15:10.005	info	javascript.1 (2139) script.js.blockly.Test3_Blockly: 67.498
                        Q
                        Q
                        quorle
                        schrieb am zuletzt editiert von quorle
                        #261
                        Habe dir mal zwei Bilder aus Grafana angehängt.
                        Entweder regeln beide ( Script und Adapter) nur auf 100% und bleiben dann dort stehen, oder sie machen einfach nichts.
                        Liegt wahrscheinlich nur an den Einstellungen?
                        Ich wollte eigentlich den Adapter für mehrere Zwecke einsetzen.
                        Habe auch die Einstellungen von Nutzern weiter oben im Beitrag genutzt, jedoch regelt hier auch nichts.
                        Mit dem Scripteinstellungen habe ich auch etwas gespielt, bringt mich auch nicht weiter.
                        Ich meine, wenn ich jetzt 1600 W am Eingang anliegen habe, sollte der Regler ja auf 80% Reglen (bei 2000W max = Heizstab) und nicht auf 100% Reglen und stehen bleiben. Und wenn es weniger Leistung am Eingang wird, sollte der Regler entsprechend herunter Regeln, dann bei Mehrleistung am Eingang wieder Hochregeln. Oder verstehe ich das Falsch?
                        @mcm57 Gibt es schon Anwendungsfälle, die Dokumentiert sind?
                        Scriptauswertung:
                        Adapterauswertung:
                        • Q quorle
                          Scriptauswertung:
                          Adapterauswertung:
                          paul53P
                          paul53P
                          #262
                          @quorle sagte: auf 100% und bleiben dann dort stehen
                          Wenn der Ausgang nicht auf den Heizstab wirkt, läuft der Ausgang nach Skriptstart auf 100 % (I-Anteil) und verharrt dort. Er verringert sich erst wieder, wenn der Eingang negativ wird (Bezug).
                          EDIT: Einen PI-Regler kann man nicht sinnvoll ohne geschlossenen Regelkreis (Verbraucher Heizstab) testen.
                          Hier habe ich die Aktualisierungsrate auf 1 s verringert und Tn auf 2 s eingestellt. Der Regler verhält sich genau so wie erwartet:
                          12:50:14.726	info	javascript.1 (2174) script.js.blockly.Test3_Blockly: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                          12:50:15.013	info	javascript.1 (2174) script.js.blockly.Test3_Blockly: 57.5
                          12:50:16.002	info	javascript.1 (2174) script.js.blockly.Test3_Blockly: 60
                          12:50:17.006	info	javascript.1 (2174) script.js.blockly.Test3_Blockly: 62.5
                          12:50:18.003	info	javascript.1 (2174) script.js.blockly.Test3_Blockly: 65
                          12:50:19.002	info	javascript.1 (2174) script.js.blockly.Test3_Blockly: 67.5
                          12:50:20.003	info	javascript.1 (2174) script.js.blockly.Test3_Blockly: 70
                          12:50:21.006	info	javascript.1 (2174) script.js.blockly.Test3_Blockly: 72.5
                          12:50:22.004	info	javascript.1 (2174) script.js.blockly.Test3_Blockly: 75
                          12:50:23.002	info	javascript.1 (2174) script.js.blockly.Test3_Blockly: 77.5
                          12:50:24.014	info	javascript.1 (2174) script.js.blockly.Test3_Blockly: 80
                          12:50:25.003	info	javascript.1 (2174) script.js.blockly.Test3_Blockly: 82.5
                          12:50:26.003	info	javascript.1 (2174) script.js.blockly.Test3_Blockly: 85
                          12:50:27.012	info	javascript.1 (2174) script.js.blockly.Test3_Blockly: 87.5
                          12:50:28.003	info	javascript.1 (2174) script.js.blockly.Test3_Blockly: 90
                          12:50:29.006	info	javascript.1 (2174) script.js.blockly.Test3_Blockly: 92.5
                          12:50:30.003	info	javascript.1 (2174) script.js.blockly.Test3_Blockly: 95
                          12:50:31.004	info	javascript.1 (2174) script.js.blockly.Test3_Blockly: 97.5
                          12:50:32.003	info	javascript.1 (2174) script.js.blockly.Test3_Blockly: 100
                          12:50:33.004	info	javascript.1 (2174) script.js.blockly.Test3_Blockly: 100
                          12:50:34.002	info	javascript.1 (2174) script.js.blockly.Test3_Blockly: 100
                          • Q quorle
                            Scriptauswertung:
                            Adapterauswertung:
                            paul53P
                            paul53P
                            #263
                            @quorle sagte: Adapterauswertung:
                            Habe den Adapter getestet mit Invertierung und nachträglicher Eingabe des Offset (wurde nicht aus der Konfiguration übernommen). Nun verhält er sich wie erwartet:
                            Hier die History von "output value" nachdem um 13:05:13 Uhr "reset controller" auf true gesetzt wurde.
                            fu_zhouF 1 Antwort Letzte Antwort
                              fu_zhouF
                              fu_zhouF
                              fu_zhou
                              #264
                              @mcm57 Hallo mal wieder, habe gestern Nacht oder eher heute früh mal ein Issue in Github eröffnet, wollte das Thema aber auch hier noch platzieren:
                              Kurz zusammen gefasst: es wäre Klasse, wenn "inv" beschreibbar wäre (true/false), wenn man "Zustände für die Konfiguration verwenden" aktiviert.
