  4. Adapter Hyundai (Bluelink) oder KIA (UVO)
    6.0k
2.5k Beiträge 161 Kommentatoren 1.2m Aufrufe 147 Beobachtet
  • arteckA arteck
    @aiouh sagte in Adapter Hyundai (Bluelink) oder KIA (UVO):
    beim Start Fehlermeldungen
    wo ..ich seh da keine.. nur info
    Aiouh
    #1259
    @arteck sorry, ja sind nur Infos. Ich stell einfach mal den loglevel um, ist als workaround für mich absolut OK.
    • arteckA arteck
      installiert mal von GIT
      GerdSo
      #1260
      @arteck Bei mir kann er sich zwar einloggen, danach stürzt er aber ab. Aktuelle Version von git und Objekte gelöscht
      bluelink.0 2023-07-04 14:51:33.380	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
      bluelink.0 2023-07-04 14:51:33.380	info	terminating
      bluelink.0 2023-07-04 14:51:33.379	info	Adapter bluelink cleaned up everything...
      bluelink.0 2023-07-04 14:51:33.377	error	Cannot read properties of null (reading 'val')
      bluelink.0 2023-07-04 14:51:33.377	error	TypeError: Cannot read properties of null (reading 'val') at Bluelink.readStatus (/opt/iobroker/node_modules/iobroker.bluelink/main.js:290:61) at async Te.<anonymous> (/opt/iobroker/node_modules/iobroker.bluelink/main.js:211:17)
      bluelink.0 2023-07-04 14:51:33.376	error	unhandled promise rejection: Cannot read properties of null (reading 'val')
      bluelink.0 2023-07-04 14:51:33.376	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      bluelink.0 2023-07-04 14:51:33.372	debug	Read new status from api for xxxxx
      bluelink.0 2023-07-04 14:51:33.369	debug	[{"vehicleConfig":{"nickname":"Niro","name":"Niro","regDate":"2023-01-18 13:33:04.996","brandIndicator":"H","id":"3e953589-376b-43a5-8bb4-bd47cae87ef0","vin": --snip-- "_fullStatus":null,"_status":null,"_location":null,"_odometer":null,"region":"EU","serverRates":{"max":-1,"current":-1}}]
      bluelink.0 2023-07-04 14:51:33.369	info	1 Vehicles found
      bluelink.0 2023-07-04 14:51:31.518	info	Login to api
      bluelink.0 2023-07-04 14:51:31.496	info	starting. Version 2.3.2 (non-npm: Newan/ioBroker.bluelink#54a2a58f9f1bd540237a380c9ea08ce2d8657ea3) in /opt/iobroker/node_modules/iobroker.bluelink, node: v18.16.0, js-controller: 4.0.24
      nik82N 1 Antwort Letzte Antwort
      • G GerdSo
        nik82N Offline
        nik82N Offline
        nik82
        #1261
        @gerdso
        Als ich deinen Post jetzt gelesen habe, habe ich auch mal den Adapter gestoppt und alle Objekte gelöscht, da ja die Klima jetzt in einem anderen Ordner ist.
        Habe dann wieder gestartet und jetzt habe ich das gleiche Problem wie du und den gleichen Fehler im Log.
        • Meister MopperM Offline
          Meister Mopper
          schrieb am zuletzt editiert von Meister Mopper
          #1262
          @arteck
          Ich bekomme den von github nicht installiert. Es kommt der bekannte 'error 25' bei der Installation.
          edit:
          Ich Depp hatte den falschen von github geladen :man-facepalming:
          Läuft jetzt, vielen Dank!
          Proxmox und HA ...
          Ich schreibe den Code nicht mehr selbst – ich schimpfe mit der KI, bis er funktioniert.
            stefan.cloer
            #1263
            Ich habe den gleichen Fehler wie @GerdSo. Auch ich habe vor der Installation alle Objekte gelöscht.
            • arteckA Offline
              arteckA Offline
              arteck
              #1264
              jetzt nochmal von GIT
              G nik82N 2 Antworten Letzte Antwort
              • arteckA arteck
                GerdSo
                #1265
                @arteck funktioniert, Danke <3
                • arteckA arteck
                  nik82N Offline
                  nik82N Offline
                  nik82
                  #1266
                  @arteck
                  Bist echt der Wahnsinn!!!
                  Funktioniert, vielen Dank👍
                  P.S. Klimatest kann ich noch nicht machen, Fahrzeug leider noch nicht da...
                    Michael Loddoch
                    #1267
                    Hallo!
                    Leider läuft der tolle Adapter seit 10 Tagen nicht mehr bei mir.
                    Ich bekomme diese Meldungen:
                    Hat jemand vielleicht eine Idee, wie ich ihn wieder zum Laufen bekomme?
                    Ganz viele Grüße!
                    Michael
                    [KIA Ceed SW Plug-in Hybrid]
                    • M Michael Loddoch
                      Hallo!
                      Ganz viele Grüße!
                      Michael
                      arteckA Offline
                      arteckA Offline
                      arteck
                      #1268
                      @michael-loddoch du kannst da nix machen.. die Serer spinnen wieder..es nervt langsam bei KIA
                      • G Offline
                        GerdSo
                        schrieb am zuletzt editiert von GerdSo
                        #1269
                        @michael-loddoch hast Du die aktuelle Version von github installiert? Der login Mechanismus wurde geändert und dazu brauchst Du die neue Version
                          Michael Loddoch
                          #1270
                          Ich habe bisher alle Instanzen über die Adapterauswahl im IObroker installiert. Demnach habe ich Version 2.2.5.
                          Auf github habe ich 2.3.2 gefunden. Wäre das die richtige?
                          Wie man die in IObroker bekommt, muss ich (als Anfänger) aber erst einmal herausfinden ...
                          • M Michael Loddoch
                            DaLugi
                            #1271
                            Ich habe die 2.3.2 und es geht bei mir anscheinend auch nicht:
                            Login-Daten sollten aber passen. Geht das beim Rest noch oder habe ich irgendetwas falsch gemacht?
                            A M 2 Antworten Letzte Antwort
                            • D DaLugi
                              Aiouh
                              #1272
                              @dalugi ich habe auch V2.3.2 und habe es gerade mal getestet
                              Login funktioniert, es gibt lediglich ein paar falsche datentypen bei der drive history, was mich nicht stört, die Objekte nutze ich eh nicht.
                              bluelink.0 2023-07-10 12:16:05.622	info	State value to set for "bluelink.0.xxxxxxxxxxxxxxxxxxx.driveHistory.cumulated03.distance" has to be type "undefined" but received type "number"
                              bluelink.0 2023-07-10 12:16:05.577	info	State value to set for "bluelink.0.xxxxxxxxxxxxxxxxxxx.driveHistory.cumulated03.regen" has to be type "undefined" but received type "number"
                              bluelink.0 2023-07-10 12:16:05.534	info	State value to set for "bluelink.0.xxxxxxxxxxxxxxxxxxx.driveHistory.cumulated03.consumption.battery" has to be type "undefined" but received type "number"
                              bluelink.0 2023-07-10 12:16:05.488	info	State value to set for "bluelink.0.xxxxxxxxxxxxxxxxxxx.driveHistory.cumulated03.consumption.devices" has to be type "undefined" but received type "number"
                              bluelink.0 2023-07-10 12:16:05.444	info	State value to set for "bluelink.0.xxxxxxxxxxxxxxxxxxx.driveHistory.cumulated03.consumption.climate" has to be type "undefined" but received type "number"
                              bluelink.0 2023-07-10 12:16:05.400	info	State value to set for "bluelink.0.xxxxxxxxxxxxxxxxxxx.driveHistory.cumulated03.consumption.engine" has to be type "undefined" but received type "number"
                              bluelink.0 2023-07-10 12:16:05.371	info	State value to set for "bluelink.0.xxxxxxxxxxxxxxxxxxx.driveHistory.cumulated03.consumption.total" has to be type "undefined" but received type "number"
                              bluelink.0 2023-07-10 12:16:03.766	info	Update for xxxxxxxxxxxxxxxxxxx successfull
                              bluelink.0 2023-07-10 12:15:30.437	info	Read new update for xxxxxxxxxxxxxxxxxxx directly from the car
                              bluelink.0 2023-07-10 12:15:30.424	info	1 Vehicles found
                              bluelink.0 2023-07-10 12:15:26.332	info	Login to api
                              bluelink.0 2023-07-10 12:15:26.068	info	starting. Version 2.3.2 (non-npm: Newan/ioBroker.bluelink#d92a933047aa0b2276f21f9e8efd25f9a9142a2a) in /opt/iobroker/node_modules/iobroker.bluelink, node: v18.16.0, js-controller: 4.0.24
                                Michael Loddoch
                                #1273
                                Ich habe jetzt auch die 2.3.2 laufen und bekomme leider genau die gleichen 3 Fehlermeldungen wie DaLugi ...
                                • M Michael Loddoch
                                  DaLugi
                                  #1274
                                  Muss ich noch irgendetwas anderes einstellen? Nutze den Adapter nun zum ersten Mal:
                                    Meister Mopper
                                    #1275
                                    @dalugi
                                    Ich sehe die 100 Abfragen am Tag als problematisch an. Wenn das 100x Abfrage des Kfz sind, bedeutet das, dass die 12 V-Batterie schnell leer ist.
                                    Ich habe da 3 eingestellt und hole mir die Daten je nachdem mit cron oder einer Aktion (z. B. Öffnen der entsprechenden vis site).
                                    Proxmox und HA ...
                                    T ? 2 Antworten Letzte Antwort
                                      @dalugi
                                      theGrinch
                                      #1276
                                      @meister-mopper ich habe 400 - rufe aber nur vom Server ab.
                                      Kommt halt sehr auf den use-case an.
                                        @dalugi
                                        #1277
                                        @meister-mopper
                                        warst anscheinend die letzten 2 Monate nicht hier dabei.. :-)
                                        @arteck hatte das doch umgestellt, es wird per Default vom Server geholt und es gibt einen extra Datenpunkt zum abholen vom Auto...
                                        Mach mal n Update vom Adapter, dann siehst du das.. :-)
                                        RTFM hab ich noch vergessen.. da hat sich einer die Mueh gemacht und was geschrieben.. was mal wieder keine Sau liest..
                                          @meister-mopper
                                          Meister Mopper
                                          #1278
                                          @ilovegym sagte in Adapter Hyundai (Bluelink) oder KIA (UVO):
                                          Das habe ich tatsächlich nicht mitbekommen, dann ist es ja gut. Ich hole aktuell je nach Bedarf mal vom Auto mal vom Server.
                                          Proxmox und HA ...
                                          docadamsD 1 Antwort Letzte Antwort
