  4. Adapter Hyundai (Bluelink) oder KIA (UVO)
    6.0k
2.5k Beiträge 161 Kommentatoren 1.2m Aufrufe 147 Beobachtet
  • A Aiouh
    @arteck Login Funktioniert wieder ! Danke.👍
    Allerdings bekomme ich jetzt beim Start Fehlermeldungen:
    bluelink.0 2023-07-04 12:09:20.963	info	undefined is not a valid state value for id "bluelink.0.KNAxxxxxxxxxxxxxxx.driveHistory.cumulated03.distance"
    bluelink.0 2023-07-04 12:09:20.954	info	undefined is not a valid state value for id "bluelink.0.KNAxxxxxxxxxxxxxxx.driveHistory.cumulated03.regen"
    bluelink.0 2023-07-04 12:09:20.946	info	undefined is not a valid state value for id "bluelink.0.KNAxxxxxxxxxxxxxxx.driveHistory.cumulated03.consumption.battery"
    bluelink.0 2023-07-04 12:09:20.938	info	undefined is not a valid state value for id "bluelink.0.KNAxxxxxxxxxxxxxxx.driveHistory.cumulated03.consumption.devices"
    bluelink.0 2023-07-04 12:09:20.921	info	undefined is not a valid state value for id "bluelink.0.KNAxxxxxxxxxxxxxxx.driveHistory.cumulated03.consumption.climate"
    bluelink.0 2023-07-04 12:09:20.892	info	undefined is not a valid state value for id "bluelink.0.KNAxxxxxxxxxxxxxxx.driveHistory.cumulated03.consumption.engine"
    bluelink.0 2023-07-04 12:09:20.880	info	undefined is not a valid state value for id "bluelink.0.KNAxxxxxxxxxxxxxxx.driveHistory.cumulated03.consumption.total"
    bluelink.0 2023-07-04 12:09:19.303	info	Update for KNAxxxxxxxxxxxxxxx successfull
    bluelink.0 2023-07-04 12:09:05.008	info	Read new update for KNAxxxxxxxxxxxxxxx directly from the car
    bluelink.0 2023-07-04 12:09:04.928	info	1 Vehicles found
    bluelink.0 2023-07-04 12:09:01.221	info	Login to api
    arteckA Offline
    arteckA Offline
    arteck
    #1255
    @aiouh sagte in Adapter Hyundai (Bluelink) oder KIA (UVO):
    wo ..ich seh da keine.. nur info
    • ? Offline
      #1256
      @arteck sagte in Adapter Hyundai (Bluelink) oder KIA (UVO):
      ja nur info, hier auch, aber bei JEDEM start.. das ist irritierend.. :-)
      Hab auch schon genau die Datenpunkte geloescht und Adapter neu gestartet...
        arteckA Offline
        arteckA Offline
        arteck
        #1257
        @ilovegym guckmal jetzt
        • arteckA arteck
          #1258
          @arteck
          Immer noch….
          • arteckA arteck
            Aiouh
            #1259
            @arteck sorry, ja sind nur Infos. Ich stell einfach mal den loglevel um, ist als workaround für mich absolut OK.
            • arteckA arteck
              installiert mal von GIT
              GerdSo
              #1260
              @arteck Bei mir kann er sich zwar einloggen, danach stürzt er aber ab. Aktuelle Version von git und Objekte gelöscht
              bluelink.0 2023-07-04 14:51:33.380	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
              bluelink.0 2023-07-04 14:51:33.380	info	terminating
              bluelink.0 2023-07-04 14:51:33.379	info	Adapter bluelink cleaned up everything...