                              Ich habe den nächsten Einsatz für den Regler: Wärme-/ Kälterückgewinnung über die Drehzahl der Wärmeräder in der Lüftung. Dazu muss ich den inv mit true oder false aus einem Skript beschreiben können, das geht aktuell nicht. Alternativ könnte ich kp und tn auf einen negativen Wert setzen, der Adapter lässt aber nur positive Werte zu. Bei tn, tv, xp lassen sich negative Werte setzen.
                              Hintergrund: wenn die Außenluft kälter ist, als die Raumluft, kann ich über die Erhöhung der Drehzahl die Zuluft mit der Abluft erwärmen. Im Sommer ist die Außenluft wärmer, als die Raumluft, d.h. ich kann über die Erhöhung der Drehzahl die Zuluft mit der Abluft kühlen. D.h. wenn Temperatur Außenluft < Raumluft, dann inv = 0 und wenn Temperatur Außenluft > Raumluft, dann inv = 1 . Kannst du inv beschreibbar machen? Dann kannst du auch bei tn, tv, xp nur pos. Werte zulassen.
                              Danke vorab!
                              Synology DS920+ VM, S7-315 PN mit ET200S
                              • fu_zhouF fu_zhou
                                Danke vorab!
                                mcm1957M
                                mcm1957M
                                mcm1957
                                #265
                                @fu_zhou
                                Schaus mir an
                                • mcm1957M mcm1957
                                  @fu_zhou
                                  Schaus mir an
                                  fu_zhouF
                                  fu_zhouF
                                  fu_zhou
                                  #266
                                  @mcm57 hattest du schon die Chance, mal reinzuschauen?
                                  • fu_zhouF fu_zhou
                                    mcm1957M
                                    mcm1957M
                                    mcm1957
                                    #267
                                    @fu_zhou
                                    Danke für den Schubs / Erinnerung.
                                    Leider bin ich noch nicht dazu gekommen das umzusetzen. Habs auf meienr Liste. Technisch sehe ich keinen Grund warum dies nicht gehen sollte. Ev komm ich diese Woche dazu - aber versprechen möcht ich nix.
                                    Ja, könnte rascherer Support sein. Kann nur sorry sagen.
                                    • mcm1957M mcm1957
                                      @fu_zhou
                                      fu_zhouF
                                      fu_zhouF
                                      fu_zhou
                                      #268
                                      @mcm57 Kein Grund für eine Entschuldigung, im Moment behelfe ich mir mit 2 Reglern, die ich Außentemperatur-abhängig abwechselnd freigebe (über hold). Ich bin nach wie vor begeistert, wie gut der Regler mit den Funktionen funktioniert!
                                      • fu_zhouF fu_zhou
                                        mcm1957M
                                        mcm1957M
                                        mcm1957
                                        #269
                                        @fu_zhou
                                        Ab Morgen steht im LATEST die neueste Version 1.0.0 des Adapters zur Verfügung.
                                        Neu ist die Möglichkeit den Parameter INVERT via State zu ändern.
                                        Weiters wurden die bekannten Fehler behoben.
                                        Releasenotes im ersten Beitrag und im Repository.
                                        ACHTUNG:
                                        Der Adapter erfordert nun minimal
                                        • Node.js 18
                                        • js-controller 5
                                        • admin 6
                                        Die Anforderungen wurden hochgezogen, da node 16 mittlerweile nicht mehr mit Updates versorgt wird und von mir auch nicht mehr getestet wird. Auch js-controlelr 4 und admin 5 werden von mir nicht mehr gtestet - zusätzlich arbeite ich (sobald ich dazu komme) an einer (kompatiblen) umgestaltung der Config UI Seite da derzeit wie Paramater zu oft unlesbar abgeschnitten werden. Das neue Format benötigt jedenfalls dann Admin 6. Ich gehe davon aus, dass die Anforderungen insbesondere frü Tester kein Hindernis darstellen.
                                        Fehler bitte wie immer hier bzw. als issues melden.
                                        Hinweis: Aus persönichen Gründe bin ich voraussichtlich ab nächster Woche 2 bis 3 Wochen nur eingschränkt / nicht verfügbar. Aber wie sagte schon Paulchen Panter: "ich komm wieder - keine Frage" :-)
                                        • ZarelloZ
                                          ZarelloZ
                                          Zarello
                                          #270
                                          ich verwende seit einiger Zeit den pid.adapter zur Steuerung eines Heizkörper-Thermostats.
                                          Was mir dabei aufgefallen ist:
                                          Der D-Anteil des Reglers ist für mich leider nicht sinnvoll zu verwenden.
                                          Der D-Anteil wird nur über das letzte Intervall gebildet.
                                          Ich möchte das Intervall nicht zu groß wählen, damit der Regler einigermaßen schnell reagiert, wenn es eine Änderung der Soll-Größe gibt. Ich habe 10s gewählt.
                                          Die Ist-Temperatur, erhalte ich vom verwendeten Thermometer nur mit einer Nachkommastelle.
                                          Die Temperatur-Änderungen sind relativ langsam.
                                          Das hat zur Folge, dass eine Änderung in der Ist-Temperatur über den D-Anteil des Reglers nur einen Peak von 10s Länge erzeugt, von dem ich dann wählen kann, wie stark er sein soll.
                                          Schön wäre, wenn man für den D-Anteil eine Anzahl von Intervallen angeben kann, über die er berechnet wird. Dann könnte ich die Zeitkonstante für diesen Anteil auf einige Minuten erhöhen.
                                          G paul53P 2 Antworten Letzte Antwort
                                          83.8k
