  4. Adapter Hyundai (Bluelink) oder KIA (UVO)
    6.0k
2.5k Beiträge 161 Kommentatoren 1.2m Aufrufe 147 Beobachtet
  • arteckA arteck
    installiert mal von GIT
    nik82N Offline
    nik82N Offline
    nik82
    #1253
    @arteck
    Du bist der beste :-) Funktioniert wieder!!! 👍
    Vielen, vielen Dank...
    P.S. Vielleicht funktioniert ja jetzt auch der Klimastart bei mir, bekomme Fahrzeug erst wieder in ein paar Tagen, dann werde ich testen.
    • arteckA arteck
      Aiouh
      schrieb am zuletzt editiert von Aiouh
      #1254
      @arteck Login Funktioniert wieder ! Danke.👍
      Allerdings bekomme ich jetzt beim Start Fehlermeldungen:
      bluelink.0 2023-07-04 12:09:20.963	info	undefined is not a valid state value for id "bluelink.0.KNAxxxxxxxxxxxxxxx.driveHistory.cumulated03.distance"
      bluelink.0 2023-07-04 12:09:20.954	info	undefined is not a valid state value for id "bluelink.0.KNAxxxxxxxxxxxxxxx.driveHistory.cumulated03.regen"
      bluelink.0 2023-07-04 12:09:20.946	info	undefined is not a valid state value for id "bluelink.0.KNAxxxxxxxxxxxxxxx.driveHistory.cumulated03.consumption.battery"
      bluelink.0 2023-07-04 12:09:20.938	info	undefined is not a valid state value for id "bluelink.0.KNAxxxxxxxxxxxxxxx.driveHistory.cumulated03.consumption.devices"
      bluelink.0 2023-07-04 12:09:20.921	info	undefined is not a valid state value for id "bluelink.0.KNAxxxxxxxxxxxxxxx.driveHistory.cumulated03.consumption.climate"
      bluelink.0 2023-07-04 12:09:20.892	info	undefined is not a valid state value for id "bluelink.0.KNAxxxxxxxxxxxxxxx.driveHistory.cumulated03.consumption.engine"
      bluelink.0 2023-07-04 12:09:20.880	info	undefined is not a valid state value for id "bluelink.0.KNAxxxxxxxxxxxxxxx.driveHistory.cumulated03.consumption.total"
      bluelink.0 2023-07-04 12:09:19.303	info	Update for KNAxxxxxxxxxxxxxxx successfull
      bluelink.0 2023-07-04 12:09:05.008	info	Read new update for KNAxxxxxxxxxxxxxxx directly from the car
      bluelink.0 2023-07-04 12:09:04.928	info	1 Vehicles found
      bluelink.0 2023-07-04 12:09:01.221	info	Login to api
      • A Aiouh
        arteckA Offline
        arteckA Offline
        arteck
        #1255
        @aiouh sagte in Adapter Hyundai (Bluelink) oder KIA (UVO):
        wo ..ich seh da keine.. nur info
        • ? Offline
          #1256
          @arteck sagte in Adapter Hyundai (Bluelink) oder KIA (UVO):
          ja nur info, hier auch, aber bei JEDEM start.. das ist irritierend.. :-)
          Hab auch schon genau die Datenpunkte geloescht und Adapter neu gestartet...
            arteckA Offline
            arteckA Offline
            arteck
            #1257
            @ilovegym guckmal jetzt
            • arteckA arteck
              #1258
              @arteck
              Immer noch….
              • arteckA arteck
                Aiouh
                #1259
                @arteck sorry, ja sind nur Infos. Ich stell einfach mal den loglevel um, ist als workaround für mich absolut OK.
                • arteckA arteck
                  GerdSo
                  #1260
                  @arteck Bei mir kann er sich zwar einloggen, danach stürzt er aber ab. Aktuelle Version von git und Objekte gelöscht
                  bluelink.0 2023-07-04 14:51:33.380	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                  bluelink.0 2023-07-04 14:51:33.380	info	terminating
                  bluelink.0 2023-07-04 14:51:33.379	info	Adapter bluelink cleaned up everything...
                  bluelink.0 2023-07-04 14:51:33.377	error	Cannot read properties of null (reading 'val')
                  bluelink.0 2023-07-04 14:51:33.377	error	TypeError: Cannot read properties of null (reading 'val') at Bluelink.readStatus (/opt/iobroker/node_modules/iobroker.bluelink/main.js:290:61) at async Te.<anonymous> (/opt/iobroker/node_modules/iobroker.bluelink/main.js:211:17)
                  bluelink.0 2023-07-04 14:51:33.376	error	unhandled promise rejection: Cannot read properties of null (reading 'val')
                  bluelink.0 2023-07-04 14:51:33.376	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                  bluelink.0 2023-07-04 14:51:33.372	debug	Read new status from api for xxxxx
                  bluelink.0 2023-07-04 14:51:33.369	debug	[{"vehicleConfig":{"nickname":"Niro","name":"Niro","regDate":"2023-01-18 13:33:04.996","brandIndicator":"H","id":"3e953589-376b-43a5-8bb4-bd47cae87ef0","vin": --snip-- "_fullStatus":null,"_status":null,"_location":null,"_odometer":null,"region":"EU","serverRates":{"max":-1,"current":-1}}]
                  bluelink.0 2023-07-04 14:51:33.369	info	1 Vehicles found
                  bluelink.0 2023-07-04 14:51:31.518	info	Login to api
                  bluelink.0 2023-07-04 14:51:31.496	info	starting. Version 2.3.2 (non-npm: Newan/ioBroker.bluelink#54a2a58f9f1bd540237a380c9ea08ce2d8657ea3) in /opt/iobroker/node_modules/iobroker.bluelink, node: v18.16.0, js-controller: 4.0.24
                  nik82N 1 Antwort Letzte Antwort
                  • G GerdSo
                    nik82N Offline
                    nik82N Offline
                    nik82
                    #1261
                    @gerdso
                    Als ich deinen Post jetzt gelesen habe, habe ich auch mal den Adapter gestoppt und alle Objekte gelöscht, da ja die Klima jetzt in einem anderen Ordner ist.
                    Habe dann wieder gestartet und jetzt habe ich das gleiche Problem wie du und den gleichen Fehler im Log.
                    • Meister MopperM Online
                      Meister Mopper
                      schrieb am zuletzt editiert von Meister Mopper
                      #1262
                      @arteck
                      Ich bekomme den von github nicht installiert. Es kommt der bekannte 'error 25' bei der Installation.
                      edit:
                      Ich Depp hatte den falschen von github geladen :man-facepalming:
                      Läuft jetzt, vielen Dank!
                      Proxmox und HA ...
                      Ich schreibe den Code nicht mehr selbst – ich schimpfe mit der KI, bis er funktioniert.
                        stefan.cloer
                        #1263
                        Ich habe den gleichen Fehler wie @GerdSo. Auch ich habe vor der Installation alle Objekte gelöscht.
                        • arteckA Offline
                          arteckA Offline
                          arteck
                          #1264
                          jetzt nochmal von GIT
                          G nik82N 2 Antworten Letzte Antwort
                          • arteckA arteck
                            GerdSo
                            #1265
                            @arteck funktioniert, Danke <3
                            • arteckA arteck
                              nik82N Offline
                              nik82N Offline
                              nik82
                              #1266
                              @arteck
                              Bist echt der Wahnsinn!!!
                              Funktioniert, vielen Dank👍
                              P.S. Klimatest kann ich noch nicht machen, Fahrzeug leider noch nicht da...
                                Michael Loddoch
                                #1267
                                Hallo!
                                Leider läuft der tolle Adapter seit 10 Tagen nicht mehr bei mir.
                                Ich bekomme diese Meldungen:
                                Hat jemand vielleicht eine Idee, wie ich ihn wieder zum Laufen bekomme?
                                Ganz viele Grüße!
                                Michael
                                [KIA Ceed SW Plug-in Hybrid]
                                • M Michael Loddoch
                                  Hallo!
                                  Ganz viele Grüße!
                                  Michael
                                  arteckA Offline
                                  arteckA Offline
                                  arteck
                                  #1268
                                  @michael-loddoch du kannst da nix machen.. die Serer spinnen wieder..es nervt langsam bei KIA
                                  • G Offline
                                    GerdSo
                                    schrieb am zuletzt editiert von GerdSo
                                    #1269
                                    @michael-loddoch hast Du die aktuelle Version von github installiert? Der login Mechanismus wurde geändert und dazu brauchst Du die neue Version
                                      Michael Loddoch
                                      #1270
                                      Ich habe bisher alle Instanzen über die Adapterauswahl im IObroker installiert. Demnach habe ich Version 2.2.5.
                                      Auf github habe ich 2.3.2 gefunden. Wäre das die richtige?
                                      Wie man die in IObroker bekommt, muss ich (als Anfänger) aber erst einmal herausfinden ...
                                      • M Michael Loddoch
                                        DaLugi
                                        #1271
                                        Ich habe die 2.3.2 und es geht bei mir anscheinend auch nicht:
                                        Login-Daten sollten aber passen. Geht das beim Rest noch oder habe ich irgendetwas falsch gemacht?
                                        A M 2 Antworten Letzte Antwort
                                        • D DaLugi
                                          Aiouh
                                          #1272
                                          @dalugi ich habe auch V2.3.2 und habe es gerade mal getestet
                                          Login funktioniert, es gibt lediglich ein paar falsche datentypen bei der drive history, was mich nicht stört, die Objekte nutze ich eh nicht.
                                          bluelink.0 2023-07-10 12:16:05.622	info	State value to set for "bluelink.0.xxxxxxxxxxxxxxxxxxx.driveHistory.cumulated03.distance" has to be type "undefined" but received type "number"
                                          bluelink.0 2023-07-10 12:16:05.577	info	State value to set for "bluelink.0.xxxxxxxxxxxxxxxxxxx.driveHistory.cumulated03.regen" has to be type "undefined" but received type "number"
                                          bluelink.0 2023-07-10 12:16:05.534	info	State value to set for "bluelink.0.xxxxxxxxxxxxxxxxxxx.driveHistory.cumulated03.consumption.battery" has to be type "undefined" but received type "number"
                                          bluelink.0 2023-07-10 12:16:05.488	info	State value to set for "bluelink.0.xxxxxxxxxxxxxxxxxxx.driveHistory.cumulated03.consumption.devices" has to be type "undefined" but received type "number"
                                          bluelink.0 2023-07-10 12:16:05.444	info	State value to set for "bluelink.0.xxxxxxxxxxxxxxxxxxx.driveHistory.cumulated03.consumption.climate" has to be type "undefined" but received type "number"
                                          bluelink.0 2023-07-10 12:16:05.400	info	State value to set for "bluelink.0.xxxxxxxxxxxxxxxxxxx.driveHistory.cumulated03.consumption.engine" has to be type "undefined" but received type "number"
                                          bluelink.0 2023-07-10 12:16:05.371	info	State value to set for "bluelink.0.xxxxxxxxxxxxxxxxxxx.driveHistory.cumulated03.consumption.total" has to be type "undefined" but received type "number"
                                          bluelink.0 2023-07-10 12:16:03.766	info	Update for xxxxxxxxxxxxxxxxxxx successfull
                                          bluelink.0 2023-07-10 12:15:30.437	info	Read new update for xxxxxxxxxxxxxxxxxxx directly from the car
                                          bluelink.0 2023-07-10 12:15:30.424	info	1 Vehicles found
                                          bluelink.0 2023-07-10 12:15:26.332	info	Login to api
                                          bluelink.0 2023-07-10 12:15:26.068	info	starting. Version 2.3.2 (non-npm: Newan/ioBroker.bluelink#d92a933047aa0b2276f21f9e8efd25f9a9142a2a) in /opt/iobroker/node_modules/iobroker.bluelink, node: v18.16.0, js-controller: 4.0.24