              bluelink.0 2023-07-04 14:51:33.377	error	Cannot read properties of null (reading 'val')
              bluelink.0 2023-07-04 14:51:33.377	error	TypeError: Cannot read properties of null (reading 'val') at Bluelink.readStatus (/opt/iobroker/node_modules/iobroker.bluelink/main.js:290:61) at async Te.<anonymous> (/opt/iobroker/node_modules/iobroker.bluelink/main.js:211:17)
              bluelink.0 2023-07-04 14:51:33.376	error	unhandled promise rejection: Cannot read properties of null (reading 'val')
              bluelink.0 2023-07-04 14:51:33.376	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
              bluelink.0 2023-07-04 14:51:33.372	debug	Read new status from api for xxxxx
              bluelink.0 2023-07-04 14:51:33.369	debug	[{"vehicleConfig":{"nickname":"Niro","name":"Niro","regDate":"2023-01-18 13:33:04.996","brandIndicator":"H","id":"3e953589-376b-43a5-8bb4-bd47cae87ef0","vin": --snip-- "_fullStatus":null,"_status":null,"_location":null,"_odometer":null,"region":"EU","serverRates":{"max":-1,"current":-1}}]
              bluelink.0 2023-07-04 14:51:33.369	info	1 Vehicles found
              bluelink.0 2023-07-04 14:51:31.518	info	Login to api
              bluelink.0 2023-07-04 14:51:31.496	info	starting. Version 2.3.2 (non-npm: Newan/ioBroker.bluelink#54a2a58f9f1bd540237a380c9ea08ce2d8657ea3) in /opt/iobroker/node_modules/iobroker.bluelink, node: v18.16.0, js-controller: 4.0.24
              nik82N 1 Antwort Letzte Antwort
              • G GerdSo
                nik82N Offline
                nik82N Offline
                nik82
                #1261
                @gerdso
                Als ich deinen Post jetzt gelesen habe, habe ich auch mal den Adapter gestoppt und alle Objekte gelöscht, da ja die Klima jetzt in einem anderen Ordner ist.
                Habe dann wieder gestartet und jetzt habe ich das gleiche Problem wie du und den gleichen Fehler im Log.
                • Meister MopperM Online
                  Meister Mopper
                  schrieb am zuletzt editiert von Meister Mopper
                  #1262
                  @arteck
                  Ich bekomme den von github nicht installiert. Es kommt der bekannte 'error 25' bei der Installation.
                  edit:
                  Ich Depp hatte den falschen von github geladen :man-facepalming:
                  Läuft jetzt, vielen Dank!
                  Proxmox und HA ...
                  Ich schreibe den Code nicht mehr selbst – ich schimpfe mit der KI, bis er funktioniert.
                    stefan.cloer
                    #1263
                    Ich habe den gleichen Fehler wie @GerdSo. Auch ich habe vor der Installation alle Objekte gelöscht.
                    • arteckA Offline
                      arteckA Offline
                      arteck
                      #1264
                      jetzt nochmal von GIT
                      G nik82N 2 Antworten Letzte Antwort
                      • arteckA arteck
                        GerdSo
                        #1265
                        @arteck funktioniert, Danke <3
                        • arteckA arteck
                          nik82N Offline
                          nik82N Offline
                          nik82
                          #1266
                          @arteck
                          Bist echt der Wahnsinn!!!
                          Funktioniert, vielen Dank👍
                          P.S. Klimatest kann ich noch nicht machen, Fahrzeug leider noch nicht da...
                            Michael Loddoch
                            #1267
                            Hallo!
                            Leider läuft der tolle Adapter seit 10 Tagen nicht mehr bei mir.
                            Ich bekomme diese Meldungen:
                            Hat jemand vielleicht eine Idee, wie ich ihn wieder zum Laufen bekomme?
                            Ganz viele Grüße!
                            Michael
                            [KIA Ceed SW Plug-in Hybrid]
                            • M Michael Loddoch
                              Hallo!
                              Ganz viele Grüße!
                              Michael
                              arteckA Offline
                              arteckA Offline
                              arteck
                              #1268
                              @michael-loddoch du kannst da nix machen.. die Serer spinnen wieder..es nervt langsam bei KIA
                              • G Offline
                                GerdSo
                                schrieb am zuletzt editiert von GerdSo
                                #1269
                                @michael-loddoch hast Du die aktuelle Version von github installiert? Der login Mechanismus wurde geändert und dazu brauchst Du die neue Version
                                  Michael Loddoch
                                  #1270
                                  Ich habe bisher alle Instanzen über die Adapterauswahl im IObroker installiert. Demnach habe ich Version 2.2.5.
