  4. Update auf 1.2.3 funktioniert nicht
25 Beiträge 7 Kommentatoren 4.4k Aufrufe
  • J Offline
    jensus11
    Hi, ich wollte heute auf die neue js-controller version 1.2.3 updaten.
    Dabei bekomme ich folgende Fehlermeldung und iobroker lässt sich danach nicht mehr starten.
    Update js-controller from @1.2.0 to @1.2.3
    npm install iobroker.js-controller@1.2.3 --production --prefix "/opt/iobroker" (System call)
    npm WARN deprecated localhost.daplie.me-certificates@1.3.5: this package has been deprecated
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@~0.1.4 (node_modules/iobroker.radar/node_modules/noble/node_modules/xpc-connection):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
    npm ERR! Linux 4.9.0-4-amd64
    npm ERR! argv "/usr/bin/node" "/usr/bin/npm" "install" "iobroker.js-controller@1.2.3" "--production" "--prefix" "/opt/iobroker"
    npm ERR! node v6.12.0
    npm ERR! npm  v3.10.10
    npm ERR! path /opt/iobroker/node_modules/.staging/abbrev-bc1a4de2
    npm ERR! code ENOENT
    npm ERR! errno -2
    npm ERR! syscall rename
    npm ERR! enoent ENOENT: no such file or directory, rename '/opt/iobroker/node_modules/.staging/abbrev-bc1a4de2' -> '/opt/iobroker/node_modules/npm/node_modules/abbrev'
    npm ERR! enoent This is most likely not a problem with npm itself
    npm ERR! enoent and is related to npm not being able to find a file.
    npm ERR! enoent
    npm ERR! Please include the following file with any support request:
    npm ERR!     /opt/iobroker/npm-debug.log
    host.debianioBroker Cannot install iobroker.js-controller@1.2.3: 254
      RappiRN
      Ich hatte auch ein Problem, http://forum.iobroker.net/search.php?keywords=js+controller+update&terms=all&author=&sc=1&sf=all&sk=t&sd=d&sr=posts&st=0&ch=300&t=0&submit=Suche hat mir weiter geholfen:
      http://forum.iobroker.net/viewtopic.php?f=17&t=9100&p=97758&hilit=js+controller+update#p97758 hatte mir hiermit die Lösung gebracht, allerdings erstmal nur Version 1.2.2! Aber es lief wieder!
      @Bluefox:
      Ich empfehle die neuste js-controller vom github zu installieren:
      cd /opt/iobroker
      iobroker stop
      npm i https://github.com/ioBroker/ioBroker.js-controller/tarball/master --production
      iobroker start
      Danach sollte js-controller alle fehlende Pakete selbst nachinstallieren. `
      Enrico
      • J Offline
        jensus11
        so update auf 1.2.2 hat geklappt mit tarball/master–production.
        Dann mit upgrade self weiter gemacht und jetzt kommt das.
        npm ERR! errno -2
        npm ERR! enoent
        npm ERR! code 1
        Host "debianioBroker" (linux) updated
        Execute: chmod -R 777 /opt/iobroker
        Chmod finished. Restart controller
        Starting node restart.js
         Cannot save file /opt/iobroker/node_modules/iobroker.js-controller/lib/objects/../../../../iobroker-data/objects.json: Error: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/../../../../iobroker-data/objects.json'
         Cannot save /opt/iobroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/states.json: Error: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/states.json'
        root@debianioBroker:/opt/iobroker# iobroker start
        module.js:471
            throw err;
        Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
            at Function.Module._resolveFilename (module.js:469:15)
            at Function.Module._load (module.js:417:25)
            at Module.runMain (module.js:604:10)
            at run (bootstrap_node.js:383:7)
            at startup (bootstrap_node.js:149:9)
            at bootstrap_node.js:496:3
          RappiRN
          @jensus11:
          so update auf 1.2.2 hat geklappt mit tarball/master–production. `
          Lass es erstmal dabei, bis sich hier jemand meldet, der mehr Ahnung hat als ich, wichtiger ist doch, dass es wieder läuft. Also nochmal ohne danach wieder upgrade self einzugeben.
          Enrico
          • J Offline
            jensus11
            bei dem Slave ist das update auf 1.2.3 super durchgelaufen.
            • lobomauL Offline
              lobomauL Offline
              lobomau
              @jensus11:
              bei dem Slave ist das update auf 1.2.3 super durchgelaufen. `
              Bei mir auch. Pi3-slave Update von 1.2 auf 1.2.3 ohne Probleme.
              Beim Master traue ich mich noch nicht… :roll:
              Host: NUC8i3 mit Proxmox:
              • Slave: Pi4
                RappiRN
                @jensus11:
                Bei mir auch, Master (PC mit Ubuntu, glaub 16?) ging bei mir nur so, wie oben beschrieben! :(
                Der Workaround oben hat dann wenigstens die Version 1.2.2 gebracht!
                Enrico
                • K Offline
                  knopers1
                  hmm, die Version 1.2.3 wurde installiert, jedoch spuckt es Fehler beim Starten aus…
                  root@orangepiplus2e:/opt/iobroker# iobroker start
                  Starting iobroker controller daemon...
                  /opt/iobroker/node_modules/daemonize2/lib/daemonize.js:136
                  throw new Error(msg.error);
                  Error: Error: Cannot find module 'winston/lib/winston/common'
                  at Module.require (module.js:497:17)
                  at require (internal/module.js:20:19)
                  at Object. <anonymous>(/opt/iobroker/node_modules/winston-daily-rotate-file/index.js:6:14)
                  at Module._compile (module.js:570:32)
                  at Object.Module._extensions..js (module.js:579:10)
                  at Module.load (module.js:487:32)
                  at tryModuleLoad (module.js:446:12)
                  at Function.Module._load (module.js:438:3)
                  at ChildProcess. <anonymous>(/opt/iobroker/node_modules/daemonize2/lib/daemonize.js:136:19)
                  at emitTwo (events.js:106:13)
                  at ChildProcess.emit (events.js:191:7)
                  at process.nextTick (internal/child_process.js:787:12)
                  at _combinedTickCallback (internal/process/next_tick.js:73:7)
                  at process._tickCallback (internal/process/next_tick.js:104:9)
                  root@orangepiplus2e:/opt/iobroker#</anonymous></anonymous>
                    RappiRN
                    @knopers1:
                    Bei dir könnte helfen:
                    npm install winston
                    Das musste ich bei mir, allerdings auf 1.2.2 auch machen, diesen Fehler hatte ich auch drin!
                    Enrico
                      Tiger015
                      Hallo
                      Habe so ein ähnliches problem. Bekommen den admin Bereich auch nicht mehr zum laufen.
                      Bekomme immer diese meldung
                      Error: listen EADDRINUSE 0.0.0.0:9001
                      at Object.exports._errnoException (util.js:1020:11)
                      at exports._exceptionWithHostPort (util.js:1043:20)
                      at Server._listen2 (net.js:1262:14)
                      at listen (net.js:1298:10)
                      at net.js:1408:9
                      at _combinedTickCallback (internal/process/next_tick.js:83:11)
                        Ist es ein RasPi1??
                        (sonst) mach mal einen reboot.
                        Wenn es (bei nicht Pi1) dann wiederkommt hast du ggf. statt drüberzuinstallieren eine zweite Instanz angelegt?
                        Rainer
                          Tiger015
                          Es handelt sich um einen Pi3 und reboot und nach der anleitung hier habe ich es auch schon versucht.
                          alles ohne erfolg.
                          Befehlt iobroker status gibt zurück das es lauft.
                          update habe ich auch alle neu auf gespielt it update self.
                          admin.0 port schon geänder bringt auch kein erfolg.
                            @Tiger015:
                            update habe ich auch alle neu auf gespielt it update self. `
                            update geht aber:
                            sudo iobroker stop
                            sudo iobroker update
                            sudo iobroker upgrade self
                            sudo iobroker start
                            Ich würde aber eher diese Methode wählen:
                            sudo iobroker stop
                            npm cache clean
                            sudo iobroker start
                            Was mich noch irritiert ist:
                            @Tiger015:
                            Hast du eine Multihost Installation?
                            Rainer
                              Tiger015
                              Nein ist kein Multihorst
                              fehler war auch auf einmal von selber da seit heute nach mittage.
                              da vor lief alles noch einbar frei.
                              npm cache clean
                              sudo iobroker start
                              Rüchgabe nach der ausfürhrung:
                              npm WARN enoent ENOENT: no such file or directory, open '/root/package.json'
                              npm WARN root No description
                              npm WARN root No repository field.
                              npm WARN root No README data
                              npm WARN root No license field.
                              root@raspberrypi3:~# iobroker start
                              iobroker controller daemon started. PID: 1982
                              admin ist aber immer nich nicht erreichbar
                              root@raspberrypi3:~# iobroker stop admin.0
                              events.js:160
                                    throw er; // Unhandled 'error' event
                                  at net.js:1408:9
                                RappiRN
                                Ich würde mal sagen, davor fehlt ein:
                                cd /opt/iobroker
                                Oder?
                                Enrico
                                  @RappiRN:
                                  CODE: ALLES AUSWÄHLEN
                                  cd /opt/iobroker `
                                  Das ist ja was ich meinte mit:
                                  @Homoran:
                                  hast du ggf. statt drüberzuinstallieren eine zweite Instanz angelegt? `
                                  Jetzt hat der TE zwei Installationen.
                                  Da sind die Ports natürlich doppelt vergeben.
                                  Rainer
                                    Tiger015
                                    @RappiRN:
                                    cd /opt/iobroker
                                    Oder?
                                    Enrico `
                                    Gleiches ergebniss:
                                    root@raspberrypi3:~# cd /opt/iobroker
                                    root@raspberrypi3:/opt/iobroker# iobroker stop admin.0
                                    events.js:160
                                        at net.js:1408:9
                                      RappiRN
                                      @Homoran:
                                      Da sind die Ports natürlich doppelt vergeben. `
                                      Dann brauchen wir jetzt ne Anleitung, wie einfach zu prüfen wäre, ob denn wirklich zwei Installationen da sind. Ich selbst würde über z.B. winSCP nachsehen, ob noch weitere ioBroker-Ordner angelegt wurden, aber das geht bestimmt auch eleganter! ;)
                                      Enrico
                                      • DutchmanD Offline
                                        DutchmanD Offline
                                        Dutchman
                                        @RappiRN:
                                        Enrico `
                                        Auf Linux gibt es dafür dass"find" Commando.
                                        Komme gerade nicht an meine Installation aber wenn du nach einer Datei/Ordner suchst die es nur im ioBroker Verzeichnis gibt solltest du fündig werden:
                                         Finding a directory
                                        To find a directory called apt in / (root) file system, enter:
                                        Alert: When searching / (root) file system, you need to run the find command as root user.
                                        find / -type d -name "apt"
                                        Sample outputs:
                                        /var/log/apt
                                        /var/lib/apt
                                        /var/cache/apt
                                        /etc/apt
                                        /etc/logrotate.d/apt
                                        /etc/cron.daily/apt
                                        https://www.google.nl/amp/s/www.cyberci … mmand/amp/
                                        Send from mobile device
                                        • J Offline
                                          jensus11
                                          Bei mir hat das zur Lösung geführt.
                                          cd /opt/iobroker
                                          sudo chmod 777 * -R
                                          sudo npm install iobroker.js-controller --production