                                  Auf github habe ich 2.3.2 gefunden. Wäre das die richtige?
                                  Wie man die in IObroker bekommt, muss ich (als Anfänger) aber erst einmal herausfinden ...
                                  • M Michael Loddoch
                                    DaLugi
                                    #1271
                                    Ich habe die 2.3.2 und es geht bei mir anscheinend auch nicht:
                                    Login-Daten sollten aber passen. Geht das beim Rest noch oder habe ich irgendetwas falsch gemacht?
                                    A M 2 Antworten Letzte Antwort
                                    • D DaLugi
                                      Aiouh
                                      #1272
                                      @dalugi ich habe auch V2.3.2 und habe es gerade mal getestet
                                      Login funktioniert, es gibt lediglich ein paar falsche datentypen bei der drive history, was mich nicht stört, die Objekte nutze ich eh nicht.
                                      bluelink.0 2023-07-10 12:16:05.622	info	State value to set for "bluelink.0.xxxxxxxxxxxxxxxxxxx.driveHistory.cumulated03.distance" has to be type "undefined" but received type "number"
                                      bluelink.0 2023-07-10 12:16:05.577	info	State value to set for "bluelink.0.xxxxxxxxxxxxxxxxxxx.driveHistory.cumulated03.regen" has to be type "undefined" but received type "number"
                                      bluelink.0 2023-07-10 12:16:05.534	info	State value to set for "bluelink.0.xxxxxxxxxxxxxxxxxxx.driveHistory.cumulated03.consumption.battery" has to be type "undefined" but received type "number"
                                      bluelink.0 2023-07-10 12:16:05.488	info	State value to set for "bluelink.0.xxxxxxxxxxxxxxxxxxx.driveHistory.cumulated03.consumption.devices" has to be type "undefined" but received type "number"
                                      bluelink.0 2023-07-10 12:16:05.444	info	State value to set for "bluelink.0.xxxxxxxxxxxxxxxxxxx.driveHistory.cumulated03.consumption.climate" has to be type "undefined" but received type "number"
                                      bluelink.0 2023-07-10 12:16:05.400	info	State value to set for "bluelink.0.xxxxxxxxxxxxxxxxxxx.driveHistory.cumulated03.consumption.engine" has to be type "undefined" but received type "number"
                                      bluelink.0 2023-07-10 12:16:05.371	info	State value to set for "bluelink.0.xxxxxxxxxxxxxxxxxxx.driveHistory.cumulated03.consumption.total" has to be type "undefined" but received type "number"
                                      bluelink.0 2023-07-10 12:16:03.766	info	Update for xxxxxxxxxxxxxxxxxxx successfull
                                      bluelink.0 2023-07-10 12:15:30.437	info	Read new update for xxxxxxxxxxxxxxxxxxx directly from the car
                                      bluelink.0 2023-07-10 12:15:30.424	info	1 Vehicles found
                                      bluelink.0 2023-07-10 12:15:26.332	info	Login to api
                                      bluelink.0 2023-07-10 12:15:26.068	info	starting. Version 2.3.2 (non-npm: Newan/ioBroker.bluelink#d92a933047aa0b2276f21f9e8efd25f9a9142a2a) in /opt/iobroker/node_modules/iobroker.bluelink, node: v18.16.0, js-controller: 4.0.24
                                        Michael Loddoch
                                        #1273
                                        Ich habe jetzt auch die 2.3.2 laufen und bekomme leider genau die gleichen 3 Fehlermeldungen wie DaLugi ...
                                        • M Michael Loddoch
                                          DaLugi
                                          #1274
                                          Muss ich noch irgendetwas anderes einstellen? Nutze den Adapter nun zum ersten Mal:
